  4. Owntracks läuft nicht mehr richtig nach Fritzbox tausch
dyndnsfritzbox 7590owntracks adapter
65 Beiträge 3 Kommentatoren 10.2k Aufrufe
  • R rebel85
    Hier ein Auszug aus dem LOG
    2024-11-10 08:12:15.143 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:12:15.155 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:12:15.216 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 57118) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:12:15.218 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:16:53.380 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:16:53.586 E [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /10.129.245.245 (port 48218) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:17:03.621 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:17:03.635 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:17:03.689 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /10.129.245.245 (port 59780) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:17:03.691 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:17:13.713 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:17:13.717 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:17:13.766 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /10.129.245.245 (port 33126) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:17:13.766 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:17:33.780 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:17:33.793 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:17:33.937 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 53130) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:17:33.938 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:17:51.459 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:17:51.459 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:17:51.536 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:17:51.537 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:18:03.950 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:18:03.955 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:18:03.981 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 58718) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:18:03.982 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:18:44.055 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:18:44.070 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:18:44.175 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint because the connection was lost
    java.net.SocketException: No route to host
       at java.net.SocketInputStream.socketRead0(Native Method)
       at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
       at java.net.SocketInputStream.read(SocketInputStream.java:173)
       at java.net.SocketInputStream.read(SocketInputStream.java:143)
       at java.net.SocketInputStream.read(SocketInputStream.java:205)
       at java.io.DataInputStream.readByte(DataInputStream.java:273)
       at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(SourceFile:14)
       at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:88)
       at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
       at java.util.concurrent.FutureTask.run(FutureTask.java:264)
       at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:307)
       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
       at java.lang.Thread.run(Thread.java:1012)
    2024-11-10 08:18:44.176 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:19:34.215 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:19:34.239 I [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:19:34.286 E [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 37168) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:19:34.288 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:20:35.979 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:20:36.000 I [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:20:36.161 E [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 56482) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:20:36.165 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:21:50.049 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:21:50.061 I [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:21:50.134 E [DefaultDispatcher-worker-7] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint: failed to connect to mqttowntracks.ddns.net/92.116.121.27 (port 1884) from /192.168.178.21 (port 54264) after 30000ms: isConnected failed: EHOSTUNREACH (No route to host)
    2024-11-10 08:21:50.136 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-10 08:22:46.160 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:22:46.160 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:22:46.161 W [main] MapViewModel: no location available
    2024-11-10 08:22:46.220 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
    2024-11-10 08:22:46.228 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:22:46.228 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:22:49.516 W [main] MapViewModel: no location available
    2024-11-10 08:23:10.169 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:23:10.181 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:23:10.729 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-10 08:23:10.735 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-10 08:23:10.736 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
    2024-11-10 08:23:10.956 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=b8c122ac
    2024-11-10 08:23:10.958 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:23:10.959 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=48302f14
    2024-11-10 08:23:10.959 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:23:11.052 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
    2024-11-10 08:23:13.030 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:23:13.379 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-10 08:23:13.387 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-10 08:23:13.604 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=efee084e
    2024-11-10 08:23:13.614 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=5bf5e4bb
    2024-11-10 08:26:04.980 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:26:05.471 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-10 08:26:05.604 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-10 08:26:05.827 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=26b7bd1b
    2024-11-10 08:26:05.833 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=ef2f2971
    2024-11-10 08:57:23.737 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
    2024-11-10 08:57:47.952 E [main] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
    Zeitlimitüberschreitung beim Warten auf eine Antwort vom Server (32000)
       at kotlin.ranges.RangesKt.createMqttException(SourceFile:10)
       at org.eclipse.paho.client.mqttv3.internal.ClientState.checkForActivity(SourceFile:120)
       at org.owntracks.android.net.mqtt.MQTTPingAlarmReceiver.onReceive(SourceFile:53)
       at android.app.LoadedApk$ReceiverDispatcher$Args.lambda$getRunnable$0(LoadedApk.java:1842)
       at android.app.LoadedApk$ReceiverDispatcher$Args.$r8$lambda$gDuJqgxY6Zb-ifyeubKeivTLAwk(Unknown Source:0)
       at android.app.LoadedApk$ReceiverDispatcher$Args$$ExternalSyntheticLambda0.run(Unknown Source:2)
       at android.os.Handler.handleCallback(Handler.java:958)
       at android.os.Handler.dispatchMessage(Handler.java:99)
       at android.os.Looper.loopOnce(Looper.java:224)
       at android.os.Looper.loop(Looper.java:318)
       at android.app.ActivityThread.main(ActivityThread.java:8759)
       at java.lang.reflect.Method.invoke(Native Method)
       at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:561)
       at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1013)
    2024-11-10 08:57:57.894 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:57:57.965 I [DefaultDispatcher-worker-7] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-10 08:57:58.352 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-10 08:57:58.357 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-10 08:57:58.363 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
    2024-11-10 08:57:58.698 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-10 08:57:58.703 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-10 08:57:58.704 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
    2024-11-10 08:57:58.931 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=64a4ce57
    2024-11-10 08:57:58.932 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=7f8cfad7
    2024-11-10 08:58:02.511 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:58:02.511 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:58:02.570 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-10 08:58:02.570 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-10 08:58:04.350 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@cecf186]
    2024-11-10 08:58:04.352 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@cecf186] dispatched in 1.321458ms
    2024-11-10 08:58:04.382 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=8c71feaf
    2024-11-10 08:58:05.188 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@c813541]
    2024-11-10 08:58:05.189 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@c813541] dispatched in 463.698us
    2024-11-10 08:58:05.231 I [MQTT Call: iobrokermarco] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=a0be1f1c
    2024-11-10 08:58:06.641 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
    Ro75R Online
    Ro75R Online
    Ro75
    @rebel85 Port durchgereicht? Passphrase in der App eingetragen? Da das Problem erst nach Tausch der FB auftrat, kommt für mich nur eine Einstellung in FB in Frage. Und das wäre für mich der Port.
    Ro75.
    R Ro75R 2 Antworten Letzte Antwort
    • Ro75R Ro75
      Ro75.
      rebel85
      @ro75 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
      Ro75.
      so hab im log noch mal neu eingefügt, und aktuell,
      • Ro75R Ro75
        Ro75.
        Ro75R Online
        Ro75R Online
        Ro75
        @ro75
        Im Log
        Im Smartphone
        Die Ports. Kontrolliere diese.
        Ro75.
        R 1 Antwort Letzte Antwort
        • Ro75R Ro75
          @ro75
          Im Log
          Im Smartphone
          Ro75.
          rebel85
          @ro75 ja warte ich aktualisiere.... hab alles wieder auf no-ip gesetzt.
          Ro75R 1 Antwort Letzte Antwort
          • R rebel85
            Ro75R Online
            Ro75R Online
            Ro75
            @rebel85 bitte nicht die Posts bearbeiten. Da sieht man nicht was du änderst und man hat keine Lust alles neu zu lesen und nachzudenken was nun der Unterschied ist. Das ist nicht produktiv.
            Ro75.
            • Ro75R Ro75
              Ro75.
              rebel85
              @ro75 ich hatte es mit selfhost versucht und mit No-IP wie ich es vor dem Fritzbox Tausch hatte.
              habe nur den DYNDNS Anbieter gewechselt und die ips kontrolliert.
              bei dem log hatte ich einen falschen absatz kopiert und nicht den aktuellen.
              • R rebel85
                Ro75R Online
                Ro75R Online
                Ro75
                schrieb am zuletzt editiert von Ro75
                @rebel85 ändert aber nichts
                Port 1884 oder 1886? So klappt das nicht.
                Ro75.
                EDIT: Und wenn du den Dyndns Anbieter wechselst, musst du den auch überall anpassen.
                EDIT 2 : Was ist mit der Portweiterleitung in der FB?
                • R Offline
                  rebel85
                  Hier die Fritzbox Portfreigebe und der Verweis auf No-IP
                  das Ziel die IPv4 ist bei beiden gleich
                  • Ro75R Ro75
                    Ro75.
                    rebel85
                    @ro75
                    Port 1884 wie es vorm wechsel funktionierte,
                    Anbieter in der Owntracks App angepasst, und in der Fritzbox unter dyndns
                    • R rebel85
                      @ro75
                      Ro75R Online
                      Ro75R Online
                      Ro75
                      @rebel85 Und der Port in der App?
                      Ro75.
                      • Ro75R Ro75
                        Ro75.
                        rebel85
                        @ro75 Port 1884
                        muss ich in der fritzbox noch unter einem anderen menü punkt irgendwas anhaken das ich von außen wieder über dir Fritzbox auf den IoBroker komme?
                        iobroker läuft, wie vorher auch, als VM auf einem Proxmox System
                        • R rebel85
                          @ro75 Port 1884
                          Ro75R Online
                          Ro75R Online
                          Ro75
                          @rebel85 was ist mit dem Port 1884 in der App? ist das geklärt? Was ist mit der Portweiterleitung 1884 in der FB an das Proxmox Zeug?
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            rebel85
                            @ro75 in der APP ist der Port 1884Screenshot_2024-11-10-09-02-35-361_org.owntracks.android.jpg
                            ist schon zu dem Zeitpunkt gewesen wie es im log steht.
                            das ist doch der screenshot, die VM hat ihre eigene IP und die hat auch wie vorher wieder die Port Freigabe 1884 bekommen mit der selben IP wie bei No-IP.
                            • R Offline
                              rebel85
                              ich hab mir noch mal die Anleitung von no-IP angeschaut und das dort wie beschrieben angepasst. 9:40
                              https://www.noip.com/support/knowledgebase/configuring-ddns-fritzbox
                              Auf dem Handy will er sich nun Verbinden und kommt nicht weiter , oder muss ich die fritze noch mal neu starten?
                              Screenshot_2024-11-10-09-44-22-942_org.owntracks.android.jpg Screenshot_2024-11-10-09-44-14-412_org.owntracks.android.jpg
                              Ro75R R 2 Antworten Letzte Antwort
                              • R rebel85
                                Ro75R Online
                                Ro75R Online
                                Ro75
                                @rebel85 nutzt du den seaparaten MQTT oder den internen MQTT?
                                Ro75.
                                • Ro75R Ro75
                                  Ro75.
                                  rebel85
                                  @ro75
                                  ich nutze den Adapter im iobroker und der lief die letzten Jahre problemlos, auch nach einem Handy wechsel. Einfach die Config gespeichert, neugeladen auf dem Handy und alles war schön.
                                  nur nicht bei dem FGritzboxwechsel.
                                  Anfangs hatte ich auch Probleme (vor 4 Jahren) das zum laufen zu bekommen, habe auch schon in meinen gespeicherten Daten geschaut aber nichts gefunden.
                                  • R rebel85
                                    Ro75R Online
                                    Ro75R Online
                                    Ro75
                                    @rebel85 was ist mit der Passphrase?
                                    Ro75.
                                    • R rebel85
                                      rebel85
                                      @rebel85 Config fehler....
                                      nun hat er sich verbunden, in der APP muss ja der NO-IP Web Host stehen und in der Fritze die Log in daten für den WEB Host.
                                      komme aber immer noch nicht weiter,
                                      Berreiche mal Verlassen?
                                      Fritzbox noch mal Neustarten? in dieser Woche bestimmt schon 15 mal passiert inkl. Zwangstrennung.
                                      Port Weiterleitung sollte doch so richtig sein mit TCP oder?
                                      • Ro75R Ro75
                                        Ro75.
                                        Ro75R Online
                                        Ro75R Online
                                        Ro75
                                        Ro75.
                                        Was ist damit?
                                        Ro75.
                                        • Ro75R Ro75
                                          Ro75.
                                          rebel85
                                          @ro75 die ist wie im Adapter 1zu1 Identisch
                                          habe den mal neu eingegeben im Adapter und APP
