  4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
adapteremmahuaweiinverterluna2000modbus tcpmodbus-proxysdonglesmartloggersun2000
1.3k Beiträge 97 Kommentatoren 490.1k Aufrufe 87 Beobachtet
  • B bolliy
    @leonundjulie
    {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3695,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":3653,"getMultipleHoldingRegisters-address_32064-value_2-unidId_1":6028,"getMultipleHoldingRegisters-address_37113-value_2-unidId_1":6028,"getMultipleHoldingRegisters-address_38233-value_3-unidId_1":3653,"getMultipleHoldingRegisters-address_38275-value_3-unidId_1":3653,"getMultipleHoldingRegisters-address_38229-value_13-unidId_1":894,"getMultipleHoldingRegisters-address_38271-value_13-unidId_1":893,"getMultipleHoldingRegisters-address_37000-value_23-unidId_1":893,"getMultipleHoldingRegisters-address_37046-value_4-unidId_1":893,"getMultipleHoldingRegisters-address_47081-value_18-unidId_1":893,"getMultipleHoldingRegisters-address_32000-value_11-unidId_1":892,"getMultipleHoldingRegisters-address_32016-value_4-unidId_1":1774,"getMultipleHoldingRegisters-address_32089-value_1-unidId_1":893,"getMultipleHoldingRegisters-address_32066-value_50-unidId_1":892,"getMultipleHoldingRegisters-address_37100-value_38-unidId_1":1773,"getMultipleHoldingRegisters-address_37758-value_30-unidId_1":892,"getMultipleHoldingRegisters-address_47415-value_4-unidId_1":892,"getMultipleHoldingRegisters-address_37411-value_1-unidId_100":894,"getMultipleHoldingRegisters-address_37498-value_20-unidId_100":1773,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37001-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37107-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37109-value_2-unidId_1":2375,"#getMultipleHoldingRegisters-address_37068-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37004-value_1-unidId_1":2375,"getMultipleHoldingRegisters-address_37111-value_2-unidId_1":2375,"getMultipleHoldingRegisters-address_37121-value_2-unidId_1":2375}}
    Im Protokoll den letzten Eintrag vom Modbus tcp server in die Zwischenablage kopieren und hier posten.
    leonundjulie
    #590
    @bolliy hoffe, dass das richtig ist:
    2024-11-02 22:38:47.897 - info: sun2000.0 (57957) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":9069,"#getInputRegister-address_37760-value_1-unidId_1":9069,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":4512,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":4512,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4510,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4510}}
    2024-11-02 22:39:07.663 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 (force=false, process=true)
    2024-11-02 22:39:07.672 - info: sun2000.0 (57957) Got terminate signal TERMINATE_YOURSELF
    2024-11-02 22:39:07.675 - info: sun2000.0 (57957) cleaned everything up...
    2024-11-02 22:39:07.680 - info: sun2000.0 (57957) terminating
    2024-11-02 22:39:07.682 - info: sun2000.0 (57957) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-11-02 22:39:07.684 - info: sun2000.0 (57957) Modbus-proxy closed
    2024-11-02 22:39:07.875 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
    2024-11-02 22:39:08.184 - info: sun2000.0 (57957) terminating
    2024-11-02 22:39:08.331 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-02 22:39:12.159 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.15.1" started with pid 3698113
    2024-11-02 22:39:15.993 - info: sun2000.0 (3698113) starting. Version 0.15.1 in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
    2024-11-02 22:39:16.359 - info: sun2000.0 (3698113) Modbus-proxy listening on modbus://0.0.0.0:502
    2024-11-02 22:39:16.368 - info: sun2000.0 (3698113) Modbus-proxy initialized
    2024-11-02 22:39:16.517 - info: sun2000.0 (3698113) Open Connection...
    2024-11-02 22:39:21.523 - info: sun2000.0 (3698113) Connected Modbus TCP to 192.168.178.129:502
    2024-11-02 22:39:22.127 - info: sun2000.0 (3698113) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
    2024-11-02 22:39:22.289 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 (force=false, process=true)
    2024-11-02 22:39:22.294 - info: sun2000.0 (3698113) Got terminate signal TERMINATE_YOURSELF
    2024-11-02 22:39:22.296 - info: sun2000.0 (3698113) cleaned everything up...
    2024-11-02 22:39:22.300 - info: sun2000.0 (3698113) terminating
    2024-11-02 22:39:22.304 - info: sun2000.0 (3698113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-11-02 22:39:22.305 - info: sun2000.0 (3698113) Modbus-proxy closed
    2024-11-02 22:39:22.524 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
    2024-11-02 22:39:22.807 - info: sun2000.0 (3698113) terminating
    2024-11-02 22:39:22.962 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-02 22:39:26.687 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.15.1" started with pid 3698407
    2024-11-02 22:39:31.315 - info: sun2000.0 (3698407) starting. Version 0.15.1 in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
    2024-11-02 22:39:31.724 - info: sun2000.0 (3698407) Modbus-proxy listening on modbus://0.0.0.0:502
    2024-11-02 22:39:31.732 - info: sun2000.0 (3698407) Modbus-proxy initialized
    2024-11-02 22:39:31.873 - info: sun2000.0 (3698407) Open Connection...
    2024-11-02 22:39:36.880 - info: sun2000.0 (3698407) Connected Modbus TCP to 192.168.178.129:502
    2024-11-02 22:39:37.520 - info: sun2000.0 (3698407) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
    2024-11-02 22:39:38.219 - info: sun2000.0 (3698407) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 2
    2024-11-02 22:41:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":6,"#getInputRegister-address_37760-value_1-unidId_1":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":1,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":1}}
    2024-11-02 22:42:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":9,"#getInputRegister-address_37760-value_1-unidId_1":9,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":3}}
    2024-11-02 22:42:55.169 - warn: ebus.0 (2954287) no update since 2.11.2024, 12:35:27 broadcast.messages.error.lastup
    2024-11-02 22:42:55.225 - warn: ebus.0 (2954287) no update since 24.10.2024, 14:24:52 broadcast.messages.signoflife.lastup
    2024-11-02 22:42:55.529 - info: ebus.0 (2954287) installed ebusd version is 23.3
    2024-11-02 22:42:55.647 - info: ebus.0 (2954287) all http done
    2024-11-02 22:43:31.723 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":12,"#getInputRegister-address_37760-value_1-unidId_1":12,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4}}
    2024-11-02 22:44:31.718 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":15,"#getInputRegister-address_37760-value_1-unidId_1":15,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":6,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":6,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":6}}
    2024-11-02 22:45:15.306 - info: admin.0 (2952665) <== Disconnect system.user.admin from ::ffff:192.168.178.88 admin
    2024-11-02 22:45:23.163 - info: admin.0 (2952665) ==> Connected system.user.admin from ::ffff:192.168.178.88
    2024-11-02 22:45:31.719 - info: sun2000.0 (3698407) Modbus tcp server: {"stat":{"#getMultipleInputRegisters-address_37765-value_2-unidId_1":18,"#getInputRegister-address_37760-value_1-unidId_1":18,"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":8,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":8,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":7,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":7}}
    2024-11-02 22:45:40.053 - info: host.raspberrypi instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3705914
    2024-11-02 22:45:44.183 - info: daswetter.0 (3705914) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.4, js-controller: 6.0.11
    Raspi mit IOB für PV-Steuerung & Home Entertainment & Wtterzentrale
    B 2 Antworten Letzte Antwort
    • L leonundjulie
      bolliy
      #591
      @leonundjulie ich sehe nun was das Problem ist. smartfox liest die Registerdaten auch über die inputRegister-Abfrage. Das Verhalten ist zwar ok, aber ungewöhnlich.
      Ich werde den Adapter anpassen und mich wieder melden. Dann kannst du testen ;)
      LG Stephan
      • L leonundjulie
        bolliy
        #592
        @leonundjulie ich hoffe, dass es nun mit dem smartfox und dem modbus-proxy funktioniert - bitte testen und Rückmeldung geben.
        Die Installation erfolgt über den Expertenmodus. Danach auf die „Krakenkatze“ klicken, dann "von github" den Adapter "sun2000" auswählen und die Installation starten.
        Danach muss der Adapter ggf. einmal neu gestartet werden!
        Falls weiter Probleme auftauchen - nur das JSON hinter Modbus tcp server: posten. Sonst platzt hier das Forum noch. ;)
        LG Stephan
        L 1 Antwort Letzte Antwort
        • B bolliy
          LG Stephan
          leonundjulie
          #593
          @bolliy danke Stephan.
          In welcher Version hast Du es angepasst?
          Weil ich an der Stelle noch keine Erfahrungen gemacht habe: wie kann ich Deine Bitte zum JSON umsetzen?
          Gruß Andreas
          • L leonundjulie
            Gruß Andreas
            bolliy
            #594
            @leonundjulie in der letzten. (V0.16.0)
            Das Projekt wird auf github (Versionsverwaltung) gehostet. https://github.com/bolliy/ioBroker.sun2000
            Dort kannst du meine Änderungen verfolgen.
            Bitte so installieren wie ich es beschrieben habe. Es ist noch keine eigene Version. Eine neue Version erfolgt erst wenn es keine Fehler mehr von dir festgestellt werden...
            Das JSON ist ein Format um Daten und deren Struktur abzubilden. Kannst du bei Wikipedia nachlesen.
            Im Protokoll die Stelle mit dem JSON in die Zwischenablage kopieren und hier posten.
            Stephan
            • B bolliy
              Stephan
              leonundjulie
              #595
              @bolliy Guten Morgen Stephan.
              Die Sonne ist aufgegangen und ich habe die neue Version eingepflanzt.
              Das Ergebnis:
              2024-11-04 07:48:36.012 - info: sun2000.0 (1896556) terminating
              2024-11-04 07:48:36.014 - info: sun2000.0 (1896556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-11-04 07:48:36.016 - info: sun2000.0 (1896556) Modbus-proxy closed
              2024-11-04 07:48:36.220 - info: host.raspberrypi stopInstance system.adapter.sun2000.0 send kill signal
              2024-11-04 07:48:36.517 - info: sun2000.0 (1896556) terminating
              2024-11-04 07:48:36.661 - info: host.raspberrypi instance system.adapter.sun2000.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-11-04 07:48:40.544 - info: host.raspberrypi instance system.adapter.sun2000.0 in version "0.16.0" (non-npm: bolliy/ioBroker.sun2000) started with pid 1897241
              2024-11-04 07:48:45.602 - info: sun2000.0 (1897241) starting. Version 0.16.0 (non-npm: bolliy/ioBroker.sun2000) in /opt/iobroker/node_modules/iobroker.sun2000, node: v18.20.4, js-controller: 6.0.11
              2024-11-04 07:48:46.047 - info: sun2000.0 (1897241) Modbus-proxy listening on modbus://0.0.0.0:502
              2024-11-04 07:48:46.059 - info: sun2000.0 (1897241) Modbus-proxy initialized
              2024-11-04 07:48:46.189 - info: sun2000.0 (1897241) Open Connection...
              2024-11-04 07:48:51.198 - info: sun2000.0 (1897241) Connected Modbus TCP to 192.168.178.129:502
              2024-11-04 07:48:53.108 - info: sun2000.0 (1897241) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 1
              2024-11-04 07:48:54.518 - info: sun2000.0 (1897241) Identified a Huawei SUN2000-6KTL-M1 model 427 for modbus ID 2
              2024-11-04 07:50:46.036 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":2,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":3,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":1,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":1}}
              2024-11-04 07:51:46.035 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":3,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":6,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":6,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":3,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":3}}
              2024-11-04 07:52:46.035 - info: sun2000.0 (1897241) Modbus tcp server: {"stat":{"getMultipleHoldingRegisters-address_32080-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_32106-value_2-unidId_2":5,"getMultipleHoldingRegisters-address_37765-value_2-unidId_1":9,"getMultipleHoldingRegisters-address_37760-value_1-unidId_1":9,"getMultipleHoldingRegisters-address_32080-value_2-unidId_1":4,"getMultipleHoldingRegisters-address_32106-value_2-unidId_1":4}}
              Und im SMARTFOX werden weiterhin weder LEISTUNG noch SOC angezeigt.
              • L leonundjulie
                Das Ergebnis:
                bolliy
                schrieb am zuletzt editiert von bolliy
                #596
                @leonundjulie im Log wird vom modbus-proxy kein Fehler angezeigt. Das Screenshot zeigt aber doch Werte - nur kein SOC?!
                Was am Morgen im Winter durchaus normal ist.
                Der Screenshot ist doch vom smartfox - oder nicht?
                Stephan
                L M 2 Antworten Letzte Antwort
                • B bolliy
                  Stephan
                  leonundjulie
                  #597
                  @bolliy Hallo Stephan.
                  Meine LUNA2000 ist so eingestellt, dass sie bei 5% abschaltet.
                  Hier drei Fotos - die ich vor einer Minute machte:
                  • Die Werte der Batterie in Fusion Solar
                  • Die Werte der Batterie im iOBroker
                  • Die Werte der Batterie im SMARTFOX
                  FusionSolar und IOBroker passen ungefähr zusammen (das Delta erklärt sich sicherlich aus dem Delay, welches sich aus der Datenübertragung in die Cloud und zurück ergibt. Und der SMARTFOX zeigt halt gar nichts zur Batterie.
                  Da stimmt doch etwas nicht … aber was?
                  Also habe ich iOBroker den HUAWEI Adapter deaktiviert und den SMARTFOX direkt auf die IP des SDONGLES gelegt … dann müsste der SMARTFOX ja eigentlich alles richtig anzeigen - tut er aber nicht. Die Batterie zeigt weiterhin nichts und die von der Batterie abgegebene Leistung wird im SMARTTFOX als PRODUKTION angezeigt. Damit werde ich erstmal die Hotline des SMARTFOX konfrontireren.
                  • B bolliy
                    Stephan
                    mhuber
                    #598
                    Hallo zusammen, ich bekomme vom Adapter laufen folgende Meldungen:
                    "Not all data can be read! Please inspect the sun2000 log."
                    Welches Log muss ich da wo auslesen und auf was muss ich achten?
                    B T 2 Antworten Letzte Antwort
                    • L leonundjulie
                      bolliy
                      #599
                      @leonundjulie vielleicht sind falsche Register hinterlegt:
                      Hier findest du Definitionen
                      https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/definitions.md
                      LG Stephan
                      • M mhuber
                        bolliy
                        #600
                        @mhuber die Logs findest unter im ioBroker unter Protokolle! Auf den sun2000 abgrenzen und die Fehler hier posten.
                        Das Video ist zwar etwas älter, aber vielleicht dennoch hilfreich:
                        https://www.youtube.com/watch?v=-1PCHancttc
                        Stephan
                        B M 2 Antworten Letzte Antwort
                        • M mhuber
                          Thofri
                          #601
                          @mhuber Was auf jeden Fall sichergestellt sein muss, ist die aktuelle Firmware
                          beim Dongle. Seit dem neusten Update (PC121) habe ich keine Warnungen mehr und alle Daten werden
                          ausgelesen. Vielleicht hilft das auch bei dir? 👍
                          • B bolliy
                            Stephan
                            bolliy
                            #602
                            @bolliy dann bitte für alle Geräteeinheiten einen Firmwareupdate machen!
                            M L 2 Antworten Letzte Antwort
                            • B bolliy
                              mhuber
                              #603
                              @leonundjulie kann ich das selbst beeinflussen? Hab nichts geändert....
                              • T Thofri
                                mhuber
                                #604
                                @thofri ist drauf, halte immer alles aktuell
                                • B bolliy
                                  Stephan
                                  mhuber
                                  schrieb am zuletzt editiert von mhuber
                                  #605
                                  @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                                  Stephan
                                  @bolliy ah eh einfach Adapter auf Debug stellen, dachte es ist ein anderes Log (ev direkt vom WR) gemeint.
                                  So sieht das Debug log aus, immer wenn der Fehler kommt
                                  sun2000.0
                                  2024-11-05 06:43:40.803	debug	Fetched inverter.0.activePower, val=-0.069
                                  sun2000.0
                                  2024-11-05 06:43:40.706	debug	Try to read data from id/address 1/38229/low/battery Pack1 information
                                  sun2000.0
                                  2024-11-05 06:43:39.739	debug	Try to read data from id/address 1/38317/high/Battery Pack3 Charge And Discharge Power
                                  sun2000.0
                                  2024-11-05 06:43:37.244	debug	Try to read data from id/address 1/38275/high/Battery Pack2 Charge And Discharge Power
                                  sun2000.0
                                  2024-11-05 06:43:35.659	debug	Try to read data from id/address 1/38233/high/Battery Pack1 Charge And Discharge Power
                                  sun2000.0
                                  2024-11-05 06:43:34.772	debug	Try to read data from id/address 1/37113/high/meter activePower
                                  sun2000.0
                                  2024-11-05 06:43:32.804	debug	Try to read data from id/address 1/32064/high/Input Power
                                  sun2000.0
                                  2024-11-05 06:43:32.372	warn	Not all data can be read! Please inspect the sun2000 log.
                                  sun2000.0
                                  2024-11-05 06:43:32.372	debug	{"timeout":10000,"delay":0,"connectDelay":5000,"modbusAdjust":false,"min":0,"max":6000,"stat":{"successSumCounter":73,"errorSumCounter":0},"adjust":{"successLevel":0,"successCounter":3,"errorCounter":0,"lastLength":2,"SuccessDelay":0,"ErrorDelay":0}}
                                  sun2000.0
                                  2024-11-05 06:43:32.371	debug	### Watchdog: time since last update 2.368 sec
                                  Aja zur Info: Further battery register data hab ich beide schon ein und ausgeschalten, bringt aber nichts.
                                  • M mhuber
                                    Stephan
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    sun2000.0
                                    bolliy
                                    #606
                                    @mhuber die Fehlermeldung besagt, dass nicht alle Daten gelesen werden können. Das Log des Adapters auf info einstellen oder das Protokoll auf info filtern, damit ich auch die errors und warn sehen kannst. Das Log bitte dann hier posten.
                                    Denn im Log müssten Fehler oder weitere Warnmeldung aufgetaucht sein und die sind für uns interessant und entscheidend für eine Diagnose ;)
                                    Das Debug Log ist für eine Ersteinschätzung hinderlich, da zuviele Einträge im Log erscheinen.
                                    Übrigens: DIe Batteriedaten unit und Pack können anscheinend vom Adapter ohne Fehlermeldung gelesen werden. Es müsste ein anderes Problem vorliegen.
                                    • B bolliy
                                      mhuber
                                      #607
                                      Also bei mir kommt da nichts ausser:
                                      sun2000.0
                                      2024-11-05 08:59:20.982	warn	Not all data can be read! Please inspect the sun2000 log.
                                      sun2000.0
                                      2024-11-05 08:53:20.974	warn	Not all data can be read! Please inspect the sun2000 log.
                                      sun2000.0
                                      2024-11-05 08:52:20.973	warn	Not all data can be read! Please inspect the sun2000 log.
                                      Adapter auf Info gestellt und im Protokoll kommt nur das, oder muss ich wo anders noch schaun?
                                      • M mhuber
                                        sun2000.0
                                        sun2000.0
                                        sun2000.0
                                        bolliy
                                        #608
                                        @mhuber dann zeig mal deine allg. Einstellungen als Screenshot.
                                        • B bolliy
                                          mhuber
                                          #609
