  4. iobroker.zigbee 1.11.x - Tester gesucht
40 Beiträge 7 Kommentatoren 5.4k Aufrufe 9 Beobachtet
  • P peterfido
    @asgothian
    OK, dann ignoriere ich diesen Fehler. Die aktuelle Fehlermeldung habe ich oben gepostet.
    Die bisherigen Meldungen waren:
    zigbee.0
    2025-01-11 20:04:57.884	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2025-01-11 20:03:35.406	error	Error herdsman start
    zigbee.0
    2025-01-11 20:03:35.406	error	Failed to start Zigbee
    zigbee.0
    2025-01-11 20:03:35.406	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    zigbee.0
    2025-01-11 20:03:35.316	info	Installed Version: asgothian/ioBroker.zigbee#1.11
    zigbee.0
    2025-01-11 20:03:35.308	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:03:35.307	info	Try to reconnect. 1 attempts left
    zigbee.0
    2025-01-11 20:03:25.306	error	Error herdsman start
    zigbee.0
    2025-01-11 20:03:25.306	error	Failed to start Zigbee
    zigbee.0
    2025-01-11 20:03:25.306	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2025-01-11 20:03:25.190	info	Installed Version: asgothian/ioBroker.zigbee#1.11
    zigbee.0
    2025-01-11 20:03:25.133	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:03:25.110	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    zigbee.0
    2025-01-11 20:03:21.134	info	terminating
    zigbee.0
    2025-01-11 20:03:20.758	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-01-11 20:03:20.758	info	terminating
    zigbee.0
    2025-01-11 20:03:20.677	info	Closing Zigbee network, 0 seconds remaining
    zigbee.0
    2025-01-11 20:03:20.468	info	Closing Zigbee network, 0 seconds remaining
    zigbee.0
    2025-01-11 20:03:20.258	info	cleaned everything up...
    zigbee.0
    2025-01-11 20:03:20.257	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-01-11 20:03:13.701	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2025-01-11 20:03:13.645	info	debug devices set to []
    zigbee.0
    2025-01-11 20:03:13.635	warn	getDevices called from system.adapter.admin.0 with command "getDevices" and id null
    zigbee.0
    2025-01-11 20:03:13.635	warn	get Debug Devices Called
    zigbee.0
    2025-01-11 20:01:37.347	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2025-01-11 20:01:37.272	info	debug devices set to []
    zigbee.0
    2025-01-11 20:01:37.265	warn	getDevices called from system.adapter.admin.0 with command "getDevices" and id null
    zigbee.0
    2025-01-11 20:01:37.264	warn	get Debug Devices Called
    zigbee.0
    2025-01-11 20:01:31.693	info	Zigbee started
    zigbee.0
    2025-01-11 20:01:31.693	info	Currently no devices.
    zigbee.0
    2025-01-11 20:01:31.692	info	Unable to set transmit power, unsupported function.
    zigbee.0
    2025-01-11 20:01:31.692	info	--> transmitPower : normal
    zigbee.0
    2025-01-11 20:01:31.692	info	Unable to disable LED, unsupported function.
    zigbee.0
    2025-01-11 20:01:31.692	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    zigbee.0
    2025-01-11 20:01:31.564	info	Installed Version: asgothian/ioBroker.zigbee#1.11
    zigbee.0
    2025-01-11 20:01:31.505	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:01:31.484	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    zigbee.0
    2025-01-11 20:01:27.310	info	terminating
    zigbee.0
    2025-01-11 20:01:27.101	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-01-11 20:01:27.099	info	terminating
    zigbee.0
    2025-01-11 20:01:26.599	info	Zigbee: disabling joining new devices.
    zigbee.0
    2025-01-11 20:01:26.598	info	cleaned everything up...
    zigbee.0
    2025-01-11 20:01:26.597	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-01-11 20:00:29.968	info	Zigbee started
    zigbee.0
    2025-01-11 20:00:29.967	info	Currently no devices.
    zigbee.0
    2025-01-11 20:00:29.966	info	--> transmitPower : normal
    zigbee.0
    2025-01-11 20:00:29.965	info	Unable to disable LED, unsupported function.
    zigbee.0
    2025-01-11 20:00:29.965	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    zigbee.0
    2025-01-11 20:00:29.856	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-11 20:00:29.737	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:00:29.717	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    zigbee.0
    2025-01-11 20:00:25.462	info	terminating
    zigbee.0
    2025-01-11 20:00:25.334	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-01-11 20:00:25.333	info	terminating
    zigbee.0
    2025-01-11 20:00:24.833	info	Zigbee: disabling joining new devices.
    zigbee.0
    2025-01-11 20:00:24.833	info	cleaned everything up...
    zigbee.0
    2025-01-11 20:00:24.832	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-01-11 20:00:24.824	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
    zigbee.0
    2025-01-11 20:00:24.824	info	Zigbee started
    zigbee.0
    2025-01-11 20:00:24.823	info	Currently no devices.
    zigbee.0
    2025-01-11 20:00:24.822	info	--> transmitPower : normal
    zigbee.0
    2025-01-11 20:00:24.821	info	Unable to disable LED, unsupported function.
    zigbee.0
    2025-01-11 20:00:24.819	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    zigbee.0
    2025-01-11 20:00:19.555	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-11 20:00:19.450	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:00:19.439	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    zigbee.0
    2025-01-11 20:00:15.503	info	terminating
    zigbee.0
    2025-01-11 20:00:15.004	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-01-11 20:00:15.003	info	terminating
    zigbee.0
    2025-01-11 20:00:15.003	warn	Failed to stop zigbee during startup
    zigbee.0
    2025-01-11 20:00:15.002	info	Zigbee: disabling joining new devices.
    zigbee.0
    2025-01-11 20:00:15.001	info	cleaned everything up...
    zigbee.0
    2025-01-11 20:00:15.001	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-01-11 20:00:07.019	error	Error herdsman start
    zigbee.0
    2025-01-11 20:00:07.019	error	Failed to start Zigbee
    zigbee.0
    2025-01-11 20:00:07.019	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
    zigbee.0
    2025-01-11 20:00:06.930	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-11 20:00:06.802	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-11 20:00:06.801	error	Serial port not selected! Go to settings page.
    zigbee.0
    2025-01-11 20:00:06.793	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    Ich springe jetzt nochmal zum jungfräulichen ioBroker und probiere es nochmal.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @peterfido Was ist mit diesem uralt link ? warum kommt der immer in deinen Posts ?
    Die Version 1.3 ist gefühlt 3 Jahre alt.
    A.
    P 4 Antworten Letzte Antwort
    • AsgothianA Asgothian
      A.
      peterfido
      schrieb am zuletzt editiert von peterfido
      @asgothian Hm. Da habe ich gar nicht drauf geachtet. Ich schaue mal, wo das herkommt.
      Peterfido
        A.
        peterfido
        @asgothian gute Frage. Im Editor ist es nicht zu sehen, aber in der Vorschau 😕
        Peterfido
          A.
          peterfido
          @asgothian nochmal frisch installiert und hier nur die Fehlermeldungen:
          zigbee.0
          2025-01-11 20:20:22.333	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          zigbee.0
          2025-01-11 20:20:17.379	warn	Failed to stop zigbee during startup
          zigbee.0
          2025-01-11 20:20:17.379	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:255:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:509:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:484:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:983:17)
          zigbee.0
          2025-01-11 20:20:15.867	error	Error herdsman start
          zigbee.0
          2025-01-11 20:20:15.866	error	Failed to start Zigbee
          zigbee.0
          2025-01-11 20:20:15.866	error	Starting zigbee-herdsman problem : "USB adapter discovery error (No valid USB adapter found). Specify valid 'adapter' and 'port' in your configuration."
          zigbee.0
          2025-01-11 20:20:05.793	error	Error herdsman start
          zigbee.0
          2025-01-11 20:20:05.793	error	Failed to start Zigbee
          zigbee.0
          2025-01-11 20:20:05.793	error	Starting zigbee-herdsman problem : "USB adapter discovery error (No valid USB adapter found). Specify valid 'adapter' and 'port' in your configuration."
          zigbee.0
          2025-01-11 20:20:05.634	error	Serial port not selected! Go to settings page.
          und hier komplett:
          zigbee.0
          2025-01-11 20:20:36.527	info	Unable to disable LED, unsupported function.
          zigbee.0
          2025-01-11 20:20:36.526	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
          zigbee.0
          2025-01-11 20:20:36.407	info	Installed Version: asgothian/ioBroker.zigbee#1.11
          zigbee.0
          2025-01-11 20:20:36.349	info	Starting Zigbee npm ...
          zigbee.0
          2025-01-11 20:20:36.327	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
          zigbee.0
          2025-01-11 20:20:32.283	info	terminating
          zigbee.0
          2025-01-11 20:20:31.969	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          2025-01-11 20:20:31.968	info	terminating
          zigbee.0
          2025-01-11 20:20:31.878	info	Closing Zigbee network, 0 seconds remaining
          zigbee.0
          2025-01-11 20:20:31.674	info	Closing Zigbee network, 0 seconds remaining
          zigbee.0
          2025-01-11 20:20:31.468	info	cleaned everything up...
          zigbee.0
          2025-01-11 20:20:31.467	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.0
          2025-01-11 20:20:27.342	info	Zigbee started
          zigbee.0
          2025-01-11 20:20:27.342	info	Currently no devices.
          zigbee.0
          2025-01-11 20:20:27.341	info	Unable to set transmit power, unsupported function.
          zigbee.0
          2025-01-11 20:20:27.341	info	--> transmitPower : normal
          zigbee.0
          2025-01-11 20:20:27.341	info	Unable to disable LED, unsupported function.
          zigbee.0
          2025-01-11 20:20:27.340	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
          zigbee.0
          2025-01-11 20:20:27.228	info	Installed Version: asgothian/ioBroker.zigbee#1.11
          zigbee.0
          2025-01-11 20:20:27.165	info	Starting Zigbee npm ...
          zigbee.0
          2025-01-11 20:20:27.146	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
          zigbee.0
          2025-01-11 20:20:23.157	info	terminating
          zigbee.0
          2025-01-11 20:20:22.839	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          2025-01-11 20:20:22.838	info	terminating
          zigbee.0
          2025-01-11 20:20:22.751	info	Closing Zigbee network, 0 seconds remaining
          zigbee.0
          2025-01-11 20:20:22.545	info	Closing Zigbee network, 0 seconds remaining
          zigbee.0
          2025-01-11 20:20:22.338	info	cleaned everything up...
          zigbee.0
          2025-01-11 20:20:22.338	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.0
          zigbee.0
          2025-01-11 20:20:22.331	info	Zigbee started
          zigbee.0
          2025-01-11 20:20:22.331	info	Currently no devices.
          zigbee.0
          2025-01-11 20:20:22.331	info	Unable to set transmit power, unsupported function.
          zigbee.0
          2025-01-11 20:20:22.330	info	--> transmitPower : normal
          zigbee.0
          2025-01-11 20:20:22.330	info	Unable to disable LED, unsupported function.
          zigbee.0
          2025-01-11 20:20:22.330	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
          zigbee.0
          2025-01-11 20:20:21.765	info	Installed Version: asgothian/ioBroker.zigbee#1.11
          zigbee.0
          2025-01-11 20:20:21.702	info	Starting Zigbee npm ...
          zigbee.0
          2025-01-11 20:20:21.694	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
          zigbee.0
          2025-01-11 20:20:17.878	info	terminating
          zigbee.0
          2025-01-11 20:20:17.380	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          2025-01-11 20:20:17.380	info	terminating
          zigbee.0
          zigbee.0
          zigbee.0
          2025-01-11 20:20:17.377	info	cleaned everything up...
          zigbee.0
          2025-01-11 20:20:17.376	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          2025-01-11 20:20:15.796	info	Installed Version: asgothian/ioBroker.zigbee#1.11
          zigbee.0
          2025-01-11 20:20:15.794	info	Starting Zigbee npm ...
          zigbee.0
          2025-01-11 20:20:15.793	info	Try to reconnect. 1 attempts left
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          2025-01-11 20:20:05.706	info	Installed Version: asgothian/ioBroker.zigbee#1.11
          zigbee.0
          2025-01-11 20:20:05.636	info	Starting Zigbee npm ...
          zigbee.0
          zigbee.0
          2025-01-11 20:20:05.627	info	starting. Version 1.11.2 (non-npm: asgothian/ioBroker.zigbee#1.11) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
          Peterfido
          P AsgothianA 2 Antworten Letzte Antwort
          • P peterfido
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            und hier komplett:
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            peterfido
            Das hier
            kam, nachdem ich meinen Post oben editiert habe. Da waren dann die Log-Ausgaben in der Zwischenablage.
            Edit Test.
            Peterfido
              A.
              peterfido
              @asgothian Die Forensoftware erkennt das hier als Link und zeigt dann die Vorschau dazu an.
              Peterfido
              • P peterfido
                @peterfido das macht das github plugin.
                das sucht passende github Einträge zu deinem Satz.
                kein Link
                P 1 Antwort Letzte Antwort
                  kein Link
                  peterfido
                  @homoran Ah - ok. Wieder ein Rätsel gelöst :)
                  Peterfido
                  • P peterfido
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    und hier komplett:
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @peterfido Auch das 'komplette' log ist unvollständig. Der Adapter wird mehrfach angehalten, ohne das es Meldungen aus dem Adapter gibt die den Adapter anhalten.
                    Bitte folgendes machen:
                    • adapter anhalten
                    • 60 s warten damit der Adapter wirklich vollständig gestoppt ist.
                    • log löschen
                    • adapter starten (im normalen Modus - kein debug, etc.)
                    • 60 s warten
                    • das vollständige log (keine Filter auf zigbee, error, was sonst) posten.
                    Was für einen Koordinator setzt du da ein ? zStack30x deutet auf einen cc2531 oder cc2538 hin. Stimmt das ?
                    A.
                      • adapter anhalten
                      • log löschen
                      • 60 s warten
                      A.
                      peterfido
                      @asgothian Ich führe die Tage nochmal einen neuen Versuch von Vorne durch. Einiges konnte ich gestern, nach einem Rollback, nicht mehr nachvollziehen. Evtl. war ich Anfangs etwas zu schnell unterwegs, oder es fehlte einfach ein Neustart, welcher beim Rollback zwangsweise passiert.
                      Als Koordinator für die Tests nutze ich meinen älteren CC2538+CC2592 ZigBee Stick von @dimaiv, welcher inzwischen durch einen Zigstar Gateway abgelöst wurde.
                      Peterfido
                      • P peterfido
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        1.11.x Tests machen aktuell keinen weiteren Sinn. Es findet eine grössere Überarbeitung statt. Sobald diese soweit durch ist werde ich einen neuen Thread anlegen.
                        @Homoran Kannst du diesen Thread bitte schliessen ?
                          @asgothian sagte in iobroker.zigbee 1.11.x - Tester gesucht:
                          kann ich und hab ich ;-)
