  3. Einsteigerfragen
  4. mqtt Adapter startet nicht mehr nach js-controller update
    5.4k
14 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    Stell das loggen für den MQTT mal auf Debug und poste dann das log vom start
    rtwlR 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      rtwlR Offline
      rtwlR Offline
      rtwl
      schrieb am zuletzt editiert von rtwl
      @wendy2702
      Hier der Debug Log
      2024-09-04 21:53:22.196 - warn: zigbee.0 (1081) DeviceAvailability:Stopping to ping 0x000b57fffe2a31ca TRADFRI bulb E27 WS�opal 980lm after 4 ping attempts
      2024-09-04 21:59:31.441 - info: mqtt.0 (1563) Got terminate signal TERMINATE_YOURSELF
      2024-09-04 21:59:31.445 - info: mqtt.0 (1563) terminating
      2024-09-04 21:59:31.447 - info: mqtt.0 (1563) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-09-04 21:59:31.949 - info: mqtt.0 (1563) terminating
      2024-09-04 21:59:37.058 - info: javascript.0 (788) script.js.common.Adapter_check: 🟥 mqtt
      2024-09-04 21:59:37.341 - debug: mqtt.0 (3068) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-09-04 21:59:37.395 - debug: mqtt.0 (3068) Objects client ready ... initialize now
      2024-09-04 21:59:37.398 - debug: mqtt.0 (3068) Objects create System PubSub Client
      2024-09-04 21:59:37.400 - debug: mqtt.0 (3068) Objects create User PubSub Client
      2024-09-04 21:59:37.516 - debug: mqtt.0 (3068) Objects client initialize lua scripts
      2024-09-04 21:59:37.526 - debug: mqtt.0 (3068) Objects connected to redis: 127.0.0.1:9001
      2024-09-04 21:59:37.595 - debug: mqtt.0 (3068) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-09-04 21:59:37.627 - debug: mqtt.0 (3068) States create System PubSub Client
      2024-09-04 21:59:37.628 - debug: mqtt.0 (3068) States create User PubSub Client
      2024-09-04 21:59:37.732 - debug: mqtt.0 (3068) States connected to redis: 127.0.0.1:9000
      2024-09-04 21:59:37.794 - debug: mqtt.0 (3068) Plugin sentry Initialize Plugin (enabled=true)
      2024-09-04 21:59:38.391 - info: mqtt.0 (3068) starting. Version 5.2.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.20.4, js-controller: 6.0.11
      2024-09-04 21:59:38.592 - info: mqtt.0 (3068) Starting MQTT authenticated server on 0.0.0.0:1883
      2024-09-04 21:59:38.667 - debug: mqtt.0 (3068) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1725479978661,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725430558620}
      @thomas-braun sagte in mqtt Adapter startet nicht mehr nach js-controller update:
      Der mqtt-Adapter fungiert als Server?
      Ja, so ist er aktuell eingestellt.
      Ehrlichgesagt hab ich keine Ahnung was hier korrekt wäre. Aber wenn das nicht automatisch geändert wurde, war das immer so und hab bis heute vor dem js-controller update so funktioniert.
      -Peter
      • rtwlR rtwl
        @wendy2702
        Hier der Debug Log
        wendy2702W Offline
        wendy2702W Offline
        @rtwl ok. Mein Fehler.
        Log posten vom start bis zu dem Zeitpunkt wenn er wieder ausfällt. Also neu startet
          rtwlR Offline
          rtwlR Offline
          rtwl
          @wendy2702
          Er fällt ja nicht aus, er Verbindet sich gar nicht.
          es werden nur die oberen 2 Punkte grün. Der untere "Verbindung" Punkt bleibt immer Rot.
          -Peter
          • rtwlR rtwl
            @wendy2702
            wendy2702W Offline
            wendy2702W Offline
            @rtwl ok.
            Das heißt im log kommt nicht mehr?
              @rtwl ok.
              rtwlR Offline
              rtwlR Offline
              rtwl
              @wendy2702
              nein leider nicht 🤔
              -Peter
              • rtwlR Offline
                rtwlR Offline
                rtwl
                Meine aktuellen Einstellungen:
                -Peter
                • rtwlR Offline
                  rtwlR Offline
                  rtwl
                  kann es ein Bug sein, beim js-controller? bzw beim aktualisieren über den Admin?
                  Kann man mit einem consolen Befehl da was machen?
                  -Peter
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    @rtwl sagte in mqtt Adapter startet nicht mehr nach js-controller update:
                    die bleibt auch solange rot bis die Gegenstelle(sprich eines deiner Geräte) verbunden/erreichbar ist
                      rtwlR Offline
                      rtwlR Offline
                      rtwl
                      @crunchip
                      oh man - ich sag ja, ich hab keine Erfahrung mit MQTT.
                      Das war der Fehler. Ich hab die Gegenstelle also meine Smartmeter-Modul rebootet. jetzt läuft es wieder.
                      Sorry und danke für eure Geduld.
                      Wenigstens bin ich jetzt dank @Thomas-Braun auf nodejs@20 😉
                      -Peter
