  4. Amazon Dash Buton
Amazon Dash Buton
13 Beiträge 6 Kommentatoren 1.7k Aufrufe
  • I Offline
    I Offline
    igabbert
    ich bekomme den Dash Adapter nicht installiert.
    Hat jemand eine Idee? Hier der Installationscode:
    Vorab herzlichen Dank und guten Rutsch.
    $ ./iobroker add amazon-dash
    npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
    npm WARN lifecycle iobroker.amazon-dash@0.2.6~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.6 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::value>&)’:../socket_watcher.cpp:104:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated (declared at /root/.node-gyp/6.12.2/include/node/v8.h:3276): Use maybe version [-Wdeprecated-declarations]
         info.GetReturnValue().Set(cons->NewInstance());
    ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directory #include <pcap pcap.h="">
    compilation terminated.
    make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR!
     stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.9.35-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/pcap
    gyp ERR! node -v v6.12.2
    gyp
    ERR! node-gyp -v v3.4.0gyp ERR! not ok
    npm
    ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v6.12.2
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm
     ERR! pcap@2.0.0 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the pcap package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs pcap
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls pcap
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /npm-debug.log
    host.iobroker install adapter amazon-dash
    npm
    gyp
    ERR! build error
    gyp
     ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! cwd /opt/iobroker/node_modules/pcapgyp ERR! node -v v6.12.2
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.2
    npm
    npm ERR!
    npm ERR!
     If you do, this is most likely a problem with the pcap package,npm ERR!
     not with npm itself.npm ERR! Tell the author that this fails on your system:
    npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
    npm
    gyp
    ERR! build error
    gyp
    gyp ERR!
    gyp ERR! not ok
    npm
    npm
    npm ERR!
    npm
    npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
    ERROR: host.iobroker Cannot install amazon-dash
    ERROR: process exited with code 13</pcap></v8::object></v8::value></pcap></v8::object></v8::value></pcap></v8::object></v8::value>
    • arteckA Offline
      arteckA Offline
      arteck
      @igabbert:
      Vorab herzlichen Dank und guten Rutsch. `
      frohes neues
      mal im ernst was sollen wir mit solchen Infos….
      welches System ?? Admin Version ?? iobroker version ??
      • I Offline
        I Offline
        igabbert
        Hallo nachmal,
        also installiert auf einem Raspberry Pi 3, Admin Version 2.0.9, iobroker Version 1.2.3 (bin mir nicht sicher)
        Viele Grüße Ingo
        • I Offline
          I Offline
          igabbert
          Hab´s selber hinbekommen. Habe per SSH installiert, dann ging´s.
          • V Offline
            V Offline
            V_Stefan
            Hallo igabbert,
            ich habe das gleiche Problem. Da ich aber Neueinsteiger bin kann ich mit "Habe per SSH installiert, dann ging´s" leider noch nichts anfangen.
            Kannst Du das bitte näher beschreiben.
            Stefan
            • V Offline
              V Offline
              V_Stefan
              Mit Try&Error habe ich es jetzt auch hinbekommen :D .
              Putty öffnen und anmelden
              sudo su
              Bei mir musste ich dann noch im Admin den Adapter mit dem + installieren
              Ich hoffe, dass es nicht all zuviel Quatsch ist, den ich geschrieben habe :lol: :lol:
              Stefan
                Malaus
                @V_Stefan:
                sudo su
                Stefan `
                Habe das selbe Problem und es funktioniert leider nicht mit deiner Lösung.
                  baeckerman83
                  Ich glaube du musst vor dem npm install noch in des iobroker Verzeichniss. Auf dem Rapsian mit Debian unter /opt/iobroker
                  also cd /opt/iobroker und dann npm install….
                    Malaus
                    Hat leider nichts bewirkt.
                    • ThisoftT Offline
                      ThisoftT Offline
                      Thisoft
                      @lalalalala:
                      Habe das selbe Problem und es funktioniert leider nicht mit deiner Lösung. `
                      Hallo lalalalala,
                      wenn dir jemand helfen soll wirst du uns schon mal ein wenig genauer mitteilen müssen <u>was</u> denn nicht funktioniert :!:
                      Sonst müsste ich nämlich die berühmte Frage stellen "Was hast du denn gemacht?" Und wenn dann die berühmte Antwort kommt "Na - Nichts" ist es wohl klar wo der Fehler liegt ;)
                      22 HM-Geräte; PivCCU2 auf RasPi
                      ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
                        Malaus
                        Ja du hast recht!
                        Bei mir kommt so ziemlich die selbe Fehlermeldung. Also am Schluss steht das ebenfalls:
                        ` > host.iobroker install adapter amazon-dash
                        ERROR: process exited with code 13 `
                        Den Lösungsvorschlag von baeckerman83 hab ich ebenfalls schon probiert. Auch kein Erfolg.
                        Ich vermute aber, dass es an meiner Hardware liegt. Den ich habe ioBroker auf einem Android Device laufen.
                        Klar, ist dort die Ordnerstruktur anderst wie bei einem Raspberry aber ich habe den entsprechenden Ordner gefunden und es versucht per ssh zu installieren.
                        • ThisoftT Offline
                          ThisoftT Offline
                          Thisoft
                          Ja, das ist natürlich die entscheidende Ansage - du willst auf Android installieren. Da wird's zumindest ohne "Handarbeit" nicht gehen. Speziell der Dashbutton-Adapter geht ja auch auf Windows nicht zu installieren. Ob's da bei Android einen Umweg gibt…?? Da bin ich raus - kenn ich mich zu wenig damit aus...
                            Malaus
                            Dann wirds wohl Zeit für eine Umstellung :D
                            Danke dir für die Hilfe!
                            82.8k
