  4. Adapter Update funktioniert nicht "Generell"
    1.0k
    6.1k
30 Beiträge 5 Kommentatoren 4.5k Aufrufe 4 Beobachtet
  • B bishop
    @codierknecht
    sorry!!! na klar :)
    ```bash
    Skript v.2024-08-12
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-26-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:17:39 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Tue 2024-10-08 11:17:39 CEST
               Universal time: Tue 2024-10-08 09:17:39 UTC
                     RTC time: Tue 2024-10-08 09:17:39
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    zeus
    HOME=/home/zeus
    GROUPS=zeus cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             33G        6.3G         26G        565K        985M         27G
    Swap:           1.0G          0B        1.0G
    Total:           34G        6.3G         27G
    Active iob-Instances:   55
            32097 M total memory
             6037 M used memory
              355 M active memory
             5913 M inactive memory
            25430 M free memory
              126 M buffer memory
              813 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 11:17:40 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
    Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni,  0.0 id, 25.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  32097.1 total,  25429.9 free,   6037.7 used,    939.8 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  26059.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs   16G     0   16G   0% /dev
    tmpfs          tmpfs     3.2G  556K  3.2G   1% /run
    /dev/sda1      ext4       15G   14G  655M  96% /
    tmpfs          tmpfs      16G     0   16G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
    [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.8G    /var/
    1.4G    /var/log/journal/cb15876e9b724693aa4be33c5fa0a5da
    1.4G    /var/log
    220M    /var/cache
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.7G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/sonosCache
    1.1G    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    82M     /opt/iobroker/iobroker-data/states.jsonl
    74M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.3-1nodesource1 500
         18.20.2-1nodesource1 500
         18.20.1-1nodesource1 500
         18.20.0-1nodesource1 500
         18.19.1-1nodesource1 500
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.2
    javascript:     8.7.6
    nodejs modules from github:     7
    +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
    +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
    +-- iobroker.paperless-ngx@0.0.5 (git+ssh://git@github.com/BenAhrdt/ioBroker.paperless-ngx.git#494a186aee5d9b01de2117208a39f7e7c33addc7)
    +-- iobroker.sonos@3.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sonos.git#1d98195545b03129423bb575ba8aec7bf6ec105e)
    +-- iobroker.sun2000-modbus@0.1.3 (git+ssh://git@github.com/daolis/ioBroker.sun2000-modbus.git#8def037e7c12b2049f89d890d5f3121090f6d873)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.whatsapp-cmb@0.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.whatsapp-cmb.git#56e3e5faad663ca4e2fc5b4117b4a000beb639a6)
    Adapter State
    + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      system.adapter.bambulab.0               : bambulab              : iobroker                                 - disabled, port: 8883
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.email.0                  : email                 : iobroker                                 - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
    + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
      system.adapter.espresense.0             : espresense            : iobroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.govee-app.0              : govee-app             : iobroker                                 -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      system.adapter.ham.0                    : ham                   : iobroker                                 - disabled
    + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.intex.0                  : intex                 : iobroker                                 - disabled, port: 8990
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
      system.adapter.lgtv.1                   : lgtv                  : iobroker                                 - disabled
      system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 - disabled
      system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
      system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
    + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker                                 -  enabled, port: 8010
      system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pixelit.0                : pixelit               : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
    + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 25586, bind: 0.0.0.0
    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
    + system.adapter.samsung_tizen.1          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
      system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 - disabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.sonoff.1                 : sonoff                : iobroker                                 - disabled, port: 2884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.sun2000-modbus.0         : sun2000-modbus        : iobroker                                 -  enabled, port: 502
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.2  [Updatable]
    Adapter    "alarm"        : 3.6.2    , installed 3.6.0  [Updatable]
    Adapter    "alexa-shoppinglist": 1.0.0, installed 1.0.0
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
    Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
    Adapter    "email"        : 1.3.1    , installed 1.2.2  [Updatable]
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "espresense"   : 0.4.4    , installed 0.4.4
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.0  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "intex"        : 0.1.7    , installed 0.1.7
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.7.6  [Updatable]
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "lightcontrol" : 0.8.0    , installed 0.5.0  [Updatable]
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pixelit"      : 1.1.4    , installed 1.1.3  [Updatable]
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "reolink"      : 1.1.1    , installed 1.1.1
    Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
    Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 8.2.1    , installed 7.0.0  [Updatable]
    Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.0  [Updatable]
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "sun2000-modbus": 0.1.3   , installed 0.1.3
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.0.0    , installed 1.5.1  [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.0 [Updatable]
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.8 [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        67302
    States:         57777
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15714      535/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15721      535/iobroker.js-con
    tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       22902      1652/io.sainlogic.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19646      1135/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18403      1023/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17886      912/io.mqtt.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          869        1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16638      494/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16673      485/influxd
    tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17641      845/io.hm-rpc.1
    tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       16379      830/io.hm-rpc.0
    tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          16681      481/node
    tcp6       0      0 :::111                  :::*                    LISTEN      0          871        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16640      494/sshd: /usr/sbin
    tcp6       0      0 :::3501                 :::*                    LISTEN      1001       19578      1024/io.sonos.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      0          16710      481/node
    tcp6       0      0 :::3502                 :::*                    LISTEN      1001       64276      1024/io.sonos.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20332      1441/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15669      485/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       855052     23109/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22637      1552/io.web.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18628      886/io.mihome-vacuu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22633      1571/io.wled.0
    udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       20536      1048/io.tr-064.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19704      1098/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19705      1098/io.tuya.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          870        1/init
    udp6       0      0 :::111                  :::*                                0          872        1/init
    2024-10-08 11:11:27.982  - info: host.iobroker iobroker upgrade sonoff@3.1.2 --debug
    2024-10-08 11:11:29.945  - info: host.iobroker iobroker Update sonoff from @3.1.0 to @3.1.2
    2024-10-08 11:11:30.088  - info: host.iobroker iobroker NPM version: 10.7.0
    2024-10-08 11:11:30.089  - info: host.iobroker iobroker Installing iobroker.sonoff@3.1.2... (System call)
    2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error Cannot read properties of null (reading 'match')
    2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
    2024-10-08 11:11:35.115  - info: host.iobroker iobroker upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2024-10-08 11:11:35.121  - info: host.iobroker iobroker upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2024-10-08 11:11:35.124  - info: host.iobroker iobroker upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2024-10-08 11:11:35.127  - info: host.iobroker iobroker upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2024-10-08 11:11:35.130  - info: host.iobroker iobroker upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2024-10-08 11:11:35.138  - info: host.iobroker iobroker upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2024-10-08 11:11:35.141  - info: host.iobroker iobroker upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2024-10-08 11:11:35.145  - info: host.iobroker iobroker upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2024-10-08 11:11:35.149  - info: host.iobroker iobroker upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2024-10-08 11:11:35.152  - info: host.iobroker iobroker upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2024-10-08 11:11:35.157  - info: host.iobroker iobroker upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2024-10-08 11:11:35.160  - info: host.iobroker iobroker upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
    2024-10-08 11:11:35.164  - info: host.iobroker iobroker upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
    2024-10-08 11:11:35.168  - info: host.iobroker iobroker upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
    2024-10-08 11:11:35.172  - info: host.iobroker iobroker upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
    2024-10-08 11:11:35.175  - info: host.iobroker iobroker upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
    2024-10-08 11:11:36.195  - info: host.iobroker iobroker exit 0
    2024-10-08 11:17:00.510  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connection closed: closed
    2024-10-08 11:18:03.604  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connected with secret 1728379083603_5620
    Ro75R Offline
    Ro75R Offline
    Ro75
    @bishop sagte in Adapter Update funktioniert nicht "Generell":
    Das wird und ist aber sehr eng und knapp. Dir geht der Speicherplatz aus.
    Ro75.
    • Ro75R Ro75
      Ro75.
      bishop
      schrieb am zuletzt editiert von bishop
      so hab mal den Festplattenplatz erweitert.
      @Thomas-Braun
      iob update
      iob upgrade all -y
      scheint nicht zu fruchten.
      Hab nochmal ein Diag gemacht:
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
       17:09:30 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
      CPU threads: 2
                     Local time: Tue 2024-10-08 17:09:30 CEST
                 Universal time: Tue 2024-10-08 15:09:30 UTC
                       RTC time: Tue 2024-10-08 15:09:30
                    NTP service: active
                RTC in local TZ: no
      zeus
      HOME=/home/zeus
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        4.9G         11G        561K        785M         11G
      Swap:             0B          0B          0B
      Total:           16G        4.9G         11G
              15993 M total memory
               4669 M used memory
                251 M active memory
               4656 M inactive memory
              10802 M free memory
                 66 M buffer memory
                682 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 17:09:31 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
      Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15993.1 total,  10802.0 free,   4669.8 used,    749.1 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11323.3 avail Mem
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  556K  1.6G   1% /run
      /dev/sda1      ext4       30G   11G   18G  39% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      /var:
      1.7G    /var/
      1.4G    /var/log
      200M    /var/lib
      1.7G    /opt/iobroker/iobroker-data/
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      122M    /opt/iobroker/iobroker-data/objects.jsonl
      105M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.1.2
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        67302
      States:         57872
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Pending Updates: 0
      tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          15078      653/node
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16383      658/influxd
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       19545      1213/io.sonoff.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19117      1361/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18187      1146/io.mqtt.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15057      666/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1722       1/init
      tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       21210      1836/io.sainlogic.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       16443      709/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16438      709/iobroker.js-con
      tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       17141      1068/io.hm-rpc.0
      tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17192      1094/io.hm-rpc.1
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15089      658/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20462      1620/io.simple-api.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20964      1728/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17489      759/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15059      666/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1724       1/init
      tcp6       0      0 :::3500                 :::*                    LISTEN      0          15091      653/node
      tcp6       0      0 :::3501                 :::*                    LISTEN      1001       18779      1230/io.sonos.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17285      1135/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21963      1746/io.wled.0
      udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       18913      1253/io.tr-064.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19701      1260/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19702      1260/io.tuya.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1723       1/init
      udp6       0      0 :::111                  :::*                                0          1725       1/init
      2024-10-08 17:04:56.812  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.113
      2024-10-08 17:04:56.817  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.2
      2024-10-08 17:04:56.822  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.92
      2024-10-08 17:04:56.828  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.6
      2024-10-08 17:04:56.833  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.39
      2024-10-08 17:04:56.839  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.124
      2024-10-08 17:04:56.846  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.222
      2024-10-08 17:04:56.853  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.31
      2024-10-08 17:04:56.858  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.30
      2024-10-08 17:04:56.864  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.246
      2024-10-08 17:04:56.869  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.55
      2024-10-08 17:04:56.875  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
      192.168.1.8
      2024-10-08 17:06:12.393  - info: admin.0 (759) ==> Connected system.user.admin from ::ffff:192.168.1.176
      • B bishop
        @Thomas-Braun
        iob update
        iob upgrade all -y
        ```bash
        Skript v.2024-08-12
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        zeus
        HOME=/home/zeus
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
        Total:           16G        4.9G         11G
                 4669 M used memory
                  251 M active memory
                10802 M free memory
                   66 M buffer memory
                  682 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        1.7G    /var/
        1.4G    /var/log
        200M    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.1.2
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        67302
        States:         57872
        Pending Updates: 0
        192.168.1.113
        192.168.1.2
        192.168.1.92
        192.168.1.6
        192.168.1.39
        192.168.1.124
        192.168.1.222
        192.168.1.31
        192.168.1.30
        192.168.1.246
        192.168.1.55
        192.168.1.8
        Was wird denn dazu gemeldet?
          bishop
          läuft durch ohne fehler
          • B bishop
            @bishop
            iob update
            iob upgrade admin@7.1.5
            Bitte vollständig Ein- wie Ausgaben posten, nix nacherzählen.
              @bishop
              iob update
              bishop
              @thomas-braun sagte in Adapter Update funktioniert nicht "Generell":
              iob update
              zeus@iobroker:~$ iob update
              zeus@iobroker:~$ ^C
              zeus@iobroker:~$ iob upgrade admin@7.1.5
              This upgrade of "admin" will introduce the following changes:
              -> 7.1.5:
              Added the read-only flag to the `state` JSON Config component
              -> 7.1.3:
              improve appearance and standardization of some warning messages
              indicate `alert` warnings by the badge color on the notification button
              allow to distinguish between alert notifications and others for host notifications
              do not automatically open the notification dialog without user interaction
              fixed logging as socket client is now throwing real errors
              Would you like to upgrade admin from @7.1.2 to @7.1.5 now? [(y)es, (n)o]: y
              Update admin from @7.1.2 to @7.1.5
              host.iobroker Adapter "system.adapter.admin.0" is stopped.
              NPM version: 10.8.2
              Installing iobroker.admin@7.1.5... (System call)
              upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
              upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
              upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
              upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
              upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
              upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
              upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
              upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
              upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
              upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
              upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
              upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
              upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
              upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
              upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
              upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
              host.iobroker Adapter "system.adapter.admin.0" is started
              zeus@iobroker:~$ ^C
              zeus@iobroker:~$
              Ro75R 1 Antwort Letzte Antwort
              • B bishop
                iob update
                zeus@iobroker:~$ ^C
                -> 7.1.5:
                -> 7.1.3:
                NPM version: 10.8.2
                zeus@iobroker:~$ ^C
                zeus@iobroker:~$
                Ro75R Offline
                Ro75R Offline
                Ro75
                ^C
                Warum "ABBRUCH"??
                Ro75.
                • Ro75R Ro75
                  ^C
                  Warum "ABBRUCH"??
                  Ro75.
                  bishop
                  @ro75
                  strg + c
                  kopieren aus der Console raus
                  -> 7.1.5:
                  -> 7.1.3:
                  NPM version: 10.8.2
                  zeus@iobroker:~$
                  • B bishop
                    @ro75
                    strg + c
                    -> 7.1.5:
                    -> 7.1.3:
                    NPM version: 10.8.2
                    zeus@iobroker:~$
                    CodierknechtC Online
                    Codierknecht
                    @bishop
                    Was passiert, wenn Du Dich in /opt/iobroker stellst und dort das Update anschubst?
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    B H 2 Antworten Letzte Antwort
                    • CodierknechtC Codierknecht
                      @bishop
                      bishop
                      @codierknecht
                      dank für die Hilfe :)
                      zeus@iobroker:/opt/iobroker$ iob upgrade admin@7.1.5
                      -> 7.1.5:
                      -> 7.1.3:
                      NPM version: 10.8.2
                      zeus@iobroker:/opt/iobroker$ iob update
                      aber er macht es einfach nicht
                        bishop
                        so hab jetzt mal eine neue VM aufgesetz und alles komplett neu installiert.
                        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json":
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                        Adapter    "email"        : 1.3.1    , installed 1.3.1
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
                        Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
                        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                        Adapter    "shuttercontrol": 1.7.3   , installed 1.8.2
                        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                        Adapter    "telegram-menu": 2.0.0    , installed 2.0.0
                        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        zeus@iobroker:~$
                        muss ich mir um den repository hash sorgen machen?
                        edit: jetzt kommt es nicht mehr :)
                          @bishop
                          HannoSch
                          @codierknecht Ich habe auch das Problem, dass sich Adapter nicht aktualisieren lassen. Habe den Tread mal durchgearbeitet, komme aber nicht weiter.
                          hier mein System:
                          Copy text starting here:
                                                  v.2025-02-23
                                 Icon name: computer
                                    Kernel: Linux 6.6.62+rpt-rpi-v8
                              Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               64 bit
                          Timezone:               Europe/Berlin (CET, +0100)
                          User-ID:                1000
                          Boot Target:            multi-user.target
                          Pending OS-Updates:     1
                          Pending iob updates:    1
                          Nodejs-Installation:
                          /usr/bin/nodejs         v20.19.0
                          /usr/bin/node           v20.19.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.31.0
                          Recommended versions are nodejs 20.19.0 and npm 10.8.2
                          nodeJS installation is correct
                          MEMORY:
                          Mem:            8.2G        1.5G        619M        290K        6.2G        6.7G
                          Swap:           536M        5.8M        531M
                          Total:          8.7G        1.6G        1.2G
                          Active iob-Instances:   19
                          Upgrade policy: patch
                          ioBroker Core:          js-controller           7.0.6
                                                  admin                   7.4.10
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                3563
                          States:                 2473
                          Size of iob-Database:
                          15M     /opt/iobroker/iobroker-data/objects.jsonl
                          1.2M    /opt/iobroker/iobroker-data/states.jsonl
                          337 CRITICAL ERRORS DETECTED!
                          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                          Operating System is the current Debian stable version codenamed 'bookworm'!
                          === Mark text until here for copying ===
                          Das die letzte Fehlermeldung:
                          hanno@iobroker:~ $ cd /opt/iobroker
                          hanno@iobroker:/opt/iobroker $ iob stop
                          hanno@iobroker:/opt/iobroker $ iob update
                          Adapter    "admin"        : 7.4.10   , installed 7.4.10
                          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                          Adapter    "bsblan"       : 0.3.4    , installed 0.3.4
                          Adapter    "bshb"         : 0.5.0    , installed 0.5.0
                          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                          Adapter    "fb-checkpresence": 1.3.1 , installed 1.2.8  [Updatable]
                          Adapter    "go-e"         : 1.0.41   , installed 1.0.41
                          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                          Controller "js-controller": 7.0.6    , installed 7.0.6
                          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                          Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                          hanno@iobroker:/opt/iobroker $ iob upgrade all -y
                          Update fb-checkpresence from @1.2.8 to @1.3.1
                          NPM version: 10.8.2
                          Installing iobroker.fb-checkpresence@1.3.1... (System call)
                          npm error code Unknown system error -74
                          npm error syscall mkdir
                          npm error path /opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj
                          npm error errno -74
                          npm error Unknown system error -74: Unknown system error -74, mkdir '/opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj'
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-03-23T12_42_27_746Z-debug-0.log
                          host.iobroker Cannot install iobroker.fb-checkpresence@1.3.1: 182
                          Vielleicht kannst du mir ja helfen. Vielen Dank.
                          • H HannoSch
                            hier mein System:
                                                    v.2025-02-23
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                                                    admin                   7.4.10
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                3563
                            States:                 2473
                            NPM version: 10.8.2
                            npm error errno -74
                            @hannosch sagte in Adapter Update funktioniert nicht "Generell":
                            Was ist denn da los?
                            H 1 Antwort Letzte Antwort
                              HannoSch
                              @thomas-braun das hier:
                              hanno@iobroker:~ $ sudo dmesg --level=emerg,alert,crit -T
                              [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                              [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                              [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                              [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                              [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                              [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                              [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                              [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                              [Sun Mar  9 12:17:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:17:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:17:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:19:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:19:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:20:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:28:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:28:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:29:06 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:29:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:29:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:32:28 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:32:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:33:39 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:40:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:41:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:42:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 12:42:35 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:42:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar  9 14:59:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 14:59:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 14:59:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 15:13:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:07:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:08:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:09:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:11:47 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:11:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar  9 16:14:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 11 17:34:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 11 17:37:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Thu Mar 13 12:53:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Thu Mar 13 12:54:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Thu Mar 13 17:52:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 16 10:56:56 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:09:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:10:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:10:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:18:48 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 16 11:21:10 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 16 11:26:58 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:02 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:08 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm setfacl: Directory block failed checksum
                              [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:29:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 16 11:36:20 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 16 11:41:29 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:53:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 16 12:00:42 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 12:00:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 12:01:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 12:01:35 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 12:02:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Tue Mar 18 18:02:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 18:04:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 18:04:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 18:11:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 18:14:45 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 18:20:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:02:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:07:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:07:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:08:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:08:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:08:12 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:08:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Tue Mar 18 19:09:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:09:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:22:40 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 19:49:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 21:05:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 21:06:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Wed Mar 19 12:14:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 12:22:13 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 12:25:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 12:27:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 16:18:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 16:19:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 17:19:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 17:20:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Wed Mar 19 18:08:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Fri Mar 21 18:25:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Fri Mar 21 18:26:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Fri Mar 21 18:31:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Fri Mar 21 18:32:49 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 23 12:57:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 23 12:58:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 23 13:00:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                              [Sun Mar 23 13:02:44 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 23 13:18:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:53 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525085: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525070: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525082: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407146: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395906: comm chown: Directory block failed checksum
                              [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm find: Directory block failed checksum
                              [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm find: Directory block failed checksum
                              [Sun Mar 23 13:22:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                              [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                              [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                              [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                              [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm du: Directory block failed checksum
                              [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                              [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                              • H HannoSch
                                @hannosch
                                Dein Dateisystem hat 'nen Schuss. Und deswegen kann bei der Installation auch das Verzeichnis nicht angelegt werden.
                                  @hannosch
                                  HannoSch
                                  @thomas-braun Danke dir. Gibt es Hilfe in deinen Links? Dann suche ich mal.
                                  • H HannoSch
                                    Ro75R Offline
                                    Ro75R Offline
                                    Ro75
                                    @hannosch ziehst du öfters den Stecker beim Raspi? Ggfs. ist deine SD-Karte auch hinüber. Du solltest vielleicht die Karte tauschen. Du machst doch hoffentlich Backups?
                                    Ro75.
                                    • Ro75R Ro75
                                      Ro75.
                                      HannoSch
                                      @ro75 nein, normalerweise nicht. Wir hatten nur letztens Stromausfall durch Zählertausch. Muss mir wohl mal ne USV anschaffen. IOB funktioniert ja noch ohne Probleme, nur halt der Adapter-Update nicht.
                                      • H HannoSch
                                        Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        Darauf würde ich nun nicht wetten, denn einiges funktioniert ja schon nicht mehr.
                                        Ro75.
                                        • Ro75R Ro75
                                          Ro75.
                                          HannoSch
                                          @ro75 Na dann mache ich mal ne neue Karte rein, Backup's sind da.
                                          Vielen Danke erstmal.
                                          Hanno
