  4. Test Dreame Home Mova Adapter
    6.7k
275 Beiträge 48 Kommentatoren 83.5k Aufrufe 53 Beobachtet
  • P Offline
    peterp
    #107
    Nur mal um sicher zu gehen das wir hier nicht irgendwelche versions problemen haben:
    L 1 Antwort Letzte Antwort
    • P peterp
      Lachi
      schrieb am zuletzt editiert von Lachi
      #108
      Hier mein Server✌️, läuft unter proxmox.
      • L Offline
        Lachi
        #109
        Moin hab folgendes im Log stehen, jetzt meine Frage kann ich das irgendwie ändern oder kann das nur der Adapter-Entwickler?
        dreame.1	2024-10-18 17:45:30.653	info	State value to set for "dreame.1.xxxxxxxxxx.status.filter-left-time" has to be type "string" but received type "number"
        dreame.1	2024-10-18 17:45:30.653	info	State value to set for "dreame.1.xxxxxxxxxx.status.filter-life-level" has to be type "string" but received type "number"
        dreame.1	2024-10-18 17:45:30.652	info	State value to set for "dreame.1.xxxxxxxxxx.status.brush-life-level" has to be type "string" but received type "number"
        dreame.1	2024-10-18 17:45:30.652	info	State value to set for "dreame.1.xxxxxxxxxx.status.brush-left-time" has to be type "string" but received type "number"
        dreame.1	2024-10-18 17:45:30.652	info	State value to set for "dreame.1.xxxxxxxxxx.status.charging-state" has to be type "string" but received type "number"
        dreame.1	2024-10-18 17:45:30.652	info	State value to set for "dreame.1.xxxxxxxxxx.status.battery-level" has to be type "string" but received type "number"
        • L Offline
          Lachi
          #110
          Moin
          getestet mit Dreame X40 Ultra Complete (dreame.vacuum.r2449a)
          Status Meldungen:
          Fett markiert = bestätigt und getestet!
          "1": "Saugen"
          "2": "Leerlauf"
          "3": "Pause"
          "4": "Störung"
          "5": "Zurück zum Aufladen"
          "6": "Laden"
          "7": "Wischen"
          "8": "Mopp Trocknen"
          "9": "Mopp-Reinigung"
          "10": "Rückkehr zum Reinigen"
          "11": "Building"
          "12": "Beim Reinigen"
          "13": "Laden beendet"
          "14": "Upgrading"
          "15": "Summon"
          "16": "Self Repairing"
          "17": "Back Install Mop"
          "18": "Back Remove Mopp"
          "20": "Wischmopp reinigen und Wasser nachfüllen"
          "22": "Automatische Entleerung starten (Staubbehälter)"
          "25": "Die zweite Reinigung wird durchgeführt"
          "27": "Teilweise Reinigung (Spotclean-Taste)"
          "97": "ShortCut läuft gerade"
          Status Meldungen wurden aus der App entnommen.
          Objecte im Iobroker Edit: 20.10.2024 15:30
          map.cs = dreame.1.837116818.status.cleaning-area = Gereingte Fläche in m²
          status.27-1 = 0=Reinwassertank In Ordnung/1=Reinwassertank nicht Installiert/2=Reinwassertank eingesetzt aber Leer
          status.27-2 = 0=Schmutzwassertank In Ordnung/1=Schmutzwassertank nicht Installiert/Max. Wasserstand
          status.4-58 = Mopp 9=eingefahren/17=ausgefahren
          status.4-63 = geschaffte Reinigung in %
          status.4-64 = Aktueller Ladezyklus geladen in %
          status.mop-status = 0=Standby/1=Reinigung (Status 9)/2=Mopp Trocknen (Status 8)/5=Wasser nachfüllen (Status 20)
            Max_yeah
            #111
            bei mir zeigt Adapter für manche Variablen nur noch Json Elemente an.
            Am ersten Tag nach der Initialisierung waren die Werte noch normal, doch jetzt sind sie so:
            Hier zwei Beispiele:
              "did": "760736103",
              "siid": 3,
              "piid": 1,
              "value": 98
            Ich besitze den Dreame L10S Pro Ultra Heat (oder so)
            H 1 Antwort Letzte Antwort
            • M Max_yeah
                "did": "760736103",
                "siid": 3,
                "piid": 1,
                "value": 98
              Heinz2100
              #112
              @max_yeah Ist bei mir auch so. Ich hab einstweilen neue Datenpunkte angelegt und Greife mir per Blockly den Wert nach "value" sofern es im Text vorkommt.
              • H Heinz2100
                Max_yeah
                #113
                @heinz2100 ah danke, ja ist wahrscheinlich besser, so kann ich auch die einheit besser festlegen. Gilt das dann für alle Werte?
                Ändern die sich bei der nächsten Aktualisierung?
                • M Max_yeah
                  Max_yeah
                  #114
                  @max_yeah heißt aber auch das ich jetzt für alle Werte die ich möchte datenpunkte anlegen muss um sie zu parsen?
                  • wawyoW wawyo
                    @sunny9999 Der Ordner „Map“ wird erst erstellt, wenn der Roboter einen Bereich säubert, da die Daten direkt von ihm abgerufen werden; bitte nicht vergessen, beim ersten Mal die Daten manuell zu aktualisieren, das Update, den Restart und die Start Clean Objekte auf true zu setzen.
                    dezebruarD Offline
                    dezebruarD Offline
                    dezebruar
                    #115
                    @wawyo Hi, erstmal vielen Dank für diesen Adapter 👍 Ich bekomm es nicht hin das der MAP Ordner erstellt wird... Die Datenpunkte die man vorher auf "true" setzen soll find ich leider auch nicht. 😕
                    • H Offline
                      hahne
                      #116
                      Hat irgendwer einen Datenpunkte mit der Restzeit (oder Restmenge in %) des Reinigungsmittel's?
                      Den einzigen State den ich finde, ist der wo angegeben wird ob Waschmittel genutzt werden soll oder nicht.
                      Eine Restmenge oder ein State zum zurücksetzen des Waschmittels wenn man neues eingesetzt hat finde ich nicht.
                      • M Max_yeah
                        Heinz2100
                        #117
                        @max_yeah Ganau. Ich hab so um die 10 Stück gebraucht
                        • H hahne
                          Max_yeah
                          #118
                          @hahne glaube nicht das es dafür eine % Anzeige gibt. Vermute (zumindest beim l10... Heat) das er nur erkennt wenn die pumpe leer läuft. Also nur "voll(nicht leer) " und "leer" anzeigen kann. Sehe auch in der App keine Anzeige wie viel Reinigungsmittel noch da ist, was er ja wie ich denke auch nicht wissen kann weil in dem behälter keine füllanzeige ist. Wie auch beim wassertank. Denke das er da auch nur anhand des Wasserdrucks oder einer anderen Technik erkennt das der Tank fast leer ist.
                          M H 2 Antworten Letzte Antwort
                          • H Heinz2100
                            Max_yeah
                            #119
                            @heinz2100 ok danke, hast du zufällig eine seite die erklärt wie man das json umwandelt?
                            • M Max_yeah
                              Max_yeah
                              schrieb am zuletzt editiert von Max_yeah
                              #120
                              @hahne die % oder Stunden Rest wert anzeigen der sensoren, bürsten etc sind ja auch nur theoretischer Natur und über die Nutzungszeit ermittelt. Wie verschmutzt oder abgenutzt die wirklich sind weiß Roboter auch nicht. Man könnte durch Studien (ausprobieren) herausfinden wie lange ein voller Tank Reinigungsmittel hält und dann anhand der Betriebsdauer errechnen wie viel noch im Tank drin sin müsste. Jedoch kann sich das dann je Reinungsmittel (Viskosität) oder Reinungsprogramm unterscheiden.
                              -1
                              • M Max_yeah
                                hahne
                                #121
                                @max_yeah
                                Ich habe in der App eine Anzeige für die % des Waschmittels.
                                Unter "Restzeit " ganz unten.
                                Natürlich kann er nicht genau wissen wieviel noch drinnen ist aber irgendwie errechnet er sich das ja. Genau wie bei den anderen Sachen (Seitenbürste, Filter etc.) bei denen hat man ja auch eine Prozent Anzeige.
                                Wasser und Abwassertank erkennt er durch die Schwimmer wann voll.
                                M Dietmar KuepperD 2 Antworten Letzte Antwort
                                • M Max_yeah
                                  hahne
                                  #122
                                  • H hahne
                                    @max_yeah
                                    Max_yeah
                                    #123
                                    @hahne ah ok sorry für die Verwirrung. Meiner hat die Anzeige nicht. Er meldet sich auch nur wenn er ganz leer ist. Hat deine Station einen nachfüllbaren Tank oder nutzt er diese Kartuschen die man einsetzt? Bei der Variante mit den Kartuschen kann ich mir vorstellen das er es errechnen kann, man setzt ja immer eine neue volle ein und er kennt die Menge die drin sein sollte.
                                    • M Max_yeah
                                      hahne
                                      #124
                                      @max_yeah ja, aber dazu müsste man wissen Wie viele qm von den Vereinigten qm gewischt wurde . Und selbst dann Wird ja manchmal mit unterschiedlichen Wassemengen pro Raum gewischt.
                                      Ich dachte weil es in der App steht kann man es auch im Adapter abbilden. Ich habe diese Kartuschen, diese fülle ich aber mit der Original Flüssigkeit auf.
                                      • H hahne
                                        Max_yeah
                                        #125
                                        @hahne ja klar, wenn es in der App steht würde ich auch davon ausgehen das es theoretisch im Adapter möglich ist.
                                        • M Max_yeah
                                          Heinz2100
                                          #126
                                          Ja ist aber ganz einfach. Erstelle einen Zieldatenpunkt vom Typ Zahl.
                                          Bei Änderung des Quelldatenpunktes Dreame wird nachgeschaut, ob der Text "did" vorkommt (= Datenpunkt liegt als JSON vor). Wenn nicht, dann nimmt er direkt den Wert und sonst nimmt er den Wert hinter dem letzten Doppelpunkt.
