  4. Pool Thermometer und Chlormesser
    6.8k
allgemein
118 Beiträge 30 Kommentatoren 27.5k Aufrufe 40 Beobachtet
  • O oxident
    @scubydoo Eigentlich müsste alles selbsternannten sein. Hast Du schonmal Test-Adapter installiert?
    Scubydoo
    schrieb am zuletzt editiert von Scubydoo
    #84
    @oxident Installation hat funktioniert.
    O 1 Antwort Letzte Antwort
    • S Scubydoo
      O Online
      O Online
      oxident
      #85
      @scubydoo Danke für die Rückmeldung! Viel Spaß...
      • O oxident
        Okay, hier mal das YAML für ESPHome um die Blueconnects ohne Cloud auszulesen:
        substitutions:
          # erster Blueconnect
          blueriiot1_mac: '00:A0:50:ZZ:XX:YY'
          blueriiot1_name_prefix: 'pool'
          blueriiot1_id_prefix: 'pl'
          # zweiter Blueconnect
          # ggf. auskommentieren
          blueriiot2_mac: '00:A0:50:ZZ:XX:YY'
          blueriiot2_name_prefix: 'spa'
          blueriiot2_id_prefix: 'sp'
          # send true 0x01 to this service ID
          blueriiot_send_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
          blueriiot_send_characteristic_uuid: 'F3300002-F0A2-9B06-0C59-1BC4763B5C00'
          # notification is recieved on this Service ID
          blueriiot_recieve_service_uuid: 'F3300001-F0A2-9B06-0C59-1BC4763B5C00'
          blueriiot_recieve_characteristic_uuid: 'F3300003-F0A2-9B06-0C59-1BC4763B5C00'
        esphome:
          friendly_name: Poolsensoren
        esp32:
          board: m5stack-atom # ANPASSEN
          framework:
            type: arduino
        # Enable logging
        logger:
          #level: VERY_VERBOSE
          level: INFO
        # Enable Home Assistant API
        api:
          password: "1234"
        ota:
          password: "1234"
        wifi:
          ssid: !secret wifi_ssid
          password: !secret wifi_password
        esp32_ble_tracker:
        ble_client:
          # erster Sensor
          - mac_address: ${blueriiot1_mac}
            on_connect:
              then:
                - lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(true);"
                - delay: 2s
                - button.press: button_${blueriiot1_id_prefix}_doreading
            on_disconnect: [lambda: "id(binary_sensor_${blueriiot1_id_prefix}_connected).publish_state(false);"]
          # zweiter Sensor (optional)
          - mac_address: ${blueriiot2_mac}
            on_connect:
              then:
                - lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(true);"
                - delay: 2s
                - button.press: button_${blueriiot2_id_prefix}_doreading
            on_disconnect: [lambda: "id(binary_sensor_${blueriiot2_id_prefix}_connected).publish_state(false);"]
        binary_sensor:
        # erster Sensor
          - platform: template
            device_class: connectivity
            entity_category: diagnostic
        switch:
          # erster Sensor
          - platform: ble_client
            ble_client_id: ble_client_${blueriiot1_id_prefix}
            restore_mode: ALWAYS_OFF
            ble_client_id: ble_client_${blueriiot2_id_prefix}
        sensor:
          # erster Sensor
            name: ${blueriiot1_name_prefix} Temperature
            # Optional variables:
            unit_of_measurement: "°C"
            icon: "mdi:water-percent"
            device_class: "temperature"
            state_class: "measurement"
            accuracy_decimals: 1
            #unit_of_measurement: "°C"
            #icon: "mdi:water-percent"
            #device_class: "temperature"
            device_class: "voltage"
            device_class: "battery"
          # ENDE erster Sensor
            name: ${blueriiot2_name_prefix} Temperature
          # ENDE zweiter Sensor (optional)
        ## Blue Connect
        # erster Sensor
        button:
            name: ${blueriiot1_name_prefix} do reading
            internal: true
            on_press:
              then:
                - ble_client.ble_write:
                    service_uuid: ${blueriiot_send_service_uuid}
                    characteristic_uuid: ${blueriiot_send_characteristic_uuid}
                    # A lambda returning an std::vector<uint8_t>.
                    value: !lambda |-
                      return {0x01};
            name: ${blueriiot2_name_prefix} do reading
            internal: true
            on_press:
              then:
                    value: !lambda |-
                      return {0x01};
        text_sensor:
          # erster Sensor
            name: ${blueriiot1_name_prefix} reading data
            internal: true
            service_uuid: ${blueriiot_recieve_service_uuid}
            characteristic_uuid: ${blueriiot_recieve_characteristic_uuid}
            notify: true
            update_interval: never
            on_notify:
              then:
               lambda: |-
                  std::string rawhex = format_hex_pretty((uint8_t *) x.c_str(), x.size()).c_str();
                  ESP_LOGD("raw_hex", "%s", rawhex.c_str());
                  float temperature = (float)((int16_t)(x[2]<< 8) + x[1])/100;
                  ESP_LOGD("temp", "%f", temperature);
                  id(sensor_${blueriiot1_id_prefix}_temperature).publish_state(temperature);
                  float raw_ph = (float)( (int16_t) (x[4]<< 8) + x[3]) ;
                  float ph = (float)( (int16_t) (2048 - raw_ph)) / 232  + 7 ;
                  ESP_LOGD("ph", "%f", ph);
                  id(sensor_${blueriiot1_id_prefix}_ph).publish_state(ph);
                  float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86 ;
                  ESP_LOGD("orp", "%f", orp);
                  id(sensor_${blueriiot1_id_prefix}_orp).publish_state(orp);
                  float bat = (float)( (int16_t) x[11]) ;
                  ESP_LOGD("bat", "%f", bat);
                  id(sensor_${blueriiot1_id_prefix}_bat).publish_state(bat);
                  id(switch_${blueriiot1_id_prefix}_enable).turn_off();
            name: ${blueriiot2_name_prefix} reading data
            internal: true
            notify: true
            on_notify:
              then:
               lambda: |-
                  id(sensor_${blueriiot2_id_prefix}_temperature).publish_state(temperature);
                  id(sensor_${blueriiot2_id_prefix}_ph).publish_state(ph);
                  id(sensor_${blueriiot2_id_prefix}_orp).publish_state(orp);
                  id(sensor_${blueriiot2_id_prefix}_bat).publish_state(bat);
                  id(switch_${blueriiot2_id_prefix}_enable).turn_off();
        Bitte beachtet, dass Ihr ggf. die ganzen Teil zum zweiten Sensor auskommentieren müsst und natürlich auch das verwendete Board und die MAC-Adresse(n) anpassen müsst.
        Ich stelle das hier erstmal "zur Diskussion" rein. Vielleicht erspart es ja jemandem Arbeit ;-)
        Diamand2k22
        #86
        @oxident
        Hi, funktioniert das ESP32 Skript bei dir einwandfrei? Dann brauch ich kein Abo oder?
        • D Diamand2k22
          @oxident
          O Online
          O Online
          oxident
          #87
          @diamand2k22 Leider nein ... bin da bisher noch nicht weitergekommen. Theoretisch klappt es, praktisch ist es aber noch extrem unzuverlässig.
          Aber ja, wenn es klappt, dann braucht man weder Abo noch App.
          • O oxident
            Diamand2k22
            #88
            @oxident said in Pool Thermometer und Chlormesser:
            Generell bin ich kein Freund von diesem Cloud Mist, bin da eher der Verfechter von lokaler Anbindung. Was klappt denn noch nicht so richtig im Detail mit dem Skript?
            • O Online
              O Online
              oxident
              #89
              @diamand2k22 Es ist ein konzeptionelles Problem.
              Das Skript basiert auf ESPHome und erfordert daher einen ESP32. Die haben aber leider eine enorm schlechte BT-Reichweite und außerdem noch Stress bei gleichzeitiger BT/WiFi-Nutzung.
              Außerdem neigt ESPHome dazu, ständig mit den Clients verbunden zu bleiben. Da ich zwei Blueconnects verwende ist das super instabil.
              Daher suche ich nach einer anderen Plattform. Vielleicht auch irgendwas, was ganz stumpf vom iobroker direkt (BT-Stick) oder indirekt (BT-WiFi-Bridge) gesteuert werden kann.
              Es ist ja kein Hexenwerk den richtigen Befehl zu senden und dann die Rückgabe zu dekodieren. Bei Bluetooth-LE ist das aber alles zu hoch für mich.
              D 2 Antworten Letzte Antwort
              • O oxident
                Diamand2k22
                schrieb am zuletzt editiert von Diamand2k22
                #90
                @oxident
                hab's jetzt erstmal soweit hinbekommen die Daten über die Cloud auszulesen.
                Ich denke damit kann man gut arbeiten!
                Danke für den tollen Adapter!
                • O oxident
                  Diamand2k22
                  #91
                  @oxident
                  Hallo Oxident, hast du es mittlerweile hinbekommen die BlueConnect stabil auszulesen über esp32 oder ble Stick?
                  Hättest du da paar neue Infos?
                  Danke dir!
                  • FlexerF Offline
                    FlexerF Offline
                    Flexer
                    #92
                    Hi an alle. Vielleicht ist der Threat auch was für euch.
                    https://forum.iobroker.net/topic/76039/automatsche-dosieranlage-low-budget/8
                    Unterm Strich ist alles besser.
                    Ja, voll geil hier!
                    • D Diamand2k22
                      @oxident
                      Danke dir!
                      O Online
                      O Online
                      oxident
                      #93
                      @diamand2k22 Jepp, eigentlich läuft es jetzt gut. Aber ich musste wirklich einen ESP32 mit ext. Antenne finden. Den esphome-Code kann ich gerne nachliefern!
                        Diamand2k22
                        #94
                        @oxident
                        Was hast du denn genau an Hardware, dann würde ich mir das so auch zusammenbauen.
                        Ja und der Code wäre natürlich auch sehr interessant. Wenn du den zur Verfügung stellen könntest wäre natürlich super!
                        • D Diamand2k22
                          @oxident
                          O Online
                          O Online
                          oxident
                          #95
                          @diamand2k22 Letzten Endes habe ich diesen ESP32 hier benutzt: https://www.ebay.de/itm/373835160946?mkcid=16&mkevt=1&mkrid=707-127634-2357-0&ssspo=VPl0vy4uQMu&sssrc=4429486&ssuid=l3eyvw_dRxm&var=&widget_ver=artemis&media=COPY
                          Wichtig war die Antenne halt bei mir wegen WLAN und Bluetooth. Die regulären ESP32 konnten halt kaum eine Verbindung zum Blueconnect herstellen und hatten erst Recht Stress, wenn gleichzeitig Daten ins WLAN gesendet wurden.
                          Der neue ESP ist deutlich leistungsfähiger und bekommt zuverlässig die Daten vom Sensor.
                          Wie gesagt, YAML liefere ich nach, sobald ich zu Hause bin.
                          D W 2 Antworten Letzte Antwort
                          • O oxident
                            Diamand2k22
                            #96
                            @oxident
                            Super danke dir, ich hab mir gleich den esp + Gehäuse bestellt!
                            Wegen dem Code mach dir keinen Stress, ich brauch eh erstmal die Hardware. 😀
                            • D Diamand2k22
                              @oxident
                              Diamand2k22
                              #97
                              @oxident
                              Hallo oxident, könntest du mir bitte die yaml zur Verfügung stellen?
                              Eine Frage noch, ist es dann möglich, die Messung unabhängig anzutriggern? Bei mir wird aktuell alle 75 Minuten über Sigfox gemessen natürlich mit Abo 😀
                              • D Diamand2k22
                                @oxident
                                O Online
                                O Online
                                oxident
                                #98
                                @diamand2k22 Hoppla, sorry. Völlig vergessen:
                                substitutions:
                                  # Blueconnect
                                  blueriiot2_mac: '00:A0:50:24:79:67' # ANPASSEN
                                esphome:
                                  friendly_name: Pool
                                  on_boot:
                                    priority: 600
                                    then:
                                      - delay: 20s
                                esp32:
                                  framework:
                                    type: esp-idf
                                    version: recommended
                                # Enable logging
                                logger:
                                  level: INFO
                                api:
                                  password: "1234"
                                ota:
                                  password: "1234"
                                wifi:
                                web_server:
                                  port: 80
                                output:
                                  # Countermeasure to the problem that CH552 applies 4v to GPIO0, thus reducing WiFi sensitivity.
                                  # Setting output_high adds a bias of 3.3v and suppresses overvoltage.
                                  # From: https://github.com/m5stack/M5Unified/blob/d26d2415f409b664631ff066ceeaffd6a753a4ff/src/M5Unified.cpp#L506
                                  - platform: gpio
                                    pin: GPIO0
                                esp32_ble_tracker:
                                  scan_parameters:
                                    active: false
                                    interval: 1000ms
                                    window: 700ms
                                  on_ble_advertise:
                                      then:
                                        - logger.log:
                                            format: "Found Spa sensor with RSSI %d"
                                            args: [ "x.get_rssi()"]
                                            level: "INFO"
                                ble_client:
                                    on_connect:
                                      then:
                                        - logger.log:
                                            format: "Connected to 2nd sensor"
                                            level: "INFO"
                                        - delay: 2s
                                binary_sensor:
                                # OPTIONAL und SPEZIFISCH für M5Atom
                                # derzeit: Led bei Knopfdruck an-/ausschalten
                                #  - platform: gpio # btn
                                #    id: pushbutton
                                #    pin:
                                #      number: 39
                                #      inverted: true
                                #    on_click:
                                #      then:
                                #        - if:
                                #            condition:
                                #              - light.is_on: matrix_light
                                #            then:
                                #              - light.turn_off: matrix_light
                                #            else:
                                #              - light.turn_on:
                                #                  id: matrix_light
                                #                  effect: rainbow
                                #light:
                                #  - platform: fastled_clockless # 5x5 RGB Matrix (WS2812C)
                                #    name: "5x5 Matrix"
                                #    id: matrix_light
                                #    pin: 27
                                #    chipset: WS2812
                                #    num_leds: 25
                                #    color_correct: [50%, 50%, 50%] # The LED's on the Atom Matrix should not be run at full power
                                #    effects:
                                #      - addressable_rainbow:
                                #          name: rainbow
                                # ENDE spezifischer Teil M5Atom
                                sensor:
                                  - platform: ble_rssi
                                    name: "RSSI value Spa sensor"
                                    unit_of_measurement: "%"
                                    unit_of_measurement: "g/L"
                                    name: ${blueriiot2_name_prefix} Conductivity
                                    unit_of_measurement: "mS/cm"
                                switch:
                                  - platform: restart
                                button:
                                    internal: true
                                    on_press:
                                      then:
                                        - logger.log:
                                            format: "Writing to 2nd sensor..."
                                            level: "INFO"
                                            value: !lambda |-
                                              return {0x01};
                                text_sensor:
                                    internal: true
                                    notify: true
                                    on_notify:
                                      then:
                                       lambda: |-
                                          float orp = (float)( (int16_t) (x[6]<< 8) + x[5]) / 3.86  - 21.57826;
                                          float salt = (float)( (int16_t) (x[8]<< 8) + x[7]) / 25.0;
                                          ESP_LOGD("salt", "%f", salt);
                                          id(sensor_${blueriiot2_id_prefix}_salt).publish_state(salt);
                                          float cond = (float)( (int16_t) (x[10]<< 8) + x[9]) / 0.4134;
                                          ESP_LOGD("cond", "%f", cond);
                                          id(sensor_${blueriiot2_id_prefix}_cond).publish_state(cond);
                                          float bat = (float)( (int16_t) x[11]);
                                Du müsstest eigentlich nur die MAC-Adresse ganz oben eintragen und den Rest nach belieben anpassen. Ich habe es auf einem m5stack-Atom laufen ... bei anderen solltest Du eventuell noch die "platform" ändern.
                                Ja, dann kannst Du so oft Du willst die Messung anstoßen. Einfach den "... enable" switch setzen und abwarten.
                                • O oxident
                                  substitutions:
                                    # Blueconnect
                                  esphome:
                                    friendly_name: Pool
                                    on_boot:
                                      priority: 600
                                      then:
                                        - delay: 20s
                                  esp32:
                                    framework:
                                      type: esp-idf
                                  # Enable logging
                                  logger:
                                    level: INFO
                                  api:
                                    password: "1234"
                                  ota:
                                    password: "1234"
                                  wifi:
                                  web_server:
                                    port: 80
                                  output:
                                    - platform: gpio
                                      pin: GPIO0
                                  esp32_ble_tracker:
                                    scan_parameters:
                                      active: false
                                      interval: 1000ms
                                      window: 700ms
                                    on_ble_advertise:
                                        then:
                                          - logger.log:
                                              level: "INFO"
                                  ble_client:
                                      on_connect:
                                        then:
                                          - logger.log:
                                              level: "INFO"
                                          - delay: 2s
                                  binary_sensor:
                                  #    id: pushbutton
                                  #    pin:
                                  #      number: 39
                                  #      inverted: true
                                  #    on_click:
                                  #      then:
                                  #        - if:
                                  #            condition:
                                  #            then:
                                  #            else:
                                  #              - light.turn_on:
                                  #                  id: matrix_light
                                  #                  effect: rainbow
                                  #light:
                                  #    id: matrix_light
                                  #    pin: 27
                                  #    chipset: WS2812
                                  #    num_leds: 25
                                  #    effects:
                                  #          name: rainbow
                                  sensor:
                                  switch:
                                    - platform: restart
                                  button:
                                      internal: true
                                      on_press:
                                        then:
                                          - logger.log:
                                              level: "INFO"
                                              value: !lambda |-
                                                return {0x01};
                                  text_sensor:
                                      internal: true
                                      notify: true
                                      on_notify:
                                        then:
                                         lambda: |-
                                  Diamand2k22
                                  #99
                                  @oxident
                                  Super danke dir 👍🏻 hattest du nicht ein ESP32 WROOM 32 DevKitC V4 38 Pin Board?
                                  • D Diamand2k22
                                    @oxident
                                    O Online
                                    O Online
                                    oxident
                                    #100
                                    @diamand2k22 Ja, in der Tat. Das nutze ich aber zusätzlich noch für ein paar andere Sachen (Poolabdeckung und ein paar Taster). Da war mir die YAML zu kompliziert zum Auseinanderpflücken ;-)
                                    Habe daher die "alte" Version gepostet. Im Blueconnect-Teil hat sich aber nix verändert.
                                    • O oxident
                                      Diamand2k22
                                      #101
                                      @oxident
                                      Danke dir, ich probiere es mal aus. Ist mein erster esp32 😀
                                      • D Diamand2k22
                                        @oxident
                                        O Online
                                        O Online
                                        oxident
                                        #102
                                        @diamand2k22 Steile Lernkurve ... aber letzten Endes lohnt es sich und macht Spaß :-)
                                        • M mameier1234
                                          @sithys-mahony Da liegst du richtig ...
                                          Username und Passwort, aus der App....
                                          vowillV Offline
                                          vowillV Offline
                                          vowill
                                          #103
                                          Danke an @mameier1234 für den Blueconnect-Adapter - funktioniert einwandfrei!
                                          Ein Hinweis für alle, die sich - wie ich zunächst - über den Zeitversatz bei der letzten Messung wundern: Der über den Adapter in xx.timestamp gelieferte Zeitstempel ist im GMT-Format. Für Deutschland müssen da also 1 (Winterzeit) bzw. 2 (Sommerzeit) Stunden hinzuaddiert werden. Oder man nutzt in einem Skript die Funktion:
                                          // Umwandlung Zeitstempel von GMT nach ME(S)Z
                                          timestamp_in_ME_S_Z = formatDate(getDateObject(getState('blueconnect.0.xxxx.ph.timestamp').val), 'TT.MM.JJJJ SS:mm:ss');
                                          bzw. als Blockly:
                                          ioBroker im lxc auf NUC / Aktive Instanzen: 38
