  3. Off Topic
  4. Pflege des Betriebssystems
  5. RPI5 apt-get upgrade schlägt Fehlermeldung
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
28 Beiträge 5 Kommentatoren 6.0k Aufrufe 4 Beobachtet
  • K knopers1
    pi@VISundGrafana:~ $
    login as: pi
    pi@192.168.1.100's password:
    Linux VISundGrafana 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64
    permitted by applicable law.
    Last login: Sun Jan  5 14:08:55 2025
    pi@VISundGrafana:~ $ sudo apt-get update
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    pi@VISundGrafana:~ $ sudo apt-get upgrade
    Calculating upgrade... Done
    The following packages have been kept back:
      chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra labwc libpipewire-0.3-0 libpipewire-0.3-modules
      libspa-0.2-bluetooth libspa-0.2-modules linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712
      linux-image-rpi-v8 pipewire pipewire-bin pipewire-libcamera pipewire-pulse python3-picamera2 raspberrypi-ui-mods
      raspi-config raspi-utils rpi-chromium-mods rpi-connect rpi-imager wf-panel-pi
    The following packages will be upgraded:
      agnostics bsdextrautils bsdutils curl distro-info-data edid-decode eject fdisk firefox ghostscript gstreamer1.0-alsa
      gstreamer1.0-plugins-base gstreamer1.0-x gui-pkinst gui-updater initramfs-tools initramfs-tools-core iputils-ping
      libarchive13 libblkid-dev libblkid1 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev
      libcamera-ipa libcamera-tools libcamera0.3 libcjson1 libcurl3-gnutls libcurl4 libdrm-amdgpu1 libdrm-common
      libdrm-nouveau2 libdrm-radeon1 libdrm2 libfdisk1 libfm-data libfm-extra4 libfm-gtk-data libfm-gtk4 libfm-modules libfm4
      libglib2.0-0 libglib2.0-bin libglib2.0-data libglib2.0-dev libglib2.0-dev-bin libgs-common libgs10 libgs10-common
      libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libheif1 libjavascriptcoregtk-4.1-0 libliftoff0
      liblightdm-gobject-1-0 libmount-dev libmount1 libmpg123-0 libneatvnc0 libnghttp2-14 libnss3 libntfs-3g89 libpam-systemd
      libpixman-1-0 libpixman-1-dev libpython3.11 libpython3.11-dev libpython3.11-minimal libpython3.11-stdlib librados2
      librbd1 libsmartcols1 libsqlite3-0 libssl3 libsystemd-shared libsystemd0 libudev-dev libudev1 libuuid1 libvlc-bin
      libvlc5 libvlccore9 libwayland-client0 libwayland-cursor0 libwayland-egl1 libwayland-server0 libwebkit2gtk-4.1-0
      libwlroots12 lightdm linux-libc-dev locales lxde lxde-core lxinput lxpanel lxpanel-data lxplug-bluetooth lxplug-ejecter
      lxplug-menu lxplug-netman lxplug-updater lxplug-volumepulse mount ninja-build nodejs ntfs-3g openssl pcmanfm pi-greeter
      piclone pipanel pishutdown piwiz pixflat-icons pixflat-theme python3-cryptography python3-libcamera python3.11
      python3.11-dev python3.11-minimal python3.11-venv raspberrypi-net-mods raspberrypi-sys-mods raspi-firmware rc-gui rfkill
      rp-bookshelf rp-prefapps rpd-plym-splash rpi-eeprom rpicam-apps systemd systemd-sysv systemd-timesyncd tzdata udev
      userconf-pi util-linux util-linux-extra uuid-dev vlc vlc-bin vlc-data vlc-l10n vlc-plugin-access-extra vlc-plugin-base
      vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter
      vlc-plugin-visualization wayvnc xserver-common xserver-xorg-core zlib1g zlib1g-dev
    164 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
    Need to get 0 B/290 MB of archives.
    After this operation, 94.1 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    dpkg-deb (subprocess): decompressing archive '/var/cache/apt/archives/bsdutils_1%3a2.38.1-5+deb12u2_arm64.deb' (size=94448) member 'data.tar': lzma error: compressed data is corrupt
    dpkg-deb: error: <decompress> subprocess returned error exit status 2
    Reading changelogs... Done
    Extracting templates from packages: 100%
    Preconfiguring packages ...
    (Reading database ... 158889 files and directories currently installed.)
    Preparing to unpack .../bsdutils_1%3a2.38.1-5+deb12u2_arm64.deb ...
    Unpacking bsdutils (1:2.38.1-5+deb12u2) over (1:2.38.1-5+deb12u1) ...
    dpkg: error processing archive /var/cache/apt/archives/bsdutils_1%3a2.38.1-5+deb12u2_arm64.deb (--unpack):
     dpkg-deb --fsys-tarfile subprocess returned error exit status 2
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Wer kann hierbei helfen Kollegen? Das Image ist auf der SSD installiert, von der SSD wird auch gebootet. Die Fehlermeldung könnte eventuell damit etwas zu tun haben... Ein Profi wird benötigt!
    knopers1
    bin jetzt ein Stück weiter ... aber ich hänge jetzt wieder! Nach apt-get clean wurde fast alles installiert. Zum Schluß gibt es noch eine Fehlermeldung/Hinweis Wie kann ich es fixen?
    sudo apt-get clean
    sudo apt-get update
    Last login: Sun Jan  5 14:09:02 2025 from 192.168.1.174
    pi@VISundGrafana:~ $ E: Sub-process /usr/bin/dpkg returned an error code (1)^C
    pi@VISundGrafana:~ $ ^C
    pi@VISundGrafana:~ $ sudo apt-get clean
    Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Fetched 55.4 kB in 1s (108 kB/s)
    Need to get 290 MB of archives.
    Get:1 http://deb.debian.org/debian bookworm/main arm64 bsdutils arm64 1:2.38.1-5+deb12u2 [94.4 kB]
    Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dbg arm64 2.36-9+rpt2+deb12u9 [8,130 kB]
    Get:3 http://deb.debian.org/debian bookworm/main arm64 libsmartcols1 arm64 2.38.1-5+deb12u2 [104 kB]
    Get:4 http://deb.debian.org/debian bookworm/main arm64 util-linux-extra arm64 2.38.1-5+deb12u2 [112 kB]
    Get:5 http://deb.debian.org/debian bookworm/main arm64 util-linux arm64 2.38.1-5+deb12u2 [1,145 kB]
    Get:6 https://deb.nodesource.com/node_20.x nodistro/main arm64 nodejs arm64 20.18.1-1nodesource1 [30.9 MB]
    Get:7 http://deb.debian.org/debian bookworm/main arm64 mount arm64 2.38.1-5+deb12u2 [134 kB]
    Get:8 http://deb.debian.org/debian bookworm/main arm64 systemd-sysv arm64 252.31-1~deb12u1 [42.5 kB]
    Get:9 http://deb.debian.org/debian bookworm/main arm64 libpam-systemd arm64 252.31-1~deb12u1 [210 kB]
    Get:10 http://deb.debian.org/debian bookworm/main arm64 uuid-dev arm64 2.38.1-5+deb12u2 [40.4 kB]
    Get:11 http://deb.debian.org/debian bookworm/main arm64 libuuid1 arm64 2.38.1-5+deb12u2 [28.4 kB]
    Get:12 http://deb.debian.org/debian bookworm/main arm64 libblkid-dev arm64 2.38.1-5+deb12u2 [183 kB]
    Get:13 http://deb.debian.org/debian bookworm/main arm64 libblkid1 arm64 2.38.1-5+deb12u2 [143 kB]
    Get:14 http://deb.debian.org/debian bookworm/main arm64 libudev-dev arm64 252.31-1~deb12u1 [52.7 kB]
    Get:15 http://deb.debian.org/debian bookworm/main arm64 systemd-timesyncd arm64 252.31-1~deb12u1 [61.7 kB]
    Get:16 http://deb.debian.org/debian bookworm/main arm64 libsystemd-shared arm64 252.31-1~deb12u1 [1,513 kB]
    Get:17 http://deb.debian.org/debian bookworm/main arm64 libsystemd0 arm64 252.31-1~deb12u1 [308 kB]
    Get:18 http://deb.debian.org/debian bookworm/main arm64 systemd arm64 252.31-1~deb12u1 [2,834 kB]
    Get:19 http://deb.debian.org/debian bookworm/main arm64 udev arm64 252.31-1~deb12u1 [1,625 kB]
    Get:20 http://deb.debian.org/debian bookworm/main arm64 libudev1 arm64 252.31-1~deb12u1 [103 kB]
    Get:21 http://deb.debian.org/debian bookworm/main arm64 libmount-dev arm64 2.38.1-5+deb12u2 [22.5 kB]
    Get:22 http://deb.debian.org/debian bookworm/main arm64 libmount1 arm64 2.38.1-5+deb12u2 [159 kB]
    Get:23 http://deb.debian.org/debian bookworm/main arm64 libfdisk1 arm64 2.38.1-5+deb12u2 [182 kB]
    Get:24 http://deb.debian.org/debian bookworm/main arm64 python3.11-venv arm64 3.11.2-6+deb12u4 [5,896 B]
    Get:25 http://deb.debian.org/debian bookworm/main arm64 python3.11-dev arm64 3.11.2-6+deb12u4 [617 kB]
    Get:26 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-dev arm64 3.11.2-6+deb12u4 [4,394 kB]
    Get:27 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-devtools arm64 2.36-9+rpt2+deb12u9 [60.6 kB]
    Get:28 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dev arm64 2.36-9+rpt2+deb12u9 [2,091 kB]
    Get:29 http://deb.debian.org/debian bookworm/main arm64 libpython3.11 arm64 3.11.2-6+deb12u4 [1,839 kB]
    Get:30 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-dev-bin arm64 2.36-9+rpt2+deb12u9 [49.2 kB]
    Get:31 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-dev all 1:6.6.62-1+rpt1 [2,057 kB]
    Get:32 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6 arm64 2.36-9+rpt2+deb12u9 [4,989 kB]
    Get:33 http://deb.debian.org/debian bookworm/main arm64 python3.11 arm64 3.11.2-6+deb12u4 [573 kB]
    Get:34 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-stdlib arm64 3.11.2-6+deb12u4 [1,746 kB]
    Get:35 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-bin arm64 2.36-9+rpt2+deb12u9 [749 kB]
    Get:36 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-common all 2:21.1.7-3+rpt3+deb12u8 [2,387 kB]
    Get:37 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-xorg-core arm64 2:21.1.7-3+rpt3+deb12u8 [4,041 kB]
    Get:38 http://deb.debian.org/debian bookworm/main arm64 python3.11-minimal arm64 3.11.2-6+deb12u4 [1,860 kB]
    Get:39 http://archive.raspberrypi.com/debian bookworm/main arm64 libdrm-common all 2.4.123-1~bpo12+1+rpt1 [9,338 B]
    Get:40 http://archive.raspberrypi.com/debian bookworm/main arm64 libdrm2 arm64 2.4.123-1~bpo12+1+rpt1 [46.9 kB]
    Get:41 http://archive.raspberrypi.com/debian bookworm/main arm64 libpixman-1-dev arm64 0.42.2-1+rpt3 [572 kB]
    Get:42 http://archive.raspberrypi.com/debian bookworm/main arm64 libpixman-1-0 arm64 0.42.2-1+rpt3 [526 kB]
    Get:43 http://archive.raspberrypi.com/debian bookworm/main arm64 libssl3 arm64 3.0.15-1~deb12u1+rpt1 [2,363 kB]
    Get:44 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-minimal arm64 3.11.2-6+deb12u4 [808 kB]
    Get:45 http://deb.debian.org/debian bookworm/main arm64 libsqlite3-0 arm64 3.40.1-2+deb12u1 [785 kB]
    Get:46 http://deb.debian.org/debian bookworm-updates/main arm64 tzdata all 2024b-0+deb12u1 [298 kB]
    Get:47 http://archive.raspberrypi.com/debian bookworm/main arm64 zlib1g-dev arm64 1:1.2.13.dfsg-1+rpt1 [944 kB]
    Get:48 http://deb.debian.org/debian bookworm/main arm64 fdisk arm64 2.38.1-5+deb12u2 [139 kB]
    Get:49 http://deb.debian.org/debian bookworm/main arm64 iputils-ping arm64 3:20221126-1+deb12u1 [46.1 kB]
    Get:50 http://deb.debian.org/debian bookworm/main arm64 libglib2.0-dev arm64 2.74.6-2+deb12u4 [1,616 kB]
    Get:51 http://archive.raspberrypi.com/debian bookworm/main arm64 zlib1g arm64 1:1.2.13.dfsg-1+rpt1 [94.3 kB]
    Get:52 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-firmware all 1:1.20241126-1 [12.8 MB]
    Get:53 http://deb.debian.org/debian bookworm/main arm64 libglib2.0-dev-bin arm64 2.74.6-2+deb12u4 [150 kB]
    Get:54 http://deb.debian.org/debian bookworm/main arm64 libglib2.0-data all 2.74.6-2+deb12u4 [1,209 kB]
    Get:55 http://deb.debian.org/debian bookworm/main arm64 libglib2.0-bin arm64 2.74.6-2+deb12u4 [106 kB]
    Get:56 http://deb.debian.org/debian bookworm/main arm64 libglib2.0-0 arm64 2.74.6-2+deb12u4 [1,313 kB]
    Get:57 http://deb.debian.org/debian bookworm/main arm64 bsdextrautils arm64 2.38.1-5+deb12u2 [87.1 kB]
    Get:58 http://deb.debian.org/debian bookworm/main arm64 libnghttp2-14 arm64 1.52.0-1+deb12u2 [68.6 kB]
    Get:59 http://deb.debian.org/debian bookworm/main arm64 curl arm64 7.88.1-10+deb12u8 [309 kB]
    Get:60 http://deb.debian.org/debian bookworm/main arm64 libcurl4 arm64 7.88.1-10+deb12u8 [365 kB]
    Get:61 http://deb.debian.org/debian bookworm/main arm64 distro-info-data all 0.58+deb12u3 [6,272 B]
    Get:62 http://deb.debian.org/debian bookworm/main arm64 eject arm64 2.38.1-5+deb12u2 [51.1 kB]
    Get:63 http://deb.debian.org/debian-security bookworm-security/main arm64 libnss3 arm64 2:3.87.1-1+deb12u1 [1,218 kB]
    Get:64 http://deb.debian.org/debian-security bookworm-security/main arm64 ghostscript arm64 10.0.0~dfsg-11+deb12u6 [57.6 kB]
    Get:65 http://deb.debian.org/debian-security bookworm-security/main arm64 libgs10 arm64 10.0.0~dfsg-11+deb12u6 [2,258 kB]
    Get:66 http://deb.debian.org/debian-security bookworm-security/main arm64 libgs10-common all 10.0.0~dfsg-11+deb12u6 [587 kB]
    Get:67 http://deb.debian.org/debian-security bookworm-security/main arm64 libgs-common all 10.0.0~dfsg-11+deb12u6 [149 kB]
    Get:68 http://deb.debian.org/debian-security bookworm-security/main arm64 libgstreamer1.0-0 arm64 1.22.0-2+deb12u1 [1,065 kB]
    Get:69 http://deb.debian.org/debian-security bookworm-security/main arm64 libgstreamer-plugins-base1.0-0 arm64 1.22.0-3+deb12u3 [842 kB]
    Get:70 http://deb.debian.org/debian-security bookworm-security/main arm64 gstreamer1.0-alsa arm64 1.22.0-3+deb12u3 [92.8 kB]
    Get:71 http://deb.debian.org/debian-security bookworm-security/main arm64 gstreamer1.0-plugins-base arm64 1.22.0-3+deb12u3 [642 kB]
    Get:72 http://deb.debian.org/debian-security bookworm-security/main arm64 gstreamer1.0-x arm64 1.22.0-3+deb12u3 [133 kB]
    Get:73 http://deb.debian.org/debian-security bookworm-security/main arm64 libarchive13 arm64 3.6.2-1+deb12u2 [316 kB]
    Get:74 http://deb.debian.org/debian bookworm/main arm64 libcjson1 arm64 1.7.15-1+deb12u2 [22.4 kB]
    Get:75 http://deb.debian.org/debian bookworm/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u8 [360 kB]
    Get:76 http://deb.debian.org/debian-security bookworm-security/main arm64 libgstreamer-gl1.0-0 arm64 1.22.0-3+deb12u3 [225 kB]
    Get:77 http://deb.debian.org/debian bookworm/main arm64 libheif1 arm64 1.15.1-1+deb12u1 [191 kB]
    Get:78 http://deb.debian.org/debian-security bookworm-security/main arm64 libwebkit2gtk-4.1-0 arm64 2.46.5-1~deb12u1 [21.7 MB]
    Get:79 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-l10n all 2.36-9+rpt2+deb12u9 [1,541 kB]
    Get:80 http://archive.raspberrypi.com/debian bookworm/main arm64 locales all 2.36-9+rpt2+deb12u9 [5,086 kB]
    Get:81 http://archive.raspberrypi.com/debian bookworm/main arm64 agnostics arm64 0.17 [17.1 kB]
    Get:82 http://archive.raspberrypi.com/debian bookworm/main arm64 edid-decode arm64 0.1~git20241119.5332a3b-1 [175 kB]
    Get:83 http://archive.raspberrypi.com/debian bookworm/main arm64 firefox arm64 133.0-1+rpt7 [94.8 MB]
    Get:84 http://deb.debian.org/debian-security bookworm-security/main arm64 libjavascriptcoregtk-4.1-0 arm64 2.46.5-1~deb12u1 [6,989 kB]
    Get:85 http://deb.debian.org/debian-security bookworm-security/main arm64 libmpg123-0 arm64 1.31.2-1+deb12u1 [141 kB]
    Get:86 http://deb.debian.org/debian bookworm/main arm64 ntfs-3g arm64 1:2022.10.3-1+deb12u2 [376 kB]
    Get:87 http://deb.debian.org/debian bookworm/main arm64 libntfs-3g89 arm64 1:2022.10.3-1+deb12u2 [149 kB]
    Get:88 http://deb.debian.org/debian-security bookworm-security/main arm64 librbd1 arm64 16.2.15+ds-0+deb12u1 [2,082 kB]
    Get:89 http://deb.debian.org/debian-security bookworm-security/main arm64 librados2 arm64 16.2.15+ds-0+deb12u1 [2,862 kB]
    Get:90 http://deb.debian.org/debian bookworm/main arm64 ninja-build arm64 1.11.1-2~deb12u1 [126 kB]
    Get:91 http://deb.debian.org/debian bookworm/main arm64 python3-cryptography arm64 38.0.4-3+deb12u1 [590 kB]
    Get:92 http://deb.debian.org/debian bookworm/main arm64 rfkill arm64 2.38.1-5+deb12u2 [37.2 kB]
    Get:93 http://archive.raspberrypi.com/debian bookworm/main arm64 gui-pkinst arm64 0.19 [192 kB]
    Get:94 http://archive.raspberrypi.com/debian bookworm/main arm64 gui-updater arm64 0.4 [10.8 kB]
    Get:95 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools all 0.142+rpt2+deb12u1 [17.1 kB]
    Get:96 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools-core all 0.142+rpt2+deb12u1 [53.1 kB]
    Get:97 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera0.3 arm64 0.3.2+rpt20241119-1 [815 kB]
    Get:98 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-ipa arm64 0.3.2+rpt20241119-1 [1,071 kB]
    Get:99 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-tools arm64 0.3.2+rpt20241119-1 [334 kB]
    Get:100 http://archive.raspberrypi.com/debian bookworm/main arm64 libdrm-amdgpu1 arm64 2.4.123-1~bpo12+1+rpt1 [25.5 kB]
    Get:101 http://archive.raspberrypi.com/debian bookworm/main arm64 libdrm-nouveau2 arm64 2.4.123-1~bpo12+1+rpt1 [22.1 kB]
    Get:102 http://archive.raspberrypi.com/debian bookworm/main arm64 libdrm-radeon1 arm64 2.4.123-1~bpo12+1+rpt1 [25.2 kB]
    Get:103 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm-data all 1.3.2-1+rpt18 [472 kB]
    Get:104 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm-extra4 arm64 1.3.2-1+rpt18 [29.3 kB]
    Get:105 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm-gtk-data all 1.3.2-1+rpt18 [32.2 kB]
    Get:106 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm-gtk4 arm64 1.3.2-1+rpt18 [193 kB]
    Get:107 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm4 arm64 1.3.2-1+rpt18 [147 kB]
    Get:108 http://archive.raspberrypi.com/debian bookworm/main arm64 libfm-modules arm64 1.3.2-1+rpt18 [62.9 kB]
    Get:109 http://archive.raspberrypi.com/debian bookworm/main arm64 libwayland-client0 arm64 1.23.0-1~bpo12+1+rpt1 [31.4 kB]
    Get:110 http://archive.raspberrypi.com/debian bookworm/main arm64 libwayland-cursor0 arm64 1.23.0-1~bpo12+1+rpt1 [13.0 kB]
    Get:111 http://archive.raspberrypi.com/debian bookworm/main arm64 libwayland-egl1 arm64 1.23.0-1~bpo12+1+rpt1 [6,170 B]
    Get:112 http://archive.raspberrypi.com/debian bookworm/main arm64 libwayland-server0 arm64 1.23.0-1~bpo12+1+rpt1 [40.9 kB]
    Get:113 http://archive.raspberrypi.com/debian bookworm/main arm64 libliftoff0 arm64 0.4.1-1~bpo12+rpt2 [16.6 kB]
    Get:114 http://archive.raspberrypi.com/debian bookworm/main arm64 liblightdm-gobject-1-0 arm64 1.26.0-8+rpt5 [64.5 kB]
    Get:115 http://archive.raspberrypi.com/debian bookworm/main arm64 libneatvnc0 arm64 0.9.0+dfsg-1~rpt3 [77.1 kB]
    Get:116 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc arm64 1:3.0.21-0+rpt3+deb12u1 [114 kB]
    Get:117 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-base arm64 1:3.0.21-0+rpt3+deb12u1 [5,141 kB]
    Get:118 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-data all 1:3.0.21-0+rpt3+deb12u1 [473 kB]
    Get:119 http://archive.raspberrypi.com/debian bookworm/main arm64 libvlccore9 arm64 1:3.0.21-0+rpt3+deb12u1 [596 kB]
    Get:120 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-skins2 arm64 1:3.0.21-0+rpt3+deb12u1 [649 kB]
    Get:121 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-qt arm64 1:3.0.21-0+rpt3+deb12u1 [1,405 kB]
    Get:122 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-video-output arm64 1:3.0.21-0+rpt3+deb12u1 [290 kB]
    Get:123 http://archive.raspberrypi.com/debian bookworm/main arm64 libvlc5 arm64 1:3.0.21-0+rpt3+deb12u1 [154 kB]
    Get:124 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-bin arm64 1:3.0.21-0+rpt3+deb12u1 [143 kB]
    Get:125 http://archive.raspberrypi.com/debian bookworm/main arm64 libvlc-bin arm64 1:3.0.21-0+rpt3+deb12u1 [94.6 kB]
    Get:126 http://archive.raspberrypi.com/debian bookworm/main arm64 libwlroots12 arm64 0.17.4-1+rpt1 [440 kB]
    Get:127 http://archive.raspberrypi.com/debian bookworm/main arm64 lightdm arm64 1.26.0-8+rpt5 [202 kB]
    Get:128 http://archive.raspberrypi.com/debian bookworm/main arm64 lxpanel arm64 0.10.1-2+rpt20 [291 kB]
    Get:129 http://archive.raspberrypi.com/debian bookworm/main arm64 lxpanel-data all 0.10.1-2+rpt20 [1,340 kB]
    Get:130 http://archive.raspberrypi.com/debian bookworm/main arm64 pcmanfm arm64 1.3.2-1+rpt29 [469 kB]
    Get:131 http://archive.raspberrypi.com/debian bookworm/main arm64 lxde-core all 11+rpt2 [2,814 B]
    Get:132 http://archive.raspberrypi.com/debian bookworm/main arm64 lxinput arm64 0.3.5-1+rpt26 [79.1 kB]
    Get:133 http://archive.raspberrypi.com/debian bookworm/main arm64 lxde all 11+rpt2 [2,974 B]
    Get:134 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-bluetooth arm64 0.36 [32.1 kB]
    Get:135 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-ejecter arm64 0.23 [12.5 kB]
    Get:136 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-menu arm64 0.5 [31.1 kB]
    Get:137 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-netman arm64 0.12 [1,322 kB]
    Get:138 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-updater arm64 0.20 [13.5 kB]
    Get:139 http://archive.raspberrypi.com/debian bookworm/main arm64 lxplug-volumepulse arm64 0.27 [30.9 kB]
    Get:140 http://archive.raspberrypi.com/debian bookworm/main arm64 openssl arm64 3.0.15-1~deb12u1+rpt1 [1,492 kB]
    Get:141 http://archive.raspberrypi.com/debian bookworm/main arm64 pi-greeter arm64 0.25 [51.1 kB]
    Get:142 http://archive.raspberrypi.com/debian bookworm/main arm64 piclone arm64 0.31 [28.3 kB]
    Get:143 http://archive.raspberrypi.com/debian bookworm/main arm64 pipanel arm64 1:1.49 [51.2 kB]
    Get:144 http://archive.raspberrypi.com/debian bookworm/main arm64 pishutdown arm64 0.30 [9,918 B]
    Get:145 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-sys-mods arm64 20241202 [22.0 kB]
    Get:146 http://archive.raspberrypi.com/debian bookworm/main arm64 userconf-pi all 0.10 [7,118 B]
    Get:147 http://archive.raspberrypi.com/debian bookworm/main arm64 piwiz arm64 0.86 [197 kB]
    Get:148 http://archive.raspberrypi.com/debian bookworm/main arm64 pixflat-icons all 0.26 [1,331 kB]
    Get:149 http://archive.raspberrypi.com/debian bookworm/main arm64 pixflat-theme arm64 0.21 [105 kB]
    Get:150 http://archive.raspberrypi.com/debian bookworm/main arm64 python3-libcamera arm64 0.3.2+rpt20241119-1 [328 kB]
    Get:151 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-net-mods all 1.4.3 [2,272 B]
    Get:152 http://archive.raspberrypi.com/debian bookworm/main arm64 rc-gui arm64 1.90 [91.2 kB]
    Get:153 http://archive.raspberrypi.com/debian bookworm/main arm64 rp-bookshelf arm64 0.24 [53.2 kB]
    Get:154 http://archive.raspberrypi.com/debian bookworm/main arm64 rp-prefapps arm64 0.65 [84.0 kB]
    Get:155 http://archive.raspberrypi.com/debian bookworm/main arm64 rpd-plym-splash arm64 0.42 [44.1 kB]
    Get:156 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 26.7-1 [8,496 kB]
    Get:157 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps arm64 1.5.3-1 [573 kB]
    Get:158 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-l10n all 1:3.0.21-0+rpt3+deb12u1 [14.1 MB]
    Get:159 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-access-extra arm64 1:3.0.21-0+rpt3+deb12u1 [120 kB]
    Get:160 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-notify arm64 1:3.0.21-0+rpt3+deb12u1 [95.9 kB]
    Get:161 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-samba arm64 1:3.0.21-0+rpt3+deb12u1 [96.4 kB]
    Get:162 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-video-splitter arm64 1:3.0.21-0+rpt3+deb12u1 [117 kB]
    Get:163 http://archive.raspberrypi.com/debian bookworm/main arm64 vlc-plugin-visualization arm64 1:3.0.21-0+rpt3+deb12u1 [126 kB]
    Get:164 http://archive.raspberrypi.com/debian bookworm/main arm64 wayvnc arm64 0.9.0~dev-1+rpt2 [86.9 kB]
    Fetched 290 MB in 45s (6,375 kB/s)
    Setting up bsdutils (1:2.38.1-5+deb12u2) ...
    Preparing to unpack .../0-libc6-dbg_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc6-dbg:arm64 (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../1-libc-devtools_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc-devtools (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../2-libc6-dev_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc6-dev:arm64 (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../3-libc-dev-bin_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc-dev-bin (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../4-linux-libc-dev_1%3a6.6.62-1+rpt1_all.deb ...
    Unpacking linux-libc-dev (1:6.6.62-1+rpt1) over (1:6.6.51-1+rpt3) ...
    Preparing to unpack .../5-libc6_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc6:arm64 (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Setting up libc6:arm64 (2.36-9+rpt2+deb12u9) ...
    Preparing to unpack .../libsmartcols1_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libsmartcols1:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up libsmartcols1:arm64 (2.38.1-5+deb12u2) ...
    Preparing to unpack .../util-linux-extra_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking util-linux-extra (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up util-linux-extra (2.38.1-5+deb12u2) ...
    Preparing to unpack .../util-linux_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking util-linux (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up util-linux (2.38.1-5+deb12u2) ...
    fstrim.service is a disabled or a static unit not running, not starting it.
    Preparing to unpack .../libc-bin_2.36-9+rpt2+deb12u9_arm64.deb ...
    Unpacking libc-bin (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Setting up libc-bin (2.36-9+rpt2+deb12u9) ...
    Preparing to unpack .../0-mount_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking mount (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../1-systemd-sysv_252.31-1~deb12u1_arm64.deb ...
    Unpacking systemd-sysv (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../2-libpam-systemd_252.31-1~deb12u1_arm64.deb ...
    Unpacking libpam-systemd:arm64 (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../3-xserver-common_2%3a21.1.7-3+rpt3+deb12u8_all.deb ...
    Unpacking xserver-common (2:21.1.7-3+rpt3+deb12u8) over (2:21.1.7-3+rpt3+deb12u7) ...
    Preparing to unpack .../4-uuid-dev_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking uuid-dev:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../5-libuuid1_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libuuid1:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up libuuid1:arm64 (2.38.1-5+deb12u2) ...
    Preparing to unpack .../libblkid-dev_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libblkid-dev:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../libblkid1_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libblkid1:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up libblkid1:arm64 (2.38.1-5+deb12u2) ...
    Preparing to unpack .../libudev-dev_252.31-1~deb12u1_arm64.deb ...
    Unpacking libudev-dev:arm64 (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../systemd-timesyncd_252.31-1~deb12u1_arm64.deb ...
    Unpacking systemd-timesyncd (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../libsystemd-shared_252.31-1~deb12u1_arm64.deb ...
    Unpacking libsystemd-shared:arm64 (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../libsystemd0_252.31-1~deb12u1_arm64.deb ...
    Unpacking libsystemd0:arm64 (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Setting up libsystemd0:arm64 (252.31-1~deb12u1) ...
    Preparing to unpack .../xserver-xorg-core_2%3a21.1.7-3+rpt3+deb12u8_arm64.deb ...
    Unpacking xserver-xorg-core (2:21.1.7-3+rpt3+deb12u8) over (2:21.1.7-3+rpt3+deb12u7) ...
    Preparing to unpack .../systemd_252.31-1~deb12u1_arm64.deb ...
    Unpacking systemd (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../udev_252.31-1~deb12u1_arm64.deb ...
    Unpacking udev (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Preparing to unpack .../libudev1_252.31-1~deb12u1_arm64.deb ...
    Unpacking libudev1:arm64 (252.31-1~deb12u1) over (252.30-1~deb12u2) ...
    Setting up libudev1:arm64 (252.31-1~deb12u1) ...
    Preparing to unpack .../0-libdrm-common_2.4.123-1~bpo12+1+rpt1_all.deb ...
    Unpacking libdrm-common (2.4.123-1~bpo12+1+rpt1) over (2.4.114-1) ...
    Preparing to unpack .../1-libdrm2_2.4.123-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libdrm2:arm64 (2.4.123-1~bpo12+1+rpt1) over (2.4.114-1+b1) ...
    Preparing to unpack .../2-libpixman-1-dev_0.42.2-1+rpt3_arm64.deb ...
    Unpacking libpixman-1-dev:arm64 (0.42.2-1+rpt3) over (0.42.2-1+rpt1) ...
    Preparing to unpack .../3-libpixman-1-0_0.42.2-1+rpt3_arm64.deb ...
    Unpacking libpixman-1-0:arm64 (0.42.2-1+rpt3) over (0.42.2-1+rpt1) ...
    Preparing to unpack .../4-libmount-dev_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libmount-dev:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../5-libmount1_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libmount1:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Setting up libmount1:arm64 (2.38.1-5+deb12u2) ...
    (Reading database ... 158888 files and directories currently installed.)
    Preparing to unpack .../libssl3_3.0.15-1~deb12u1+rpt1_arm64.deb ...
    Unpacking libssl3:arm64 (3.0.15-1~deb12u1+rpt1) over (3.0.14-1~deb12u2+rpt1) ...
    Preparing to unpack .../libfdisk1_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking libfdisk1:arm64 (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../python3.11-venv_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking python3.11-venv (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../zlib1g-dev_1%3a1.2.13.dfsg-1+rpt1_arm64.deb ...
    Unpacking zlib1g-dev:arm64 (1:1.2.13.dfsg-1+rpt1) over (1:1.2.13.dfsg-1) ...
    Preparing to unpack .../zlib1g_1%3a1.2.13.dfsg-1+rpt1_arm64.deb ...
    Unpacking zlib1g:arm64 (1:1.2.13.dfsg-1+rpt1) over (1:1.2.13.dfsg-1) ...
    Setting up zlib1g:arm64 (1:1.2.13.dfsg-1+rpt1) ...
    Preparing to unpack .../000-python3.11-dev_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking python3.11-dev (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../001-libpython3.11-dev_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking libpython3.11-dev:arm64 (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../002-libpython3.11_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking libpython3.11:arm64 (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../003-python3.11_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking python3.11 (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../004-libpython3.11-stdlib_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking libpython3.11-stdlib:arm64 (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../005-python3.11-minimal_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking python3.11-minimal (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../006-libpython3.11-minimal_3.11.2-6+deb12u4_arm64.deb ...
    Unpacking libpython3.11-minimal:arm64 (3.11.2-6+deb12u4) over (3.11.2-6+deb12u3) ...
    Preparing to unpack .../007-libsqlite3-0_3.40.1-2+deb12u1_arm64.deb ...
    Unpacking libsqlite3-0:arm64 (3.40.1-2+deb12u1) over (3.40.1-2) ...
    Preparing to unpack .../008-raspi-firmware_1%3a1.20241126-1_all.deb ...
    Unpacking raspi-firmware (1:1.20241126-1) over (1:1.20240924-1) ...
    Preparing to unpack .../009-tzdata_2024b-0+deb12u1_all.deb ...
    Unpacking tzdata (2024b-0+deb12u1) over (2024a-0+deb12u1) ...
    Preparing to unpack .../010-fdisk_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking fdisk (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../011-iputils-ping_3%3a20221126-1+deb12u1_arm64.deb ...
    Unpacking iputils-ping (3:20221126-1+deb12u1) over (3:20221126-1) ...
    Preparing to unpack .../012-libc-l10n_2.36-9+rpt2+deb12u9_all.deb ...
    Unpacking libc-l10n (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../013-locales_2.36-9+rpt2+deb12u9_all.deb ...
    Unpacking locales (2.36-9+rpt2+deb12u9) over (2.36-9+rpt2+deb12u8) ...
    Preparing to unpack .../014-libglib2.0-dev_2.74.6-2+deb12u4_arm64.deb ...
    Unpacking libglib2.0-dev:arm64 (2.74.6-2+deb12u4) over (2.74.6-2+deb12u3) ...
    Preparing to unpack .../015-libglib2.0-dev-bin_2.74.6-2+deb12u4_arm64.deb ...
    Unpacking libglib2.0-dev-bin (2.74.6-2+deb12u4) over (2.74.6-2+deb12u3) ...
    Preparing to unpack .../016-libglib2.0-data_2.74.6-2+deb12u4_all.deb ...
    Unpacking libglib2.0-data (2.74.6-2+deb12u4) over (2.74.6-2+deb12u3) ...
    Preparing to unpack .../017-libglib2.0-bin_2.74.6-2+deb12u4_arm64.deb ...
    Unpacking libglib2.0-bin (2.74.6-2+deb12u4) over (2.74.6-2+deb12u3) ...
    Preparing to unpack .../018-libglib2.0-0_2.74.6-2+deb12u4_arm64.deb ...
    Unpacking libglib2.0-0:arm64 (2.74.6-2+deb12u4) over (2.74.6-2+deb12u3) ...
    Preparing to unpack .../019-agnostics_0.17_arm64.deb ...
    Unpacking agnostics (0.17) over (0.16) ...
    Preparing to unpack .../020-bsdextrautils_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking bsdextrautils (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../021-libnghttp2-14_1.52.0-1+deb12u2_arm64.deb ...
    Unpacking libnghttp2-14:arm64 (1.52.0-1+deb12u2) over (1.52.0-1+deb12u1) ...
    Preparing to unpack .../022-curl_7.88.1-10+deb12u8_arm64.deb ...
    Unpacking curl (7.88.1-10+deb12u8) over (7.88.1-10+deb12u7) ...
    Preparing to unpack .../023-libcurl4_7.88.1-10+deb12u8_arm64.deb ...
    Unpacking libcurl4:arm64 (7.88.1-10+deb12u8) over (7.88.1-10+deb12u7) ...
    Preparing to unpack .../024-distro-info-data_0.58+deb12u3_all.deb ...
    Unpacking distro-info-data (0.58+deb12u3) over (0.58+deb12u2) ...
    Preparing to unpack .../025-edid-decode_0.1~git20241119.5332a3b-1_arm64.deb ...
    Unpacking edid-decode (0.1~git20241119.5332a3b-1) over (0.1~git20220315.cb74358c2896-1) ...
    Preparing to unpack .../026-eject_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking eject (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../027-libnss3_2%3a3.87.1-1+deb12u1_arm64.deb ...
    Unpacking libnss3:arm64 (2:3.87.1-1+deb12u1) over (2:3.87.1-1) ...
    Preparing to unpack .../028-firefox_133.0-1+rpt7_arm64.deb ...
    Unpacking firefox (133.0-1+rpt7) over (131.0.2-2+rpt7) ...
    Preparing to unpack .../029-ghostscript_10.0.0~dfsg-11+deb12u6_arm64.deb ...
    Unpacking ghostscript (10.0.0~dfsg-11+deb12u6) over (10.0.0~dfsg-11+deb12u5) ...
    Preparing to unpack .../030-libgs10_10.0.0~dfsg-11+deb12u6_arm64.deb ...
    Unpacking libgs10:arm64 (10.0.0~dfsg-11+deb12u6) over (10.0.0~dfsg-11+deb12u5) ...
    Preparing to unpack .../031-libgs10-common_10.0.0~dfsg-11+deb12u6_all.deb ...
    Unpacking libgs10-common (10.0.0~dfsg-11+deb12u6) over (10.0.0~dfsg-11+deb12u5) ...
    Preparing to unpack .../032-libgs-common_10.0.0~dfsg-11+deb12u6_all.deb ...
    Unpacking libgs-common (10.0.0~dfsg-11+deb12u6) over (10.0.0~dfsg-11+deb12u5) ...
    Preparing to unpack .../033-libgstreamer1.0-0_1.22.0-2+deb12u1_arm64.deb ...
    Unpacking libgstreamer1.0-0:arm64 (1.22.0-2+deb12u1) over (1.22.0-2) ...
    Preparing to unpack .../034-libgstreamer-plugins-base1.0-0_1.22.0-3+deb12u3_arm64.deb ...
    Unpacking libgstreamer-plugins-base1.0-0:arm64 (1.22.0-3+deb12u3) over (1.22.0-3+deb12u2+rpt1) ...
    Preparing to unpack .../035-gstreamer1.0-alsa_1.22.0-3+deb12u3_arm64.deb ...
    Unpacking gstreamer1.0-alsa:arm64 (1.22.0-3+deb12u3) over (1.22.0-3+deb12u2+rpt1) ...
    Preparing to unpack .../036-gstreamer1.0-plugins-base_1.22.0-3+deb12u3_arm64.deb ...
    Unpacking gstreamer1.0-plugins-base:arm64 (1.22.0-3+deb12u3) over (1.22.0-3+deb12u2+rpt1) ...
    Preparing to unpack .../037-gstreamer1.0-x_1.22.0-3+deb12u3_arm64.deb ...
    Unpacking gstreamer1.0-x:arm64 (1.22.0-3+deb12u3) over (1.22.0-3+deb12u2+rpt1) ...
    Preparing to unpack .../038-gui-pkinst_0.19_arm64.deb ...
    Unpacking gui-pkinst (0.19) over (0.17) ...
    Preparing to unpack .../039-gui-updater_0.4_arm64.deb ...
    Unpacking gui-updater (0.4) over (0.2) ...
    Preparing to unpack .../040-initramfs-tools_0.142+rpt2+deb12u1_all.deb ...
    Unpacking initramfs-tools (0.142+rpt2+deb12u1) over (0.142+deb12u1) ...
    Preparing to unpack .../041-initramfs-tools-core_0.142+rpt2+deb12u1_all.deb ...
    Unpacking initramfs-tools-core (0.142+rpt2+deb12u1) over (0.142+deb12u1) ...
    Preparing to unpack .../042-libarchive13_3.6.2-1+deb12u2_arm64.deb ...
    Unpacking libarchive13:arm64 (3.6.2-1+deb12u2) over (3.6.2-1+deb12u1) ...
    Preparing to unpack .../043-libcamera0.3_0.3.2+rpt20241119-1_arm64.deb ...
    Unpacking libcamera0.3:arm64 (0.3.2+rpt20241119-1) over (0.3.2+rpt20240927-1) ...
    Preparing to unpack .../044-libcamera-ipa_0.3.2+rpt20241119-1_arm64.deb ...
    Unpacking libcamera-ipa:arm64 (0.3.2+rpt20241119-1) over (0.3.2+rpt20240927-1) ...
    Preparing to unpack .../045-libcamera-tools_0.3.2+rpt20241119-1_arm64.deb ...
    Unpacking libcamera-tools (0.3.2+rpt20241119-1) over (0.3.2+rpt20240927-1) ...
    Preparing to unpack .../046-libcjson1_1.7.15-1+deb12u2_arm64.deb ...
    Unpacking libcjson1:arm64 (1.7.15-1+deb12u2) over (1.7.15-1+deb12u1) ...
    Preparing to unpack .../047-libcurl3-gnutls_7.88.1-10+deb12u8_arm64.deb ...
    Unpacking libcurl3-gnutls:arm64 (7.88.1-10+deb12u8) over (7.88.1-10+deb12u7) ...
    Preparing to unpack .../048-libdrm-amdgpu1_2.4.123-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libdrm-amdgpu1:arm64 (2.4.123-1~bpo12+1+rpt1) over (2.4.114-1+b1) ...
    Preparing to unpack .../049-libdrm-nouveau2_2.4.123-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libdrm-nouveau2:arm64 (2.4.123-1~bpo12+1+rpt1) over (2.4.114-1+b1) ...
    Preparing to unpack .../050-libdrm-radeon1_2.4.123-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libdrm-radeon1:arm64 (2.4.123-1~bpo12+1+rpt1) over (2.4.114-1+b1) ...
    Preparing to unpack .../051-libfm-data_1.3.2-1+rpt18_all.deb ...
    Unpacking libfm-data (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../052-libfm-extra4_1.3.2-1+rpt18_arm64.deb ...
    Unpacking libfm-extra4:arm64 (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../053-libfm-gtk-data_1.3.2-1+rpt18_all.deb ...
    Unpacking libfm-gtk-data (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../054-libfm-gtk4_1.3.2-1+rpt18_arm64.deb ...
    Unpacking libfm-gtk4:arm64 (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../055-libfm4_1.3.2-1+rpt18_arm64.deb ...
    Unpacking libfm4:arm64 (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../056-libfm-modules_1.3.2-1+rpt18_arm64.deb ...
    Unpacking libfm-modules:arm64 (1.3.2-1+rpt18) over (1.3.2-1+rpt14) ...
    Preparing to unpack .../057-libwayland-client0_1.23.0-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libwayland-client0:arm64 (1.23.0-1~bpo12+1+rpt1) over (1.22.0-2.1~bpo12+rpt1) ...
    Preparing to unpack .../058-libwayland-cursor0_1.23.0-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libwayland-cursor0:arm64 (1.23.0-1~bpo12+1+rpt1) over (1.22.0-2.1~bpo12+rpt1) ...
    Preparing to unpack .../059-libwayland-egl1_1.23.0-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libwayland-egl1:arm64 (1.23.0-1~bpo12+1+rpt1) over (1.22.0-2.1~bpo12+rpt1) ...
    Preparing to unpack .../060-libgstreamer-gl1.0-0_1.22.0-3+deb12u3_arm64.deb ...
    Unpacking libgstreamer-gl1.0-0:arm64 (1.22.0-3+deb12u3) over (1.22.0-3+deb12u2+rpt1) ...
    Preparing to unpack .../061-libheif1_1.15.1-1+deb12u1_arm64.deb ...
    Unpacking libheif1:arm64 (1.15.1-1+deb12u1) over (1.15.1-1) ...
    Preparing to unpack .../062-libwayland-server0_1.23.0-1~bpo12+1+rpt1_arm64.deb ...
    Unpacking libwayland-server0:arm64 (1.23.0-1~bpo12+1+rpt1) over (1.22.0-2.1~bpo12+rpt1) ...
    Preparing to unpack .../063-libwebkit2gtk-4.1-0_2.46.5-1~deb12u1_arm64.deb ...
    Unpacking libwebkit2gtk-4.1-0:arm64 (2.46.5-1~deb12u1) over (2.46.0-2~deb12u1) ...
    dpkg-deb (subprocess): decompressing archive '/tmp/apt-dpkg-install-2EmrmN/063-libwebkit2gtk-4.1-0_2.46.5-1~deb12u1_arm64.deb' (size=21695732) member 'data.tar': lzma error: compressed data is corrupt
    dpkg: error processing archive /tmp/apt-dpkg-install-2EmrmN/063-libwebkit2gtk-4.1-0_2.46.5-1~deb12u1_arm64.deb (--unpack):
     cannot copy extracted data for './usr/lib/aarch64-linux-gnu/libwebkit2gtk-4.1.so.0.16.7' to '/usr/lib/aarch64-linux-gnu/libwebkit2gtk-4.1.so.0.16.7.dpkg-new': unexpected end of file or stream
    Preparing to unpack .../064-libjavascriptcoregtk-4.1-0_2.46.5-1~deb12u1_arm64.deb ...
    Unpacking libjavascriptcoregtk-4.1-0:arm64 (2.46.5-1~deb12u1) over (2.46.0-2~deb12u1) ...
    Preparing to unpack .../065-libliftoff0_0.4.1-1~bpo12+rpt2_arm64.deb ...
    Unpacking libliftoff0:arm64 (0.4.1-1~bpo12+rpt2) over (0.4.1-1~bpo12+rpt1) ...
    Preparing to unpack .../066-liblightdm-gobject-1-0_1.26.0-8+rpt5_arm64.deb ...
    Unpacking liblightdm-gobject-1-0:arm64 (1.26.0-8+rpt5) over (1.26.0-8+rpt3) ...
    Preparing to unpack .../067-libmpg123-0_1.31.2-1+deb12u1_arm64.deb ...
    Unpacking libmpg123-0:arm64 (1.31.2-1+deb12u1) over (1.31.2-1) ...
    Preparing to unpack .../068-libneatvnc0_0.9.0+dfsg-1~rpt3_arm64.deb ...
    Unpacking libneatvnc0:arm64 (0.9.0+dfsg-1~rpt3) over (0.9.0+dfsg-1~rpt2) ...
    Preparing to unpack .../069-ntfs-3g_1%3a2022.10.3-1+deb12u2_arm64.deb ...
    Unpacking ntfs-3g (1:2022.10.3-1+deb12u2) over (1:2022.10.3-1+b1) ...
    Preparing to unpack .../070-libntfs-3g89_1%3a2022.10.3-1+deb12u2_arm64.deb ...
    Unpacking libntfs-3g89:arm64 (1:2022.10.3-1+deb12u2) over (1:2022.10.3-1+b1) ...
    Preparing to unpack .../071-librbd1_16.2.15+ds-0+deb12u1_arm64.deb ...
    Unpacking librbd1 (16.2.15+ds-0+deb12u1) over (16.2.11+ds-2) ...
    Preparing to unpack .../072-librados2_16.2.15+ds-0+deb12u1_arm64.deb ...
    Unpacking librados2 (16.2.15+ds-0+deb12u1) over (16.2.11+ds-2) ...
    Preparing to unpack .../073-vlc_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../074-vlc-plugin-base_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-base:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../075-vlc-data_1%3a3.0.21-0+rpt3+deb12u1_all.deb ...
    Unpacking vlc-data (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../076-libvlccore9_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking libvlccore9:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../077-vlc-plugin-skins2_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-skins2:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../078-vlc-plugin-qt_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-qt:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../079-vlc-plugin-video-output_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-video-output:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../080-libvlc5_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking libvlc5:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../081-vlc-bin_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-bin (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../082-libvlc-bin_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking libvlc-bin:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../083-libwlroots12_0.17.4-1+rpt1_arm64.deb ...
    Unpacking libwlroots12:arm64 (0.17.4-1+rpt1) over (0.17.3-1~bpo12+rpt5) ...
    Preparing to unpack .../084-lightdm_1.26.0-8+rpt5_arm64.deb ...
    Unpacking lightdm (1.26.0-8+rpt5) over (1.26.0-8+rpt3) ...
    Preparing to unpack .../085-lxpanel_0.10.1-2+rpt20_arm64.deb ...
    Unpacking lxpanel (0.10.1-2+rpt20) over (0.10.1-2+rpt19) ...
    Preparing to unpack .../086-lxpanel-data_0.10.1-2+rpt20_all.deb ...
    Unpacking lxpanel-data (0.10.1-2+rpt20) over (0.10.1-2+rpt19) ...
    Preparing to unpack .../087-pcmanfm_1.3.2-1+rpt29_arm64.deb ...
    Unpacking pcmanfm (1.3.2-1+rpt29) over (1.3.2-1+rpt23) ...
    Preparing to unpack .../088-lxde-core_11+rpt2_all.deb ...
    Unpacking lxde-core (11+rpt2) over (11+rpt1) ...
    Preparing to unpack .../089-lxinput_0.3.5-1+rpt26_arm64.deb ...
    Unpacking lxinput (0.3.5-1+rpt26) over (0.3.5-1+rpt24) ...
    Preparing to unpack .../090-lxde_11+rpt2_all.deb ...
    Unpacking lxde (11+rpt2) over (11+rpt1) ...
    Preparing to unpack .../091-lxplug-bluetooth_0.36_arm64.deb ...
    Unpacking lxplug-bluetooth (0.36) over (0.35) ...
    Preparing to unpack .../092-lxplug-ejecter_0.23_arm64.deb ...
    Unpacking lxplug-ejecter (0.23) over (0.22) ...
    Preparing to unpack .../093-lxplug-menu_0.5_arm64.deb ...
    Unpacking lxplug-menu (0.5) over (0.4) ...
    Preparing to unpack .../094-lxplug-netman_0.12_arm64.deb ...
    Unpacking lxplug-netman (0.12) over (0.11) ...
    Preparing to unpack .../095-lxplug-updater_0.20_arm64.deb ...
    Unpacking lxplug-updater (0.20) over (0.19) ...
    Preparing to unpack .../096-lxplug-volumepulse_0.27_arm64.deb ...
    Unpacking lxplug-volumepulse (0.27) over (0.26) ...
    Preparing to unpack .../097-ninja-build_1.11.1-2~deb12u1_arm64.deb ...
    Unpacking ninja-build (1.11.1-2~deb12u1) over (1.11.1-1) ...
    Preparing to unpack .../098-nodejs_20.18.1-1nodesource1_arm64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (20.18.1-1nodesource1) over (20.18.0-1nodesource1) ...
    dpkg-deb (subprocess): decompressing archive '/tmp/apt-dpkg-install-2EmrmN/098-nodejs_20.18.1-1nodesource1_arm64.deb' (size=30874688) member 'data.tar': lzma error: compressed data is corrupt
    dpkg: error processing archive /tmp/apt-dpkg-install-2EmrmN/098-nodejs_20.18.1-1nodesource1_arm64.deb (--unpack):
     cannot copy extracted data for './usr/bin/node' to '/usr/bin/node.dpkg-new': unexpected end of file or stream
    Preparing to unpack .../099-openssl_3.0.15-1~deb12u1+rpt1_arm64.deb ...
    Unpacking openssl (3.0.15-1~deb12u1+rpt1) over (3.0.14-1~deb12u2+rpt1) ...
    Preparing to unpack .../100-pi-greeter_0.25_arm64.deb ...
    Unpacking pi-greeter (0.25) over (0.23) ...
    Preparing to unpack .../101-piclone_0.31_arm64.deb ...
    Unpacking piclone (0.31) over (0.30) ...
    Preparing to unpack .../102-pipanel_1%3a1.49_arm64.deb ...
    Unpacking pipanel (1:1.49) over (1:1.48) ...
    Preparing to unpack .../103-pishutdown_0.30_arm64.deb ...
    Leaving 'diversion of /usr/bin/lxde-pi-shutdown-helper to /usr/bin/lxde-pi-shutdown-helper.old by pishutdown'
    Unpacking pishutdown (0.30) over (0.29) ...
    Preparing to unpack .../104-raspberrypi-sys-mods_20241202_arm64.deb ...
    Unpacking raspberrypi-sys-mods (20241202) over (20240911) ...
    Preparing to unpack .../105-userconf-pi_0.10_all.deb ...
    Unpacking userconf-pi (0.10) over (0.9) ...
    Preparing to unpack .../106-piwiz_0.86_arm64.deb ...
    Unpacking piwiz (0.86) over (0.75) ...
    Preparing to unpack .../107-pixflat-icons_0.26_all.deb ...
    Unpacking pixflat-icons (0.26) over (0.25) ...
    Preparing to unpack .../108-pixflat-theme_0.21_arm64.deb ...
    Unpacking pixflat-theme (0.21) over (0.20) ...
    Preparing to unpack .../109-python3-cryptography_38.0.4-3+deb12u1_arm64.deb ...
    Unpacking python3-cryptography (38.0.4-3+deb12u1) over (38.0.4-3) ...
    Preparing to unpack .../110-python3-libcamera_0.3.2+rpt20241119-1_arm64.deb ...
    Unpacking python3-libcamera:arm64 (0.3.2+rpt20241119-1) over (0.3.2+rpt20240927-1) ...
    Preparing to unpack .../111-raspberrypi-net-mods_1.4.3_all.deb ...
    Unpacking raspberrypi-net-mods (1.4.3) over (1.4.1) ...
    Preparing to unpack .../112-rc-gui_1.90_arm64.deb ...
    Unpacking rc-gui (1.90) over (1.85) ...
    Preparing to unpack .../113-rfkill_2.38.1-5+deb12u2_arm64.deb ...
    Unpacking rfkill (2.38.1-5+deb12u2) over (2.38.1-5+deb12u1) ...
    Preparing to unpack .../114-rp-bookshelf_0.24_arm64.deb ...
    Unpacking rp-bookshelf (0.24) over (0.23) ...
    Preparing to unpack .../115-rp-prefapps_0.65_arm64.deb ...
    Unpacking rp-prefapps (0.65) over (0.59) ...
    Preparing to unpack .../116-rpd-plym-splash_0.42_arm64.deb ...
    Unpacking rpd-plym-splash (0.42) over (0.39) ...
    Preparing to unpack .../117-rpi-eeprom_26.7-1_all.deb ...
    Unpacking rpi-eeprom (26.7-1) over (26.0-1) ...
    Preparing to unpack .../118-rpicam-apps_1.5.3-1_arm64.deb ...
    Unpacking rpicam-apps (1.5.3-1) over (1.5.2-2) ...
    Preparing to unpack .../119-vlc-l10n_1%3a3.0.21-0+rpt3+deb12u1_all.deb ...
    Unpacking vlc-l10n (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../120-vlc-plugin-access-extra_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-access-extra:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../121-vlc-plugin-notify_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-notify:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../122-vlc-plugin-samba_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-samba:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../123-vlc-plugin-video-splitter_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-video-splitter:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../124-vlc-plugin-visualization_1%3a3.0.21-0+rpt3+deb12u1_arm64.deb ...
    Unpacking vlc-plugin-visualization:arm64 (1:3.0.21-0+rpt3+deb12u1) over (1:3.0.21-0+rpt2+deb12u1) ...
    Preparing to unpack .../125-wayvnc_0.9.0~dev-1+rpt2_arm64.deb ...
    Unpacking wayvnc (0.9.0~dev-1+rpt2) over (0.9.0~dev-1+rpt1) ...
    pi@VISundGrafana:~ $ sudo reboot
    Broadcast message from root@VISundGrafana on pts/2 (Sun 2025-01-05 17:17:32 CET):
    The system will reboot now!
    login as: pi
    Last login: Sun Jan  5 17:18:10 2025
    You might want to run 'apt --fix-broken install' to correct these.
    The following packages have unmet dependencies:
     libwebkit2gtk-4.1-0 : Depends: libjavascriptcoregtk-4.1-0 (= 2.46.0-2~deb12u1) but 2.46.5-1~deb12u1 is installed
                           Recommends: gstreamer1.0-gl but it is not installed
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    • K knopers1
      sudo apt-get clean
      sudo apt-get update
      login as: pi
      M Online
      M Online
      MCU
      @knopers1 ChatGPT sagt dazu
      fix broken dependencies
      sudo apt-get install -f
      // oder
      sudo apt --fix-broken install
      Danach soll man dist ausführen
      sudo apt-get dist-upgrade
      Hab keine Ahnung, vielleicht kann @Thomas-Braun mehr dazu sagen.
      • M MCU
        // oder
        knopers1
        @mcu said in RPI5 apt-get upgrade schlägt Fehlermeldung:
        Danke Dir, ich würde ungern die Installation zerschießen. @Thomas-Braun - kannst Du wieder helfen? 😧
        • K knopers1
          Meister MopperM Online
          Meister Mopper
          @knopers1 sagte in RPI5 apt-get upgrade schlägt Fehlermeldung:
          Da kann ja nichts kaputtgehen.
          Proxmox und HA ...
            knopers1
            schrieb am zuletzt editiert von knopers1
            @meister-mopper
            danke Dir!
            pi@VISundGrafana:~ $ sudo apt --fix-broken install
            Correcting dependencies... Done
            The following additional packages will be installed:
              libwebkit2gtk-4.1-0
            Recommended packages:
              gstreamer1.0-gl
              libwebkit2gtk-4.1-0
            1 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
            150 not fully installed or removed.
            Need to get 0 B/21.7 MB of archives.
            After this operation, 262 kB of additional disk space will be used.
            Setting up libssl3:arm64 (3.0.15-1~deb12u1+rpt1) ...
            Setting up libfdisk1:arm64 (2.38.1-5+deb12u2) ...
            Setting up libsystemd-shared:arm64 (252.31-1~deb12u1) ...
            Setting up mount (2.38.1-5+deb12u2) ...
            Setting up systemd (252.31-1~deb12u1) ...
            (Reading database ... 158829 files and directories currently installed.)
            Preparing to unpack .../libwebkit2gtk-4.1-0_2.46.5-1~deb12u1_arm64.deb ...
            Setting up libpixman-1-0:arm64 (0.42.2-1+rpt3) ...
            Setting up libwayland-server0:arm64 (1.23.0-1~bpo12+1+rpt1) ...
            Setting up libfm-gtk-data (1.3.2-1+rpt18) ...
            Setting up edid-decode (0.1~git20241119.5332a3b-1) ...
            Setting up systemd-sysv (252.31-1~deb12u1) ...
            Setting up librados2 (16.2.15+ds-0+deb12u1) ...
            Setting up libc-l10n (2.36-9+rpt2+deb12u9) ...
            Setting up libpixman-1-dev:arm64 (0.42.2-1+rpt3) ...
            Setting up libmpg123-0:arm64 (1.31.2-1+deb12u1) ...
            Setting up bsdextrautils (2.38.1-5+deb12u2) ...
            Setting up libarchive13:arm64 (3.6.2-1+deb12u2) ...
            Setting up libglib2.0-0:arm64 (2.74.6-2+deb12u4) ...
            Setting up distro-info-data (0.58+deb12u3) ...
            Setting up libgs-common (10.0.0~dfsg-11+deb12u6) ...
            Setting up libsqlite3-0:arm64 (3.40.1-2+deb12u1) ...
            Setting up libheif1:arm64 (1.15.1-1+deb12u1) ...
            Setting up agnostics (0.17) ...
            Setting up pixflat-theme (0.21) ...
            Setting up libnghttp2-14:arm64 (1.52.0-1+deb12u2) ...
            Setting up linux-libc-dev (1:6.6.62-1+rpt1) ...
            Setting up libcurl3-gnutls:arm64 (7.88.1-10+deb12u8) ...
            Setting up libnss3:arm64 (2:3.87.1-1+deb12u1) ...
            Setting up libntfs-3g89:arm64 (1:2022.10.3-1+deb12u2) ...
            Setting up vlc-l10n (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libcjson1:arm64 (1.7.15-1+deb12u2) ...
            Setting up locales (2.36-9+rpt2+deb12u9) ...
            Generating locales (this might take a while)...
              en_GB.UTF-8... done
            Generation complete.
            Setting up libfm-data (1.3.2-1+rpt18) ...
            Setting up ntfs-3g (1:2022.10.3-1+deb12u2) ...
            Setting up fdisk (2.38.1-5+deb12u2) ...
            Setting up ninja-build (1.11.1-2~deb12u1) ...
            Setting up libc6-dbg:arm64 (2.36-9+rpt2+deb12u9) ...
            Setting up gui-pkinst (0.19) ...
            Setting up lxinput (0.3.5-1+rpt26) ...
            Setting up tzdata (2024b-0+deb12u1) ...
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Sun Jan  5 17:48:06 CET 2025.
            Universal Time is now:  Sun Jan  5 16:48:06 UTC 2025.
            Run 'dpkg-reconfigure tzdata' if you wish to change it.
            Setting up eject (2.38.1-5+deb12u2) ...
            Setting up libglib2.0-data (2.74.6-2+deb12u4) ...
            Setting up libjavascriptcoregtk-4.1-0:arm64 (2.46.5-1~deb12u1) ...
            Setting up python3-cryptography (38.0.4-3+deb12u1) ...
            Setting up pipanel (1:1.49) ...
            Setting up rfkill (2.38.1-5+deb12u2) ...
            Setting up raspi-firmware (1:1.20241126-1) ...
            '/boot/vmlinuz-6.6.51+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img'
            '/boot/vmlinuz-6.6.51+rpt-rpi-v8' -> '/boot/firmware/kernel8.img'
            Setting up systemd-timesyncd (252.31-1~deb12u1) ...
            Setting up udev (252.31-1~deb12u1) ...
            Setting up libudev-dev:arm64 (252.31-1~deb12u1) ...
            Setting up librbd1 (16.2.15+ds-0+deb12u1) ...
            Setting up libfm4:arm64 (1.3.2-1+rpt18) ...
            Setting up raspberrypi-net-mods (1.4.3) ...
            Installing new version of config file /etc/profile.d/wifi-check.sh ...
            Setting up libvlccore9:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up liblightdm-gobject-1-0:arm64 (1.26.0-8+rpt5) ...
            Setting up pishutdown (0.30) ...
            Setting up libpam-systemd:arm64 (252.31-1~deb12u1) ...
            Setting up libcurl4:arm64 (7.88.1-10+deb12u8) ...
            Setting up rpi-eeprom (26.7-1) ...
            Setting up lxpanel-data (0.10.1-2+rpt20) ...
            Setting up pixflat-icons (0.26) ...
            gtk-update-icon-cache: Cache file created successfully.
            Setting up libpython3.11-minimal:arm64 (3.11.2-6+deb12u4) ...
            Setting up curl (7.88.1-10+deb12u8) ...
            Setting up libwayland-egl1:arm64 (1.23.0-1~bpo12+1+rpt1) ...
            Setting up xserver-common (2:21.1.7-3+rpt3+deb12u8) ...
            Setting up piclone (0.31) ...
            Setting up initramfs-tools-core (0.142+rpt2+deb12u1) ...
            Setting up libc-dev-bin (2.36-9+rpt2+deb12u9) ...
            Setting up openssl (3.0.15-1~deb12u1+rpt1) ...
            Setting up libdrm-common (2.4.123-1~bpo12+1+rpt1) ...
            Setting up iputils-ping (3:20221126-1+deb12u1) ...
            Setting up vlc-data (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libgstreamer1.0-0:arm64 (1.22.0-2+deb12u1) ...
            Setcap worked! gst-ptp-helper is not suid!
            Setting up vlc-plugin-notify:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libc-devtools (2.36-9+rpt2+deb12u9) ...
            Setting up vlc-plugin-samba:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up rc-gui (1.90) ...
            Setting up lightdm (1.26.0-8+rpt5) ...
            Setting up libwayland-client0:arm64 (1.23.0-1~bpo12+1+rpt1) ...
            Setting up libfm-gtk4:arm64 (1.3.2-1+rpt18) ...
            Setting up python3.11-minimal (3.11.2-6+deb12u4) ...
            Setting up libgs10-common (10.0.0~dfsg-11+deb12u6) ...
            Setting up libglib2.0-dev-bin (2.74.6-2+deb12u4) ...
            Setting up rp-prefapps (0.65) ...
            Setting up gui-updater (0.4) ...
            Setting up pcmanfm (1.3.2-1+rpt29) ...
            Setting up initramfs-tools (0.142+rpt2+deb12u1) ...
            update-initramfs: deferring update (trigger activated)
            Setting up libfm-extra4:arm64 (1.3.2-1+rpt18) ...
            Setting up firefox (133.0-1+rpt7) ...
            Setting up libfm-modules:arm64 (1.3.2-1+rpt18) ...
            Setting up libpython3.11-stdlib:arm64 (3.11.2-6+deb12u4) ...
            Setting up vlc-plugin-video-splitter:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up lxpanel (0.10.1-2+rpt20) ...
            Setting up libglib2.0-bin (2.74.6-2+deb12u4) ...
            Setting up libvlc5:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libgstreamer-plugins-base1.0-0:arm64 (1.22.0-3+deb12u3) ...
            Setting up raspberrypi-sys-mods (20241202) ...
            Setting up lxplug-menu (0.5) ...
            Setting up vlc-plugin-visualization:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up lxplug-bluetooth (0.36) ...
            Setting up vlc-plugin-access-extra:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up gstreamer1.0-plugins-base:arm64 (1.22.0-3+deb12u3) ...
            Setting up pi-greeter (0.25) ...
            Setting up rp-bookshelf (0.24) ...
            Setting up libdrm2:arm64 (2.4.123-1~bpo12+1+rpt1) ...
            Setting up vlc-plugin-qt:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libvlc-bin:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libwayland-cursor0:arm64 (1.23.0-1~bpo12+1+rpt1) ...
            Setting up libc6-dev:arm64 (2.36-9+rpt2+deb12u9) ...
            Setting up vlc-plugin-base:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up lxplug-updater (0.20) ...
            Setting up vlc-plugin-video-output:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libdrm-amdgpu1:arm64 (2.4.123-1~bpo12+1+rpt1) ...
            Setting up lxde-core (11+rpt2) ...
            Setting up libgs10:arm64 (10.0.0~dfsg-11+deb12u6) ...
            Setting up libliftoff0:arm64 (0.4.1-1~bpo12+rpt2) ...
            Setting up lxplug-netman (0.12) ...
            Setting up python3.11 (3.11.2-6+deb12u4) ...
            Setting up libdrm-nouveau2:arm64 (2.4.123-1~bpo12+1+rpt1) ...
            Setting up gstreamer1.0-x:arm64 (1.22.0-3+deb12u3) ...
            Setting up gstreamer1.0-alsa:arm64 (1.22.0-3+deb12u3) ...
            Setting up lxplug-ejecter (0.23) ...
            Setting up libpython3.11:arm64 (3.11.2-6+deb12u4) ...
            Setting up vlc-plugin-skins2:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up rpd-plym-splash (0.42) ...
            Setting up lxplug-volumepulse (0.27) ...
            Setting up libdrm-radeon1:arm64 (2.4.123-1~bpo12+1+rpt1) ...
            Setting up xserver-xorg-core (2:21.1.7-3+rpt3+deb12u8) ...
            Setting up vlc-bin (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up userconf-pi (0.10) ...
            Setting up libwlroots12:arm64 (0.17.4-1+rpt1) ...
            Setting up ghostscript (10.0.0~dfsg-11+deb12u6) ...
            Setting up libneatvnc0:arm64 (0.9.0+dfsg-1~rpt3) ...
            Setting up libgstreamer-gl1.0-0:arm64 (1.22.0-3+deb12u3) ...
            Setting up lxde (11+rpt2) ...
            Setting up python3.11-venv (3.11.2-6+deb12u4) ...
            Setting up uuid-dev:arm64 (2.38.1-5+deb12u2) ...
            Setting up piwiz (0.86) ...
            Setting up zlib1g-dev:arm64 (1:1.2.13.dfsg-1+rpt1) ...
            Setting up wayvnc (0.9.0~dev-1+rpt2) ...
            Setting up vlc (1:3.0.21-0+rpt3+deb12u1) ...
            Setting up libblkid-dev:arm64 (2.38.1-5+deb12u2) ...
            Setting up libwebkit2gtk-4.1-0:arm64 (2.46.5-1~deb12u1) ...
            Setting up libpython3.11-dev:arm64 (3.11.2-6+deb12u4) ...
            Setting up libmount-dev:arm64 (2.38.1-5+deb12u2) ...
            Setting up python3.11-dev (3.11.2-6+deb12u4) ...
            Setting up libglib2.0-dev:arm64 (2.74.6-2+deb12u4) ...
            Setting up libcamera-ipa:arm64 (0.3.2+rpt20241119-1) ...
            Setting up libcamera0.3:arm64 (0.3.2+rpt20241119-1) ...
            Setting up rpicam-apps (1.5.3-1) ...
            Setting up python3-libcamera:arm64 (0.3.2+rpt20241119-1) ...
            Setting up libcamera-tools (0.3.2+rpt20241119-1) ...
            Processing triggers for desktop-file-utils (0.26-1) ...
            Processing triggers for hicolor-icon-theme (0.17-2) ...
            Processing triggers for gnome-menus (3.36.0-1.1) ...
            Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
            Processing triggers for man-db (2.11.2-2) ...
            Processing triggers for dbus (1.14.10-1~deb12u1) ...
            Processing triggers for shared-mime-info (2.2-1) ...
            Processing triggers for mailcap (3.70+nmu1) ...
            Processing triggers for initramfs-tools (0.142+rpt2+deb12u1) ...
            update-initramfs: Generating /boot/initrd.img-6.6.51+rpt-rpi-v8
            '/boot/initrd.img-6.6.51+rpt-rpi-v8' -> '/boot/firmware/initramfs8'
            update-initramfs: Generating /boot/initrd.img-6.6.51+rpt-rpi-2712
            '/boot/initrd.img-6.6.51+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712'
            update-initramfs: Generating /boot/initrd.img-6.6.31+rpt-rpi-v8
            update-initramfs: Generating /boot/initrd.img-6.6.31+rpt-rpi-2712
            Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt3+deb12u1) ...
            Danach:
              nodejs
            1 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
            Need to get 0 B/30.9 MB of archives.
            After this operation, 42.0 kB of additional disk space will be used.
            Preparing to unpack .../nodejs_20.18.1-1nodesource1_arm64.deb ...
            Setting up nodejs (20.18.1-1nodesource1) ...
            Das wars jetzt? Ich bin der Meinung, dass alles jetzt ohne Fehler installiert ist. Kannst Du das so bestätigen? 🙄
            • K knopers1
              @meister-mopper
              danke Dir!
                libwebkit2gtk-4.1-0
                gstreamer1.0-gl
                libwebkit2gtk-4.1-0
                en_GB.UTF-8... done
              Danach:
                nodejs
              hast du da die Reparatur abgebrochen?
                knopers1
                @homoran nein !
                0 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
                da stimmt noch etwas nicht!
                • K knopers1
                  @homoran nein !
                  weil ich aus dem Putty die Zeilen mit Strg+C kopiert habe
                  das kannst du nicht!
                  nur markieren - fertig!
                  STRG-C bricht die Ausführung des laufenden Befehls ab
                    knopers1
                    das ist klar, dies habe ich aber kopiert, nachdem alles durch war! Unterbrochen habe ich dort sicherlich nichts....
                    und jetzt noch mal der fix ?
                    • K knopers1
                      da müsste man mal sehen, warum.
                      Aber frag mich nicht ;-)
                        knopers1
                        @homoran , ja genau die Pakete....
                        pi@VISundGrafana:~ $ apt list --upgradable
                        Listing... Done
                        chromium-browser-l10n/stable,stable 1:130.0.6723.116-1~deb12u1+rpt1 all [upgradable from: 125.0.6422.133-rpt1]
                        chromium-browser/stable,stable 1:130.0.6723.116-1~deb12u1+rpt1 arm64 [upgradable from: 125.0.6422.133-rpt1]
                        chromium-codecs-ffmpeg-extra/stable 126.0.6478.164-rpt1 arm64 [upgradable from: 125.0.6422.133-rpt1]
                        labwc/stable 0.8.1-1+rpt1 arm64 [upgradable from: 0.7.2-1+rpt4]
                        libpipewire-0.3-0/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        libpipewire-0.3-modules/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        libspa-0.2-bluetooth/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        libspa-0.2-modules/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        linux-headers-rpi-2712/stable 1:6.6.62-1+rpt1 arm64 [upgradable from: 1:6.6.51-1+rpt3]
                        linux-headers-rpi-v8/stable 1:6.6.62-1+rpt1 arm64 [upgradable from: 1:6.6.51-1+rpt3]
                        linux-image-rpi-2712/stable 1:6.6.62-1+rpt1 arm64 [upgradable from: 1:6.6.51-1+rpt3]
                        linux-image-rpi-v8/stable 1:6.6.62-1+rpt1 arm64 [upgradable from: 1:6.6.51-1+rpt3]
                        pipewire-bin/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        pipewire-libcamera/stable,stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        pipewire-pulse/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        pipewire/stable 1.2.4-1~bpo12+1+rpt1 arm64 [upgradable from: 0.3.65-3+rpt9+deb12u1]
                        python3-picamera2/stable,stable 0.3.23-1 all [upgradable from: 0.3.19-1]
                        raspberrypi-ui-mods/stable 1.20241211 arm64 [upgradable from: 1.20240808]
                        raspi-config/stable,stable 20241210 all [upgradable from: 20240708]
                        raspi-utils/stable,stable 20240903-1 arm64 [upgradable from: 20240402-3]
                        rpi-chromium-mods/stable 20240904 arm64 [upgradable from: 20230925]
                        rpi-connect/stable 2.1.0 arm64 [upgradable from: 1.4.0]
                        rpi-imager/stable 1.9.1 arm64 [upgradable from: 1.8.5+rpt1]
                        wf-panel-pi/stable 0.91 arm64 [upgradable from: 0.76]
                        • K knopers1
                          Listing... Done
                          knopers1
                          bin jetzt wieder ein Stück weiter...
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          pi@VISundGrafana:~ $ sudo apt full-upgrade
                          Reading package lists... Done
                          Calculating upgrade... Done
                          The following packages were automatically installed and are no longer required:
                            chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libqt5qmlworkerscript5
                            libqt5quickcontrols2-5 libqt5quicktemplates2-5 libwlroots12 python3-gi-cairo qml-module-qtgraphicaleffects
                            qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2
                            qml-module-qtquick2
                          Use 'sudo apt autoremove' to remove them.
                          The following packages will be REMOVED:
                            arandr lxinput
                          The following NEW packages will be installed:
                            autotouch chromium chromium-common chromium-l10n chromium-sandbox dconf-cli fonts-liberation labwc-prompt libc++1-16
                            libc++abi1-16 libconfig++9v5 libffado2 libfuse2 libminizip1 libspa-0.2-libcamera libunwind-16 libupower-glib3
                            libwlroots-0.18 libxcb-errors0 libxml++2.6-2v5 linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.62+rpt-rpi-2712
                            linux-headers-6.6.62+rpt-rpi-v8 linux-image-6.6.62+rpt-rpi-2712 linux-image-6.6.62+rpt-rpi-v8 linux-kbuild-6.6.62+rpt
                            notification-daemon python3-attr python3-json-pointer python3-jsonschema python3-libarchive-c python3-pyrsistent
                            python3-rfc3987 python3-tqdm python3-uritemplate python3-webcolors raindrop raspi-utils-core raspi-utils-dt
                            raspi-utils-eeprom raspi-utils-otp raspinfo rasputin upower wfplug-connect wfplug-squeek xmlstarlet
                          The following packages will be upgraded:
                            chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra labwc libpipewire-0.3-0 libpipewire-0.3-modules
                            libspa-0.2-bluetooth libspa-0.2-modules linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712
                            linux-image-rpi-v8 pipewire pipewire-bin pipewire-libcamera pipewire-pulse python3-picamera2 raspberrypi-ui-mods
                            raspi-config raspi-utils rpi-chromium-mods rpi-connect rpi-imager wf-panel-pi
                          24 upgraded, 47 newly installed, 2 to remove and 0 not upgraded.
                          Need to get 296 MB of archives.
                          After this operation, 191 MB of additional disk space will be used.
                          Do you want to continue? [Y/n] y
                          Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 rasputin arm64 0.2 [54.4 kB]
                          Get:2 http://deb.debian.org/debian bookworm/main arm64 libunwind-16 arm64 1:16.0.6-15~deb12u1 [53.1 kB]
                          Get:3 http://deb.debian.org/debian bookworm/main arm64 libc++abi1-16 arm64 1:16.0.6-15~deb12u1 [89.4 kB]
                          Get:4 http://deb.debian.org/debian bookworm/main arm64 libc++1-16 arm64 1:16.0.6-15~deb12u1 [269 kB]
                          Get:5 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-common arm64 1:130.0.6723.116-1~deb12u1+rpt1 [20.1 MB]
                          Get:6 http://deb.debian.org/debian bookworm/main arm64 libminizip1 arm64 1.1-8+deb12u1 [19.8 kB]
                          Get:7 http://deb.debian.org/debian bookworm/main arm64 xmlstarlet arm64 1.6.1-3 [210 kB]
                          Get:8 http://deb.debian.org/debian bookworm/main arm64 dconf-cli arm64 0.40.0-4 [25.2 kB]
                          Get:9 http://deb.debian.org/debian bookworm/main arm64 fonts-liberation all 1:1.07.4-11 [828 kB]
                          Get:10 http://deb.debian.org/debian bookworm/main arm64 libconfig++9v5 arm64 1.5-0.4 [36.8 kB]
                          Get:11 http://deb.debian.org/debian bookworm/main arm64 libxml++2.6-2v5 arm64 2.40.1-3 [83.7 kB]
                          Get:12 http://deb.debian.org/debian bookworm/main arm64 libffado2 arm64 2.4.7-1 [573 kB]
                          Get:13 http://deb.debian.org/debian bookworm/main arm64 libfuse2 arm64 2.9.9-6+b1 [114 kB]
                          Get:14 http://deb.debian.org/debian bookworm/main arm64 libupower-glib3 arm64 0.99.20-2 [34.2 kB]
                          Get:15 http://deb.debian.org/debian bookworm/main arm64 notification-daemon arm64 3.20.0-4+b1 [59.5 kB]
                          Get:16 http://deb.debian.org/debian bookworm/main arm64 python3-attr all 22.2.0-1 [65.4 kB]
                          Get:17 http://deb.debian.org/debian bookworm/main arm64 python3-json-pointer all 2.3-2 [15.1 kB]
                          Get:18 http://deb.debian.org/debian bookworm/main arm64 python3-pyrsistent arm64 0.18.1-1+b3 [59.4 kB]
                          Get:19 http://deb.debian.org/debian bookworm/main arm64 python3-jsonschema all 4.10.3-1 [67.9 kB]
                          Get:20 http://deb.debian.org/debian bookworm/main arm64 python3-libarchive-c all 2.9-0.1 [14.5 kB]
                          Get:21 http://deb.debian.org/debian bookworm/main arm64 python3-tqdm all 4.64.1-1 [97.7 kB]
                          Get:22 http://deb.debian.org/debian bookworm/main arm64 python3-rfc3987 all 1.3.8-2 [8,816 B]
                          Get:23 http://deb.debian.org/debian bookworm/main arm64 python3-uritemplate all 4.1.1-2 [10.9 kB]
                          Get:24 http://deb.debian.org/debian bookworm/main arm64 python3-webcolors all 1.11.1-1 [12.7 kB]
                          Get:25 http://deb.debian.org/debian bookworm/main arm64 upower arm64 0.99.20-2 [77.6 kB]
                          Get:26 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser-l10n all 1:130.0.6723.116-1~deb12u1+rpt1 [97.6 kB]
                          Get:27 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser all 1:130.0.6723.116-1~deb12u1+rpt1 [97.6 kB]
                          Get:28 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium arm64 1:130.0.6723.116-1~deb12u1+rpt1 [112 MB]
                          Get:29 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-l10n all 1:130.0.6723.116-1~deb12u1+rpt1 [17.8 MB]
                          Get:30 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-codecs-ffmpeg-extra arm64 126.0.6478.164-rpt1 [939 kB]
                          Get:31 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-chromium-mods arm64 20240904 [4,974 B]
                          Get:32 http://archive.raspberrypi.com/debian bookworm/main arm64 autotouch all 0.1 [2,724 B]
                          Get:33 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-sandbox arm64 1:130.0.6723.116-1~deb12u1+rpt1 [105 kB]
                          Get:34 http://archive.raspberrypi.com/debian bookworm/main arm64 libxcb-errors0 arm64 1.0.1-2~bpo12+1+rpt1 [19.9 kB]
                          Get:35 http://archive.raspberrypi.com/debian bookworm/main arm64 libwlroots-0.18 arm64 0.18.1-1+rpt6 [453 kB]
                          Get:36 http://archive.raspberrypi.com/debian bookworm/main arm64 labwc arm64 0.8.1-1+rpt1 [247 kB]
                          Get:37 http://archive.raspberrypi.com/debian bookworm/main arm64 labwc-prompt arm64 0.3 [6,604 B]
                          Get:38 http://archive.raspberrypi.com/debian bookworm/main arm64 pipewire-pulse arm64 1.2.4-1~bpo12+1+rpt1 [25.2 kB]
                          Get:39 http://archive.raspberrypi.com/debian bookworm/main arm64 libspa-0.2-bluetooth arm64 1.2.4-1~bpo12+1+rpt1 [539 kB]
                          Get:40 http://archive.raspberrypi.com/debian bookworm/main arm64 pipewire-libcamera all 1.2.4-1~bpo12+1+rpt1 [19.5 kB]
                          Get:41 http://archive.raspberrypi.com/debian bookworm/main arm64 pipewire-bin arm64 1.2.4-1~bpo12+1+rpt1 [549 kB]
                          Get:42 http://archive.raspberrypi.com/debian bookworm/main arm64 pipewire arm64 1.2.4-1~bpo12+1+rpt1 [111 kB]
                          Get:43 http://archive.raspberrypi.com/debian bookworm/main arm64 libpipewire-0.3-modules arm64 1.2.4-1~bpo12+1+rpt1 [1,576 kB]
                          Get:44 http://archive.raspberrypi.com/debian bookworm/main arm64 libpipewire-0.3-0 arm64 1.2.4-1~bpo12+1+rpt1 [398 kB]
                          Get:45 http://archive.raspberrypi.com/debian bookworm/main arm64 libspa-0.2-modules arm64 1.2.4-1~bpo12+1+rpt1 [1,023 kB]
                          Get:46 http://archive.raspberrypi.com/debian bookworm/main arm64 libspa-0.2-libcamera arm64 1.2.4-1~bpo12+1+rpt1 [75.9 kB]
                          Get:47 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.6.62+rpt-common-rpi all 1:6.6.62-1+rpt1 [8,236 kB]
                          Get:48 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.6.62+rpt-rpi-2712 arm64 1:6.6.62-1+rpt1 [29.7 MB]
                          Get:49 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-6.6.62+rpt arm64 1:6.6.62-1+rpt1 [1,013 kB]
                          Get:50 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.6.62+rpt-rpi-2712 arm64 1:6.6.62-1+rpt1 [1,130 kB]
                          Get:51 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.6.62+rpt-rpi-v8 arm64 1:6.6.62-1+rpt1 [29.7 MB]
                          Get:52 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.6.62+rpt-rpi-v8 arm64 1:6.6.62-1+rpt1 [1,130 kB]
                          Get:53 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-2712 arm64 1:6.6.62-1+rpt1 [1,160 B]
                          Get:54 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-v8 arm64 1:6.6.62-1+rpt1 [1,156 B]
                          Get:55 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-2712 arm64 1:6.6.62-1+rpt1 [1,420 B]
                          Get:56 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-v8 arm64 1:6.6.62-1+rpt1 [1,424 B]
                          Get:57 http://archive.raspberrypi.com/debian bookworm/main arm64 python3-picamera2 all 0.3.23-1 [98.6 kB]
                          Get:58 http://archive.raspberrypi.com/debian bookworm/main arm64 raindrop arm64 0.12 [63.3 kB]
                          Get:59 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils all 20240903-1 [4,778 B]
                          Get:60 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-core arm64 20240903-1 [64.3 kB]
                          Get:61 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-otp all 20240903-1 [7,190 B]
                          Get:62 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-dt arm64 20240903-1 [78.6 kB]
                          Get:63 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-eeprom arm64 20240903-1 [23.8 kB]
                          Get:64 http://archive.raspberrypi.com/debian bookworm/main arm64 raspinfo all 20240903-1 [6,882 B]
                          Get:65 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config all 20241210 [35.6 kB]
                          Get:66 http://archive.raspberrypi.com/debian bookworm/main arm64 wf-panel-pi arm64 0.91 [1,003 kB]
                          Get:67 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-ui-mods arm64 1.20241211 [1,058 kB]
                          Get:68 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-connect arm64 2.1.0 [7,495 kB]
                          Get:69 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-imager arm64 1.9.1 [56.0 MB]
                          Get:70 http://archive.raspberrypi.com/debian bookworm/main arm64 wfplug-connect arm64 0.10 [27.4 kB]
                          Get:71 http://archive.raspberrypi.com/debian bookworm/main arm64 wfplug-squeek arm64 0.5 [17.9 kB]
                          Fetched 296 MB in 57s (5,230 kB/s)
                          Reading changelogs... Done
                          Extracting templates from packages: 100%
                          Removing arandr (0.1.11-1+rpt26) ...
                          dpkg: lxinput: dependency problems, but removing anyway as you requested:
                           lxde depends on rasputin | lxinput; however:
                            Package rasputin is not installed.
                            Package lxinput is to be removed.
                          Removing lxinput (0.3.5-1+rpt26) ...
                          Selecting previously unselected package rasputin.
                          (Reading database ... 158683 files and directories currently installed.)
                          Preparing to unpack .../00-rasputin_0.2_arm64.deb ...
                          Unpacking rasputin (0.2) ...
                          Selecting previously unselected package libunwind-16:arm64.
                          Preparing to unpack .../01-libunwind-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
                          Unpacking libunwind-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Selecting previously unselected package libc++abi1-16:arm64.
                          Preparing to unpack .../02-libc++abi1-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
                          Unpacking libc++abi1-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Selecting previously unselected package libc++1-16:arm64.
                          Preparing to unpack .../03-libc++1-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
                          Unpacking libc++1-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Selecting previously unselected package libminizip1:arm64.
                          Preparing to unpack .../04-libminizip1_1.1-8+deb12u1_arm64.deb ...
                          Unpacking libminizip1:arm64 (1.1-8+deb12u1) ...
                          Selecting previously unselected package chromium-common.
                          Preparing to unpack .../05-chromium-common_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb ...
                          Unpacking chromium-common (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Preparing to unpack .../06-chromium-browser-l10n_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
                          Unpacking chromium-browser-l10n (1:130.0.6723.116-1~deb12u1+rpt1) over (125.0.6422.133-rpt1) ...
                          Preparing to unpack .../07-chromium-browser_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
                          Unpacking chromium-browser (1:130.0.6723.116-1~deb12u1+rpt1) over (125.0.6422.133-rpt1) ...
                          Selecting previously unselected package chromium.
                          Preparing to unpack .../08-chromium_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb ...
                          Unpacking chromium (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Selecting previously unselected package chromium-l10n.
                          Preparing to unpack .../09-chromium-l10n_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
                          Unpacking chromium-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Preparing to unpack .../10-chromium-codecs-ffmpeg-extra_126.0.6478.164-rpt1_arm64.deb ...
                          Unpacking chromium-codecs-ffmpeg-extra (126.0.6478.164-rpt1) over (125.0.6422.133-rpt1) ...
                          Preparing to unpack .../11-rpi-chromium-mods_20240904_arm64.deb ...
                          Unpacking rpi-chromium-mods (20240904) over (20230925) ...
                          Selecting previously unselected package xmlstarlet.
                          Preparing to unpack .../12-xmlstarlet_1.6.1-3_arm64.deb ...
                          Unpacking xmlstarlet (1.6.1-3) ...
                          Selecting previously unselected package autotouch.
                          Preparing to unpack .../13-autotouch_0.1_all.deb ...
                          Unpacking autotouch (0.1) ...
                          Selecting previously unselected package chromium-sandbox.
                          Preparing to unpack .../14-chromium-sandbox_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb ...
                          Unpacking chromium-sandbox (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Selecting previously unselected package dconf-cli.
                          Preparing to unpack .../15-dconf-cli_0.40.0-4_arm64.deb ...
                          Unpacking dconf-cli (0.40.0-4) ...
                          Selecting previously unselected package fonts-liberation.
                          Preparing to unpack .../16-fonts-liberation_1%3a1.07.4-11_all.deb ...
                          Unpacking fonts-liberation (1:1.07.4-11) ...
                          Selecting previously unselected package libxcb-errors0:arm64.
                          Preparing to unpack .../17-libxcb-errors0_1.0.1-2~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libxcb-errors0:arm64 (1.0.1-2~bpo12+1+rpt1) ...
                          Selecting previously unselected package libwlroots-0.18:arm64.
                          Preparing to unpack .../18-libwlroots-0.18_0.18.1-1+rpt6_arm64.deb ...
                          Unpacking libwlroots-0.18:arm64 (0.18.1-1+rpt6) ...
                          Preparing to unpack .../19-labwc_0.8.1-1+rpt1_arm64.deb ...
                          Unpacking labwc (0.8.1-1+rpt1) over (0.7.2-1+rpt4) ...
                          Selecting previously unselected package labwc-prompt.
                          Preparing to unpack .../20-labwc-prompt_0.3_arm64.deb ...
                          Unpacking labwc-prompt (0.3) ...
                          Selecting previously unselected package libconfig++9v5:arm64.
                          Preparing to unpack .../21-libconfig++9v5_1.5-0.4_arm64.deb ...
                          Unpacking libconfig++9v5:arm64 (1.5-0.4) ...
                          Selecting previously unselected package libxml++2.6-2v5:arm64.
                          Preparing to unpack .../22-libxml++2.6-2v5_2.40.1-3_arm64.deb ...
                          Unpacking libxml++2.6-2v5:arm64 (2.40.1-3) ...
                          Selecting previously unselected package libffado2:arm64.
                          Preparing to unpack .../23-libffado2_2.4.7-1_arm64.deb ...
                          Unpacking libffado2:arm64 (2.4.7-1) ...
                          Selecting previously unselected package libfuse2:arm64.
                          Preparing to unpack .../24-libfuse2_2.9.9-6+b1_arm64.deb ...
                          Unpacking libfuse2:arm64 (2.9.9-6+b1) ...
                          Preparing to unpack .../25-pipewire-pulse_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking pipewire-pulse (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../26-libspa-0.2-bluetooth_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libspa-0.2-bluetooth:arm64 (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../27-pipewire-libcamera_1.2.4-1~bpo12+1+rpt1_all.deb ...
                          Unpacking pipewire-libcamera (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../28-pipewire-bin_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking pipewire-bin (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../29-pipewire_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking pipewire:arm64 (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../30-libpipewire-0.3-modules_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libpipewire-0.3-modules:arm64 (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../31-libpipewire-0.3-0_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libpipewire-0.3-0:arm64 (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Preparing to unpack .../32-libspa-0.2-modules_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libspa-0.2-modules:arm64 (1.2.4-1~bpo12+1+rpt1) over (0.3.65-3+rpt9+deb12u1) ...
                          Selecting previously unselected package libspa-0.2-libcamera:arm64.
                          Preparing to unpack .../33-libspa-0.2-libcamera_1.2.4-1~bpo12+1+rpt1_arm64.deb ...
                          Unpacking libspa-0.2-libcamera:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Selecting previously unselected package libupower-glib3:arm64.
                          Preparing to unpack .../34-libupower-glib3_0.99.20-2_arm64.deb ...
                          Unpacking libupower-glib3:arm64 (0.99.20-2) ...
                          Selecting previously unselected package linux-headers-6.6.62+rpt-common-rpi.
                          Preparing to unpack .../35-linux-headers-6.6.62+rpt-common-rpi_1%3a6.6.62-1+rpt1_all.deb ...
                          Unpacking linux-headers-6.6.62+rpt-common-rpi (1:6.6.62-1+rpt1) ...
                          Selecting previously unselected package linux-image-6.6.62+rpt-rpi-2712.
                          Preparing to unpack .../36-linux-image-6.6.62+rpt-rpi-2712_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-image-6.6.62+rpt-rpi-2712 (1:6.6.62-1+rpt1) ...
                          Selecting previously unselected package linux-kbuild-6.6.62+rpt.
                          Preparing to unpack .../37-linux-kbuild-6.6.62+rpt_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-kbuild-6.6.62+rpt (1:6.6.62-1+rpt1) ...
                          Selecting previously unselected package linux-headers-6.6.62+rpt-rpi-2712.
                          Preparing to unpack .../38-linux-headers-6.6.62+rpt-rpi-2712_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-headers-6.6.62+rpt-rpi-2712 (1:6.6.62-1+rpt1) ...
                          Selecting previously unselected package linux-image-6.6.62+rpt-rpi-v8.
                          Preparing to unpack .../39-linux-image-6.6.62+rpt-rpi-v8_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-image-6.6.62+rpt-rpi-v8 (1:6.6.62-1+rpt1) ...
                          Selecting previously unselected package linux-headers-6.6.62+rpt-rpi-v8.
                          Preparing to unpack .../40-linux-headers-6.6.62+rpt-rpi-v8_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-headers-6.6.62+rpt-rpi-v8 (1:6.6.62-1+rpt1) ...
                          Preparing to unpack .../41-linux-headers-rpi-2712_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-headers-rpi-2712 (1:6.6.62-1+rpt1) over (1:6.6.51-1+rpt3) ...
                          Preparing to unpack .../42-linux-headers-rpi-v8_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-headers-rpi-v8 (1:6.6.62-1+rpt1) over (1:6.6.51-1+rpt3) ...
                          Preparing to unpack .../43-linux-image-rpi-2712_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-image-rpi-2712 (1:6.6.62-1+rpt1) over (1:6.6.51-1+rpt3) ...
                          Preparing to unpack .../44-linux-image-rpi-v8_1%3a6.6.62-1+rpt1_arm64.deb ...
                          Unpacking linux-image-rpi-v8 (1:6.6.62-1+rpt1) over (1:6.6.51-1+rpt3) ...
                          Selecting previously unselected package notification-daemon.
                          Preparing to unpack .../45-notification-daemon_3.20.0-4+b1_arm64.deb ...
                          Unpacking notification-daemon (3.20.0-4+b1) ...
                          Selecting previously unselected package python3-attr.
                          Preparing to unpack .../46-python3-attr_22.2.0-1_all.deb ...
                          Unpacking python3-attr (22.2.0-1) ...
                          Selecting previously unselected package python3-json-pointer.
                          Preparing to unpack .../47-python3-json-pointer_2.3-2_all.deb ...
                          Unpacking python3-json-pointer (2.3-2) ...
                          Selecting previously unselected package python3-pyrsistent:arm64.
                          Preparing to unpack .../48-python3-pyrsistent_0.18.1-1+b3_arm64.deb ...
                          Unpacking python3-pyrsistent:arm64 (0.18.1-1+b3) ...
                          Selecting previously unselected package python3-jsonschema.
                          Preparing to unpack .../49-python3-jsonschema_4.10.3-1_all.deb ...
                          Unpacking python3-jsonschema (4.10.3-1) ...
                          Selecting previously unselected package python3-libarchive-c.
                          Preparing to unpack .../50-python3-libarchive-c_2.9-0.1_all.deb ...
                          Unpacking python3-libarchive-c (2.9-0.1) ...
                          Selecting previously unselected package python3-tqdm.
                          Preparing to unpack .../51-python3-tqdm_4.64.1-1_all.deb ...
                          Unpacking python3-tqdm (4.64.1-1) ...
                          Preparing to unpack .../52-python3-picamera2_0.3.23-1_all.deb ...
                          Unpacking python3-picamera2 (0.3.23-1) over (0.3.19-1) ...
                          Selecting previously unselected package python3-rfc3987.
                          Preparing to unpack .../53-python3-rfc3987_1.3.8-2_all.deb ...
                          Unpacking python3-rfc3987 (1.3.8-2) ...
                          Selecting previously unselected package python3-uritemplate.
                          Preparing to unpack .../54-python3-uritemplate_4.1.1-2_all.deb ...
                          Unpacking python3-uritemplate (4.1.1-2) ...
                          Selecting previously unselected package python3-webcolors.
                          Preparing to unpack .../55-python3-webcolors_1.11.1-1_all.deb ...
                          Unpacking python3-webcolors (1.11.1-1) ...
                          Selecting previously unselected package raindrop.
                          Preparing to unpack .../56-raindrop_0.12_arm64.deb ...
                          Unpacking raindrop (0.12) ...
                          Preparing to unpack .../57-raspi-utils_20240903-1_all.deb ...
                          Unpacking raspi-utils (20240903-1) over (20240402-3) ...
                          Selecting previously unselected package raspi-utils-core.
                          Preparing to unpack .../58-raspi-utils-core_20240903-1_arm64.deb ...
                          Unpacking raspi-utils-core (20240903-1) ...
                          Selecting previously unselected package raspi-utils-otp.
                          Preparing to unpack .../59-raspi-utils-otp_20240903-1_all.deb ...
                          Unpacking raspi-utils-otp (20240903-1) ...
                          Selecting previously unselected package raspi-utils-dt.
                          Preparing to unpack .../60-raspi-utils-dt_20240903-1_arm64.deb ...
                          Unpacking raspi-utils-dt (20240903-1) ...
                          Selecting previously unselected package raspi-utils-eeprom.
                          Preparing to unpack .../61-raspi-utils-eeprom_20240903-1_arm64.deb ...
                          Unpacking raspi-utils-eeprom (20240903-1) ...
                          Selecting previously unselected package raspinfo.
                          Preparing to unpack .../62-raspinfo_20240903-1_all.deb ...
                          Unpacking raspinfo (20240903-1) ...
                          Preparing to unpack .../63-raspi-config_20241210_all.deb ...
                          Unpacking raspi-config (20241210) over (20240708) ...
                          Removing obsolete conffile /etc/init.d/raspi-config ...
                          Removing obsolete conffile /etc/default/cpu_governor ...
                          Preparing to unpack .../64-wf-panel-pi_0.91_arm64.deb ...
                          Unpacking wf-panel-pi (0.91) over (0.76) ...
                          Preparing to unpack .../65-raspberrypi-ui-mods_1.20241211_arm64.deb ...
                          Unpacking raspberrypi-ui-mods (1.20241211) over (1.20240808) ...
                          Preparing to unpack .../66-rpi-connect_2.1.0_arm64.deb ...
                          Unpacking rpi-connect (2.1.0) over (1.4.0) ...
                          Preparing to unpack .../67-rpi-imager_1.9.1_arm64.deb ...
                          Unpacking rpi-imager (1.9.1) over (1.8.5+rpt1) ...
                          Selecting previously unselected package upower.
                          Preparing to unpack .../68-upower_0.99.20-2_arm64.deb ...
                          Unpacking upower (0.99.20-2) ...
                          Selecting previously unselected package wfplug-connect.
                          Preparing to unpack .../69-wfplug-connect_0.10_arm64.deb ...
                          Unpacking wfplug-connect (0.10) ...
                          Selecting previously unselected package wfplug-squeek.
                          Preparing to unpack .../70-wfplug-squeek_0.5_arm64.deb ...
                          Unpacking wfplug-squeek (0.5) ...
                          Setting up python3-attr (22.2.0-1) ...
                          Setting up rasputin (0.2) ...
                          Setting up linux-image-6.6.62+rpt-rpi-v8 (1:6.6.62-1+rpt1) ...
                          /etc/kernel/postinst.d/initramfs-tools:
                          update-initramfs: Generating /boot/initrd.img-6.6.62+rpt-rpi-v8
                          '/boot/initrd.img-6.6.62+rpt-rpi-v8' -> '/boot/firmware/initramfs8'
                          /etc/kernel/postinst.d/z50-raspi-firmware:
                          '/boot/vmlinuz-6.6.62+rpt-rpi-v8' -> '/boot/firmware/kernel8.img'
                          Setting up raspi-utils-eeprom (20240903-1) ...
                          Setting up python3-libarchive-c (2.9-0.1) ...
                          Setting up raspi-utils-otp (20240903-1) ...
                          Setting up dconf-cli (0.40.0-4) ...
                          Setting up chromium-codecs-ffmpeg-extra (126.0.6478.164-rpt1) ...
                          Setting up libminizip1:arm64 (1.1-8+deb12u1) ...
                          Setting up libxcb-errors0:arm64 (1.0.1-2~bpo12+1+rpt1) ...
                          Setting up raspi-utils-dt (20240903-1) ...
                          Setting up python3-tqdm (4.64.1-1) ...
                          Setting up libconfig++9v5:arm64 (1.5-0.4) ...
                          Setting up raindrop (0.12) ...
                          Setting up libunwind-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Setting up linux-image-6.6.62+rpt-rpi-2712 (1:6.6.62-1+rpt1) ...
                          update-initramfs: Generating /boot/initrd.img-6.6.62+rpt-rpi-2712
                          '/boot/initrd.img-6.6.62+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712'
                          '/boot/vmlinuz-6.6.62+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img'
                          Setting up libfuse2:arm64 (2.9.9-6+b1) ...
                          Setting up chromium-sandbox (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up rpi-connect (2.1.0) ...
                          Replacing globally-enabled rpi-connect services with user-enabled ones...
                          Enabled rpi-connect for root
                          Enabled rpi-connect for pi
                          For Raspberry Pi OS Lite, enable user lingering for your user:
                              loginctl enable-linger
                          This allows users who are not logged in to run long-running services.
                          For information on getting started with Raspberry Pi Connect, please see the official documentation:
                              https://rptl.io/rpi-connect
                          Setting up notification-daemon (3.20.0-4+b1) ...
                          Setting up python3-uritemplate (4.1.1-2) ...
                          Setting up linux-image-rpi-2712 (1:6.6.62-1+rpt1) ...
                          Setting up python3-webcolors (1.11.1-1) ...
                          Setting up libxml++2.6-2v5:arm64 (2.40.1-3) ...
                          Setting up libspa-0.2-modules:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up libwlroots-0.18:arm64 (0.18.1-1+rpt6) ...
                          Setting up libpipewire-0.3-0:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up python3-rfc3987 (1.3.8-2) ...
                          Setting up libc++abi1-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Setting up labwc-prompt (0.3) ...
                          Setting up linux-image-rpi-v8 (1:6.6.62-1+rpt1) ...
                          Setting up xmlstarlet (1.6.1-3) ...
                          Setting up linux-headers-6.6.62+rpt-common-rpi (1:6.6.62-1+rpt1) ...
                          Setting up python3-pyrsistent:arm64 (0.18.1-1+b3) ...
                          Setting up python3-json-pointer (2.3-2) ...
                          Setting up libspa-0.2-bluetooth:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up fonts-liberation (1:1.07.4-11) ...
                          Setting up libupower-glib3:arm64 (0.99.20-2) ...
                          Setting up rpi-imager (1.9.1) ...
                          Setting up linux-kbuild-6.6.62+rpt (1:6.6.62-1+rpt1) ...
                          Setting up raspi-utils-core (20240903-1) ...
                          Setting up labwc (0.8.1-1+rpt1) ...
                          Setting up libffado2:arm64 (2.4.7-1) ...
                          Setting up libspa-0.2-libcamera:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up autotouch (0.1) ...
                          Setting up raspinfo (20240903-1) ...
                          Setting up linux-headers-6.6.62+rpt-rpi-v8 (1:6.6.62-1+rpt1) ...
                          Setting up linux-headers-6.6.62+rpt-rpi-2712 (1:6.6.62-1+rpt1) ...
                          Setting up upower (0.99.20-2) ...
                          upower.service is a disabled or a static unit, not starting it.
                          Setting up raspi-utils (20240903-1) ...
                          Setting up libpipewire-0.3-modules:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up libc++1-16:arm64 (1:16.0.6-15~deb12u1) ...
                          Setting up python3-jsonschema (4.10.3-1) ...
                          Setting up linux-headers-rpi-2712 (1:6.6.62-1+rpt1) ...
                          Setting up chromium-common (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up chromium (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up raspi-config (20241210) ...
                          Setting up pipewire-libcamera (1.2.4-1~bpo12+1+rpt1) ...
                          Setting up linux-headers-rpi-v8 (1:6.6.62-1+rpt1) ...
                          Setting up rpi-chromium-mods (20240904) ...
                          Setting up pipewire-bin (1.2.4-1~bpo12+1+rpt1) ...
                          Removing obsolete conffile /etc/security/limits.d/95-pipewire.conf ...
                          Setting up python3-picamera2 (0.3.23-1) ...
                          Setting up chromium-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up chromium-browser (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up wf-panel-pi (0.91) ...
                          Setting up chromium-browser-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
                          Setting up pipewire:arm64 (1.2.4-1~bpo12+1+rpt1) ...
                          Created symlink /etc/systemd/user/default.target.wants/filter-chain.service → /usr/lib/systemd/user/filter-chain.service.
                          Setting up wfplug-squeek (0.5) ...
                          Setting up wfplug-connect (0.10) ...
                          Setting up raspberrypi-ui-mods (1.20241211) ...
                          Installing new version of config file /etc/xdg/labwc/environment ...
                          Installing new version of config file /etc/xdg/labwc/rc.xml ...
                          Setting up pipewire-pulse (1.2.4-1~bpo12+1+rpt1) ...
                          Processing triggers for fontconfig (2.14.1-4) ...
                          Processing triggers for libglib2.0-0:arm64 (2.74.6-2+deb12u4) ...
                          Processing triggers for udev (252.31-1~deb12u1) ...
                          Broadcast message from root@VISundGrafana on pts/1 (Sun 2025-01-05 18:31:46 CET):
                          Jetzt sieht es glaube ich gut aus, bis auf die nicht mehr benötigten Pakete.... Wie werde ich sie wieder los?
                          pi@VISundGrafana:~ $ sudo apt-get upgrade
                            libqt5quickcontrols2-5 libqt5quicktemplates2-5 libwlroots12 linux-headers-6.6.31+rpt-common-rpi
                            linux-headers-6.6.31+rpt-rpi-2712 linux-headers-6.6.31+rpt-rpi-v8 linux-image-6.6.31+rpt-rpi-2712
                            linux-image-6.6.31+rpt-rpi-v8 linux-kbuild-6.6.31+rpt python3-gi-cairo qml-module-qtgraphicaleffects
                            qml-module-qtquick2
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          • K knopers1
                            sudo apt update
                            sudo reboot
                              qml-module-qtquick2
                              arandr lxinput
                              qml-module-qtquick2
                            • K knopers1
                              sudo apt update
                              sudo reboot
                                qml-module-qtquick2
                                arandr lxinput
                                qml-module-qtquick2
                              @knopers1
                              Kommt davon, wenn man den ganzen Desktop-Mumpitz mitschleppt und dann nicht regelmäßig updated.
                              sudo apt remove libjavascriptcoregtk
                              sudo apt update
                                @knopers1
                                sudo apt update
                                knopers1
                                @thomas-braun said in RPI5 apt-get upgrade schlägt Fehlermeldung:
                                Hallo Thomas, danke für deine Zeit!
                                pi@VISundGrafana:~ $ sudo apt remove libjavascriptcoregtk
                                E: Unable to locate package libjavascriptcoregtk
                                soll ich trotzdem weiter damit machen?
                                sudo apt update
                                • K knopers1
                                  sudo apt update
                                  @knopers1
                                  Ja, zeig mal was bei
                                  sudo apt update
                                  nun gemeldet wird.
                                    @knopers1
                                    sudo apt update
                                    nun gemeldet wird.
                                    knopers1
                                    @thomas-braun Danke für deine Zeit, siehe unten.....
                                    login as: pi
                                    pi@192.168.1.100's password:
                                    Linux VISundGrafana 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64
                                    permitted by applicable law.
                                    Last login: Sun Jan  5 19:27:09 2025 from 192.168.1.174
                                    pi@VISundGrafana:~ $ sudo apt update
                                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                    Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Get:5 http://archive.raspberrypi.com/debian bookworm InRelease [39.3 kB]
                                    Get:6 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [549 kB]
                                    Get:7 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [520 kB]
                                    Fetched 1,164 kB in 1s (1,495 kB/s)
                                    3 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                      edid-decode libqt5qmlworkerscript5 libqt5quickcontrols2-5
                                      qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2
                                      linux-image-6.6.31+rpt-rpi-2712 linux-image-6.6.31+rpt-rpi-v8
                                      initramfs-tools initramfs-tools-core realvnc-vnc-server
                                    3 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
                                    Need to get 9,493 kB of archives.
                                    After this operation, 71.6 MB disk space will be freed.
                                    Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools all 0.142+rpt3+deb12u1 [17.2 kB]
                                    Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools-core all 0.142+rpt3+deb12u1 [53.1 kB]
                                    Get:3 http://archive.raspberrypi.com/debian bookworm/main arm64 realvnc-vnc-server arm64 7.13.1.57 [9,422 kB]
                                    Fetched 9,493 kB in 1s (6,650 kB/s)
                                    (Reading database ... 179703 files and directories currently installed.)
                                    Removing linux-headers-6.6.31+rpt-rpi-2712 (1:6.6.31-1+rpt1) ...
                                    Removing linux-headers-6.6.31+rpt-rpi-v8 (1:6.6.31-1+rpt1) ...
                                    Removing linux-image-6.6.31+rpt-rpi-2712 (1:6.6.31-1+rpt1) ...
                                    /etc/kernel/postrm.d/initramfs-tools:
                                    update-initramfs: Deleting /boot/initrd.img-6.6.31+rpt-rpi-2712
                                    Removing linux-image-6.6.31+rpt-rpi-v8 (1:6.6.31-1+rpt1) ...
                                    update-initramfs: Deleting /boot/initrd.img-6.6.31+rpt-rpi-v8
                                    (Reading database ... 166892 files and directories currently installed.)
                                    Preparing to unpack .../initramfs-tools_0.142+rpt3+deb12u1_all.deb ...
                                    Unpacking initramfs-tools (0.142+rpt3+deb12u1) over (0.142+rpt2+deb12u1) ...
                                    Preparing to unpack .../initramfs-tools-core_0.142+rpt3+deb12u1_all.deb ...
                                    Unpacking initramfs-tools-core (0.142+rpt3+deb12u1) over (0.142+rpt2+deb12u1) ...
                                    Preparing to unpack .../realvnc-vnc-server_7.13.1.57_arm64.deb ...
                                    Unpacking realvnc-vnc-server (7.13.1.57) over (7.11.0.18) ...
                                    Setting up realvnc-vnc-server (7.13.1.57) ...
                                    Updating /etc/pam.d/vncserver
                                    Updating /etc/pam.conf... done
                                    Looking for font path... not found.
                                    Original config file "/etc/vnc/pulse/daemon.conf.old" preserved
                                    Generating private key... done
                                    Installed systemd unit for VNC Server in Service Mode daemon
                                    Start or stop the service with:
                                      systemctl (start|stop) vncserver-x11-serviced.service
                                    Mark or unmark the service to be started at boot time with:
                                      systemctl (enable|disable) vncserver-x11-serviced.service
                                    Installed systemd unit for VNC Server in Virtual Mode daemon
                                      systemctl (start|stop) vncserver-virtuald.service
                                      systemctl (enable|disable) vncserver-virtuald.service
                                    Setting up initramfs-tools-core (0.142+rpt3+deb12u1) ...
                                    Setting up initramfs-tools (0.142+rpt3+deb12u1) ...
                                    Processing triggers for initramfs-tools (0.142+rpt3+deb12u1) ...
                                    • K knopers1
                                      login as: pi
                                      @knopers1
                                      Sauberen Neustart und dann nochmal.
                                        @knopers1
                                        knopers1
                                        pi@VISundGrafana:~ $ sudo apt-get update
                                        Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                                        • K knopers1
                                          immer noch!
