  4. Lay-Z-Spa Wifi Control
    apollon77A
210 Beiträge 74 Kommentatoren 91.7k Aufrufe 72 Beobachtet
  • Agria4800A Agria4800
    @agria4800 : Anbei das Script für die Leute mit dem Layz Hawaii oder Maldives (mit den Hydrojet Düsen) ;-)
    // https://forum.iobroker.net/topic/51603/lay-z-spa-wifi-control?_=1655490942180&lang=de
    /*Notes for me
    Last filter change was 0.00 day(s) ago.  RESET Button gedrückt!
    {"CMD":10,"VALUE":0,"XTIME":1658859596,"INTERVAL":0}
    Last chlorine add was 0.00 day(s) ago.
    {"CMD":9,"VALUE":0,"XTIME":1658859652,"INTERVAL":0}
    const Messages =
     "CONTENT": "STATES",
     "LCK": 0,
     "PWR": 0,
     "UNT": 1,
     "AIR": 0,
     "GRN": 0,
     "RED": 0,
     "FLT": 0,
     "TGT": 22,
     "TMP": 13,
     "CH1": 32,
     "CH2": 49,
     "CH3": 51,
     "HJT": 0,
     "BRT": 7
    const ID = '0_userdata.0.Layz-Hydro';
    const MQTTINSTANCE = 0;
    const debug = true;
     "CONTENT": "TIMES",
     "TIME": 1650746370,
     "CLTIME": 1644734714,
     "FTIME": 1644734719,
     "UPTIME": 41660,
     "PUMPTIME": 50,
     "HEATINGTIME": 24,
     "AIRTIME": 512,
     "JETTIME": 4294966,
     "COST": 0,
     "FINT": 4294967295,
     "CLINT": 4294967295,
     "KWH": null,
     "TTTT": -74677
    const STATES=[
           _id: 'LCK',
           type: 'state',
           common: {
               type: 'boolean',
               role: 'switch',
               read: true,
               write: false,
               desc: 'Lazy spa lock'
           native: {}
           _id: 'PWR',
           type: 'state',
           common: {
               type: 'boolean',
               role: 'switch.power',
               read: true,
               write: true,
               desc: 'Lazy spa power'
           native: {}
       _id: 'UNT',
       type: 'state',
       common: {
           type: 'number',
           role: 'value',
           read: true,
           write: true,
           max: 1,
           desc: 'Lazy spa unit',
           states: {
       			0: 'Farenheit',
       			1: 'Celsius'
          native: {}
       _id: 'HJT',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'Lazy spa Hydrojets state'
          native: {}
       _id: 'AIR',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'Lazy spa bubbles state'
       native: {}
       _id: 'GRN',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: false,
           desc: 'reached target temp.'
       native: {}
       _id: 'RED',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: false,
           desc: 'not reached target temp.'
       native: {}
       _id: 'FLT',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'pump state'
       },    native: {}
       _id: 'HEATER',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'heater state'
       native: {}
       _id: 'TGT',
       type: 'state',
       common: {
           type: 'number',
           role: 'level.temperature',
           min: 20,
           max: 40,
           steps: 1,
           read: true,
           write: true,
           desc: 'taget temp.'
       native: {}
       _id: 'TMP',
       type: 'state',
       common: {
           type: 'number',
           role: 'value.temperature',
           read: true,
           write: false,
           unit: '°C',
           desc: 'temp.'
       native: {}
    init();
    async function stateChange(obj){
       let id = obj.id
       let state = id.split('.').pop()
       let value = obj.state.val
       log('change Unit' + state)
       switch (state) {
           case 'UNT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":1,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('change Unit')
           break;
           case 'TGT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":0,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('change target temp. to '+ value);
           break;
           case 'AIR':
               value = value ? 1: 0 ;
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":2,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set bubbles to '+ value);
           break;
            case 'HJT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":11,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set Hydrojets to '+ value);
           break;
           case 'HEATER':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":3,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set Heater to '+ value);
           break;
           case 'FLT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":4,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set pump to '+ value);
           break;
     default:
       // Anweisungen werden ausgeführt,
       // falls keine der case-Klauseln mit expression übereinstimmt
       break;
    async function init(){
       await asyncForEach(STATES, async (obj, index) => {
           let id = ID +'.'+ obj._id
           if (!existsState(id)) {
               log('create state '+ id)
               await createStateAsync(id, obj.common)
           else {
               log('skip state '+ id)
           //set subscription
           if(obj.common.write){
               on({id: id, change:"any"} , function(obj) {
                   if(!obj.state.ack){
                       log('change state! '+ JSON.stringify(obj))
                       stateChange(obj)
       log('init done!')
    async function setLazyStates(obj){
       try{
               let states = JSON.parse(obj)
               for (const [key, value] of Object.entries(states)) {
                   let statevalue = value
                   const found = STATES.find(state => state._id === key);
                   if(found){
                       if (found.common.type === 'boolean'){
                           statevalue = value === 1
                       await setStateAsync(ID +'.'+ key,statevalue,true)
               //set heater state
               await setStateAsync(ID +'.HEATER',(states.GRN || states.RED) === 1,true)
       catch(e){
           console.log('Error in setting State '+ e)
    async function asyncForEach(array, callback) {
       for (let index = 0; index < array.length; index++) {
       	await callback(array[index], index, array);
    function log (msg){
       if(debug) console.log (msg)
    on({id:'mqtt.'+ MQTTINSTANCE+'.layzspa.message', change:"ne"} , function(obj) {
       log('Lazyspa reached message! '+ JSON.stringify(obj.state))
       setLazyStates(obj.state.val)
    K
    K
    kukoratsch
    schrieb am zuletzt editiert von kukoratsch
    #163
    @agria4800 DANKE
    • K kukoratsch
      @agria4800 DANKE
      T
      T
      TimoWald
      #164
      @kukoratsch sehr sehr schön. Wie hast du es mit dem Zählern gemacht? Verbrauch etc.
      Könnte ich die Vis Seite haben?
      • Der-JetiD
        Der-JetiD
        Der-Jeti
        #165
        Kann jemand die stl vom einem PCB_V2 Gehäuse zur Verfügung stellen?
        • T TimoWald
          K
          K
          kukoratsch
          #166
          @timowald Die Datenpunkte manuel anlegen
          und die beiden Scripten aus post 57 nehmen und anpassen
          bei dir ist das mqtt.2
          • K kukoratsch
            T
            T
            TimoWald
            #167
            @kukoratsch Hallo habe es jetzt soweit aber es kommen noch folgende Meldungen im JS.
            • T TimoWald
              K
              K
              kukoratsch
              #168
              @timowald Zeig mal Screenshot von 0_userdata
              • K kukoratsch
                T
                T
                TimoWald
                schrieb am zuletzt editiert von TimoWald
                #169
                Wurde mit dem Handy gemacht.
                • T TimoWald
                  K
                  K
                  kukoratsch
                  #170
                  @timowald aber wo sind die anderen Datenpunkte
                  • T
                    T
                    TimoWald
                    #171
                    @kukoratsch So jetzt nochmal richtig.
                    • R
                      R
                      rooney09
                      #172
                      ich besitze seit neustem einen Lay-Z-Spa St. Moritz und würde diesen gerne "smart" machen.
                      Verkauft mir jemand ein Modul komplett fertig für einen angemessenen Betrag?
                      • R rooney09
                        T
                        T
                        TimoWald
                        #173
                        @rooney09 ich habe mein Modul komplett fertig bei eBay bestellt.
                        • T TimoWald
                          T
                          T
                          TimoWald
                          #174
                          @timowald Hallo, gibt es einen Befehl aus dem IOBroker heraus um das Display abzuschalten?
                          W 1 Antwort Letzte Antwort
                          • T TimoWald
                            W
                            W
                            wolkenloser
                            #175
                            ich habe mir vor ein paar Wochen bei ebay ein WifiWHIRL MODUL bei ebay gekauft und wollte das gerne in IOBROKER hinzufügen.
                            Da es keinen Adapter dafür gibt, hab ich gesucht und bin auf diesen Threat gestossen.
                            Ich habe ein paar Dinge ausprobiert aber ich bekomme keine Daten in IOBROKER.
                            Dabei stellt sich mir die Frage ob man ggf mal einmal die Schritte zusammen fassen könnte die bei einer neuinstallation notwenig sind.
                            1. Frage (warum) braucht man eine zusätzliche MQTT Instanz ?
                            2. Welches Script braucht man für ein LazySpa Miami ?
                            Ich habe das Script aus dem Beitrag 54 bei mir eingerichtet.
                            Dann legt das Script auch einen Datenenpunkt an.
                            Ich verstehe nur nicht wie ich jetzt die verknüpfunge zwischen dem Modul machen damit er die angelegte Instanz aktualisiert.....
                            const ID = '0_userdata.0.LazySpa';
                            const debug = true;
                            Wolke
                            K 2 Antworten Letzte Antwort
                            • W wolkenloser
                              const debug = true;
                              Wolke
                              K
                              K
                              kukoratsch
                              #176
                              @wolkenloser mit MQTT Instanz bekommst du die Daten von dein Lay-Z-Spa Wifi Modul
                              • K kukoratsch
                                W
                                W
                                wolkenloser
                                #177
                                @kukoratsch hi, anscheinend ja nicht....
                                Oder muss ich bei mqtt Instanz was anderes eingeben als 0?
                                • W wolkenloser
                                  K
                                  K
                                  kukoratsch
                                  #178
                                  @wolkenloser
                                  Zeig mal die drei screenshot von dir
                                  @kukoratsch sagte in Lay-Z-Spa Wifi Control:
                                  • K kukoratsch
                                    @wolkenloser
                                    W
                                    W
                                    wolkenloser
                                    #179
                                    @kukoratsch aufgrund deines Screenshots habe ich jetzt auch einen MQTT Adapter installiert.
                                    Daraufhin erhalte ich Werte, aber ich glaube da ist noch einiges nicht richtig:
                                    • W wolkenloser
                                      W
                                      W
                                      wolkenloser
                                      #180
                                      @kukoratsch ,
                                      wo finde ich z.B. die Objekte wo man dann die Heizung Ein- oder Ausschalten kann ?
                                      Ich glaube die fehlen einfach...
                                      • W wolkenloser
                                        @kukoratsch ,
                                        K
                                        K
                                        kukoratsch
                                        #181
                                        @wolkenloser 0_userdata.0.LazySpa heater
                                        • K kukoratsch
                                          W
                                          W
                                          wolkenloser
                                          #182
                                          @kukoratsch
                                          Hi, eben dort ist nichts dergleichen.
                                          84.0k
