  4. Telegram Meldung ignoriert, Uhrzeit falsch?
42 Beiträge 6 Kommentatoren 5.3k Aufrufe 3 Beobachtet
  • AtomicIXA Offline
    AtomicIXA Offline
    AtomicIX
    Hier noch mal der Log, mit Neustart und senden von Befehlen:
    telegram.0
    2025-02-01 13:23:46.092	warn	Message from undefined ignored, because too old: (32000) Alarm Ein
    telegram.0
    2025-02-01 13:23:46.092	debug	{"message_id":38969,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412583,"text":"Alarm Ein"}
    telegram.0
    2025-02-01 13:23:46.092	debug	Received message: {"message_id":38969,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412583,"text":"Alarm Ein"}
    telegram.0
    2025-02-01 13:23:42.293	warn	Message from undefined ignored, because too old: (32000) Temp
    telegram.0
    2025-02-01 13:23:42.293	debug	{"message_id":38967,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412580,"text":"Temp"}
    telegram.0
    2025-02-01 13:23:42.293	debug	Received message: {"message_id":38967,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412580,"text":"Temp"}
    telegram.0
    2025-02-01 13:23:37.308	warn	Message from undefined ignored, because too old: (32000) Status
    telegram.0
    2025-02-01 13:23:37.308	debug	{"message_id":38965,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412575,"text":"Status"}
    telegram.0
    2025-02-01 13:23:37.307	debug	Received message: {"message_id":38965,"from":{"id":233794520,"is_bot":false,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","language_code":"de"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412575,"text":"Status"}
    tuya.0
    2025-02-01 13:23:22.813	info	bfec618747cb2be16fqyt8: Error on Reconnect (7): connection timed out
    tuya.0
    2025-02-01 13:23:22.808	info	bfb57ca31a04d31ee0uqcx: Error on Reconnect (7): connection timed out
    tuya.0
    2025-02-01 13:23:22.808	info	bf6e3bf664db95b0b563pv: Error on Reconnect (7): connection timed out
    tuya.0
    2025-02-01 13:23:20.939	info	bfd00e48eac1982331wna0: Error on Reconnect (7): connect EHOSTUNREACH 192.168.221.171:6668
    tuya.0
    2025-02-01 13:23:19.057	info	bfefff66b01e1b11c4ifow: Error on Reconnect (7): connection timed out
    tuya.0
    2025-02-01 13:23:19.017	info	bf6ca8fbf11f2b48fegk2u: Error on Reconnect (7): connect EHOSTUNREACH 192.168.221.174:6668
    tuya.0
    2025-02-01 13:23:15.196	info	bff281bf90a49cd191hbxi: Error on Reconnect (7): connect EHOSTUNREACH 192.168.222.182:6668
    telegram.0
    2025-02-01 13:23:10.393	debug	Message sent
    telegram.0
    2025-02-01 13:23:10.392	debug	Request [saveSendRequest]: {"message_id":38964,"from":{"id":702553359,"is_bot":true,"first_name":"GartenBot","username":"AtomicGarten_Bot"},"chat":{"id":233794520,"first_name":"Christian","last_name":"xxxx","username":"AtomicIX","type":"private"},"date":1738412548,"text":"_Gartenbot Online"}
    telegram.0
    2025-02-01 13:23:10.392	debug	Message sent
    telegram.0
    2025-02-01 13:23:10.391	debug	Request [saveSendRequest]: {"message_id":38963,"from":{"id":702553359,"is_bot":true,"first_name":"GartenBot","username":"AtomicGarten_Bot"},"chat":{"id":369356584,"first_name":"Jasmin","last_name":"xxxx","username":"atoemchenIX","type":"private"},"date":1738412548,"text":"_Gartenbot Online"}
    telegram.0
    2025-02-01 13:23:10.319	debug	Send message to [atoemchenIX]: "_Gartenbot Online"
    telegram.0
    2025-02-01 13:23:10.319	debug	Send message to [AtomicIX]: "_Gartenbot Online"
    telegram.0
    2025-02-01 13:23:10.318	debug	getMe: {"id":702553359,"is_bot":true,"first_name":"GartenBot","username":"AtomicGarten_Bot","can_join_groups":true,"can_read_all_group_messages":false,"supports_inline_queries":false,"can_connect_to_business":false,"has_main_web_app":false}
    telegram.0
    2025-02-01 13:23:10.048	debug	Start polling with: 2000(number) ms interval
    telegram.0
    2025-02-01 13:23:09.887	info	starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v20.18.1, js-controller: 7.0.6
    telegram.0
    2025-02-01 13:23:09.765	debug	Plugin sentry Initialize Plugin (enabled=true)
    telegram.0
    2025-02-01 13:23:09.750	debug	States connected to redis: 127.0.0.1:9000
    telegram.0
    2025-02-01 13:23:09.696	debug	States create User PubSub Client
    telegram.0
    2025-02-01 13:23:09.696	debug	States create System PubSub Client
    telegram.0
    2025-02-01 13:23:09.689	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    telegram.0
    2025-02-01 13:23:09.674	debug	Objects connected to redis: 127.0.0.1:9001
    telegram.0
    2025-02-01 13:23:09.672	debug	Objects client initialize lua scripts
    telegram.0
    2025-02-01 13:23:09.558	debug	Objects create User PubSub Client
    telegram.0
    2025-02-01 13:23:09.558	debug	Objects create System PubSub Client
    telegram.0
    2025-02-01 13:23:09.558	debug	Objects client ready ... initialize now
    telegram.0
    2025-02-01 13:23:09.543	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.ioBroker
    2025-02-01 13:23:09.114	info	instance system.adapter.telegram.0 in version "4.0.0" started with pid 190323
    host.ioBroker
    2025-02-01 13:23:05.906	info	instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Hier noch mal der Auzug aus dem iob diag:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
    Operating System: Ubuntu 24.10
              Kernel: Linux 6.8.12-4-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:25:33 up 3 days, 20:44,  2 users,  load average: 0.13, 0.35, 0.28
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'oracular' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-02-01 13:25:33 CET
               Universal time: Sat 2025-02-01 12:25:33 UTC
                     RTC time: n/a
    System clock synchronized: no
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            6.4G        2.1G        2.1G        163K        2.2G        4.3G
    Swap:           1.1G        4.1K        1.1G
    Total:          7.5G        2.1G        3.2G
    Active iob-Instances:   35
             6144 M total memory
             2038 M used memory
             2009 M active memory
             1935 M inactive memory
             2007 M free memory
                0 M buffer memory
             2097 M swap cache
             1024 M total swap
                0 M used swap
             1023 M free swap
    top - 13:25:33 up 3 days, 20:44,  2 users,  load average: 0.13, 0.35, 0.28
    Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   6144.0 total,   2005.4 free,   2040.7 used,   2098.1 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   4103.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    @Homoran ja das werde ich probieren. Aber alles was ich dazu gefunden habe, hat bis jetzt nicht funktioniert.
    Mir ist eben aufgefallen, das die Web Version von Telegram nicht mehr geht. Ist das nur bei mir so, oder wurde die abgeschaltet?
    • AtomicIXA AtomicIX
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      telegram.0
      host.ioBroker
      host.ioBroker
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               6144 M total memory
               2038 M used memory
               2007 M free memory
                  0 M buffer memory
               2097 M swap cache
               1024 M total swap
                  0 M used swap
               1023 M free swap
      @atomicix sagte in Telegram Meldung ignoriert, Uhrzeit falsch?:
      was soll das sein?
      Telegram für Win?
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        telegram.0
        host.ioBroker
        host.ioBroker
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 6144 M total memory
                 2038 M used memory
                 2007 M free memory
                    0 M buffer memory
                 2097 M swap cache
                 1024 M total swap
                    0 M used swap
                 1023 M free swap
        • AtomicIXA Offline
          AtomicIXA Offline
          AtomicIX
          @homoran sagte in Telegram Meldung ignoriert, Uhrzeit falsch?:
          1738412580
          Ich bekomme das einfach nicht hin.
          Egal ob auf dem System im Garten, das jetzt lange Zeit ohne Probleme lief, sowohl auch das relativ neue System 2 Monate alt, das hier zuhause steht, laufen nicht mit dem Bot und Commandos.
          Die Zeit Sync soll wohl aus dem Hauptsystem von Proxmox kommen und dann an den LXC weitergereicht werden.
          Ich habe echt keine Ahnung was/wie/warum das zusammen hängt.
          Werde gleich mal iobroker auf nen Raspaberry installieren und gucken ob es da läuft.
          Es gibt sonnst Telegram direkt übern Browser: https://web.telegram.org/ aber das geht scheinbar auch nicht mehr.
            1738412580
            BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            @atomicix also wie @Homoran auch feststellen konnte sind da 42 Sekunden Abweichung.
            Meistens ist bis 30 Sekunden Abweichung egal bzw. wird noch toleriert (ob das bei Telegram auch so ist weis sich nicht).
            Beruflich muss ich mich auch um Zeit-Synchronität in den Netzen kümmern - wobei dabei wichtiger ist das alle die gleiche Zeit haben, auch wenn die vielleicht daneben liegt.
            Also wäre ein Ansatz dafür zu sorgen das alle den gleichen Zeitserver nehmen.
            Dein Host läuft mit Proxmox. Da gibt es diese Anleitung:
            https://pve.proxmox.com/wiki/Time_Synchronization
            Den Einträgen nach läuft da noch der "klassische" ntp.service
            Bei mir ist in der Datei
            /etc/chrony/chrony.conf
            der Debian-Pool voreingestellt:
            # Include configuration files found in /etc/chrony/conf.d.
            confdir /etc/chrony/conf.d
            # Use Debian vendor zone.
            pool 2.debian.pool.ntp.org iburst
            # Use time sources from DHCP.
            sourcedir /run/chrony-dhcp
            # Use NTP sources found in /etc/chrony/sources.d.
            sourcedir /etc/chrony/sources.d
            Die anderen Optionen greifen bei mir nicht, /etc/chrony/conf.d ist bis auf eine README leer, die IP des Proxmox ist fest eingestellt so das es das Verzeichnis /run/chrony-dhcp nicht gibt und /etc/chrony/sources.d ist auch leer bis auf die README.
            Der benutzt bei mir also nur den Pool 2.debian.pool.ntp.org
            Ok, nutzen wir eine gemeinsame Zeitquelle für alle Geräte. Das kann die FRITZ!Box sein oder z.B. meine Lieblinge zeit.fu-berlin.de und time.fu-berlin.de, siehe https://www.zedat.fu-berlin.de/Time-Service (ja, das sind 2 verschiedene Server)
            Also ändern wir das in der Datei /etc/chrony/chrony.confwie folgt ab:
            #pool 2.debian.pool.ntp.org iburst
            server zeit.fu-berlin.de iburst
            server time.fu-berlin.de iburst
            und den Dienst neu starten:
            systemctl restart chronyd
            und nach einiger Zeit prüfen ob das klappt:
            root@proxmox01:~# journalctl --since -1h -u chrony
            Feb 02 14:26:26 proxmox01 chronyd[1148]: chronyd exiting
            Feb 02 14:26:26 proxmox01 systemd[1]: Stopping chrony.service - chrony, an NTP client/server...
            Feb 02 14:26:26 proxmox01 systemd[1]: chrony.service: Deactivated successfully.
            Feb 02 14:26:26 proxmox01 systemd[1]: Stopped chrony.service - chrony, an NTP client/server.
            Feb 02 14:26:26 proxmox01 systemd[1]: Starting chrony.service - chrony, an NTP client/server...
            Feb 02 14:26:26 proxmox01 chronyd[922074]: chronyd version 4.3 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 -DEBUG)
            Feb 02 14:26:26 proxmox01 chronyd[922074]: Frequency -40.622 +/- 0.028 ppm read from /var/lib/chrony/chrony.drift
            Feb 02 14:26:26 proxmox01 chronyd[922074]: Using right/UTC timezone to obtain leap second data
            Feb 02 14:26:26 proxmox01 chronyd[922074]: Loaded seccomp filter (level 1)
            Feb 02 14:26:26 proxmox01 systemd[1]: Started chrony.service - chrony, an NTP client/server.
            Feb 02 14:26:31 proxmox01 chronyd[922074]: Selected source 160.45.10.8 (zeit.fu-berlin.de)
            Feb 02 14:26:31 proxmox01 chronyd[922074]: System clock TAI offset set to 37 seconds
            Interessanterweise hatte ich wohl ein Offset von 37 Sekunden .....
            So, nun noch die ioBroker VM (oder Container?).
            Ein Container sollte die Zeit des Hosts übernehmen. Hier sollte also nichts zu tun sein. Außer das ggf. die richtige Zeitzone eingestellt werden muss.
            timedatectl set-timezone Europe/Berlin
            Wenn es eine VM ist, dann müsste man schauen welchen Zeitprovider diese benutzt.
            Neuere System sollten den systemd-timesyncd.service nutzen, das prüfst du per
            systemctl status systemd-timesyncd.service
            Läuft der Dienst kannst du diese Datei bearbeiten:
            nano /etc/systemd/timesyncd.conf
            und setzt folgende 2 Einträge bzw. änderst die vorhandenen:
            [Time]
            NTP=zeit.fu-berlin.de
            FallbackNTP=time.fu-berlin.de
            Wichtig ist auch den Fallback zu setzen, der steht sonst auch auf einer Pool-Adresse
            Dann den Dienst neu starten
            systemctl restart systemd-timesyncd.service
            und nach einer Weile prüfen:
            timedatectl show-timesync
            Wenn es den Dienst nicht gibt / der nicht läuft, prüfe ob der NTP läuft:
            systemctl status ntp.service
            ist der es, so bearbeite folgende Datei:
            nano /etc/ntp.conf
            Die Einträge sind wie auf dem Proxmox-Host,
            also alle Zeilen die mit pool oder server anfangen, auskommentieren und nur diese beiden setzen:
            Dann den Dienst neu starten:
            systemctl restart ntp.service
            und nach einer Weile mit
            ntpq -p
            prüfen.
            Ggf. prüfst bei einem Container ob da nicht trotzdem etwas läuft.
            Wie beschrieben hatte ich 37 Sekunden Abweichung meines Proxmox-Host ...
            • BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              Nachtrag: Also bei mir zu Hause ist alles was den Ubuntu-Pool, die FRITZ!Box oder die TU-Berlin Server nutzt im Millisekunden-Bereich auseinander.
              Alle 3 Proxmox-Server aus dem Cluster (auch der eine der als VM unter VMware auf einem ESXi läuft), wichen um 37 Sekunden davon ab.
              Die Proxmox-Backup-Appliance die auf dem ESXi läuft hatte die richtige Zeit.
              Wobei ich bei meiner Recherche irgendwo meine gelesen zu haben das die Proxmox-System in einem Cluster peinlich genau ihre untereinander abstimmen weil es sonst Probleme gibt
              AtomicIXA 1 Antwort Letzte Antwort
              • AtomicIXA Offline
                AtomicIXA Offline
                AtomicIX
                Das ist ja Wahnsinn was du da zusammen getragen hast. Vielen dank dafür.
                Ich habe gestern Abend einen Raspi3 mit iobroker aufgesetzt und dort ein aktueller Backup eingespielt.
                (Wusste gar nicht mehr, wie langsam son Rapsi ist :( )
                Hat natürlich alles funktioniert, mit Telegram ect.
                Also nachdem ich noch noch einiges an Zeit in einem Proxmox System gesteckt habe und damit auch gescheitert bin, habe ich auf meinem Test/Ersatzsystem ein sauberes Proxmox aufgesetzt und alles neu eingerichtet. Jetzt läuft alles.
                Wenn ich jetzt die nächsten Tage in Garten komme, werde ich die Systeme tauschen und das fehlerhafte Gartensystem hier zuhause mal mit deinen Informationen füttern bzw. probieren woran es gelegen hat. Vielleicht komme ich ja mit deiner Anleitung weiter.
                Da ich eh die NVE tauschen wollte, kann ich das jetzt umsetzten. Nach 3 Jahren 24/7 kann man das mal machen.
                Also vielen dank @BananaJoe , ich werde die nächsten Tage berichten, was ich geworden bin.
                  (Wusste gar nicht mehr, wie langsam son Rapsi ist )
                  Der 3er ist mittlerweile mit seinem 1GB RAM zu klein. Die aktuellen Versionen 4&5 mit mehr RAM sind deutlich performanter.
                  • BananaJoeB BananaJoe
                    AtomicIXA Offline
                    AtomicIXA Offline
                    AtomicIX
                    @bananajoe
                    nun habe ich es mal geschafft, die Systeme zu tauschen.
                    Habe mein Ersatzsystem mit neuer NVE und alles frisch aufgesetzt in Garten gepflanzt. Es ist sehr gut angewachsen .
                    Läuft alles super.
                    Nun habe ich also mein altes Gartensystem mit den Uhrzeit Fehler zuhause.
                    Habe es einmal alles frisch upgedatet, also das Proxmox/Linux System.
                    Nun läuft es wieder einwandfrei mit der Uhrzeit 🙄
                    Vielleicht hat sich beim letzten Update im Garten ( I-Net über Sim) vielleicht irgendetwas verschluckt, wobei mein relativ frisches Ersatzsystem (was ich ja jetzt noch mal neu gemacht habe und jetzt im Garten läuft) hier zuhause ja auch Probleme hatte.
                    Also es läuft, leider konnte ich jetzt keinen Fehler feststellen und muss es hinnehmen, das es wieder geht.
                    Ich bedanke mich jedenfalls für die Unterstützung.
                      AtomicIXA Offline
                      AtomicIXA Offline
                      AtomicIX
                      meine 2x Rpi4 mit 4Gb Ram hatte ich zur Kriese ( vor 2 Jahren oder so) für einen sehr guten Preis verkauft.
                      Habe ja eigentlich mit den 2 NUC's eine sehr gute alternative. Für kleine Bastelprojekte reichen mir die 3er noch.
                      War hat nur erschrocken, wie langsam das ist, im Gegensatz zum NUC Gen10 mit i7 und i3 und 32GB Ram :)
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        @atomicix ich habe vor ein paar Monaten mal einen Pi 1 und Pi 2 mal wieder in Betrieb genommen ... die hatte ich früher als Eigenbau AccessPoint genutzt, und jetzt um ein Relais zu schalten. Habe es dann gelassen.
                        Nö, da ist man inzwischen verwöhnt ...
                          @bananajoe
                          Läuft alles super.
                          @atomicix was sagt denn das System zum ntp?
                            AtomicIXA Offline
                            AtomicIXA Offline
                            AtomicIX
                            Also im Proxmox Root System habe ich:
                            root@Proxmox:~# timedatectl status
                                           Local time: Wed 2025-02-05 15:05:15 CET
                                       Universal time: Wed 2025-02-05 14:05:15 UTC
                                             RTC time: Wed 2025-02-05 14:05:15
                                          NTP service: active
                                      RTC in local TZ: no
                            und im LXC Container:
                            iobroker@ioBroker:~$ timedatectl status
                                           Local time: Mi 2025-02-05 15:07:04 CET
                                       Universal time: Mi 2025-02-05 14:07:04 UTC
                                             RTC time: n/a
                                      RTC in local TZ: yes
                            So scheint es jedenfalls zu funktionieren.
                                            NTP service: active
                                        RTC in local TZ: no
                                               RTC time: n/a
                              Noch!??
                              bis die Zeiten wiedrr auseinander driften
                                              NTP service: active
                                          RTC in local TZ: no
                                                 RTC time: n/a
                                  RTC in local TZ: no
                                und
                                Da es aber nur eine RTC/RealTimeClock gibt sollten da auch die Einstellungen imho gleich sein.
                                  Noch!??
                                  AtomicIXA Offline
                                  AtomicIXA Offline
                                  AtomicIX
                                  Mein Fehler, das war das alte Garten System, das jetzt hier zuhause steht, das Livesystem im Garten hat:
                                                 Local time: Mi 2025-02-05 15:12:25 CET
                                             Universal time: Mi 2025-02-05 14:12:25 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                  • AtomicIXA Offline
                                    AtomicIXA Offline
                                    AtomicIX
                                    Ich brauche noch mal Hilfe.
                                    Das Problem ist wieder da.
                                    Ich habe gestern das Proxmox System neu gestartet und Telegram läuft wieder nicht.
                                    In Proxmox habe ich:
                                                     RTC time: Wed 2025-02-19 14:53:03 UTC
                                                  NTP service: active
                                              RTC in local TZ: no
                                    und im LXC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    Das scheint aber auch nur im Garten zu sein. Zuhause läuft das alles.
                                    Zuhause hängt der NUC über ein USB -> LAN Adapter direkt an meiner FB 6690
                                    im Garten hängt der NUC direkt am LAN an einer FB 4060 und als Modem habe ich ein Zyxel FWA 505 5G Router.
                                    Die 5060 ist aber der DNS im Netzwerk.
                                    Vor meinem ganzen Umbau, als es sehr lange ohne Probleme lief, hatte ich eine FB 6850LTE.
                                    Ich habe die Vermutung, das durch die Kombi FB und Zyxel vielleicht irgendetwas blockiert wird?
                                    Kann ich das irgendwie prüfen?
                                    Das aktuelle Proxmox System ist quasi auf Standard was die NTP/RTC Einstellung betrifft, was zuhause auch läuft.
                                    Somit schien die Config ok zu sein.
                                    Ich hatte ja am Anfang, als ich die Probleme hatte, schon einmal die alte 6850 wieder eingebaut und es lief auch nicht, aber vielleicht habe ich auch nicht lange genug gewartet?
                                    Dazu kommt momentan ist es halt sehr kalt und ich habe jetzt nicht die Lust, Stunden im Garten zu sitzen und rum zu stochern um eine Lösung zu finden.
                                    Über Remote komme ich nur auf den LXC vom iobroker und auf die FB, aber nicht auf das Proxmox System. Das war schon immer so und muss an der Mobilfunkverbindung liegen. Von daher würde ich mich über Ergebnisse freuen, die ich Vorort im Schrebergarten probieren kann.
                                    Noch mal die alte 6850 verbauen und warten? Wie lange?
                                    Über Unterstützung wäre ich sehr dankbar.
                                      BananaJoeB Offline
                                      BananaJoe
                                      Naja, NTP scheint an, synchronisiert aber nichts.
                                      Da oben hatte ich eine längere Anleitung gepostet was man machen kann: https://forum.iobroker.net/post/1245092
                                      Die vor eingestellten Debian-Zeitserver waren bei mir da auch Mist. Ist bei mir nur nicht aufgefallen weil ich nur Ubuntu und Windows-VMs habe, und die holen sich die Zeit separat von woanders - und nur beim Start die vom Virtualisierungshost
                                      • AtomicIXA Offline
                                        AtomicIXA Offline
                                        AtomicIX
                                        schrieb am zuletzt editiert von AtomicIX
                                        So, bin heute mal 2h im Garten gewesen und habe Probiert.
                                        Das System das zuhause ohne Probleme, funktioniert hat, als Sync und NTP/RTC alles gut, läuft im Garten nicht.
                                        im Root System :
                                                   RTC time: Wed 2025-02-20 15:58:03 UTC
                                                      NTP service: active
                                        im LXC:
                                                   RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        Das system aus dem Garten hier zuhause läuft hingegen Problemlos.
                                        Also es scheint nicht an den Einstellungen vom Proxmox System zu liegen, sondern irgendwie mit der Fritzbox/Zyxel System
                                        Ich hatte jetzt keine Lust mehr, weil kalt und die Gasflasche ist leer, noch die Fritzbox gegen die alte zu tauschen.
                                        Müsste dann ja noch ne weile warten, um sicher zu sein, das auch alles Synchronisiert ist.
                                        Hab ihr ne Idee, ob oder wie ich testen kann, ob es an der FB oder Sim Verbindung liegen kann?
                                        Internet generell läuft echt super.
                                        So langsam bin ich echt am verzweifeln. 😖
                                          im Root System :
                                                        NTP service: active
                                          im LXC:
                                                     RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          @atomicix was hast du denn Probiert?
                                          So muss das auf dem Host aussehen:
                                          root@proxmox01:~# timedatectl status
                                                         Local time: Thu 2025-02-20 19:48:33 CET
                                                     Universal time: Thu 2025-02-20 18:48:33 UTC
                                                           RTC time: Thu 2025-02-20 18:48:33
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          Und so in der VM / Container (wobei der vermutlich die richtige zeit hat wenn der Host die hat):
                                          root@piholepm:~# timedatectl status
                                                         Local time: Do 2025-02-20 19:49:51 CET
                                                     Universal time: Do 2025-02-20 18:49:51 UTC
                                                           RTC time: Do 2025-02-20 18:49:51
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          root@piholepm:~#
                                          man beachte die Zeile mit
                                          Wenn du Zeitserver aus dem Internet konfiguriert hast und diese für den Host erreichbar sind, ist alles andere egal.
                                          Wobei die FRITZ!Boxen in der Regel auch die genaue Zeit liefern.
                                          Darf ich noch mal auf meinen obigen Beitrag verweisen?
