  4. Hoymiles hms-800w-2t
    6.4k
hoymilesbalkonkraftwerk
27 Beiträge 14 Kommentatoren 23.9k Aufrufe 23 Beobachtet
  • M Michael 6
    @hosssa Dem schließe ich mich auch an als neuer User einer HMS-800W-2T. Ich bekomme die WEB-API leider nicht zum Laufen.
    Daher bitte auch ichj um ein Docker-Image für den RaspberryPi.
    Update:
    Error:
    pi@rpi:/media/nas $ cat /etc/debian_version
    11.9
    sudo pip install -r req.txt
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
    Requirement already satisfied: Flask[async] in /usr/lib/python3/dist-packages (from -r req.txt (line 1)) (1.1.2)
    Collecting hoymiles-wifi
      Downloading https://www.piwheels.org/simple/hoymiles-wifi/hoymiles_wifi-0.2.2-py3-none-any.whl (33 kB)
    WARNING: flask 1.1.2 does not provide the extra 'async'
    Collecting protobuf
      Downloading https://www.piwheels.org/simple/protobuf/protobuf-5.27.2-cp39-cp39-linux_armv7l.whl (981 kB)
         |████████████████████████████████| 981 kB 966 kB/s
    Collecting crcmod
      Downloading https://www.piwheels.org/simple/crcmod/crcmod-1.7-cp39-cp39-linux_armv7l.whl (30 kB)
    Installing collected packages: protobuf, crcmod, hoymiles-wifi
    Successfully installed crcmod-1.7 hoymiles-wifi-0.2.2 protobuf-5.27.2
    pi@rpi:/media/nas $ python3 app.py
    Traceback (most recent call last):
      File "/media/nas/app.py", line 93, in <module>
        @app.post("/restartDtu/<hostname>")
    AttributeError: 'Flask' object has no attribute 'post'
    pi@rpi:/media/nas $ sudo docker build --tag hoymiles-web-api .
    [+] Building 0.5s (1/1) FINISHED        docker:default
     => [internal] load build definition from Dockerfile        0.3s
     => => transferring dockerfile: 2B        0.0s
    ERROR: failed to solve: failed to read dockerfile: open Dockerfile: no such file or directory
    pi@rpi:/media/nas $ sudo docker run -d -p 5000:5000 --name hoymiles-web-api hoymiles-web-api
    Unable to find image 'hoymiles-web-api:latest' locally
    docker: Error response from daemon: pull access denied for hoymiles-web-api, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
    @michael-6 sagte in Hoymiles hms-800w-2t:
    Bitte pip nie mittels sudo aufrufen.
      Michael 6
      Klar, hast ja recht.
        Beowolf
        HMS-800W-2T
        Ich sehe das doch jetzt richitg, der HMS-800-2T wird doch jetzt unterstützt, richtig?
        Hier ist er doch aufgeführt.
        https://github.com/tbnobody/OpenDTU
        Manfred
        • B Beowolf
          HMS-800W-2T
          Manfred
          Samson71S Offline
          Samson71S Offline
          Samson71
          @beowolf sagte in Hoymiles hms-800w-2t:
          HMS-800W-2T
          VS
          Der HMS-800-2T ja, aber nicht der HMS-800W-2T
          Das "W" macht den Unterschied.
          Markus
          Bitte beachten:
          • DickenD Offline
            DickenD Offline
            Dicken
            Hab ebenfalls den HMS-800W-2T und hab mir einfach ne Strommesssteckdose dazwischen gesetzt. So bin ich auch nicht von der Cloud abhängig und bekomm Live-Werte.
            • DickenD Dicken
              Michael 6
              @dicken Das war auch mein erster Ansatz. Nur hat der Shelly IN der Garage schlechtes WLAN (50%) bricht weg. Alternativ müsste ich per PowerLine LAN in die Garage verlegen oder funktechnisch auf andere Produkte ausweichen wie FRITZ!DECT 210 oder Homematic HmIP-PSM-2 oder Powerline.
              https://github.com/suaveolent/hoymiles-wifi läuft bei mir, zu EDA-Kosten. Also dachte ich am WE könnte ich über MQTT Datenpunkte schnell in den ioBroker bekommen - und später bei Bedarf neue Plugs nachrüsten...
              DickenD bilberryB 2 Antworten Letzte Antwort
              • M Michael 6
                DickenD Offline
                DickenD Offline
                Dicken
                @michael-6 also ich hab ne HmIP-PSM-2 dazwischen.
                • M Michael 6
                  bilberryB Offline
                  bilberryB Offline
                  bilberry
                  @michael-6 , @hosssa
                  Ich finde Euren Weg über eine API deutlich eleganter als noch ein Gerät dazwischen zu schalten (auch wenn das derzeit die pragmatische und unkomplizierteste Lösung ist).
                  Mir (und vielen ander Usern vielleicht auch) ist aber noch nicht ganz klar, wie ihr vorgegangnen seid. Könnt ihr das hier mal bitte mit ein paar Stichpunkten skizzieren? Welches Setup ist erforderlich? Welche speziellen Voraussetzungen müssen ggf. geschaffen werden? Über welchen Weg wird mit der HMS kommuniziert (WLAN, Cloud, DTU-AP?) Wie kommen die Daten am einfachsten in den iobroker?
                  • bilberryB bilberry
                    Michael 6
                    schrieb am zuletzt editiert von Michael 6
                    @bilberry per LAN und Kommandozeile bisher (https://github.com/suaveolent/hoymiles-wifi).
                    Da siehst du sogar im Klartext die Passwörter von WLAN und AccessPoint.
                    Ich will etwas basteln um die Textausgabe in Datenpunkte zu bekommen, vielleicht hilt ChatGPT dabei...
                      Der hier folgende Teil zum Adapter wurde nach https://forum.iobroker.net/post/1182973 verschoben.
                      Bitte dort weitermachen
