  3. Einsteigerfragen
  4. Automatisierung
  5. goto in node red
    1.0k
goto in node red
Geplant Angeheftet Gesperrt Verschoben Automatisierung
77 Beiträge 6 Kommentatoren 10.1k Aufrufe 4 Beobachtet
  • B bynight
    @bynight Hallo Micky, langsam erschließt sich mir der Unterschied zwischen flow und msg ... ;-)
    Hab mal noch ne Frage... hab den Tages Ertrag/Verbrauch nun auf die 7 letzten Tage erweitert...
    Funktioniert wohl auch...
    Ich frag mich nun: triggere ich die Auswertung mit einem extra con-plus Trigger, z.B. minütlich oder hänge ich die Auswertung an den Mitternachtszeig, wo es dann wohl einmal alle 24 Std getriggert wird. Ist das egal oder ist eine Variante unbedingt zu bevorzugen?
    Danke und Gruß,
    Ronald
    [{"id":"b467aad8a4041e89","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"Shelly3EM#01.aktuell","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":280,"wires":[[]]},{"id":"9b8fcca6a07f3085","type":"victron-input-pvinverter","z":"e8df20d7cb27f1d6","service":"com.victronenergy.pvinverter/40","path":"/Ac/Energy/Forward","serviceObj":{"service":"com.victronenergy.pvinverter/40","name":"Shelly 3EM #01"},"pathObj":{"path":"/Ac/Energy/Forward","type":"float","name":"Total energy (kWh)"},"name":"","onlyChanges":false,"x":160,"y":280,"wires":[["5961d7b1dd7cb2fb"]]},{"id":"5961d7b1dd7cb2fb","type":"delay","z":"e8df20d7cb27f1d6","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":450,"y":280,"wires":[["b467aad8a4041e89"]]},{"id":"2bc5614ad0813065","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"aktuell","pt":"msg","to":"Shelly3EM#01.aktuell","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"payload ? aktuell - payload : 0","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":400,"wires":[["d329b73fae6948e9","98ed2a0aa9dccf43"]]},{"id":"f7f1d966da33067f","type":"cronplus","z":"e8df20d7cb27f1d6","name":"","outputField":"payload","timeZone":"","storeName":"","commandResponseMsgOutput":"output1","defaultLocation":"","defaultLocationType":"default","outputs":1,"options":[{"name":"minutly","topic":"minütlich","payloadType":"flow","payload":"Shelly3EM#01.minütlich","expressionType":"cron","expression":"0 * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"},{"name":"Midnight","topic":"Mitternacht","payloadType":"flow","payload":"Shelly3EM#01.mitternacht","expressionType":"cron","expression":"0 0 0 * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":90,"y":400,"wires":[["4e3fa675f5cedbfd","2bc5614ad0813065"]]},{"id":"4e3fa675f5cedbfd","type":"debug","z":"e8df20d7cb27f1d6","d":true,"name":"trigger","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":120,"y":540,"wires":[]},{"id":"d329b73fae6948e9","type":"switch","z":"e8df20d7cb27f1d6","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"minütlich","vt":"str"},{"t":"eq","v":"Mitternacht","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":400,"wires":[["9b45854e7128e039"],["0f5db7d3bc7fa87c"]]},{"id":"98ed2a0aa9dccf43","type":"debug","z":"e8df20d7cb27f1d6","d":true,"name":"Verbrauch","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":410,"y":540,"wires":[]},{"id":"9b45854e7128e039","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"Shelly3EM#01.minütlich","pt":"flow","to":"Shelly3EM#01.aktuell","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":340,"wires":[["2acdf9fe2c64c5fb"]]},{"id":"0f5db7d3bc7fa87c","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"Shelly3EM#01.Mitternacht","pt":"flow","to":"Shelly3EM#01.aktuell","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":460,"wires":[["830523c93bea3a96"]]},{"id":"36542b0235872729","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":5,"width":0,"height":0,"name":"Solar Wechselrichter aktueller Tag neu","icon":"fa-area-chart","label":"Solar Wechselrichter aktueller Tag neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#00ff00","t":"min","dot":0},{"val":100,"col":"#00ff00","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":340,"wires":[]},{"id":"2acdf9fe2c64c5fb","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.Mitternacht","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"aktuell - payload","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":340,"wires":[["1916a8315df3d4dc","3d36f065a45a9bf0"]]},{"id":"1865ab5230a35c0a","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch seit Mitternacht","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1820,"y":380,"wires":[]},{"id":"6062cdffc866fbe8","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":7,"width":0,"height":0,"name":"Solar Wechselrichter Gestern neu","icon":"fa-area-chart","label":"Solar Wechselrichter Gestern neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1820,"y":460,"wires":[]},{"id":"698e223189be8cc9","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch Gestern","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1790,"y":500,"wires":[]},{"id":"aae7dce9246e9e7d","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor2Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":540,"wires":[]},{"id":"0b3dac1bbe0c5e02","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_gest_neu","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":460,"wires":[["6062cdffc866fbe8","698e223189be8cc9"]]},{"id":"1916a8315df3d4dc","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_heute_neu","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":340,"wires":[]},{"id":"7b7e269a9a701b06","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_heute_neu","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":340,"wires":[["36542b0235872729","1865ab5230a35c0a"]]},{"id":"830523c93bea3a96","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"Shelly3EM#01.vor7Tagen","pt":"flow","to":"Shelly3EM#01.vor6Tagen","tot":"flow"},{"t":"set","p":"Shelly3EM#01.vor6Tagen","pt":"flow","to":"Shelly3EM#01.vor5Tagen","tot":"flow"},{"t":"set","p":"Shelly3EM#01.vor5Tagen","pt":"flow","to":"Shelly3EM#01.vor4Tagen","tot":"flow"},{"t":"set","p":"Shelly3EM#01.vor4Tagen","pt":"flow","to":"Shelly3EM#01.vor3Tagen","tot":"flow"},{"t":"set","p":"Shelly3EM#01.vor3Tagen","pt":"flow","to":"Shelly3EM#01.vor2Tagen","tot":"flow"},{"t":"set","p":"Shelly3EM#01.vor2Tagen","pt":"flow","to":"Shelly3EM#01.gestern","tot":"flow"},{"t":"set","p":"Shelly3EM#01.gestern","pt":"flow","to":"Shelly3EM#01.heute","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":460,"wires":[[]]},{"id":"3d36f065a45a9bf0","type":"change","z":"e8df20d7cb27f1d6","name":"","rules":[{"t":"set","p":"Shelly3EM#01.heute","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":400,"wires":[[]]},{"id":"e60d021656df2e7d","type":"change","z":"e8df20d7cb27f1d6","name":"gestern","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.gestern","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":460,"wires":[["cbfb6c99aae3cceb","530a73d563bcf295"]]},{"id":"d42a7ebd131856a8","type":"change","z":"e8df20d7cb27f1d6","name":"2 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor2Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":540,"wires":[["aae7dce9246e9e7d","b3ed35d91a409019"]]},{"id":"1d9f027e766e8f84","type":"change","z":"e8df20d7cb27f1d6","name":"3 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor3Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":620,"wires":[["ac5ce3ff5817ec8b","aebf05e68b8fcf11"]]},{"id":"05a607240e5d567c","type":"change","z":"e8df20d7cb27f1d6","name":"4 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor4Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":700,"wires":[["ad8696b37a7d7bac","231166605ab47bad"]]},{"id":"cbfb6c99aae3cceb","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_gest_neu","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":460,"wires":[]},{"id":"ac5ce3ff5817ec8b","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor3Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":620,"wires":[]},{"id":"ad8696b37a7d7bac","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor4Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":700,"wires":[]},{"id":"cb2d6d754c8fa3cf","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":8,"width":0,"height":0,"name":"Solar Wechselrichter vor 2 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 2 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":540,"wires":[]},{"id":"18296667d61ee8aa","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch Vor 2 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":580,"wires":[]},{"id":"ec321f374df305df","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor2Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":540,"wires":[["cb2d6d754c8fa3cf","18296667d61ee8aa"]]},{"id":"06fa97892bb92d9b","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":9,"width":0,"height":0,"name":"Solar Wechselrichter vor 3 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 3 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":620,"wires":[]},{"id":"f62650f678f67a31","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch vor 3 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":660,"wires":[]},{"id":"733e8969baca9f07","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor3Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":620,"wires":[["06fa97892bb92d9b","f62650f678f67a31"]]},{"id":"14a14d8511154976","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":10,"width":0,"height":0,"name":"Solar Wechselrichter vor 4 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 4 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":700,"wires":[]},{"id":"baf6282dc39af0b5","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch vor 4 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":740,"wires":[]},{"id":"b6b2aed30b4a0604","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor4Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":700,"wires":[["14a14d8511154976","baf6282dc39af0b5"]]},{"id":"530a73d563bcf295","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 52","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":500,"wires":[]},{"id":"b3ed35d91a409019","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 53","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":580,"wires":[]},{"id":"aebf05e68b8fcf11","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 54","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":660,"wires":[]},{"id":"231166605ab47bad","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 55","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":740,"wires":[]},{"id":"1e34838f78694036","type":"cronplus","z":"e8df20d7cb27f1d6","name":"minütlich","outputField":"payload","timeZone":"","storeName":"","commandResponseMsgOutput":"output1","defaultLocation":"","defaultLocationType":"default","outputs":1,"options":[{"name":"sekündlich","topic":"topic1","payloadType":"default","payload":"","expressionType":"cron","expression":"0 * * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":820,"y":600,"wires":[["e60d021656df2e7d","d42a7ebd131856a8","1d9f027e766e8f84","05a607240e5d567c","39c4cd753dc98760","5aa1f517b7641cbb","a3509d7f822622cb"]]},{"id":"34483ae7a5ca1974","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor5Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":780,"wires":[]},{"id":"39c4cd753dc98760","type":"change","z":"e8df20d7cb27f1d6","name":"5 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor5Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":780,"wires":[["34483ae7a5ca1974","190ec3d810fee4b5"]]},{"id":"5aa1f517b7641cbb","type":"change","z":"e8df20d7cb27f1d6","name":"6 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor6Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":860,"wires":[["585215327ffdb064","e00c6033518e5ed5"]]},{"id":"a3509d7f822622cb","type":"change","z":"e8df20d7cb27f1d6","name":"7 Tage","rules":[{"t":"set","p":"payload","pt":"msg","to":"Shelly3EM#01.vor7Tagen","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":940,"wires":[["04947606e5d050db","16694706f65011bf"]]},{"id":"585215327ffdb064","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor6Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":860,"wires":[]},{"id":"04947606e5d050db","type":"mqtt out","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor7Tagen","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"4a6c9e018feabe54","x":1250,"y":940,"wires":[]},{"id":"9218e27ad7a645d8","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":11,"width":0,"height":0,"name":"Solar Wechselrichter vor 5 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 5 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":780,"wires":[]},{"id":"54c8c49843623dc0","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch Vor 5 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":820,"wires":[]},{"id":"0d91e0f11f978557","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor5Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":780,"wires":[["9218e27ad7a645d8","54c8c49843623dc0"]]},{"id":"21e3fc69920c24ca","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":12,"width":0,"height":0,"name":"Solar Wechselrichter vor 6 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 6 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":860,"wires":[]},{"id":"ea91f014e926c1fd","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch vor 6 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":900,"wires":[]},{"id":"f06ab56d1e9fd141","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor6Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":860,"wires":[["21e3fc69920c24ca","ea91f014e926c1fd"]]},{"id":"4f0246648b95813a","type":"ui_artlessgauge","z":"e8df20d7cb27f1d6","group":"95fef75fbb31f51e","order":13,"width":0,"height":0,"name":"Solar Wechselrichter vor 7 Tagen neu","icon":"fa-area-chart","label":"Solar Wechselrichter vor 7 Tagen neu","unit":"kWh","layout":"linear","decimals":"2","differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#379b37","t":"min","dot":0},{"val":100,"col":"#379b37","t":"max","dot":0}],"lineWidth":"7","bgcolorFromTheme":true,"diffCenter":"","x":1830,"y":940,"wires":[]},{"id":"ed6050f6b4eff396","type":"debug","z":"e8df20d7cb27f1d6","name":"Tagesverbrauch vor 7 Tagen","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1800,"y":980,"wires":[]},{"id":"2640529ebb7bb352","type":"mqtt in","z":"e8df20d7cb27f1d6","name":"","topic":"NR/Victron/PVErtrag_vor7Tagen","qos":"2","datatype":"auto-detect","broker":"4a6c9e018feabe54","nl":false,"rap":true,"rh":0,"inputs":0,"x":1530,"y":940,"wires":[["4f0246648b95813a","ed6050f6b4eff396"]]},{"id":"190ec3d810fee4b5","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 56","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":820,"wires":[]},{"id":"e00c6033518e5ed5","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 57","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":900,"wires":[]},{"id":"16694706f65011bf","type":"debug","z":"e8df20d7cb27f1d6","name":"debug 58","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1280,"y":980,"wires":[]},{"id":"95fef75fbb31f51e","type":"ui_group","name":"mitte","tab":"2dbf5f84d75bd5b7","order":2,"disp":false,"width":9,"collapse":false,"className":""},{"id":"4a6c9e018feabe54","type":"mqtt-broker","name":"","broker":"192.168.178.200","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"2dbf5f84d75bd5b7","type":"ui_tab","name":"ATB18 Dashboard","icon":"fa-flash","order":1,"disabled":false,"hidden":false}]
    mickymM Online
    mickymM Online
    mickym
    @bynight sagte in goto in node red:
    Na da hast Du ja schon Einigen was voraus.
    Im Grunde sollte man so wenig wie möglich trigger nehmen, da jeder zusätzliche Trigger das System selbst belastet.
    Wenn ein Flow getriggert ist, dann sollte man den trigger möglichst (gut thematisch sollte es zusammenpassen) für alles nutzen, was man zu dem Zeitpunkt erledigen will. Also auch für mehrere Geräte.
    Im Ergebnis macht es zwar keinen Unterschied - aber es ist halt für das System ein Unterschied, ob ein Wecker klingelt der alle aufweckt - oder 50 Wecker zur gleichen Zeit klingeln. ;)
    • mickymM mickym
      bynight
      @mickym Danke! Das deckt sich mit meiner Annahme. Also hänge ich die an den Mitternachts-Zweig an und entferne den zusätzlichen Trigger. ;-)
      • B bynight
        bynight
        schrieb am zuletzt editiert von bynight
        @bynight Hallo Micky, ich hab schon wieder ne Frage:
        ich bekomme von dem Shelly die 3 Phasen korrekt angezeigt.
        Aber sobald ich den SummenNode für die Gesamtleistung anhänge bekomme ich TypeError: Cannot read properties of undefined (reading 'toString'). Hinter den Victron Nodes funktioniert der SummenNode aber.
        Lese ich den Shelly falsch aus oder fehlt weiter hinten noch was oder passt der Summen Node nicht?
        Danke und Gruß,
        Ronald
        [{"id":"89fd986bbb999da8","type":"ui_artlessgauge","z":"82e5452c01cee4bf","group":"e428548ce9e7be58","order":14,"width":8,"height":1,"name":"Summe Shelly 3EM #02","icon":"fa-bar-chart","label":"Summe Shelly 3EM #02","unit":"W","layout":"linear","decimals":"0","differential":true,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":false,"animate":true,"sectors":[{"val":-10000,"col":"#00ff00","t":"min","dot":1},{"val":-2000,"col":"#28c828","t":"sec","dot":0},{"val":0,"col":"#cccc00","t":"sec","dot":0},{"val":4400,"col":"#fb6565","t":"sec","dot":0},{"val":7000,"col":"#ff00ff","t":"sec","dot":0},{"val":10000,"col":"#ff00ff","t":"max","dot":1}],"lineWidth":"5","bgcolorFromTheme":true,"diffCenter":"0","x":1270,"y":2560,"wires":[]},{"id":"47f64f65b6d5e911","type":"shelly-gen1","z":"82e5452c01cee4bf","hostname":"192.168.178.84","description":"Shelly 3EM #02","mode":"polling","verbose":false,"server":"","outputmode":"event","uploadretryinterval":5000,"pollinginterval":"5000","pollstatus":true,"getstatusoncommand":true,"devicetype":"SHEM-3","devicetypemustmatchexactly":true,"outputs":1,"x":638,"y":2581,"wires":[["38c5a45ce8d0c7b5","d7ba4e620986b182","197d5eb7ccfdfac4"]]},{"id":"06b36d06d4c01cc4","type":"ui_artlessgauge","z":"82e5452c01cee4bf","group":"e428548ce9e7be58","order":15,"width":8,"height":1,"name":"Shelly 3EM #03","icon":"fa-bar-chart","label":"Shelly 3EM #03","unit":"W","layout":"linear","decimals":"0","differential":true,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":false,"animate":true,"sectors":[{"val":-4000,"col":"#00ff00","t":"min","dot":1},{"val":-2000,"col":"#28c828","t":"sec","dot":0},{"val":0,"col":"#cccc00","t":"sec","dot":0},{"val":4400,"col":"#fb6565","t":"sec","dot":0},{"val":7000,"col":"#ff00ff","t":"sec","dot":0},{"val":10000,"col":"#ff00ff","t":"max","dot":1}],"lineWidth":"5","bgcolorFromTheme":true,"diffCenter":"0","x":540,"y":2680,"wires":[]},{"id":"70c8facf6744462c","type":"debug","z":"82e5452c01cee4bf","name":"debug 62","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1009,"y":2561,"wires":[]},{"id":"38c5a45ce8d0c7b5","type":"function","z":"82e5452c01cee4bf","name":"function 7","func":"var newmsg = {payload: msg.payload.emeters[0].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2581,"wires":[["70c8facf6744462c","686c871ac2585c7e"]]},{"id":"af6c890c54e4ec5a","type":"debug","z":"82e5452c01cee4bf","name":"debug 64","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1008,"y":2621,"wires":[]},{"id":"d7ba4e620986b182","type":"function","z":"82e5452c01cee4bf","name":"function 8","func":"var newmsg = {payload: msg.payload.emeters[1].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2621,"wires":[["af6c890c54e4ec5a"]]},{"id":"e3f2e33ffab7bb36","type":"debug","z":"82e5452c01cee4bf","name":"debug 65","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1009,"y":2681,"wires":[]},{"id":"197d5eb7ccfdfac4","type":"function","z":"82e5452c01cee4bf","name":"function 9","func":"var newmsg = {payload: msg.payload.emeters[2].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2661,"wires":[["e3f2e33ffab7bb36"]]},{"id":"686c871ac2585c7e","type":"sum","z":"82e5452c01cee4bf","name":"","topic":"","x":1190,"y":2620,"wires":[["89fd986bbb999da8","55c58fb1d96329a5"]]},{"id":"55c58fb1d96329a5","type":"debug","z":"82e5452c01cee4bf","name":"Summe Shelly","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1250,"y":2680,"wires":[]},{"id":"e428548ce9e7be58","type":"ui_group","name":"links","tab":"2dbf5f84d75bd5b7","order":1,"disp":false,"width":8,"collapse":false,"className":""},{"id":"2dbf5f84d75bd5b7","type":"ui_tab","name":"ATB18 Dashboard","icon":"fa-flash","order":1,"disabled":false,"hidden":false}]
        • B bynight
          Danke und Gruß,
          Ronald
          mickymM Online
          mickymM Online
          mickym
          @bynight Mit Summennodes oder so einem Schmarn arbeite ich nicht. Ich benutze für einfache Berechnungen immer nur die Standardnodes. Ausserdem vermeide ich function Nodes wo immer es geht. Wenn Du aber Summen periodisch zusammenzählen willst, dann benötigst du wohl den Kontext der function Nodes - insofern kann Deine Summennode eine Vereinfachung darstellen.
          Wenn die Summennode hinter der Shelly Node funktioniert, hinter der function Node nicht, dann hast du mit der function Node das Nachrichtenobjekt so verändert, dass diese nicht mehr funktioniert.
          Dazu müsstest Du über eine Debug ausgabe - die Nachrichtenobjekte, sowie den Fehler aus der Summennode sowie deren Definition zeigen.
          Ich kann mir leider nicht jede Node installieren, die sich irgendjemand mal installiert hat.
          • mickymM mickym
            bynight
            @mickym wie komme ich an den Kontext einzelner Nodes, speziell der Funktion Node?
            Der Summennode funktioniert hinter den Victrons, nicht hinter dem Shelly!
            Im Debug hinter den Function Nodes wird jeweils ordentlich der Leistungswert ausgegeben.
            Nur die Summe aller drei bekomme ich nicht hin. Sobald ich den Summen Node an einen der Function Nodes hänge, bekomme ich rote Fernster.
            Bei Victron funzt es, bei Shelly nicht:
            vllt passt ja der Text in den function Nodes nicht:
            return newmsg;
            • B bynight
              return newmsg;
              mickymM Online
              mickymM Online
              mickym
              #66
              @bynight klick halt mal auf die node-id umzu sehen, welche node den fehler ausspukt.
              • mickymM mickym
                bynight
                #67
                @mickym es ist die node-red-contrib-sum:
                • B bynight
                  mickymM Online
                  mickymM Online
                  mickym
                  #68
                  @bynight Gut dann kann ja der Fehler nur aus der function Node 8 kommen. Also diese auf Fehler überprüfen bzw. im Protokoll schauen, ob da manchmal keine Zahlenwerte rauskommen.
                  • mickymM mickym
                    bynight
                    #69
                    @mickym ist nicht nur bei der 8, auch bei 7 und 9... auch wenn ich einen Switch verwende :
                    selbes Ergebnis... :-/
                    • B bynight
                      mickymM Online
                      mickymM Online
                      mickym
                      #70
                      @bynight Ja dann scheint halt nicht immer dieser Wert aus dem Shelly zu kommen und Du musst ggf. abfangen, wenn dieser Wert Null ist.
                        bynight
                        #71
                        @mickym nach langer Suche im Netz bin ich nun fündig geworden:
                        Shelly scheint die Summe zu liefern, obwohl ich den Wert im Array nicht finden kann:
                        Somit ist es ganz einfach, entweder per Function oder per Switch:
                        • B bynight
                          mickymM Online
                          mickymM Online
                          mickym
                          #72
                          @bynight Na dann ist ja alles gut! :)
                          • mickymM mickym
                            bynight
                            #73
                            @mickym ja endlich :-))) und nun hab ich auch noch das Summieren rausgekriegt...
                            im Switch:
                            oder in Function:
                            überall dasselbe Ergebnis :-)))
                            Du hast das Thema übrigens 2023 schon mal behandelt. Der Fragesteller hat fast dieselben Ansätze gehabt wie ich... ;-)
                            Die Lösung habe ich dann aber erst hier ganz unten gefunden...
                            link text
                            Danke für die Hilfe!
                            Und Grüße,
                            Ronald
                            • B bynight
                              im Switch:
                              oder in Function:
                              link text
                              Und Grüße,
                              Ronald
                              mickymM Online
                              mickymM Online
                              mickym
                              #74
                              @bynight Das geht aber mit JSONATa viel einfacher.
                              Zeig mal das komplette Array hier in CodeTags. Kopiere einfach den Wert über die Schaltfläche aus dem Debugfenster und stell ihn hier in CodeTags ein.
                              • mickymM mickym
                                bynight
                                #75
                                @mickym meinst Du das hier?
                                17.8.2024, 01:43:01node: debug 66
                                msg : Object
                                object
                                status: object
                                wifi_sta: object
                                cloud: object
                                mqtt: object
                                time: "01:43"
                                unixtime: 1723851795
                                serial: 391
                                has_update: false
                                mac: "485519DB63BC"
                                cfg_changed_cnt: 0
                                actions_stats: object
                                relays: array[1]
                                emeters: array[3]
                                0: object
                                1: object
                                2: object
                                total_power: 272.12
                                emeter_n: object
                                fs_mounted: true
                                v_data: 1
                                ct_calst: 0
                                update: object
                                ram_total: 49920
                                ram_free: 30904
                                fs_size: 233681
                                fs_free: 153612
                                uptime: 7981
                                payload: object
                                relays: array[1]
                                0: object
                                emeters: array[3]
                                0: object
                                1: object
                                2: object
                                _msgid: "5ae6ba6a42a5c12a"
                                Jetzt sehe ich auch die Total Power im Status. Bisher habe ich immer nur relays und emeters gesehen. Den Status Reiter habe ich bisher nie gesehen... :-/
                                Was soll denn einfacher gehen als ein Switch mit status.total_power drin oder eben die 3 Power Werte addiert?
                                Das ist alles für 3 Shellys und 9 Phasen...
                                • B bynight
                                  msg : Object
                                  object
                                  status: object
                                  wifi_sta: object
                                  cloud: object
                                  mqtt: object
                                  time: "01:43"
                                  serial: 391
                                  has_update: false
                                  mac: "485519DB63BC"
                                  cfg_changed_cnt: 0
                                  relays: array[1]
                                  emeters: array[3]
                                  0: object
                                  1: object
                                  2: object
                                  total_power: 272.12
                                  emeter_n: object
                                  fs_mounted: true
                                  v_data: 1
                                  ct_calst: 0
                                  update: object
                                  ram_total: 49920
                                  ram_free: 30904
                                  fs_size: 233681
                                  fs_free: 153612
                                  uptime: 7981
                                  payload: object
                                  relays: array[1]
                                  0: object
                                  emeters: array[3]
                                  0: object
                                  1: object
                                  2: object
                                  mickymM Online
                                  mickymM Online
                                  mickym
                                  #76
                                  msg : Object
                                  object
                                  status: object
                                  wifi_sta: object
                                  cloud: object
                                  mqtt: object
                                  time: "01:43"
                                  serial: 391
                                  has_update: false
                                  mac: "485519DB63BC"
                                  cfg_changed_cnt: 0
                                  relays: array[1]
                                  emeters: array[3]
                                  0: object
                                  1: object
                                  2: object
                                  total_power: 272.12
                                  emeter_n: object
                                  fs_mounted: true
                                  v_data: 1
                                  ct_calst: 0
                                  update: object
                                  ram_total: 49920
                                  ram_free: 30904
                                  fs_size: 233681
                                  fs_free: 153612
                                  uptime: 7981
                                  payload: object
                                  relays: array[1]
                                  0: object
                                  emeters: array[3]
                                  0: object
                                  1: object
                                  2: object
                                  Nein so genau nicht. Nichts mit der Maus markieren, sondern das Objekt schön über die Schaltfläche Wert kopieren und dann in die Zwischen ablage kopieren und dann hier in Codetags reinstellen.
                                  Also wenn Deine payload bzw. Teile Deines Nachrichtenobjektes warscheinich so aussieht
                                    "payload": {
                                      "emeters": [
                                          "power": 20
                                          "power": 120
                                          "power": 220
                                          "power": 30
                                  Dann kannst Du das mit JSONATA einfach so aufsummieren:
                                  $sum(payload.emeters.power)
                                  Testen kannst Du auch solche Sachen direkt im JSONATA exerciser: https://try.jsonata.org/Pel8ES7G0
                                  • B bynight
                                    im Switch:
                                    oder in Function:
                                    link text
                                    Und Grüße,
                                    Ronald
                                    mickymM Online
                                    mickymM Online
                                    mickym
                                    #77
                                    im Switch:
                                    Ausserdem läst man in JSONATA das msg weg, sondern greift direkt auf die Namen des Objektes zu.
