  4. [gelöst]ioBroker sehr langsam
27 Beiträge 6 Kommentatoren 3.8k Aufrufe 4 Beobachtet
  • H Holzwurm1976
    wie stelle ich denn auf multi-user.target um?
    Ich hatte immer im Reiter "info" vom ioBroker geschaut, dort stand alle Adapter sind auf dem aktuellen Stand???
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     12:19:25 up 7 min,  4 users,  load average: 14.39, 7.87, 3.46
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-01-01 12:19:26 CET
               Universal time: Wed 2025-01-01 11:19:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi        -user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix        '
    *** MEMORY ***
    Mem:            4.0G        3.7G        137M         19M        234M        273M
    Swap:           536M        108M        428M
    Total:          4.5G        3.8G        565M
    Active iob-Instances:   29
             3791 M total memory
             3531 M used memory
             1709 M active memory
             1769 M inactive memory
              130 M free memory
               17 M buffer memory
              205 M swap cache
              511 M total swap
              103 M used swap
              408 M free swap
    top - 12:19:27 up 7 min,  4 users,  load average: 14.39, 7.87, 3.46
    Tasks: 261 total,   2 running, 259 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 80.0 us, 13.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  6.7 si,  0.0 st
    MiB Mem :   3791.9 total,    128.9 free,   3532.8 used,    224.3 buff/cache
    MiB Swap:    512.0 total,    408.2 free,    103.8 used.    259.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  378M   1% /run
    /dev/mmcblk0p2 ext4       58G  9.9G   46G  18% /
    tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   67M  444M  14% /boot/firmware
    tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
    [Wed Jan  1 12:12:22 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave sn        d_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=        0  smsc95xx.macaddr=DC:A6:32:51:36:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size        =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5a905def-02 rootfst        ype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles c        fg80211.ieee80211_regdom=DE
    [Wed Jan  1 12:12:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be        -4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
    [Wed Jan  1 12:12:25 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7        a6-0481bca99d89 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id        =1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=002        2,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    233M    /var/log
    232M    /var/log/journal/8e3d143e94b24b14ab4c426d226d810e
    198M    /var/lib
    Archived and active journals take up 231.9M in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:633:26)
        at Socket.emit (node:events:518:28)
        at TCP.<anonymous> (node:net:343:12)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    Node.js v20.18.1
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
    + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, port: 8200, bind: 192.168.178.195
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.km200.0                  : km200                 : raspberrypi                              -  enabled
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.proxy.0                  : proxy                 : raspberrypi                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              - disabled
    + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.195, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                              │ auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.4.10
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.7
    Adapter    "backitup"     : 3.0.25   , installed 3.0.31
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "ems-esp"      : 5.0.6    , installed 5.1.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.4.5
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "rpi2"         : 2.2.1    , installed 2.3.0
    Adapter    "shelly"       : 8.2.1    , installed 8.5.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.2.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 6.2.5    , installed 6.3.1
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "worx"         : 3.1.1    , installed 3.1.1
    Objects and States
    Objects:        23222
    States:         14724
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5094       662/sshd: /usr/sbin
    tcp        0      0 192.168.178.195:8701    0.0.0.0:*               LISTEN      1001       13325      2074/io.hm-rpc.1
    tcp        0      0 192.168.178.195:8200    0.0.0.0:*               LISTEN      1001       12162      2365/io.cameras.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9233       648/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9289       648/iobroker.js-con
    tcp        0      0 192.168.178.195:8082    0.0.0.0:*               LISTEN      1001       12150      2350/io.web.0
    tcp        0      0 192.168.178.195:2010    0.0.0.0:*               LISTEN      1001       13332      2103/io.hm-rpc.2
    tcp        0      0 192.168.178.195:2001    0.0.0.0:*               LISTEN      1001       9155       2059/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6551       647/cupsd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       9042       1916/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11990      2221/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11993      2178/io.shelly.0
    tcp6       0      0 :::123                  :::*                    LISTEN      1001       9044       1916/node-red
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5096       662/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6550       647/cupsd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       12683      2275/io.sonos.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8879       1288/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       14806      2460/io.socketio.0
    udp        0      0 0.0.0.0:34418           0.0.0.0:*                           1001       22854      2320/io.ring.0
    udp        0      0 0.0.0.0:44667           0.0.0.0:*                           1001       21640      2320/io.ring.0
    udp        0      0 0.0.0.0:34429           0.0.0.0:*                           1001       16993      2320/io.ring.0
    udp        0      0 0.0.0.0:48826           0.0.0.0:*                           1001       19239      2320/io.ring.0
    udp        0      0 0.0.0.0:50907           0.0.0.0:*                           1001       22860      2320/io.ring.0
    udp        0      0 0.0.0.0:36595           0.0.0.0:*                           1001       21647      2320/io.ring.0
    udp        0      0 0.0.0.0:48929           0.0.0.0:*                           1001       20247      2320/io.ring.0
    udp        0      0 0.0.0.0:53025           0.0.0.0:*                           1001       21646      2320/io.ring.0
    udp        0      0 0.0.0.0:46902           0.0.0.0:*                           1001       20255      2320/io.ring.0
    udp        0      0 0.0.0.0:46907           0.0.0.0:*                           1001       18015      2320/io.ring.0
    udp        0      0 0.0.0.0:44860           0.0.0.0:*                           1001       18014      2320/io.ring.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       9046       1916/node-red
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       9045       1916/node-red
    udp        0      0 0.0.0.0:49020           0.0.0.0:*                           1001       19238      2320/io.ring.0
    udp        0      0 0.0.0.0:55168           0.0.0.0:*                           1001       18963      2320/io.ring.0
    udp        0      0 0.0.0.0:40858           0.0.0.0:*                           1001       20225      2320/io.ring.0
    udp        0      0 0.0.0.0:59325           0.0.0.0:*                           1001       20246      2320/io.ring.0
    udp        0      0 0.0.0.0:51152           0.0.0.0:*                           1001       24024      2320/io.ring.0
    udp        0      0 0.0.0.0:47123           0.0.0.0:*                           1001       24049      2320/io.ring.0
    udp        0      0 0.0.0.0:49206           0.0.0.0:*                           1001       17060      2320/io.ring.0
    udp   428288      0 0.0.0.0:14391           0.0.0.0:*                           1001       18037      3731/ffmpeg
    udp        0      0 0.0.0.0:14392           0.0.0.0:*                           1001       18038      3731/ffmpeg
    udp   426496      0 0.0.0.0:14393           0.0.0.0:*                           1001       18035      3731/ffmpeg
    udp        0      0 0.0.0.0:14394           0.0.0.0:*                           1001       18036      3731/ffmpeg
    udp   427264      0 0.0.0.0:14411           0.0.0.0:*                           1001       19233      3858/ffmpeg
    udp        0      0 0.0.0.0:14412           0.0.0.0:*                           1001       19234      3858/ffmpeg
    udp   426496      0 0.0.0.0:14413           0.0.0.0:*                           1001       19231      3858/ffmpeg
    udp        0      0 0.0.0.0:14414           0.0.0.0:*                           1001       19232      3858/ffmpeg
    udp   427904      0 0.0.0.0:14415           0.0.0.0:*                           1001       16163      3924/ffmpeg
    udp        0      0 0.0.0.0:14416           0.0.0.0:*                           1001       16164      3924/ffmpeg
    udp   426496      0 0.0.0.0:14417           0.0.0.0:*                           1001       16161      3924/ffmpeg
    udp        0      0 0.0.0.0:14418           0.0.0.0:*                           1001       16162      3924/ffmpeg
    udp        0      0 0.0.0.0:43109           0.0.0.0:*                           1001       20254      2320/io.ring.0
    udp        0      0 0.0.0.0:14451           0.0.0.0:*                           1001       21679      4370/ffmpeg
    udp        0      0 0.0.0.0:14452           0.0.0.0:*                           1001       21680      4370/ffmpeg
    udp        0      0 0.0.0.0:14453           0.0.0.0:*                           1001       21677      4370/ffmpeg
    udp        0      0 0.0.0.0:14454           0.0.0.0:*                           1001       21678      4370/ffmpeg
    udp        0      0 0.0.0.0:14475           0.0.0.0:*                           1001       24692      5206/ffmpeg
    udp        0      0 0.0.0.0:14476           0.0.0.0:*                           1001       24693      5206/ffmpeg
    udp        0      0 0.0.0.0:14477           0.0.0.0:*                           1001       24690      5206/ffmpeg
    udp        0      0 0.0.0.0:14478           0.0.0.0:*                           1001       24691      5206/ffmpeg
    udp        0      0 0.0.0.0:14479           0.0.0.0:*                           1001       24839      5363/ffmpeg
    udp        0      0 0.0.0.0:14480           0.0.0.0:*                           1001       24840      5363/ffmpeg
    udp        0      0 0.0.0.0:14481           0.0.0.0:*                           1001       24837      5363/ffmpeg
    udp        0      0 0.0.0.0:14482           0.0.0.0:*                           1001       24838      5363/ffmpeg
    udp        0      0 0.0.0.0:14483           0.0.0.0:*                           1001       25807      5364/ffmpeg
    udp        0      0 0.0.0.0:14484           0.0.0.0:*                           1001       25808      5364/ffmpeg
    udp        0      0 0.0.0.0:14485           0.0.0.0:*                           1001       25805      5364/ffmpeg
    udp        0      0 0.0.0.0:14486           0.0.0.0:*                           1001       25806      5364/ffmpeg
    udp        0      0 0.0.0.0:45239           0.0.0.0:*                           1001       18020      2320/io.ring.0
    udp        0      0 0.0.0.0:47374           0.0.0.0:*                           1001       18961      2320/io.ring.0
    udp        0      0 0.0.0.0:33093           0.0.0.0:*                           1001       20223      2320/io.ring.0
    udp        0      0 0.0.0.0:47432           0.0.0.0:*                           104        7187       462/avahi-daemon: r
    udp        0      0 0.0.0.0:45458           0.0.0.0:*                           1001       20928      2320/io.ring.0
    udp        0      0 0.0.0.0:49556           0.0.0.0:*                           1001       16110      2320/io.ring.0
    udp        0      0 0.0.0.0:43417           0.0.0.0:*                           1001       16994      2320/io.ring.0
    udp        0      0 0.0.0.0:49594           0.0.0.0:*                           1001       16111      2320/io.ring.0
    udp        0      0 0.0.0.0:55739           0.0.0.0:*                           1001       18962      2320/io.ring.0
    udp        0      0 0.0.0.0:43516           0.0.0.0:*                           1001       20253      2320/io.ring.0
    udp        0      0 0.0.0.0:51877           0.0.0.0:*                           1001       20248      2320/io.ring.0
    udp        0      0 0.0.0.0:33448           0.0.0.0:*                           1001       18021      2320/io.ring.0
    udp        0      0 0.0.0.0:51959           0.0.0.0:*                           1001       20224      2320/io.ring.0
    udp        0      0 0.0.0.0:48012           0.0.0.0:*                           1001       24824      2320/io.ring.0
    udp        0      0 0.0.0.0:48045           0.0.0.0:*                           1001       21641      2320/io.ring.0
    udp        0      0 0.0.0.0:35761           0.0.0.0:*                           1001       24019      2320/io.ring.0
    udp        0      0 0.0.0.0:44014           0.0.0.0:*                           1001       16109      2320/io.ring.0
    udp        0      0 0.0.0.0:46140           0.0.0.0:*                           1001       24008      2320/io.ring.0
    udp        0      0 0.0.0.0:52289           0.0.0.0:*                           1001       24002      2320/io.ring.0
    udp        0      0 0.0.0.0:35913           0.0.0.0:*                           1001       24823      2320/io.ring.0
    udp        0      0 0.0.0.0:50276           0.0.0.0:*                           1001       24825      2320/io.ring.0
    udp        0      0 0.0.0.0:44132           0.0.0.0:*                           1001       22861      2320/io.ring.0
    udp        0      0 0.0.0.0:38047           0.0.0.0:*                           1001       20927      2320/io.ring.0
    udp        0      0 0.0.0.0:58536           0.0.0.0:*                           1001       17061      2320/io.ring.0
    udp        0      0 0.0.0.0:36037           0.0.0.0:*                           1001       24050      2320/io.ring.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7185       462/avahi-daemon: r
    udp        0      0 0.0.0.0:50429           0.0.0.0:*                           1001       24025      2320/io.ring.0
    udp        0      0 0.0.0.0:60672           0.0.0.0:*                           1001       24018      2320/io.ring.0
    udp        0      0 0.0.0.0:34064           0.0.0.0:*                           1001       24051      2320/io.ring.0
    udp        0      0 0.0.0.0:48475           0.0.0.0:*                           1001       24007      2320/io.ring.0
    udp        0      0 0.0.0.0:38383           0.0.0.0:*                           1001       20929      2320/io.ring.0
    udp        0      0 0.0.0.0:46580           0.0.0.0:*                           1001       24001      2320/io.ring.0
    udp        0      0 0.0.0.0:54773           0.0.0.0:*                           1001       19240      2320/io.ring.0
    udp        0      0 0.0.0.0:58904           0.0.0.0:*                           1001       22855      2320/io.ring.0
    udp6       0      0 :::40512                :::*                                1001       24023      2320/io.ring.0
    udp6       0      0 :::46683                :::*                                1001       21651      2320/io.ring.0
    udp6       0      0 :::56929                :::*                                1001       22865      2320/io.ring.0
    udp6       0      0 :::42627                :::*                                1001       24006      2320/io.ring.0
    udp6       0      0 :::44690                :::*                                1001       21643      2320/io.ring.0
    udp6       0      0 :::34487                :::*                                1001       24005      2320/io.ring.0
    udp6       0      0 :::52994                :::*                                1001       18023      2320/io.ring.0
    udp6       0      0 :::53028                :::*                                1001       16996      2320/io.ring.0
    udp6   11008      0 :::46896                :::*                                1001       24003      2320/io.ring.0
    udp6       0      0 :::55116                :::*                                1001       17063      2320/io.ring.0
    udp6       0      0 :::42843                :::*                                1001       24022      2320/io.ring.0
    udp6   11008      0 :::40868                :::*                                1001       24026      2320/io.ring.0
    udp6       0      0 :::44975                :::*                                1001       18025      2320/io.ring.0
    udp6       0      0 :::57271                :::*                                1001       22863      2320/io.ring.0
    udp6       0      0 :::34793                :::*                                1001       18024      2320/io.ring.0
    udp6  214656      0 :::57387                :::*                                1001       22856      2320/io.ring.0
    udp6       0      0 :::41004                :::*                                1001       17065      2320/io.ring.0
    udp6       0      0 :::36950                :::*                                1001       16998      2320/io.ring.0
    udp6       0      0 :::34913                :::*                                1001       24012      2320/io.ring.0
    udp6       0      0 :::53376                :::*                                1001       24021      2320/io.ring.0
    udp6       0      0 :::43145                :::*                                1001       24027      2320/io.ring.0
    udp6       0      0 :::41122                :::*                                1001       22859      2320/io.ring.0
    udp6       0      0 :::43185                :::*                                1001       17064      2320/io.ring.0
    udp6  203648      0 :::47285                :::*                                1001       21642      2320/io.ring.0
    udp6       0      0 :::37062                :::*                                1001       24029      2320/io.ring.0
    udp6       0      0 :::39119                :::*                                1001       24028      2320/io.ring.0
    udp6  170624      0 :::51455                :::*                                1001       18022      2320/io.ring.0
    udp6       0      0 :::41391                :::*                                1001       22864      2320/io.ring.0
    udp6       0      0 :::57811                :::*                                1001       21645      2320/io.ring.0
    udp6       0      0 :::35317                :::*                                1001       24011      2320/io.ring.0
    udp6       0      0 fe80::5258:561a:ac4:546 :::*                                0          7530       581/NetworkManager
    udp6       0      0 fe80::69c9:52c2:907:546 :::*                                0          8403       581/NetworkManager
    udp6  170624      0 :::41584                :::*                                1001       17062      2320/io.ring.0
    udp6  170624      0 :::58032                :::*                                1001       22862      2320/io.ring.0
    udp6       0      0 :::56015                :::*                                1001       22857      2320/io.ring.0
    udp6       0      0 :::54052                :::*                                1001       21644      2320/io.ring.0
    udp6       0      0 :::33632                :::*                                1001       24004      2320/io.ring.0
    udp6  203648      0 :::58267                :::*                                1001       21648      2320/io.ring.0
    udp6       0      0 :::43997                :::*                                1001       16997      2320/io.ring.0
    udp6  167872      0 :::52221                :::*                                1001       24020      2320/io.ring.0
    udp6       0      0 :::58382                :::*                                1001       18019      2320/io.ring.0
    udp6       0      0 :::44063                :::*                                1001       18018      2320/io.ring.0
    udp6  181632      0 :::35888                :::*                                1001       18016      2320/io.ring.0
    udp6       0      0 :::48214                :::*                                1001       24010      2320/io.ring.0
    udp6   11008      0 :::60543                :::*                                1001       24009      2320/io.ring.0
    udp6       0      0 :::56452                :::*                                1001       21650      2320/io.ring.0
    udp6       0      0 :::33986                :::*                                1001       18017      2320/io.ring.0
    udp6       0      0 :::5353                 :::*                                104        7186       462/avahi-daemon: r
    udp6       0      0 :::42305                :::*                                1001       21649      2320/io.ring.0
    udp6       0      0 :::58756                :::*                                1001       22858      2320/io.ring.0
    udp6  181632      0 :::46483                :::*                                1001       16995      2320/io.ring.0
    udp6       0      0 :::60931                :::*                                104        7188       462/avahi-daemon: r
    2025-01-01 12:21:39.651  - warn: ring.0 (2320) Device 362750470 ("Haustür"): Couldn't create snapshot from image
    2025-01-01 12:21:40.969  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Livestream.request/ring.0.doorbell_362750470.Livestream.request:{"val":false,"ack":true,"ts":1735730499239,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654462833}
    2025-01-01 12:21:48.020  - debug: tr-064.1 (2305) in updateAll
    2025-01-01 12:21:48.022  - debug: tr-064.1 (2305) updateDevices
    2025-01-01 12:21:48.022  - debug: tr-064.1 (2305) forEachConfiguredDevice
    2025-01-01 12:21:48.406  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Livestream.request/ring.0.doorbell_362750470.Livestream.request:{"val":false,"ack":false,"ts":1735730506593,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654462833}
    2025-01-01 12:21:48.407  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Snapshot.request/ring.0.doorbell_362750470.Snapshot.request:{"val":false,"ack":false,"ts":1735730506598,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654153563}
    2025-01-01 12:21:48.408  - silly: ring.0 (2320) States user redis pmessage ring.0.doorbell_362750470.Snapshot.request/ring.0.doorbell_362750470.Snapshot.request:{"val":false,"ack":false,"ts":1735730506598,"q":0,"from":"system.adapter.ring.0","user":"system.user.admin","lc":1735654153563}
    2025-01-01 12:21:50.515  - debug: tr-064.1 (2305) forEachConfiguredDevice: i=0 fritz.box active=1
    2025-01-01 12:21:50.516  - debug: tr-064.1 (2305) forEachConfiguredDevice: {"NewIPAddress":"192.168.178.1","NewAddressSource":"Static","NewLeaseTimeRemaining":"0","NewInterfaceType":"","NewActive":"1","NewHostName":"fritz.box","NewMACAddress":"04:B4:FE:69:92:73"}
    2025-01-01 12:21:49.654  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Livestream.request changed: false (ack = false)
    2025-01-01 12:21:49.656  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Livestream request for 362750470 to value false
    2025-01-01 12:21:49.684  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Snapshot.request changed: false (ack = false)
    2025-01-01 12:21:49.685  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Snapshot request for 362750470 to value false
    2025-01-01 12:21:49.686  - silly: ring.0 (2320) state ring.0.doorbell_362750470.Snapshot.request changed: false (ack = false)
    2025-01-01 12:21:49.687  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Get Snapshot request for 362750470 to value false
    2025-01-01 12:21:49.688  - silly: ring.0 (2320) Adapter File /opt/iobroker/iobroker-data/files/ring.0/doorbell_362750470/doorbell_362750470/livestream362750470_1735730435839.mp4 written!
    2025-01-01 12:21:49.689  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Update Livestream Object
    2025-01-01 12:21:49.691  - debug: ring.0 (2320) Device 362750470 ("Haustür"): Done creating livestream to /opt/iobroker/iobroker-data/files/ring.0/doorbell_362750470/doorbell_362750470/livestream362750470_1735730435839.mp4
    2025-01-01 12:21:49.693  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save Snaspshot starts
    2025-01-01 12:21:49.694  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.takeSnapshot()
    2025-01-01 12:21:49.694  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save HD Snapshot starts
    2025-01-01 12:21:49.695  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.takeHDSnapshot()
    2025-01-01 12:21:51.302  - info: ring.0 (2320) Device 362750470 ("Haustür"): Cronjob Auto save Livestream starts
    2025-01-01 12:21:51.303  - silly: ring.0 (2320) Device 362750470 ("Haustür"): 362750470.startLivestream()
    iob diag has finished.
    @holzwurm1976 sagte in ioBroker sehr langsam:
    Geht mittlerweile über den
    iob fix
    Wir sprechen aber nicht von ioBroker-Adapter-Updates sondern von Updates des Betriebssystems. Die werden da nicht angezeigt.
    • H Holzwurm1976
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               3791 M total memory
               3531 M used memory
                130 M free memory
                 17 M buffer memory
                205 M swap cache
                511 M total swap
                103 M used swap
                408 M free swap
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      233M    /var/log
      198M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
              throw e;
      Node.js v20.18.1
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        23222
      States:         14724
      Pending Updates: 0
      Deutlich zu hoch.
      Schau dir per
      top
      oder
      htop
      an was da so schwer im System liegt.
      H 1 Antwort Letzte Antwort
      • H Holzwurm1976
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 3791 M total memory
                 3531 M used memory
                  130 M free memory
                   17 M buffer memory
                  205 M swap cache
                  511 M total swap
                  103 M used swap
                  408 M free swap
        *** FILESYSTEM ***
        /var:
        1.1G    /var/
        233M    /var/log
        198M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
                throw e;
        Node.js v20.18.1
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        23222
        States:         14724
        Pending Updates: 0
        @holzwurm1976
        Wenn ein System nicht mehr rund läuft, liegt es oft an den letzten Änderungen, die man getätigt hat.
        Schau Dir bitte mal die Auslastung an:
        CPU threads: 4
        Und dann seitenweise zigfach gestartete Prozesse:
        Dein System geht unter und die stellst bei den Adaptern tr-064, daswetter und ring noch wahnwitzige Loggingeinstellungen ein - debug zum Teil silly.
        Seit mehreren Tagen wurstelst Du an Deinem System - installierst neu - dann aber
        alle Adapter aus dem Beta-Repo, stellst dann aber schön auf "stable". Wieso macht man sowas?
          @holzwurm1976
          CPU threads: 4
          Holzwurm1976
          @rscsb
          Das kann ich Dir nicht sagen!
          Ich habe davon keine tiefgründige Ahnung!
          Kannst Du mir sagen, welche Einstellungen ich wo machen sollte?
          Updates habe ich (meiner Meinung nach) jetzt alle gemacht…
          • H Holzwurm1976
            @rscsb
            @holzwurm1976
            Stell die Adapter schon mal auf debug-level 'info'.
            Also den tr-064.1 und ring.0 mindestens.
            Wieviele Kameras hast du da am Start? Scheint mir zu viel zu sein.
              Deutlich zu hoch.
              Schau dir per
              top
              oder
              htop
              Holzwurm1976
              sorry, aber wie kann ich diese Daten deuten?
              • H Holzwurm1976
                Was meinst du? Die beiden genannten Instanzen kippen alles mögliche in dein LogFile und bremsen so das System aus.
                  @holzwurm1976
                  Holzwurm1976
                  den debug-level habe ich umgestellt, scheint schon etwas besser zu laufen, hängt sich aber noch immer um.
                  Den Camera Adapter habe ich komplett deaktiviert, habe aber auch nur 2 Cameras...
                    Holzwurm1976
                    ja, aber wie sehe ich welche die sind, die am meisten blockieren?
                    • H Holzwurm1976
                      @holzwurm1976
                      Dann zeig jetzt nochmal ein kompletten Lauf von
                      iob diag
                      sowie
                      top
                      H 2 Antworten Letzte Antwort
                        @holzwurm1976
                        iob diag
                        sowie
                        top
                        Holzwurm1976
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         13:56:08 up 2 min,  3 users,  load average: 5.38, 2.01, 0.74
                        CPU threads: 4
                        Current issues:
                                       Local time: Wed 2025-01-01 13:56:08 CET
                                   Universal time: Wed 2025-01-01 12:56:08 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.0G        1.8G        1.6G        1.4M        561M        2.1G
                        Swap:           536M          0B        536M
                        Total:          4.5G        1.8G        2.2G
                        Active iob-Instances:   16
                                 3791 M total memory
                                 1758 M used memory
                                 1865 M active memory
                                  228 M inactive memory
                                 1572 M free memory
                                   47 M buffer memory
                                  487 M swap cache
                                  511 M total swap
                                    0 M used swap
                                  511 M free swap
                        top - 13:56:09 up 2 min,  3 users,  load average: 5.38, 2.01, 0.74
                        Tasks: 244 total,   9 running, 235 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 77.8 us, 22.2 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3791.9 total,   1570.3 free,   1760.8 used,    535.9 buff/cache
                        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2031.1 avail Mem
                        *** FILESYSTEM ***
                        tmpfs          tmpfs     380M  1.2M  378M   1% /run
                        tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                        tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
                        [Wed Jan  1 13:53:39 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:51:36:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5a905def-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                        [Wed Jan  1 13:53:42 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
                        [Wed Jan  1 13:53:43 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.2G    /var/
                        321M    /var/log
                        320M    /var/log/journal/8e3d143e94b24b14ab4c426d226d810e
                        198M    /var/lib
                        Archived and active journals take up 319.9M in the file system.
                        45M     /opt/iobroker/iobroker-data/states.jsonl
                        19M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 160)
                        admin:          7.4.10
                        javascript:     8.8.3
                        Adapter State
                        + system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        + instance is alive
                        Objects and States
                        Objects:        23199
                        States:         14710
                        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Pending Updates: 0
                        tcp        0      0 192.168.178.195:8701    0.0.0.0:*               LISTEN      1001       10262      1381/io.hm-rpc.1
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6299       655/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6327       642/cupsd
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4017       643/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9221       643/iobroker.js-con
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       6935       1212/node-red
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11983      1674/io.sonoff.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13461      1681/io.shelly.0
                        tcp        0      0 192.168.178.195:2001    0.0.0.0:*               LISTEN      1001       7956       1355/io.hm-rpc.0
                        tcp        0      0 192.168.178.195:2010    0.0.0.0:*               LISTEN      1001       11908      1448/io.hm-rpc.2
                        tcp        0      0 192.168.178.195:8082    0.0.0.0:*               LISTEN      1001       12085      2027/io.web.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6326       642/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6301       655/sshd: /usr/sbin
                        tcp6       0      0 :::123                  :::*                    LISTEN      1001       6937       1212/node-red
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       14448      2230/io.socketio.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9300       901/io.admin.0
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11088      1695/io.sonos.0
                        udp        0      0 0.0.0.0:46211           0.0.0.0:*                           104        5014       471/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5012       471/avahi-daemon: r
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6939       1212/node-red
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       6938       1212/node-red
                        udp6       0      0 :::5353                 :::*                                104        5013       471/avahi-daemon: r
                        udp6       0      0 :::46396                :::*                                104        5015       471/avahi-daemon: r
                        udp6       0      0 fe80::5258:561a:ac4:546 :::*                                0          6629       585/NetworkManager
                        udp6       0      0 fe80::69c9:52c2:907:546 :::*                                0          6375       585/NetworkManager
                        2025-01-01 13:57:19.870  - debug: info.0 (2129) Process wifi with networks.net0: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"44:4e:6d:24:35:0a","mode":"Infra","channel":1,"frequency":2412,"signalLevel":-50,"quality":100,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                        2025-01-01 13:57:19.991  - debug: info.0 (2129) Process wifi with networks.net1: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"04:b4:fe:69:92:75","mode":"Infra","channel":11,"frequency":2462,"signalLevel":-58,"quality":84,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                        2025-01-01 13:57:20.428  - debug: info.0 (2129) Process wifi with networks.net2: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"04:b4:fe:69:92:76","mode":"Infra","channel":100,"frequency":5500,"signalLevel":-66.5,"quality":67,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                        2025-01-01 13:57:20.541  - debug: info.0 (2129) Process wifi with networks.net3: {"ssid":"FRITZ!Box 6660 Cable FP","bssid":"44:4e:6d:24:35:09","mode":"Infra","channel":52,"frequency":5260,"signalLevel":-67,"quality":66,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                        2025-01-01 13:57:20.679  - debug: info.0 (2129) Process wifi with networks.net4: {"ssid":"FRITZ!Box 6660 Repeater","bssid":"08:96:d7:ec:9f:68","mode":"Infra","channel":1,"frequency":2412,"signalLevel":-67.5,"quality":65,"security":["WPA2"],"wpaFlags":[],"rsnFlags":["pair_ccmp","group_ccmp","psk"]}
                        2025-01-01 13:57:21.110  - info: hm-rega.0 (1302) added/updated 53 variables
                        2025-01-01 13:57:21.112  - debug: info.0 (2129) Process docker with info: {}
                        2025-01-01 13:57:21.111  - info: hm-rega.0 (1302) deleted 0 variables
                        2025-01-01 13:57:21.220  - info: hm-rega.0 (1302) got 57 programs
                        2025-01-01 13:57:25.644  - info: hm-rega.0 (1302) added/updated 57 programs
                        2025-01-01 13:57:25.644  - info: hm-rega.0 (1302) deleted 0 programs
                        2025-01-01 13:57:26.123  - info: hm-rega.0 (1302) update rooms to enum.rooms
                        2025-01-01 13:57:26.250  - info: hm-rega.0 (1302) update functions to enum.functions
                        2025-01-01 13:57:26.274  - info: hm-rega.0 (1302) hm-rpc.0.BidCoS-RF.5 has been added to functions Neues Gewerk-2
                        2025-01-01 13:57:26.291  - silly: info.0 (2129) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":["hm-rpc.0.BidCoS-RF.5"],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2025-01-01 13:57:26.293  - silly: socketio.0 (2230) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":["hm-rpc.0.BidCoS-RF.5"],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2025-01-01 13:57:26.302  - info: hm-rega.0 (1302) hm-rpc.0.BidCoS-RF.5 has been removed from functions Neues Gewerk-2
                        2025-01-01 13:57:26.328  - silly: info.0 (2129) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":[],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2025-01-01 13:57:26.330  - silly: socketio.0 (2230) Objects system redis pmessage enum.*/cfg.o.enum.functions.Neues Gewerk-2:{"_id":"enum.functions.Neues Gewerk-2","desc":"","type":"enum","common":{"name":"Neues Gewerk-2","members":[],"smartName":false},"native":{"Name":"Neues Gewerk-2","TypeName":"ENUM","EnumInfo":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1578319114633,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2025-01-01 13:57:26.504  - info: hm-rega.0 (1302) update favorites to enum.favorites
                        2025-01-01 13:57:29.147  - info: admin.0 (901) ==> Connected system.user.admin from ::ffff:192.168.178.36
                        2025-01-01 13:57:30.517  - info: ems-esp.0 (1218) end of initializing KM200 states
                        2025-01-01 13:57:30.519  - info: ems-esp.0 (1218) KM200: polling every 300 secs
                        2025-01-01 13:57:31.961  - info: cloud.0 (1147) Trying to connect as system.user.admin to cloud
                        2025-01-01 13:57:32.105  - info: cloud.0 (1147) Connection changed: connect
                          @holzwurm1976
                          iob diag
                          sowie
                          top
                          Holzwurm1976
                          • H Holzwurm1976
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           536M          0B        536M
                                     3791 M total memory
                                     1758 M used memory
                                     1572 M free memory
                                       47 M buffer memory
                                      487 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.2G    /var/
                            321M    /var/log
                            198M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.4.10
                            javascript:     8.8.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        23199
                            States:         14710
                            Pending Updates: 0
                            info.0
                            Der info-Adaper sollte deinstalliert werden. Der funktioniert schon geraume Zeit nicht mehr richtig.
                            Davon abgesehen läuft der auch auf debug-Loglevel. Weg damit!
                            • H Offline
                              Holzwurm1976
                              OK, ist erledigt...
                                info.0
                                Holzwurm1976
                                ich glaube das "schlimmste" macht der Ring Adapter.
                                Ich habe den deaktiviert, jetzt läuft es wieder recht stabil...
                                -1
                                • H Holzwurm1976
                                  Natürlich!
                                  war ja schon hier zu sehen.
                                  ist ja auch klar wenn der auf silly steht
