  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • M MrNight
    Nun mache mir mal keine Angst 🥲……was aber wohl am Limit läuft ist der Arbeitsspeicher.
    Da kam schon eine Meldung.
    @mrnight sagte in io Broker startet nicht mehr:
    das hilft ohne exakten Wortlaut nichts!
    was sagt denn top
      MrNight
      Bevor ich was zerschiesse….ich habe ja einen MacMini laufen. Der Befehl „Top“ kommt doch von linux.
      Oder wie finde ich es?
      • M MrNight
        und apfelware ist modifiziertes linux
          MrNight
          ommands:
            iobroker setup                                               Setup ioBroker
            iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
            iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
            iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
            iobroker info                                                Shows the host info
            iobroker logs [<adapter>]                                    Monitor log
            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
            iobroker rebuild [<module>]                                  Rebuild all native modules or path
            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
            iobroker update [<repositoryUrl>]                            Update repository and list adapters
            iobroker upgrade                                             Upgrade management
            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
            iobroker object                                              Object management  [aliases: o]
            iobroker state                                               State management  [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
            iobroker list <type> [<filter>]                              List all entries, like objects
            iobroker chmod <mode> <file>                                 Change file rights
            iobroker chown <user> <group> <file>                         Change file ownership
            iobroker touch <file>                                        Touch file
            iobroker rm <file>                                           Remove file
            iobroker file                                                File management
            iobroker user                                                User commands
            iobroker group                                               group management
            iobroker host <hostname>                                     Set host to given hostname
            iobroker set <adapter>.<instance>                            Change settings of adapter config
            iobroker license <license.file or license.text>              Update license by given file
            iobroker cert                                                Certificate management
            iobroker clean <yes>                                         Clears all objects and states
            iobroker backup                                              Create backup
            iobroker restore <backup name or path>                       Restore a specified backup
            iobroker validate <backup name or path>                      Validate a specified backup
            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
            iobroker repo                                                Show repo information
            iobroker uuid                                                Show uuid of the installation  [aliases: id]
            iobroker unsetup                                             Reset license, installation secret and language
            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
            iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
            iobroker multihost                                           Multihost management
            iobroker compact                                             compact group management
            iobroker plugin                                              Plugin management
            iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
          Options:
            --help  Show help  [boolean]
          • M MrNight
            ommands:
            Options:
            @mrnight bitte immer alles zeigen!
            was hast du eingegeben?
              MrNight
              ./IoBroker top habe ich eingegeben.
              • M MrNight
                @mrnight
                top
                ist ein eigenes Programm und hat mit dem iobroker nichts zu tun.
                Ich weiß nur nicht, ob es das bei dir gibt.
                  @mrnight
                  top
                  MrNight
                  Was ich dir so sagen kann ist…..das er in IObroker anzeigt das nur 1GB RAM zur Verfügung stehen…..wenn ich aber beim Mac so schaue hat er noch gute 5GB frei von 8GB.
                  • M MrNight
                    @mrnight
                    Du solltest dir angewöhnen, weniger zu umschreiben und nachzuerzählen. Hier sind eher Fakten (Auszüge aus dem Terminal) gefragt. Da kann man auch mehr mit anfangen...
                    • M MrNight
                      Das hatte ich so ja nicht geschrieben.
                      Deswegen immer alles zeigen.
                      Von der Eingabe bis zum letzten iota der Ausgabe
