  4. Hargassner Anbindung ModBus läuft nicht
hargassner modbus
99 Beiträge 7 Kommentatoren 8.6k Aufrufe 2 Beobachtet
  • F FloK
    @homoran Schaut schon besser aus. Instanz bleibt grün aber bekomme noch keine Werte. Auch der Datenpunkt erscheint bei Objekten nicht mehr.
    Hier das LOG:
    modbus.0
    2024-10-25 09:23:02.545	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2024-10-25 09:22:57.473	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2024-10-25 09:22:52.410	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2024-10-25 09:22:52.409	info	Connected to slave 192.168.178.41
    modbus.0
    2024-10-25 09:22:52.331	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
    modbus.0
    2024-10-25 09:22:52.322	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatle","len":2,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2024-10-25 09:22:52.322	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatle","len":2,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2024-10-25 09:22:52.322	error	Invalid data holdingRegisters/0: {"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatle","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
    modbus.0
    2024-10-25 09:22:52.322	debug	Initialize Objects for holdingRegs: [{"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatle","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
    modbus.0
    2024-10-25 09:22:52.322	debug	Initialize Objects for inputRegs: []
    modbus.0
    2024-10-25 09:22:52.322	debug	Initialize Objects for coils: []
    modbus.0
    2024-10-25 09:22:52.322	debug	Initialize Objects for disInputs: []
    modbus.0
    2024-10-25 09:22:52.321	error	Invalid holdingRegisters address: -39714
    modbus.0
    2024-10-25 09:22:52.261	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
    modbus.0
    2024-10-25 09:22:52.126	debug	Plugin sentry Initialize Plugin (enabled=true)
    @flok sagte in Hargassner Anbindung ModBus läuft nicht:
    mit welcher Einstellung?
    F 1 Antwort Letzte Antwort
    • F FloK
      Hier das LOG:
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      modbus.0
      W Offline
      W Offline
      warp735
      @flok
      Sieht nach falschem Daten Typ aus
      • W warp735
        @flok
        FloK
        @warp735 Beschreibung sagt Float. So ist es auch hinterlegt
          FloK
          • F FloK
            @flok ....und im Register??
              FloK
              • F FloK
                @flok und was steht im log mit 287 und ohne Aias verwenden?
                  FloK
                  @homoran Hier das LOG mit den gerade gezeigten Einstellungen:
                  modbus.0
                  2024-10-25 09:29:28.833	debug	[DevID_1] Poll start ---------------------
                  modbus.0
                  2024-10-25 09:29:23.761	debug	[DevID_1] Poll start ---------------------
                  modbus.0
                  2024-10-25 09:29:23.761	info	Connected to slave 192.168.178.41
                  modbus.0
                  2024-10-25 09:29:23.692	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                  modbus.0
                  2024-10-25 09:29:23.684	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                  modbus.0
                  2024-10-25 09:29:23.684	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                  modbus.0
                  2024-10-25 09:29:23.684	error	Invalid data holdingRegisters/0: {"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
                  modbus.0
                  2024-10-25 09:29:23.684	debug	Initialize Objects for holdingRegs: [{"_address":287,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
                  modbus.0
                  2024-10-25 09:29:23.684	debug	Initialize Objects for inputRegs: []
                  modbus.0
                  2024-10-25 09:29:23.684	debug	Initialize Objects for coils: []
                  modbus.0
                  2024-10-25 09:29:23.683	debug	Initialize Objects for disInputs: []
                  modbus.0
                  2024-10-25 09:29:23.682	error	Invalid holdingRegisters address: -39714
                  modbus.0
                  2024-10-25 09:29:23.615	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                  modbus.0
                  2024-10-25 09:29:23.486	debug	Plugin sentry Initialize Plugin (enabled=true)
                  Hier das LOG ohne Alias:
                  modbus.0
                  2024-10-25 09:42:29.140	debug	[DevID_1] Poll start ---------------------
                  modbus.0
                  2024-10-25 09:42:24.078	debug	[DevID_1] Poll start ---------------------
                  modbus.0
                  2024-10-25 09:42:24.078	info	Connected to slave 192.168.178.41
                  modbus.0
                  2024-10-25 09:42:23.969	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                  modbus.0
                  2024-10-25 09:42:23.961	debug	Add undefined: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                  modbus.0
                  2024-10-25 09:42:23.961	error	Invalid object: {"type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":-39714,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                  modbus.0
                  2024-10-25 09:42:23.961	error	Invalid data holdingRegisters/0: {"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714,"fullId":"modbus.0.0"}
                  modbus.0
                  2024-10-25 09:42:23.961	debug	Initialize Objects for holdingRegs: [{"_address":-39714,"deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":-39714}]
                  modbus.0
                  2024-10-25 09:42:23.961	debug	Initialize Objects for inputRegs: []
                  modbus.0
                  2024-10-25 09:42:23.961	debug	Initialize Objects for coils: []
                  modbus.0
                  2024-10-25 09:42:23.960	debug	Initialize Objects for disInputs: []
                  modbus.0
                  2024-10-25 09:42:23.960	error	Invalid holdingRegisters address: -39714
                  modbus.0
                  2024-10-25 09:42:23.900	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                  modbus.0
                  2024-10-25 09:42:23.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                  • F FloK
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    ohne Alias:
                    immer noch?
                    _address":-39714
                    da ist was faul
                    • F FloK
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      da haben wir den undefined!
                      und
                      da stimmt irgendwas gar nicht
                      F HomoranH 2 Antworten Letzte Antwort
                        und
                        FloK
                        @homoran Gerade gesehen, die Holding Adresse hatte sich geändert als ich Alias entfernt hatte. Hier das log mit ohne Alias aber wieder mit Adresse 287:
                        modbus.0
                        2024-10-25 09:49:10.759	info	Disconnected from slave 192.168.178.41
                        modbus.0
                        2024-10-25 09:49:10.759	debug	Closing client on purpose.
                        modbus.0
                        2024-10-25 09:49:09.757	debug	Cleaning up request fifo.
                        modbus.0
                        2024-10-25 09:49:09.757	debug	Clearing timeout of the current request.
                        modbus.0
                        2024-10-25 09:49:09.756	debug	Socket closed with error
                        modbus.0
                        2024-10-25 09:49:09.755	warn	[DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                        modbus.0
                        2024-10-25 09:49:09.754	error	Client in error state.
                        modbus.0
                        2024-10-25 09:49:09.753	error	Request timed out.
                        modbus.0
                        2024-10-25 09:49:09.753	warn	Error: undefined
                        modbus.0
                        2024-10-25 09:49:04.749	debug	[DevID_1/holdingRegs] Poll address 287 - 2 registers
                        modbus.0
                        2024-10-25 09:49:04.749	debug	Initialization of scale factors done!
                        modbus.0
                        2024-10-25 09:49:04.749	debug	[DevID_1] Poll start ---------------------
                        modbus.0
                        2024-10-25 09:49:04.748	info	Connected to slave 192.168.178.41
                        modbus.0
                        2024-10-25 09:49:04.644	debug	Add holdingRegisters.1.287_Pufferfüllgrad: {"_id":"holdingRegisters.1.287_Pufferfüllgrad","type":"state","common":{"name":"Füllgrad des Puffers","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":287,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true}}
                        modbus.0
                        2024-10-25 09:49:04.643	debug	Initialize Objects for holdingRegs: [{"_address":"287","deviceId":1,"name":"Pufferfüllgrad","description":"Füllgrad des Puffers","unit":"%","type":"floatsw","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"enum.rooms.enum_5","poll":true,"wp":"","cw":"","isScale":"","address":287,"id":"holdingRegisters.1.287_Pufferfüllgrad"}]
                        modbus.0
                        2024-10-25 09:49:04.643	debug	Initialize Objects for inputRegs: []
                        modbus.0
                        2024-10-25 09:49:04.643	debug	Initialize Objects for coils: []
                        modbus.0
                        2024-10-25 09:49:04.643	debug	Initialize Objects for disInputs: []
                        modbus.0
                        2024-10-25 09:49:04.583	info	starting. Version 6.3.2 in C:/iobroker/KieserHome/node_modules/iobroker.modbus, node: v18.20.4, js-controller: 6.0.11
                        modbus.0
                        2024-10-25 09:49:04.450	debug	Plugin sentry Initialize Plugin (enabled=true)
                        • F FloK
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          modbus.0
                          Das ist ja Sinn der Sache!
                          ich wollte sehen mit welchem Offset das passiert (40000 oder 40001)
                            und
                            @homoran sagte in Hargassner Anbindung ModBus läuft nicht:
                            Was ist jetzt damit?
                            welche ID hast du?
                              welche ID hast du?
                              FloK
                              @homoran Geräte ID habe ich 1 eingestellt. Slave ID steht auch auf 1
                              • F FloK
                                @flok Liest du auch die Meldungen?
                                Da steht
                                und welche ID hat das Gerät?
                                Lass dir doch nicht alles aus der Nase ziehen!
                                  Da steht
                                  FloK
                                  @homoran Sorry, bin kein Profi. Verstehe ich nicht. Was meins damit?
                                  • F FloK
                                    ich auch nicht!
                                    Verstehe ich nicht.
                                    was?
                                    solche Halbsätze nutzen niemandem.
                                    Was meins damit?
                                    womit?
                                    Dein Gerät hat eine ID
                                    welche ist das?
                                      ich auch nicht!
                                      Verstehe ich nicht.
                                      was?
                                      Was meins damit?
                                      womit?
                                      welche ist das?
                                      FloK
                                      @homoran Welches Gerät meinst du denn? Den Heizkessel? Wo finde ich die ID? Kenne nur die IP Adresse davon.
                                      • F FloK
                                        wenn es das ist was du abfragst, ja!
                                        keine Ahnung.
                                        müsste bei der Modbuskarte in der Anleitung stehen.
                                          keine Ahnung.
                                          FloK
                                          @homoran Es geht um die Kommunikation mit einem Hargassner nano PK15 Heizkessel. Es gibt keine Modbus-Hardware dazu. Es wurde lediglich eine SD Karte gesteckt, was den Kessel dann Modbus-fähig macht. Daher wüsste ich nicht, wie oder wo man die ID nachschauen kann.
                                          Wie sieht so eine ID aus? Hast du ein Beispiel?
