  4. Test Adapter flexcharts - Stapeldiagramme und mehr
chartchartsdiagrammeechartsvisualisierungvisualization
280 Beiträge 21 Kommentatoren 75.7k Aufrufe 24 Beobachtet
  • Merlin123M Merlin123
    @jrbwh Jup... sehen bei mir auch so aus:
    const IDS = { hourly:  'tibberlink.0.Homes.xxx.Consumption.jsonHourly',  // hourly data
                  daily:   'tibberlink.0.Homes.xxx.Consumption.jsonDaily',  // daily data
                  weekly:  'tibberlink.0.Homes.xxx.Consumption.jsonWeekly',  // weekly data
                  monthly: 'tibberlink.0.Homes.xxx.Consumption.jsonMonthly'   // monthly data
    Aktualisierung:
    Das hab ich überlesen.
    Wenn die aber beim Laden des Frames aktualisiert werden, reicht mir das auch :)
    jrbwhJ Offline
    jrbwhJ Offline
    jrbwh
    #174
    @merlin123 Gut. Hier mal ein Skript zum Testen:
    // Create chart for Tibber data. To be used with flexcharts.
    // Sample http request for hourly data chart:
    // http://localhost:8082/flexcharts/echarts.html?source=script&message=tibber&chart=hourly
    // Replace 'MY-TOKEN' with your own token:
    const ID_TIBBER = 'tibberLink.0.Homes.MY-TOKEN.Consumption';
    const IDS = { hourly:  '.jsonHourly',  // hourly data
                  daily:   '.jsonDaily',   // daily data
                  weekly:  '.jsonWeekly',  // weekly data
                  monthly: '.jsonMonthly'  // monthly data
    onMessage('tibber', (httpParams, callback) => {
        // Use hourly data in case of invalid chart type
        const id = (httpParams.chart && httpParams.chart in IDS ? ID_TIBBER+IDS[httpParams.chart] : ID_TIBBER+IDS['hourly']);
        if (existsState(id)) {
            evalTibberData(httpParams.chart, id, result => callback(result));
        } else {
            console.log('Requested state is not available >>'+id+'<<');
            callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "REQUESTED STATE IS NOT AVAILABLE: >>" + id +"<<" }});
    function evalTibberData(myChart, id, callback) {
        const tibber = JSON.parse(getState(id).val);  // Read tibber data
        const chart = {
                        tooltip: { trigger: "axis", axisPointer: { type: "cross" }},
                        legend: { show: true, orient: "horizontal", left: "center", top: 25 },
                        title: { left: "center", text: "Tibber " },
                        grid: { right: "20%" },
                        toolbox: { feature: { dataView: { show: true, readOnly: false }, restore: { show: true }, saveAsImage: { show: true }}},
                        xAxis: [{ type: "category", axisTick: { alignWithLabel: true }, data: []}],
                        yAxis: [{ type: "value", position: "left",  alignTicks: true, axisLine: { show: true, lineStyle: { color: "#5470C6" }}, axisLabel: { formatter: "{value} kWh" }},
                                { type: "value", position: "right", alignTicks: true, axisLine: { show: true, lineStyle: { color: "#91CC75" }}, axisLabel: { formatter: "{value} €" }}],
                        series: [{ name: "Consumption", type: "bar", yAxisIndex: 0, data: []},
                                 { name: "Cost",        type: "bar", yAxisIndex: 1, data: []}]
        const xAxis  = [];
        const yAxis0 = [];
        const yAxis1 = [];
        for (const data of Object.values(tibber)) {
            const isHourly = (myChart == 'hourly');  // Hourly data?
            const xValue = (isHourly ? new Date(data.from).toLocaleTimeString() : new Date(data.from).toLocaleDateString());
            xAxis.push(xValue);
            yAxis0.push((data.consumption ? data.consumption.toFixed(2) : 0));  // push 0 on null values
            yAxis1.push((data.cost ? data.cost.toFixed(2) : 0));                // push 0 on null values
        chart.xAxis[0].data  = xAxis;       // Set chart x-axis data
        chart.series[0].data = yAxis0;      // Set chart y-values consumption
        chart.series[1].data = yAxis1;      // Set chart y-values cost
        chart.title.text += myChart;             // Add type of chart to title
        console.log('Evaluation of tibber '+myChart+' data done.');
        callback(chart);
    Merlin123M 1 Antwort Letzte Antwort
    • jrbwhJ jrbwh
          } else {
          const chart = {
          const xAxis  = [];
          const yAxis0 = [];
          const yAxis1 = [];
              xAxis.push(xValue);
          callback(chart);
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #175
      @jrbwh nope...
      der Name des DPs sieht aber richtig aus....
      Beta-Tester
      jrbwhJ 1 Antwort Letzte Antwort
        @jrbwh nope...
        jrbwhJ Offline
        jrbwhJ Offline
        jrbwh
        #176
        @merlin123 Ups, es muss tibberlink heißen und nicht tibberLink (mit großem L). Bitte nochmal mit kleinem l probieren.
        • jrbwhJ jrbwh
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          #177
          @jrbwh Geht :) Das hab ich jetzt auch nicht gesehen :P
          Beta-Tester
            jrbwhJ Offline
            jrbwhJ Offline
            jrbwh
            #178
            @merlin123 Hab auch eine Weile gebraucht. Aber es musste ein Schreibfehler sein.
            Werde gleich den Beitrag unter "Discussions" entsprechend anpassen.
            Danke!
            • jrbwhJ jrbwh
              Danke!
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              schrieb am zuletzt editiert von Merlin123
              #179
              @jrbwh Gern.... Bei Hourly macht das Format der Zeit keinen Sinn... Minuten und Sekunden braucht man da nicht. Kann man das anpassen?
              Beta-Tester
                jrbwhJ Offline
                jrbwhJ Offline
                jrbwh
                #180
                @merlin123 sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
                Stimmt. Hab ich auch gleich geändert. Minuten finde ich aber schon sinnvoll. Kannst Du leicht entfernen, wenn Du den Eintrag , minute: '2-digit' löscht.
                • jrbwhJ jrbwh
                  Merlin123M Offline
                  Merlin123M Offline
                  Merlin123
                  #181
                  @jrbwh Funktioniert :) Minuten sind optisch schöner, stimmt
                  Muss jetzt nur die Änderungen in meinem angepassten Script als nachziehen :D Hab die Farben angepasst, da ich keinen weißen Hintergrund habe.
                  Mir ist noch was aufgefallen, keine Ahnung wo man das anpasst:
                  Es wird z,B. "1,234.56 kWh" angezeigt. Im Deutschen müsste das aber "1.234,56" heißen.
                  Idee:
                  Farben für die einzelnen Sachen als Variable am Anfang deklarieren...
                  Aber das ist eher der Goldrand, den man nicht unbedingt braucht ;)
                  Beta-Tester
                    Idee:
                    jrbwhJ Offline
                    jrbwhJ Offline
                    jrbwh
                    #182
                    Ja, auch eine gute Idee. Man könnte auch in der Konstante IDS für jeden Chart-Typ eigene Farben vorsehen und im Skript passend zuweisen.
                    Es soll ja aber eigentlich eine Vorlage sein und auch zu eigenen Experimenten anregen. Deshalb werde ich es jetzt erstmal so lassen. Du kannst natürlich gerne Weiterentwicklungen in der Diskussion posten.
                    • jrbwhJ jrbwh
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #183
                      @jrbwh Muss mal schauen, was ich da noch anpasse, aktuell passt es erstmal.
                      Weißt zu zufällig, wie man die Darstellung der Tausender anpassen kann?
                      Beta-Tester
                      • icebearI Offline
                        icebearI Offline
                        icebear
                        #184
                        Was mir noch nicht so ganz klar ist, wie bekomme ich den die Daten aus den DP's z.B. Heizung (VLT, AT, RLT) in ein Array so das ich es dann als Datenreihe im Fexchart verarbeiten kann?
                        Also ich hab die drei DP's in denen die Werte stehen und die auch in InfluxDB gespeichert werden. So wie ich es Vertsanden hab müssen die ja irgendwie in ein Daten Array kommen z.B. Tägliche, Wöchentlich oder Monatliche Werte. Wie stell ich das an.
                        jrbwhJ L 2 Antworten Letzte Antwort
                          jrbwhJ Offline
                          jrbwhJ Offline
                          jrbwh
                          #185
                          @merlin123 Meinst Du die Darstellung im Tooltip? Das geht, ist aber nicht ganz einfach. Schau Dir mal dieses Issue an und den Abschnitt zu "Functions" im Readme an.
                          • icebearI icebear
                            jrbwhJ Offline
                            jrbwhJ Offline
                            jrbwh
                            #186
                            @icebear Das geht nur über ein Skript (Blockly oder Javascript). Schau Dir mal die Templates (siehe im Readme) an, oder z.B. diesen oder diesen Beitrag in Discussions.
                            • jrbwhJ jrbwh
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #187
                              @jrbwh Danke für den Link. Muss ich mir heute Mittag mal anschauen.
                              Hab hier noch was gefunden. Muss ich mal testen. Da hatte jemand das gleiche Problem
                              Beta-Tester
                              • icebearI icebear
                                legro
                                #188
                                @icebear sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
                                Schau mal hier vorbei! Dort findest du alle Techniken, die du benötigst und wie man sie handhabt.
                                Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                                  Aktualisierung:
                                  M-A HuebM Offline
                                  M-A HuebM Offline
                                  M-A Hueb
                                  #189
                                  @merlin123 wenn ich das Richtig gesehn hab bei deinem TestSkript wird unter dem DP flexcharts.0.info kein Punkt angelegt.
                                  könnte man das noch mit rein machen?
                                  Woher bekomme ich die URL die bei dir im Kommentar steht?
                                  iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                                  • M-A HuebM M-A Hueb
                                    Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #190
                                    @m-a-hueb Welches Script von mir meinst Du?
                                    Beta-Tester
                                    M-A HuebM 1 Antwort Letzte Antwort
                                      M-A HuebM Offline
                                      M-A HuebM Offline
                                      M-A Hueb
                                      #191
                                      @merlin123 von dem hier:
                                          } else {
                                          const chart = {
                                          const xAxis  = [];
                                          const yAxis0 = [];
                                          const yAxis1 = [];
                                              xAxis.push(xValue);
                                          callback(chart);
                                      • M-A HuebM Offline
                                        M-A HuebM Offline
                                        M-A Hueb
                                        schrieb am zuletzt editiert von M-A Hueb
                                        #192
                                        hab hier mal 2 Charts gebaut. Dank geht an
                                        @jrbwh für die Grundidee und ChatGPT:
                                        const ID_TIBBER = 'tibberlink.0.Homes.MY-TOKEN.Consumption';
                                            } else {
                                            const chart = {
                                            const xAxis  = [];
                                            const yAxis0 = [];
                                            const yAxis1 = [];
                                                xAxis.push(xValue);
                                            chart.title.text = "Tibber stündliche Kosten";             // Add type of chart to title
                                            callback(chart);
                                        und das hier:
                                        //http://localhost:8082/flexcharts/echarts.html?source=script&message=tibberpreis&chart=hourly&darkmode
                                        const ID_TIBBER = 'tibberlink.0.Homes.MY-HOME-ID.PricesToday';
                                        onMessage('tibberpreis', (httpParams, callback) => {
                                            console.log("Anfrage für Tibber-Daten:", httpParams);
                                            const id = ID_TIBBER + '.json'; // Stündliche Daten für heute
                                                evalTibberData(id, result => callback(result));
                                            } else {
                                                console.warn('Datenpunkt nicht verfügbar:', id);
                                                callback({
                                                    title: {
                                                        left: "center",
                                                        text: "Daten nicht verfügbar: >>" + id + "<<"
                                        function evalTibberData(id, callback) {
                                            console.log("Lese Tibber-Daten:", id);
                                            let tibber;
                                            try {
                                                console.log("Tibber-Daten geladen:", tibber);
                                            } catch (error) {
                                                console.error("Fehler beim Parsen:", error);
                                                callback({
                                                    title: { left: "center", textStyle: { color: "#ff0000" }, text: "FEHLER BEIM PARSEN" }
                                                return;
                                            if (!Array.isArray(tibber) || tibber.length === 0) {
                                                console.error("Keine gültigen Daten:", tibber);
                                                callback({
                                                    title: { left: "center", textStyle: { color: "#ff0000" }, text: "KEINE GÜLTIGEN DATEN VERFÜGBAR" }
                                                return;
                                            console.log("Verarbeite", tibber.length, "Einträge.");
                                            const currentHour = new Date().getHours(); // Aktuelle Stunde holen
                                            console.log("Aktuelle Stunde:", currentHour);
                                            const chart = {
                                                tooltip: {
                                                    trigger: "axis",
                                                    axisPointer: { type: "shadow" },
                                                    formatter: function (params) {
                                                        let energyPrice = 0;
                                                        let taxPrice = 0;
                                                        let totalPrice = 0;
                                                        // Berechne die Werte von Energiepreis, Steuern und Gesamtkosten aus den aktuellen Tooltip-Elementen
                                                        params.forEach(function (item) {
                                                            if (item.seriesName === "Energiepreis") {
        energyPrice = item.value;
                                                            } else if (item.seriesName === "Steuern") {
        taxPrice = item.value;
                                                            } else if (item.seriesName === "Gesamtkosten") {
        totalPrice = item.value;
                                                        // Zeige die Summe von Energiepreis und Steuern im Tooltip an
                                                        return `
                                                            <div>
        <strong>${params[0].name}</strong><br />
        Energiepreis: ${energyPrice} €/kWh<br />
        Steuern: ${taxPrice} €/kWh<br />
        <strong>Gesamtkosten: ${totalPrice} €/kWh</strong>
                                                            </div>
                                                legend: { show: true, left: "center", top: 25 },
                                                title: { left: "center", text: "Tibberpreis heute" }, // Neuer Titel
                                                grid: { right: "10%" },
                                                toolbox: {
                                                    feature: {
                                                xAxis: [{ type: "category", axisTick: { alignWithLabel: true }, data: [] }],
                                                yAxis: [{ type: "value", position: "left", axisLabel: { formatter: "{value} €/kWh" }}],
                                                series: [
                                                    { name: "Energiepreis", type: "bar", stack: "cost", data: [] },
                                                    { name: "Steuern", type: "bar", stack: "cost", data: [] },
                                                    { name: "Gesamtkosten", type: "bar", data: [], itemStyle: { color: "green", borderColor: "black", borderWidth: 2 } } // Separate Serie für Gesamtkosten
                                            const xAxis = [];
                                            const energyPrices = [];
                                            const taxPrices = [];
                                            const totalPrices = []; // Neues Array für Gesamtkosten
                                            for (const data of tibber) {
                                                if (!data.startsAt || typeof data.energy === "undefined" || typeof data.tax === "undefined") {
                                                    console.warn("Fehlende Werte:", data);
                                                    continue;
                                                const date = new Date(data.startsAt);
                                                const hour = date.getHours();
                                                const xValue = date.toLocaleTimeString('de-DE', { hour: '2-digit', minute: '2-digit' });
                                                console.log(`Zeit: ${xValue}, Energie: ${data.energy}, Steuern: ${data.tax}`);
                                                xAxis.push(xValue);
                                                energyPrices.push(Number(data.energy).toFixed(4)); // Netto-Energiepreis
                                                taxPrices.push(Number(data.tax).toFixed(4)); // Steuern
                                                // Berechne die Gesamtkosten (Energiepreis + Steuern) und füge sie zu totalPrices hinzu
                                                const totalPrice = (Number(data.energy) + Number(data.tax)).toFixed(4);
                                                totalPrices.push(totalPrice); // Gesamtkosten als neuer Balken
                                            // Ändere die Farbe des Gesamtkostenbalkens für die aktuelle Stunde zu rot
                                            chart.series[2].data = totalPrices.map((totalPrice, index) => {
                                                const hour = new Date(tibber[index].startsAt).getHours();
                                                return {
                                                    value: totalPrice,
                                                    itemStyle: {
                                                        color: hour === currentHour ? 'red' : 'green', // Rot für aktuelle Stunde, sonst grün
                                                        borderWidth: 2
                                            chart.series[0].data = energyPrices;
                                            chart.series[1].data = taxPrices;
                                            console.log("Finales Chart-Objekt:", JSON.stringify(chart, null, 2));
                                            console.log("Chart für Tibberpreis heute fertig.");
                                            callback(chart);
                                        jrbwhJ icebearI 2 Antworten Letzte Antwort
                                              } else {
                                              const chart = {
                                              const xAxis  = [];
                                              const yAxis0 = [];
                                              const yAxis1 = [];
                                                  xAxis.push(xValue);
                                              callback(chart);
                                          und das hier:
                                              } else {
                                                  callback({
                                                      title: {
                                                          left: "center",
                                              let tibber;
                                              try {
                                              } catch (error) {
                                                  callback({
                                                  return;
                                                  callback({
                                                  return;
                                              const chart = {
                                                  tooltip: {
                                                      trigger: "axis",
                                                          let taxPrice = 0;
                                                          let totalPrice = 0;
                                                          return `
                                                              <div>
                                                              </div>
                                                  toolbox: {
                                                      feature: {
                                                  series: [
                                              const xAxis = [];
                                                      continue;
                                                  xAxis.push(xValue);
                                                  return {
                                                      value: totalPrice,
                                                      itemStyle: {
                                                          borderWidth: 2
                                              callback(chart);
                                          jrbwhJ Offline
                                          jrbwhJ Offline
                                          jrbwh
                                          #193
                                          @m-a-hueb Top! Würde mich freuen, wenn Du es auch als Beitrag auf der flexcharts-Seite postest, also hier.
