  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 474.9k Aufrufe 138 Beobachtet
  • JackDanielJ Offline
    JackDanielJ Offline
    JackDaniel
    #708
    kommt auch nicht wirklich viel, die aktuelle dev auf debug gestellt beim start
    roborock.0
    2024-12-11 13:17:21.875	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
    roborock.0
    2024-12-11 13:17:21.680	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
    roborock.0
    2024-12-11 13:17:21.659	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
    roborock.0
    2024-12-11 13:17:21.402	debug	initializeRoborockApi
    roborock.0
    2024-12-11 13:17:21.377	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    2024-12-11 13:17:21.367	info	starting. Version 0.6.17 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.5
    roborock.0
    2024-12-11 13:17:21.212	debug	Plugin sentry Initialize Plugin (enabled=true)
    roborock.0
    2024-12-11 13:17:21.190	debug	States connected to redis: 127.0.0.1:6379
    roborock.0
    2024-12-11 13:17:21.185	debug	States create User PubSub Client
    roborock.0
    2024-12-11 13:17:21.185	debug	States create System PubSub Client
    roborock.0
    2024-12-11 13:17:21.182	debug	Redis States: Use Redis connection: 127.0.0.1:6379
    roborock.0
    2024-12-11 13:17:21.173	debug	Objects connected to redis: 127.0.0.1:6379
    roborock.0
    2024-12-11 13:17:21.171	debug	Objects client initialize lua scripts
    roborock.0
    2024-12-11 13:17:21.036	debug	Objects create User PubSub Client
    roborock.0
    2024-12-11 13:17:21.036	debug	Objects create System PubSub Client
    roborock.0
    2024-12-11 13:17:21.035	debug	Objects client ready ... initialize now
    roborock.0
    2024-12-11 13:17:21.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
    Carpe diem
    • T TimoWald
      Hallo habe aktuell diese Fehlermeldung. Diese kommt aber nur wenn ich Kartenerstellung aktiviere.
      Was kann ich dagegen tun?
      2024-12-07 13:00:18.752 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:20.373 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:21.787 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:24.444 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:26.375 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:28.423 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:30.431 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:32.502 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:34.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:36.428 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:38.402 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:40.751 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:42.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:44.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:46.411 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:48.468 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:49.028 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 240048
      2024-12-07 13:00:50.514 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:50.963 - info: daswetter.0 (240048) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
      2024-12-07 13:00:51.008 - info: daswetter.0 (240048) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-12-07 13:00:51.522 - info: daswetter.0 (240048) cleaned everything up...
      2024-12-07 13:00:51.537 - info: host.iobroker instance system.adapter.daswetter.0 having pid 240048 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-07 13:00:52.441 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:54.501 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:56.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:00:58.377 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:00.558 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:02.519 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:04.407 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:04.646 - info: solax.0 (70086) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2024-12-07 13:01:06.664 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:08.438 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:10.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:12.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:14.367 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:16.430 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:18.613 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:20.397 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:22.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:24.477 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:26.365 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:28.442 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:30.598 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:32.440 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      2024-12-07 13:01:34.439 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
      TimoWald
      schrieb am zuletzt editiert von TimoWald
      #709
      @timowald Keiner eine Lösung für mich?
      IOB läuft auf Proxmox.
      Ro75R 1 Antwort Letzte Antwort
      • T TimoWald
        Ro75R Offline
        Ro75R Offline
        Ro75
        #710
        @timowald Compact mode aktiv? Für die map wird doch ein Port benötigt.
        Ro75
        T mcm1957M 2 Antworten Letzte Antwort
        • copystringC Offline
          copystringC Offline
          copystring
          #711
          @JackDaniel ich gehe davon aus, dass du den Adapter auch schon mal komplett gelöscht und neu eingerichtet hast?
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
            JackDanielJ Offline
            JackDaniel
            #712
            danke das war genau der richtige tip, adapter geht wieder als ob nie etwas gewesen wäre :man-shrugging:
            Carpe diem
              copystringC Offline
              copystring
              #713
              Das Issue von dir auf GitHub kann das also geschlossen werden?
                JackDanielJ Offline
                JackDaniel
                #714
                ist schon erledigt, danke nochmal
                Carpe diem
                • Ro75R Ro75
                  Ro75
                  TimoWald
                  #715
                  @ro75 Compact Mode sagt mir jetzt gar nix.
                  So sieht es bei mir im Adapter aus. Wenn ich Kartenerstellung aktiviere kommt der Fehler im LOG.
                  • Ro75R Ro75
                    Ro75
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #716
                    @ro75 said in Neuer Adapter für Roborock-Staubsauger:
                    Ro75
                    @Ro75
                    Bitte prüfe ob der Adapter im COMPACT MODE funktioniert. Compact Mode und Port haben zunächst mal nichts miteinander zu tun. Wenn der COMPACT MODE nicht sicher funktioniert wäre der Fehler zu suchen oder der Adapter muss spezifizieren, dass er den Compact Mode nicht unterstützt.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    T Ro75R 2 Antworten Letzte Antwort
                    • mcm1957M mcm1957
                      Ro75
                      @Ro75
                      TimoWald
                      #717
                      @mcm1957 wie aktiviere ich den Compact Mode?
                      • mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #718
                        @timowald
                        https://forum.iobroker.net/topic/32789/anleitung-für-adapter-entwickler-compact-mode-testen
                        Normaler Weise laufen alle Adapter (und der js-controller) als getrennte Prozesse. Das bedeutet dass sioe sich keinen Speicherbereich (im RAM) teilen. Dies bedeutet auch, dass ein Fehler (= Crash) eines Adapters im Allgemeinen keinen Einfluss auf die Funktion anderer Adapter hat - von gesmmter CPU Auslastung etc, mal abgesehen,
                        Der Compact Mode bedeutet dass mehrere Adapter sich einen Prozess teilen. Dies spoart insbesondere auf Systemen mit (zu) kleinem Speicher Resourcen. Allerdings bedeutet das auch, dass ein Adapter der abstürzt zwangsweise alle anderen Adapter mitreißt. Un da keine Trennung der Speicherbereiche existiert kann im Proinzip ein Adapter Daten eines anderen Adapters überschreiben (auch wenn javascritp da eh schon recht gut separiert).
                        Ergo:
                        Der Compact Mode sollte dann und nur dann eingesetztw erden, wenn Speicher (RAM) eingespart werden muss. Für ein stabiles System ist aber meist eine Migration auf ein größerers System die mittelfristig bessere Alternativ.
                        Ein Adapter der im Compact Mode läuft ist übrigends im Log durch (COMPACT) erkennbar.
                        • F Offline
                          fuchs1978
                          #719
                          Ich habe in der letzten Version den Fehler:
                          State "roborock.0.HomeData" has no existing object, this might lead to an error in future versions
                          Das Objekt ist bei mir nicht vorhanden
                          • F fuchs1978
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #720
                            @fuchs1978 said in Neuer Adapter für Roborock-Staubsauger:
                            Erstell bitte ein issue im Adapterrepository und gib die Version exakt an. letzteVersion ist jetzt dchon unklar (letzte stable od letzte latrst) und morgen ev ganz was anderes.
                            F 1 Antwort Letzte Antwort
                            • mcm1957M mcm1957
                              Ro75
                              @Ro75
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              #721
                              @mcm1957 sagte in Neuer Adapter für Roborock-Staubsauger:
                              Ro75
                              @Ro75
                              @mcm1957 das Problem betrifft mich nicht. Wollte nur prüfen lassen ob der Kollege das
                              aktiviert hat. Wenn ja wäre es ggfs. eine Ursache.
                              Ro75.
                              • Ro75R Ro75
                                Ro75
                                @Ro75
                                Ro75.
                                TimoWald
                                #722
                                @ro75 In welchem Adapter ect. finde ich diese Option?
                                • T TimoWald
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #723
                                  @timowald
                                  • mcm1957M mcm1957
                                    fuchs1978
                                    #724
                                    @mcm1957 said in Neuer Adapter für Roborock-Staubsauger:
                                    https://github.com/copystring/ioBroker.roborock/issues/734
                                    • H Offline
                                      highline
                                      #725
                                      Hallo Zusammen und Danke für diesen Adapter.
                                      Ich kann den Roborock leider nicht "per Mausklick" aus dem Adapter heraus per app_segment_clean losfahren lassen, es funktioniert einfach nicht. Ich hatte es so verstanden, dass ich entweder alle Räume, außer einem, auf false stellen muss und dann einfach den Button app_segment_clean anklicke, der dann kurz von false auf true geht. Der Adapter ist sonst grün. Was mache ich falsch?
                                      • H highline
                                        Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        #726
                                        @highline also du setzt nur den Raum auf true der gereinigt werden soll. Dann muss eine kleine Pause rein und dann kannst du den anderen Befehl starten.
                                        Dann geht es auch, funktioniert bei mir auch nur so
                                        Ro75
                                        H 1 Antwort Letzte Antwort
                                        • Ro75R Ro75
                                          Ro75
                                          highline
                                          #727
                                          @ro75 danke, und das geht auch per Mausklick nacheinander direkt in den Objekten oder nur per Script?
