  4. über Port 8081 und 8082 kann ich ioBroker nicht aufrufen
77 Beiträge 5 Kommentatoren 9.7k Aufrufe 4 Beobachtet
    @thorsten4-71
    Das hat aber mit einem laufenden X / Display Server nix zu tun.
    iob diag
    in der Langfassung erzählt uns?
    Thorsten4-71
    @thomas-braun ich habe folgende Meldung erhalten:
    *** iob diag is starting up, please wait ***
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    shthorsten@raspberrypi:~ $
    Wie kann ich das updaten?
    • T Thorsten4-71
      @thorsten4-71
      iobroker fix
      ist nie eine doofe Idee.
      Auf einem Raspberry momentan bitte so aufrufen:
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
      chmod 744 iob_diag.sh
      ./iob_diag.sh
      T 2 Antworten Letzte Antwort
        @thorsten4-71
        iobroker fix
        ./iob_diag.sh
        Thorsten4-71
        Your system is booting into 'graphical.target', which means that a user interfac e or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
        library: loaded
        Library version=2024-10-22
        ioBroker or some processes are still running:
        877 iobroker.js-con
        1360 io.history.0
        1673 io.javascript.0
        2073 io.telegram.0
        2088 io.ping.0
        2124 io.shelly.0
        2147 io.deyeidc.0
        2164 io.mqtt.0
        2183 io.chromecast.0
        2203 io.echarts.0
        2222 io.cloud.0
        2244 io.hm-rpc.0
        2262 io.hm-rega.0
        2277 io.hm-rpc.2
        2313 io.rpi2.0
        2334 io.accuweather.
        2335 io.tr-064.0
        2341 io.tankerkoenig
        2352 io.fritzbox.0
        2353 io.broadlink2.0
        2392 io.discovery.0
        2489 io.fritzdect.0
        2506 io.web.0
        2526 io.iqontrol.0
        2543 io.vis-2.0
        2561 io.growatt.0
        2578 io.vis-inventwo
        2593 io.openligadb.0
        2608 io.yahoo-stock-
        2623 io.parser.0
        Please stop them first and try again!
          @thorsten4-71
          iobroker fix
          ./iob_diag.sh
          Thorsten4-71
          curl https://raw.githubusercontent.com/Grothesk242/io Broker/refs/reads/Paspgian/diag.sh > iob_diag.sh
          % Total % Received % Xferd Average Speed Time Time Time Current
          Dload Upload Total Spent Left Speed
          100 14 100 14 0 0 48 0 --:--:-- --:--:-- --:--:-- 48
          xx@raspberrypi:~ $ chmod 744 iob_diag.sh
          xx@raspberrypi:~ $ ./iob:diag.sh
          -bash: ./iob:diag.sh: Datei oder Verzeichnis nicht gefunden
          mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
          • T Thorsten4-71
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @thorsten4-71
            Keinen Doppelpunkt beim Aufruf sondern auch dort _
            ./iob:diag.sh
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • T Thorsten4-71
              @thorsten4-71
              Du musst es auch schon so eingeben oder kopieren wie es angegeben ist.
              Und bitte CodeTags verwenden.
              • mcm1957M mcm1957
                @thorsten4-71
                ./iob:diag.sh
                Thorsten4-71
                @mcm1957
                ./iob_diag.sh: Zeile 1: 404:: Kommando nicht gefunden.
                • T Thorsten4-71
                  @mcm1957
                  @thorsten4-71
                  Lade es nochmal...
                    @thorsten4-71
                    Lade es nochmal...
                    Thorsten4-71
                    meinst Du diesen Befehl? ./iob_diag.sh
                    kommt die gleiche Fehlermeldung
                    Thomas BraunT T 2 Antworten Letzte Antwort
                    • T Thorsten4-71
                      @thorsten4-71
                      Nein, ich meine EXAKT diese drei Zeilen:
                      ./iob_diag.sh
                      Vorher vielleicht
                      rm iob_diag.sh
                      • T Thorsten4-71
                        Thorsten4-71
                        @thorsten4-71
                        Es gibt eine Befehlszeile, die anzeigt welche Adapter/Port aktiviert oder deaktiviert ist. Kann mir jemand sagen, wie der heißt? Ich habe erst seit Oktober eine Raspberry. Sorry
                          @thorsten4-71
                          ./iob_diag.sh
                          Vorher vielleicht
                          rm iob_diag.sh
                          Thorsten4-71
                          @thomas-braun Habe jetzt diese Meldung erhalten:
                          *** ioBroker Diagnosis ***
                          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                          https://forum.iobroker.net
                          Just copy and paste the Summary Page, including the ``` characters at start and end.
                          It helps us to help you!
                          • Some output is masked. For full results please use 'iob diag --unmask' *
                          Press any key to continue
                          • T Thorsten4-71
                            @thorsten4-71 sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
                            Jo.
                            sollte doch klar sein...
                              Jo.
                              Thorsten4-71
                              @thomas-braun Das ist mir schon klar aber dann habe ich keine weiter Meldung mehr erhalten. steht bei xx@raspberrypi:~ $
                              • T Thorsten4-71
                                Zeigen...
                                Genaue und vollständige Kopie von dem was da in deinem Terminal steht.
                                In CodeTags.
                                  Zeigen...
                                  In CodeTags.
                                  Thorsten4-71
                                  xx@raspberrypi:~ $
                                  mehr steht da leider nicht, was vorher alles war, ist weg.
                                  • T Thorsten4-71
                                    xx@raspberrypi:~ $
                                    @thorsten4-71
                                    Und dein user heißt 'xx'? Du sollst das VOLLSTÄNDIG und UNVERÄNDERT und UNGEKÜRZT kopieren.
                                    Und IN CODETAGS setzen.
                                      @thorsten4-71
                                      Thorsten4-71
                                      @thomas-braun Sorry
                                      • T Thorsten4-71
                                        @thomas-braun Sorry
                                        @thorsten4-71
                                        Keine CodeTags...
                                          @thorsten4-71
                                          Keine CodeTags...
                                          Thorsten4-71
                                          @thomas-braun Mehr steht da nicht, habe alles kopiert. Was ist Code Tag. Sorry, ich habe keine große Erfahrung mit Raspberry
                                          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
