Meine Blockly-Skripte funktionieren nach Updates nicht mehr
@thomas-braun said in Meine Blockly-Skripte funktionieren nach Updates nicht mehr:
Bring das auf nodejs@20.
Update läuft!
Update ist durch.
Leider startet iobroker nicht mehr
Hier das Ergebnis von iob diag======================= SUMMARY ======================= v.2024-05-22 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: 32 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: false Boot Target: graphical.target Pending OS-Updates: 0 node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) Pending iob updates: 0 Nodejs-Installation: nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs) /usr/bin/nodejs nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs) node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) /usr/bin/node node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) /usr/bin/npm node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) /usr/bin/npx node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) /usr/bin/corepack node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.8G 163M 3.3G 8.0M 400M 3.6G Swap: 99M 0B 99M Total: 3.9G 163M 3.4G Active iob-Instances: 0 node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) ioBroker Core: js-controller node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) admin node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node) ioBroker Status: Status admin and web instance: Objects: 0 States: 0 Size of iob-Database: 13M /opt/iobroker/iobroker-data/objects.jsonl 3.9M /opt/iobroker/iobroker-data/objects.json.migrated 3.9M /opt/iobroker/iobroker-data/objects.json.bak.migrated 8.6M /opt/iobroker/iobroker-data/states.jsonl 408K /opt/iobroker/iobroker-data/states.json.migrated 408K /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ======================= Mark text until here for copying ===
Update ist durch.
@tombir sagte in Meine Blockly-Skripte funktionieren nach Updates nicht mehr:
buster
Ist tot, muss durch was lebendiges ersetzt werden.
iob nodejs-update 18bringt dich wieder runter.
Update ist durch.
dieses Betriebssystem ist seit langem tot!
Update ist durch.
buster
Danke! Das läuft gerade.
Also müsste ich Buster updaten.
Habe mich bisher vor der Neuinstallation gefürchtet - ein Update gibt es da ja nicht, oder? -
Habe mich bisher vor der Neuinstallation gefürchtet - ein Update gibt es da ja nicht, oder?@tombir sagte in Meine Blockly-Skripte funktionieren nach Updates nicht mehr:
Nix updaten. Raspberry OS 12 'Bookworm' von Grund auf NEUinstallieren. In der 64Bit-Lite-Version.
das geht nicht
bookwneu installieren und möglichst weit upgedatetes Backup wieder einspielen -
das geht nicht
@homoran said in Meine Blockly-Skripte funktionieren nach Updates nicht mehr:
Du meinst damit sicher ein iobroker-Backup, oder?
ja
Ja. Den ioBroker voll durchpatchen, davon ein Backup machen und mit dem ganzen Summs dann in das neue System umziehen.
iobroker läuft wieder!
allerdings auch wieder mir allen Errors.
Da muss ich mich wohl einmal in einer ruhigen Stunde an bookworm wagen.Danke für eure Hilfe und die Tipps!
reicht wieder das summary? -
reicht wieder das summary?Nein, die Langfassung.
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.2 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 22:06:13 up 21 min, 1 user, load average: 1.62, 2.20, 1.63 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Mon 2024-09-09 22:06:13 CEST Universal time: Mon 2024-09-09 20:06:13 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.1G 1.7G 8.0M 1.0G 2.7G Swap: 99M 0B 99M Total: 3.9G 1.1G 1.8G Active iob-Instances: 21 3838 M total memory 1090 M used memory 472 M active memory 1496 M inactive memory 1732 M free memory 185 M buffer memory 830 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 22:06:14 up 21 min, 1 user, load average: 1.62, 2.20, 1.63 Tasks: 148 total, 1 running, 147 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.9 us, 2.9 sy, 0.0 ni, 94.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3838.7 total, 1732.9 free, 1090.2 used, 1015.6 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 2671.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * rc-local.service loaded failed failed /etc/rc.local Compatibility LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 14G 49% / devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 1.9G 8.5M 1.9G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 384M 0 384M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Sep 9 21:44:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:EA:20:D4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=55190a09-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Mon Sep 9 21:44:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Mon Sep 9 21:44:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Mon Sep 9 21:44:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=1800568k,nr_inodes=84157,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,relatime |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup tmpfs tmpfs ro,nosuid,nodev,noexec,mode=755 | | |-/sys/fs/cgroup/unified cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate | | |-/sys/fs/cgroup/systemd cgroup cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd | | |-/sys/fs/cgroup/freezer cgroup cgroup rw,nosuid,nodev,noexec,relatime,freezer | | |-/sys/fs/cgroup/net_cls,net_prio cgroup cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio | | |-/sys/fs/cgroup/cpu,cpuacct cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct | | |-/sys/fs/cgroup/devices cgroup cgroup rw,nosuid,nodev,noexec,relatime,devices | | |-/sys/fs/cgroup/blkio cgroup cgroup rw,nosuid,nodev,noexec,relatime,blkio | | |-/sys/fs/cgroup/perf_event cgroup cgroup rw,nosuid,nodev,noexec,relatime,perf_event | | |-/sys/fs/cgroup/cpuset cgroup cgroup rw,nosuid,nodev,noexec,relatime,cpuset | | `-/sys/fs/cgroup/pids cgroup cgroup rw,nosuid,nodev,noexec,relatime,pids | |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/debug debugfs debugfs rw,relatime | `-/sys/kernel/config configfs configfs rw,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/run tmpfs tmpfs rw,nosuid,nodev,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1005M /var/ 477M /var/cache 472M /var/cache/apt 413M /var/cache/apt/archives 346M /var/lib Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 1.3G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 820M /opt/iobroker/iobroker-data/ 720M /opt/iobroker/iobroker-data/files 441M /opt/iobroker/iobroker-data/files/javascript.admin 409M /opt/iobroker/iobroker-data/files/javascript.admin/static 408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map 17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v18.20.4 /usr/bin/node v18.20.4 /usr/bin/npm 10.7.0 /usr/bin/npx 10.7.0 /usr/bin/corepack 0.28.0 nodejs: Installed: 18.20.4-1nodesource1 Candidate: 18.20.4-1nodesource1 Version table: *** 18.20.4-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.20.3-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 6.0.11 admin: 7.0.23 javascript: 8.7.6 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.backitup.0 : backitup : raspberrypi - disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.ds18b20.0 : ds18b20 : raspberrypi - enabled system.adapter.echarts.0 : echarts : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fronius-wattpilot.0 : fronius-wattpilot : raspberrypi - enabled + system.adapter.fronius-wattpilot.1 : fronius-wattpilot : raspberrypi - enabled + system.adapter.fronius.0 : fronius : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.mqtt-client.0 : mqtt-client : raspberrypi - disabled, port: 1883 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1884, bind: 192.168.178.22 + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled system.adapter.ocpp.0 : ocpp : raspberrypi - disabled, port: 9220 system.adapter.onvif.0 : onvif : raspberrypi - disabled + system.adapter.parser.0 : parser : raspberrypi - enabled + system.adapter.ping.0 : ping : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1884, bind: 192.168.178.22 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.0.23 , installed 7.0.23 Adapter "backitup" : 3.0.22 , installed 3.0.22 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "ds18b20" : 2.0.5 , installed 2.0.5 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "fronius-wattpilot": 4.6.3, installed 4.6.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homekit-controller": 0.5.10, installed 0.5.10 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.7.6 , installed 8.7.6 Controller "js-controller": 6.0.11 , installed 6.0.11 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "mqtt-client" : 2.0.0 , installed 2.0.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "ocpp" : 0.12.5 , installed 0.12.5 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "parser" : 2.2.2 , installed 2.2.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.0 , installed 3.1.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 2318 States: 1778 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB] Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Err:3 https://repos.influxdata.com/debian buster InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Fetched 12.9 kB in 2s (6051 B/s) Reading package lists... W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14259 653/sshd tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 14708 365/influxd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 48207 3339/io.sonoff.0 tcp 0 0 192.168.178.22:1884 0.0.0.0:* LISTEN 1001 46484 3288/io.mqtt.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 46201 3089/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 45213 3089/iobroker.js-co tcp6 0 0 :::8081 :::* LISTEN 1001 43798 3110/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 50205 3531/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 999 17181 365/influxd tcp6 0 0 :::22 :::* LISTEN 0 14261 653/sshd udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 46542 3306/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 46543 3306/io.tuya.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 17077 644/dhcpcd udp 0 0 0.0.0.0:39564 0.0.0.0:* 108 15844 332/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15842 332/avahi-daemon: r udp6 0 0 :::546 :::* 0 17100 644/dhcpcd udp6 0 0 :::44593 :::* 108 15845 332/avahi-daemon: r udp6 0 0 :::5353 :::* 108 15843 332/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-09-09 22:05:00.028 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 3.1 2024-09-09 22:05:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:05:20.014 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:05:20.015 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:05:20.015 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 3.3 2024-09-09 22:05:40.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:05:40.011 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.8 2024-09-09 22:06:00.009 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:00.010 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.6 2024-09-09 22:06:20.012 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:20.012 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:20.013 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 1 2024-09-09 22:06:40.007 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:06:40.008 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:06:40.008 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:06:40.009 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 2.3 2024-09-09 22:07:00.027 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: WW-Merker0 2024-09-09 22:07:00.028 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab AUTO 2 2024-09-09 22:07:00.029 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Heizstab aus 2024-09-09 22:07:00.029 - info: javascript.0 (3121) script.js.Heizstab_für_Warmwasser: Netzeispeisung kleiner 1500 Watt 0.6============ Mark until here for C&P =============
iob diag has finished.
