  3. Off Topic
  4. Grafana
  5. Grafana - Stromzähler nachbauen
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
36 Beiträge 5 Kommentatoren 5.2k Aufrufe 6 Beobachtet
    @humidor
    Hier das json zum importieren, da sind dann auch alle Formatierungen und overrides mit drin:
     "datasource": {
       "type": "influxdb",
       "uid": "000000001"
     "description": "",
     "fieldConfig": {
       "defaults": {
         "custom": {
           "lineWidth": 1,
           "fillOpacity": 80,
           "gradientMode": "none",
           "axisPlacement": "auto",
           "axisLabel": "",
           "axisColorMode": "text",
           "axisBorderShow": false,
           "scaleDistribution": {
             "type": "linear"
           "axisCenteredZero": false,
           "hideFrom": {
             "tooltip": false,
             "viz": false,
             "legend": false
           "thresholdsStyle": {
             "mode": "off"
         "color": {
           "mode": "fixed",
           "fixedColor": "red"
         "mappings": [],
         "thresholds": {
           "mode": "absolute",
           "steps": [
               "color": "green",
               "value": null
               "color": "red",
               "value": 80
         "links": [],
         "min": 0,
         "unit": "kwatth"
       "overrides": [
           "matcher": {
             "id": "byName",
             "options": "Time"
           "properties": [
               "id": "unit",
               "value": "time: D dd"
     "gridPos": {
       "h": 7,
       "w": 12,
       "x": 12,
       "y": 27
     "hideTimeOverride": true,
     "id": 98,
     "interval": "1d",
     "options": {
       "orientation": "auto",
       "xTickLabelRotation": -90,
       "xTickLabelSpacing": 0,
       "showValue": "always",
       "stacking": "none",
       "groupWidth": 0.7,
       "barWidth": 0.7,
       "barRadius": 0,
       "fullHighlight": false,
       "tooltip": {
         "mode": "single",
         "sort": "none"
       "legend": {
         "showLegend": false,
         "displayMode": "list",
         "placement": "bottom",
         "calcs": []
     "pluginVersion": "8.5.1",
     "targets": [
         "datasource": {
           "type": "influxdb",
           "uid": "000000001"
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "measurement": "0_userdata.0.Energie.PV.Netzbezug",
         "orderByTime": "ASC",
         "policy": "default",
         "query": "import \"timezone\"\r\noption location = timezone.location(name: \"Europe/Berlin\")\r\n\r\nfrom(bucket: \"iobroker\")\r\n  |> range(start: -1mo, stop: v.timeRangeStop)\r\n  |> filter(fn: (r) => r[\"_measurement\"] == \"smartmeter.0.1-0:1_8_0__255.value\" and r[\"_field\"] == \"value\")\r\n  |> difference()\r\n  |> aggregateWindow(every: 1d, fn: sum, timeSrc: \"_start\")",
         "refId": "A",
         "resultFormat": "time_series",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "max"
         "tags": []
         "alias": "Direct self-use",
         "datasource": {
           "type": "influxdb",
           "uid": "000000001"
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "hide": false,
         "measurement": "kWh",
         "refId": "B",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "max"
         "tags": [
             "key": "entity_id",
             "operator": "=",
             "value": "selfuse_energy_daily"
     "timeFrom": "1h",
     "title": "Tagesbezug (Monat)",
     "type": "barchart"
    Hier influx
    import "timezone"
    option location = timezone.location(name: "Europe/Berlin")
    from(bucket: "iobroker")
      |> filter(fn: (r) => r["_measurement"] == "smartmeter.0.1-0:1_8_0__255.value" and r["_field"] == "value")
      |> difference()
      |> aggregateWindow(every: 1d, fn: sum, timeSrc: "_start")
    HumidorH Offline
    HumidorH Offline
    Humidor
    @meister-mopper sagte in Grafana - Stromzähler nachbauen:
    |> difference() |> aggregateWindow(every: 1d, fn: sum, timeSrc: "_start")
    OK, das kapier ich noch nicht
    woher stammt der "Spoiler"? iobroker oder grafana?
    wenn ich deine Influx Text (geändert auf meine Werte) eingebe, kommt mal nix
    BG
    • HumidorH Humidor
      Meister MopperM Online
      Meister Mopper
      schrieb am zuletzt editiert von Meister Mopper
      @humidor sagte in Grafana - Stromzähler nachbauen:
      Das ist das json des dashboard von Grafana und kann in Grafana eingelesen werden.
      Proxmox und HA ...
      HumidorH 1 Antwort Letzte Antwort
        HumidorH Offline
        HumidorH Offline
        Humidor
        schrieb am zuletzt editiert von Humidor
        @meister-mopper etwas weiter bin ich gekommen, habe dein dashboard eingelesen, darin ein panel geöffnet mit das query eingetragen
        (ist das richtig ein Panel zu öffnen, das ist auf std. Einstellungen)
        nun sehe ich diese Information
        BG
        • Meister MopperM Online
          Meister Mopper
          Schau mal hier.
          Damit habe ich es hinbekommen.
          Proxmox und HA ...
            Schau mal hier.
            HumidorH Offline
            HumidorH Offline
            Humidor
            @meister-mopper super, danke, habs soweit kapiert
            jetzt habe ich ein Problem mit den Daten
            Alias - aus einem Mqtt Wert wird der aktuelle Wert (Leistung) entnommen
            Alias - aus einem Mqtt Wert nur der Neg. Wert
            Alias - aus einem Mqtt Wert nur der Pos. Wert
            alle werden in die Influx eingetragen
            wenn ich mir im ioBroker den Verlauf ansehe, sehe ich die jeweiligen Werte zBsp. bezogen auf 1 Tag
            im Grafana mit der Summen Funktion, kommt dann irgendwas raus, auch Minuswerte??
            BG
            • HumidorH Humidor
              Meister Mopper
              Tatsächlich kann ich nicht nachvollziehen, was du hier sagen möchtest. Meinst mit negativen Werten die Einspeisung?
              Ich rechne alle Negativdaten in positive Werte um. Mit diesen Daten arbeite ich in Grafana,
              Proxmox und HA ...
                HumidorH Offline
                HumidorH Offline
                Humidor
                @meister-mopper mache ich genauso, dh die neg. Werte werden in pos. Werte umgerechnet, es geht mir um die Summen wieviel Bezug bzw. Lieferung stattgefunden hat.
                Aus pos. Werte wird im Grafana ein Minuswert erzeugt, völliger quatsch. Aber wo liegt der Fehler?
                du siehst am Graph vom ioBroker die pos. Werte, da müsste im Grafana dann die Summe berechnet werden. Soweit klar, raus kommt aber unsinnige Werte und auch Minus.
                BG
                • HumidorH Humidor
                  Meister Mopper
                  Okay, das sind zwei verschiedene Ausgangslagen und ein Missverständnis.
                  Ich visualisiere bei dem täglichen Verbrauch im letzten Monat sowohl für den Tagesbezug als auch den Tagesverbrauch anwachsende Datenpunkte (Stromzähler und selbst berechneter Verbrauchszähler).
                  Proxmox und HA ...
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    @meister-mopper hmm
                    das ist dann das -1mo, wie sage ich ihm von 0:00 - 23:59? also 1 Tag?
                    und das summiert wird, ist aber
                    difference()
                    fn: sum oder nicht?
                    welche Rolle spielt das difference?
                    BG
                    • HumidorH Humidor
                      @meister-mopper hmm
                      difference()
                      fn: sum oder nicht?
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      hätte ev. jemand die richtigen Settings um die den Wert im Grafana zu summieren?
                      BG
                      mickemupM 1 Antwort Letzte Antwort
                      • HumidorH Humidor
                        mickemupM Offline
                        mickemupM Offline
                        mickemup
                        @humidor
                        Habe da einiges bei mir gemacht um solche Sachen darzustellen.
                        Um dir helfen zu können, muss man aber wissen wie (und wie oft du dir Rohdaten loggst.)
                        Sind es Leistungen oder Zählerstände?
                        Wenn du Leistungen aufsummieren willst, kommt es darauf an, wie oft du die loggst
                        difference()
                        Das hier macht nur Sinn, wenn du "Zählerstände loggst....
                        • mickemupM mickemup
                          @humidor
                          difference()
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          @mickemup danke dir!
                          das sind Werte die per Mqtt einlese
                          mW ist Mqtt Event gesteuert, dh keine fixe Abfragezeit, der Timestamp könnte da eine Auskunft geben
                          BG
                          • HumidorH Humidor
                            mickemupM Offline
                            mickemupM Offline
                            mickemup
                            schrieb am zuletzt editiert von mickemup
                            @humidor
                            OK das heisst es sind Leistungswerte?
                            Um Energie zu erhalten, muss man das Integrieren.
                            Das kann man "grob" im Grafana machen.
                            Die saubere Lösung wurde aber schon hier beschrieben.
                            @lesiflo hat das im Post von 13.Okt als Blockly aufgezeigt...
                            Kannst du sagen wie oft die Werte in Influx geloggt werden und loggst du nur Veränderungen oder jeden mqtt Wert?
                            evtl Printscrren?
                              @humidor
                              evtl Printscrren?
                              HumidorH Offline
                              HumidorH Offline
                              Humidor
                              @mickemup Ja, momentane Leistungswerte
                              das ist was ich aus dem System per Mqtt raus bekomme:
                              die Werte kommen jede Sekunde
                              gibt zwar auch die Möglichkeit per Modbus direkt auf den Zähler zu gehen, aber die Register scheinen nicht zu stimmen, da kommen oft utopische Werte rüber.
                              BG
                              mickemupM 2 Antworten Letzte Antwort
                              • HumidorH Humidor
                                mickemupM Offline
                                mickemupM Offline
                                mickemup
                                @humidor
                                Ok probier mal das:
                                import "date"
                                import "timezone"
                                option location = timezone.location(name: "Europe/Madrid")
                                from(bucket: "iobroker_YOURBUCKET")
                                  |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
                                  |> filter(fn: (r) => r["_measurement"] == "YOURdatapoint")
                                  |> filter(fn: (r) => r["_field"] == "value")
                                    |> aggregateWindow(every: 1m, fn: mean, timeSrc: "_start")
                                |> aggregateWindow(every: 1h, fn: mean, timeSrc: "_start")
                                aja und kommen die Daten immer oder nur bei Veränderung
                                und loggst du immer oder nur bei Veränderung?
                                  @humidor
                                  Ok probier mal das:
                                  import "date"
                                  import "timezone"
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  @mickemup standard Einstellung von influxdb
                                  BG
                                  HumidorH mickemupM 2 Antworten Letzte Antwort
                                  • HumidorH Humidor
                                    HumidorH Offline
                                    HumidorH Offline
                                    Humidor
                                    hab mal diesen Wert genommen: Power (ist ein Plus/Minus Wert)
                                    das wird aber wenig Sinn machen, verm. muss ich getrennt für Plus und Minus Werte hier loggen.
                                    Bildschirmfoto 2024-11-29 um 07.21.26.png Bildschirmfoto 2024-11-29 um 07.23.46.png
                                    BG
                                    • HumidorH Humidor
                                      mickemupM Offline
                                      mickemupM Offline
                                      mickemup
                                      @humidor
                                      Du hast ja gesagt, dass du Dps für Einspeisung und Bezug separat hast.
                                      Diese müsstest du natürlich auch so loggen.
                                      Falls du denn generellen loggst, hast du Einfach eine Netto Bilanz...hast du überhaupt ein PV Anlage?
                                      Aber die die 12 KW (Ich nehme an Bezug) machen wohl schon Sinn, wenn man mit deinem INFLUX Plot vergleicht :-)
                                      Hast du erst Daten von heute gesammelt?
                                      Falls nicht, musst du mal die Tiemrange in deinem Panel erhöhen
                                      Schreib mal beim zweiten "Printscreen" unter Query Options:
                                      Relative time now/M
                                      Time shift 0M/M
                                      Und nimm mal Barchart
                                      Sobald du mit dem ersten Plot zufrieden bist, kann man anschliessend noch die Wochen/Jahressummaries erstellen.
                                      Dies ist dann nur noch ein kleiner Schritt
                                      • HumidorH Humidor
                                        mickemupM Offline
                                        mickemupM Offline
                                        mickemup
                                        @humidor
                                        OK das passt 👍
                                        Wenn die Datenpunkte regelmässig beschrieben werden, wie du ja gesagt hast, dann stimmt auch die "Pseudointegrierung" in Grafana :-)
                                        • HumidorH Humidor
                                          mickemupM Offline
                                          mickemupM Offline
                                          mickemup
                                          @humidor Sry für die vielen Fragen, aber hier hättest du ja unter Energy: Forward einen Datenpunkt, welche die Energie liefert...
                                          Wird der jeden Tag genullt oder erhöht der sich kontinuirlich?
