  3. Einsteigerfragen
  4. Installation
  5. pam_unix(su:auth): authentication failure
    2.7k
    2.9k
51 Beiträge 8 Kommentatoren 6.5k Aufrufe 8 Beobachtet
  • ? Offline
    Guten Tag zusammen,
    ich komm nicht mehr weiter.
    Alle bisherigen Beiträge, die ich zum Thema gefunden habe, helfen mir leider nicht weiter.
    User bei Installation: pi
    Alles aktuell, neueste Versionen.
    $ node -v --> v22.13.0
    $ iob version --> 7.0.6
    Der Service startet nicht richtig.
    an 08 14:36:20 pi5 systemd[1]: Started iobroker.service - ioBroker Server.
    Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.admin.0" for host "pi5"
    Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.backitup.0" for host "pi5"
    Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.discovery.0" for host "pi5"
    Jan 08 14:36:22 pi5 su[1541]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=root
    Jan 08 14:36:23 pi5 sudo[1559]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session closed for user root
    Jan 08 14:36:23 pi5 sudo[1564]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Jan 08 14:36:23 pi5 sudo[1564]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    an 08 14:36:24 pi5 sudo[1564]: pam_unix(sudo:session): session closed for user root
    Jan 08 14:36:25 pi5 su[1541]: FAILED SU (to root) iobroker on none
    Jan 08 14:36:25 pi5 su[1575]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=root
    Jan 08 14:36:27 pi5 su[1575]: FAILED SU (to root) iobroker on none
    Jan 08 14:36:28 pi5 su[1592]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
    Jan 08 14:36:30 pi5 su[1592]: FAILED SU (to pi) iobroker on none
    Jan 08 14:36:31 pi5 su[1608]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
    Jan 08 14:36:33 pi5 su[1608]: FAILED SU (to pi) iobroker on none
    Jan 08 14:36:34 pi5 su[1609]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
    $ iob info
    Platform       : linux
    os             : linux
    Architecture   : arm64
    CPUs           : 4
    Speed          : 2400 MHz
    Model          : Cortex-A76
    RAM            : 7.8 GB
    System uptime  : 02:46:11
    Node.js        : v22.13.0
    time           : 1736343814820
    timeOffset     : -60
    NPM            : 10.9.2
    adapters count : 554
    Disk size      : 468.9 GiB
    Disk free      : 451.1 GiB
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: pi5
           Icon name: computer
              Kernel: Linux 6.6.63-v8-16k+
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     11:11:16 up 3 min,  4 users,  load average: 0.14, 0.06, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-01-08 11:11:17 CET
               Universal time: Wed 2025-01-08 10:11:17 UTC
                     RTC time: Wed 2025-01-08 10:11:16
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.5G        1.1G        6.3G         28M        1.1G        7.3G
    Swap:           536M          0B        536M
    Total:          9.0G        1.1G        6.9G
    Active iob-Instances: 	4
             8064 M total memory
             1065 M used memory
             1228 M active memory
              552 M inactive memory
             6034 M free memory
               83 M buffer memory
              990 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 11:11:17 up 3 min,  4 users,  load average: 0.14, 0.06, 0.02
    Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8064.2 total,   6033.3 free,   1067.0 used,   1073.5 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6997.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  6.0M  801M   1% /run
    /dev/nvme0n1p2 ext4      469G   18G  428G   4% /
    tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   68M  443M  14% /boot/firmware
    tmpfs          tmpfs     807M  192K  807M   1% /run/user/1000
    [Wed Jan  8 11:08:03 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:9D:43:28 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6a5f591c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Jan  8 11:08:04 2025] EXT4-fs (nvme0n1p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
    [Wed Jan  8 11:08:04 2025] EXT4-fs (nvme0n1p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/nvme0n1p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.5G	/var/
    2.6G	/var/lib
    2.4G	/var/lib/caddy/
    Archived and active journals take up 180.6M in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    192M	/opt/iobroker/iobroker-data/
    187M	/opt/iobroker/iobroker-data/files
    158M	/opt/iobroker/iobroker-data/files/admin.admin
    157M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    12M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    7.4M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.11.0
    /usr/bin/node 		v22.11.0
    /usr/bin/npm 		10.9.0
    /usr/bin/npx 		10.9.0
    /usr/bin/corepack 	0.29.4
    nodejs:
      Installed: 22.11.0-1nodesource1
      Candidate: 22.13.0-1nodesource1
      Version table:
         22.13.0-1nodesource1 500
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.12.0-1nodesource1 500
     *** 22.11.0-1nodesource1 500
         22.10.0-1nodesource1 500
         22.9.0-1nodesource1 500
         22.8.0-1nodesource1 500
         22.7.0-1nodesource1 500
         22.6.0-1nodesource1 500
         22.5.1-1nodesource1 500
         22.5.0-1nodesource1 500
         22.4.1-1nodesource1 500
         22.4.0-1nodesource1 500
         22.3.0-1nodesource1 500
         22.2.0-1nodesource1 500
         22.1.0-1nodesource1 500
         22.0.0-1nodesource1 500
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    pi5                 pi5 (version: 7.0.6, hostname: pi5           , alive, uptime: 181)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.4.10
    javascript: 	"javascript" not found
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : pi5                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : pi5                                      -  enabled
    + system.adapter.discovery.0              : discovery             : pi5                                      -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Objects and States
    Objects: 	141
    States: 	99
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Get:5 https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version InRelease [8266 B]
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Fetched 8266 B in 0s (18.1 kB/s)
    Reading package lists...
    Pending Updates: 25
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6067       740/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6952       741/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6957       741/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2046       765/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:2019          0.0.0.0:*               LISTEN      999        8432       989/caddy
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9387       954/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6066       740/cupsd
    tcp6       0      0 :::30000                :::*                    LISTEN      1000       12297      1015/node
    tcp6       0      0 :::30001                :::*                    LISTEN      1000       9808       1016/node
    tcp6       0      0 :::9091                 :::*                    LISTEN      0          9645       1179/authelia
    tcp6       0      0 :::443                  :::*                    LISTEN      999        9461       989/caddy
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2048       765/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      999        9463       989/caddy
    udp        0      0 0.0.0.0:36846           0.0.0.0:*                           104        1905       574/avahi-daemon: r
    udp        0      0 192.168.178.95:41504    0.0.0.0:*                           1000       8709       1016/node
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1903       574/avahi-daemon: r
    udp6       0      0 :::59895                :::*                                104        1906       574/avahi-daemon: r
    udp6       0      0 :::443                  :::*                                999        9462       989/caddy
    udp6       0      0 fe80::8790:86fb:544:546 :::*                                0          8534       642/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        1904       574/avahi-daemon: r
    2025-01-08 11:07:50.841  - info: host.pi5 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2025-01-08 11:07:50.841  - info: host.pi5 All instances are stopped.
    2025-01-08 11:07:50.988  - info: host.pi5 terminated
    2025-01-08 11:08:07.000  - info: host.pi5 iobroker.js-controller version 7.0.6 js-controller starting
    2025-01-08 11:08:07.002  - info: host.pi5 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-01-08 11:08:07.003  - info: host.pi5 hostname: pi5, node: v22.11.0
    2025-01-08 11:08:07.003  - info: host.pi5 ip addresses:
    2025-01-08 11:08:07.350  - info: host.pi5 connected to Objects and States
    2025-01-08 11:08:07.360  - info: host.pi5 added notifications configuration of host
    2025-01-08 11:08:07.473  - info: host.pi5 3 instances found
    2025-01-08 11:08:07.475  - info: host.pi5 starting 3 instances
    2025-01-08 11:08:07.637  - info: host.pi5 instance system.adapter.admin.0 in version "7.4.10" started with pid 954
    2025-01-08 11:08:08.530  - info: admin.0 (954) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v22.11.0, js-controller: 7.0.6
    2025-01-08 11:08:08.550  - info: admin.0 (954) requesting all objects
    2025-01-08 11:08:08.610  - warn: admin.0 (954) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
    2025-01-08 11:08:08.799  - info: admin.0 (954) received all objects
    2025-01-08 11:08:08.821  - warn: admin.0 (954) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
    2025-01-08 11:08:08.967  - info: admin.0 (954) socket.io server listening on port 8081
    2025-01-08 11:08:08.971  - info: admin.0 (954) http server listening on port 8081
    2025-01-08 11:08:08.971  - info: admin.0 (954) Use link "http://127.0.0.1:8081" to configure.
    2025-01-08 11:08:11.696  - info: host.pi5 instance system.adapter.backitup.0 in version "3.0.25" started with pid 1515
    2025-01-08 11:08:12.609  - info: backitup.0 (1515) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.11.0, js-controller: 7.0.6
    2025-01-08 11:08:12.646  - info: backitup.0 (1515) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-01-08 11:08:15.632  - info: host.pi5 instance system.adapter.discovery.0 in version "5.0.0" started with pid 1969
    2025-01-08 11:08:16.300  - info: discovery.0 (1969) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v22.11.0, js-controller: 7.0.6
      Guten Tag zusammen,
      $ iob info
      Platform       : linux
      os             : linux
      CPUs           : 4
      Speed          : 2400 MHz
      Model          : Cortex-A76
      RAM            : 7.8 GB
      Node.js        : v22.13.0
      timeOffset     : -60
      NPM            : 10.9.2
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               8064 M total memory
               1065 M used memory
               6034 M free memory
                 83 M buffer memory
                990 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      3.5G	/var/
      2.6G	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		10.9.0
      /usr/bin/npx 		10.9.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.4.10
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	141
      States: 	99
      Pending Updates: 25
      @blubby worum geht es hier?
      Da gibt es leider 0 Hintergrund!
      pam klingt nach Proxmox
      @blubby sagte in pam_unix(su:auth): authentication failure:
      zu neu!
      ist noch nicht für ioBroker empfohlen.
      Wie kommst du daran?
      mit dem Installer jedenfalls nicht.
        zu neu!
        Danke schonmal für dein Feedback.
        Node war schon auf dem System, für andere Services...
        AFAIK sollte das Problem nichts mit der Node Version zu tun haben. Es scheint ein Berechtigungsproblem zu geben.
        Der Service versucht hier als anderer (priviligierter) User zu agieren, mal als root, sonst als pi. Das scheitert aber leider aus mir unbekannten Gründen.
        Muss man hier irgendwie systemseitig noch Dinge wie su oder irgendwelche Gruppenberechtigungen für iobroker-User anlegen?
        EDIT: Proxmox läuft nicht. es ist ein Raspberry PI5, Raspbian 64bit
        EDIT2: und es geht hierum: Der Service startet nicht richtig.
          auf keinen Fall!
          das würde das gesamte Rechtegefüge von ioBroker aushebeln können.
          iob soll nie als root installiert oder gestartet werden, ebenso niemals iob...dosomething Befehle niemals mit sudo einleiten.
            @blubby
            Zum testen:
            Als User mal
            sudo whoami
              @blubby
              Zum testen:
              Als User mal
              sudo whoami
              @thomas-braun said in pam_unix(su:auth): authentication failure:
              sudo whoami
              ➜  ~ sudo whoami
              root
              ➜  ~ whoami
              pi
                sudo whoami
                ➜  ~ sudo whoami
                root
                ➜  ~ whoami
                pi
                @blubby
                Vollständige Ein- und Ausgaben inkl des LoginPrompts bitte
                  @blubby
                  ich weiß deine Bemühungen zu schätzen, aber vollständiger wird's hier nicht...
                  Wenn du nach sudo whoami fragst und ich damit (s.o.) antworte.
                  LoginPrompt? von meiner SSH Sitzung oder was? nee, sorry.
                    @blubby
                    Dann halt nicht...
                    Wenn du aber ein Thema mit den Usern und deren Rechten hast muss ich sehen, mit welchem User du da hantierst.
                      @blubby
                      Dann halt nicht...
                      ich versteh halt nicht warum das login Prompt von Bedeutung sein soll. aber gut
                      ~ ssh pi@pi5
                      Linux pi5 6.6.63-v8-16k+ #1824 SMP PREEMPT Tue Dec  3 13:01:07 GMT 2024 aarch64
                      permitted by applicable law.
                      Last login: Wed Jan  8 14:30:58 2025 from 192.168.178.93
                        ~ ssh pi@pi5
                        @blubby Das ist nicht das LogIn-Prompt...
                        Das LoginPrompt ist
                        user@host:~ $
                        Also die vollständige Eingabezeile.
                          Das LoginPrompt ist
                          user@host:~ $
                          ja dann noch mal sorry, aber wie oben schon beschrieben, vollständiger wird es nicht.
                          wenn es dir hilft, hänge ich einen Screenshot an. Aber bei mir zeigt es nun mal ➜ ~ an. Verkürzte Darstellung. Der user ist pi, der host ist pi5.
                          führe ich als user pi den Befehl sudo whoami aus, dann kommt als Ergebnis wie oben gepostet: root
                          hier noch mal:
                          ➜  ~ sudo whoami
                          root
                          ➜  ~ whoami
                          pi
                          Um was geht es hier bitte? Ob ich mich als root eingeloggt hab um das zu installieren? Nein, natürlich nicht. Ich kann ja lesen. Außerdem ist der root user beim Raspberry standardmäßig nicht für den ssh login aktiviert.
                            hier noch mal:
                            ➜  ~ sudo whoami
                            root
                            ➜  ~ whoami
                            pi
                            Ich kann ja lesen.
                            dann hast du ja auch sicherlich gekesen, dass man im prompt sieht, ob man im falschen Verzeichnis steht
                              hier noch mal:
                              ➜  ~ sudo whoami
                              root
                              ➜  ~ whoami
                              pi
                              Es geht darum, welcher user da nicht richtig über pam authentifiziert werden kann.
                              Mir ist das aber eigentlich auch zu blöde.
                              Bin dann raus, wenn du eh alles besser weißt.
                                Ich kann ja lesen.
                                @Homoran
                                und was ist das richtige / falsche Verzeichnis? von was? in welchem Kontext? Was hat bitte ein LoginPrompt oder ein Verzeichnis mit dem system.d service iobroker.service zu tun, der nicht sauber hoch fährt?
                                Da fühle ich mich jetzt nicht wirklich ernst genommen.
                                  na das steht doch im log vom iobroker.service, siehe oben.
                                  Auf dem System gibts die User
                                  iobroker (vom Skript angelegt)
                                  pi (vom OS angelegt)
                                  root (ebenso)
                                  LOG
                                    @Homoran
                                    @blubby
                                    Was ist denn bei dir im System noch alles modifiziert, wenn schon der prompt nicht vollständig ist?
                                    Thomas BraunT ? 2 Antworten Letzte Antwort
                                      @blubby
                                      @homoran sagte in pam_unix(su:auth): authentication failure:
                                      Das liegt am lokal verwendeten Terminal. Die Darstellung kann ja angepasst werden. Machen aber die meisten user nicht.
                                        root (ebenso)
                                        LOG
                                        Der Service wird aber gestartet:
                                          @blubby
                                          hier läuft einfach nur eine zsh. daher ist der Prompt modifiziert. https://ohmyz.sh/
                                          Ansonsten: ein Reverse Proxy (caddy), Authelia, eine statische Webseite, zwei Instanzen von VTT (nodeJS). das war es glaube ich.
