  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
    3.2k
111 Beiträge 7 Kommentatoren 19.7k Aufrufe 6 Beobachtet
  • E e-i-k-e
    Ich komme aber trotzdem leider nicht weiter.
    pi@iobroker:~$ lsusb
    Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
    Bus 002 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    pi@iobroker:~$ sudo ls /dev/serial/by-id
    ls: cannot access '/dev/serial/by-id': No such file or directory
    #95
    @e-i-k-e
    Schau dir per
    dmesg -wT
    die Meldungen an, wenn der Stickk entfernt und nach einer Minute wieder eingesteckt wird.
    E 1 Antwort Letzte Antwort
      @e-i-k-e
      Schau dir per
      dmesg -wT
      e-i-k-e
      schrieb am zuletzt editiert von e-i-k-e
      #96
      @thomas-braun sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
      @e-i-k-e
      Schau dir per
      dmesg -wT
      [Thu Dec 12 21:05:18 2024] usb 2-1: USB disconnect, device number 5
      [Thu Dec 12 21:05:18 2024] usb 2-2: USB disconnect, device number 4
      [Thu Dec 12 21:05:18 2024] workqueue: hub_event hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
      [Thu Dec 12 21:05:18 2024] usb 2-2: new full-speed USB device number 6 using xhci_hcd
      [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
      [Thu Dec 12 21:05:18 2024] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [Thu Dec 12 21:05:18 2024] usb 2-2: Product: CP2102 USB to UART Bridge Controller
      [Thu Dec 12 21:05:18 2024] usb 2-2: Manufacturer: Silicon Labs
      [Thu Dec 12 21:05:18 2024] usb 2-2: SerialNumber: 0021
      [Thu Dec 12 21:05:54 2024] usb 2-1: new high-speed USB device number 7 using xhci_hcd
      [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
      [Thu Dec 12 21:05:54 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [Thu Dec 12 21:05:54 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
      [Thu Dec 12 21:05:54 2024] usb 2-1: Manufacturer: Texas Instruments
      [Thu Dec 12 21:05:54 2024] usb 2-1: SerialNumber: L1100L7S
      [Thu Dec 12 21:05:54 2024] hid-generic 0003:0451:BEF3.0003: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
      Ein USB-Device habe ich stecken lassen und eins habe ich getrennt und nach einer gewissen zeit, wieder verbunden.
      • E e-i-k-e
        @e-i-k-e
        Schau dir per
        dmesg -wT
        #97
        @e-i-k-e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
        Und haben die auch Bezeichnungen?
          e-i-k-e
          #98
          Beide entfern.
          Erst "Silicon Labs CP210x UART Bridge", anschließend " Texas Instruments, Inc. CC1352R1 Launchpad".
          [Thu Dec 12 21:13:04 2024] usb 2-2: USB disconnect, device number 6
          [Thu Dec 12 21:13:10 2024] usb 2-1: USB disconnect, device number 7
          Einen wieder Verbunden "Texas Instruments, Inc. CC1352R1 Launchpad".
          [Thu Dec 12 21:14:40 2024] usb 2-1: new high-speed USB device number 8 using xhci_hcd
          [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
          [Thu Dec 12 21:14:40 2024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Thu Dec 12 21:14:40 2024] usb 2-1: Product: XDS110 (03.00.00.25) Embed with CMSIS-DAP
          [Thu Dec 12 21:14:40 2024] usb 2-1: Manufacturer: Texas Instruments
          [Thu Dec 12 21:14:40 2024] usb 2-1: SerialNumber: L1100L7S
          [Thu Dec 12 21:14:40 2024] hid-generic 0003:0451:BEF3.0004: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.25) Embed with CMSIS-DAP] on usb-0000:01:1b.0-1/input5
          • E e-i-k-e
            Beide entfern.
            #99
            @e-i-k-e
            Das ist nur der Debugger.
            Keine Ahnung, warum das eigentliche Device nicht gesehen wird.
            Verwendest du da einen USB-Hub oder sowas? Stick am Verlängerungskabel?
              @e-i-k-e
              e-i-k-e
              #100
              @e-i-k-e
              Es ist ein kurzes USB-Verlängerungskabel dazwischen. Aber diese Konstellation hat an der vorherigen Hardware genauso funktioniert.
              Warum erhalte ich keine Ausgabe durch ls /dev/serial/by-id
              Sondern nur die Meldung "ls: cannot access '/dev/serial/by-id': No such file or directory" ?
              • E e-i-k-e
                @e-i-k-e
                #101
                Weil der Kernel/udev das Gerät nicht als serielles Gerät erkennt und deswegen auch die Links nicht angelegt werden.
                  e-i-k-e
                  #102
                  Kann ich noch was machen oder prüfen?
                  Ich finde es ja sehr merkwürdig, dass es nicht funktioniert.
                  Ich habe eine neue VM mit einer anderen Version (22.04) von Ubuntu aufgesetzt.
                  Gleiches Problem.
                  root@iobroker:~# lsusb
                  Bus 002 Device 002: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                  root@iobroker:~# ls -l /dev/serial/by-id
                  root@iobroker:~
                  • E e-i-k-e
                    Gleiches Problem.
                    root@iobroker:~
                    #103
                    @e-i-k-e
                    Joh, du sollst auch partout nicht als root herumeiern.
                      @e-i-k-e
                      e-i-k-e
                      #104
                      Ist klar. Ist auch nur eine neue Test-Umgebung.
                      • E e-i-k-e
                        #105
                        @e-i-k-e
                        Egal. Macht man ganz grundsätzlich nicht.
                          @e-i-k-e
                          e-i-k-e
                          #106
                          Okay.
                          Was kann ich bei meinem Problem noch machen?
                          Kann das an der neuen Hardware (HP T640) bzw. einer falschen Bios Einstellung liegen?
                          • E e-i-k-e
                            Okay.
                            #107
                            @e-i-k-e
                            Ich weiß, das nutzt dir nix, aber richtig schaut das Einstecken eines seriellen Devices so aus:
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: Product: slae.sh cc2652rb stick - slaesh's iot stuff
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: Manufacturer: Silicon Labs
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: SerialNumber: 00_12_4B_00_23_93_2C_A8
                            [Thu Dec 12 22:57:10 2024] cp210x 1-1.3:1.0: cp210x converter detected
                            [Thu Dec 12 22:57:10 2024] usb 1-1.3: cp210x converter now attached to ttyUSB0
                            Dann gibt es auch die Geräte-Datei und den Link by-id dorthin:
                            echad@chet:~ $ ls -la /dev/serial/by-id/
                            total 0
                            drwxr-xr-x 2 root root 60 Dec 12 22:57 .
                            drwxr-xr-x 4 root root 80 Dec 12 22:57 ..
                            lrwxrwxrwx 1 root root 13 Dec 12 22:57 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                            echad@chet:~ $
                              @e-i-k-e
                              total 0
                              echad@chet:~ $
                              e-i-k-e
                              #108
                              Ich habe gerade eine dritte VM aufgesetzt, diesmal mit Debian 12.
                              pi@localhost:~$ sudo ls -l /dev/serial/by-id
                              [sudo] password for pi:
                              total 0
                              lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if00 -> ../../ttyACM0
                              lrwxrwxrwx 1 root root 13 Dec 12 22:55 usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100L7S-if03 -> ../../ttyACM1
                              Verstehe nicht, warum es jetzt klappt.
                              • E e-i-k-e
                                total 0
                                #109
                                Weil es Debian ist... ;-)
                                  e-i-k-e
                                  #110
                                  😉 bedeutet, dass Debian „besser“ für diesen Anwendungsfall wäre?
                                  • E e-i-k-e
                                    #111
                                    @e-i-k-e
                                    Ist es ohnehin... Ubuntu ist ja nur der zweite Aufguss.
