  4. Homematic IP Cloud Access Point Adapter
    6.3k
homematic cloud adapterhomematic ip cloud adapter
430 Beiträge 101 Kommentatoren 130.0k Aufrufe 89 Beobachtet
  • L LukasWPT
    Aktuell habe ich zwei Probleme mit meinem HMIP Adapter, in der Suche konnte ich nichts vergleichbares finden.
    1. Aus irgendeinem Grund bekomme ich folgende Log-Einträge ausgegeben, obwohl ich weder per Skript noch manuell Objekteinstellungen ändere:
    2024-07-06 08:22:12.133 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.1.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:12.179 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.2.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:12.185 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.3.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:12.208 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.4.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:14.181 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.1.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:14.186 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.2.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:14.191 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.3.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    2024-07-06 08:22:14.199 - info: hmip.0 (9185) State value to set for "hmip.0.devices.3014F711A00033E0C98DA72C.channels.4.hardwareColorTemperatureColdWhite" has to be type "numbern" but received type "number"
    Das selbe Spiel scheint auch mit den Jalousien zu geben (da allerdings mit dem Objekt previousShutterlevel (wird auch nicht angesteuert). Ich habe etwas Sorgen, dass damit irgendwann die Cloud überlastet wird und meine IP HMIP-seitig gesperrt wird.
    1. Bei dem RGBW Controller werden keine Einstellungen für Farbe und Sättigung (Hue und Saturationlevel) übernommen. D.h. ich kann zwar eine Zahl eingeben, diese wird allerdings nicht übertragen. Umgekehrt werden aber Zahlen in IoBroker übertragen die ich in der App einstelle.
    Besten Dank für eure Hilfe!
    TT-Tom
    #358
    @lukaswpt schau mal in die Datenpunkt Einstellung. Der Typ numbern gibt es nicht, der heißt number/zahl.
    Das wird in dem log bemängelt.
    Wie trägst du dort Werte ein?
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    HomoranH L 2 Antworten Letzte Antwort
    • T TT-Tom
      #359
      @tt-tom sagte in Homematic IP Cloud Access Point Adapter:
      ich tippe daher auf eine Tippfehler im Code, der beim Anlegen der states diesen falschen Typ verwendet.
        TT-Tom
        #360
        Ja ist ein Fehler im Adapter.
        bug im Code
        Muss ein Issue erstellt werden.
        Edit: ist erstellt, kurz und knapp ;)
        Gruß Tom
        Public Transport
        • O oFbEQnpoLKKl6mbY5e13
          @apollon77
          Es geht bis heute mit einer älteren Adapterversion vor Umstellung auf Axios. Es kann also nicht so kompliziert sein. Ja, ich weiß, das ist leicht gesagt...
          #361
          @ofbeqnpolkkl6mby5e13 Dann bitte debug log mit alt und neu als issue im Github. Müssen wir ansehen. Es tut halt für viele USer, daher ists scheinbar irgendwas in den Details
          • T TT-Tom
            LukasWPT
            schrieb am zuletzt editiert von LukasWPT
            #362
            @tt-tom Danke für die Antwort - ich trage da eben gar nichts ein (weder durch Skripte, noch manuell). Ich hab in der Doku den Punkt von „Numbers“ auf „number“ Geändert allerdings ist nach einem Neustart der Instanz alles beim Alten.
            • edit: gerade die restlichen Antworten gesehen. Danke euch! Dann warte ich auf ein Update :)
            • Edit2: für previous.Shutterlevel ist es dann ein ähnlicher Bug - siehe Log:
            hmip.0
            2024-07-06 14:23:23.416	info	State value to set for "hmip.0.devices.3014F711A000369F29AE921C.channels.1.previousShutterLevel" has to be type "string" but received type "number"
            • L LukasWPT
              hmip.0
              TT-Tom
              #363
              @lukaswpt kommt die Meldung beim Beschreiben des Datenpunkt oder wenn der Adapter Daten abruft??
              Edit: was für ein Gerät ist es Shutter oder Blind?
              Gruß Tom
              Public Transport
              L 1 Antwort Letzte Antwort
              • T TT-Tom
                LukasWPT
                #364
                @tt-tom in dem Fall wenn ich den shutter (ist ein shutter) öffne oder schließe. Natürlich nicht über den beschriebenen Datenpunkt sondern den dafür vorgesehenen.
                Bei dem RGBW Controller ist es allerdings gefühlt random.
                • L LukasWPT
                  TT-Tom
                  #365
                  @lukaswpt
                  Es gab mal ein Issue dafür wurde aber von Ersteller wieder geschlossen.
                  @apollon77 Öffnest du Ihn neu oder soll ich es in dem Aktuellen mit reinschreiben?
                  Das mit dem RGBW bedeutet jetzt es klappt mal, mal nicht?
                  Gruß Tom
                  Public Transport
                  L T 2 Antworten Letzte Antwort
                  • T TT-Tom
                    @lukaswpt
                    LukasWPT
                    #366
                    @tt-tom also bzgl des RGBW:
                    Ein/Aus sowie Dimmen des LED streifen klappt immer, Farbe einstellen & Farbsättigung nie. Bei den restlichen Parametern die per IOB steuerbar sind klappen meiner Meinung nach auch nicht. Ich weiß aber nicht ob das zwingend mit dem „Numbern“ Fehler zusammenhängt oder was separates ist. Die o.g. Meldung tritt nur (für mich) recht zufällig auf und scheint nicht mit Interaktionen von mir / einem Skript zusammen zu hängen.
                    • L LukasWPT
                      TT-Tom
                      #367
                      @lukaswpt
                      Das RGBW-Problem ist separat zu betrachten.
                      Habe leider nicht so ein Modul, um das zu verifizieren.
                      Mach dazu mal bitte auf Github ein Issue auf, damit es bearbeitet wird und hier nicht untergeht.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @lukaswpt
                        TT-Tom
                        #368
                        @apollon77 habe das Issue #571 jetzt angepasst für die Type - Fehler bei den States.
                        Gruß Tom
                        Public Transport
                        L apollon77A 2 Antworten Letzte Antwort
                        • T TT-Tom
                          LukasWPT
                          #369
                          @tt-tom erledigt, danke!
                          • L LukasWPT
                            TT-Tom
                            #370
                            @lukaswpt
                            habe dein Issue gesehen, bist du wirklich noch auf Buster unterwegs. Solltest mal auf ein aktuelles System wechseln. Es gibt hier genug Beiträge zum Wechsel auf Bookworm.
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @lukaswpt
                              LukasWPT
                              #371
                              @tt-tom nehme ich mir auch schon länger vor. Bzw. ebenfalls eine Trennung von iobroker und Nextcloud (läuft auf dem selben PI), bisher sind meine Versuche upzugraden an Nextcloud gescheitert, da hab ich es leider nicht sauber hinbekommen.
                              • apollon77A apollon77
                                Komisch ... Dann ehrlich langsam keine Idee mehr :-(
                                Mathias MeisterM Offline
                                Mathias Meister
                                #372
                                @apollon77 Was nun?
                                Gibt es irgendwas, das ich noch probieren und testen kann? Mit der App von Homematic IP funktioniert ja alles bestens, aber ich würde das schon lieber mit dem ioBroker machen...
                                Mathias MeisterM 1 Antwort Letzte Antwort
                                • T TT-Tom
                                  #373
                                  @tt-tom GitHub updated. Bitte verifizieren und zurückmelden
                                    TT-Tom
                                    #374
                                    @LukasWPT
                                    Kannst du bitte das Update von Github installieren und prüfen. Rückmeldung an @apollon77
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @LukasWPT
                                      LukasWPT
                                      #375
                                      @tt-tom done - zumindest die Status Fehler scheinen bei mir gelöst. Danke euch :)
                                      • L LukasWPT
                                        TT-Tom
                                        #376
                                        @lukaswpt
                                        Was ist jetzt mit RGBW kannst du dort die Werte ändern?
                                        Gruß Tom
                                        Public Transport
                                        • L LukasWPT
                                          TT-Tom
                                          #377
                                          @lukaswpt
                                          Bitte auf Github in meinem Issue bestätigen, das Ingo es übernehmen kann/soll.
                                          Hat sich erledigt, sollte öfter mal ein refresh machen 😁
                                          Gruß Tom
                                          Public Transport
