  4. Adapter Update funktioniert nicht "Generell"
    2.8k
    2.9k
30 Beiträge 5 Kommentatoren 3.7k Aufrufe 4 Beobachtet
    bishop
    ich wollte mal wieder teilweise paar Adapter aktualisieren z.b. Sonoff wird mir angebote von 3.1.0 auf 3.1.2 wenn ich das starte bekomme ich ein Error zurück.
    $ iobroker upgrade sonoff@3.1.2 --debug
    Update sonoff from @3.1.0 to @3.1.2
    Installing iobroker.sonoff@3.1.2... (System call)
    npm error Cannot read properties of null (reading 'match')
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
    upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
    Process exited with code 0
    In der Log steht.
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@10.7.0
    2 info using node@v18.20.4
    3 silly config:load:file:/usr/lib/node_modules/npm/npmrc
    4 silly config:load:file:/opt/iobroker/.npmrc
    5 silly config:load:file:/home/iobroker/.npmrc
    6 silly config:load:file:/usr/etc/npmrc
    7 verbose title npm install iobroker.sonoff@3.1.2
    8 verbose argv "install" "--save-exact" "iobroker.sonoff@3.1.2" "--foreground-scripts"
    9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-
    10 verbose logfile /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
    11 silly logfile start cleaning logs, removing 1 files
    12 silly logfile done cleaning log files
    13 silly idealTree buildDeps
    14 silly fetch manifest iobroker.sonoff@3.1.2
    15 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
    16 http fetch GET 200 https://registry.npmjs.org/iobroker.sonoff 1528ms (cache revalidated)
    17 silly placeDep ROOT iobroker.sonoff@3.1.2 REPLACE for: iobroker.inst@3.0.0 want: 3.1.2
    18 verbose stack TypeError: Cannot read properties of null (reading 'match')
    18 verbose stack     at getAction (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:148:33)
    18 verbose stack     at diffNode (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:240:18)
    18 verbose stack     at getChildren (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:209:5)
    18 verbose stack     at kidNodes (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:52:18)
    18 verbose stack     at visitNode (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:47:14)
    18 verbose stack     at depth (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:71:10)
    18 verbose stack     at Diff.calculate (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:96:12)
    18 verbose stack     at [diffTrees] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:465:22)
    18 verbose stack     at Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:141:27)
    18 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    19 verbose cwd /opt/iobroker
    20 verbose Linux 6.1.0-26-amd64
    21 verbose node v18.20.4
    22 verbose npm  v10.7.0
    23 error Cannot read properties of null (reading 'match')
    24 verbose exit 1
    25 verbose code 1
    26 silly unfinished npm timer reify 1728378690569
    27 silly unfinished npm timer reify:diffTrees 1728378694604
    28 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
    • Adaptername: Sonoff
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 3.1.0
    • js-controller Version: 6.0.11
    • Admin Version: 7.1.2
    • Hardwaresystem: Proxmox VM
    • Arbeitsspeicher: ...16GB
    • Nodejs-Version: v18.20.4
    • NPM-Version: 10.7.0
    Wenn ich Admin aktualisieren möchte kommt ca. das gleiche, also funktioniert nicht.
    Danke schon mal
    • B bishop
      In der Log steht.
      24 verbose exit 1
      25 verbose code 1
      Danke schon mal
      CodierknechtC Offline
      Codierknecht
      @bishop
      Solltest Du doch wissen: Mit welchem Unterbau bist Du da unterwegs?
      iob diag
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @bishop
        iob diag
        bishop
        @codierknecht
        sorry!!! na klar :)
        ```bash
        Skript v.2024-08-12
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-26-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
        OS is similar to:
        model name      : QEMU Virtual CPU version 2.5+
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         11:17:39 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Tue 2024-10-08 11:17:39 CEST
                   Universal time: Tue 2024-10-08 09:17:39 UTC
                         RTC time: Tue 2024-10-08 09:17:39
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        zeus
        HOME=/home/zeus
        GROUPS=zeus cdrom floppy sudo audio dip video plugdev users netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             33G        6.3G         26G        565K        985M         27G
        Swap:           1.0G          0B        1.0G
        Total:           34G        6.3G         27G
        Active iob-Instances:   55
                32097 M total memory
                 6037 M used memory
                  355 M active memory
                 5913 M inactive memory
                25430 M free memory
                  126 M buffer memory
                  813 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 11:17:40 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
        Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni,  0.0 id, 25.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  32097.1 total,  25429.9 free,   6037.7 used,    939.8 buff/cache
        MiB Swap:    975.0 total,    975.0 free,      0.0 used.  26059.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs   16G     0   16G   0% /dev
        tmpfs          tmpfs     3.2G  556K  3.2G   1% /run
        /dev/sda1      ext4       15G   14G  655M  96% /
        tmpfs          tmpfs      16G     0   16G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
        [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.8G    /var/
        1.4G    /var/log/journal/cb15876e9b724693aa4be33c5fa0a5da
        1.4G    /var/log
        220M    /var/cache
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.7G    /opt/iobroker/iobroker-data/
        1.2G    /opt/iobroker/iobroker-data/sonosCache
        1.1G    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        82M     /opt/iobroker/iobroker-data/states.jsonl
        74M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.20.3-1nodesource1 500
             18.20.2-1nodesource1 500
             18.20.1-1nodesource1 500
             18.20.0-1nodesource1 500
             18.19.1-1nodesource1 500
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.2
        javascript:     8.7.6
        nodejs modules from github:     7
        +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
        +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
        +-- iobroker.paperless-ngx@0.0.5 (git+ssh://git@github.com/BenAhrdt/ioBroker.paperless-ngx.git#494a186aee5d9b01de2117208a39f7e7c33addc7)
        +-- iobroker.sonos@3.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sonos.git#1d98195545b03129423bb575ba8aec7bf6ec105e)
        +-- iobroker.sun2000-modbus@0.1.3 (git+ssh://git@github.com/daolis/ioBroker.sun2000-modbus.git#8def037e7c12b2049f89d890d5f3121090f6d873)
        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.whatsapp-cmb@0.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.whatsapp-cmb.git#56e3e5faad663ca4e2fc5b4117b4a000beb639a6)
        Adapter State
        + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
        + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobroker                                 -  enabled
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          system.adapter.bambulab.0               : bambulab              : iobroker                                 - disabled, port: 8883
        + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.email.0                  : email                 : iobroker                                 - disabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
        + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
          system.adapter.espresense.0             : espresense            : iobroker                                 - disabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.govee-app.0              : govee-app             : iobroker                                 -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
          system.adapter.ham.0                    : ham                   : iobroker                                 - disabled
        + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.intex.0                  : intex                 : iobroker                                 - disabled, port: 8990
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
          system.adapter.lgtv.1                   : lgtv                  : iobroker                                 - disabled
          system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 - disabled
          system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
          system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
        + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker                                 -  enabled, port: 8010
          system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pixelit.0                : pixelit               : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
        + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
        + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 25586, bind: 0.0.0.0
        + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
        + system.adapter.samsung_tizen.1          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
          system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 - disabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.sonoff.1                 : sonoff                : iobroker                                 - disabled, port: 2884, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
        + system.adapter.sun2000-modbus.0         : sun2000-modbus        : iobroker                                 -  enabled, port: 502
          system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.2  [Updatable]
        Adapter    "alarm"        : 3.6.2    , installed 3.6.0  [Updatable]
        Adapter    "alexa-shoppinglist": 1.0.0, installed 1.0.0
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
        Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
        Adapter    "countdown"    : 2.2.0    , installed 2.2.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
        Adapter    "email"        : 1.3.1    , installed 1.2.2  [Updatable]
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
        Adapter    "espresense"   : 0.4.4    , installed 0.4.4
        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.0  [Updatable]
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "intex"        : 0.1.7    , installed 0.1.7
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 8.8.3    , installed 8.7.6  [Updatable]
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
        Adapter    "lightcontrol" : 0.8.0    , installed 0.5.0  [Updatable]
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pixelit"      : 1.1.4    , installed 1.1.3  [Updatable]
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "reolink"      : 1.1.1    , installed 1.1.1
        Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
        Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
        Adapter    "shelly"       : 8.2.1    , installed 7.0.0  [Updatable]
        Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.0  [Updatable]
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "sun2000-modbus": 0.1.3   , installed 0.1.3
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "telegram-menu": 2.0.0    , installed 1.5.1  [Updatable]
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.0 [Updatable]
        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.8 [Updatable]
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        67302
        States:         57777
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15714      535/iobroker.js-con
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15721      535/iobroker.js-con
        tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       22902      1652/io.sainlogic.0
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19646      1135/io.shelly.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18403      1023/io.sonoff.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17886      912/io.mqtt.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          869        1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16638      494/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16673      485/influxd
        tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17641      845/io.hm-rpc.1
        tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       16379      830/io.hm-rpc.0
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          16681      481/node
        tcp6       0      0 :::111                  :::*                    LISTEN      0          871        1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16640      494/sshd: /usr/sbin
        tcp6       0      0 :::3501                 :::*                    LISTEN      1001       19578      1024/io.sonos.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          16710      481/node
        tcp6       0      0 :::3502                 :::*                    LISTEN      1001       64276      1024/io.sonos.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20332      1441/io.simple-api.
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15669      485/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       855052     23109/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22637      1552/io.web.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18628      886/io.mihome-vacuu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22633      1571/io.wled.0
        udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       20536      1048/io.tr-064.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19704      1098/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19705      1098/io.tuya.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          870        1/init
        udp6       0      0 :::111                  :::*                                0          872        1/init
        2024-10-08 11:11:27.982  - info: host.iobroker iobroker upgrade sonoff@3.1.2 --debug
        2024-10-08 11:11:29.945  - info: host.iobroker iobroker Update sonoff from @3.1.0 to @3.1.2
        2024-10-08 11:11:30.088  - info: host.iobroker iobroker NPM version: 10.7.0
        2024-10-08 11:11:30.089  - info: host.iobroker iobroker Installing iobroker.sonoff@3.1.2... (System call)
        2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error Cannot read properties of null (reading 'match')
        2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
        2024-10-08 11:11:35.115  - info: host.iobroker iobroker upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
        2024-10-08 11:11:35.121  - info: host.iobroker iobroker upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
        2024-10-08 11:11:35.124  - info: host.iobroker iobroker upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
        2024-10-08 11:11:35.127  - info: host.iobroker iobroker upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        2024-10-08 11:11:35.130  - info: host.iobroker iobroker upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
        2024-10-08 11:11:35.138  - info: host.iobroker iobroker upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        2024-10-08 11:11:35.141  - info: host.iobroker iobroker upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        2024-10-08 11:11:35.145  - info: host.iobroker iobroker upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        2024-10-08 11:11:35.149  - info: host.iobroker iobroker upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        2024-10-08 11:11:35.152  - info: host.iobroker iobroker upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        2024-10-08 11:11:35.157  - info: host.iobroker iobroker upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        2024-10-08 11:11:35.160  - info: host.iobroker iobroker upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
        2024-10-08 11:11:35.164  - info: host.iobroker iobroker upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
        2024-10-08 11:11:35.168  - info: host.iobroker iobroker upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
        2024-10-08 11:11:35.172  - info: host.iobroker iobroker upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
        2024-10-08 11:11:35.175  - info: host.iobroker iobroker upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
        2024-10-08 11:11:36.195  - info: host.iobroker iobroker exit 0
        2024-10-08 11:17:00.510  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connection closed: closed
        2024-10-08 11:18:03.604  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connected with secret 1728379083603_5620
        Thomas BraunT Ro75R 2 Antworten Letzte Antwort
        • B bishop
          @codierknecht
          sorry!!! na klar :)
          ```bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          zeus
          HOME=/home/zeus
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
          Total:           34G        6.3G         27G
                   6037 M used memory
                    355 M active memory
                  25430 M free memory
                    126 M buffer memory
                    813 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          1.8G    /var/
          1.4G    /var/log
          220M    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.2
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        67302
          States:         57777
          Pending Updates: 0
          @bishop
          Bring den Rest erstmal auf Stand.
          iob update
          iob upgrade all -y
          Und installier zuvor nodejs@20:
          iob nodejs-upadate
            @bishop
            iob update
            iob upgrade all -y
            iob nodejs-upadate
            bishop
            alles erledigt
            === Mark text until here for copying ===
            zeus@iobroker:~$
            bash
            s.jsonl> Skript v.2024-08-12
            > *** BASE SYSTEM ***
            >          Chassis: vm 🖴
            >   Virtualization: kvm
            > Operating System: Debian GNU/Linux 12 (bookworm)
            > OS is similar to:
            > Docker          : false
            > Kernel          : x86_64
            > Userland        : 64 bit
            >  13:39:23 up 16:41,  2 users,  load average: 1.34, 1.34, 1.29
            > CPU threads: 2
            .> *** Time and Time Zones ***
            >                Local time: Tue 2024-10-08 13:39:23 CEST
            >            Universal time: Tue 2024-10-08 11:39:23 UTC
            >                  RTC time: Tue 2024-10-08 11:39:23
            >                 Time zone: Europe/Berlin (CEST, +0200)
            > System clock synchronized: yes
            >               NTP service: active
            >           RTC in local TZ: no
            > zeus
            > HOME=/home/zeus
            > User that is running 'js-controller':
            > iobroker
            > HOME=/home/iobroker
            o> *** Display-Server-Setup ***
            > Desktop:
            > Terminal:       tty
            > Boot Target:    graphical.target
            n> *** MEMORY ***
            >                total        used        free      shared  buff/cache   available
            0.x > Mem:             33G        5.0G         26G        565K        2.9G         28G
            > Swap:           1.0G          0B        1.0G
            > Total:           34G        5.0G         27G
            u>         32097 M total memory
            >          4806 M used memory
            >           883 M active memory
            >          5842 M inactive memory
            >         24925 M free memory
            >           278 M buffer memory
            >          2461 M swap cache
            >           974 M total swap
            >             0 M used swap
            >           974 M free swap
            > *** top - Table Of Processes  ***
            > top - 13:39:24 up 16:41,  2 users,  load average: 1.34, 1.34, 1.29
            > %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            > MiB Mem :  32097.1 total,  24925.6 free,   4806.4 used,   2739.5 buff/cache
            > MiB Swap:    975.0 total,    975.0 free,      0.0 used.  27290.7 avail Mem
            >   UNIT LOAD ACTIVE SUB DESCRIPTION
            > *** FILESYSTEM ***
            > Filesystem     Type      Size  Used Avail Use% Mounted on
            > /dev/sda1      ext4       15G   14G  482M  97% /
            > Messages concerning ext4 filesystem in dmesg:
            > Files in neuralgic directories:
            > /var:
            > 1.8G    /var/
            > 1.4G    /var/log
            > 250M    /var/cache
            > Hint: You are currently not seeing messages from other users and the system.
            >       Users in groups 'adm', 'systemd-journal' can see all messages.
            main amd64 Packages
                 20.4.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                    500 https://d>       Pass -q to turn off this notice.
            > 442M    /opt/iobroker/iobroker-data/files/javascript.admin
            > 410M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            > The five largest files in iobroker-data are:
            > 92M     /opt/iobroker/iobroker-data/objects.jsonl
            > 52M     /opt/iobroker/iobroker-data/states.jsonl
            > USB-Devices by-id:
            > USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
            > HINT:
            > /dev/ttyACM0
            > /usr/bin/nodejs         v20.18.0
            > /usr/bin/node           v20.18.0
            > /usr/bin/npm            10.8.2
            > /usr/bin/npx            10.8.2
            > /usr/bin/corepack       0.29.3
            > nodejs:
            >   Installed: 20.18.0-1nodesource1
            >   Candidate: 20.18.0-1nodesource1
            >   Version table:
            >  *** 20.18.0-1nodesource1 1001
            >      20.17.0-1nodesource1 1001
            >      20.16.0-1nodesource1 1001
            >      20.15.1-1nodesource1 1001
            >      20.15.0-1nodesource1 1001
            >      20.14.0-1nodesource1 1001
            >      20.13.1-1nodesource1 1001
            >      20.13.0-1nodesource1 1001
            >      20.12.2-1nodesource1 1001
            >      20.12.1-1nodesource1 1001
            >      20.12.0-1nodesource1 1001
            >      20.11.1-1nodesource1 1001
            >      20.11.0-1nodesource1 1001
            >      20.10.0-1nodesource1 1001
            >      20.9.0-1nodesource1 1001
            >      20.8.1-1nodesource1 1001
            >      20.8.0-1nodesource1 1001
            >      20.7.0-1nodesource1 1001
            >      20.6.1-1nodesource1 1001
            >      20.6.0-1nodesource1 1001
            >      20.5.1-1nodesource1 1001
            >      20.5.0-1nodesource1 1001
            >      20.2.0-1nodesource1 1001
            >      20.1.0-1nodesource1 1001
            >      20.0.0-1nodesource1 1001
            > Temp directories causing npm8 problem: 0
            > Errors in npm tree:
            > ioBroker Status
            > iobroker is running on this host.
            > Objects type: jsonl
            > States  type: jsonl
            > admin:          7.1.2
            > javascript:     8.7.6
            > Adapter State
            > + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            > + instance is alive
            > Enabled adapters with bindings
            > Adapter    "flot"         : 1.12.0   , installed 1.12.0
            > Adapter    "history"      : 3.0.1    , installed 3.0.1
            > Adapter    "influxdb"     : 4.0.2    , installed 4.0.2
            //deb.nodesource.com/> Adapter    "iot"          : 3.3.0    , installed 3.3.0
            > Adapter    "ping"         : 1.6.2    , installed 1.6.2
            > Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            > Adapter    "vis"          : 1.5.6    , installed 1.5.6
            > Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
            > Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
            > Adapter    "vis-hqwidgets": 1.5.1    , installed 1.5.1
            > Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            > Adapter    "vis-materialdesign": 0.5.9, installed 0.5.9
            > Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
            > Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
            > Objects and States
            > Please stand by - This may take a while
            > Objects:        67302
            > States:         57872
            > *** OS-Repositories and Updates ***
            dmin /o> Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            > Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            > Pending Updates: 0
            > Active Internet connections (only servers)
            > Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
            > tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1001859    30144/iobroker.js-c
            > tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1001864    30144/iobroker.js-c
            > tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       1006587    31231/io.sainlogic.
            > tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1005206    30761/io.shelly.0
            > tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1004033    30630/io.sonoff.0
            > tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1004623    30552/io.mqtt.0
            > tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       1003561    30500/io.hm-rpc.1
            > tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       1002491    30474/io.hm-rpc.0
            > tcp6       0      0 :::3501                 :::*                    LISTEN      1001       1004163    30632/io.sonos.0
            > tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1006842    31013/io.simple-api
            > tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1001959    30165/io.admin.0
            > tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1006290    31128/io.web.0
            > udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1003507    30541/io.mihome-vac
            > udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1006261    31150/io.wled.0
            > udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       1004278    30650/io.tr-064.0
            > udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1005202    30684/io.tuya.0
            > udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1005203    30684/io.tuya.0
            > *** Log File - Last 25 Lines ***
            > 2024-10-08 13:32:08.380  - info: host.iobroker iobroker upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            > 2024-10-08 13:32:08.388  - info: host.iobroker iobroker upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            > 2024-10-08 13:32:08.392  - info: host.iobroker iobroker upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            > 2024-10-08 13:32:08.404  - info: host.iobroker iobroker upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            > 2024-10-08 13:32:08.413  - info: host.iobroker iobroker upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            > 2024-10-08 13:32:08.425  - info: host.iobroker iobroker upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            > 2024-10-08 13:32:08.435  - info: host.iobroker iobroker upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
            > 2024-10-08 13:32:08.444  - info: host.iobroker iobroker upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
            > 2024-10-08 13:32:08.452  - info: host.iobroker iobroker upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
            > 2024-10-08 13:32:08.461  - info: host.iobroker iobroker upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
            > 2024-10-08 13:32:08.471  - info: host.iobroker iobroker upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
            > 2024-10-08 13:32:09.500  - info: host.iobroker iobroker exit 0
            > 2024-10-08 13:33:10.299  - info: web.0 (31128) <== Disconnect system.user.admin from ::ffff:192.168.1.205 iqontrol.0
            > 2024-10-08 13:33:12.340  - info: web.0 (31128) <== Disconnect system.user.admin from ::ffff:192.168.1.205
            > 2024-10-08 13:35:54.012  - info: host.iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 31476
            > 2024-10-08 13:35:55.941  - info: weatherunderground.0 (31476) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.0, js-controller: 6.0.11
            > 2024-10-08 13:36:12.372  - info: weatherunderground.0 (31476) Terminated (NO_ERROR): Without reason
            > 2024-10-08 13:36:12.887  - info: host.iobroker instance system.adapter.weatherunderground.0 having pid 31476 terminated with code 0 (NO_ERROR)
            > 2024-10-08 13:36:20.295  - info: admin.0 (30165) <== Disconnect system.user.admin from ::ffff:192.168.1.205 admin
            > 2024-10-08 13:37:55.308  - info: host.iobroker instance system.adapter.yr.0 in version "5.3.0" started with pid 31543
            > 2024-10-08 13:37:57.349  - info: yr.0 (31543) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.0, js-controller: 6.0.11
            > 2024-10-08 13:37:57.366  - info: yr.0 (31543) longitude/longitude will be set by self-Config - longitude: 9.236412048339844 latitude: 49.186699923402585
            > 2024-10-08 13:38:34.086  - info: yr.0 (31543) Data updated.
            > 2024-10-08 13:38:34.086  - info: yr.0 (31543) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            > 2024-10-08 13:38:34.606  - info: host.iobroker instance system.adapter.yr.0 having pid 31543 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            zeus@iobroker:~$
            zeus@iobroker:~$ ============ Mark until here for C&P =============
            [1] 32831
            bash: ============: Kommando nicht gefunden.
            bash: P: Kommando nicht gefunden.
            [1]+  Exit 127                ============ Mark until here for C
            zeus@iobroker:~$
            zeus@iobroker:~$ iob diag has finished.
            npm error code ELSPROBLEMS
            npm error missing: homebridge-samsung-air-conditioner-smart-things@^1.0.9, required by iobroker.ham@5.3.1
            npm error missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
            npm error A complete log of this run can be found in: /home/zeus/.npm/_logs/2024-10-08T11_42_12_128Z-debug-0.log
            Press any key for a summary
            Copy text starting here:
            ```bash
                                    v.2024-08-12
                     Chassis: vm 🖴
              Virtualization: kvm
            Installation:           kvm
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                1000
            Pending OS-Updates:     0
            Pending iob updates:    16
            Nodejs-Installation:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            MEMORY:
            Mem:             33G        5.2G         25G        569K        2.9G         28G
            Swap:           1.0G          0B        1.0G
            Total:           34G        5.2G         26G
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.1.2
            Objects type: jsonl
            States  type: jsonl
            Objects:                67302
            States:                 57872
            Size of iob-Database:
            56M     /opt/iobroker/iobroker-data/states.jsonl
            EDIT: sehe gerade, dass ich wenig Speicherplatz habe.
            • B bishop
              @codierknecht
              sorry!!! na klar :)
              ```bash
              Skript v.2024-08-12
              *** BASE SYSTEM ***
                       Chassis: vm 🖴
                Virtualization: kvm
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 2
                            NTP service: active
                        RTC in local TZ: no
              zeus
              HOME=/home/zeus
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           1.0G          0B        1.0G
              Total:           34G        6.3G         27G
                       6037 M used memory
                        355 M active memory
                      25430 M free memory
                        126 M buffer memory
                        813 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              *** FILESYSTEM ***
              /var:
              1.8G    /var/
              1.4G    /var/log
              220M    /var/cache
              USB-Devices by-id:
              HINT:
              /dev/ttyACM0
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.1.2
              javascript:     8.7.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        67302
              States:         57777
              Pending Updates: 0
              Ro75R Online
              Ro75R Online
              Ro75
              @bishop sagte in Adapter Update funktioniert nicht "Generell":
              Das wird und ist aber sehr eng und knapp. Dir geht der Speicherplatz aus.
              Ro75.
              • Ro75R Ro75
                Ro75.
                bishop
                schrieb am zuletzt editiert von bishop
                so hab mal den Festplattenplatz erweitert.
                @Thomas-Braun
                iob update
                iob upgrade all -y
                scheint nicht zu fruchten.
                Hab nochmal ein Diag gemacht:
                ```bash
                Skript v.2024-08-12
                *** BASE SYSTEM ***
                         Chassis: vm 🖴
                  Virtualization: kvm
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 17:09:30 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
                CPU threads: 2
                               Local time: Tue 2024-10-08 17:09:30 CEST
                           Universal time: Tue 2024-10-08 15:09:30 UTC
                                 RTC time: Tue 2024-10-08 15:09:30
                              NTP service: active
                          RTC in local TZ: no
                zeus
                HOME=/home/zeus
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             16G        4.9G         11G        561K        785M         11G
                Swap:             0B          0B          0B
                Total:           16G        4.9G         11G
                        15993 M total memory
                         4669 M used memory
                          251 M active memory
                         4656 M inactive memory
                        10802 M free memory
                           66 M buffer memory
                          682 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                top - 17:09:31 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
                Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  15993.1 total,  10802.0 free,   4669.8 used,    749.1 buff/cache
                MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11323.3 avail Mem
                *** FILESYSTEM ***
                udev           devtmpfs  7.8G     0  7.8G   0% /dev
                tmpfs          tmpfs     1.6G  556K  1.6G   1% /run
                /dev/sda1      ext4       30G   11G   18G  39% /
                tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                /var:
                1.7G    /var/
                1.4G    /var/log
                200M    /var/lib
                1.7G    /opt/iobroker/iobroker-data/
                408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                122M    /opt/iobroker/iobroker-data/objects.jsonl
                105M    /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.1.2
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        67302
                States:         57872
                Pending Updates: 0
                tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          15078      653/node
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16383      658/influxd
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       19545      1213/io.sonoff.0
                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19117      1361/io.shelly.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18187      1146/io.mqtt.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15057      666/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1722       1/init
                tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       21210      1836/io.sainlogic.0
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       16443      709/iobroker.js-con
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16438      709/iobroker.js-con
                tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       17141      1068/io.hm-rpc.0
                tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17192      1094/io.hm-rpc.1
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        15089      658/influxd
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20462      1620/io.simple-api.
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20964      1728/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17489      759/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15059      666/sshd: /usr/sbin
                tcp6       0      0 :::111                  :::*                    LISTEN      0          1724       1/init
                tcp6       0      0 :::3500                 :::*                    LISTEN      0          15091      653/node
                tcp6       0      0 :::3501                 :::*                    LISTEN      1001       18779      1230/io.sonos.0
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17285      1135/io.mihome-vacu
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21963      1746/io.wled.0
                udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       18913      1253/io.tr-064.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19701      1260/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19702      1260/io.tuya.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1723       1/init
                udp6       0      0 :::111                  :::*                                0          1725       1/init
                2024-10-08 17:04:56.812  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.113
                2024-10-08 17:04:56.817  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.2
                2024-10-08 17:04:56.822  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.92
                2024-10-08 17:04:56.828  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.6
                2024-10-08 17:04:56.833  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.39
                2024-10-08 17:04:56.839  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.124
                2024-10-08 17:04:56.846  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.222
                2024-10-08 17:04:56.853  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.31
                2024-10-08 17:04:56.858  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.30
                2024-10-08 17:04:56.864  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.246
                2024-10-08 17:04:56.869  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.55
                2024-10-08 17:04:56.875  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                192.168.1.8
                2024-10-08 17:06:12.393  - info: admin.0 (759) ==> Connected system.user.admin from ::ffff:192.168.1.176
                • B bishop
                  @Thomas-Braun
                  iob update
                  iob upgrade all -y
                  ```bash
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                    Virtualization: kvm
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 2
                                NTP service: active
                            RTC in local TZ: no
                  zeus
                  HOME=/home/zeus
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                  Total:           16G        4.9G         11G
                           4669 M used memory
                            251 M active memory
                          10802 M free memory
                             66 M buffer memory
                            682 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  /var:
                  1.7G    /var/
                  1.4G    /var/log
                  200M    /var/lib
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.1.2
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        67302
                  States:         57872
                  Pending Updates: 0
                  192.168.1.113
                  192.168.1.2
                  192.168.1.92
                  192.168.1.6
                  192.168.1.39
                  192.168.1.124
                  192.168.1.222
                  192.168.1.31
                  192.168.1.30
                  192.168.1.246
                  192.168.1.55
                  192.168.1.8
                  Was wird denn dazu gemeldet?
                    bishop
                    läuft durch ohne fehler
                    • B bishop
                      @bishop
                      iob update
                      iob upgrade admin@7.1.5
                      Bitte vollständig Ein- wie Ausgaben posten, nix nacherzählen.
                        @bishop
                        iob update
                        bishop
                        @thomas-braun sagte in Adapter Update funktioniert nicht "Generell":
                        iob update
                        zeus@iobroker:~$ iob update
                        zeus@iobroker:~$ ^C
                        zeus@iobroker:~$ iob upgrade admin@7.1.5
                        This upgrade of "admin" will introduce the following changes:
                        -> 7.1.5:
                        Added the read-only flag to the `state` JSON Config component
                        -> 7.1.3:
                        improve appearance and standardization of some warning messages
                        indicate `alert` warnings by the badge color on the notification button
                        allow to distinguish between alert notifications and others for host notifications
                        do not automatically open the notification dialog without user interaction
                        fixed logging as socket client is now throwing real errors
                        Would you like to upgrade admin from @7.1.2 to @7.1.5 now? [(y)es, (n)o]: y
                        Update admin from @7.1.2 to @7.1.5
                        host.iobroker Adapter "system.adapter.admin.0" is stopped.
                        NPM version: 10.8.2
                        Installing iobroker.admin@7.1.5... (System call)
                        upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                        host.iobroker Adapter "system.adapter.admin.0" is started
                        zeus@iobroker:~$ ^C
                        zeus@iobroker:~$
                        Ro75R 1 Antwort Letzte Antwort
                        • B bishop
                          iob update
                          zeus@iobroker:~$ ^C
                          -> 7.1.5:
                          -> 7.1.3:
                          NPM version: 10.8.2
                          zeus@iobroker:~$ ^C
                          zeus@iobroker:~$
                          Ro75R Online
                          Ro75R Online
                          Ro75
                          ^C
                          Warum "ABBRUCH"??
                          Ro75.
                          • Ro75R Ro75
                            ^C
                            Warum "ABBRUCH"??
                            Ro75.
                            bishop
                            @ro75
                            strg + c
                            kopieren aus der Console raus
                            -> 7.1.5:
                            -> 7.1.3:
                            NPM version: 10.8.2
                            zeus@iobroker:~$
                            • B bishop
                              @ro75
                              strg + c
                              -> 7.1.5:
                              -> 7.1.3:
                              NPM version: 10.8.2
                              zeus@iobroker:~$
                              Codierknecht
                              @bishop
                              Was passiert, wenn Du Dich in /opt/iobroker stellst und dort das Update anschubst?
                              B H 2 Antworten Letzte Antwort
                                @bishop
                                bishop
                                @codierknecht
                                dank für die Hilfe :)
                                zeus@iobroker:/opt/iobroker$ iob upgrade admin@7.1.5
                                -> 7.1.5:
                                -> 7.1.3:
                                NPM version: 10.8.2
                                zeus@iobroker:/opt/iobroker$ iob update
                                aber er macht es einfach nicht
                                  bishop
                                  so hab jetzt mal eine neue VM aufgesetz und alles komplett neu installiert.
                                  Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json":
                                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                  Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                                  Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                  Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
                                  Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
                                  Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                  Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                  Adapter    "shuttercontrol": 1.7.3   , installed 1.8.2
                                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                  Adapter    "telegram-menu": 2.0.0    , installed 2.0.0
                                  Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  zeus@iobroker:~$
                                  muss ich mir um den repository hash sorgen machen?
                                  edit: jetzt kommt es nicht mehr :)
                                    @bishop
                                    HannoSch
                                    @codierknecht Ich habe auch das Problem, dass sich Adapter nicht aktualisieren lassen. Habe den Tread mal durchgearbeitet, komme aber nicht weiter.
                                    hier mein System:
                                                            v.2025-02-23
                                           Icon name: computer
                                              Kernel: Linux 6.6.62+rpt-rpi-v8
                                        Architecture: arm64
                                    Kernel:                 aarch64
                                    Userland:               64 bit
                                    Timezone:               Europe/Berlin (CET, +0100)
                                    User-ID:                1000
                                    Boot Target:            multi-user.target
                                    Pending OS-Updates:     1
                                    /usr/bin/nodejs         v20.19.0
                                    /usr/bin/node           v20.19.0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.31.0
                                    Recommended versions are nodejs 20.19.0 and npm 10.8.2
                                    nodeJS installation is correct
                                    MEMORY:
                                    Mem:            8.2G        1.5G        619M        290K        6.2G        6.7G
                                    Swap:           536M        5.8M        531M
                                    Total:          8.7G        1.6G        1.2G
                                    Active iob-Instances:   19
                                    Upgrade policy: patch
                                    ioBroker Core:          js-controller           7.0.6
                                                            admin                   7.4.10
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                3563
                                    States:                 2473
                                    15M     /opt/iobroker/iobroker-data/objects.jsonl
                                    1.2M    /opt/iobroker/iobroker-data/states.jsonl
                                    337 CRITICAL ERRORS DETECTED!
                                    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                    Das die letzte Fehlermeldung:
                                    hanno@iobroker:~ $ cd /opt/iobroker
                                    hanno@iobroker:/opt/iobroker $ iob stop
                                    hanno@iobroker:/opt/iobroker $ iob update
                                    Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                    Adapter    "bsblan"       : 0.3.4    , installed 0.3.4
                                    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
                                    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                                    Adapter    "fb-checkpresence": 1.3.1 , installed 1.2.8  [Updatable]
                                    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
                                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                    Controller "js-controller": 7.0.6    , installed 7.0.6
                                    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                    Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                                    hanno@iobroker:/opt/iobroker $ iob upgrade all -y
                                    Update fb-checkpresence from @1.2.8 to @1.3.1
                                    NPM version: 10.8.2
                                    Installing iobroker.fb-checkpresence@1.3.1... (System call)
                                    npm error code Unknown system error -74
                                    npm error syscall mkdir
                                    npm error path /opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj
                                    npm error errno -74
                                    npm error Unknown system error -74: Unknown system error -74, mkdir '/opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj'
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-03-23T12_42_27_746Z-debug-0.log
                                    host.iobroker Cannot install iobroker.fb-checkpresence@1.3.1: 182
                                    Vielleicht kannst du mir ja helfen. Vielen Dank.
                                    • H HannoSch
                                      hier mein System:
                                                              v.2025-02-23
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      MEMORY:
                                                              admin                   7.4.10
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                3563
                                      States:                 2473
                                      NPM version: 10.8.2
                                      npm error errno -74
                                      @hannosch sagte in Adapter Update funktioniert nicht "Generell":
                                      Was ist denn da los?
                                      H 1 Antwort Letzte Antwort
                                        HannoSch
                                        @thomas-braun das hier:
                                        hanno@iobroker:~ $ sudo dmesg --level=emerg,alert,crit -T
                                        [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                        [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                        [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                        [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                        [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                        [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                        [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                        [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                        [Sun Mar  9 12:17:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:17:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:17:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:19:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:19:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:20:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:28:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:28:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:29:06 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:29:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:29:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:32:28 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:32:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:33:39 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:40:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:41:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:42:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 12:42:35 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:42:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar  9 14:59:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 14:59:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 14:59:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 15:13:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:07:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:08:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:09:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:11:47 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:11:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar  9 16:14:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 11 17:34:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 11 17:37:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Thu Mar 13 12:53:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Thu Mar 13 12:54:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Thu Mar 13 17:52:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 16 10:56:56 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:09:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:10:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:10:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:18:48 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 16 11:21:10 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 16 11:26:58 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:02 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:08 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm setfacl: Directory block failed checksum
                                        [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:29:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 16 11:36:20 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 16 11:41:29 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:53:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 16 12:00:42 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 12:00:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 12:01:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 12:01:35 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 12:02:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Tue Mar 18 18:02:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 18:04:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 18:04:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 18:11:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 18:14:45 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 18:20:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:02:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:07:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:07:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:08:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:08:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:08:12 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:08:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Tue Mar 18 19:09:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:09:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:22:40 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 19:49:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 21:05:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 21:06:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Wed Mar 19 12:14:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 12:22:13 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 12:25:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 12:27:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 16:18:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 16:19:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 17:19:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 17:20:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Wed Mar 19 18:08:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Fri Mar 21 18:25:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Fri Mar 21 18:26:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Fri Mar 21 18:31:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Fri Mar 21 18:32:49 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 23 12:57:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 23 12:58:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 23 13:00:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                        [Sun Mar 23 13:02:44 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 23 13:18:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:53 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525085: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525070: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525082: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407146: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395906: comm chown: Directory block failed checksum
                                        [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:22:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                        [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                        [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                        [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                        [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm du: Directory block failed checksum
                                        [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                                        [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                                        • H HannoSch
                                          === Mark text until here for copying ===
                                          @hannosch
                                          Dein Dateisystem hat 'nen Schuss. Und deswegen kann bei der Installation auch das Verzeichnis nicht angelegt werden.
