  4. ESPHome kein Webinterface
    6.8k
39 Beiträge 6 Kommentatoren 5.3k Aufrufe 5 Beobachtet
  • A AndreasE112
    @ralf-2
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Static hostname: iobroker
          Icon name: computer
             Kernel: Linux 6.6.62+rpt-rpi-v8
       Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
    18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                  Local time: Thu 2025-01-30 18:02:11 CET
              Universal time: Thu 2025-01-30 17:02:11 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.2G        1.9G        4.8G        1.3M        1.5G        6.3G
    Swap:           536M          0B        536M
    Total:          8.7G        1.9G        5.4G
    Active iob-Instances:   22
            7808 M total memory
            1831 M used memory
            2648 M active memory
             355 M inactive memory
            4624 M free memory
              79 M buffer memory
            1396 M swap cache
             511 M total swap
               0 M used swap
             511 M free swap
    top - 18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
    Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7808.9 total,   4622.7 free,   1832.6 used,   1477.1 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5976.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    31 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     781M  1.3M  780M   1% /run
    /dev/sda2      ext4      110G   15G   91G  14% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
    tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
    [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Thu Jan 30 17:33:35 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.6G    /var/
    4.3G    /var/lib
    4.2G    /var/lib/docker/overlay2
    1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/usr
    Archived and active journals take up 308.1M in the file system.
    /opt/iobroker/backups:
    130M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    32M     /opt/iobroker/iobroker-data/history/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
     Installed: 20.18.1-1nodesource1
     Candidate: 20.18.2-1nodesource1
     Version table:
        20.18.2-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
    *** 20.18.1-1nodesource1 1001
        20.18.0-1nodesource1 1001
        20.17.0-1nodesource1 1001
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main arm64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1708)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
     system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
     system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
     system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 0.0.0.0
     system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
     system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
     system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
     system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 7.4.19   , installed 7.4.10 [Updatable]
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.0.13   , installed 3.0.12 [Updatable]
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "modbus"       : 6.4.0    , installed 6.3.2  [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "notification-manager": 1.3.0, installed 1.2.1 [Updatable]
    Adapter    "scenes"       : 4.0.1    , installed 3.2.3  [Updatable]
    Adapter    "shuttercontrol": 1.8.8   , installed 1.8.5  [Updatable]
    Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
    Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
    Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.16.0 [Updatable]
    Adapter    "vis-2"        : 2.11.2   , installed 2.9.64 [Updatable]
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weather-warnings": 0.7.3 , installed 0.6.11 [Updatable]
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.3.1    , installed 6.2.5  [Updatable]
    Objects and States
    Objects:        9057
    States:         8038
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://download.docker.com/linux/debian bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 11
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6006       589/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1888       589/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8172       1968/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8173       1968/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       11029      2042/io.sonoff.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8557       1043/python
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5674       614/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          9339       1043/python
    tcp        0      0 0.0.0.0:12101           0.0.0.0:*               LISTEN      0          959        915/docker-proxy
    tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       7255       453/Agent
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5676       614/sshd: /usr/sbin
    tcp6       0      0 :::12101                :::*                    LISTEN      0          964        928/docker-proxy
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12580      2133/io.web.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       11470      1248/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14977      3056/io.esphome.0
    udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       7341       453/Agent
    udp        0      0 192.168.178.54:5353     0.0.0.0:*                           1000       7340       453/Agent
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7339       453/Agent
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           0          9338       1043/python
    udp        0      0 192.168.178.54:5353     0.0.0.0:*                           0          9337       1043/python
    udp        0      0 172.17.0.1:5353         0.0.0.0:*                           0          9336       1043/python
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          9330       1043/python
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5547       455/avahi-daemon: r
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       12292      1992/io.mihome.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          7287       1043/python
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11123      2014/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11124      2014/io.tuya.0
    udp        0      0 0.0.0.0:44125           0.0.0.0:*                           0          8514       1043/python
    udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1000       6267       453/Agent
    udp        0      0 0.0.0.0:52788           0.0.0.0:*                           104        5549       455/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        5548       455/avahi-daemon: r
    udp6       0      0 :::43249                :::*                                104        5550       455/avahi-daemon: r
    udp6       0      0 fe80::34bb:d917:52c:546 :::*                                0          5735       537/NetworkManager
    2025-01-30 18:03:22.529  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
    2025-01-30 18:03:22.531  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
    2025-01-30 18:03:22.721  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.723  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.724  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.725  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.727  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.728  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.729  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.733  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:22.734  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
    2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
     Time: '2025-01-30T18:03:25',
     DS18B20: { Id: '02131692A9AA', Temperature: 4.6 },
     TempUnit: 'C'
    2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
    2025-01-30 18:03:29.171  - info: javascript.0 (1387) script.js.Heizung.ATMOS_Steuerung: TSV received
    2025-01-30 18:03:35.367  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
     Time: '2025-01-30T18:03:35',
     TempUnit: 'C'
    2025-01-30 18:03:35.369  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
    iob diag has finished.
    AndreasE112
    @andrease112
    ich sehe dass der ESPShome Adapter keinen Port offen hat.
    Und NPM Version 10.8.2 hört sich alt an
    • A AndreasE112
      @ralf-2
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
            Icon name: computer
         Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           536M          0B        536M
              7808 M total memory
              1831 M used memory
              4624 M free memory
                79 M buffer memory
              1396 M swap cache
               511 M total swap
                 0 M used swap
               511 M free swap
      *** FILESYSTEM ***
      /var:
      5.6G    /var/
      4.3G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9057
      States:         8038
      Pending Updates: 11
       TempUnit: 'C'
       TempUnit: 'C'
      Ralf 2
      @andrease112
      @andrease112
      Nein, 10.8.2 sollte OK sein. Aber ich sehe da viele Errors.
      Aber um das zu checken bin ich hier der falsche, das sollte sich einmal kurz jemand von den Linux-Könnern ansehen um erst mal das System fit zu bekommen. Scheinbar liest hier keiner von denen mit.
      Und ja, einen Port muß das schon auf machen, aber der ist ja bei dir offen:
      @thomas-braun kannst du dir das diag mal ansehen?
      Gruß Ralf
      Thomas BraunT R 2 Antworten Letzte Antwort
      • R Ralf 2
        @andrease112
        @andrease112
        @ralf-2
        Da ist die Spannungsversorgung zu wackelig.
        Da mal genauer schauen:
        Updaten:
        Pending Updates: 11
        Gilt auch für die ganzen ioBroker-Adapter. UPDATEN!
        • R Ralf 2
          @andrease112
          @andrease112
          Ralf 2
          @AndreasE112
          Ich muß für heute Schluß machen, ich versuche mich für morgen noch einmal zu erinnern wie ich das damals ans laufen bekommen habe.
          Die Ratschläge von Thomas bitte beachten, das was er vorschlägt hat immer Hand und Fuß.
          Im übrigen: Der Adapter sollte auch ohne Weboberfläche laufen.
          Bis morgen...
          Gruß Ralf
          • R Ralf 2
            @AndreasE112
            Bis morgen...
            AndreasE112
            schrieb am zuletzt editiert von AndreasE112
            @ralf-2 hab alle updates gemacht, die 31 crticals waren nur die Spannungsversorgung.
            Aber das versteh ich nicht da ist eine Powerbank dran und dann Netzgerät.
            Das soll zum Schutz dienen falls der Strom ausfällt. Dann geht das FS nicht kaputt.
            Das läuft schon Jahre so... also ich glaub nicht das es ein Problem ist. Eher eine HW Auffälligkeit die wie bekannt ist, auf der Leiterbahn bei dem Strom schon mal 0,1-0,2V abfallen und man dann kurz in den kritischen Bereich kommt (kritisch ist nicht tot) .
            Bei dem Adapter hatte ich noch den Issue gefunden dass die ESPHome view hardcodiert war. Aber nach dem Update hat sich nichts geändert.
            Mit den Updates ist schon krass... hab den IObroker erst vor 14 Tagen neu installiert.
            • A AndreasE112
              @andrease112 sagte in ESPHome kein Webinterface:
              Aber das versteh ich nicht da ist eine Powerbank drank und dann Netzgerät.
              Das hört sich nach einer schrägen Konstellation an. Der Pi braucht dringend was ordentliches an der Stelle.
                AndreasE112
                ich habe im IOBrokerlog noch folgendes gefunden:
                esphome.0
                	2025-01-30 23:19:24.219	info	Bonjour service started, new devices will be detected automatically
                esphome.0
                	2025-01-30 23:19:19.621	error	Error in function sendSentry: TypeError: Cannot read properties of undefined (reading 'captureException')
                esphome.0
                	2025-01-30 23:19:19.619	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:110:19) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:78:5)
                Pip wird ist aber installiert und zeigt auf das richtige python:
                pi@iobroker:/usr/bin $ pip -V
                pip 25.0 from /home/pi/.local/lib/python3.11/site-packages/pip (python 3.11)
                pi@iobroker:/usr/bin $ pip3 -V
                R 1 Antwort Letzte Antwort
                • A AndreasE112
                  esphome.0
                  esphome.0
                  esphome.0
                  Ralf 2
                  @andrease112
                  Ich hatte nicht erwartet, das durch die Massnahmen ESPHome ans rennen kommt, aber Probleme die man erkennt sollte man schon irgendwie angehen. 😊
                  Mir ist da tatsächlich noch etwas eingefallen: Das Dashboard wird ja über ein IFrame eingeblendet das Dashboard funktioniert nur, wenn das über HTTP aufgerufen wird. Hast du deine Web-Instanz auf HTTPS eingestellt?
                  Teste mal ob du das Dashboard so aufrufen kannst:
                  http://deineIP:6052/
                  Vorrausgesetzt du hast ESPHome auf 6052 konfiguriert
                  Gruß Ralf
                    AndreasE112
                    moin, nee ich hab keine Authentifizierung an, und mit der IP-Adresse:6052 kommt keine Antwort.
                    hier noch der neueste IOB diag log
                    ```bash
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     08:22:15 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                    CPU threads: 4
                    Current issues:
                                   Local time: Fri 2025-01-31 08:22:15 CET
                               Universal time: Fri 2025-01-31 07:22:15 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi i        obroker
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.2G        2.3G        2.2G        1.3M        3.8G        5.9G
                    Swap:           536M          0B        536M
                    Total:          8.7G        2.3G        2.7G
                             7808 M total memory
                             2198 M used memory
                             2993 M active memory
                             2294 M inactive memory
                             2087 M free memory
                              220 M buffer memory
                             3424 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    top - 08:22:16 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                    Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                    MiB Mem :   7808.9 total,   2087.1 free,   2199.4 used,   3645.6 buff/cache
                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5609.5 avail Mem
                    540 CRITICAL ERRORS DETECTED!
                    *** FILESYSTEM ***
                    /dev/sda2      ext4      110G   14G   92G  14% /
                    [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headph        ones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_si        ze=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes        rootwait cfg80211.ieee80211_regdom=DE
                    [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode        : none.
                    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname        =mixed,errors=remount-ro
                    /var:
                    5.6G    /var/
                    4.3G    /var/lib
                    1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/u        sr
                    Archived and active journals take up 316.1M in the file system.
                    906M    /opt/iobroker/iobroker-data/
                    529M    /opt/iobroker/iobroker-data/files
                    236M    /opt/iobroker/iobroker-data/history
                    158M    /opt/iobroker/iobroker-data/files/admin.admin
                    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                    45M     /opt/iobroker/iobroker-data/objects.jsonl
                    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                    16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
                    USB-Devices by-id:
                    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-i        d':
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 53301)
                    admin:          7.4.19
                    javascript:     8.9.1
                    Adapter State
                    + instance is alive
                    Adapter    "admin"        : 7.4.19   , installed 7.4.19
                    Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                    Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                    Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                    Adapter    "notification-manager": 1.3.0, installed 1.3.0
                    Adapter    "scenes"       : 4.0.1    , installed 4.0.1
                    Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                    Adapter    "trashschedule": 4.0.0    , installed 4.0.0
                    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                    Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
                    Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
                    Adapter    "web"          : 6.3.1    , installed 6.3.1
                    Objects and States
                    Objects:        9068
                    States:         8048
                    Hit:4 https://download.docker.com/linux/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
                    Pending Updates: 11
                    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       33089      5976/io.sonoff.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32565      6322/io.web.0
                    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29004      5128/io.admin.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       49519      9110/io.esphome.0
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       31288      6181/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       31289      6181/io.tuya.0
                    2025-01-31 08:23:17.122  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.System.heartbeat"
                    2025-01-31 08:23:17.123  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.ratio_Raum_zu_Speicherabgabe"
                    2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.spezifischerBedarf"
                    2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Vorlauf"
                    2025-01-31 08:23:17.125  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Ruecklauf"
                    2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Pumpe_literMin"
                    2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
                    2025-01-31 08:23:17.127  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
                    2025-01-31 08:23:17.322  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.323  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.324  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.328  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.338  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.339  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:17.340  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                    2025-01-31 08:23:23.391  - info: javascript.0 (5666) script.js.Heizung.ATMOS_Steuerung: TSV received
                    2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: {
                      Time: '2025-01-31T08:23:24',
                      DS18B20: { Id: '02131692A9AA', Temperature: 3.7 },
                      TempUnit: 'C'
                    2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: 3.7
                    -> ESPhome hat kein Binding
                    -> ESPhome zeigt keinen PORT an
                    und dieses ist mir noch aufgefallen:
                    schaut der jetzt auf Portz 5353. Da kommt aber auch nix im Browser.
                    • A AndreasE112
                      ```bash
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           536M          0B        536M
                               7808 M total memory
                               2198 M used memory
                               2087 M free memory
                                220 M buffer memory
                               3424 M swap cache
                                511 M total swap
                                  0 M used swap
                                511 M free swap
                      *** FILESYSTEM ***
                      /var:
                      5.6G    /var/
                      4.3G    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.4.19
                      javascript:     8.9.1
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        9068
                      States:         8048
                      Pending Updates: 11
                        TempUnit: 'C'
                      Pending Updates: 11
                      Öh...
                        Pending Updates: 11
                        Öh...
                        AndreasE112
                        @thomas-braun Also ja öh ... aber mir erscheint das logisch wenn ich das development repository drin hab. Jetzt hab ich viele Adapter in der beta installiert. toll. Und ich glaube nicht dass die Spannungsvesorgung etwas mit dem Dashbord von ESPHome zu tun hat.
                        Wie gesagt das läuft schon jahre so und das raspi läuft ohne Fehler.
                        A R Thomas BraunT 3 Antworten Letzte Antwort
                        • A AndreasE112
                          AndreasE112
                          Ich hab's ESP home jetzt mal im Docker installiert.
                          klappt aber auch nicht :
                          pi@iobroker:/usr/bin $ docker run esphome/esphome
                          Creating cache directory /config/.esphome/platformio
                          You can change this behavior by mounting a directory to the container's /cache directory.
                          2025-01-31 08:07:27,472 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /config...
                          2025-01-31 08:07:53,186 INFO 200 GET /version (127.0.0.1) 1.75ms
                          2025-01-31 08:08:23,301 INFO 200 GET /version (127.0.0.1) 1.06ms
                          2025-01-31 08:08:53,547 INFO 200 GET /version (127.0.0.1) 2.39ms
                          • A AndreasE112
                            Ralf 2
                            @andrease112
                            Nun, nachdem man etwas aus Beta installiert hat stellt man eigentlich wieder auf stable um 😊
                            Du kannst auf Stable zurück stellen und dann die aus dem Beta hier wieder auf die stable bringen:
                            Expertenmodus muss dazu aktiviert sein:
                            Der Port auf dem ESPHome läuft ist von phyton geöffnet. Vielleicht hat auch das damit zu tuen, bei mir steht dort phyton3, bei dir phyton. Auch hier hatte ich mal ein Problem gehabt, ist aber alles sooo lange her.
                            Schau mal was als Port bei dir im ESPHome konfiguriert ist.
                            versuche mal auf port 80 und 443 zu verbinden, die stehen bei dir auf Listen - seltsam, bei mir ist es nur ein Port. Kann aber sein, das du noch etwas anderes phytonbasiertes laufen hast, es sind ja noch zwei weitere Ports angegeben.
                            Welchen Port hast du denn im Adapter angegeben?
                            Port 5353 ist der Port, wo die Sensoren die Daten hin schicken.
                            Das sind deine Ports auf denen Phyton lauscht:
                            Das hier sind meine Ports, wobei das Dashboard auf 6052 aufgeht, auf 5353 gehen die Signale ein:
                            tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       46729      2188/python3
                            udp        0      0 192.168.176.98:5353     0.0.0.0:*                           1000       47752      2188/python3
                            udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       47751      2188/python3
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       47747      2188/python3
                            Gruß Ralf
                            • A AndreasE112
                              Nein, er läuft eben nicht ohne Fehler. Steht ja auch so im Log.
                              • R Ralf 2
                                @andrease112
                                AndreasE112
                                @ralf-2
                                Ja die beiden anderen Ports sind von : DIY HUE Bridge auf Port 80
                                und Agent DVR auf PORT 5353
                                Auf 443 kommt nix zurück.... ich glaube das ist die Verbindung IObrokerMII adapter zur MII brigde. zwischen Agent DVR und IP CAM
                                • A AndreasE112
                                  @ralf-2
                                  Ralf 2
                                  @andrease112
                                  Ich habe mir gerade einen neuen Raspberry hochgezogen und das aus dem Latest installiert. Nein, es klappt nicht, dazu gibt es auch schon länger ein Issue. Das Problem ist mit der 0.5.0-beta.10 behoben, aber das ist nicht im Beta (Latest) vorhanden.
                                  Das Issue dazu hier hier dort steht auch die Lösung, dazu muß man etwas tuen, wo hier immer absolut abgeraten wird nämlich mit der bösen Katze direkt von GitHub zu installieren.
                                  Dazu muss man einen Branch von dem Adapter von dieser Adresse installieren.
                                  (Thomas wird mich für den Rat jetzt hauen 🙄 )
                                  Der Adapter ist von Dutchman, ich hoffe es geht ihm gut und er wird irgendwann noch mal dazu kommen den Adapter weiter zu pflegen. Ich möchte ihn nicht missen.
                                  Die Installation direkt von GitHub ist absolut auf eigene Gefahr und sollte eine ganz ganz seltene Ausnahme bleiben.
                                  Aber eine bitte noch von mir: Reparier dein System!
                                  "Das Auto ist jahrelang ohne Probleme mit der roten Lampe gefahren" sagte der Autofahrer mit Motorschaden zum gelben Engel ...
                                  Gruß Ralf
                                  • R Ralf 2
                                    @andrease112
                                    AndreasE112
                                    Hi ja das ist mir auch schon in den sinn gekommen.
                                    Ich hatte es runtergeladen unzipped und dann konnte ich es nicht mit ./configure und make bauen.
                                    hat hier noch jemand nen tip ?
                                    Habs nun auch hinbekommen über die Katze :) : ist aber immernoch der gleiche Fehler da.
                                    Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)```
                                    • A AndreasE112
                                      AndreasE112
                                      • A AndreasE112
                                        Ralf 2
                                        @andrease112
                                        PIP gehört zu Phyton, also liegt da etwas im argen.
                                        Ich habe wie gesagt nur IOBroker frisch aufgesetzt, einmal Webadapter reingehauen und dann das ESPHome installiert. Ohne mich vorher mit phyton und pip rum zu schlagen. Aus dem Branch lief es dann und ich konnte ein Testgerät anlegen.
                                        Wenn ich auf der Console dann nach pip oder phyton Version frage, wird beides nicht gefunden, scheint irgendwo lokal zu liegen (noch nicht nachgeschaut). Auf meinem Produktivsystem bekomme ich für beides die korrekten Versionsnummern angezeigt.
                                        Vielleicht muß hier noch irgendwo ein Pfad bei dir gesetzt werden, aber da habe ich echt viel zu wenig Ahnung von Linux als das ich hier noch helfen könnte.
                                        Gruß Ralf
                                        • R Ralf 2
                                          @andrease112
                                          AndreasE112
                                          ja und zwar glaub ich hier liegt das Problem:
                                          pi@iobroker:/usr/local/bin/esphome $ python -m ensurepip
                                          Defaulting to user installation because normal site-packages is not writeable
                                          Looking in links: /tmp/tmplhmx8v86
                                          Requirement already satisfied: setuptools in /usr/local/lib/python3.9/site-packages (58.1.0)
                                          Requirement already satisfied: pip in /usr/local/lib/python3.9/site-packages (23.0.1)
                                          Mal schauen wie sich das ändern lässt...
                                          deinstallieren und neu installiert: Pfade zu pip sind nun scheinbar korrekt
                                          pi@iobroker:/usr/local/lib $ pip -V
                                          pi@iobroker:/usr/local/lib $ pip3 -V
