  4. Node-Red
  5. Wasserregulierung Aquarium
    6.4k
150 Beiträge 3 Kommentatoren 28.8k Aufrufe 3 Beobachtet
  • AphofisA Aphofis
    Irgendwie komme ich nicht weiter und Videos habe ich bis jetzt nur Integration Dashboard und VIS. Also nur wie man abgreift und in eine visualisierung brint.
    Weit bin ich noch nicht.
            "id": "e96d40e5c03c8e73",
            "type": "tab",
            "label": "Flow 2",
            "disabled": false,
            "info": "",
            "env": []
            "id": "99af6969144d7cdd",
            "type": "junction",
            "z": "e96d40e5c03c8e73",
            "x": 200,
            "y": 200,
            "wires": [
                    "9f9432b0c01ceb15"
            "id": "f91ee89f94dfe23c",
            "type": "junction",
            "x": 180,
            "y": 160,
            "wires": [
                    "9f9432b0c01ceb15"
            "id": "8eeeee9dee4f69dd",
            "type": "junction",
            "x": 340,
            "y": 220,
            "wires": [
                    "ed6a34a53f4a5f8a"
            "id": "4135d8f01c675d48",
            "type": "debug",
            "name": "debug 1",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 960,
            "y": 80,
            "wires": []
            "id": "d603f22a313281eb",
            "type": "calculator",
            "name": "",
            "inputMsgField": "payload",
            "outputMsgField": "payload",
            "operation": "mult",
            "constant": "5.1",
            "round": true,
            "truncate": false,
            "decimals": "2",
            "decimals2": 0,
            "x": 700,
            "y": 80,
            "wires": [
                    "4135d8f01c675d48"
            "id": "17fc122a8cc82dc5",
            "type": "ioBroker in",
            "name": "Schwimmer",
            "attrname": "payload",
            "topic": "sonoff.0.Aqua_Float.POWER",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "true",
            "outFormat": "MQTT",
            "x": 90,
            "y": 80,
            "wires": [
                    "9f9432b0c01ceb15",
                    "8eeeee9dee4f69dd"
            "id": "9f9432b0c01ceb15",
            "type": "ioBroker get",
            "name": "Wasserdurchfluß",
            "topic": "sonoff.0.Aqua_Float.SENSOR.COUNTER.C2",
            "errOnInvalidState": "nothing",
            "x": 430,
            "y": 80,
            "wires": [
                    "d603f22a313281eb"
            "id": "df1de44c69ce020f",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "payloadType": "str",
            "x": 90,
            "y": 160,
            "wires": [
                    "f91ee89f94dfe23c"
            "id": "e41278b18f57ac4e",
            "type": "debug",
            "name": "debug 14",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 960,
            "y": 180,
            "wires": []
            "id": "37ae982b985109a9",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "false",
            "x": 90,
            "y": 200,
            "wires": [
                    "99af6969144d7cdd"
            "id": "ed6a34a53f4a5f8a",
            "type": "ioBroker out",
            "name": "Magnetventil",
            "topic": "sonoff.0.Aqua_Control.POWER1",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 970,
            "y": 220,
            "wires": []
    Zumindest, wenn ich den true Button klicke und im durchfluß ein Wert steht wird dieser richtg berechnet und in die Debug geschrieben.
    Das Problem ist auch das hinter den Datenpunkten ein echtes Aquarium dahinter hängt und auch wenn nix passieren kann, da der Strom vom Magnetventil mit über den Schwimmer läuft also mechanisch ist die minus leitung vom magnetventil durch den Schwimmer getrennt. Nur kann man das halt ohne Schwimmer im true zustand testen ob die Steuerung dann auch läuft.
    mickymM Offline
    mickymM Offline
    mickym
    @aphofis Na ich dachte eigentlich wir machen das zusammen und installiere Dir nicht dauernd irgendwelche überflüssigen Nodes, solange es die Standardnodes aucht tun. Diese Multiply Node ist so ÜBERFLÜSSIG wie ...
    Also wir waren doch dabei, dass gemeinsam zu entwickeln?
    @mickym sagte in Wasserregulierung Aquarium:
    Trigger ist Schwimmer -
    Also iobroker-IN Node mit Schwimmerdatenpunkt.
    Wenn schwimmer (Sonoff) true dann setze Magnetventil (Sonoff) auf true warte bis Schwimmer false dann setze Magnetventil (Sonoff) auf false
    Na dann kannst Du doch die Nachricht des Schwimmers direkt auf das Magnetventil leiten - da braucht es doch keine Veränderung
    Also hat doch der Rest da noch gar nichts drin zu suchen.
    • mickymM Offline
      mickymM Offline
      mickym
      @aphofis sagte in Wasserregulierung Aquarium:
      Wenn schwimmer (Sonoff) true dann setze Magnetventil (Sonoff) auf true warte bis Schwimmer false dann setze Magnetventil (Sonoff) auf false nimm den Wert setze den Wert vom Counter Wasserdurchfluss Puls Messer in eine Liste. multipliziere diesen Wert mit 5,1 und runde den Wert mit 2 Nachkomma stellen aus dem Datenpunkt Wasser kalibibrierung schreibe diesen in den Datenpunkt Wasser Counter.
      So und was ich damit erreichen will ist, dass Du lernst Dinge nicht durcheinander zu schmeissen und einzelne Teilaufgaben auch als solche zu betrachten.
      Das was Du da oben geschrieben lässt sich einfach in 2 Teilaufgaben zerlegen, die NICHTS miteinander zu tun haben. Das 1. ist das Schalten des Magnetventils und das 2. ist eine Berechnung des Wasserdurchflusses. Der Wasserdurchfluss hat aber mit dem Schalten des Ventils nichts zu tun. Sprich das Schalten des Magnetventils funktioniert auch ohne die Berechnung.
      Also dieser Satz
      Erstens:
      Zweitens:
      Sprich dann nimmst Du den Zustand des Magnetventils als Trigger und startest dann die Berechnung, WENN das Magnetventil false ist. Und wenn Du eine payload ÄNDERN willst, dann kannst Du dies zu 99% mit einer Change Node erreichen - dafür braucht es keine zusätzlichen Nodes. Um eine Bedingung als Filter oder mehrere Bedinungen unterschiedlich zu behandeln, nimmst Du eine switch Node mit der Eigenschaft, die Du untersuchen willst.
      • AphofisA Aphofis
                "type": "tab",
                "label": "Flow 2",
                "disabled": false,
                "info": "",
                "env": []
                "type": "junction",
                "x": 200,
                "y": 200,
                "wires": [
                        "9f9432b0c01ceb15"
                "type": "junction",
                "x": 180,
                "y": 160,
                "wires": [
                        "9f9432b0c01ceb15"
                "type": "junction",
                "x": 340,
                "y": 220,
                "wires": [
                        "ed6a34a53f4a5f8a"
                "type": "debug",
                "name": "debug 1",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 960,
                "y": 80,
                "wires": []
                "name": "",
                "constant": "5.1",
                "round": true,
                "truncate": false,
                "decimals": "2",
                "decimals2": 0,
                "x": 700,
                "y": 80,
                "wires": [
                        "4135d8f01c675d48"
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 90,
                "y": 80,
                "wires": [
                        "9f9432b0c01ceb15",
                        "8eeeee9dee4f69dd"
                "x": 430,
                "y": 80,
                "wires": [
                        "d603f22a313281eb"
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 90,
                "y": 160,
                "wires": [
                        "f91ee89f94dfe23c"
                "type": "debug",
                "name": "debug 14",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 960,
                "y": 180,
                "wires": []
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "false",
                "x": 90,
                "y": 200,
                "wires": [
                        "99af6969144d7cdd"
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 970,
                "y": 220,
                "wires": []
        mickymM Offline
        mickymM Offline
        mickym
        Das ist ja richtig. Der Vorteil von NodeRed ist ja, dass Du mit Inject und Debug Nodes die Logik testen kannst ohne ein Gerät zu schalten.
        • AphofisA Offline
          AphofisA Offline
          Aphofis
          @mickym
          Ja hab jetzt auch erstmal Test Datenpunkte erstellt.
          Das auch nett von dir und auch richtog so, sonst lerne ich das ja nie.
          Soweit bin ich jetzt nur mit iobroker list ist mir noch nicht ganz klar.
                  "type": "tab",
                  "label": "Flow 2",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "type": "junction",
                  "x": 240,
                  "y": 80,
                  "wires": [
                          "ed6a34a53f4a5f8a",
                          "9f9432b0c01ceb15"
                  "id": "6fb6d75b6711436b",
                  "type": "junction",
                  "x": 400,
                  "y": 340,
                  "wires": [
                          "74e005d5d7a506a9"
                  "id": "5dbd6039e9b3e94d",
                  "type": "junction",
                  "x": 380,
                  "y": 300,
                  "wires": [
                          "74e005d5d7a506a9"
                  "type": "debug",
                  "name": "ml aktuell",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "complete": "payload",
                  "targetType": "msg",
                  "statusVal": "",
                  "x": 900,
                  "y": 140,
                  "wires": []
                  "name": "multi ml",
                  "constant": "5.21",
                  "round": true,
                  "truncate": false,
                  "decimals": "2",
                  "decimals2": 0,
                  "x": 580,
                  "y": 120,
                  "wires": [
                          "4135d8f01c675d48",
                          "be1fec4a5a0c39ea"
                  "outputLabels": [
                      "ml"
                  "icon": "font-awesome/fa-subscript"
                  "topic": "0_userdata.0.Test_Wasser.Test_Schwimmer",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "fireOnStart": "false",
                  "x": 110,
                  "y": 120,
                  "wires": [
                          "9f9432b0c01ceb15",
                          "8eeeee9dee4f69dd"
                  "topic": "0_userdata.0.Test_Wasser.Test_Durchfluss",
                  "x": 370,
                  "y": 120,
                  "wires": [
                          "d603f22a313281eb"
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "payload": "true",
                  "x": 130,
                  "y": 40,
                  "wires": [
                          "8eeeee9dee4f69dd"
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "payload": "false",
                  "x": 130,
                  "y": 80,
                  "wires": [
                          "8eeeee9dee4f69dd"
                  "topic": "0_userdata.0.Test_Wasser.Test_Magnetventil",
                  "ack": "false",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 910,
                  "y": 80,
                  "wires": []
                  "id": "74e005d5d7a506a9",
                  "name": "Div auf Liter",
                  "operation": "div",
                  "constant": "1000",
                  "round": false,
                  "truncate": false,
                  "decimals": "0",
                  "decimals2": 0,
                  "x": 590,
                  "y": 240,
                  "wires": [
                          "f4ff5bf12e391bb6"
                  "id": "be1fec4a5a0c39ea",
                  "name": "Wasser errechnet ml",
                  "topic": "0_userdata.0.Test_Wasser.Test_Wasser_kallibriert",
                  "ack": "true",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 940,
                  "y": 180,
                  "wires": []
                  "id": "d811cfd1597fb46e",
                  "name": "Wasser Kallibriert",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "x": 100,
                  "y": 240,
                  "wires": [
                          "74e005d5d7a506a9"
                  "id": "d21f0a7f46d45828",
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "payload": "true",
                  "x": 130,
                  "y": 300,
                  "wires": [
                          "5dbd6039e9b3e94d"
                  "id": "273ea49ed25edb46",
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "payload": "false",
                  "x": 130,
                  "y": 340,
                  "wires": [
                          "6fb6d75b6711436b"
                  "id": "f4ff5bf12e391bb6",
                  "type": "debug",
                  "name": "Kallibriert Liter",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 920,
                  "y": 240,
                  "wires": []
          • AphofisA Aphofis
            @mickym
                    "type": "tab",
                    "label": "Flow 2",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "type": "junction",
                    "x": 240,
                    "y": 80,
                    "wires": [
                            "ed6a34a53f4a5f8a",
                            "9f9432b0c01ceb15"
                    "type": "junction",
                    "x": 400,
                    "y": 340,
                    "wires": [
                            "74e005d5d7a506a9"
                    "type": "junction",
                    "x": 380,
                    "y": 300,
                    "wires": [
                            "74e005d5d7a506a9"
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 900,
                    "y": 140,
                    "wires": []
                    "name": "multi ml",
                    "constant": "5.21",
                    "round": true,
                    "truncate": false,
                    "decimals": "2",
                    "decimals2": 0,
                    "x": 580,
                    "y": 120,
                    "wires": [
                            "4135d8f01c675d48",
                            "be1fec4a5a0c39ea"
                    "outputLabels": [
                        "ml"
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 110,
                    "y": 120,
                    "wires": [
                            "9f9432b0c01ceb15",
                            "8eeeee9dee4f69dd"
                    "x": 370,
                    "y": 120,
                    "wires": [
                            "d603f22a313281eb"
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "true",
                    "x": 130,
                    "y": 40,
                    "wires": [
                            "8eeeee9dee4f69dd"
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "false",
                    "x": 130,
                    "y": 80,
                    "wires": [
                            "8eeeee9dee4f69dd"
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 910,
                    "y": 80,
                    "wires": []
                    "operation": "div",
                    "constant": "1000",
                    "round": false,
                    "truncate": false,
                    "decimals": "0",
                    "decimals2": 0,
                    "x": 590,
                    "y": 240,
                    "wires": [
                            "f4ff5bf12e391bb6"
                    "ack": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 940,
                    "y": 180,
                    "wires": []
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 100,
                    "y": 240,
                    "wires": [
                            "74e005d5d7a506a9"
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "true",
                    "x": 130,
                    "y": 300,
                    "wires": [
                            "5dbd6039e9b3e94d"
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "false",
                    "x": 130,
                    "y": 340,
                    "wires": [
                            "6fb6d75b6711436b"
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 920,
                    "y": 240,
                    "wires": []
            mickymM Offline
            mickymM Offline
            mickym
            @aphofis
            1. Ich verstehe es immer noch nicht. Warum nutzt Du diese ÜBERFLÜSSIGEN Nodes und nutzt nicht die normalen Change Nodes, um eine Payload zu verändern?
            2. Ich dachte, dass ein Berechnung erst dann stattfinden darf, wenn das Magnetventil false ist.
            Wenn das so richtig ist, kannst Du dann mal alles andere aus dem Flow entfernen und wir gehen Schritt für Schritt vor?
            Bis jetzt sind wir soweit und KEIN Stück weiter:
            Also nochmal meine Frage, ob wir nun so weiter machen, dass die Berechnung stattfindet, wenn das Magnetventil mit false triggert.
            AphofisA 1 Antwort Letzte Antwort
            • mickymM mickym
              @aphofis
              AphofisA Offline
              AphofisA Offline
              Aphofis
              schrieb am zuletzt editiert von Aphofis
              @mickym
              Ja! Hab jetzt nur Schwimmer, Magnetventil und zum Testen den inject node einer mit false einer mit true und klappt auch sind wie gesagt alles virtuelle Geräte
              Zum verarbeiten, habe ich Paar Datenpunkte erstellt insofern die benötigt werden.
              alles auch auf null gesetzt außer Test durchfluss, das wäre dann ja der zu verrechnende Wert. Vom Durchflußmesser.
              • AphofisA Aphofis
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @aphofis Gut den false Inject kannst Du dir ja sparen, weil die Berechnung ja NUR stattfinden, wenn das Magnetventil auf false triggert. Sprich du startest die Berechnung mit einem eigenen Flow und filterst die Nachrichten aus, dass nur noch true als payload durchkommt.
                Ja Du kannst das jetzt mit Testdatenpunkten machen - später langt es mit Inject-Nodes zu simmulieren. Aber so ist das doch OK.
                Also triggere mit dem Magnetventil die Berechnung, wenn die payload false ist und zeige den Flow. Wir entwickeln den Schritt für Schritt aber mit STANDARD Nodes.
                • mickymM mickym
                  AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  @mickym
                  Jetzt wird erst auf false die Rechnung ausgegeben. und in den Datenpunkt Test Wasser Kallibriert eingetragen.
                          "type": "tab",
                          "label": "Flow 2",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "junction",
                          "x": 180,
                          "y": 80,
                          "wires": [
                                  "ed6a34a53f4a5f8a"
                          "type": "debug",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 880,
                          "y": 180,
                          "wires": []
                          "name": "multi ml",
                          "constant": "5.21",
                          "round": true,
                          "truncate": false,
                          "decimals": "2",
                          "decimals2": 0,
                          "x": 660,
                          "y": 180,
                          "wires": [
                                  "4135d8f01c675d48",
                                  "be1fec4a5a0c39ea"
                          "outputLabels": [
                              "ml"
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 70,
                          "y": 120,
                          "wires": [
                                  "8eeeee9dee4f69dd"
                          "x": 490,
                          "y": 180,
                          "wires": [
                                  "d603f22a313281eb"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "true",
                          "x": 90,
                          "y": 80,
                          "wires": [
                                  "8eeeee9dee4f69dd"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 890,
                          "y": 80,
                          "wires": []
                          "ack": "true",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 920,
                          "y": 220,
                          "wires": []
                          "id": "2eb8ac5cc0f35dca",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 70,
                          "y": 180,
                          "wires": [
                                  "74d17f220e91338e"
                          "id": "fb8e38c311376891",
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "false",
                          "x": 90,
                          "y": 40,
                          "wires": [
                                  "8eeeee9dee4f69dd"
                          "id": "74d17f220e91338e",
                          "type": "switch",
                          "name": "",
                          "property": "payload",
                          "propertyType": "msg",
                          "rules": [
                                  "t": "eq",
                                  "v": "false",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 1,
                          "x": 270,
                          "y": 180,
                          "wires": [
                                  "9f9432b0c01ceb15"
                  • AphofisA Aphofis
                    @mickym
                            "type": "tab",
                            "label": "Flow 2",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "type": "junction",
                            "x": 180,
                            "y": 80,
                            "wires": [
                                    "ed6a34a53f4a5f8a"
                            "type": "debug",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 880,
                            "y": 180,
                            "wires": []
                            "name": "multi ml",
                            "constant": "5.21",
                            "round": true,
                            "truncate": false,
                            "decimals": "2",
                            "decimals2": 0,
                            "x": 660,
                            "y": 180,
                            "wires": [
                                    "4135d8f01c675d48",
                                    "be1fec4a5a0c39ea"
                            "outputLabels": [
                                "ml"
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 70,
                            "y": 120,
                            "wires": [
                                    "8eeeee9dee4f69dd"
                            "x": 490,
                            "y": 180,
                            "wires": [
                                    "d603f22a313281eb"
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "true",
                            "x": 90,
                            "y": 80,
                            "wires": [
                                    "8eeeee9dee4f69dd"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 890,
                            "y": 80,
                            "wires": []
                            "ack": "true",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 920,
                            "y": 220,
                            "wires": []
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 70,
                            "y": 180,
                            "wires": [
                                    "74d17f220e91338e"
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "false",
                            "x": 90,
                            "y": 40,
                            "wires": [
                                    "8eeeee9dee4f69dd"
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "eq",
                                    "v": "false",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 1,
                            "x": 270,
                            "y": 180,
                            "wires": [
                                    "9f9432b0c01ceb15"
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @aphofis Ja Du machst zwar immer mehr, als wir zusammen entwickeln aber immerhin bist Du jetzt auf dem richtigen Weg, aber schmei0 diese Kalkulator Node weg - sondern lerne mit den Standardnodes umzugehen. Es gibt NOdes die man sich zusätzlich installieren kann, aber das braucht man nicht.
                    Für Berechnungen nutzt man JSONATA. Also schmeiß das weg und nutze die Node, die man nutzt um ein payload zu Ändern.
                    • mickymM mickym
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      JSONATA
                      Welche ist denn JSONATA
                      oder meinst du json
                      • AphofisA Aphofis
                        JSONATA
                        oder meinst du json
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @aphofis
                        Sowas braucht kein Mensch und ICH werde diese NODES nicht installieren
                        Um eine payload zu ÄNDERN gibt es eine Standardnode. Wie heißt die wohl ÄNDERN = ...... - NOde
                        • mickymM mickym
                          @aphofis
                          AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          @mickym
                          ok also change node
                          hab die calculator Node rausgeschmissen.
                          • AphofisA Aphofis
                            @mickym
                            ok also change node
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @aphofis Sehr gut :)
                            So also mit der Change Node kannst Du eine payload innerhalb des Nachrichtenobjektes verschieben, sie neu schreiben, ändern oder löschen.
                            Sind dir diese 4 Fälle geläufig?
                            Importiere Dir mal diesen Flow - und schau Dir an, was wir mit dem Nachrichtenobjekt machen können:
                                   "id": "cd051990e045ac73",
                                   "type": "inject",
                                   "z": "95d5d241e51360cd",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "20",
                                   "payloadType": "num",
                                   "x": 370,
                                   "y": 460,
                                   "wires": [
                                           "070a2b4cb0049c8b",
                                           "79acf22a95932020"
                                   "id": "070a2b4cb0049c8b",
                                   "type": "debug",
                                   "name": "Komplettes Nachrichtenobjekt",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "true",
                                   "targetType": "full",
                                   "statusVal": "",
                                   "x": 630,
                                   "y": 420,
                                   "wires": []
                                   "id": "79acf22a95932020",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 570,
                                   "y": 480,
                                   "wires": [
                                           "3429626fc84b980b"
                                   "id": "3429626fc84b980b",
                                   "type": "debug",
                                   "name": "Verändertes Nachrichtenobjekt",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "true",
                                   "statusVal": "",
                                   "x": 830,
                                   "y": 480,
                                   "wires": []
                            Damit siehst Du auch wie ein minimales Nachrichtenobjekt in der Regel aussieht. Schau Dir auch an, was der UNTERSCHIED ist, wenn Du Dir das komplette Nachrichtenobjekt ausgibst oder nur die payload Eigenschaft des Nachrichtenobjektes.
                            AphofisA 2 Antworten Letzte Antwort
                            • mickymM mickym
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "20",
                                     "x": 370,
                                     "y": 460,
                                     "wires": [
                                             "070a2b4cb0049c8b",
                                             "79acf22a95932020"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "complete": "true",
                                     "statusVal": "",
                                     "x": 630,
                                     "y": 420,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 570,
                                     "y": 480,
                                     "wires": [
                                             "3429626fc84b980b"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "complete": "true",
                                     "statusVal": "",
                                     "x": 830,
                                     "y": 480,
                                     "wires": []
                              AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              @mickym bekannt ja aber was genau verschieben und setzen heißt nicht so genau
                              • mickymM mickym
                                       "type": "inject",
                                       "name": "",
                                       "props": [
                                               "p": "payload"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "20",
                                       "x": 370,
                                       "y": 460,
                                       "wires": [
                                               "070a2b4cb0049c8b",
                                               "79acf22a95932020"
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 630,
                                       "y": 420,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 570,
                                       "y": 480,
                                       "wires": [
                                               "3429626fc84b980b"
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 830,
                                       "y": 480,
                                       "wires": []
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                Ja hab ich gesehen.
                                1. Debug hat den Wert 20
                                2. Debug hat den Wert 0
                                • AphofisA Aphofis
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Na deswegen machen wir erst mal diese Grundlagen.
                                  Also importiere den unteren Flow - und Du musst wissen, welche Datentypen es gibt.
                                  Also: Zeichenkette, Boolean, Zahl, Objekt, Array.
                                  • AphofisA Aphofis
                                    Ja hab ich gesehen.
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @aphofis Na siehst Du dass wir das GESAMTE Nachrichtenobjekt ausgegeben haben?
                                    • AphofisA Aphofis
                                      Ja hab ich gesehen.
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      Ja hab ich gesehen.
                                      Nein - die 2. Debug Node enthält nicht den Wert 0 sondern eine leere Zeichenkette.
                                      mickymM AphofisA 2 Antworten Letzte Antwort
                                      • mickymM mickym
                                        AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        @mickym
                                        Ja die Datentypen sind mir bekannt. Wir wollen ja nur mit value (Zahlen) arbeiten.
                                        • mickymM mickym
                                          Ja hab ich gesehen.
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          Ja hab ich gesehen.
