  4. Probleme mit sudo apt update / PUBKEY
sudo apt update pubkey
26 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @mp3junkie
    Zeig mal die Langfassung von
    iob diag
    Könnte es evtl. sein, dass du von einer Vorversion auf RaspberryOS 12 'Bookworm' upgegraded hast und keine Neuinstallation?
    mp3junkie
    @thomas-braun sagte in Probleme mit sudo apt update / PUBKEY:
    Ne, Bookworm habe ich bereits ein paar Monate laufen. Grafana habe ich wieder "in Betrieb genommen".
    • M mp3junkie
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2024-12-21 12:47:38 CET
                 Universal time: Sat 2024-12-21 11:47:38 UTC
                       RTC time: Sat 2024-12-21 11:47:38
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.4G        3.9G        3.0G         28M        1.7G        4.6G
      Swap:           209M          0B        209M
      Total:          8.7G        3.9G        3.2G
      Active iob-Instances:   39
               8052 M total memory
               3697 M used memory
               3792 M active memory
                893 M inactive memory
               2852 M free memory
                162 M buffer memory
               1463 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
      Tasks: 260 total,   2 running, 258 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,   2852.3 free,   3698.6 used,   1626.0 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4353.7 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     806M  6.2M  800M   1% /run
      /dev/nvme0n1p2 ext4      457G   12G  422G   3% /
      tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/nvme0n1p1 vfat      511M   77M  435M  15% /boot/firmware
      tmpfs          tmpfs     806M  176K  806M   1% /run/user/1000
      /dev/mmcblk0p2 ext4       58G   11G   45G  19% /media/pi/rootfs
      /dev/mmcblk0p1 vfat      510M   76M  435M  15% /media/pi/bootfs
      [Sat Dec 21 10:10:17 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:6D:4C:3A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4f3e1646-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Sat Dec 21 10:10:18 2024] EXT4-fs (nvme0n1p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 ro with ordered data mode. Quota mode: none.
      [Sat Dec 21 10:10:19 2024] EXT4-fs (nvme0n1p2): re-mounted f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w. Quota mode: none.
      [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/nvme0n1p2 ext4        rw,noatime,commit=600
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/media/pi/rootfs   /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
      `-/media/pi/bootfs   /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
      /var:
      1.5G    /var/
      639M    /var/log
      637M    /var/log/journal/bc573ed170a0404295df5010a84c38bc
      384M    /var/cache
      Archived and active journals take up 636.8M in the file system.
      /opt/iobroker/backups:
      215M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      987M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      29M     /opt/iobroker/iobroker-data/states.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2251966-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 9424)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     3
      +-- iobroker.connector-local-control@0.0.4 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#dae4c44e29a8a44cfc5076aca69aac3694fac729)
      +-- iobroker.eusec@1.3.3 (git+ssh://git@github.com/bropat/ioBroker.eusec.git#14b7097588d080eeef69a8e2b91bfb2f9c6d1c09)
      +-- iobroker.lg-thinq@1.0.7 (git+ssh://git@github.com/TA2k/ioBroker.lg-thinq.git#4e823328b9f01752506f96dd8bdd78e98580c75d)
      Adapter State
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.connector-local-control.0: connector-local-control: raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
        system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
      + system.adapter.hass.0                   : hass                  : raspberrypi                              -  enabled, port: 8123
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              - disabled
      + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
      + system.adapter.melcloud.0               : melcloud              : raspberrypi                              -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
        system.adapter.roborock.0               : roborock              : raspberrypi                              - disabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "ems-esp"      : 5.0.6    , installed 5.0.6
      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
      Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "lg-thinq"     : 1.0.5    , installed 1.0.7
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "melcloud"     : 2.0.4    , installed 2.0.4
      Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
      Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "roborock"     : 0.6.17   , installed 0.6.17
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "solarmanpv"   : 0.6.2    , installed 0.6.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Objects and States
      Objects:        23603
      States:         19117
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6745       916/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10662      2340/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10657      2340/iobroker.js-co
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6064       687/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9266       945/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       6807       687/deCONZ
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17117      3179/io.shelly.1
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       728463     129005/nc
      tcp6       0      0 :::3000                 :::*                    LISTEN      114        14423      1736/grafana
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          6738       930/xrdp-sesman
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21177      3734/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        10501      1498/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22614      3682/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12873      2457/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23036      3773/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       21362      3872/io.ws.0
      tcp6       0      0 :::3389                 :::*                    LISTEN      113        9416       952/xrdp
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       15009      2858/io.harmony.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6744       916/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          9268       945/sshd: /usr/sbin
      udp        0      0 0.0.0.0:37152           0.0.0.0:*                           104        6414       681/avahi-daemon: r
      udp        0      0 192.168.178.32:5353     0.0.0.0:*                           1001       18790      3263/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6412       681/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15830      3137/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15386      2784/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6953       687/deCONZ
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17289      3288/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17290      3288/io.tuya.0
      udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       17842      3375/io.connector-l
      udp6       0      0 fe80::a68d:18ea:57a:546 :::*                                0          140872     778/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        6413       681/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       15389      2784/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       15388      2784/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       15387      2784/io.deconz.0
      udp6       0      0 :::39141                :::*                                104        6415       681/avahi-daemon: r
      2024-12-21 11:43:20.764  - info: fb-checkpresence.0 (31196) newActive Andreas false
      2024-12-21 11:43:40.713  - info: fb-checkpresence.0 (31196) newActive Andreas true
      2024-12-21 11:52:57.675  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
      2024-12-21 11:52:59.705  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
      2024-12-21 11:53:09.694  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
      2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
      2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
      2024-12-21 11:53:14.164  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
      2024-12-21 11:53:24.144  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
      2024-12-21 11:53:30.405  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
      2024-12-21 11:53:30.406  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
      2024-12-21 11:53:32.257  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
      2024-12-21 11:55:19.396  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
      2024-12-21 12:01:45.821  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.1 seconds ago and is ignored. Must be at least 2 seconds.
      2024-12-21 12:01:46.092  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
      2024-12-21 12:04:45.725  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertreppe zu] activated Zone 'Kellertreppe_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
      2024-12-21 12:11:47.246  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Abstellkammer zu] activated Zone 'Abstellkammer_Licht_Aus'. However, device(s) 'Abstellkammer' not turned off as these are already off.
      2024-12-21 12:26:43.722  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank links zu] activated Zone 'Schranklicht_Li_Aus'. However, device(s) 'Licht Kleiderschrank links' not turned off as these are already off.
      2024-12-21 12:30:57.980  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank rechts zu] activated Zone 'Schranklicht_Re_Aus'. However, device(s) 'Licht Kleiderschrank rechts' not turned off as these are already off.
      2024-12-21 12:44:03.066  - info: admin.0 (2457) ==> Connected system.user.admin from ::ffff:192.168.178.28
      2024-12-21 12:44:16.100  - error: backitup.0 (2686) [iobroker/grafana] Error on Grafana Datasource Request
      2024-12-21 12:44:16.139  - error: backitup.0 (2686) [iobroker/grafana] cannot found Grafana Backup files
      2024-12-21 12:44:46.961  - error: backitup.0 (2686) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2024-12-21 12:45:35.696  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
      2024-12-21 12:46:21.152  - info: admin.0 (2457) <== Disconnect system.user.admin from ::ffff:192.168.178.28 backitup
      iob diag has finished.
      Press any key for a summary
      @mp3junkie sagte in Probleme mit sudo apt update / PUBKEY:
      Tu das.
      Ansonsten sieht das soweit okay aus.
      Künftig den ersten User nicht 'pi' nennen sondern was eigenes ausdenken.
      vorname oder forumsnick sind da besser.
        Tu das.
        mp3junkie
        iob fix ist erledigt.
        Deine Hinweise habe ich notiert und werde sie umsetzen.
        Danke für deine schnelle und perfekte Hilfe. 😀
        P 1 Antwort Letzte Antwort
        • M mp3junkie
          puffy00007
          @mp3junkie Hi, ich habe ein ähnliches Problem, könnt ih mir helfen?
          pi@iobroker:/var/lib $ sudo apt update
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
          Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
          Err:5 https://repos.influxdata.com/debian stable InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          Err:6 https://packages.grafana.com/oss/deb stable InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          Fetched 6,907 B in 2s (3,699 B/s)
          Reading package lists... Done
          104 packages can be upgraded. Run 'apt list --upgradable' to see them.
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          die Zugriffsrechte (ls -l /etc/apt/trusted.gpg.d/) dind alle auf 644
          • P puffy00007
            @puffy00007 sagte in Probleme mit sudo apt update / PUBKEY:
            DRINGENDST updaten...
            Sowohl grafana wie auch influx müssen neu angelegt werden.
            Mach es danach:
            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
              Mach es danach:
              puffy00007
              @thomas-braun Bei Grafana ging alles gut, bei Influx sieht so aus:
              pi@iobroker:/var/lib $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
              sha256sum: influxdata-archive_compat.key: No such file or directory
              influxdata-archive_compat.key: FAILED open or read
              sha256sum: WARNING: 1 listed file could not be read
              • P puffy00007
                @puffy00007
                Stell dich NICHT in /var/lib rein.
                Du musst in deinem home stehen....
                Grundsätzlich hast du da eh nix verloren.
                • P Offline
                  puffy00007
                  @thomas-braun Super, alles sauber durchgelaufen und aufm neusten Stand!
                  Aber es gibt ein Problem:
                  Ich nutze VIS (1.5.6), darin habe ich auf der Hauptpage ein iFrame und als Quelle eine der URL aus Grafana, um die Visualisierung darzustellen.
                  Der weigert sich den Inhalt zu zeigen. KATASTROPHE
                  Was ist hier anders?
                  -1
                  • P puffy00007
                    KATASTROPHE
                    das hat nichts mit diesem Thread zu tun.
                    Bitte neuen Thread in der richtigen Kategorie aufmachen, oder an einen der zu diesem Thema bestehenden anhängen
                      KATASTROPHE
                      puffy00007
                      @homoran Habs gelöst, sorry und DANKE!
