  5. Regensensor Blockly vereinen
    6.5k
41 Beiträge 7 Kommentatoren 5.7k Aufrufe 6 Beobachtet
  • S Sushibomba
    @chris76e
    Klaro :)
      <variables>
        <variable id="YM#%4ryA|zg=hJxPLR]9">delay</variable>
        <variable type="timeout" id="timeout2">timeout2</variable>
        <variable id="Px*`UM+[bBTnRrkz7ahY">msg</variable>
        <variable id="uZcvBI;$3hz:XKTG%H~a">lastMsg</variable>
      </variables>
      <block type="variables_set" id=";{/vyPH[lUJ|j@ydR+U5" x="263" y="588">
        <field name="VAR" id="YM#%4ryA|zg=hJxPLR]9">delay</field>
        <value name="VALUE">
          <block type="math_number" id="+}tQ;h6~%j_?ACtg|gqz">
            <field name="NUM">10000</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="MQumz1aO.lQ;5n3mi_CK">
            <value name="OID0">
              <shadow type="field_oid" id="GA2V$#WqnaO=^jS}aDm}">
                <field name="oid">zigbee.0.00158d0009e15c4e.detected</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="timeouts_cleartimeout" id="J_e=W;xlRrG/7CC-RI6]">
                <field name="NAME">delay</field>
                <next>
                  <block type="timeouts_settimeout_variable" id="rY,mUnIIXAQ4V[i#XS$$">
                    <field name="NAME">timeout2</field>
                    <value name="DELAY_MS">
                      <shadow type="math_number" id="te*eQbAx}q,v=}EO-HEx">
                        <field name="NUM">1000</field>
                      </shadow>
                      <block type="variables_get" id="D$#{DMS]x+#KV1lRMlTw">
                      </block>
                    </value>
                      <block type="controls_if" id="bKIjzCMM.7E!I4!47`;!">
                        <value name="IF0">
                          <block type="logic_compare" id="(YeX3v|8R23Hw_)7G,M|">
                            <field name="OP">EQ</field>
                            <value name="A">
                              <block type="variables_get" id="aaebj(u.x23^a~|2G-@r">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="D`wFSS%H%bDAi5Co+{9R">
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="variables_set" id="0mGZ4EPI6?.;0ylMMA_s">
                              <block type="math_number" id="D8/B+K5Qk+J24mcB|~*r">
                                <field name="NUM">30000</field>
                              </block>
                            </value>
                          </block>
                        </statement>
                        <statement name="ELSE">
                          <block type="variables_set" id="TOGWW8xacPfv_1eELS+,">
                              <block type="math_number" id="R}cJqg|l2Q`sV2T`0igG">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block type="controls_if" id="qXC,B2]hdVPPQVSG#0xz">
                            <value name="IF0">
                              <block type="on_source" id="xEp}O*VO~C)oX.m_17sq">
                              </block>
                            </value>
                              <block type="debug" id="GbF0aP1FWJbz6H*ylYC7">
                                <value name="TEXT">
                                  <shadow type="text" id="E=^Vk*yCQq!2u*wB^sWw">
                                    <field name="TEXT">Es regnet!</field>
                                  </shadow>
                                </value>
                                <next>
                                  <block type="variables_set" id="A@nCgjPl)N%1O/+%[6KR">
                                    <field name="VAR" id="Px*`UM+[bBTnRrkz7ahY">msg</field>
                                      <block type="text" id="fD?BmD)*eSZqPw$}kRvN">
                                        <field name="TEXT">🌧️ Es regnet seit: </field>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="update" id="4bR$MR$-E|fp~hS7R$sS">
                                        <field name="OID">0_userdata.0.VIS.Eigene_Datenpunkte.Sensoren.Regensensor</field>
                                          <block type="text" id="$=7.8%G6.XR%p4GW_:*o">
                                            <field name="TEXT">Regen</field>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                              <block type="debug" id="lW0w^=/{7?y-h.k;~g+.">
                                <value name="TEXT">
                                  <shadow type="text" id="dUdC#XW0Ofqw=;KFLFrC">
                                    <field name="TEXT">Es ist trocken!</field>
                                  </shadow>
                                </value>
                                <next>
                                  <block type="variables_set" id="9uo@uL`$19!v$1xicC;Y">
                                      <block type="text" id="k|t_kalP`p-}MYTNx]c)">
                                        <field name="TEXT">⛅ Es ist trocken seit: </field>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="update" id="[|(O6pJhjjLsvg_oPDY9">
                                          <block type="text" id="nz{LIn_/3w/)`Ku$XsSm">
                                            <field name="TEXT">Trocken</field>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <next>
                              <block type="controls_if" id="tIrmc/NqX{h+nvyI5)Wn">
                                <value name="IF0">
                                  <block type="logic_compare" id="Hr(,J3HaZuwe6M`rgt0p">
                                    <field name="OP">NEQ</field>
                                    <value name="A">
                                      <block type="variables_get" id="sgPGTt^$9/-SBiXr62DZ">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="variables_get" id="!?^{C=Q=H3NAi-*#}Hf`">
                                        <field name="VAR" id="uZcvBI;$3hz:XKTG%H~a">lastMsg</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="variables_set" id="Ewz8`X_80GmZpB?N/Rg*">
                                      <block type="variables_get" id="3PK?u-Gk3r[oK;wDIj_H">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="controls_if" id="fw5%cK9r[$FOQY?7M{?n">
                                        <value name="IF0">
                                          <block type="logic_operation" id="IP6d{Ol89E)i}i3%|Qr/" inline="false">
                                            <field name="OP">AND</field>
                                            <value name="A">
                                              <block type="on_source" id=".Sad9s?yEPT6bmevg1K#">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="logic_compare" id="8Ek_%muzvXq42!kbkJI%">
                                                <value name="A">
                                                  <block type="get_value" id="@X,+.D[N2_XE{Wj)[!xi">
                                                    <field name="OID">0_userdata.0.VIS.Eigene_Datenpunkte.Tageszeit</field>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="text" id="kgUsh/_8jM_SFV7_L4a/">
                                                    <field name="TEXT">Tag</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="control" id="JVHP0_0-HgVqE=0?:yV%">
                                            <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                            <field name="OID">alexa2.0.Echo-Devices.G0918309036602A9.Commands.speak</field>
                                            <field name="DELAY_MS">1</field>
                                            <comment pinned="false" h="80" w="160">Hier das Echo Gerät mit speak auswählen, welches die Updates ansagen soll. Für mehrere Echo Geräte einfach den Block kopieren und drunter anhängen.</comment>
                                              <block type="text" id="atpiy%H2G_IZa!oLfZd_">
                                                <field name="TEXT">30;Hey, es fängt gerade an zu regnen.</field>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="telegram" id="9gM_-~h%1Gj4h~^7IsFq">
                                            <field name="LOG"></field>
                                            <field name="ESCAPING">FALSE</field>
                                            <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                                            <value name="MESSAGE">
                                              <shadow type="text" id="16%7eWeUx^=[]wcA]DYd">
                                              </shadow>
                                              <block type="text_join" id="6e7En|$yufE3)riC1o{L">
                                                <value name="ADD0">
                                                  <block type="variables_get" id="p-iCge:`Dm)$5wDc7w%5">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                  <block type="time_get" id="ce|f=6BC@ZChs$je={xL">
                                                    <field name="OPTION">hh:mm</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
      <block type="comment" id="]#;fUXsqP;An.q2Ca+dQ" x="513" y="688">
        <field name="COMMENT">Verzögerung um ...</field>
      </block>
      <block type="comment" id=";q{hIgl39F;$bEv%B#PP" x="613" y="788">
        <field name="COMMENT">Falls die Var. auf 10 Sek. dann timeout auf 30 Sek.</field>
        <next>
          <block type="comment" id="E%XhYYjw|S]V;$IUgBQ#">
            <field name="COMMENT">Falls die Var. auf 30 Sek. dann timeout auf 10 Sek.</field>
          </block>
        </next>
      </block>
      <block type="comment" id="?cC[Mlaf2uS3FQ*gp:jF" x="638" y="888">
        <field name="COMMENT">Falls der Sensor Regen meldet</field>
      </block>
      <block type="comment" id="7END()XIOq(@M~:0@=/~" x="638" y="1163">
        <field name="COMMENT">Falls sich die Meldung ändert ...</field>
      </block>
    </xml>
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @sushibomba bitte auch zusätzlich zum Code einen Screenshot reinsetzen - Code kann man nicht am Handy importieren ;)
    Lehrling seit 1975 !!!
    • Chris76eC Chris76e
      @sushibomba
      Kann es sein das da ein Fehler drin ist?
      Muss da nicht bei "Stop" timeout2 rein? Damit funktioniert es beim mir, mit Stop delay kommen die Meldungen ohne verzögerung an.
      Gonzokalle
      @chris76e
      Bei mir sieht es so aus, da wird am Anfang überprüft, ob es regnet, sonst kann es durcheinander kommen.
      Dank @paul53
      • DJMarc75D DJMarc75
        Sushibomba
        @djmarc75
        Ok sorry. Musste schnell gehen in dem Moment. Falls gewünscht stelle ich aber noch einen Screenshot ein :)
          @sushibomba
          Sushibomba
          @chris76e
          Ja du hast recht. Hat zwar auch so funktioniert die ganze Zeit aber richtig ist es mit dem Timeout.
          • G Gonzokalle
            @chris76e
            Dank @paul53
            accessburn
            @gonzokalle
            Zwar ist das schon älter, aber was ist denn "Input / Detach"?
            • G Offline
              Gonzokalle
              @accessburn
              Das ist der Eingang von einem Shelly 1, der auf true geht, wenn der Regensensor Regen erkennt.
              G 1 Antwort Letzte Antwort
              • G Gonzokalle
                @accessburn
                Gonzokalle
                @gonzokalle
                Sieht jetzt etwas anders aus.
                A 2 Antworten Letzte Antwort
                • G Gonzokalle
                  @gonzokalle
                  accessburn
                  @gonzokalle
                  Wärst du so lieb mir das zu exportieren?
                  Nachdem ich gestern 600 Telegramnachrichten bekommen habe ist mir die sache etwas zu doof geworden hahaha
                  • A accessburn
                    @gonzokalle
                    Gonzokalle
                    @accessburn
                    Da hat es aber viel geregnet bei euch. 😊
                      <variables>
                        <variable id="ODxvCYx}qY[p[9jsAhzT">es_ist_trocken</variable>
                        <variable id="hd#kKs8k^qI]2V25M6Ae">Nachricht</variable>
                        <variable type="timeout" id="delay_bis_trocken">delay_bis_trocken</variable>
                        <variable id="n!cC=1(RbCOt^R%Gf(/0">letzte_Nachricht</variable>
                      </variables>
                      <block type="comment" id="*!c.Sow7PxOKs$;_:bK}" x="-362" y="62">
                        <field name="COMMENT">Überprüfe Regensensor</field>
                        <next>
                          <block type="variables_set" id="?`yMl;F^2@8}G.15%M!y">
                            <field name="VAR" id="ODxvCYx}qY[p[9jsAhzT">es_ist_trocken</field>
                              <block type="logic_ternary" id="?1G=pLXLEaoyH$QRNnoR">
                                <value name="IF">
                                  <block type="get_value" id="^otDxS1wp1n,P#hbk6B(">
                                    <field name="OID">shelly.0.SHSW-1#4C752532AA51#1.Relay0.Input</field>
                                  </block>
                                </value>
                                <value name="THEN">
                                  <block type="logic_boolean" id="=06r_yipleAnPEN2_#;T">
                                  </block>
                                </value>
                                <value name="ELSE">
                                  <block type="logic_boolean" id="{:h|/cfcK.Kl`l(_.4$P">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="on_ext" id="rG[][A*.K0=!t];vZd?@">
                                <value name="OID0">
                                  <shadow type="field_oid" id="|/Pm%8pv2kIZO~focF%.">
                                    <field name="oid">shelly.0.SHSW-1#4C752532AA51#1.Relay0.Input</field>
                                  </shadow>
                                </value>
                                  <block type="controls_if" id="SbW-,0(h7a_hiczSO-:j">
                                    <value name="IF0">
                                      <block type="logic_negate" id="CqRSX^?zPf*iQ,S,vbRs">
                                        <value name="BOOL">
                                          <block type="on_source" id="n%pDUFxB@Vp$P7DfIBjh">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      <block type="timeouts_cleartimeout" id="Km`o:(%50uo28fht5{w!">
                                        <field name="NAME">delay_bis_trocken</field>
                                        <next>
                                          <block type="comment" id="6LqT}[k3wZ!z2.DF0EI-">
                                            <field name="COMMENT">Zeit bis es wieder trocken ist</field>
                                            <next>
                                              <block type="timeouts_settimeout" id="A{u/vt+sCFpW]QOau)#=">
                                                <field name="DELAY">15</field>
                                                <field name="UNIT">min</field>
                                                  <block type="variables_set" id="0Vv3(Kv$xTHsF|Q^cZd_">
                                                      <block type="logic_boolean" id="%v!J)Qdr^stU%3V7lxM-">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="update" id="G=amHyETm_k;}V/@@uOX">
                                                        <field name="OID">0_userdata.0.Wetter.Regensensor_Logikwert</field>
                                                          <block type="logic_boolean" id="i~E1!p=LD~HRt$rH!%aK">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="update" id="Rkt#~6)hCbcyLx^o*eEo">
                                                            <field name="OID">0_userdata.0.Wetter.Regensensor_Zeichenkette</field>
                                                              <block type="text" id="`08k!o5aX:ubxpq*8~(0">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                      <block type="timeouts_cleartimeout" id="/Oy6#Ac,+t~/1C?e}YXQ">
                                        <next>
                                          <block type="controls_if" id="0Om_vjd+ooJEAqcZ=sAl">
                                            <value name="IF0">
                                              <block type="variables_get" id="%;UkX[+uDe!Uz@:;tS?`">
                                              </block>
                                            </value>
                                              <block type="variables_set" id="fU.j:m-Q%?UPCa=h*eKH">
                                                  <block type="logic_boolean" id="fNaCxetV!6?54NbM}R]U">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="update" id="oy$#HPA?$BH0)(Q*zk8+">
                                                      <block type="logic_boolean" id="ikQ-^Uu`YUYif4j)rsh:">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="controls_if" id="aK5Ml]^HoGOrpKV^eu3.">
                                                        <value name="IF0">
                                                          <block type="logic_compare" id="DS*0sc]21]5[%O]-6APr">
                                                            <field name="OP">GT</field>
                                                            <value name="A">
                                                              <block type="get_value" id="czifB+mY[3C-{9Z#lxnH">
        <field name="OID">jeelink.0.LaCrosse_2.temp</field>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="2X#%uS[?a2Nsg:+b!#6d">
        <field name="NUM">2</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                          <block type="update" id="-o9xO;F(8?Mb*@ES[Ty-">
                                                              <block type="text" id="#6P4Fx6IVEb=6BT*J7O9">
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="comment" id="!IPzjY:,D-mfAU6reK5S">
        <field name="COMMENT">Meldung über Alexa nur am Tag</field>
        <next>
        <block type="controls_if" id="W5xY+eG6.(,KrjHh$m|5">
        <value name="IF0">
        <block type="logic_compare" id="zO@YIo1=y3*Q%N5hGa?a">
        <value name="A">
        <block type="get_value" id="-AUC1;q3FJQeVAfYjgn/">
        <field name="OID">0_userdata.0.Zeiten.Tageszeit</field>
        </block>
        </value>
        <value name="B">
        <block type="text" id="J$L!Fh5W^/R_1F{M+IgM">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="ruk,T?KNofER[Bhpx-bo">
        <field name="OID">alexa2.0.Echo-Devices.a12592da4dc64069926aa26ce626e6dc.Commands.speak</field>
        <block type="text" id="u?262)+1SigcQ+Gmi=n1">
        <field name="TEXT">30; Es fängt an zu regnen</field>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                          <block type="update" id="%`2:9wUxTRP1#opwDNgt">
                                                              <block type="text" id="kiBjreoy45Z92P?/Va0(">
        <field name="TEXT">Schnee</field>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="comment" id="KQ*0NYUB.iBV)bX-`||j">
        <next>
        <block type="controls_if" id="CMj}rky%4-F3.1@u,7_3">
        <value name="IF0">
        <block type="logic_compare" id="Hsn)7#~aysxU}ktCABZt">
        <value name="A">
        <block type="get_value" id=";ixl2YeU-;~6aXl~:awC">
        </block>
        </value>
        <value name="B">
        <block type="text" id="C{Oe9K5s7Ql*~Hc8-Zbt">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="UUmR$8a=q$NLnlTot^ah">
        <block type="text" id="JIXZ285Ws2_`@t_ET(WQ" collapsed="true">
        <field name="TEXT">30; Schneeflöckchen, Weißröckchen, Wann kommst du geschneit, Du wohnst in den Wolken, Dein Weg ist so weit</field>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                                <next>
                                  <block type="on_ext" id="$p0Z36LH%.LD+er?LJQd">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="w28naSLFcq6bb+(?MLw:">
                                        <field name="oid">0_userdata.0.Wetter.Regensensor_Zeichenkette</field>
                                      </shadow>
                                    </value>
                                      <block type="controls_if" id="F.`xjm:FSEEW5nve[;;0">
                                        <mutation elseif="2"></mutation>
                                        <value name="IF0">
                                          <block type="logic_compare" id="S(;QVSfD#2$6.{|4v6DX">
                                            <value name="A">
                                              <block type="get_value" id="m^Ge=cjhnX:j(E?JS1v^">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="text" id="3G|~L-f0k6c5S73)]aZY">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="variables_set" id="pI-S+?h{daGe-(/3S9=Q">
                                            <field name="VAR" id="hd#kKs8k^qI]2V25M6Ae">Nachricht</field>
                                              <block type="text" id="Vhb$d2!^W6@ec5-SRSDn">
                                                <field name="TEXT">⛅ Es ist trocken seit</field>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <value name="IF1">
                                          <block type="logic_compare" id="({YyVpB@ngnFWeZ~sT6=">
                                            <value name="A">
                                              <block type="get_value" id="|o*T6WS`Rn[@yYI,ysaa">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="text" id="#Fo=?J=;@]+7pN_F`V4z">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <statement name="DO1">
                                          <block type="variables_set" id="YxvYr!*cH;/8i=4@mi!a">
                                              <block type="text" id="Z~@09w.3)4J:Rd~b!qHG">
                                                <field name="TEXT">🌧️ Es regnet seit</field>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <value name="IF2">
                                          <block type="logic_compare" id="R_rH3,Tp].cX03Rfz-vt">
                                            <value name="A">
                                              <block type="get_value" id="hD0*L:21Z,fkx(R*;N3}">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="text" id="ht@nU4s*,+^t~pm`-o(H">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <statement name="DO2">
                                          <block type="variables_set" id="ENiFf;R3n%TEm~x*IU}s">
                                              <block type="text" id="B~{~N(F--KjcV!+=3*mX">
                                                <field name="TEXT">🌧️ Es schneit seit</field>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="controls_if" id="BVbq+RbB9a3qP;(;AZPz">
                                            <value name="IF0">
                                              <block type="logic_compare" id="R)A#gw=6ID;VQb5=AUR|">
                                                <value name="A">
                                                  <block type="variables_get" id="+q{BE6X^TcpcW$U~LRWA">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="variables_get" id="~5mfj,uSlFMTW+%}Y6@#">
                                                    <field name="VAR" id="n!cC=1(RbCOt^R%Gf(/0">letzte_Nachricht</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="variables_set" id=")wP:cOH%4L@Zt2|OCOQT">
                                                  <block type="variables_get" id="IH8Wag_=j+1~:i796=*-">
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                            <next>
                                              <block type="telegram" id="C}bV(5^/ne_|nXoL@I)=">
                                                  <shadow type="text" id="t;6i^#QC##l{aAL!Wj.0">
                                                  </shadow>
                                                  <block type="variables_get" id="(VI:mT#,5g@)MH,n/,W;">
                                                  </block>
                                                </value>
                                                <value name="CHATID">
                                                  <block type="text" id=";6Sk8MqJ?tvn_{%XM~[~">
                                                    <field name="TEXT">123456789</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </xml>
                    • G Gonzokalle
                      @accessburn
                        <variables>
                        </variables>
                          <next>
                                  <value name="IF">
                                    </block>
                                  </value>
                                  <value name="THEN">
                                    </block>
                                  </value>
                                  <value name="ELSE">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                  <value name="OID0">
                                    </shadow>
                                  </value>
                                      <value name="IF0">
                                          <value name="BOOL">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                          <next>
                                              <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </block>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                          <next>
                                              <value name="IF0">
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="IF0">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
        </block>
                                                              </value>
                                                              <next>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
        </block>
                                                              </value>
                                                              <next>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                  <next>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <value name="IF2">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </xml>
                      accessburn
                      schrieb am zuletzt editiert von accessburn
                      @gonzokalle Mega! Danke... ich versuch das mal an meine Zwecke anzupassen. Nee, ich hab nur bei Nebel oder zartem nieseln einen ständigen Wechsel zwischen true und false im DP und dann jedesmal einen Push bekommen :-D
                      • G Gonzokalle
                        @gonzokalle
                        accessburn
                        @gonzokalle "Es regnet seit". Fehlt da nicht etwas dahinter?
                        • A accessburn
                          Gonzokalle
                          @accessburn
                          Sollte eigentlich nicht sein.
                          Dafür sind die 15 Minuten Sperrzeit gedacht.
                          • A accessburn
                            Gonzokalle
                            @accessburn sagte in Regensensor Blockly vereinen:
                            Nö, ist so richtig.
                            In Telegram steht ja dann die Uhrzeit, wann die Meldung empfangen wurde. Das hat mir gereicht.
                            • G Gonzokalle
                              Nö, ist so richtig.
                              accessburn
                              @gonzokalle Achsooo :-)
