  4. Node-Red
  5. 2 Bewegungsmelder (Aqara) sollen einen Lampe schalten
    6.4k
216 Beiträge 3 Kommentatoren 30.9k Aufrufe 3 Beobachtet
  • AphofisA Aphofis
    @mickym Habe jetzt schalter An/Aus ~~ licht an/aus
            "id": "1d761786cd03b6eb",
            "type": "tab",
            "label": "Flow 4",
            "disabled": false,
            "info": "",
            "env": []
            "id": "60c60fdc914d5454",
            "type": "junction",
            "z": "1d761786cd03b6eb",
            "x": 290,
            "y": 120,
            "wires": [
                    "2b793d273b25a2f7",
                    "50172abc4513c6cf"
            "id": "825a34e2e6145b1c",
            "type": "ioBroker in",
            "name": "",
            "attrname": "payload",
            "topic": "Lichtschalter Bad",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 130,
            "y": 120,
            "wires": [
                    "60c60fdc914d5454"
            "id": "2b793d273b25a2f7",
            "type": "ioBroker out",
            "name": "Bad Decke",
            "topic": "tuya.0.bf78f027e5e33c3d76xrfe.1",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 440,
            "y": 120,
            "wires": []
            "id": "d4d742934b195768",
            "type": "inject",
            "name": "Aus",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "false",
            "payloadType": "bool",
            "x": 160,
            "y": 80,
            "wires": [
                    "60c60fdc914d5454"
            "id": "34a6d988e012a62b",
            "type": "inject",
            "name": "An",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 160,
            "y": 40,
            "wires": [
                    "60c60fdc914d5454"
            "id": "50172abc4513c6cf",
            "type": "debug",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 440,
            "y": 80,
            "wires": []
    mickymM Offline
    mickymM Offline
    mickym
    #113
    @aphofis Sehr gut. Da Du ja auf alle Schalterstellungen sofort reagieren willst, würde ich dann parallel an dem Knoten eine flow Variable setzen, dass der Schalter betätigt wurde. Am Besten erstellst Du ein Objekt im Flow Kontext, so dass es Du später auch für andere Schalter nutzen kannst. Also zum Beispiel Schalter.Bad. Am Besten nimmst Du direkt eine ChangeNode und setzt diese Eigenschaft auf true. Anschließend nimmst Du den Trigger, der erst mal nichts schickt und erst nach 15 Minuten ein false schickt. Achte darauf, dass ich diese Verzögerung verlängert, wenn eine neue Nachricht kommt, denn Du willst ja erst das Licht ausschalten, wenn 15 Minuten lang kein Schalter mehr betätigt wurde. Anschließend setzt Du mit einer weiteren ChangeNode die Eigenschaft Schalter.Bad wieder auf false und die payload wird ja dann an das Licht weitergeleitet. Damit sollte Dein Flow für den Schalter fertig sein.
    Ein flow Variable setzt Du indem Du in der ChangeNode eben nicht eine Nachrichteneigenschaft, sondern eine Flow eigenschaft setzt:
    den aktuellen Inhalt der Flowvariablen kannst Du über den Plattenstapel sehen:
    • AphofisA Offline
      AphofisA Offline
      Aphofis
      #114
      @mickym
      also meinst du so !?
      ![2b3971da-7ecd-4e63-86d2-d233b62728b4-grafik.png](/assets/uploads/files/1724174848479-2b3971da-7ecd-4e63-86d2-d233b62728b4-grafik.png) code_text
      • AphofisA Aphofis
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        #115
        @aphofis sagte in 2 Bewegungsmelder (Aqara) sollen einen Lampe schalten:
        @mickym
        Nein ich habe doch gesagt parallel. Du möchtest doch, dass das direkte Schalen weiter direkt an die Lampe durchgereicht wird.
        Um ich sagte Dir auch, dass Du keine payload ändern sollst, sondern eine Flowvariable.
        • AphofisA Aphofis
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          #116
          @aphofis und
          damit kann ich nichts anfangen. Aber lies Dir das in Ruhe durch und beachte alle Hinweise.
          AphofisA 1 Antwort Letzte Antwort
          • mickymM mickym
            @aphofis und
            AphofisA Offline
            AphofisA Offline
            Aphofis
            #117
            @mickym
            Wenn ich auf Plattenstapel umschalte ist der leer!
                    "type": "tab",
                    "label": "Flow 4",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "name": "",
                    "payloadType": "object",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 130,
                    "y": 120,
                    "wires": [
                            "6e55b108db47eaed",
                            "2b793d273b25a2f7"
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1020,
                    "y": 120,
                    "wires": []
                    "type": "inject",
                    "name": "Aus",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "false",
                    "x": 170,
                    "y": 170,
                    "wires": [
                            "6e55b108db47eaed"
                    "type": "inject",
                    "name": "An",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "true",
                    "x": 170,
                    "y": 210,
                    "wires": [
                            "6e55b108db47eaed"
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1020,
                    "y": 170,
                    "wires": []
                    "id": "6e55b108db47eaed",
                    "type": "change",
                    "name": "bad schalten",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 360,
                    "y": 160,
                    "wires": [
                            "4faf1ed0bf7c1af3"
                    "id": "4faf1ed0bf7c1af3",
                    "type": "trigger",
                    "name": "",
                    "op1": "1",
                    "op2": "false",
                    "op1type": "str",
                    "op2type": "bool",
                    "duration": "15",
                    "extend": true,
                    "overrideDelay": false,
                    "units": "min",
                    "reset": "",
                    "bytopic": "all",
                    "topic": "topic",
                    "outputs": 1,
                    "x": 550,
                    "y": 160,
                    "wires": [
                            "f65257011e0b574c"
                    "id": "f65257011e0b574c",
                    "type": "change",
                    "name": "Schalten",
                    "rules": [
                            "t": "set",
                            "p": "schalten.bad",
                            "pt": "msg",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 740,
                    "y": 160,
                    "wires": [
                            "50172abc4513c6cf",
                            "2b793d273b25a2f7"
            • AphofisA Aphofis
              @mickym
                      "type": "tab",
                      "label": "Flow 4",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "name": "",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 130,
                      "y": 120,
                      "wires": [
                              "6e55b108db47eaed",
                              "2b793d273b25a2f7"
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1020,
                      "y": 120,
                      "wires": []
                      "type": "inject",
                      "name": "Aus",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "false",
                      "x": 170,
                      "y": 170,
                      "wires": [
                              "6e55b108db47eaed"
                      "type": "inject",
                      "name": "An",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "true",
                      "x": 170,
                      "y": 210,
                      "wires": [
                              "6e55b108db47eaed"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1020,
                      "y": 170,
                      "wires": []
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 360,
                      "y": 160,
                      "wires": [
                              "4faf1ed0bf7c1af3"
                      "type": "trigger",
                      "name": "",
                      "op1": "1",
                      "op2": "false",
                      "op1type": "str",
                      "op2type": "bool",
                      "duration": "15",
                      "extend": true,
                      "units": "min",
                      "reset": "",
                      "bytopic": "all",
                      "topic": "topic",
                      "outputs": 1,
                      "x": 550,
                      "y": 160,
                      "wires": [
                              "f65257011e0b574c"
                      "type": "change",
                      "name": "Schalten",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 740,
                      "y": 160,
                      "wires": [
                              "50172abc4513c6cf",
                              "2b793d273b25a2f7"
              AphofisA Offline
              AphofisA Offline
              Aphofis
              #118
              so besser !?
                      "type": "tab",
                      "label": "Flow 4",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "name": "",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 130,
                      "y": 120,
                      "wires": [
                              "6e55b108db47eaed",
                              "2b793d273b25a2f7"
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1020,
                      "y": 120,
                      "wires": []
                      "type": "inject",
                      "name": "Aus",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "false",
                      "x": 170,
                      "y": 170,
                      "wires": [
                              "6e55b108db47eaed"
                      "type": "inject",
                      "name": "An",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "true",
                      "x": 170,
                      "y": 210,
                      "wires": [
                              "6e55b108db47eaed"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1020,
                      "y": 170,
                      "wires": []
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "Bad_Motion",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 360,
                      "y": 160,
                      "wires": [
                              "4faf1ed0bf7c1af3"
                      "type": "trigger",
                      "name": "",
                      "op1": "1",
                      "op2": "false",
                      "op1type": "str",
                      "op2type": "bool",
                      "duration": "15",
                      "extend": true,
                      "units": "min",
                      "reset": "",
                      "bytopic": "all",
                      "topic": "topic",
                      "outputs": 1,
                      "x": 550,
                      "y": 160,
                      "wires": [
                              "f65257011e0b574c"
                      "type": "change",
                      "name": "Schalten",
                      "rules": [
                              "t": "set",
                              "p": "Bad_Motion",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 740,
                      "y": 160,
                      "wires": [
                              "50172abc4513c6cf",
                              "2b793d273b25a2f7"
              • AphofisA Aphofis
                so besser !?
                        "type": "tab",
                        "label": "Flow 4",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "name": "",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 130,
                        "y": 120,
                        "wires": [
                                "6e55b108db47eaed",
                                "2b793d273b25a2f7"
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1020,
                        "y": 120,
                        "wires": []
                        "type": "inject",
                        "name": "Aus",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "false",
                        "x": 170,
                        "y": 170,
                        "wires": [
                                "6e55b108db47eaed"
                        "type": "inject",
                        "name": "An",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "true",
                        "x": 170,
                        "y": 210,
                        "wires": [
                                "6e55b108db47eaed"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1020,
                        "y": 170,
                        "wires": []
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "Bad_Motion",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 360,
                        "y": 160,
                        "wires": [
                                "4faf1ed0bf7c1af3"
                        "type": "trigger",
                        "name": "",
                        "op1": "1",
                        "op2": "false",
                        "op1type": "str",
                        "op2type": "bool",
                        "duration": "15",
                        "extend": true,
                        "units": "min",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 550,
                        "y": 160,
                        "wires": [
                                "f65257011e0b574c"
                        "type": "change",
                        "name": "Schalten",
                        "rules": [
                                "t": "set",
                                "p": "Bad_Motion",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 740,
                        "y": 160,
                        "wires": [
                                "50172abc4513c6cf",
                                "2b793d273b25a2f7"
                mickymM Offline
                mickymM Offline
                mickym
                #119
                @aphofis Na ja das parallel ist prinzipiell richtig und 2 Change Nodes und in der Mitte die Trigger node auch - aber das wars dann auch mit richtig. Warum hast Du nun die flow Variable bad_motion genannt und nicht wie ich empfohlen habe, ein Objekt gemacht, damit du es mal für mehrere Schalter verwenden kannst, warum hälst Du nicht exakt was ich schreibe?
                Du hast die Flowvariable anders genannt und nicht auf true, sondern auf false gesetzt, warum?
                Deine Trigger Node schickt zu Beginn einen String "1". Warum?
                Tja und Du machst halt ein true. Keine Ahnung, wenn Du es immer besser weißt, dann spare ich mir meinen Text. ;)
                Wenn Du den Flow korrigiert hast, dann beschreibe mir bitte mit Worten im Text, was passiert wenn Du den Schalter betätigst, das Licht einschaltest und dann nach 5 Minuten das Licht beim Rausgehen ausschaltest.
                Und dann beschreibe noch kurz was passiert, wenn Du den Lichtschalter einschaltest und dann nichts tust.
                mickymM AphofisA 2 Antworten Letzte Antwort
                • mickymM mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #120
                  @mickym Oder war etwa Deine Idee - das Deine Flowvariable was mit dem Bewegungsmelder zu tun haben soll und Du ihm gleich über den Flowkontext von der Ferne winken wolltest, dass er gefälligst false und somit nichts tun soll?
                  • mickymM mickym
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    schrieb am zuletzt editiert von Aphofis
                    #121
                    @mickym
                    ich wusste nicht das du ein objekt als Datenpunkt meinst
                    Ganz einfach, weil ich von den einzenen nodes keine Ahnung habe ich habe das 1 jetzt geändert in true und bei dem Rest bin ich bei.
                    • mickymM mickym
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      #122
                      @mickym hihi ich habe das so verstanden, das wenn man aus dem Kontextmenü flow auswählt das dann der Flow angesprochen wird.
                      • AphofisA Aphofis
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        #123
                        beim Schalten des Schalter geht Licht an und geht nach x min aus. Wenn ich den Lichtschalter ausschalte schaltet das Licht aus aber was jetzt die Steuerung macht keine Ahnung. Ich weiß nicht was das bewirkt wenn man auf flow umstellt.
                                "type": "tab",
                                "label": "Flow 4",
                                "disabled": false,
                                "info": "",
                                "env": []
                                "id": "35403a23852c1068",
                                "type": "junction",
                                "x": 320,
                                "y": 190,
                                "wires": [
                                        "39c33f0b9f2fddef"
                                "id": "39c33f0b9f2fddef",
                                "type": "junction",
                                "x": 830,
                                "y": 190,
                                "wires": [
                                        "2b793d273b25a2f7",
                                        "8e8b0850594a2a69"
                                "name": "",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 130,
                                "y": 160,
                                "wires": [
                                        "6e55b108db47eaed",
                                        "35403a23852c1068"
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1050,
                                "y": 190,
                                "wires": []
                                "type": "inject",
                                "name": "Aus",
                                "props": [
                                        "p": "payload"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "payload": "false",
                                "x": 160,
                                "y": 210,
                                "wires": [
                                        "35403a23852c1068"
                                "type": "inject",
                                "name": "An",
                                "props": [
                                        "p": "payload"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "payload": "true",
                                "x": 160,
                                "y": 250,
                                "wires": [
                                        "6e55b108db47eaed"
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1050,
                                "y": 240,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "Schalten.Bad",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 410,
                                "y": 250,
                                "wires": [
                                        "4faf1ed0bf7c1af3"
                                "type": "trigger",
                                "name": "",
                                "op1": "true",
                                "op2": "false",
                                "op1type": "str",
                                "op2type": "bool",
                                "duration": "2",
                                "extend": true,
                                "units": "min",
                                "reset": "",
                                "bytopic": "all",
                                "topic": "topic",
                                "outputs": 1,
                                "x": 620,
                                "y": 250,
                                "wires": [
                                        "f65257011e0b574c"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 820,
                                "y": 250,
                                "wires": [
                                        "50172abc4513c6cf",
                                        "2b793d273b25a2f7"
                                "id": "8e8b0850594a2a69",
                                "type": "debug",
                                "name": "debug 1",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "false",
                                "statusVal": "",
                                "x": 1040,
                                "y": 150,
                                "wires": []
                        Objekt Schalten.Bad habe ich erstellt bzw Ordner ist Schalten Objekt ist Bad
                        • AphofisA Aphofis
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #124
                          @aphofis Meinte ich auch nicht.
                          Ein Objekt erstellt man in dem man dem Objekt einen Namen und eine Eigenschaft gibt.
                          Das heißt, das Objekt heißt Schalter und die Eigenschaft Bad.
                          Na aber Du willst doch eine Ahnung haben und Du solltest beim Trigger nicht die 1 auf true ändern, sondern der Trigger soll erst mal gar nichts senden.
                          Ich mach Dir den Flow fertig und dann kannst Du Fragen stellen und - Deine Kabel sind durcheinander.
                          Wie Du siehst hast Du damit im Kontext ein Objekt Schalter erstellt und eine Eigenschaft Bad, die den Wert true hat:
                          Nimm jetzt besser meinen Flow:
                                 "name": "",
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 130,
                                 "y": 120,
                                 "wires": [
                                         "8ba39a421f5c3317"
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 1120,
                                 "y": 120,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1120,
                                 "y": 170,
                                 "wires": []
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "Schalter.Bad",
                                         "pt": "flow",
                                         "to": "true",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 430,
                                 "y": 160,
                                 "wires": [
                                         "4faf1ed0bf7c1af3"
                                 "type": "trigger",
                                 "name": "",
                                 "op1": "",
                                 "op2": "false",
                                 "op1type": "nul",
                                 "op2type": "bool",
                                 "duration": "15",
                                 "extend": true,
                                 "units": "min",
                                 "reset": "",
                                 "bytopic": "all",
                                 "topic": "topic",
                                 "outputs": 1,
                                 "x": 660,
                                 "y": 160,
                                 "wires": [
                                         "f65257011e0b574c"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "pt": "flow",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 160,
                                 "wires": [
                                         "50172abc4513c6cf",
                                         "2b793d273b25a2f7"
                                 "type": "inject",
                                 "name": "Aus",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "false",
                                 "x": 150,
                                 "y": 40,
                                 "wires": [
                                         "8ba39a421f5c3317"
                                 "type": "inject",
                                 "name": "An",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "true",
                                 "x": 150,
                                 "y": 80,
                                 "wires": [
                                         "8ba39a421f5c3317"
                                 "id": "8ba39a421f5c3317",
                                 "type": "junction",
                                 "x": 260,
                                 "y": 120,
                                 "wires": [
                                         "6e55b108db47eaed",
                                         "2b793d273b25a2f7"
                          Das wäre ja noch schlimmer, damit hättesr Du im Trigger
                          ein Wort "true" als payload versendet.
                          • mickymM mickym
                                   "name": "",
                                   "onlyack": "",
                                   "func": "all",
                                   "gap": "",
                                   "x": 130,
                                   "y": 120,
                                   "wires": [
                                           "8ba39a421f5c3317"
                                   "ack": "false",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 1120,
                                   "y": 120,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1120,
                                   "y": 170,
                                   "wires": []
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "pt": "flow",
                                           "to": "true",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 430,
                                   "y": 160,
                                   "wires": [
                                           "4faf1ed0bf7c1af3"
                                   "type": "trigger",
                                   "name": "",
                                   "op1": "",
                                   "op2": "false",
                                   "op1type": "nul",
                                   "op2type": "bool",
                                   "duration": "15",
                                   "extend": true,
                                   "units": "min",
                                   "reset": "",
                                   "bytopic": "all",
                                   "topic": "topic",
                                   "outputs": 1,
                                   "x": 660,
                                   "y": 160,
                                   "wires": [
                                           "f65257011e0b574c"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "pt": "flow",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 160,
                                   "wires": [
                                           "50172abc4513c6cf",
                                           "2b793d273b25a2f7"
                                   "type": "inject",
                                   "name": "Aus",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "false",
                                   "x": 150,
                                   "y": 40,
                                   "wires": [
                                           "8ba39a421f5c3317"
                                   "type": "inject",
                                   "name": "An",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "true",
                                   "x": 150,
                                   "y": 80,
                                   "wires": [
                                           "8ba39a421f5c3317"
                                   "type": "junction",
                                   "x": 260,
                                   "y": 120,
                                   "wires": [
                                           "6e55b108db47eaed",
                                           "2b793d273b25a2f7"
                            AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            #125
                            Oh gott ne das ne schlechte Schleife
                            woher hat denn jetzt Kontextdaten Bad_Motion hergeholt und steht auf true !?
                            Ist schalter.bad ein virtueller schalter !?
                            • AphofisA Aphofis
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #126
                              @aphofis Das stammt doch von Deinem Flow. Von meinem habe ich Dir doch einen Screenshot von dem Flowkontext gepostet.
                              • mickymM mickym
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                #127
                                @mickym alles klar den muss man löschen!
                                So ist es dann wohl wie gewollt
                                • AphofisA Aphofis
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #128
                                  Nein das ist ein Variable, die für den ganzen FLOW Gültigkeit hat.
                                  Wie Du siehst gibt es auch einen NODE Kontext - der hat Gültigkeit innerhalb einer function Node.
                                  Und es gibt einen GLOBAL Kontext, dessen Variablen haben über alle Flows Gültigkeit
                                  • mickymM mickym
                                    AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    #129
                                    @mickym ok
                                    • AphofisA Aphofis
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #130
                                      Nein wenn Du meinen Flow nimmst - NUR EINE Variable. Ich hatte doch in beiden Change Nodes Schalter.
                                      Vor der trigger Node ist der Schalter true und signalisiert, dass der Schalter betätigt oder aktiv ist. Sobald der trigger abgelaufen ist, wird die Eigenschaft Schalter.Bad auf false gesetzt und signalisiert, dass der Schalter nun nicht mehr als aktiv gilt.
                                      Soweit verstanden?
                                      Dann beschreibe mir bitte was passiert wie ich unten beschrieben habe.
                                      • mickymM mickym
                                        Soweit verstanden?
                                        AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        #131
                                        @mickym ja habe deinen Flow genommen.
                                        Habe die falschen objekte gelöscht ist nur noch Schalter.Bad
                                        • AphofisA Aphofis
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #132
                                          @aphofis Gut - Können wir dann auf meinen Wunsch zurückkommen?
