  4. Test Adapter onvif camera v1.x.x
    6.7k
341 Beiträge 48 Kommentatoren 125.8k Aufrufe 49 Beobachtet
  • T tombox
    @ewc Bekommst du noch ein Fehler ? Bitte mit log
    ewc
    #309
    @tombox
    Fehlermeldungen nicht direkt, aber noch ziemlich viel traffic
    2024-07-29 18:40:13.220 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.VideoSource/MotionAlarm:{"val":"VINToken0","ack":true,"ts":1722271213218,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213218}
    2024-07-29 18:40:13.223 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
    /onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_Rule:{"val":"MDRule0","ack":true,"ts":1722271213222,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646262}
    2024-07-29 18:40:13.223 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_VideoSourceConfigurationToken:{"val":"VINToken0_0","ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646238}
    /onvif.0.192_168_178_153_80.events.VideoSource/MotionAlarm:{"val":"VINToken0","ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213223}
    2024-07-29 18:40:13.224 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.RuleEngine/CellMotionDetector/Motion:{"val":false,"ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646148}
    2024-07-29 18:40:13.226 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
    /onvif.0.192_168_178_150_80.events.RuleEngine/CellMotionDetector/Motion_VideoAnalyticsConfigurationToken:{"val":"VANToken0","ack":true,"ts":1722271213225,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646111}
    2024-07-29 18:40:13.226 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.VideoSource/MotionAlarm:{"val":false,"ack":true,"ts":1722271213226,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213226}
    2024-07-29 18:40:13.227 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
    /onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion:{"val":false,"ack":true,"ts":1722271213226,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646288}
    2024-07-29 18:40:13.229 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_VideoAnalyticsConfigurationToken:{"val":"VANToken0","ack":true,"ts":1722271213228,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646247}
    /onvif.0.192_168_178_153_80.events.VideoSource/MotionAlarm:{"val":false,"ack":true,"ts":1722271213228,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213228}
    Ich glaube, ich schmeiße die beiden Kameras doch noch in die Tonne, bevor Du deinen Adapter vergewaltigen musst
    • E ewc
      @tombox
      tombox
      #310
      @ewc Problem ist also behoben sehr gut
      Du solltest das log level auf info setzen und nicht auf silly
      E 1 Antwort Letzte Antwort
      • T tombox
        ewc
        #311
        @tombox said in Test Adapter onvif camera v1.x.x:
        @ewc
        ist schon erledigt... war ja nur für den Wunsch nach einem Log
        Hab Dank
        • C Offline
          c3b
          #312
          Hi Leutz
          Ich hänge mich mal hier dran. Ich habe schon gesucht, aber nichts gefunden.
          Ich habe eine Reolink E1 Outdoor am Kabel hängen. Alle erkannten Alarme werden auf meinen FTP-Server geschickt. Jedes Mal ein Bild und ein Video.
          Im iobroker habe ich sie mit dem onfiv-Adapter eingefügt.
          Wenn ich jetzt von Hand einen snapshot auslöse, erstellt er keinen Datenpunkt mit der URL in dem Ordner Remote. Wenn ich die URL aus dem Info-Ordner eingebe, zeigt er mir den snapshot an. Will aber immer einen Benutzer und ein Kennwort.
          Mein Ziel ist es, das Bild, welches er zum FTP-Server schickt per Telegramm auf mein Handy zu schicken.
          Jetzt habe ich hier gelesen, dass es mit dem Reolink-Adapter gehen soll. So habe ich das zumindest verstanden.
          Also installiert und eingerichtet. V 1.1.1. Funktioniert auch. Adapter ist grün, objekte sind angelegt.
          Aber wie geht es jetzt weiter? Ich sehe keinen snapshot bzw. eine URL.
          Kann mir da jemand weiterhelfen? Ich lese schon die ganze Zeit auf github, werde aber nicht richtig schlau daraus.
          LG aus dem Sauerland
          Jörg
          • XBiTX Online
            XBiTX Online
            XBiT
            #313
            @c3b
            Kann dir leider nicht direkt helfen da ich selbst keine Reolink Kamera habe.
            Wollte dir nur den Tipp geben da es ja bei deiner Frage mehr um den Reolink-Adapter geht, diese eventuell besser hier zu stellen.
            Da kann dir sicher schneller jemand helfen.
            • C c3b
              Hi Leutz
              Jörg
              bommel_030
              #314
              @c3b
              Der Reolink-Adapter erstellt meines Wissens keine Snapshots, aber das ist mit nem Blockly doch leicht erledigt.
              Trigger nebst Konditionen anpassen und ggf. Telegram verfeinern. Funktioniert mit hier ner E1 Outdoor PoE problemlos.
               <block type="on_ext" id="I6{E8q1TwHTCti=gNWYU" x="-712" y="-62">
                 <value name="OID0">
                   <shadow type="field_oid" id="0[4DFJ{$Y#II4lwDBR-4">
                     <field name="oid">alias.0.Zimmer.EG.Flur.Fenster</field>
                   </shadow>
                   <block type="field_oid" id="r^#Z/B^0ok0t.GgT~gcg">
                     <field name="oid">ID auswählen</field>
                   </block>
                 </value>
                 <statement name="STATEMENT">
                   <block type="exec" id="7y|0nSY]!//y,4P70]W)">
                     <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                     <field name="WITH_STATEMENT">TRUE</field>
                     <field name="LOG"></field>
                     <value name="COMMAND">
                       <shadow type="text" id="QL]`;3dY(Vl[w27L]E$h">
                         <field name="TEXT">wget -O /opt/iobroker/Eingang.jpg "http://192.168.10.95/cgi-bin/api.cgi?cmd=Snap&amp;channel=0&amp;rs=wuuPhkmUCeI9WG7C&amp;user=userename&amp;password=passwort"</field>
                       </shadow>
                     </value>
                       <block type="telegram" id="{(|fFOBclDO+P+3R:83*">
                         <field name="INSTANCE">.0</field>
                         <field name="ESCAPING">FALSE</field>
                         <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                         <value name="MESSAGE">
                           <shadow type="text" id="ycSmBrHt+l+k=pv/Sn~k">
                             <field name="TEXT">/opt/iobroker/Eingang.jpg</field>
                           </shadow>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
              </xml>
              • C Offline
                c3b
                #315
                @ XBiT
                Danke für die Info. Ich versuche mal da mein Glück.
                @ bommel_030
                Danke für das Blockly. So ganz schnalle ich das noch nicht. Mit exec habe ich noch gar nichts gemacht. Sollte die Objekt ID eine Bewegungserkennung sein? Der Pfad im Telegramm weist auf ein Unterverzeichnis im iobroker hin. Wie bekommst du da die Bilder hin? Ich tippe mal darauf, das der wget-Befehl das Bild dort hin kopiert.
                Kannst du mir noch ein paar mehr Infos geben?
                Jörg
                • L Offline
                  lemmymania
                  schrieb am zuletzt editiert von lemmymania
                  #316
                  @tombox
                  Hallo, ich und zwar habe ich eine "SV3C - C13" und eine von "X-Serie" kamera welche auch über die IP erkannt wird im ONVIF Adapter.
                  Aber mit folgender meldung (zumindest bei der SV3C):
                  danach sieht man unter Objekte folgendes:
                  klicke ich auf "snapshot" wird auch ein neues Foto erzeugt. Aber unter dem Pfad "Event" kann ich leider keine einträge erkennen.
                  Mache ich etwas falsch weil unter Events nicht erscheint ? Oder werden diese kameras dann nicht vom Adapter unterstüzt ?
                  D matze55M 2 Antworten Letzte Antwort
                  • L lemmymania
                    @tombox
                    denjo
                    #317
                    Hallo, ich habe mir Kameras von IMOU geholt und bin eigentlich recht zufrieden damit. ich habe sie über go2rtc in meine vis eingebunden, nur leider wenn sich mein internet neu verbindet um ca 3 Uhr morgens läuft es auf meiner vis nicht. sobald ich die kameras in der app neu starte läuft es wieder. deswegen würde ich sie gerne über onvif neustarten lassen. leider klappt das nicht mit dem adapter, aber mit dem Windows Programm ODM-Onvif klappt das. könnte man die Funktion in den Adapter einbringen????
                    • L lemmymania
                      @tombox
                      matze55M Offline
                      matze55M Offline
                      matze55
                      schrieb am zuletzt editiert von matze55
                      #318
                      @lemmymania möchtest du nur die Bilder angezeigt haben? Du musst in der Vis das widget ,,string img src,, auswählen. Dann unter den Objekten die ID ==>>onvif.0.192_168_178_**_****.snapshot auswählen da der Adapter onvif es verschlüsselt in base64.
                      Der Datenpunkt zeigt doch an. Es wird aber immer nur ein Bild gespeichert, danch wird es überschrieben bei einem neuen Bild.
                      lg
                      Homematic CCU3,-Synology NAS 4TB,- 2 Sonos One,- Gigabyte N4500 8GB DDR4 2TB
                      Tapo C210 Cam
                      WLED Steuerung über lcdwiki
                      • E Offline
                        exitus
                        schrieb am zuletzt editiert von exitus
                        #319
                        @tombox Hallo
                        habe annke nc 800 kameras habe die onvif ports und username passwort richtig eingegeben aber er findet die kameras nicht kann jemand mir helfen ???
                        Data: null xml: undefined
                        onvif.0
                        2025-05-21 12:42:02.017	info	Error Error: connect EHOSTUNREACH 192.168.0.53:80
                        onvif.0
                        2025-05-21 12:42:02.015	error	Failed to login to 192.168.0.53:80 with admin:*********
                        onvif.0
                        2025-05-21 12:41:58.944	info	Data: null xml: undefined
                        onvif.0
                        2025-05-21 12:41:58.943	info	Error Error: socket hang up
                        onvif.0
                        2025-05-21 12:41:58.942	error	Failed to login to 192.168.0.52:443 with admin:*********
                        onvif.0
                        2025-05-21 12:41:58.935	info	Data: null xml: undefined
                        onvif.0
                        2025-05-21 12:41:58.934	info	Error Error: read ECONNRESET
                        onvif.0
                        2025-05-21 12:41:58.934	error	Failed to login to 192.168.0.52:8000 with admin:E*********1
                        onvif.0
                        2025-05-21 12:41:58.926	info	Data: null xml: <!DOCTYPE html> <html><head><title>Document Error: Not Found</title></head> <body><h2>Access Error: 404 -- Not Found</h2> <p>Request Refuse: ONVIF integrate function is disabled.</p> </body> </html>
                        onvif.0
                        2025-05-21 12:41:58.921	info	Error Error: Wrong ONVIF SOAP response
                        onvif.0
                        2025-05-21 12:41:58.921	error	Failed to login to 192.168.0.52:80 with admin:*****
                        wendy2702W T 2 Antworten Letzte Antwort
                        • E exitus
                          @tombox Hallo
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          onvif.0
                          wendy2702W Online
                          wendy2702W Online
                          #320
                          @exitus sagte in Test Adapter onvif camera v1.x.x:
                          annke nc 800
                          Laut Google Onvif Port 8080, sehe ich in deinem Log nicht. Hast du den eingestellt?
                          Screenshot Adapter config
                          • E exitus
                            @tombox Hallo
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            onvif.0
                            tombox
                            #321
                            @exitus Port 8000 sagt: " ONVIF integrate function is disabled"
                            • T tombox
                              exitus
                              #322
                              @tombox also die Onvif port ist aktiv der Recorder verbindet sich auch ich schaue mal genauer hin. Die port sind 8000
                              • E exitus
                                tombox
                                #323
                                @exitus Teste mal mit ODM
                                https://sourceforge.net/projects/onvifdm/files/latest/download
                                E 2 Antworten Letzte Antwort
                                • T tombox
                                  exitus
                                  #324
                                  @tombox danke erstmal ich habe ein neuen user angelegt und jetzt klappt es.
                                  Wie kann ich jetzt zu telegramm bilder schicken????
                                  • E exitus
                                    wendy2702W Online
                                    wendy2702W Online
                                    #325
                                    @exitus in dem du die Forensuche benutzt.
                                    Es gibt gefühlt 1000 Beiträge dazu.
                                    • T tombox
                                      exitus
                                      #326
                                      @tombox so Verbindung habe ich die Datenpunkte sind auch da , habe eine Frage die NC800 sind sehr gut bei der Personen Erkennung , ich habe kein, Datenpunkt gesehen der bei dieser Event auslöst . Original bekommt Alarm aber es gibt kein Datenpunkt für diese Erkennung . Es gib nur Motiondection der bei alles Alarm gibt.
                                      Die Frage ist dieser Option mit programmiert oder muss ich an der Kamera was anderes einstellen einstellen ?? ich möchte gerne den Datenpunkt haben, der bei Personen ausgibt.
                                      • E exitus
                                        wendy2702W Online
                                        wendy2702W Online
                                        #327
                                        @exitus Habe nur Reolink,
                                        da gibt es "events". Hast du die nicht?
                                        • wendy2702W wendy2702
                                          exitus
                                          #328
                                          @wendy2702 doch habe ich , aber es aktualisiert sich bei jede bewegung welche ist nur auf person ?
                                          onvif.0.192_168_0_51_80.events.RuleEngine/FieldDetector/ObjectsInside
                                          hier passiert nichts
