pam_unix(su:auth): authentication failure
Guten Tag zusammen,
ich komm nicht mehr weiter.
Alle bisherigen Beiträge, die ich zum Thema gefunden habe, helfen mir leider nicht weiter.User bei Installation: pi
Alles aktuell, neueste Versionen.
$ node -v --> v22.13.0
$ iob version --> 7.0.6Der Service startet nicht richtig.
an 08 14:36:20 pi5 systemd[1]: Started iobroker.service - ioBroker Server. Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.admin.0" for host "pi5" Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.backitup.0" for host "pi5" Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.discovery.0" for host "pi5" Jan 08 14:36:22 pi5 su[1541]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:23 pi5 sudo[1559]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:23 pi5 sudo[1564]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable Jan 08 14:36:23 pi5 sudo[1564]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) an 08 14:36:24 pi5 sudo[1564]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:25 pi5 su[1541]: FAILED SU (to root) iobroker on none Jan 08 14:36:25 pi5 su[1575]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:27 pi5 su[1575]: FAILED SU (to root) iobroker on none Jan 08 14:36:28 pi5 su[1592]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:30 pi5 su[1592]: FAILED SU (to pi) iobroker on none Jan 08 14:36:31 pi5 su[1608]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:33 pi5 su[1608]: FAILED SU (to pi) iobroker on none Jan 08 14:36:34 pi5 su[1609]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi$ iob info Platform : linux os : linux Architecture : arm64 CPUs : 4 Speed : 2400 MHz Model : Cortex-A76 RAM : 7.8 GB System uptime : 02:46:11 Node.js : v22.13.0 time : 1736343814820 timeOffset : -60 NPM : 10.9.2 adapters count : 554 Disk size : 468.9 GiB Disk free : 451.1 GiB========== Start marking the full check here =========== ```bash Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: pi5 Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.63-v8-16k+ Architecture: arm64 OS is similar to: Model : Raspberry Pi 5 Model B Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 11:11:16 up 3 min, 4 users, load average: 0.14, 0.06, 0.02 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Wed 2025-01-08 11:11:17 CET Universal time: Wed 2025-01-08 10:11:17 UTC RTC time: Wed 2025-01-08 10:11:16 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 8.5G 1.1G 6.3G 28M 1.1G 7.3G Swap: 536M 0B 536M Total: 9.0G 1.1G 6.9G Active iob-Instances: 4 8064 M total memory 1065 M used memory 1228 M active memory 552 M inactive memory 6034 M free memory 83 M buffer memory 990 M swap cache 511 M total swap 0 M used swap 511 M free swap *** top - Table Of Processes *** top - 11:11:17 up 3 min, 4 users, load average: 0.14, 0.06, 0.02 Tasks: 237 total, 1 running, 236 sleeping, 0 stopped, 0 zombie %Cpu(s): 50.0 us, 0.0 sy, 0.0 ni, 50.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8064.2 total, 6033.3 free, 1067.0 used, 1073.5 buff/cache MiB Swap: 512.0 total, 512.0 free, 0.0 used. 6997.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 807M 6.0M 801M 1% /run /dev/nvme0n1p2 ext4 469G 18G 428G 4% / tmpfs tmpfs 4.0G 368K 4.0G 1% /dev/shm tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock /dev/nvme0n1p1 vfat 510M 68M 443M 14% /boot/firmware tmpfs tmpfs 807M 192K 807M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Jan 8 11:08:03 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:9D:43:28 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=6a5f591c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Wed Jan 8 11:08:04 2025] EXT4-fs (nvme0n1p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none. [Wed Jan 8 11:08:04 2025] EXT4-fs (nvme0n1p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/nvme0n1p2 ext4 rw,noatime |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 `-/boot/firmware /dev/nvme0n1p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 3.5G /var/ 2.6G /var/lib 2.4G /var/lib/caddy/ Archived and active journals take up 180.6M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 192M /opt/iobroker/iobroker-data/ 187M /opt/iobroker/iobroker-data/files 158M /opt/iobroker/iobroker-data/files/admin.admin 157M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 157M /opt/iobroker/iobroker-data/files/admin.admin/custom/static The five largest files in iobroker-data are: 12M /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js 7.4M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v22.11.0 /usr/bin/node v22.11.0 /usr/bin/npm 10.9.0 /usr/bin/npx 10.9.0 /usr/bin/corepack 0.29.4 nodejs: Installed: 22.11.0-1nodesource1 Candidate: 22.13.0-1nodesource1 Version table: 22.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages *** 22.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: pi5 pi5 (version: 7.0.6, hostname: pi5 , alive, uptime: 181) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: "javascript" not found nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : pi5 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : pi5 - enabled + system.adapter.discovery.0 : discovery : pi5 - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : pi5 - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "backitup" : 3.0.25 , installed 3.0.25 Adapter "discovery" : 5.0.0 , installed 5.0.0 Controller "js-controller": 7.0.6 , installed 7.0.6 Objects and States Please stand by - This may take a while Objects: 141 States: 99 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Get:5 https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version InRelease [8266 B] Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease Fetched 8266 B in 0s (18.1 kB/s) Reading package lists... Pending Updates: 25 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 6067 740/cupsd tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 6952 741/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 6957 741/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 2046 765/sshd: /usr/sbin tcp 0 0 127.0.0.1:2019 0.0.0.0:* LISTEN 999 8432 989/caddy tcp6 0 0 :::8081 :::* LISTEN 1001 9387 954/io.admin.0 tcp6 0 0 ::1:631 :::* LISTEN 0 6066 740/cupsd tcp6 0 0 :::30000 :::* LISTEN 1000 12297 1015/node tcp6 0 0 :::30001 :::* LISTEN 1000 9808 1016/node tcp6 0 0 :::9091 :::* LISTEN 0 9645 1179/authelia tcp6 0 0 :::443 :::* LISTEN 999 9461 989/caddy tcp6 0 0 :::22 :::* LISTEN 0 2048 765/sshd: /usr/sbin tcp6 0 0 :::80 :::* LISTEN 999 9463 989/caddy udp 0 0 0.0.0.0:36846 0.0.0.0:* 104 1905 574/avahi-daemon: r udp 0 0 192.168.178.95:41504 0.0.0.0:* 1000 8709 1016/node udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 1903 574/avahi-daemon: r udp6 0 0 :::59895 :::* 104 1906 574/avahi-daemon: r udp6 0 0 :::443 :::* 999 9462 989/caddy udp6 0 0 fe80::8790:86fb:544:546 :::* 0 8534 642/NetworkManager udp6 0 0 :::5353 :::* 104 1904 574/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-01-08 11:07:50.841 - info: host.pi5 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR) 2025-01-08 11:07:50.841 - info: host.pi5 All instances are stopped. 2025-01-08 11:07:50.988 - info: host.pi5 terminated 2025-01-08 11:08:07.000 - info: host.pi5 iobroker.js-controller version 7.0.6 js-controller starting 2025-01-08 11:08:07.002 - info: host.pi5 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker 2025-01-08 11:08:07.003 - info: host.pi5 hostname: pi5, node: v22.11.0 2025-01-08 11:08:07.003 - info: host.pi5 ip addresses: 2025-01-08 11:08:07.350 - info: host.pi5 connected to Objects and States 2025-01-08 11:08:07.360 - info: host.pi5 added notifications configuration of host 2025-01-08 11:08:07.473 - info: host.pi5 3 instances found 2025-01-08 11:08:07.475 - info: host.pi5 starting 3 instances 2025-01-08 11:08:07.637 - info: host.pi5 instance system.adapter.admin.0 in version "7.4.10" started with pid 954 2025-01-08 11:08:08.530 - info: admin.0 (954) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v22.11.0, js-controller: 7.0.6 2025-01-08 11:08:08.550 - info: admin.0 (954) requesting all objects 2025-01-08 11:08:08.610 - warn: admin.0 (954) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org 2025-01-08 11:08:08.799 - info: admin.0 (954) received all objects 2025-01-08 11:08:08.821 - warn: admin.0 (954) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live 2025-01-08 11:08:08.967 - info: admin.0 (954) socket.io server listening on port 8081 2025-01-08 11:08:08.971 - info: admin.0 (954) http server listening on port 8081 2025-01-08 11:08:08.971 - info: admin.0 (954) Use link "http://127.0.0.1:8081" to configure. 2025-01-08 11:08:11.696 - info: host.pi5 instance system.adapter.backitup.0 in version "3.0.25" started with pid 1515 2025-01-08 11:08:12.609 - info: backitup.0 (1515) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.11.0, js-controller: 7.0.6 2025-01-08 11:08:12.646 - info: backitup.0 (1515) [iobroker] backup will be activated at 02:48 every 1 day(s) 2025-01-08 11:08:15.632 - info: host.pi5 instance system.adapter.discovery.0 in version "5.0.0" started with pid 1969 2025-01-08 11:08:16.300 - info: discovery.0 (1969) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v22.11.0, js-controller: 7.0.6============ Mark until here for C&P =============
@blubby worum geht es hier?
Da gibt es leider 0 Hintergrund!pam klingt nach Proxmox
@blubby sagte in pam_unix(su:auth): authentication failure:
$ node -v --> v22.13.0zu neu!
ist noch nicht für ioBroker empfohlen.Wie kommst du daran?
mit dem Installer jedenfalls nicht. -
mit dem Installer jedenfalls nicht.@homoran
Danke schonmal für dein Feedback.
Node war schon auf dem System, für andere Services...AFAIK sollte das Problem nichts mit der Node Version zu tun haben. Es scheint ein Berechtigungsproblem zu geben.
Der Service versucht hier als anderer (priviligierter) User zu agieren, mal als root, sonst als pi. Das scheitert aber leider aus mir unbekannten Gründen.FAILED SU (to root) iobroker on none FAILED SU (to pi) iobroker on noneMuss man hier irgendwie systemseitig noch Dinge wie su oder irgendwelche Gruppenberechtigungen für iobroker-User anlegen?
EDIT: Proxmox läuft nicht. es ist ein Raspberry PI5, Raspbian 64bit
EDIT2: und es geht hierum: Der Service startet nicht richtig.
auf keinen Fall!
das würde das gesamte Rechtegefüge von ioBroker aushebeln können.iob soll nie als root installiert oder gestartet werden, ebenso niemals iob...dosomething Befehle niemals mit sudo einleiten.
@blubby
Zum testen:
Als User mal
sudo whoami -
@blubby
Zum testen:
Als User mal
sudo whoami@thomas-braun said in pam_unix(su:auth): authentication failure:
sudo whoami
➜ ~ sudo whoami root ➜ ~ whoami pi -
sudo whoami
➜ ~ sudo whoami root ➜ ~ whoami pi@blubby
Vollständige Ein- und Ausgaben inkl des LoginPrompts bitte
@blubby
ich weiß deine Bemühungen zu schätzen, aber vollständiger wird's hier nicht...
Wenn du nach sudo whoami fragst und ich damit (s.o.) antworte.LoginPrompt? von meiner SSH Sitzung oder was? nee, sorry.
@blubby
Dann halt nicht...
Wenn du aber ein Thema mit den Usern und deren Rechten hast muss ich sehen, mit welchem User du da hantierst.
@blubby
Dann halt nicht...
ich versteh halt nicht warum das login Prompt von Bedeutung sein soll. aber gut
~ ssh pi@pi5 Linux pi5 6.6.63-v8-16k+ #1824 SMP PREEMPT Tue Dec 3 13:01:07 GMT 2024 aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Jan 8 14:30:58 2025 from 192.168.178.93 -
~ ssh pi@pi5 Linux pi5 6.6.63-v8-16k+ #1824 SMP PREEMPT Tue Dec 3 13:01:07 GMT 2024 aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Jan 8 14:30:58 2025 from 192.168.178.93@blubby Das ist nicht das LogIn-Prompt...
Das LoginPrompt ist
user@host:~ $Also die vollständige Eingabezeile.
Das LoginPrompt ist
ja dann noch mal sorry, aber wie oben schon beschrieben, vollständiger wird es nicht.
➜ ~wenn es dir hilft, hänge ich einen Screenshot an. Aber bei mir zeigt es nun mal ➜ ~ an. Verkürzte Darstellung. Der user ist pi, der host ist pi5.
führe ich als user pi den Befehl sudo whoami aus, dann kommt als Ergebnis wie oben gepostet: root
hier noch mal:➜ ~ sudo whoami root ➜ ~ whoami piUm was geht es hier bitte? Ob ich mich als root eingeloggt hab um das zu installieren? Nein, natürlich nicht. Ich kann ja lesen. Außerdem ist der root user beim Raspberry standardmäßig nicht für den ssh login aktiviert.
Ich kann ja lesen.
dann hast du ja auch sicherlich gekesen, dass man im prompt sieht, ob man im falschen Verzeichnis steht
Es geht darum, welcher user da nicht richtig über pam authentifiziert werden kann.
Mir ist das aber eigentlich auch zu blöde.
Bin dann raus, wenn du eh alles besser weißt. -
Ich kann ja lesen.
@Homoran
und was ist das richtige / falsche Verzeichnis? von was? in welchem Kontext? Was hat bitte ein LoginPrompt oder ein Verzeichnis mit dem system.d service iobroker.service zu tun, der nicht sauber hoch fährt?Da fühle ich mich jetzt nicht wirklich ernst genommen.
Bin dann raus, wenn du eh alles besser weißt.@thomas-braun said in pam_unix(su:auth): authentication failure:
na das steht doch im log vom iobroker.service, siehe oben.
Auf dem System gibts die User
iobroker (vom Skript angelegt)
pi (vom OS angelegt)
root (ebenso)LOG
Jan 08 14:36:22 pi5 su[1541]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:23 pi5 sudo[1559]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:23 pi5 sudo[1564]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable Jan 08 14:36:23 pi5 sudo[1564]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) an 08 14:36:24 pi5 sudo[1564]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:25 pi5 su[1541]: FAILED SU (to root) iobroker on none Jan 08 14:36:25 pi5 su[1575]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:27 pi5 su[1575]: FAILED SU (to root) iobroker on none Jan 08 14:36:28 pi5 su[1592]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:30 pi5 su[1592]: FAILED SU (to pi) iobroker on none Jan 08 14:36:31 pi5 su[1608]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:33 pi5 su[1608]: FAILED SU (to pi) iobroker on none -
@Homoran
@blubby
Was ist denn bei dir im System noch alles modifiziert, wenn schon der prompt nicht vollständig ist?@homoran sagte in pam_unix(su:auth): authentication failure:
Das liegt am lokal verwendeten Terminal. Die Darstellung kann ja angepasst werden. Machen aber die meisten user nicht.
root (ebenso)LOG
Jan 08 14:36:22 pi5 su[1541]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:23 pi5 sudo[1559]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:23 pi5 sudo[1564]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable Jan 08 14:36:23 pi5 sudo[1564]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001) an 08 14:36:24 pi5 sudo[1564]: pam_unix(sudo:session): session closed for user root Jan 08 14:36:25 pi5 su[1541]: FAILED SU (to root) iobroker on none Jan 08 14:36:25 pi5 su[1575]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=root Jan 08 14:36:27 pi5 su[1575]: FAILED SU (to root) iobroker on none Jan 08 14:36:28 pi5 su[1592]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:30 pi5 su[1592]: FAILED SU (to pi) iobroker on none Jan 08 14:36:31 pi5 su[1608]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost= user=pi Jan 08 14:36:33 pi5 su[1608]: FAILED SU (to pi) iobroker on none@blubby sagte in pam_unix(su:auth): authentication failure:
Der Service wird aber gestartet:
*** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. -
@blubby
Was ist denn bei dir im System noch alles modifiziert, wenn schon der prompt nicht vollständig ist?hier läuft einfach nur eine zsh. daher ist der Prompt modifiziert. https://ohmyz.sh/
Ansonsten: ein Reverse Proxy (caddy), Authelia, eine statische Webseite, zwei Instanzen von VTT (nodeJS). das war es glaube ich.
@blubby
naja, trotzdem danke, für die Versuche Hilfe zu leisten. (Leider habe ich nur gelernt, dass Leute mit einer anderen Shell oder einem anderen Prompt gleich für doof gehalten werden.)
Vielleicht hätte ich es anders formulieren sollen, ich versuche es zum Abschluss vom Thema mal:
Der Service startet nicht richtig. Im Sinne von fehlerfrei. Es kommen Fehler im LOG vom iobroker.service.Ist das normal? Muss mir das Sorgen bereiten?
Kann man hier optimieren? Müsste man dafür ggfs. ein Bug ticket irgendwo aufmachen?Danke noch mal, ich wünsche allen noch ein frohes neues Jahr.
