  4. [gelöst]ioBroker sehr langsam
27 Beiträge 6 Kommentatoren 3.8k Aufrufe 4 Beobachtet
  • H Holzwurm1976
    @thomas-braun ```
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     18:36:35 up 1 min,  4 users,  load average: 3.46, 1.04, 0.36
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2024-12-31 18:36:35 CET
               Universal time: Tue 2024-12-31 17:36:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi        -user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix        '
    *** MEMORY ***
    Mem:            4.0G        1.0G        2.2G         23M        828M        2.9G
    Swap:           536M          0B        536M
    Total:          4.5G        1.0G        2.7G
    Active iob-Instances:   25
             3791 M total memory
              989 M used memory
             1143 M active memory
              405 M inactive memory
             2107 M free memory
               49 M buffer memory
              741 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 18:36:36 up 1 min,  4 users,  load average: 3.46, 1.04, 0.36
    Tasks: 245 total,   2 running, 243 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 28.6 us, 14.3 sy,  0.0 ni, 57.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3792.0 total,   2107.0 free,    989.5 used,    790.5 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2802.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  378M   1% /run
    /dev/mmcblk0p2 ext4       58G  9.7G   46G  18% /
    tmpfs          tmpfs     1.9G  216K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
    tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
    [Tue Dec 31 18:35:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:51:36:68 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=5a905def-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Tue Dec 31 18:35:37 2024] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be        -4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
    [Tue Dec 31 18:35:39 2024] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7        a6-0481bca99d89 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id        =1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=002        2,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    201M    /var/log
    200M    /var/log/journal/8e3d143e94b24b14ab4c426d226d810e
    195M    /var/lib
    Archived and active journals take up 199.9M in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.m        ap
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive        , uptime: 70)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
      system.adapter.cameras.0                : cameras               : raspberrypi        -  enabled, port: 8200, bind: 192.168.178.195
    + system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi        -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi        -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : raspberrypi        -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi        - disabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi        -  enabled
      system.adapter.history.0                : history               : raspberrypi        -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi        -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi        -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi        -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi        -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi        -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi        - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
    + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi        -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
    + system.adapter.km200.0                  : km200                 : raspberrypi        -  enabled
      system.adapter.mihome.0                 : mihome                : raspberrypi        - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.mobile.0                 : mobile                : raspberrypi        - disabled
      system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : raspberrypi        -  enabled
      system.adapter.proxy.0                  : proxy                 : raspberrypi        -  enabled
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi        - disabled
    + system.adapter.ring.0                   : ring                  : raspberrypi        -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi        -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.socketio.0               : socketio              : raspberrypi        -  enabled, port: 8084, bind: 0.0.0.0, run as: admi        n
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi        -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi        -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi        -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi        -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi        - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi        - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 192.168.178.195, run        as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi        -  enabled
      system.adapter.worx.0                   : worx                  : raspberrypi        - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                              │ auto u        pgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.4.10
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.7
    Adapter    "backitup"     : 3.0.25   , installed 3.0.31
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "ems-esp"      : 5.0.6    , installed 5.1.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.4.5
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "rpi2"         : 2.2.1    , installed 2.3.0
    Adapter    "shelly"       : 8.2.1    , installed 8.5.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.2.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 6.2.5    , installed 6.3.1
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "worx"         : 3.1.1    , installed 3.1.1
    Objects and States
    Objects:        23222
    States:         14753
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 43
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4890       669/cupsd
    tcp        0      0 192.168.178.195:8701    0.0.0.0:*               LISTEN      1001       16431      2676/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9399       670/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7167       670/iobroker.js-con
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       13109      2420/node-red
    tcp        0      0 192.168.178.195:8200    0.0.0.0:*               LISTEN      1001       16467      2723/io.cameras.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4837       686/sshd: /usr/sbin
    tcp        0      0 192.168.178.195:2010    0.0.0.0:*               LISTEN      1001       16430      2690/io.hm-rpc.2
    tcp        0      0 192.168.178.195:2001    0.0.0.0:*               LISTEN      1001       16397      2621/io.hm-rpc.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9844       1863/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4839       686/sshd: /usr/sbin
    tcp6       0      0 :::123                  :::*                    LISTEN      1001       13111      2420/node-red
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4889       669/cupsd
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13113      2420/node-red
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13112      2420/node-red
    udp        0      0 0.0.0.0:41741           0.0.0.0:*                           104        7417       473/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7415       473/avahi-daemon: r
    udp6       0      0 fe80::5258:561a:ac4:546 :::*                                0          8828       575/NetworkManager
    udp6       0      0 fe80::69c9:52c2:907:546 :::*                                0          5022       575/NetworkManager
    udp6       0      0 :::51835                :::*                                104        7418       473/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        7416       473/avahi-daemon: r
    2024-12-31 18:38:25.111  - info: host.raspberrypi instance system.adapter.iot.0 in version "3.4.5" started with pid 3849
    2024-12-31 18:38:25.342  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_1.Wetterbedingungen_value with Den ganzen Tag über Bewölkt
    2024-12-31 18:38:25.371  - info: host.raspberrypi instance system.adapter.web.0 in version "6.3.1" started with pid 3856
    2024-12-31 18:38:25.598  - info: host.raspberrypi instance system.adapter.ring.0 in version "6.3.0" started with pid 3863
    2024-12-31 18:38:25.794  - debug: tr-064.1 (3370) States connected to redis: 127.0.0.1:9000
    2024-12-31 18:38:25.797  - silly: tr-064.1 (3370) statesDB connected
    2024-12-31 18:38:26.438  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2 with null  {"type":"channel","common":{"name":"Day 2","role":"weather"}}
    2024-12-31 18:38:26.762  - debug: daswetter.0 (2754) number of datapoints 6
    2024-12-31 18:38:26.767  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Minimale_Temperatur_value with 4
    2024-12-31 18:38:27.016  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Maximale_Temperatur_value with 8
    2024-12-31 18:38:27.066  - debug: tr-064.1 (3370) Plugin sentry Initialize Plugin (enabled=true)
    2024-12-31 18:38:27.167  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wind_valueB with Sehr starker Wind aus Südwesten
    2024-12-31 18:38:27.283  - debug: dwd.0 (2786) Add warning "dwd.0.warning": 2024-12-31T17:00:00.000Z
    2024-12-31 18:38:27.328  - info: vis.0 (3371) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
    2024-12-31 18:38:27.366  - debug: dwd.0 (2786) Plugin sentry destroyed
    2024-12-31 18:38:27.370  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wind_value with Starker Wind aus Südwesten
    2024-12-31 18:38:27.368  - info: dwd.0 (2786) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-31 18:38:27.495  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wind_idB with 78
    2024-12-31 18:38:27.624  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wind_id with 22
    2024-12-31 18:38:27.734  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/78.png
    2024-12-31 18:38:27.765  - info: shelly.0 (2918) starting. Version 8.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.1, js-controller: 7.0.6
    2024-12-31 18:38:27.876  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wetter_Symbol_value2 with Bedeckt mit stürmischen Regenschauern
    2024-12-31 18:38:27.952  - info: sonos.0 (3352) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.18.1, js-controller: 7.0.6
    2024-12-31 18:38:28.113  - silly: shelly.0 (2918) States system redis pmessage system.adapter.shelly.0.logLevel/system.adapter.shelly.0.logLevel:{"val":"silly","ack":true,"ts":1735666707967,"q":0,"from":"system.adapter.shelly.0","lc":1735643836908}
    2024-12-31 18:38:29.061  - debug: daswetter.0 (2754) insert NextDays.Location_1.Day_2.Wetter_Symbol_value with Bedeckt mit mäßigem Regen
    iob diag has finished.
    @holzwurm1976
    Updaten, neustarten, dann iob diag nochmal.
    Und stell diesmal zuvor dein puTTY in den Vollbildmodus.
    Oder verwende gleich ein gescheites Terminal.
    H 1 Antwort Letzte Antwort
      @holzwurm1976
      Holzwurm1976
      Es sind keine Updates offen, alles sollte aktuell sein…???
      CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
      • H Holzwurm1976
        CodierknechtC Offline
        Codierknecht
        @holzwurm1976 sagte in ioBroker sehr langsam:
        Pending Updates: 43
        Das sagt aber etwas völlig anderes!
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • H Holzwurm1976
          @holzwurm1976
          Pending Updates: 43
          Um dein Betriebssystem musst du dich natürlich auch kümmern...
          sudo apt update
          iob stop
          sudo apt full-upgrade
          sudo reboot
            @holzwurm1976
            Pending Updates: 43
            sudo apt update
            iob stop
            sudo reboot
            Holzwurm1976
            wie stelle ich denn auf multi-user.target um?
            Ich hatte immer im Reiter "info" vom ioBroker geschaut, dort stand alle Adapter sind auf dem aktuellen Stand???
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
                   Icon name: computer
                      Kernel: Linux 6.6.62+rpt-rpi-v8
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             12:19:25 up 7 min,  4 users,  load average: 14.39, 7.87, 3.46
            CPU threads: 4
            Current issues:
                           Local time: Wed 2025-01-01 12:19:26 CET
                       Universal time: Wed 2025-01-01 11:19:26 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Display-Server: true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            4.0G        3.7G        137M         19M        234M        273M
            Swap:           536M        108M        428M
            Total:          4.5G        3.8G        565M
            Active iob-Instances:   29
                     3791 M total memory
                     3531 M used memory
                     1709 M active memory
                     1769 M inactive memory
                      130 M free memory
                       17 M buffer memory
                      205 M swap cache
                      511 M total swap
                      103 M used swap
                      408 M free swap
            top - 12:19:27 up 7 min,  4 users,  load average: 14.39, 7.87, 3.46
            Tasks: 261 total,   2 running, 259 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 80.0 us, 13.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  6.7 si,  0.0 st
            MiB Mem :   3791.9 total,    128.9 free,   3532.8 used,    224.3 buff/cache
            MiB Swap:    512.0 total,    408.2 free,    103.8 used.    259.1 avail Mem
            *** FILESYSTEM ***
            /dev/mmcblk0p2 ext4       58G  9.9G   46G  18% /
            tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
            /dev/mmcblk0p1 vfat      510M   67M  444M  14% /boot/firmware
            [Wed Jan  1 12:12:22 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave sn        d_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=        0  smsc95xx.macaddr=DC:A6:32:51:36:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size        =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5a905def-02 rootfst        ype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles c        fg80211.ieee80211_regdom=DE
            [Wed Jan  1 12:12:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be        -4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
            [Wed Jan  1 12:12:25 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7        a6-0481bca99d89 r/w. Quota mode: none.
            /var:
            1.1G    /var/
            233M    /var/log
            232M    /var/log/journal/8e3d143e94b24b14ab4c426d226d810e
            198M    /var/lib
            Archived and active journals take up 231.9M in the file system.
            26M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                    throw e;
            Error: Connection is closed.
                at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                at Object.onceWrapper (node:events:633:26)
                at Socket.emit (node:events:518:28)
                at TCP.<anonymous> (node:net:343:12)
            Emitted 'error' event on ScanStream instance at:
                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            Node.js v20.18.1
            admin:          7.4.10
            javascript:     8.8.3
            Adapter State
            + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, port: 8200, bind: 192.168.178.195
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
            + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
            + instance is alive
            │ (index) │ name     │ url                                              │ auto upgrade │
            Objects and States
            Objects:        23222
            States:         14724
            Pending Updates: 0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5094       662/sshd: /usr/sbin
            tcp        0      0 192.168.178.195:8701    0.0.0.0:*               LISTEN      1001       13325      2074/io.hm-rpc.1
            tcp        0      0 192.168.178.195:8200    0.0.0.0:*               LISTEN      1001       12162      2365/io.cameras.0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9233       648/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9289       648/iobroker.js-con
            tcp        0      0 192.168.178.195:8082    0.0.0.0:*               LISTEN      1001       12150      2350/io.web.0
            tcp        0      0 192.168.178.195:2010    0.0.0.0:*               LISTEN      1001       13332      2103/io.hm-rpc.2
            tcp        0      0 192.168.178.195:2001    0.0.0.0:*               LISTEN      1001       9155       2059/io.hm-rpc.0
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6551       647/cupsd
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       9042       1916/node-red
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11990      2221/io.sonoff.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11993      2178/io.shelly.0
            tcp6       0      0 :::123                  :::*                    LISTEN      1001       9044       1916/node-red
            tcp6       0      0 :::22                   :::*                    LISTEN      0          5096       662/sshd: /usr/sbin
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6550       647/cupsd
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       12683      2275/io.sonos.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8879       1288/io.admin.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       14806      2460/io.socketio.0
            udp        0      0 0.0.0.0:34418           0.0.0.0:*                           1001       22854      2320/io.ring.0
            udp        0      0 0.0.0.0:44667           0.0.0.0:*                           1001       21640      2320/io.ring.0
            udp        0      0 0.0.0.0:34429           0.0.0.0:*                           1001       16993      2320/io.ring.0
            udp        0      0 0.0.0.0:48826           0.0.0.0:*                           1001       19239      2320/io.ring.0
            udp        0      0 0.0.0.0:50907           0.0.0.0:*                           1001       22860      2320/io.ring.0
            udp        0      0 0.0.0.0:36595           0.0.0.0:*                           1001       21647      2320/io.ring.0
            udp        0      0 0.0.0.0:48929           0.0.0.0:*                           1001       20247      2320/io.ring.0
            udp        0      0 0.0.0.0:53025           0.0.0.0:*                           1001       21646      2320/io.ring.0
            udp        0      0 0.0.0.0:46902           0.0.0.0:*                           1001       20255      2320/io.ring.0
            udp        0      0 0.0.0.0:46907           0.0.0.0:*                           1001       18015      2320/io.ring.0
            udp        0      0 0.0.0.0:44860           0.0.0.0:*                           1001       18014      2320/io.ring.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       9046       1916/node-red
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       9045       1916/node-red
            udp        0      0 0.0.0.0:49020           0.0.0.0:*                           1001       19238      2320/io.ring.0
            udp        0      0 0.0.0.0:55168           0.0.0.0:*                           1001       18963      2320/io.ring.0
            udp        0      0 0.0.0.0:40858           0.0.0.0:*                           1001       20225      2320/io.ring.0
            udp        0      0 0.0.0.0:59325           0.0.0.0:*                           1001       20246      2320/io.ring.0
            udp        0      0 0.0.0.0:51152           0.0.0.0:*                           1001       24024      2320/io.ring.0
            udp        0      0 0.0.0.0:47123           0.0.0.0:*                           1001       24049      2320/io.ring.0
            udp        0      0 0.0.0.0:49206           0.0.0.0:*                           1001       17060      2320/io.ring.0
            udp   428288      0 0.0.0.0:14391           0.0.0.0:*                           1001       18037      3731/ffmpeg
            udp        0      0 0.0.0.0:14392           0.0.0.0:*                           1001       18038      3731/ffmpeg
            udp   426496      0 0.0.0.0:14393           0.0.0.0:*                           1001       18035      3731/ffmpeg
            udp        0      0 0.0.0.0:14394           0.0.0.0:*                           1001       18036      3731/ffmpeg
            udp   427264      0 0.0.0.0:14411           0.0.0.0:*                           1001       19233      3858/ffmpeg
            udp        0      0 0.0.0.0:14412           0.0.0.0:*                           1001       19234      3858/ffmpeg
            udp   426496      0 0.0.0.0:14413           0.0.0.0:*                           1001       19231      3858/ffmpeg
            udp        0      0 0.0.0.0:14414           0.0.0.0:*                           1001       19232      3858/ffmpeg
            udp   427904      0 0.0.0.0:14415           0.0.0.0:*                           1001       16163      3924/ffmpeg
            udp        0      0 0.0.0.0:14416           0.0.0.0:*                           1001       16164      3924/ffmpeg
            udp   426496      0 0.0.0.0:14417           0.0.0.0:*                           1001       16161      3924/ffmpeg
            udp        0      0 0.0.0.0:14418           0.0.0.0:*                           1001       16162      3924/ffmpeg
            udp        0      0 0.0.0.0:43109           0.0.0.0:*                           1001       20254      2320/io.ring.0
            udp        0      0 0.0.0.0:14451           0.0.0.0:*                           1001       21679      4370/ffmpeg
            udp        0      0 0.0.0.0:14452           0.0.0.0:*                           1001       21680      4370/ffmpeg
            udp        0      0 0.0.0.0:14453           0.0.0.0:*                           1001       21677      4370/ffmpeg
            udp        0      0 0.0.0.0:14454           0.0.0.0:*                           1001       21678      4370/ffmpeg
            udp        0      0 0.0.0.0:14475           0.0.0.0:*                           1001       24692      5206/ffmpeg
            udp        0      0 0.0.0.0:14476           0.0.0.0:*                           1001       24693      5206/ffmpeg
            udp        0      0 0.0.0.0:14477           0.0.0.0:*                           1001       24690      5206/ffmpeg
            udp        0      0 0.0.0.0:14478           0.0.0.0:*                           1001       24691      5206/ffmpeg
            udp        0      0 0.0.0.0:14479           0.0.0.0:*                           1001       24839      5363/ffmpeg
            udp        0      0 0.0.0.0:14480           0.0.0.0:*                           1001       24840      5363/ffmpeg
            udp        0      0 0.0.0.0:14481           0.0.0.0:*                           1001       24837      5363/ffmpeg
            udp        0      0 0.0.0.0:14482           0.0.0.0:*                           1001       24838      5363/ffmpeg
            udp        0      0 0.0.0.0:14483           0.0.0.0:*                           1001       25807      5364/ffmpeg
            udp        0      0 0.0.0.0:14484           0.0.0.0:*                           1001       25808      5364/ffmpeg
            udp        0      0 0.0.0.0:14485           0.0.0.0:*                           1001       25805      5364/ffmpeg
            udp        0      0 0.0.0.0:14486           0.0.0.0:*                           1001       25806      5364/ffmpeg
            udp        0      0 0.0.0.0:45239           0.0.0.0:*                           1001       18020      2320/io.ring.0
            udp        0      0 0.0.0.0:47374           0.0.0.0:*                           1001       18961      2320/io.ring.0
            udp        0      0 0.0.0.0:33093           0.0.0.0:*                           1001       20223      2320/io.ring.0
            udp        0      0 0.0.0.0:47432           0.0.0.0:*                           104        7187       462/avahi-daemon: r
            udp        0      0 0.0.0.0:45458           0.0.0.0:*                           1001       20928      2320/io.ring.0
            udp        0      0 0.0.0.0:49556           0.0.0.0:*                           1001       16110      2320/io.ring.0
            udp        0      0 0.0.0.0:43417           0.0.0.0:*                           1001       16994      2320/io.ring.0
            udp        0      0 0.0.0.0:49594           0.0.0.0:*                           1001       16111      2320/io.ring.0
            udp        0      0 0.0.0.0:55739           0.0.0.0:*                           1001       18962      2320/io.ring.0
            udp        0      0 0.0.0.0:43516           0.0.0.0:*                           1001       20253      2320/io.ring.0
            udp        0      0 0.0.0.0:51877           0.0.0.0:*                           1001       20248      2320/io.ring.0
            udp        0      0 0.0.0.0:33448           0.0.0.0:*                           1001       18021      2320/io.ring.0
            udp        0      0 0.0.0.0:51959           0.0.0.0:*                           1001       20224      2320/io.ring.0
            udp        0      0 0.0.0.0:48012           0.0.0.0:*                           1001       24824      2320/io.ring.0
            udp        0      0 0.0.0.0:48045           0.0.0.0:*                           1001       21641      2320/io.ring.0
            udp        0      0 0.0.0.0:35761           0.0.0.0:*                           1001       24019      2320/io.ring.0
            udp        0      0 0.0.0.0:44014           0.0.0.0:*                           1001       16109      2320/io.ring.0
            udp        0      0 0.0.0.0:46140           0.0.0.0:*                           1001       24008      2320/io.ring.0
            udp        0      0 0.0.0.0:52289           0.0.0.0:*                           1001       24002      2320/io.ring.0
            udp        0      0 0.0.0.0:35913           0.0.0.0:*                           1001       24823      2320/io.ring.0
            udp        0      0 0.0.0.0:50276           0.0.0.0:*                           1001       24825      2320/io.ring.0
            udp        0      0 0.0.0.0:44132           0.0.0.0:*                           1001       22861      2320/io.ring.0
            udp        0      0 0.0.0.0:38047           0.0.0.0:*                           1001       20927      2320/io.ring.0
            udp        0      0 0.0.0.0:58536           0.0.0.0:*                           1001       17061      2320/io.ring.0
            udp        0      0 0.0.0.0:36037           0.0.0.0:*                           1001       24050      2320/io.ring.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7185       462/avahi-daemon: r
            udp        0      0 0.0.0.0:50429           0.0.0.0:*                           1001       24025      2320/io.ring.0
            udp        0      0 0.0.0.0:60672           0.0.0.0:*                           1001       24018      2320/io.ring.0
            udp        0      0 0.0.0.0:34064           0.0.0.0:*                           1001       24051      2320/io.ring.0
            udp        0      0 0.0.0.0:48475           0.0.0.0:*                           1001       24007      2320/io.ring.0
            udp        0      0 0.0.0.0:38383           0.0.0.0:*                           1001       20929      2320/io.ring.0
            udp        0      0 0.0.0.0:46580           0.0.0.0:*                           1001       24001      2320/io.ring.0
            udp        0      0 0.0.0.0:54773           0.0.0.0:*                           1001       19240      2320/io.ring.0
            udp        0      0 0.0.0.0:58904           0.0.0.0:*                           1001       22855      2320/io.ring.0
            udp6       0      0 :::40512                :::*                                1001       24023      2320/io.ring.0
            udp6       0      0 :::46683                :::*                                1001       21651      2320/io.ring.0
            udp6       0      0 :::56929                :::*                                1001       22865      2320/io.ring.0
            udp6       0      0 :::42627                :::*                                1001       24006      2320/io.ring.0
            udp6       0      0 :::44690                :::*                                1001       21643      2320/io.ring.0
            udp6       0      0 :::34487                :::*                                1001       24005      2320/io.ring.0
            udp6       0      0 :::52994                :::*                                1001       18023      2320/io.ring.0
            udp6       0      0 :::53028                :::*                                1001       16996      2320/io.ring.0
            udp6   11008      0 :::46896                :::*                                1001       24003      2320/io.ring.0
            udp6       0      0 :::55116                :::*                                1001       17063      2320/io.ring.0
            udp6       0      0 :::42843                :::*                                1001       24022      2320/io.ring.0
            udp6   11008      0 :::40868                :::*                                1001       24026      2320/io.ring.0
            udp6       0      0 :::44975                :::*                                1001       18025      2320/io.ring.0
            udp6       0      0 :::57271                :::*                                1001       22863      2320/io.ring.0
            udp6       0      0 :::34793                :::*                                1001       18024      2320/io.ring.0
            udp6  214656      0 :::57387                :::*                                1001       22856      2320/io.ring.0
            udp6       0      0 :::41004                :::*                                1001       17065      2320/io.ring.0
            udp6       0      0 :::36950                :::*                                1001       16998      2320/io.ring.0
            udp6       0      0 :::34913                :::*                                1001       24012      2320/io.ring.0
            udp6       0      0 :::53376                :::*                                1001       24021      2320/io.ring.0
            udp6       0      0 :::43145                :::*                                1001       24027      2320/io.ring.0
            udp6       0      0 :::41122                :::*                                1001       22859      2320/io.ring.0
            udp6       0      0 :::43185                :::*                                1001       17064      2320/io.ring.0
            udp6  203648      0 :::47285                :::*                                1001       21642      2320/io.ring.0
            udp6       0      0 :::37062                :::*                                1001       24029      2320/io.ring.0
            udp6       0      0 :::39119                :::*                                1001       24028      2320/io.ring.0
            udp6  170624      0 :::51455                :::*                                1001       18022      2320/io.ring.0
            udp6       0      0 :::41391                :::*                                1001       22864      2320/io.ring.0
            udp6       0      0 :::57811                :::*                                1001       21645      2320/io.ring.0
            udp6       0      0 :::35317                :::*                                1001       24011      2320/io.ring.0
            udp6       0      0 fe80::5258:561a:ac4:546 :::*                                0          7530       581/NetworkManager
            udp6       0      0 fe80::69c9:52c2:907:546 :::*                                0          8403       581/NetworkManager
            udp6  170624      0 :::41584                :::*                                1001       17062      2320/io.ring.0
            udp6  170624      0 :::58032                :::*                                1001       22862      2320/io.ring.0
            udp6       0      0 :::56015                :::*                                1001       22857      2320/io.ring.0
            udp6       0      0 :::54052                :::*                                1001       21644      2320/io.ring.0
            udp6       0      0 :::33632                :::*                                1001       24004      2320/io.ring.0
            udp6  203648      0 :::58267                :::*                                1001       21648      2320/io.ring.0
            udp6       0      0 :::43997                :::*                                1001       16997      2320/io.ring.0
            udp6  167872      0 :::52221                :::*                                1001       24020      2320/io.ring.0
            udp6       0      0 :::58382                :::*                                1001       18019      2320/io.ring.0
            udp6       0      0 :::44063                :::*                                1001       18018      2320/io.ring.0
            udp6  181632      0 :::35888                :::*                                1001       18016      2320/io.ring.0
            udp6       0      0 :::48214                :::*                                1001       24010      2320/io.ring.0
            udp6   11008      0 :::60543                :::*                                1001       24009      2320/io.ring.0
            udp6       0      0 :::56452                :::*                                1001       21650      2320/io.ring.0
            udp6       0      0 :::33986                :::*                                1001       18017      2320/io.ring.0
            udp6       0      0 :::5353                 :::*                                104        7186       462/avahi-daemon: r
            udp6       0      0 :::42305                :::*                                1001       21649      2320/io.ring.0
            udp6       0      0 :::58756                :::*                                1001       22858      2320/io.ring.0
            udp6  181632      0 :::46483                :::*                                1001       16995      2320/io.ring.0
            udp6       0      0 :::60931                :::*                                104        7188       462/avahi-daemon: r
            2025-01-01 12:21:39.651  - warn: ring.0 (2320) Device 362750470 ("Haustür"): Couldn't create snapshot from image
            2025-01-01 12:21:40.969  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Livestream.request/ring.0.doorbell_362750470.Livestream.request:{"val":false,"ack":true,"ts":1735730499239,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654462833}
            2025-01-01 12:21:48.020  - debug: tr-064.1 (2305) in updateAll
            2025-01-01 12:21:48.022  - debug: tr-064.1 (2305) updateDevices
            2025-01-01 12:21:48.022  - debug: tr-064.1 (2305) forEachConfiguredDevice
            2025-01-01 12:21:48.406  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Livestream.request/ring.0.doorbell_362750470.Livestream.request:{"val":false,"ack":false,"ts":1735730506593,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654462833}
            2025-01-01 12:21:48.407  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Snapshot.request/ring.0.doorbell_362750470.Snapshot.request:{"val":false,"ack":false,"ts":1735730506598,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654153563}
            2025-01-01 12:21:48.408  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Snapshot.request/ring.0.doorbell_362750470.Snapshot.request:{"val":false,"ack":false,"ts":1735730506598,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654153563}
            2025-01-01 12:21:50.515  - debug: tr-064.1 (2305) forEachConfiguredDevice: i=0 fritz.box active=1
            2025-01-01 12:21:50.516  - debug: tr-064.1 (2305) forEachConfiguredDevice: {"NewIPAddress":"192.168.178.1","NewAddressSource":"Static","NewLeaseTimeRemaining":"0","NewInterfaceType":"","NewActive":"1","NewHostName":"fritz.box","NewMACAddress":"04:B4:FE:69:92:73"}
            2025-01-01 12:21:49.654  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Livestream.request changed: false (ack = false)
            2025-01-01 12:21:49.656  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Livestream request for 362750470 to value false
            2025-01-01 12:21:49.684  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Snapshot.request changed: false (ack = false)
            2025-01-01 12:21:49.685  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Snapshot request for 362750470 to value false
            2025-01-01 12:21:49.686  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Snapshot.request changed: false (ack = false)
            2025-01-01 12:21:49.687  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Snapshot request for 362750470 to value false
            2025-01-01 12:21:49.688  - silly: ring.0 (2320) Adapter File /opt/iobroker/iobroker-data/files/ring.0/doorbell_362750470/doorbell_362750470/livestream362750470_1735730435839.mp4 written!
            2025-01-01 12:21:49.689  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Update Livestream Object
            2025-01-01 12:21:49.691  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Done creating livestream to /opt/iobroker/iobroker-data/files/ring.0/doorbell_362750470/doorbell_362750470/livestream362750470_1735730435839.mp4
            2025-01-01 12:21:49.693  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save Snaspshot starts
            2025-01-01 12:21:49.694  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.takeSnapshot()
            2025-01-01 12:21:49.694  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save HD Snapshot starts
            2025-01-01 12:21:49.695  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.takeHDSnapshot()
            2025-01-01 12:21:51.302  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save Livestream starts
            2025-01-01 12:21:51.303  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.startLivestream()
            Thomas BraunT ? 3 Antworten Letzte Antwort
            • H Holzwurm1976
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
                       3791 M total memory
                       3531 M used memory
                        130 M free memory
                         17 M buffer memory
                        205 M swap cache
                        511 M total swap
                        103 M used swap
                        408 M free swap
              *** FILESYSTEM ***
              /var:
              1.1G    /var/
              233M    /var/log
              198M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
                      throw e;
              Node.js v20.18.1
              admin:          7.4.10
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        23222
              States:         14724
              Pending Updates: 0
              Geht mittlerweile über den
              iob fix
              Wir sprechen aber nicht von ioBroker-Adapter-Updates sondern von Updates des Betriebssystems. Die werden da nicht angezeigt.
              • H Holzwurm1976
                ```bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         3791 M total memory
                         3531 M used memory
                          130 M free memory
                           17 M buffer memory
                          205 M swap cache
                          511 M total swap
                          103 M used swap
                          408 M free swap
                *** FILESYSTEM ***
                /var:
                1.1G    /var/
                233M    /var/log
                198M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                        throw e;
                Node.js v20.18.1
                admin:          7.4.10
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        23222
                States:         14724
                Pending Updates: 0
                Deutlich zu hoch.
                Schau dir per
                top
                oder
                htop
                an was da so schwer im System liegt.
                • H Holzwurm1976
                  ```bash
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                           3791 M total memory
                           3531 M used memory
                            130 M free memory
                             17 M buffer memory
                            205 M swap cache
                            511 M total swap
                            103 M used swap
                            408 M free swap
                  *** FILESYSTEM ***
                  /var:
                  1.1G    /var/
                  233M    /var/log
                  198M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                          throw e;
                  Node.js v20.18.1
                  admin:          7.4.10
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        23222
                  States:         14724
                  Pending Updates: 0
                  @holzwurm1976
                  Wenn ein System nicht mehr rund läuft, liegt es oft an den letzten Änderungen, die man getätigt hat.
                  Schau Dir bitte mal die Auslastung an:
                  CPU threads: 4
                  Und dann seitenweise zigfach gestartete Prozesse:
                  Dein System geht unter und die stellst bei den Adaptern tr-064, daswetter und ring noch wahnwitzige Loggingeinstellungen ein - debug zum Teil silly.
                  Seit mehreren Tagen wurstelst Du an Deinem System - installierst neu - dann aber
                  alle Adapter aus dem Beta-Repo, stellst dann aber schön auf "stable". Wieso macht man sowas?
                    @holzwurm1976
                    CPU threads: 4
                    Holzwurm1976
                    @rscsb
                    Das kann ich Dir nicht sagen!
                    Ich habe davon keine tiefgründige Ahnung!
                    Kannst Du mir sagen, welche Einstellungen ich wo machen sollte?
                    Updates habe ich (meiner Meinung nach) jetzt alle gemacht…
                    • H Holzwurm1976
                      @rscsb
                      @holzwurm1976
                      Stell die Adapter schon mal auf debug-level 'info'.
                      Also den tr-064.1 und ring.0 mindestens.
                      Wieviele Kameras hast du da am Start? Scheint mir zu viel zu sein.
                        Deutlich zu hoch.
                        Schau dir per
                        top
                        oder
                        htop
                        Holzwurm1976
                        sorry, aber wie kann ich diese Daten deuten?
                        • H Holzwurm1976
                          Was meinst du? Die beiden genannten Instanzen kippen alles mögliche in dein LogFile und bremsen so das System aus.
                            @holzwurm1976
                            Holzwurm1976
                            den debug-level habe ich umgestellt, scheint schon etwas besser zu laufen, hängt sich aber noch immer um.
                            Den Camera Adapter habe ich komplett deaktiviert, habe aber auch nur 2 Cameras...
                              Holzwurm1976
                              ja, aber wie sehe ich welche die sind, die am meisten blockieren?
                              • H Holzwurm1976
                                @holzwurm1976
                                Dann zeig jetzt nochmal ein kompletten Lauf von
                                iob diag
                                sowie
                                top
                                H 2 Antworten Letzte Antwort
                                  @holzwurm1976
                                  iob diag
                                  sowie
                                  top
                                  Holzwurm1976
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   13:56:08 up 2 min,  3 users,  load average: 5.38, 2.01, 0.74
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Wed 2025-01-01 13:56:08 CET
                                             Universal time: Wed 2025-01-01 12:56:08 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.0G        1.8G        1.6G        1.4M        561M        2.1G
                                  Swap:           536M          0B        536M
                                  Total:          4.5G        1.8G        2.2G
                                  Active iob-Instances:   16
                                           3791 M total memory
                                           1758 M used memory
                                           1865 M active memory
                                            228 M inactive memory
                                           1572 M free memory
                                             47 M buffer memory
                                            487 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  top - 13:56:09 up 2 min,  3 users,  load average: 5.38, 2.01, 0.74
                                  Tasks: 244 total,   9 running, 235 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s): 77.8 us, 22.2 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3791.9 total,   1570.3 free,   1760.8 used,    535.9 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2031.1 avail Mem
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     380M  1.2M  378M   1% /run
                                  tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                                  tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
                                  [Wed Jan  1 13:53:39 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:51:36:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5a905def-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                  [Wed Jan  1 13:53:42 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
                                  [Wed Jan  1 13:53:43 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
                                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  1.2G    /var/
                                  321M    /var/log
                                  320M    /var/log/journal/8e3d143e94b24b14ab4c426d226d810e
                                  198M    /var/lib
                                  Archived and active journals take up 319.9M in the file system.
                                  45M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 160)
                                  admin:          7.4.10
                                  javascript:     8.8.3
                                  Adapter State
                                  + system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                  + instance is alive
                                  Objects and States
                                  Objects:        23199
                                  States:         14710
                                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                  Pending Updates: 0
                                  tcp        0      0 192.168.178.195:8701    0.0.0.0:*               LISTEN      1001       10262      1381/io.hm-rpc.1
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6299       655/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6327       642/cupsd
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4017       643/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9221       643/iobroker.js-con
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       6935       1212/node-red
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11983      1674/io.sonoff.0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13461      1681/io.shelly.0
                                  tcp        0      0 192.168.178.195:2001    0.0.0.0:*               LISTEN      1001       7956       1355/io.hm-rpc.0
                                  tcp        0      0 192.168.178.195:2010    0.0.0.0:*               LISTEN      1001       11908      1448/io.hm-rpc.2
                                  tcp        0      0 192.168.178.195:8082    0.0.0.0:*               LISTEN      1001       12085      2027/io.web.0
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6326       642/cupsd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          6301       655/sshd: /usr/sbin
                                  tcp6       0      0 :::123                  :::*                    LISTEN      1001       6937       1212/node-red
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       14448      2230/io.socketio.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9300       901/io.admin.0
                                  tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11088      1695/io.sonos.0
                                  udp        0      0 0.0.0.0:46211           0.0.0.0:*                           104        5014       471/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5012       471/avahi-daemon: r
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6939       1212/node-red
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6938       1212/node-red
                                  udp6       0      0 :::5353                 :::*                                104        5013       471/avahi-daemon: r
                                  udp6       0      0 :::46396                :::*                                104        5015       471/avahi-daemon: r
                                  udp6       0      0 fe80::5258:561a:ac4:546 :::*                                0          6629       585/NetworkManager
                                  udp6       0      0 fe80::69c9:52c2:907:546 :::*                                0          6375       585/NetworkManager
                                  2025-01-01 13:57:19.870  - debug: info.0 (2129) Process wifi with networks.net0: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"44:4e:6d:24:35:0a","mode":"Infra","channel":1,"frequency":2412,"signalLevel":-50,"quality":100,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                                  2025-01-01 13:57:19.991  - debug: info.0 (2129) Process wifi with networks.net1: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"04:b4:fe:69:92:75","mode":"Infra","channel":11,"frequency":2462,"signalLevel":-58,"quality":84,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                                  2025-01-01 13:57:20.428  - debug: info.0 (2129) Process wifi with networks.net2: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"04:b4:fe:69:92:76","mode":"Infra","channel":100,"frequency":5500,"signalLevel":-66.5,"quality":67,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                                  2025-01-01 13:57:20.541  - debug: info.0 (2129) Process wifi with networks.net3: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"44:4e:6d:24:35:09","mode":"Infra","channel":52,"frequency":5260,"signalLevel":-67,"quality":66,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                                  2025-01-01 13:57:20.679  - debug: info.0 (2129) Process wifi with networks.net4: {"ssid":"FRITZ!Box 6660 Repeater","bssid":"08:96:d7:ec:9f:68","mode":"Infra","channel":1,"frequency":2412,"signalLevel":-67.5,"quality":65,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                                  2025-01-01 13:57:21.110  - info: hm-rega.0 (1302) added/updated 53 variables
                                  2025-01-01 13:57:21.112  - debug: info.0 (2129) Process docker with info: {}
                                  2025-01-01 13:57:21.111  - info: hm-rega.0 (1302) deleted 0 variables
                                  2025-01-01 13:57:21.220  - info: hm-rega.0 (1302) got 57 programs
                                  2025-01-01 13:57:25.644  - info: hm-rega.0 (1302) added/updated 57 programs
                                  2025-01-01 13:57:25.644  - info: hm-rega.0 (1302) deleted 0 programs
                                  2025-01-01 13:57:26.123  - info: hm-rega.0 (1302) update rooms to enum.rooms
                                  2025-01-01 13:57:26.250  - info: hm-rega.0 (1302) update functions to enum.functions
                                  2025-01-01 13:57:26.274  - info: hm-rega.0 (1302) hm-rpc.0.BidCoS-RF.5 has been added to functions Neues Gewerk-2
                                  2025-01-01 13:57:26.291  - silly: info.0 (2129) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":["hm-rpc.0.BidCoS-RF.5"],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2025-01-01 13:57:26.293  - silly: socketio.0 (2230) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":["hm-rpc.0.BidCoS-RF.5"],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2025-01-01 13:57:26.302  - info: hm-rega.0 (1302) hm-rpc.0.BidCoS-RF.5 has been removed from functions Neues Gewerk-2
                                  2025-01-01 13:57:26.328  - silly: info.0 (2129) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":[],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2025-01-01 13:57:26.330  - silly: socketio.0 (2230) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":[],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2025-01-01 13:57:26.504  - info: hm-rega.0 (1302) update favorites to enum.favorites
                                  2025-01-01 13:57:29.147  - info: admin.0 (901) ==> Connected system.user.admin from ::ffff:192.168.178.36
                                  2025-01-01 13:57:30.517  - info: ems-esp.0 (1218) end of initializing KM200 states
                                  2025-01-01 13:57:30.519  - info: ems-esp.0 (1218) KM200: polling every 300 secs
                                  2025-01-01 13:57:31.961  - info: cloud.0 (1147) Trying to connect as system.user.admin to cloud
                                  2025-01-01 13:57:32.105  - info: cloud.0 (1147) Connection changed: connect
                                    @holzwurm1976
                                    iob diag
                                    sowie
                                    top
                                    Holzwurm1976
                                    • H Holzwurm1976
                                      Script v.2024-10-19
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      HOME=/home/pi
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           536M          0B        536M
                                               3791 M total memory
                                               1758 M used memory
                                               1572 M free memory
                                                 47 M buffer memory
                                                487 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.2G    /var/
                                      321M    /var/log
                                      198M    /var/lib
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.4.10
                                      javascript:     8.8.3
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        23199
                                      States:         14710
                                      Pending Updates: 0
                                      info.0
                                      Der info-Adaper sollte deinstalliert werden. Der funktioniert schon geraume Zeit nicht mehr richtig.
                                      Davon abgesehen läuft der auch auf debug-Loglevel. Weg damit!
                                      • H Offline
                                        Holzwurm1976
                                        OK, ist erledigt...
                                          info.0
                                          Holzwurm1976
                                          ich glaube das "schlimmste" macht der Ring Adapter.
                                          Ich habe den deaktiviert, jetzt läuft es wieder recht stabil...
                                          -1
