  4. Pool Thermometer und Chlormesser
    6.8k
allgemein
118 Beiträge 30 Kommentatoren 27.5k Aufrufe 40 Beobachtet
  • S Scubydoo
    @oxident Installation hat funktioniert.
    O Online
    O Online
    oxident
    #85
    @scubydoo Danke für die Rückmeldung! Viel Spaß...
    • O oxident
      Okay, hier mal das YAML für ESPHome um die Blueconnects ohne Cloud auszulesen:
      substitutions:
        # erster Blueconnect
        blueriiot1_mac: '00:A0:50:ZZ:XX:YY'
        blueriiot1_name_prefix: 'pool'
        blueriiot1_id_prefix: 'pl'
        # zweiter Blueconnect
        # ggf. auskommentieren
        blueriiot2_mac: '00:A0:50:ZZ:XX:YY'
        blueriiot2_name_prefix: 'spa'
        blueriiot2_id_prefix: 'sp'
        # send true 0x01 to this service ID
        blueriiot_send_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
        blueriiot_send_characteristic_uuid: 'F3300002-F0A2-9B06-0C59-1BC4763B5C00'
        # notification is recieved on this Service ID
        blueriiot_recieve_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
        blueriiot_recieve_characteristic_uuid: 'F3300003-F0A2-9B06-0C59-1BC4763B5C00'
      esphome:
        friendly_name: Poolsensoren
      esp32:
        board: m5stack-atom # ANPASSEN
        framework:
          type: arduino
      # Enable logging
      logger:
        #level: VERY_VERBOSE
        level: INFO
      # Enable Home Assistant API
      api:
        password: "1234"
      ota:
        password: "1234"
      wifi:
        ssid: !secret wifi_ssid
        password: !secret wifi_password
      esp32_ble_tracker:
      ble_client:
        # erster Sensor
        - mac_address: ${blueriiot1_mac}
          on_connect:
            then:
              - lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(true);"
              - delay: 2s
              - button.press: button_${blueriiot1_id_prefix}_doreading
          on_disconnect: [lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(false);"]
        # zweiter Sensor (optional)
        - mac_address: ${blueriiot2_mac}
          on_connect:
            then:
              - lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(true);"
              - delay: 2s
              - button.press: button_${blueriiot2_id_prefix}_doreading
          on_disconnect: [lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(false);"]
      binary_sensor:
      # erster Sensor
        - platform: template
          device_class: connectivity
          entity_category: diagnostic
      switch:
        # erster Sensor
        - platform: ble_client
          ble_client_id: ble_client_${blueriiot1_id_prefix}
          restore_mode: ALWAYS_OFF
          ble_client_id: ble_client_${blueriiot2_id_prefix}
      sensor:
        # erster Sensor
          name: ${blueriiot1_name_prefix} Temperature
          # Optional variables:
          unit_of_measurement: "°C"
          icon: "mdi:water-percent"
          device_class: "temperature"
          state_class: "measurement"
          accuracy_decimals: 1
          #unit_of_measurement: "°C"
          #icon: "mdi:water-percent"
          #device_class: "temperature"
          device_class: "voltage"
          device_class: "battery"
        # ENDE erster Sensor
          name: ${blueriiot2_name_prefix} Temperature
        # ENDE zweiter Sensor (optional)
      ## Blue Connect
      # erster Sensor
      button:
          name: ${blueriiot1_name_prefix} do reading
          internal: true
          on_press:
            then:
              - ble_client.ble_write:
                  service_uuid: ${blueriiot_send_service_uuid}
                  characteristic_uuid: ${blueriiot_send_characteristic_uuid}
                  # A lambda returning an std::vector<uint8_t>.
                  value: !lambda |-
                    return {0x01};
          name: ${blueriiot2_name_prefix} do reading
          internal: true
          on_press:
            then:
                  value: !lambda |-
                    return {0x01};
      text_sensor:
        # erster Sensor
          name: ${blueriiot1_name_prefix} reading data
          internal: true
          service_uuid: ${blueriiot_recieve_service_uuid}
          characteristic_uuid: ${blueriiot_recieve_characteristic_uuid}
          notify: true
          update_interval: never
          on_notify:
            then:
             lambda: |-
                std::string rawhex = format_hex_pretty((uint8_t *) x.c_str(), x.size()).c_str();
                ESP_LOGD("raw_hex", "%s", rawhex.c_str());
                float temperature = (float)((int16_t)(x[2]<< 8) + x[1])/100;
                ESP_LOGD("temp", "%f", temperature);
                id(sensor_${blueriiot1_id_prefix}_temperature).publish_state(temperature);
                float raw_ph = (float)( (int16_t) (x[4]<< 8) + x[3]) ;
                float ph = (float)( (int16_t) (2048 - raw_ph)) / 232  + 7 ;
                ESP_LOGD("ph", "%f", ph);
                id(sensor_${blueriiot1_id_prefix}_ph).publish_state(ph);
                float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86 ;
                ESP_LOGD("orp", "%f", orp);
                id(sensor_${blueriiot1_id_prefix}_orp).publish_state(orp);
                float bat = (float)( (int16_t) x[11]) ;
                ESP_LOGD("bat", "%f", bat);
                id(sensor_${blueriiot1_id_prefix}_bat).publish_state(bat);
                id(switch_${blueriiot1_id_prefix}_enable).turn_off();
          name: ${blueriiot2_name_prefix} reading data
          internal: true
          notify: true
          on_notify:
            then:
             lambda: |-
                id(sensor_${blueriiot2_id_prefix}_temperature).publish_state(temperature);
                id(sensor_${blueriiot2_id_prefix}_ph).publish_state(ph);
                id(sensor_${blueriiot2_id_prefix}_orp).publish_state(orp);
                id(sensor_${blueriiot2_id_prefix}_bat).publish_state(bat);
                id(switch_${blueriiot2_id_prefix}_enable).turn_off();
      Bitte beachtet, dass Ihr ggf. die ganzen Teil zum zweiten Sensor auskommentieren müsst und natürlich auch das verwendete Board und die MAC-Adresse(n) anpassen müsst.
      Ich stelle das hier erstmal "zur Diskussion" rein. Vielleicht erspart es ja jemandem Arbeit ;-)
      Diamand2k22
      #86
      @oxident
      Hi, funktioniert das ESP32 Skript bei dir einwandfrei? Dann brauch ich kein Abo oder?
      O 1 Antwort Letzte Antwort
      • D Diamand2k22
        @oxident
        O Online
        O Online
        oxident
        #87
        @diamand2k22 Leider nein ... bin da bisher noch nicht weitergekommen. Theoretisch klappt es, praktisch ist es aber noch extrem unzuverlässig.
        Aber ja, wenn es klappt, dann braucht man weder Abo noch App.
        • O oxident
          Diamand2k22
          #88
          @oxident said in Pool Thermometer und Chlormesser:
          Generell bin ich kein Freund von diesem Cloud Mist, bin da eher der Verfechter von lokaler Anbindung. Was klappt denn noch nicht so richtig im Detail mit dem Skript?
          • O Online
            O Online
            oxident
            #89
            @diamand2k22 Es ist ein konzeptionelles Problem.
            Das Skript basiert auf ESPHome und erfordert daher einen ESP32. Die haben aber leider eine enorm schlechte BT-Reichweite und außerdem noch Stress bei gleichzeitiger BT/WiFi-Nutzung.
            Außerdem neigt ESPHome dazu, ständig mit den Clients verbunden zu bleiben. Da ich zwei Blueconnects verwende ist das super instabil.
            Daher suche ich nach einer anderen Plattform. Vielleicht auch irgendwas, was ganz stumpf vom iobroker direkt (BT-Stick) oder indirekt (BT-WiFi-Bridge) gesteuert werden kann.
            Es ist ja kein Hexenwerk den richtigen Befehl zu senden und dann die Rückgabe zu dekodieren. Bei Bluetooth-LE ist das aber alles zu hoch für mich.
            D 2 Antworten Letzte Antwort
            • O oxident
              Diamand2k22
              schrieb am zuletzt editiert von Diamand2k22
              #90
              @oxident
              hab's jetzt erstmal soweit hinbekommen die Daten über die Cloud auszulesen.
              Ich denke damit kann man gut arbeiten!
              Danke für den tollen Adapter!
              • O oxident
                Diamand2k22
                #91
                @oxident
                Hallo Oxident, hast du es mittlerweile hinbekommen die BlueConnect stabil auszulesen über esp32 oder ble Stick?
                Hättest du da paar neue Infos?
                Danke dir!
                • FlexerF Offline
                  FlexerF Offline
                  Flexer
                  #92
                  Hi an alle. Vielleicht ist der Threat auch was für euch.
                  https://forum.iobroker.net/topic/76039/automatsche-dosieranlage-low-budget/8
                  Unterm Strich ist alles besser.
                  Ja, voll geil hier!
                  • D Diamand2k22
                    @oxident
                    Danke dir!
                    O Online
                    O Online
                    oxident
                    #93
                    @diamand2k22 Jepp, eigentlich läuft es jetzt gut. Aber ich musste wirklich einen ESP32 mit ext. Antenne finden. Den esphome-Code kann ich gerne nachliefern!
                      Diamand2k22
                      #94
                      @oxident
                      Was hast du denn genau an Hardware, dann würde ich mir das so auch zusammenbauen.
                      Ja und der Code wäre natürlich auch sehr interessant. Wenn du den zur Verfügung stellen könntest wäre natürlich super!
                      • D Diamand2k22
                        @oxident
                        O Online
                        O Online
                        oxident
                        #95
                        @diamand2k22 Letzten Endes habe ich diesen ESP32 hier benutzt: https://www.ebay.de/itm/373835160946?mkcid=16&mkevt=1&mkrid=707-127634-2357-0&ssspo=VPl0vy4uQMu&sssrc=4429486&ssuid=l3eyvw_dRxm&var=&widget_ver=artemis&media=COPY
                        Wichtig war die Antenne halt bei mir wegen WLAN und Bluetooth. Die regulären ESP32 konnten halt kaum eine Verbindung zum Blueconnect herstellen und hatten erst Recht Stress, wenn gleichzeitig Daten ins WLAN gesendet wurden.
                        Der neue ESP ist deutlich leistungsfähiger und bekommt zuverlässig die Daten vom Sensor.
                        Wie gesagt, YAML liefere ich nach, sobald ich zu Hause bin.
                        D W 2 Antworten Letzte Antwort
                        • O oxident
                          Diamand2k22
                          #96
                          @oxident
                          Super danke dir, ich hab mir gleich den esp + Gehäuse bestellt!
                          Wegen dem Code mach dir keinen Stress, ich brauch eh erstmal die Hardware. 😀
                          • D Diamand2k22
                            @oxident
                            Diamand2k22
                            #97
                            @oxident
                            Hallo oxident, könntest du mir bitte die yaml zur Verfügung stellen?
                            Eine Frage noch, ist es dann möglich, die Messung unabhängig anzutriggern? Bei mir wird aktuell alle 75 Minuten über Sigfox gemessen natürlich mit Abo 😀
                            • D Diamand2k22
                              @oxident
                              O Online
                              O Online
                              oxident
                              #98
                              @diamand2k22 Hoppla, sorry. Völlig vergessen:
                              substitutions:
                                # Blueconnect
                                blueriiot2_mac: '00:A0:50:24:79:67' # ANPASSEN
                              esphome:
                                friendly_name: Pool
                                on_boot:
                                  priority: 600
                                  then:
                                    - delay: 20s
                              esp32:
                                framework:
                                  type: esp-idf
                                  version: recommended
                              # Enable logging
                              logger:
                                level: INFO
                              api:
                                password: "1234"
                              ota:
                                password: "1234"
                              wifi:
                              web_server:
                                port: 80
                              output:
                                # Countermeasure to the problem that CH552 applies 4v to GPIO0, thus reducing WiFi sensitivity.
                                # Setting output_high adds a bias of 3.3v and suppresses overvoltage.
                                # From: https://github.com/m5stack/M5Unified/blob/d26d2415f409b664631ff066ceeaffd6a753a4ff/src/M5Unified.cpp#L506
                                - platform: gpio
                                  pin: GPIO0
                              esp32_ble_tracker:
                                scan_parameters:
                                  active: false
                                  interval: 1000ms
                                  window: 700ms
                                on_ble_advertise:
                                    then:
                                      - logger.log:
                                          format: "Found Spa sensor with RSSI %d"
                                          args: [ "x.get_rssi()"]
                                          level: "INFO"
                              ble_client:
                                  on_connect:
                                    then:
                                      - logger.log:
                                          format: "Connected to 2nd sensor"
                                          level: "INFO"
                                      - delay: 2s
                              binary_sensor:
                              # OPTIONAL und SPEZIFISCH für M5Atom
                              # derzeit: Led bei Knopfdruck an-/ausschalten
                              #  - platform: gpio # btn
                              #    id: pushbutton
                              #    pin:
                              #      number: 39
                              #      inverted: true
                              #    on_click:
                              #      then:
                              #        - if:
                              #            condition:
                              #              - light.is_on: matrix_light
                              #            then:
                              #              - light.turn_off: matrix_light
                              #            else:
                              #              - light.turn_on:
                              #                  id: matrix_light
                              #                  effect: rainbow
                              #light:
                              #  - platform: fastled_clockless # 5x5 RGB Matrix (WS2812C)
                              #    name: "5x5 Matrix"
                              #    id: matrix_light
                              #    pin: 27
                              #    chipset: WS2812
                              #    num_leds: 25
                              #    color_correct: [50%, 50%, 50%] # The LED's on the Atom Matrix should not be run at full power
                              #    effects:
                              #      - addressable_rainbow:
                              #          name: rainbow
                              # ENDE spezifischer Teil M5Atom
                              sensor:
                                - platform: ble_rssi
                                  name: "RSSI value Spa sensor"
                                  unit_of_measurement: "%"
                                  unit_of_measurement: "g/L"
                                  name: ${blueriiot2_name_prefix} Conductivity
                                  unit_of_measurement: "mS/cm"
                              switch:
                                - platform: restart
                              button:
                                  internal: true
                                  on_press:
                                    then:
                                      - logger.log:
                                          format: "Writing to 2nd sensor..."
                                          level: "INFO"
                                          value: !lambda |-
                                            return {0x01};
                              text_sensor:
                                  internal: true
                                  notify: true
                                  on_notify:
                                    then:
                                     lambda: |-
                                        float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86  - 21.57826;
                                        float salt = (float)( (int16_t) (x[8]<< 8) + x[7]) / 25.0;
                                        ESP_LOGD("salt", "%f", salt);
                                        id(sensor_${blueriiot2_id_prefix}_salt).publish_state(salt);
                                        float cond = (float)( (int16_t) (x[10]<< 8) + x[9]) / 0.4134;
                                        ESP_LOGD("cond", "%f", cond);
                                        id(sensor_${blueriiot2_id_prefix}_cond).publish_state(cond);
                                        float bat = (float)( (int16_t) x[11]);
                              Du müsstest eigentlich nur die MAC-Adresse ganz oben eintragen und den Rest nach belieben anpassen. Ich habe es auf einem m5stack-Atom laufen ... bei anderen solltest Du eventuell noch die "platform" ändern.
                              Ja, dann kannst Du so oft Du willst die Messung anstoßen. Einfach den "... enable" switch setzen und abwarten.
                              • O oxident
                                substitutions:
                                  # Blueconnect
                                esphome:
                                  friendly_name: Pool
                                  on_boot:
                                    priority: 600
                                    then:
                                      - delay: 20s
                                esp32:
                                  framework:
                                    type: esp-idf
                                # Enable logging
                                logger:
                                  level: INFO
                                api:
                                  password: "1234"
                                ota:
                                  password: "1234"
                                wifi:
                                web_server:
                                  port: 80
                                output:
                                  - platform: gpio
                                    pin: GPIO0
                                esp32_ble_tracker:
                                  scan_parameters:
                                    active: false
                                    interval: 1000ms
                                    window: 700ms
                                  on_ble_advertise:
                                      then:
                                        - logger.log:
                                            level: "INFO"
                                ble_client:
                                    on_connect:
                                      then:
                                        - logger.log:
                                            level: "INFO"
                                        - delay: 2s
                                binary_sensor:
                                #    id: pushbutton
                                #    pin:
                                #      number: 39
                                #      inverted: true
                                #    on_click:
                                #      then:
                                #        - if:
                                #            condition:
                                #            then:
                                #            else:
                                #              - light.turn_on:
                                #                  id: matrix_light
                                #                  effect: rainbow
                                #light:
                                #    id: matrix_light
                                #    pin: 27
                                #    chipset: WS2812
                                #    num_leds: 25
                                #    effects:
                                #          name: rainbow
                                sensor:
                                switch:
                                  - platform: restart
                                button:
                                    internal: true
                                    on_press:
                                      then:
                                        - logger.log:
                                            level: "INFO"
                                            value: !lambda |-
                                              return {0x01};
                                text_sensor:
                                    internal: true
                                    notify: true
                                    on_notify:
                                      then:
                                       lambda: |-
                                Diamand2k22
                                #99
                                @oxident
                                Super danke dir 👍🏻 hattest du nicht ein ESP32 WROOM 32 DevKitC V4 38 Pin Board?
                                • D Diamand2k22
                                  @oxident
                                  O Online
                                  O Online
                                  oxident
                                  #100
                                  @diamand2k22 Ja, in der Tat. Das nutze ich aber zusätzlich noch für ein paar andere Sachen (Poolabdeckung und ein paar Taster). Da war mir die YAML zu kompliziert zum Auseinanderpflücken ;-)
                                  Habe daher die "alte" Version gepostet. Im Blueconnect-Teil hat sich aber nix verändert.
                                  • O oxident
                                    Diamand2k22
                                    #101
                                    @oxident
                                    Danke dir, ich probiere es mal aus. Ist mein erster esp32 😀
                                    • D Diamand2k22
                                      @oxident
                                      O Online
                                      O Online
                                      oxident
                                      #102
                                      @diamand2k22 Steile Lernkurve ... aber letzten Endes lohnt es sich und macht Spaß :-)
                                      • M mameier1234
                                        @sithys-mahony Da liegst du richtig ...
                                        Username und Passwort, aus der App....
                                        vowillV Offline
                                        vowillV Offline
                                        vowill
                                        #103
                                        Danke an @mameier1234 für den Blueconnect-Adapter - funktioniert einwandfrei!
                                        Ein Hinweis für alle, die sich - wie ich zunächst - über den Zeitversatz bei der letzten Messung wundern: Der über den Adapter in xx.timestamp gelieferte Zeitstempel ist im GMT-Format. Für Deutschland müssen da also 1 (Winterzeit) bzw. 2 (Sommerzeit) Stunden hinzuaddiert werden. Oder man nutzt in einem Skript die Funktion:
                                        // Umwandlung Zeitstempel von GMT nach ME(S)Z
                                        timestamp_in_ME_S_Z = formatDate(getDateObject(getState('blueconnect.0.xxxx.ph.timestamp').val), 'TT.MM.JJJJ SS:mm:ss');
                                        bzw. als Blockly:
                                        ioBroker im lxc auf NUC / Aktive Instanzen: 38
                                        • O oxident
                                          Diamand2k22
                                          #104
                                          @oxident
                                          Wie hast du die Mac Adresse von dem BlueConnect herausgefunden?
                                          vowillV O 2 Antworten Letzte Antwort
