  3. Off Topic
  4. InfluxDB
  5. InfluxDB Restore über Backitup nicht möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
56 Beiträge 6 Kommentatoren 6.4k Aufrufe 4 Beobachtet
  • K Kilian 0
    @thomas-braun Scheint als hättest du recht aber kapieren tue ich es nicht.
    smartmeter@raspberrypi:~ $ ls -la /usr/bin/influx
    influx version
    influxd version
    ls: cannot access '/usr/bin/influx': No such file or directory
    -bash: influx: command not found
    InfluxDB v2.7.8 (git: 18c989726c) build_date: 2024-07-25T19:55:35Z
    Und:
    smartmeter@raspberrypi:~ $ sudo apt update
    apt policy influx*
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Get:6 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Err:6 https://repos.influxdata.com/debian bookworm InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Reading package lists... Done
    W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    N: Unable to locate package influxdata-archive_compat.key
    N: Unable to locate package influxdb2_2.7.8-1_arm64.deb
    @kilian-0
    Dann hast du das auch nicht über den Paketmanager installiert und stattdessen irgendwas irgendwie in das System geknüppelt. Denn weder die Datei influxdata-archive_compat.key noch influxdb2_2.7.8-1_arm64.deb haben an der Stelle was zu suchen...
    rm influx*
    sudo rm /etc/apt/sources.list.d/influ*
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    Dann sauber installieren
    sudo apt update
    sudo apt install influxdb2 influxdb2-cli
      Kilian 0
      schrieb am zuletzt editiert von Kilian 0
      Ja tatsächlich. Ich habe die Paketbefehle nicht gefunden. Vielen Danke ich werde berichten.
      Update: Vielen Dank deine Hilfe hat das Problem behoben. Habe meine alten Werte wieder in der DB.
      • K Kilian 0
        @kilian-0
        Lesson learned:
        Für Softwareinstallationen immer den Paketmanager verwenden.
        • O Offline
          O Offline
          opöl
          schrieb am zuletzt editiert von opöl
          beim Versuch, meine Influx 1 DB von meinem Raspberry auf einen Futro zu übertragen komme ich auch nicht so richtig voran und bin auf diesen Beitrag gestoßen. Da ich einen ähnlichen Fehler bei mir vermutet habe, bin ich der Anleitung von @Thomas-Braun in diesem Beitrag gefolgt, bekomme aber bei der Neuinstallation die folgende Meldung.
          /usr/bin/influx und
          /var/cache/apt/archives/influxdb_1.8.10-1_amd64.deb
          wurden bereits gelöscht.
          @futro:/usr/bin$ sudo apt-get update && sudo apt-get install influxdb
          OK:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
          OK:2 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
          OK:3 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
          OK:4 http://security.ubuntu.com/ubuntu noble-security InRelease
          OK:5 https://apt.grafana.com stable InRelease
          OK:6 https://repos.influxdata.com/debian stable InRelease
          OK:7 https://deb.nodesource.com/node_20.x nodistro InRelease
          Fehl:6 https://repos.influxdata.com/debian stable InRelease
            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
          Die folgenden NEUEN Pakete werden installiert:
            influxdb
          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
          Es müssen noch 0 B von 54,4 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 153 MB Plattenplatz zusätzlich benutzt.
          (Lese Datenbank ... 146163 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../influxdb_1.8.10-1_amd64.deb ...
          Entpacken von influxdb (1.8.10-1) ...
          dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/influxdb_1.8.10-1_amd64.deb (--unpack):
           Versuch, »/usr/bin/influx« zu überschreiben, welches auch in Paket influxdb-client 1.6.7~rc0-2ubuntu0.24.04.1 ist
          dpkg-deb: Fehler: »einfügen«-Unterprozess wurde durch Signal (Broken pipe) getötet
          Failed to disable unit: Unit file influxdb.service does not exist.
          Fehler traten auf beim Bearbeiten von:
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          Hat jemand eine Idee dazu?
          Danke und Gruß
          • O opöl
            /usr/bin/influx und
              influxdb
            Danke und Gruß
            @opöl sagte in InfluxDB Restore über Backitup nicht möglich:
            influxdb-client
            sudo apt remove influxdb-client
            Zuvor aber das influx-Repo neuanlegen:
            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
            • O Offline
              O Offline
              opöl
              @Thomas-Braun ,
              bis dahin kein Fehler, aber dann:
              @futro:/usr/share/keyrings$ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
              sha256sum: influxdata-archive_compat.key: No such file or directory
              influxdata-archive_compat.key: FAILED open or read
              sha256sum: WARNING: 1 listed file could not be read
              Der Inhalt des Ordners:
              l@futro:/usr/share/keyrings$ ls
              influxdata-archive_compat.gpg       ubuntu-pro-cis.gpg
              ubuntu-archive-keyring.gpg          ubuntu-pro-esm-apps.gpg
              ubuntu-archive-removed-keys.gpg     ubuntu-pro-esm-infra.gpg
              ubuntu-cloudimage-keyring.gpg       ubuntu-pro-fips.gpg
              ubuntu-cloudimage-removed-keys.gpg  ubuntu-pro-fips-preview.gpg
              ubuntu-master-keyring.gpg           ubuntu-pro-realtime-kernel.gpg
              ubuntu-pro-anbox-cloud.gpg          ubuntu-pro-ros.gpg
              ubuntu-pro-cc-eal.gpg
              • O opöl
                @Thomas-Braun ,
                @opöl
                Stell dich in dein Home.
                O N 2 Antworten Letzte Antwort
                  @opöl
                  O Offline
                  O Offline
                  opöl
                  @thomas-braun ,
                  danke. Das war es.
                  Meine Schritte, um die influx 1.8 DB auf ein neues System zu übertragen habe ich hier dokumentiert:
                  https://forum.iobroker.net/topic/77362/keine-grafana-dashboards-nach-systemwechsel?_=1729892070152
                    @opöl
                    N Offline
                    N Offline
                    nobbiman
                    @thomas-braun Ich habe Probleme meine Influxdb-Konfiguration und -Datenbanken (3 Instanzen) mittels Backitup auf einen neuen RasPi zu übertragen.
                    Wie bin ich vorgegangen:
                    • Stopp der Influxdb-Instanzen auf meinem Alt-RasPi
                    • Ausführen von Backitup auf Alt-RasPi
                    • Kopieren der Sicherungsdatei in den Pfad /opt/iobroker/backups des Neu-RasPi
                    • Installation des Adapters Influxdb auf dem Neu-RasPi mit 3 Instanzen
                    • Restore auf dem Neu-RasPi
                    Nach komplettem Restoredurchlauf verweist die Instanz des Neu-RasPi auf die IP-Adresse des Alt-RasPi!
                    Wie bekomme ich es hin, dass die Instanzen des Neu-RasPi auf die übertragenen Daten des Neu-RasPi zugreift?
                    • N nobbiman
                      @nobbiman
                      iob host this
                      mal versuchen.
                      N 1 Antwort Letzte Antwort
                        @nobbiman
                        iob host this
                        mal versuchen.
                        N Offline
                        N Offline
                        nobbiman
                        pi@raspberrypi:~ $ iobroker stop
                        pi@raspberrypi:~ $ iob host this
                        A host with the name "raspberrypi" already exists!
                        pi@raspberrypi:~ $
                        Heißt das ich muss meinen Neu-RasPi umbenennen?
                        • N nobbiman
                          pi@raspberrypi:~ $
                          @nobbiman
                          Joh...
                          Es darf in einem Netzwerk nicht zwei gleiche hostnames geben. Wohhin soll denn der arme Router die Pakete senden?
                          Davon abgesehen ändert man den User wie auch den hostname während der Installation auf eigene Namen ab.
                          Also nicht pi@raspberrypi.
                            @nobbiman
                            Joh...
                            N Offline
                            N Offline
                            nobbiman
                            @thomas-braun Wenn ich den Hostnamen ändere, muss ich dann den RasPi komplett neu aufsetzen oder reicht diese Änderung und Neuinstallation des ioBroker und danach das Restore?
                            • N nobbiman
                              @nobbiman
                              Den hostname am besten in
                              raspi-config
                              ändern.
                                @nobbiman
                                raspi-config
                                ändern.
                                N Offline
                                N Offline
                                nobbiman
                                @thomas-braun ... und jetzt ein neues Restore ?
                                • N nobbiman
                                  @nobbiman
                                  Nein. Jetzt den neuen hostname im iobroker bekannt machen.
                                  iob host this
                                    @nobbiman
                                    iob host this
                                    N Offline
                                    N Offline
                                    nobbiman
                                    pi@ioBraspi:~ $ iobroker stop
                                    pi@ioBraspi:~ $ iob host this
                                    A host with the name "ioBraspi" already exists!
                                    Das verstehe ich nicht, der Alt-RasPi trägt den Hostnamen 'RasPi-ioBroker'
                                    • N nobbiman
                                      @nobbiman sagte in InfluxDB Restore über Backitup nicht möglich:
                                      und der neue?
                                        und der neue?
                                        N Offline
                                        N Offline
                                        nobbiman
                                        @homoran s.o. 'ioBraspi'
                                        • N nobbiman
                                          dann ist doch alles gut!
                                          Dann hat iob nach dem Reboot nach der Namensänderung das bereits selbst gefixt
                                          zeig mal im Expertenmodus die system.hosts in den Objekten
