  4. Nach Update Anmeldung nicht mehr möglich
    1.0k
    6.1k
39 Beiträge 16 Kommentatoren 6.2k Aufrufe 14 Beobachtet
    TT-Tom
    habe den Test mit dem js-controller 7.0.0, Admin 7.2.1 und Nodejs 20.18.0 durchgeführt. Das Log sieht den andren gleich aus.
    2024-10-07 11:30:55.346  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
    2024-10-07 11:31:25.572  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.1" started with pid 9133
    2024-10-07 11:31:26.332  - info: admin.0 (9133) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
    2024-10-07 11:31:26.347  - info: admin.0 (9133) requesting all objects
    2024-10-07 11:31:26.385  - error: admin.0 (9133) Cannot init i18n: Error: Cannot find i18n directory
    2024-10-07 11:31:26.753  - info: admin.0 (9133) received all objects
    2024-10-07 11:31:26.877  - info: admin.0 (9133) socket.io server listening on port 8081
    2024-10-07 11:31:26.878  - info: admin.0 (9133) http server listening on port 8081
    2024-10-07 11:31:26.878  - info: admin.0 (9133) Use link "http://127.0.0.1:8081" to configure.
    2024-10-07 11:31:31.081  - error: admin.0 (9133) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:31:31.081  - error: admin.0 (9133) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
        at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
        at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
        at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
        at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
        at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
        at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
        at Array.forEach (<anonymous>)
        at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
        at WebSocketServer.emit (node:events:519:28)
        at WebSocketServer.emit (node:domain:488:12)
    2024-10-07 11:31:31.081  - error: admin.0 (9133) Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:31:31.089  - info: admin.0 (9133) terminating http server on port 8081
    2024-10-07 11:31:31.090  - warn: admin.0 (9133) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
    2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
    2024-10-07 11:31:31.442  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-10-07 11:31:31.442  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
    gleiches Verhalten mit Version 7.2.2
    2024-10-07 11:38:26.917  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 9648
    2024-10-07 11:38:27.722  - info: admin.0 (9648) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
    2024-10-07 11:38:27.737  - info: admin.0 (9648) requesting all objects
    2024-10-07 11:38:27.776  - error: admin.0 (9648) Cannot init i18n: Error: Cannot find i18n directory
    2024-10-07 11:38:28.145  - info: admin.0 (9648) received all objects
    2024-10-07 11:38:28.348  - info: admin.0 (9648) socket.io server listening on port 8081
    2024-10-07 11:38:28.349  - info: admin.0 (9648) http server listening on port 8081
    2024-10-07 11:38:28.350  - info: admin.0 (9648) Use link "http://127.0.0.1:8081" to configure.
    2024-10-07 11:38:29.654  - error: admin.0 (9648) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:38:29.654  - error: admin.0 (9648) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:38:29.654  - error: admin.0 (9648) Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:38:29.662  - info: admin.0 (9648) terminating http server on port 8081
    2024-10-07 11:38:29.663  - warn: admin.0 (9648) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
    2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
    2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
    2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
    2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
    2024-10-07 11:38:30.016  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-10-07 11:38:30.016  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      Scheint mir ein Fehler mit der Authentifzierung bei admins mit SSL/https zu sein.
      A T E 3 Antworten Letzte Antwort
        A Online
        A Online
        ag
        @thomas-braun sagte in Nach Update Anmeldung nicht mehr möglich:
        Habe Authentifizierung ausgeschaltet und dann auf 7.2.2 upgedatet.
        Admin wird problemlos angezeigt
        ag
        Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
        /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
        js-controller 7.0.6 admin 7.4.10
          TT-Tom
          ich nutze kein https, aber die Anmeldung als Admin. Werde es auch mal ohne versuchen.
          ohne Authentifizierung funktioniert das Update auf 7.2.2.
          habe danach die Authentifizierung wieder aktiviert und folgendes Log erhalten mit den Resultat, dass man sich nicht mehr einloggen kann und der Admin in einer Schleife wieder hängt.
          2024-10-07 13:19:06.612  - info: admin.0 (10274) starting. Version 7.2.0 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:19:06.627  - info: admin.0 (10274) requesting all objects
          2024-10-07 13:19:06.666  - error: admin.0 (10274) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:19:07.037  - info: admin.0 (10274) received all objects
          2024-10-07 13:19:07.161  - info: admin.0 (10274) socket.io server listening on port 8081
          2024-10-07 13:19:07.161  - info: admin.0 (10274) http server listening on port 8081
          2024-10-07 13:19:07.162  - info: admin.0 (10274) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:19:08.974  - info: admin.0 (10274) ==> Connected system.user.admin from ::ffff:192.168.178.11
          2024-10-07 13:19:26.550  - info: fahrplan.0 (8780) Updated 2 routes, 2 enabled and 0 disabled
          2024-10-07 13:19:26.792  - info: fahrplan.0 (8780) Updated 1 departure timetables, 1 enabled and 0 disabled
          2024-10-07 13:19:29.572  - info: host.iobtest "system.adapter.admin.0" disabled
          2024-10-07 13:19:29.573  - info: host.iobtest stopInstance system.adapter.admin.0 (force=false, process=true)
          2024-10-07 13:19:29.575  - info: admin.0 (10274) Got terminate signal TERMINATE_YOURSELF
          2024-10-07 13:19:29.575  - info: admin.0 (10274) terminating http server on port 8081
          2024-10-07 13:19:29.577  - info: admin.0 (10274) terminating
          2024-10-07 13:19:29.577  - info: admin.0 (10274) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-10-07 13:19:29.614  - info: host.iobtest stopInstance system.adapter.admin.0 send kill signal
          2024-10-07 13:19:30.078  - info: admin.0 (10274) terminating
          2024-10-07 13:19:30.100  - info: host.iobtest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-07 13:19:32.575  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
          2024-10-07 13:19:35.917  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 7.2.2
          2024-10-07 13:19:36.350  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Final information delivered
          2024-10-07 13:19:36.355  - info: host.iobtest "system.adapter.admin.0" enabled
          2024-10-07 13:19:36.355  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Successfully started adapter
          2024-10-07 13:19:36.588  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10336
          2024-10-07 13:19:37.318  - info: admin.0 (10336) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:19:37.333  - info: admin.0 (10336) requesting all objects
          2024-10-07 13:19:37.371  - error: admin.0 (10336) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:19:37.744  - info: admin.0 (10336) received all objects
          2024-10-07 13:19:37.858  - info: admin.0 (10336) socket.io server listening on port 8081
          2024-10-07 13:19:37.858  - info: admin.0 (10336) http server listening on port 8081
          2024-10-07 13:19:37.859  - info: admin.0 (10336) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:19:40.480  - info: admin.0 (10336) ==> Connected system.user.admin from ::ffff:192.168.178.11
          2024-10-07 13:19:41.606  - info: admin.0 (10336) <== Disconnect system.user.admin from ::ffff:192.168.178.11 admin
          2024-10-07 13:19:42.118  - info: admin.0 (10336) ==> Connected system.user.admin from ::ffff:192.168.178.11
          2024-10-07 13:20:15.922  - info: host.iobtest stopInstance system.adapter.admin.0 (force=false, process=true)
          2024-10-07 13:20:15.925  - info: admin.0 (10336) Got terminate signal TERMINATE_YOURSELF
          2024-10-07 13:20:15.926  - info: admin.0 (10336) terminating http server on port 8081
          2024-10-07 13:20:15.929  - info: admin.0 (10336) terminating
          2024-10-07 13:20:15.930  - info: admin.0 (10336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-10-07 13:20:15.964  - info: host.iobtest stopInstance system.adapter.admin.0 send kill signal
          2024-10-07 13:20:16.429  - info: admin.0 (10336) terminating
          2024-10-07 13:20:16.453  - info: host.iobtest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-07 13:20:19.656  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10404
          2024-10-07 13:20:20.390  - info: admin.0 (10404) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:20:20.404  - info: admin.0 (10404) requesting all objects
          2024-10-07 13:20:20.443  - error: admin.0 (10404) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:20:20.823  - info: admin.0 (10404) received all objects
          2024-10-07 13:20:20.945  - info: admin.0 (10404) socket.io server listening on port 8081
          2024-10-07 13:20:20.946  - info: admin.0 (10404) http server listening on port 8081
          2024-10-07 13:20:20.946  - info: admin.0 (10404) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:20:22.775  - error: admin.0 (10404) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:20:22.775  - error: admin.0 (10404) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:20:22.775  - error: admin.0 (10404) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:20:22.783  - info: admin.0 (10404) terminating http server on port 8081
          2024-10-07 13:20:22.784  - warn: admin.0 (10404) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[1]: strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[2]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[3]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[4]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[5]: strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[6]: strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[7]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[8]: strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[9]: strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[10]: strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[10]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[11]: strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[12]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[12]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[13]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[14]: strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[15]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[15]: strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[16]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[16]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[17]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[18]: strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[18]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[19]: strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[20]: strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[21]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[21]: strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[22]: strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[23]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[23]: strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[24]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[25]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[25]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[26]: strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[26]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[27]: strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[29]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[30]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[30]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[31]: strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[32]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[33]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[34]: strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[35]: strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[36]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[36]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[37]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[38]: strict mode: required property "complex" is not defined at "#/items/allOf/21/then/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[39]: strict mode: required property "simple" is not defined at "#/items/allOf/21/then/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[40]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[41]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[41]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[42]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[43]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[43]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[44]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[45]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[46]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[47]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[48]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[49]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[50]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[51]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[52]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[52]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[53]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[54]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[55]: strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[55]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[56]: strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[57]: strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[58]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[58]: strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[60]: strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[61]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[61]: strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[62]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[62]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[63]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[64]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[65]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[66]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[67]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[68]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[69]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[70]: strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[70]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[71]: strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[72]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[72]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[73]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[74]: strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[75]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[75]: strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[76]: strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[76]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[77]: strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[78]: strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[78]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[79]: strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[80]: strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[80]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[81]: strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[82]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[83]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[83]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[84]: strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[85]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[85]: strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[86]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[87]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[87]: strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[88]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[89]: strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[90]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[91]: strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[92]: strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[93]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[93]: strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[94]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[94]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[95]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[96]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[100]: strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[100]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[101]: strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[102]: strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[102]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[103]: strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[104]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[105]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[105]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[106]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[107]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[108]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[109]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[110]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[111]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Array.forEach (<anonymous>)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.emit (node:events:519:28)
          2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.emit (node:domain:488:12)
          2024-10-07 13:20:23.118  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 13:20:23.118  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
          2024-10-07 13:20:53.346  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10437
          2024-10-07 13:20:54.082  - info: admin.0 (10437) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:20:54.096  - info: admin.0 (10437) requesting all objects
          2024-10-07 13:20:54.135  - error: admin.0 (10437) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:20:54.510  - info: admin.0 (10437) received all objects
          2024-10-07 13:20:54.637  - info: admin.0 (10437) socket.io server listening on port 8081
          2024-10-07 13:20:54.638  - info: admin.0 (10437) http server listening on port 8081
          2024-10-07 13:20:54.638  - info: admin.0 (10437) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:21:29.058  - error: admin.0 (10437) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:21:29.058  - error: admin.0 (10437) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:21:29.058  - error: admin.0 (10437) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:21:29.066  - info: admin.0 (10437) terminating http server on port 8081
          2024-10-07 13:21:29.067  - info: admin.0 (10437) terminating
          2024-10-07 13:21:29.067  - warn: admin.0 (10437) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
          2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
          2024-10-07 13:21:29.503  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 13:21:29.504  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
          2024-10-07 13:21:59.721  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10476
          2024-10-07 13:22:00.471  - info: admin.0 (10476) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:22:00.485  - info: admin.0 (10476) requesting all objects
          2024-10-07 13:22:00.524  - error: admin.0 (10476) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:22:00.899  - info: admin.0 (10476) received all objects
          2024-10-07 13:22:01.029  - info: admin.0 (10476) socket.io server listening on port 8081
          2024-10-07 13:22:01.030  - info: admin.0 (10476) http server listening on port 8081
          2024-10-07 13:22:01.031  - info: admin.0 (10476) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:22:05.403  - error: admin.0 (10476) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:05.403  - error: admin.0 (10476) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:05.404  - error: admin.0 (10476) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:05.411  - info: admin.0 (10476) terminating http server on port 8081
          2024-10-07 13:22:05.412  - info: admin.0 (10476) terminating
          2024-10-07 13:22:05.412  - warn: admin.0 (10476) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 13:22:05.730  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
          2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
          2024-10-07 13:22:05.731  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 13:22:05.731  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
          2024-10-07 13:22:35.960  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10509
          2024-10-07 13:22:36.702  - info: admin.0 (10509) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
          2024-10-07 13:22:36.717  - info: admin.0 (10509) requesting all objects
          2024-10-07 13:22:36.755  - error: admin.0 (10509) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 13:22:37.139  - info: admin.0 (10509) received all objects
          2024-10-07 13:22:37.255  - info: admin.0 (10509) socket.io server listening on port 8081
          2024-10-07 13:22:37.256  - info: admin.0 (10509) http server listening on port 8081
          2024-10-07 13:22:37.256  - info: admin.0 (10509) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 13:22:41.460  - error: admin.0 (10509) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:41.460  - error: admin.0 (10509) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:41.461  - error: admin.0 (10509) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:41.468  - info: admin.0 (10509) terminating http server on port 8081
          2024-10-07 13:22:41.469  - info: admin.0 (10509) terminating
          2024-10-07 13:22:41.469  - warn: admin.0 (10509) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
          2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
          2024-10-07 13:22:41.867  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 13:22:41.867  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
          mit https und ohne Authentifizierung funktioniert der Admin in Version 7.2.2
          jetzt könnte es am Password liegen, das bestimmte Zeichen oder länge nicht mehr passt.
          Gruß Tom
          Public Transport
            el_rob
            Bei meiner Installation ist HTTPS nicht aktiviert.
            • E el_rob
              tomatenforever
              @el_rob Guten Abend, Ich habe das gleiche Problem. Mein ioBroker läuft an sich im Hintergrund, jedoch ist die Webseite nicht mehr erreichbar... Lediglich der Ladebalken dreht die ganze Zeit.
              Oct  7 20:24:05 raspberrypi bash[3479769]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at Array.forEach (<anonymous>)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.emit (node:events:519:28)
              Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.emit (node:domain:488:12)
              Oct  7 20:24:06 raspberrypi systemd[1]: Stopping ioBroker Server...
              • T tomatenforever
                S Abwesend
                S Abwesend
                Shadowhunter23
                schrieb am zuletzt editiert von Shadowhunter23
                @tomatenforever
                Zeig mal iob diag
                Und mit iobroker upgrade admin@7.2.0 kommst du zurück zur 7.2.0
                Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                ioBroker Backup Analyzer
                D T 2 Antworten Letzte Antwort
                • S Shadowhunter23
                  @tomatenforever
                  Zeig mal iob diag
                  DLaurenz
                  schrieb am zuletzt editiert von DLaurenz
                  @shadowhunter23 Same here:
                  2024-10-08 13:23:54.342  - error: admin.0 (121735) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-08 13:23:54.343  - error: admin.0 (121735) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-08 13:23:54.344  - error: admin.0 (121735) Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-08 13:23:54.785  - info: admin.0 (121735) terminating https server on port 8081
                  2024-10-08 13:23:54.788  - info: admin.0 (121735) terminating
                                          v.2024-08-12
                     Static hostname: iob-master
                           Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               64 bit
                  User-ID:                0
                  Display-Server:         false
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/node           v20.18.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  Recommended versions are nodejs 20.18.0 and npm 10.8.2
                  MEMORY:
                  Mem:            7.9G        2.1G        2.8G        192M        2.9G        5.4G
                  Swap:            99M          0B         99M
                  Total:          8.0G        2.1G        2.9G
                  Active iob-Instances:   20
                  Upgrade policy: none
                  ioBroker Core:          js-controller           7.0.0
                                          admin                   7.2.2
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : iob-master                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.web.0                    : web                   : iob-master                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                47963
                  States:                 43200
                  Size of iob-Database:
                  53M     /opt/iobroker/iobroker-data/objects.jsonl
                  110M    /opt/iobroker/iobroker-data/states.jsonl
                  iob diag:
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   13:29:20 up  2:14,  1 user,  load average: 0.52, 0.74, 0.96
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-10-08 13:29:20 CEST
                             Universal time: Tue 2024-10-08 11:29:20 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                  *** Display-Server-Setup ***
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           7862 M total memory
                           2132 M used memory
                           2829 M active memory
                           1983 M inactive memory
                           2818 M free memory
                            149 M buffer memory
                           2761 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 13:29:20 up  2:14,  1 user,  load average: 0.52, 0.74, 0.96
                  Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7862.2 total,   2818.8 free,   2132.9 used,   2910.5 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5375.3 avail Mem
                  *** FAILED SERVICES ***
                    UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                  * hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4      469G   14G  431G   4% /
                  devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs          tmpfs     3.9G   20K  3.9G   1% /dev/shm
                  tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
                  /dev/sda1      vfat      255M   31M  225M  13% /boot
                  folder2ram     tmpfs     3.9G  190M  3.7G   5% /opt/powershell
                  tmpfs          tmpfs     787M     0  787M   0% /run/user/0
                  [Tue Oct  8 11:14:36 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:C6:A8 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=7f03ccbc-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Tue Oct  8 11:14:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Oct  8 11:14:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Tue Oct  8 11:14:40 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET                           SOURCE                     FSTYPE OPTIONS
                  /                                /dev/sda2                  ext4   rw,noatime
                  |-/boot                          /dev/sda1                  vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  `-/var/folder2ram/opt/powershell /dev/sda2[/opt/powershell] ext4   rw,noatime
                  /var:
                  5.6G    /var/
                  4.1G    /var/log/journal/913411ec2113471e8a5a95f370c5ddcb
                  4.1G    /var/log
                  653M    /var/lib
                  Archived and active journals take up 4.0G in the file system.
                  /opt/iobroker/backups:
                  16K     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.3G    /opt/iobroker/iobroker-data/
                  885M    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  109M    /opt/iobroker/iobroker-data/states.jsonl
                  24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
                  24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
                  19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyACM0
                  *** NodeJS-Installation ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Installed: 20.18.0-1nodesource1
                    Candidate: 20.18.0-1nodesource1
                    Version table:
                   *** 20.18.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u5 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin:          7.2.2
                  javascript:     8.8.3
                  nodejs modules from github:     0
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : iob-master                               -  enabled
                  + system.adapter.backitup.0               : backitup              : iob-master                               -  enabled
                    system.adapter.ble.0                    : ble                   : io-blegw02                               -  enabled
                  + system.adapter.discovery.0              : discovery             : iob-master                               -  enabled
                    system.adapter.dwd.0                    : dwd                   : iob-master                               -  enabled
                  + system.adapter.eventlist.0              : eventlist             : iob-master                               -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob-master                               - disabled
                  + system.adapter.fritzdect.0              : fritzdect             : iob-master                               -  enabled
                  + system.adapter.hmip.0                   : hmip                  : iob-master                               -  enabled
                  + system.adapter.hmip.1                   : hmip                  : iob-master                               -  enabled
                    system.adapter.homeconnect.0            : homeconnect           : iob-master                               -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iob-master                               -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : iob-master                               -  enabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : iob-master                               -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-master                               -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-master                               -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-master                               -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iob-master                               -  enabled, port: 8086
                  + system.adapter.javascript.0             : javascript            : iob-master                               -  enabled
                  + system.adapter.linux-control.0          : linux-control         : iob-master                               -  enabled
                  + system.adapter.mercedesme.0             : mercedesme            : iob-master                               -  enabled
                  + system.adapter.meross.0                 : meross                : iob-master                               -  enabled
                  + system.adapter.ping.0                   : ping                  : iob-master                               -  enabled
                  + system.adapter.roborock.0               : roborock              : iob-master                               -  enabled
                  + system.adapter.selverf.0                : selverf               : io-fhem                                  -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : iob-master                               -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iob-master                               -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-master                               -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-master                               -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-master                               -  enabled
                    system.adapter.vis-history.0            : vis-history           : iob-master                               -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-master                               -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iob-master                               -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-master                               -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : iob-master                               -  enabled
                    system.adapter.vis-map.0                : vis-map               : iob-master                               -  enabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-master                               -  enabled
                    system.adapter.vis-material.0           : vis-material          : iob-master                               -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : iob-master                               -  enabled
                    system.adapter.vis-players.0            : vis-players           : iob-master                               -  enabled
                    system.adapter.vis-plumb.0              : vis-plumb             : iob-master                               -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-master                               -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : iob-master                               -  enabled
                    system.adapter.vis.0                    : vis                   : iob-master                               -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : io-fhem                                  -  enabled, port: /dev/ttyACM0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                  Adapter    "admin"        : 7.2.0    , installed 7.2.2
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                  Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                  Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.0    , installed 7.0.0
                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                  Adapter    "mercedesme"   : 0.2.3    , installed 0.2.3
                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                  Adapter    "ping"         : 1.7.9    , installed 1.7.9
                  Adapter    "roborock"     : 0.6.16   , installed 0.6.16
                  Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "web"          : 6.3.1    , installed 6.3.1
                  Objects and States
                  Objects:        47963
                  States:         43200
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:3 http://deb.debian.org/debian bullseye InRelease
                  Hit:4 https://repo.saltproject.io/salt/py3/debian/11/amd64/latest bullseye InRelease
                  Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
                  Hit:7 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:8 https://repos.influxdata.com/debian stable InRelease
                  Hit:9 https://packages.microsoft.com/debian/11/prod bullseye InRelease
                  Ign:10 https://download.webmin.com/download/repository sarge InRelease
                  Hit:11 https://download.webmin.com/download/repository sarge Release
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          15221      1256/perl
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       191961     106721/iobroker.js-
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       191353     106721/iobroker.js-
                  tcp        0      0 0.0.0.0:33733           0.0.0.0:*               LISTEN      107        181783     102314/rpc.statd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          181170     102324/sshd: /usr/s
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21351      1/init
                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          19120      1172/smbd
                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          19119      1172/smbd
                  tcp        0      0 0.0.0.0:44701           0.0.0.0:*               LISTEN      0          222860     -
                  tcp6       0      0 :::10000                :::*                    LISTEN      0          15222      1256/perl
                  tcp6       0      0 :::36915                :::*                    LISTEN      107        181787     102314/rpc.statd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          181181     102324/sshd: /usr/s
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          20266      1/init
                  tcp6       0      0 :::80                   :::*                    LISTEN      0          181236     102347/node
                  tcp6       0      0 :::139                  :::*                    LISTEN      0          19118      1172/smbd
                  tcp6       0      0 :::443                  :::*                    LISTEN      0          186523     102347/node
                  tcp6       0      0 :::445                  :::*                    LISTEN      0          19117      1172/smbd
                  tcp6       0      0 :::7906                 :::*                    LISTEN      1001       197205     107257/io.roborock.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       196923     107818/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       214951     123102/io.admin.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        19147      1008/influxd
                  tcp6       0      0 :::6824                 :::*                    LISTEN      1001       197204     107257/io.roborock.
                  tcp6       0      0 :::39729                :::*                    LISTEN      0          222863     -
                  tcp6       0      0 :::6556                 :::*                    LISTEN      0          12079      1/init
                  udp        0      0 0.0.0.0:56293           0.0.0.0:*                           107        181781     102314/rpc.statd
                  udp        0      0 0.0.0.0:48461           0.0.0.0:*                           0          222859     -
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20262      1/init
                  udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          18981      1104/nmbd
                  udp        0      0 192.168.2.117:137       0.0.0.0:*                           0          18980      1104/nmbd
                  udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18959      1104/nmbd
                  udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          18983      1104/nmbd
                  udp        0      0 192.168.2.117:138       0.0.0.0:*                           0          18982      1104/nmbd
                  udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18960      1104/nmbd
                  udp        0      0 0.0.0.0:57850           0.0.0.0:*                           108        12108      444/avahi-daemon: r
                  udp        0      0 192.168.2.117:16989     0.0.0.0:*                           0          186507     102347/node
                  udp        0      0 0.0.0.0:16989           0.0.0.0:*                           0          186506     102347/node
                  udp        0      0 127.0.0.1:730           0.0.0.0:*                           0          181779     102314/rpc.statd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12106      444/avahi-daemon: r
                  udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          15223      1256/perl
                  udp6       0      0 :::36688                :::*                                0          222861     -
                  udp6       0      0 :::111                  :::*                                0          21355      1/init
                  udp6       0      0 fe80::95a2:3a:dd49::546 :::*                                0          14809      465/NetworkManager
                  udp6       0      0 fe80::95a2:3a:dd4:16989 :::*                                0          186520     102347/node
                  udp6       0      0 2003:d7:b736:fa00:16989 :::*                                0          186517     102347/node
                  udp6       0      0 fd00::8c2e:fc9f:e:16989 :::*                                0          186514     102347/node
                  udp6       0      0 2003:d7:b736:fa00:16989 :::*                                0          186511     102347/node
                  udp6       0      0 :::16989                :::*                                0          186508     102347/node
                  udp6       0      0 :::53915                :::*                                108        12109      444/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        12107      444/avahi-daemon: r
                  udp6       0      0 :::54757                :::*                                107        181785     102314/rpc.statd
                  2024-10-08 13:25:37.055  - info: host.iob-master instance system.adapter.dwd.0 in version "2.8.5" started with pid 123923
                  2024-10-08 13:25:40.918  - info: dwd.0 (123923) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.0
                  2024-10-08 13:25:42.331  - info: dwd.0 (123923) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-10-08 13:25:42.868  - info: host.iob-master instance system.adapter.dwd.0 having pid 123923 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-10-08 13:28:39.181  - warn: homeconnect.0 (107315) Restart initiated
                  2024-10-08 13:28:39.189  - info: homeconnect.0 (107315) terminating
                  2024-10-08 13:28:39.192  - info: homeconnect.0 (107315) Terminated (NO_ERROR): Without reason
                  2024-10-08 13:28:39.688  - info: homeconnect.0 (107315) terminating
                  2024-10-08 13:28:40.055  - info: host.iob-master instance system.adapter.homeconnect.0 terminated with code 0 (NO_ERROR)
                  2024-10-08 13:28:40.056  - info: host.iob-master Restart adapter system.adapter.homeconnect.0 because enabled
                  2024-10-08 13:29:11.333  - info: host.iob-master instance system.adapter.homeconnect.0 in version "1.4.1" started with pid 127185
                  2024-10-08 13:29:15.065  - info: homeconnect.0 (127185) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v20.18.0, js-controller: 7.0.0
                  2024-10-08 13:29:15.925  - error: homeconnect.0 (127185) refresh token failed
                  2024-10-08 13:29:15.927  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 400
                  2024-10-08 13:29:15.928  - error: homeconnect.0 (127185) {"error":"invalid_grant","error_description":"invalid refresh_token"}
                  2024-10-08 13:29:15.929  - error: homeconnect.0 (127185) Restart adapter in 20min
                  2024-10-08 13:29:16.030  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 401
                  2024-10-08 13:29:16.031  - error: homeconnect.0 (127185) {"error":{"key":"invalid_token","description":"The access token expired"}}
                  2024-10-08 13:29:16.118  - error: homeconnect.0 (127185) 401 Unauthorized
                  2024-10-08 13:29:16.120  - error: homeconnect.0 (127185) Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
                  2024-10-08 13:29:16.121  - info: homeconnect.0 (127185) Token abgelaufen
                  2024-10-08 13:29:16.228  - error: homeconnect.0 (127185) refresh token failed
                  2024-10-08 13:29:16.229  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 400
                  2024-10-08 13:29:16.230  - error: homeconnect.0 (127185) {"error":"invalid_grant","error_description":"invalid refresh_token"}
                  2024-10-08 13:29:16.231  - error: homeconnect.0 (127185) Restart adapter in 20min
                  Admin 7.2.0 works
                  • D DLaurenz
                                            v.2024-08-12
                             Icon name: computer
                          Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               64 bit
                    User-ID:                0
                    /usr/bin/nodejs         v20.18.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:            99M          0B         99M
                                            admin                   7.2.2
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                47963
                    States:                 43200
                    iob diag:
                    Skript v.2024-08-12
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    root
                    HOME=/root
                    GROUPS=root
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             7862 M total memory
                             2132 M used memory
                             2818 M free memory
                              149 M buffer memory
                             2761 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    *** FILESYSTEM ***
                    /var:
                    5.6G    /var/
                    4.1G    /var/log
                    653M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyACM0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          7.2.2
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        47963
                    States:         43200
                    Pending Updates: 0
                    Admin 7.2.0 works
                    Derda
                    Bei mir das gleiche Problem. Der Log ist bei mir mit >100 MB ala
                    AoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAWBjP2ab8Mb94KhlSJDUAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgMZN/Y0v9ScfRmoGIT7GiPqTf6MtAjyc/aOf0928/MC/5UatL5j+Ij9Feln053DfA5X6yP1TznrAHeRQHO1/GW/4Un3wVTLczzu+w+xn0TV1c/OwUAoCnt2EFplTC8bKwlHDB1kDR9PvGDZ4YEGbMFFuLhqQRTMZUhAASmAwdIW4DUoGNzzEI+FgWEXjuPSD9PJsmjD5Wq2BxIPnDdsoLowuHK51FBKIogmBlVAIXXxEAEaIEHyHE5rMc1yprkzZ
                    zu gesumpft.
                    Ich kann daher nichts inhaltliches zur Lösung beitragen.
                    Danke für den Tipp mit der 7.2.0.
                    Die Version läuft bei mir auch erstmal stabile !
                    • S Shadowhunter23
                      @tomatenforever
                      Zeig mal iob diag
                      tomatenforever
                      @shadowhunter23 Das Downgrade auf 7.2.0 funktioniert. Habe mit der 7.2.0 soeben sogar den js-controller auf 7.0.0 aktualisiert. Keine weiteren Probleme. Danke :)
