  4. Mal wieder BLE Probleme
58 Beiträge 5 Kommentatoren 7.3k Aufrufe 4 Beobachtet
  • T Tenor 0
    BTMon sieht auch gut aus:
    Bluetooth monitor ver 5.72
    btmon[9941]: = Note: Linux version 6.8.0-45-generic (x86_64)        0.998794
    btmon[9941]: = Note: Bluetooth subsystem version 2.22        0.998797
    = New Index: 8C:88:4B:05:62:63 (Primary,USB,hci0)        [hci0] 0.998799
    = Open Index: 8C:88:4B:05:62:63        [hci0] 0.998799
    = Index Info: 8C:88:4B:05:62:63 (Realtek Semiconductor Corporation)        [hci0] 0.998800
    node[9403]: @ RAW Open: node (privileged) version 2.22        {0x0002} [hci0] 0.998801
    bluetoothd[3925]: @ MGMT Open: bluetoothd (privileged) version 1.22        {0x0001} 0.998803
    node[9403]: @ RAW Close: node        {0x0002} [hci0] 36.721193
    node[10055]: @ RAW Open: node (privileged) version 2.22        {0x0002} [hci0] 40.825724
    node[10055]: < HCI Command: Set Event Mask (0x03|0x0001) plen 8        #1 [hci0] 40.826612
            Mask: 0x3dbff807fffbffff
              Inquiry Complete
              Inquiry Result
              Connection Complete
              Connection Request
              Disconnection Complete
              Authentication Complete
              Remote Name Request Complete
              Encryption Change
              Change Connection Link Key Complete
              Link Key Type Changed
              Read Remote Supported Features Complete
              Read Remote Version Information Complete
              QoS Setup Complete
              Command Complete
              Command Status
              Hardware Error
              Flush Occurred
              Role Change
              Mode Change
              Return Link Keys
              PIN Code Request
              Link Key Request
              Link Key Notification
              Loopback Command
              Data Buffer Overflow
              Max Slots Change
              Read Clock Offset Complete
              Connection Packet Type Changed
              QoS Violation
              Page Scan Mode Change
              Page Scan Repetition Mode Change
              Flow Specification Complete
              Inquiry Result with RSSI
              Read Remote Extended Features Complete
              Synchronous Connection Complete
              Synchronous Connection Changed
              Sniff Subrating
              Extended Inquiry Result
              Encryption Key Refresh Complete
              IO Capability Request
              IO Capability Request Reply
              User Confirmation Request
              User Passkey Request
              Remote OOB Data Request
              Simple Pairing Complete
              Link Supervision Timeout Changed
              Enhanced Flush Complete
              User Passkey Notification
              Keypress Notification
              Remote Host Supported Features Notification
              LE Meta
    > HCI Event: Command Complete (0x0e) plen 4        #2 [hci0] 40.927875
          Set Event Mask (0x03|0x0001) ncmd 2
            Status: Success (0x00)
    node[10055]: < HCI Command: LE Set Event Mask (0x08|0x0001) plen 8        #3 [hci0] 40.927956
            Mask: 0x000000000000001f
              LE Connection Complete
              LE Advertising Report
              LE Connection Update Complete
              LE Read Remote Used Features Complete
              LE Long Term Key Request
    > HCI Event: Command Complete (0x0e) plen 4        #4 [hci0] 40.929794
          LE Set Event Mask (0x08|0x0001) ncmd 2
    node[10055]: < HCI Command: Read Local Version Information (0x04|0x0001) plen 0                                                          #5 [hci0] 40.929848
    > HCI Event: Command Complete (0x0e) plen 12        #6 [hci0] 40.931813
          Read Local Version Information (0x04|0x0001) ncmd 2
            HCI version: Bluetooth 5.1 (0x0a) - Revision 57286 (0xdfc6)
            LMP version: Bluetooth 5.1 (0x0a) - Subversion 55586 (0xd922)
            Manufacturer: Realtek Semiconductor Corporation (93)
    node[10055]: < HCI Command: Write LE Host Supported (0x03|0x006d) plen 2        #7 [hci0] 40.931854
            Supported: 0x01
            Simultaneous: 0x00
    > HCI Event: Command Complete (0x0e) plen 4        #8 [hci0] 40.933655
          Write LE Host Supported (0x03|0x006d) ncmd 2
    node[10055]: < HCI Command: Read LE Host Supported (0x03|0x006c) plen 0        #9 [hci0] 40.933716
    > HCI Event: Command Complete (0x0e) plen 6        #10 [hci0] 40.935679
          Read LE Host Supported (0x03|0x006c) ncmd 2
            Supported: 0x01
            Simultaneous: 0x00
    node[10055]: < HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0        #11 [hci0] 40.935729
    > HCI Event: Command Complete (0x0e) plen 7        #12 [hci0] 40.937657
          LE Read Buffer Size (0x08|0x0002) ncmd 2
            Data packet length: 27
            Num data packets: 8
    node[10055]: < HCI Command: Read BD ADDR (0x04|0x0009) plen 0        #13 [hci0] 40.937715
    > HCI Event: Command Complete (0x0e) plen 10        #14 [hci0] 40.939649
          Read BD ADDR (0x04|0x0009) ncmd 2
            Address: 8C:88:4B:05:62:63 (OUI 8C-88-4B)
    Tenor 0
    @tenor-0
    Der Neustart im Syslog
    2024-10-12T19:41:51.235429+02:00 server bluetoothd[4282]: Stopping SDP server
    2024-10-12T19:41:51.235456+02:00 server bluetoothd[4282]: Exit
    2024-10-12T19:41:51.235486+02:00 server bluealsa: bluez.c:1308: Signal: org.freedesktop.DBus.ObjectManager.InterfacesRemoved()
    2024-10-12T19:41:51.235506+02:00 server bluealsa: ba-adapter.c:144: Freeing adapter: hci0
    2024-10-12T19:41:51.236722+02:00 server systemd[1]: bluetooth.service: Deactivated successfully.
    2024-10-12T19:41:51.236949+02:00 server systemd[1]: Stopped bluetooth.service - Bluetooth service.
    2024-10-12T19:41:53.277298+02:00 server systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
    2024-10-12T19:41:53.509695+02:00 server systemd[1]: Configuration file /run/systemd/system/systemd-networkd-wait-online.service.d/10-netplan.conf is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
    2024-10-12T19:41:53.906915+02:00 server systemd[1]: Starting bluetooth.service - Bluetooth service...
    2024-10-12T19:41:53.907273+02:00 server (uetoothd)[6107]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
    2024-10-12T19:41:53.956777+02:00 server bluetoothd[6107]: Bluetooth daemon 5.72
    2024-10-12T19:41:53.957787+02:00 server systemd[1]: Started bluetooth.service - Bluetooth service.
    2024-10-12T19:41:53.957851+02:00 server bluetoothd[6107]: Starting SDP server
    2024-10-12T19:41:53.957897+02:00 server bluetoothd[6107]: Excluding (cli) sap
    2024-10-12T19:41:53.958160+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support csip plugin
    2024-10-12T19:41:53.958198+02:00 server bluetoothd[6107]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
    2024-10-12T19:41:53.958224+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support micp plugin
    2024-10-12T19:41:53.958245+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support vcp plugin
    2024-10-12T19:41:53.958267+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support mcp plugin
    2024-10-12T19:41:53.958290+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support bass plugin
    2024-10-12T19:41:53.958312+02:00 server bluetoothd[6107]: src/plugin.c:plugin_init() System does not support bap plugin
    2024-10-12T19:41:53.958826+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T19:41:53.958997+02:00 server dbus-daemon[969]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.52' (uid=0 pid=6107 comm="/usr/libexec/bluetooth/bluetoothd --noplugin=sap" label="unconfined")
    2024-10-12T19:41:53.959038+02:00 server bluetoothd[6107]: Bluetooth management interface 1.22 initialized
    2024-10-12T19:41:53.959063+02:00 server bluetoothd[6107]: Battery Provider Manager created
    2024-10-12T19:41:53.959347+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T19:41:53.959464+02:00 server bluealsa: ba-adapter.c:53: Couldn't get HCI version: Network is down
    2024-10-12T19:41:53.959490+02:00 server bluealsa: bluez.c:783: Registering battery provider: /org/bluez/hci0/battery
    2024-10-12T19:41:53.960281+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T19:41:53.960311+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T19:41:53.960420+02:00 server bluetoothd[6107]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/1
    2024-10-12T19:41:53.960507+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T19:41:53.960529+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T19:41:53.960621+02:00 server bluetoothd[6107]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/2
    2024-10-12T19:41:53.960695+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T19:41:53.960716+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T19:41:53.960807+02:00 server bluetoothd[6107]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/1
    2024-10-12T19:41:53.960876+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T19:41:53.960901+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T19:41:53.960982+02:00 server bluetoothd[6107]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/2
    2024-10-12T19:41:53.961055+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
    2024-10-12T19:41:53.974784+02:00 server systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
    2024-10-12T19:41:54.051605+02:00 server dbus-daemon[969]: [system] Successfully activated service 'org.freedesktop.hostname1'
    2024-10-12T19:41:54.051794+02:00 server systemd[1]: Started systemd-hostnamed.service - Hostname Service.
    2 Probleme sehe ich da
    und
    letzters scheint neu zu sein.
    Mittlerweile kommt
    matthias@server:~$ sudo hcitool lescan
    Set scan parameters failed: Broken pipe
    Alles was ich gemacht habe ist ein paar mal den Dienst neu gestartet zu haben
    • T Tenor 0
      @tenor-0
      und
      Mittlerweile kommt
      @tenor-0
      Irgendwas haste da an den Rechten verfummelt...
      systemctl cat bluetooth.service
      sagt?
      • T Tenor 0
        @tenor-0
        und
        Mittlerweile kommt
        @tenor-0
        CAPs gesetzt?
        Jag den
        iobroker fix
        über das System, ich glaube der setzt die auch. Aber NICHT als root!
          @tenor-0
          sagt?
          Tenor 0
          # /usr/lib/systemd/system/bluetooth.service
          [Unit]
          Description=Bluetooth service
          Documentation=man:bluetoothd(8)
          ConditionPathIsDirectory=/sys/class/bluetooth
          [Service]
          Type=dbus
          BusName=org.bluez
          ExecStart=/usr/libexec/bluetooth/bluetoothd --noplugin=sap
          NotifyAccess=main
          #WatchdogSec=10
          Restart=on-failure
          CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE
          LimitNPROC=1
          # Filesystem lockdown
          ProtectHome=true
          ProtectSystem=strict
          PrivateTmp=true
          ProtectKernelTunables=true
          ProtectControlGroups=true
          StateDirectory=bluetooth
          StateDirectoryMode=0700
          ConfigurationDirectory=bluetooth
          ConfigurationDirectoryMode=0555
          # Execute Mappings
          MemoryDenyWriteExecute=true
          # Privilege escalation
          NoNewPrivileges=true
          # Real-time
          RestrictRealtime=true
          [Install]
          WantedBy=bluetooth.target
          Alias=dbus-org.bluez.service
          • T Tenor 0
            [Unit]
            [Service]
            Type=dbus
            BusName=org.bluez
            NotifyAccess=main
            #WatchdogSec=10
            Restart=on-failure
            LimitNPROC=1
            ProtectHome=true
            PrivateTmp=true
            # Execute Mappings
            # Real-time
            [Install]
            @tenor-0 sagte in Mal wieder BLE Probleme:
            Die Zeile dürfte falsch sein. Das dürfte
            ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
            heißen müssen.
              @tenor-0
              CAPs gesetzt?
              Jag den
              iobroker fix
              Tenor 0
              Was meinst du mit CAPs gesetzt?
              Den Fix habe ich erneut ausgeführt, aber kein Unterschied, der Adapter ist gelb.
              Der Scan ging nach einem Neustart wieder.
              • T Tenor 0
                @tenor-0
                sudo apt update
                sudo apt install libcap2-bin
                sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                  heißen müssen.
                  Tenor 0
                  Das musste ich extra rein machen, da ich sonst beim starten eine Fehlermeldung bekomme.
                  Habe die noch als Bild gespeichert:
                  quelle
                  • T Tenor 0
                    quelle
                    @tenor-0
                    Keine Bildchens...
                    Der Pfad /usr/libexec/bluetooth/bluetoothd dürfte falsch sein.
                    Auf meinem Debian gibt es kein /usr/libexec
                    Das sieht mir nach einem Kopierfehler aus.
                    €dit: Okay, bei ubuntu und Debian trixie gibt es den Pfad wohl. Also so lassen.
                      @tenor-0
                      Keine Bildchens...
                      Tenor 0
                      @thomas-braun said in Mal wieder BLE Probleme:
                      matthias@server:~$ cd /usr/libexec/bluetooth/
                      matthias@server:/usr/libexec/bluetooth$ ls
                      bluetoothd  obexd
                      Das existiert so und war vorher auch so drin. Ich habe nur den Parameter angehangen wie in der Quelle beschrieben.
                      Ich befürchte das der onboard adapter dazwischen funkt.
                      Der Server hat einen onboard WiFi/BT Adapter, der jedoch kein BLE kann:
                      02:00.0 Network controller: MEDIATEK Corp. MT7921K (RZ608) Wi-Fi 6E 80MHz
                      Deswegen hatte ich den deaktiviert wie aus dem ursprünglichem Thread beschrieben, dieser war immer hci0 und der USB Adapter dann HCI1
                      Seit dem ich den deaktiviert hatte, war dann der USB Adapter HCI0.
                      Bei der Fehlersuch habe ich schon 2 mal gesehen das der HCIconfig den USB Adapter als HCI1 bezeichnet hat..
                      Nach einem Reboot ist das Thema dann wieder erledigt.
                      Anleitung
                      • T Tenor 0
                        bluetoothd  obexd
                        Anleitung
                        @tenor-0
                        libcap2 installiert?
                        Kommando dazu ausgeführt?
                        Siehe oben.
                          @tenor-0
                          Siehe oben.
                          Tenor 0
                          ging wahrscheinlich wegen doppelpost unter, ja ich hatte das schon gemacht. leider kein Unterschied.
                          lescan geht, unter iobroker, kommen keinen neuen Geräte mehr dazu. (Haken in den Einstellungen ist gesetzt)
                          • T Tenor 0
                            Die Ausgaben dazu würde ich gerne sehen.
                              Tenor 0
                              matthias@server:/usr/libexec/bluetooth$ sudo apt update
                              OK:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
                              OK:2 http://security.ubuntu.com/ubuntu noble-security InRelease
                              OK:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
                              OK:4 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
                              Alle Pakete sind aktuell.
                              matthias@server:/usr/libexec/bluetooth$ sudo apt install libcap2-bin
                              libcap2-bin ist schon die neueste Version (1:2.66-5ubuntu2).
                              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                mailcap wmdocker
                              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              matthias@server:/usr/libexec/bluetooth$ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                              • T Tenor 0
                                  mailcap wmdocker
                                Tenor 0
                                ich stosse immer wieder auf die Meldung:
                                bluetoothd[3674]: Failed to set privacy: Rejected (0x0b)
                                2024-10-12T20:41:52.551245+02:00 server systemd[1]: bluetooth.service: Deactivated successfully.
                                2024-10-12T20:41:52.551384+02:00 server systemd[1]: Stopped bluetooth.service - Bluetooth service.
                                2024-10-12T20:41:54.589079+02:00 server systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
                                2024-10-12T20:41:54.814941+02:00 server systemd[1]: Configuration file /run/systemd/system/systemd-networkd-wait-online.service.d/10-netplan.conf is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
                                2024-10-12T20:41:55.201508+02:00 server (uetoothd)[3674]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
                                2024-10-12T20:41:55.201632+02:00 server systemd[1]: Starting bluetooth.service - Bluetooth service...
                                2024-10-12T20:41:55.250612+02:00 server bluetoothd[3674]: Bluetooth daemon 5.72
                                2024-10-12T20:41:55.251545+02:00 server systemd[1]: Started bluetooth.service - Bluetooth service.
                                2024-10-12T20:41:55.251591+02:00 server bluetoothd[3674]: Starting SDP server
                                2024-10-12T20:41:55.251620+02:00 server bluetoothd[3674]: Excluding (cli) sap
                                2024-10-12T20:41:55.251891+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support csip plugin
                                2024-10-12T20:41:55.251945+02:00 server bluetoothd[3674]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
                                2024-10-12T20:41:55.251988+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support micp plugin
                                2024-10-12T20:41:55.252020+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support vcp plugin
                                2024-10-12T20:41:55.252045+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support mcp plugin
                                2024-10-12T20:41:55.252070+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support bass plugin
                                2024-10-12T20:41:55.252095+02:00 server bluetoothd[3674]: src/plugin.c:plugin_init() System does not support bap plugin
                                2024-10-12T20:41:55.252554+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
                                2024-10-12T20:41:55.252690+02:00 server dbus-daemon[971]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.45' (uid=0 pid=3674 comm="/usr/libexec/bluetooth/bluetoothd --noplugin=sap" label="unconfined")
                                2024-10-12T20:41:55.252765+02:00 server bluetoothd[3674]: Bluetooth management interface 1.22 initialized
                                2024-10-12T20:41:55.252793+02:00 server bluetoothd[3674]: Battery Provider Manager created
                                2024-10-12T20:41:55.252889+02:00 server bluetoothd[3674]: Failed to set privacy: Rejected (0x0b)
                                2024-10-12T20:41:55.253179+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
                                2024-10-12T20:41:55.271225+02:00 server systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
                                2024-10-12T20:41:55.347612+02:00 server dbus-daemon[971]: [system] Successfully activated service 'org.freedesktop.hostname1'
                                2024-10-12T20:41:55.347704+02:00 server systemd[1]: Started systemd-hostnamed.service - Hostname Service.
                                2024-10-12T20:41:55.356604+02:00 server bluealsa: bluez.c:783: Registering battery provider: /org/bluez/hci0/battery
                                2024-10-12T20:41:55.357266+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/1
                                2024-10-12T20:41:55.357317+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/1
                                2024-10-12T20:41:55.357504+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/1
                                2024-10-12T20:41:55.357618+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/source/2
                                2024-10-12T20:41:55.357670+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/source/2
                                2024-10-12T20:41:55.357785+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/source/2
                                2024-10-12T20:41:55.357890+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/1
                                2024-10-12T20:41:55.357930+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/1
                                2024-10-12T20:41:55.358065+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/1
                                2024-10-12T20:41:55.358135+02:00 server bluealsa: bluez.c:598: Creating media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/2
                                2024-10-12T20:41:55.358155+02:00 server bluealsa: bluez.c:509: Registering media endpoint: /org/bluez/hci0/A2DP/SBC/sink/2
                                2024-10-12T20:41:55.358215+02:00 server bluetoothd[3674]: Endpoint registered: sender=:1.11 path=/org/bluez/hci0/A2DP/SBC/sink/2
                                2024-10-12T20:41:55.358275+02:00 server bluealsa: bluez.c:1199: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
                                2024-10-12T20:42:25.372785+02:00 server systemd[1]: systemd-hostnamed.service: Deactivated successfully.
                                meistens verschwindet sie nach dem Neustart des Adapters, weiß aber nicht wie relevant sie ist.
                                • T Tenor 0
                                  @tenor-0
                                  rfkill
                                  sagt?
                                    @tenor-0
                                    rfkill
                                    sagt?
                                    Tenor 0
                                    rfkill
                                    alles tuti
                                    matthias@server:~$ rfkill
                                    ID TYPE      DEVICE      SOFT      HARD
                                     0 bluetooth hci0   unblocked unblocked
                                     1 wlan      phy0   unblocked unblocked
                                    matthias@server:~$ rfkill list
                                    0: hci0: Bluetooth
                                            Soft blocked: no
                                            Hard blocked: no
                                    1: phy0: Wireless LAN
                                            Soft blocked: no
                                            Hard blocked: no
                                    • T Tenor 0
                                      rfkill
                                      alles tuti
                                      0: hci0: Bluetooth
                                              Soft blocked: no
                                              Hard blocked: no
                                              Soft blocked: no
                                              Hard blocked: no
                                      @tenor-0
                                      Den Haken bei 'Neue Gerät akzeptieren' im Adapter hattest du schon mal gesetzt?
                                        @tenor-0
                                        Tenor 0
                                        ja diverse male
                                        • T Tenor 0
                                          ja diverse male
                                          @tenor-0
                                          Dann weiß ich nix mehr dazu.
