  3. Off Topic
  4. Magic Mirror zusammen mit IOBroker
    6.8k
magic mirror
224 Beiträge 24 Kommentatoren 61.4k Aufrufe 21 Beobachtet
    @kusselin
    Ich vermute, da läuft kein ioBroker auf der Kiste, oder?
    Dann musst du das nodesource-Repo 'von Hand' auf den aktuellen Stand bringen.
    sudo rm /etc/apt/sources.list.d/node*
    curl -fsSL https://deb.nodesource.com/setup_20.x -o nodesource_setup.sh
    bash nodesource_setup.sh
    sudo apt update
    sudo apt install nodejs
    KusselinK Offline
    KusselinK Offline
    Kusselin
    #189
    @thomas-braun nee da läuft kein iobroker..ist reiner lxc für magicmirror..dann so wie du vorgegeben hast updaten ok?
      @kusselin
      sudo apt update
      KusselinK Offline
      KusselinK Offline
      Kusselin
      #190
      @thomas-braun ergebnis deiner codes jetzt
      pi@MagicMirror-live:~/MagicMirror$ npm run server
      > magicmirror@2.27.0 server
      > node ./serveronly
      [2024-08-09 11:18:05.959] [LOG]   Starting MagicMirror: v2.27.0
      [2024-08-09 11:18:05.970] [LOG]   Loading config ...
      [2024-08-09 11:18:05.972] [LOG]   config template file not exists, no envsubst
      [2024-08-09 11:18:06.407] [LOG]   Loading module helpers ...
      [2024-08-09 11:18:06.408] [LOG]   No helper found for module: alert.
      [2024-08-09 11:18:06.568] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.569] [LOG]   Module helper loaded: updatenotification
      [2024-08-09 11:18:06.569] [LOG]   No helper found for module: clock.
      [2024-08-09 11:18:06.643] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.644] [LOG]   Module helper loaded: calendar
      [2024-08-09 11:18:06.644] [LOG]   No helper found for module: weather.
      [2024-08-09 11:18:06.706] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.706] [LOG]   Module helper loaded: MMM-Remote-Control
      [2024-08-09 11:18:06.707] [LOG]   No helper found for module: compliments.
      [2024-08-09 11:18:06.765] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.765] [LOG]   Module helper loaded: newsfeed
      [2024-08-09 11:18:06.775] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.775] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.27.0
      [2024-08-09 11:18:06.776] [LOG]   Version is ok!
      [2024-08-09 11:18:06.776] [LOG]   Module helper loaded: MMM-Fuel
      [2024-08-09 11:18:06.786] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:06.787] [LOG]   Module helper loaded: MMM-PublicTransportHafas
      [2024-08-09 11:18:07.089] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:07.089] [LOG]   Module helper loaded: MMM-RNV
      [2024-08-09 11:18:07.090] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:07.090] [LOG]   Module helper loaded: MMM-ioBroker
      [2024-08-09 11:18:07.123] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:07.123] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
      [2024-08-09 11:18:07.125] [LOG]   Initializing new module helper ...
      [2024-08-09 11:18:07.126] [LOG]   Module helper loaded: MMM-SoccerLiveScore
      [2024-08-09 11:18:07.129] [ERROR] Whoops! There was an uncaught exception...
      [2024-08-09 11:18:07.133] [ERROR] Error: Cannot find module 'node-fetch'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js
      - /home/pi/MagicMirror/js/app.js
      - /home/pi/MagicMirror/serveronly/index.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:986:27)
          at Module.require (node:internal/modules/cjs/loader:1233:19)
          at require (node:internal/modules/helpers:179:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js:8:15)
          at Module._compile (node:internal/modules/cjs/loader:1358:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          at Module.load (node:internal/modules/cjs/loader:1208:32)
          at Module._load (node:internal/modules/cjs/loader:1024:12)
          at loadModule (/home/pi/MagicMirror/js/app.js:183:19)
          at loadModules (/home/pi/MagicMirror/js/app.js:213:10)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          at async App.start (/home/pi/MagicMirror/js/app.js:261:3) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/serveronly/index.js'
      [2024-08-09 11:18:07.133] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2024-08-09 11:18:07.133] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      [2024-08-09 11:18:07.219] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: ; raspberry: undefined; virtual: false
      ### OS:       platform: linux; distro: Ubuntu; release: 22.04.4 LTS; arch: x64; kernel: 6.5.13-3-pve
      ### VERSIONS: electron: undefined; used node: 20.16.0; installed node: 20.16.0; npm: 10.8.1; pm2:
      ### OTHER:    timeZone: UTC; ELECTRON_ENABLE_GPU: undefined
      • KusselinK Kusselin
        > node ./serveronly
        Require stack:
          requireStack: [
        #191
        @kusselin
        Also läuft das nun in der aktuellen nodejs-Umgebung.
        Fein.
        Zur Konfiguration des ganzen kann ich dir nix raten, da musst du mal auf der Seite von magicmirror schauen.
        KusselinK 1 Antwort Letzte Antwort
          @kusselin
          Fein.
          KusselinK Offline
          KusselinK Offline
          Kusselin
          #192
          @thomas-braun o.k. laufen tut er in der aktuellen umgebung aber ich kann ihn nicht aufrufen...
          am besten wirds sein das ich die config sichere udn den container neu aufsetze mit aktuellem Ubuntu system...
          ist das O.K.?
            ist das O.K.?
            #193
            @kusselin
            Und was soll das bringen?
            Den MagicMirror musst du auch in einem anderen System richtig konfigurieren.
              @kusselin
              KusselinK Offline
              KusselinK Offline
              Kusselin
              #194
              @thomas-braun war jetzt nur ne Frage.....
              lt. der consolenausgabe läuft der MM aber die Module laufen nicht...kannst du das auch herauslesen?
              • M mrjeschke
                @kusselin
                Du könntest den Installer noch mal starten.
                cd ~/MagicMirror
                npm run install-mm
                KusselinK Offline
                KusselinK Offline
                Kusselin
                schrieb am zuletzt editiert von Kusselin
                #195
                @mrjeschke Hi, ich habe jetzt mal ein bisschen probiert und neu installiert.. ich habe ja den MM in einem Container udn auch gesichert...wenn ich diesen wieder aufspiele dann geht er ist aber nicht aktuell...aber man kann ja auch probieren....also was habe ich gemacht..
                1. Neuen ConLXC Container angelegt
                2. Ubuntu 24 LTS installiert
                3. apt-get update && apt-get upgrade -y ausgeführt
                4. neuen User "MM" angelegt mit useradd -s /bin/bash -m MM
                5. passwort für MM vergeben
                6. den Neuen User der Gruppe "sudo" zugeführt mit sudo usermod -a -G sudo MM
                7. reboot
                8. angemeldet mit MM uns pass
                9. dann folegenden Befehl ausgeführt:
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                1. nach Installation folegenden weiteren Befehl ausgeführt:
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                1. dann cd eingegeben und ich stehe auf
                mm@MagicMirror-live:~$
                1. dann nano mm.sh eingegeben und fiolgendes dort eingefügt:
                cd ~/MagicMirror
                npm run server
                • Dann die Datei ausfürbargemacht mit
                chmod +r ~/mm.sh
                1. dann crontab -e eingebgeben und 1 gewählt dann dort das ganz unten als letztes eingegeben:
                @reboot /home/pi/mm.sh
                1. dann raus und reboot gemacht....
                  15.sicherheitshalber ins verzeichnis /MagicMirror gegangen udn npm run server ausgeführt..
                2. dann kommt das raus:
                mm@MagicMirror-live:~/MagicMirror$ npm run server
                > magicmirror@2.28.0 server
                > node ./serveronly
                [2024-08-10 16:51:17.974] [LOG]   Starting MagicMirror: v2.28.0
                [2024-08-10 16:51:17.986] [LOG]   Loading config ...
                [2024-08-10 16:51:17.989] [LOG]   config template file not exists, no envsubst
                [2024-08-10 16:51:18.334] [LOG]   Loading module helpers ...
                [2024-08-10 16:51:18.335] [LOG]   No helper found for module: alert.
                [2024-08-10 16:51:18.343] [LOG]   Initializing new module helper ...
                [2024-08-10 16:51:18.344] [LOG]   Module helper loaded: updatenotification
                [2024-08-10 16:51:18.344] [LOG]   No helper found for module: clock.
                [2024-08-10 16:51:18.561] [LOG]   Initializing new module helper ...
                [2024-08-10 16:51:18.563] [LOG]   Module helper loaded: calendar
                [2024-08-10 16:51:18.565] [LOG]   No helper found for module: compliments.
                [2024-08-10 16:51:18.567] [LOG]   No helper found for module: weather.
                [2024-08-10 16:51:18.568] [LOG]   No helper found for module: weather.
                [2024-08-10 16:51:18.717] [LOG]   Initializing new module helper ...
                [2024-08-10 16:51:18.717] [LOG]   Module helper loaded: newsfeed
                [2024-08-10 16:51:18.718] [LOG]   All module helpers loaded.
                [2024-08-10 16:51:18.724] [LOG]   Starting server on port 8080 ...
                [2024-08-10 16:51:18.746] [LOG]   Server started ...
                [2024-08-10 16:51:18.747] [LOG]   Connecting socket for: updatenotification
                [2024-08-10 16:51:18.747] [LOG]   Starting module helper: updatenotification
                [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: calendar
                [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: calendar
                [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: newsfeed
                [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: newsfeed
                [2024-08-10 16:51:18.749] [LOG]   Sockets connected & modules started ...
                [2024-08-10 16:51:18.749] [INFO]
                >>>   Ready to go! Please point your browser to: http://localhost:8080   <<<
                [2024-08-10 16:51:18.871] [INFO]  System information:
                ### OS:       platform: linux; distro: Ubuntu; release: 24.04 LTS; arch: x64; kernel: 6.5.13-3-pve
                ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                ^C[2024-08-10 16:51:29.977] [LOG]   [SIGINT] Received. Shutting down server...
                [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: updatenotification
                [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: calendar
                [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: newsfeed
                [2024-08-10 16:51:29.978] [LOG]   Node_helpers stopped ...
                whats that :-(
                Er fährt den Server wieder runter.. :-( wieso ?
                Bin ich wieder falsch vorgegangen?????
                Danke und Gruss
                Thomas BraunT M 2 Antworten Letzte Antwort
                  7. reboot
                  cd ~/MagicMirror
                  npm run server
                  chmod +r ~/mm.sh
                  > node ./serveronly
                  whats that :-(
                  Danke und Gruss
                  #196
                  @kusselin sagte in Magic Mirror zusammen mit IOBroker:
                  Wozu? Der User soll natürlich keine root-Rechte erhalten können.
                    7. reboot
                    cd ~/MagicMirror
                    npm run server
                    chmod +r ~/mm.sh
                    > node ./serveronly
                    whats that :-(
                    Danke und Gruss
                    M Online
                    M Online
                    mrjeschke
                    #197
                    @kusselin
                    Ich musste das ganze WE arbeiten. Darum konnte ich es mir erst jetzt ansehen.
                    Der Server ist runtergefahren weil du Strg-C gedrückt hast (vermute ich)
                    Das ist ja nur zum Test ob es überhaupt läuft.
                    Den Autostart muss du anpassen da du den usernamen geändert hast.
                    Im crontab musst du den username (pi) durch den neuen usernamen (MM) ersetzen.
                    Den Autostart auf systemd zu ändern wäre sicher besser.
                    Mit der Konfiguration wirst du aber keine Verbindung bekommen.
                    Dazu muss noch die config.js angepasst werden da der Server sonst nur aus localhost reagiert.
                    address: "0.0.0.0",
                    ipWhitelist: [],
                      KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      #198
                      @thomas-braun sagte in Magic Mirror zusammen mit IOBroker:
                      Doch, ich muss den neuen user der Gruppo sudo (in der /etc/sodoer) zuordnen, sonst kann ich unter dem neuen User MM nicht installieren (Beschreibung).
                      • M mrjeschke
                        @kusselin
                        address: "0.0.0.0",
                        ipWhitelist: [],
                        KusselinK Offline
                        KusselinK Offline
                        Kusselin
                        #199
                        @mrjeschke sagte in Magic Mirror zusammen mit IOBroker:
                        @kusselin
                        Oh mann....stimmt das kann sein..weil ich dann wieder auf dem "Prompt" stand...also mm@....
                        Heisst für mich...nach dem starten vom "npm run server" nichts mehr machen....richtig?
                        Wenn ich dann aber mal zb. den Container neu starten muss, dann greift der Cron richtig?
                        Ne Frage zum Cron habe ich auch noch....wenn ich mit dem User "MM" angemeldet bin und mache dann ein "CD" dann, dann steht da ja in putty zb. mm@magicmirror-live..
                        Heisst das jetzt das ich von hier ab dann im home-verzeichnis von user mm bin, also das ich dann hier das "nano mm.sh" machen kann? oder muss ich da dann erst noch nach cd home navigieren..? das hab ich noch nicht so verstanden udn es wäre nett wenn ihr mir das noch erklären könnt. Danke
                        @kusselin
                        O.K. ist auch verständlich habe ich auch nicht gemacht....danke
                        Du meinst mit systemd, richtig? nicht Cron.
                        @kusselin
                        Sorry, das ist natürlich bei so einem Wetter auch nicht gerade angenehm. Danke für Deine Unterstützung.
                        Aber hätte der MM nicht bei
                        wenn ich die IP:8080 eingebe im Browser erscheinen müssen? bevor ich CTRL+c gedrückt habe?
                        Das ist er nämlich auch nicht.....also aufgegangen im Browser.
                        Ich probiers nochmal.....
                        Ach und nochwas...ich kann ja jetzt die alte config.js speichern....kann ich diese dann 1:1 in die neue Installation übernehmen? (Ich muss natürlich unter modules die Module installiert haben. Geht das ?
                        Aber soweit bin ich schon korrekt vorgegangen vom Ablauf oder?
                          @kusselin
                          @kusselin
                          @kusselin
                          M Online
                          M Online
                          mrjeschke
                          #200
                          @kusselin
                          Ja richtig. Gehe mit cd in das home-Verzeichnis
                          Mit
                          nano mm.sh
                          die Datei öffnen und Inhalt reinkopieren
                          cd ~/MagicMirror
                          npm run Server
                          speichern + beenden und ausführbar machen
                          chmod +x mm.sh
                          Dann
                          crontab -e
                          den username korrigieren
                          dann kannst du dein alte config.js in das config-Verzeichnis kopieren und den Container neu starten
                          Dann sollte alles wieder laufen. Den Befehl npm run server brauchst du dann nicht mehr.
                          Der war nur zum Test ob die Sofware läuft.
                          KusselinK 2 Antworten Letzte Antwort
                          • M mrjeschke
                            @kusselin
                            Mit
                            nano mm.sh
                            cd ~/MagicMirror
                            npm run Server
                            chmod +x mm.sh
                            Dann
                            crontab -e
                            KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            #201
                            @mrjeschke ich probiers und melde mich.
                            ne Frage noch zu /home....ich komme da aber auch rein indem ich cd /home schreibe...du sagst aber ich solle dann erstmal cd machen....bin ich dann wirklich auch im home verzeichnis von user mm?
                              M Online
                              M Online
                              mrjeschke
                              #202
                              @kusselin
                              Wenn du cd eingibst kommst du in das home-Vereichnis des angemeldeten users.
                              Wenn du cd /home eingibst landest du ein Verzeichnis höher.
                              Also das Verzeichnis in dem sich die Verzeichisse aller user sind.
                              Probier es aus. Mit pwd zeigt er dir dein aktuelles Vezeichnis an.
                              cd
                              pwd
                              cd /home
                              pwd
                              • M mrjeschke
                                @kusselin
                                cd
                                pwd
                                cd /home
                                pwd
                                KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                #203
                                @kusselin
                                cd
                                pwd
                                cd /home
                                pwd
                                ahh ok...mit cd und user mm bzw. pi komme ich in das jeweilige "Home-verzeichnis" des entsprechenden Users.
                                Mit cd /home komme ich generell in das "Home-Verzeichnis" unabhängig vom User richtig verstanden?
                                  @kusselin
                                  cd
                                  pwd
                                  cd /home
                                  pwd
                                  #204
                                  Mit cd /pfad/irgendwohin (steht für Change Directory) wechselst du in das angegebene Verzeichnis.
                                  Mit cd ohne weitere Angaben springst du immer sofort in das /home des Users, mit dem du eingeloggt bist.
                                  MIt cd - springst du in das vorherige Verzeichnis zurück.
                                    KusselinK Offline
                                    KusselinK Offline
                                    Kusselin
                                    #205
                                    o.k. danke Thomas...so ist es natürlich ausfürlich erklärt...aber so wie ichs oben geschrieben habe, passt es doch auch einfach ja oder nein?
                                    • M mrjeschke
                                      @kusselin
                                      Mit
                                      nano mm.sh
                                      cd ~/MagicMirror
                                      npm run Server
                                      chmod +x mm.sh
                                      Dann
                                      crontab -e
                                      KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                      #206
                                      @kusselin
                                      Mit
                                      nano mm.sh
                                      cd ~/MagicMirror
                                      npm run Server
                                      chmod +x mm.sh
                                      Dann
                                      crontab -e
                                      Habs eben nochmal probiert mit dem Befehl:
                                      es kam dann noch die Meldung bei der Installation ob ich den Screensaver disablen will...habe da ja gesagt...
                                      und dann kommt noch die Meldung ob ich pm2 autostarting will? was mach ich da? yes oder?
                                        @kusselin
                                        Mit
                                        nano mm.sh
                                        cd ~/MagicMirror
                                        npm run Server
                                        chmod +x mm.sh
                                        Dann
                                        crontab -e
                                        M Online
                                        M Online
                                        mrjeschke
                                        #207
                                        @kusselin
                                        Beim Autostart sag mal nein. Sonst startet es ja 2x.
                                        Der Autostart mit pm2 hat bei mir außerdem nicht funktioniert.
                                        • M mrjeschke
                                          @kusselin
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          #208
                                          @mrjeschke o.k so habs ichs gemacht...habe in der config datei noch das kjetzt geändert...
                                          et config = {
                                          	address: "0.0.0.0",	// Address to listen on, can be:
                                          							// - "localhost", "127.0.0.1", "::1" to listen on loopback interface
                                          							// - another specific IPv4/6 to listen on a specific interface
                                          							// - "0.0.0.0", "::" to listen on any interface
                                          							// Default, when address config is left out or empty, is "localhost"
                                          	port: 8080,
                                          	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                          									// you must set the sub path here. basePath must end with a /
                                          	ipWhitelist: [],	// Set [] to allow all IP addresses
                                          									// or add a specific IPv4 of 192.168.1.5 :
                                          									// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
                                          									// or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
                                          									// ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
                                          Jetzt komme ich drauf mit IP:8080
                                          die mm.sh liegt jetzt unter user mm unter /home/mm
                                          wenn ich den Container reboote dann startet der MM aber auch nicht obwohl ich die mm.sh ausführbar gemacht habe. Was ist eigentlich ausfürhbar bei dir?? 755 oder 777 oder 644?
                                          Ich muss erst wieder per putty drauf in cd MagicMirror dann npm run server udn dann startet der auch und bleibt an bis zum nächsten reboot
