  4. Pegelwerte Fritzbox 6490 Cable auslesen?
199 Beiträge 20 Kommentatoren 67.0k Aufrufe 21 Beobachtet
  • F fastfoot
    @martinp es könnte helfen body: durch data: zu ersetzen
    MartinPM Online
    MartinPM Online
    MartinP
    #167
    @fastfoot Das hat auch nicht geholfen ...
    2024-07-04 07:22:00.197 - info: javascript.0 (33499) script.js.Fritzbox.DOCSISV01: status 200
    2024-07-04 07:22:00.198 - info: javascript.0 (33499) script.js.Fritzbox.DOCSISV01: headers cache-control: no-cache, no-cache, no-store, must-revalidate
    connection: close
    content-type: text/html; charset=utf-8
    date: Thu, 04 Jul 2024 05:22:00 GMT
    expires: -1
    pragma: no-cache
    x-frame-options: SAMEORIGIN
    x-xss-protection: 1; mode=block
    x-content-type-options: nosniff
    content-security-policy: default-src 'none'; connect-src 'self'; font-src 'self'; frame-src https://service.avm.de https://fritzhelp.avm.de/help/ https://help.avm.de https://www.avm.de https://avm.de https://assets.avm.de https://clickonce.avm.de http://clickonce.avm.de http://download.avm.de https://download.avm.de 'self'; img-src 'self' https://tv.avm.de https://help.avm.de/images/ http://help.avm.de/images/ data:; script-src 'self' 'unsafe-inline'; style-src 'self' 'unsafe-inline'; frame-ancestors 'self'; media-src 'self'
    2024-07-04 07:22:00.199 - info: javascript.0 (33499) script.js.Fritzbox.DOCSISV01: data:
    2024-07-04 07:22:00.204 - error: javascript.0 (33499) Error in callback: SyntaxError: Unexpected token '<', ")
    2024-07-04 07:22:00.205 - error: javascript.0 (33499) at Object. (script.js.Fritzbox.DOCSISV01:292:30)
    2024-07-04 07:22:00.205 - error: javascript.0 (33499) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1242:38
    2024-07-04 07:22:00.206 - error: javascript.0 (33499) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    • MartinPM MartinP
      connection: close
      expires: -1
      pragma: no-cache
      MartinPM Online
      MartinPM Online
      MartinP
      #168
      Das ist der httpPost
      script.js.Fritzbox.DOCSISV01: httpPost(config={"method":"post","url":"http://192.168.2.1/data.lua","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Content-Type":"application/x-www-form-urlencoded"},"data":{"title":"channels","body":"xhr=1&sid=4........................&lang=de&page=docInfo&xhrId=all&no_sidrenew=","user_id":"1"}}, data=[object Object])
      Auch das geht nicht:
      	script.js.Fritzbox.DOCSISV01: httpPost(config={"method":"post","url":"http://192.168.2.1/data.lua","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Content-Type":"application/x-www-form-urlencoded","Authorization":"Bearer ae..............b"},"data":{"title":"channels","body":"xhr=1&sid=ae................b&lang=de&page=docInfo&xhrId=all&no_sidrenew=","user_id":"1"}}, data=[object Object])
      • MartinPM MartinP
        MartinPM Online
        MartinPM Online
        MartinP
        #169
        Da kann man ja manisch werden, bei dieser Bastelei... ziemlich sperrig die neuen Funktionen ...
        Das ist das, was zwischen Firefox und Fritzbox beim httpPost ausgetauscht wird ...
        F 1 Antwort Letzte Antwort
        • MartinPM MartinP
          F Online
          F Online
          fastfoot
          #170
          @martinp ich mag diese httpGet und httpPost nicht sonderlich, obwohl die Idee dahinter schon sehr gut ist. Mir fehlen da die Async Functionen um die awaiten zu können. Deshalb bevorzuge ich axios direkt, schon wegen der Doku. Anyway, hier sind zwei simple Wrapper die du verwenden kannst, wenn es dir nur um den reinen Aufruf geht dann nimmst du nur die innersten Aufrufe. Ist getestet.
          const httpGetAsync = (url, options) => {
              return new Promise((resolve) => {
                  httpGet(url, options, (err, res) => {
                      if (res.statusCode === 200) {
                          resolve(res)
          const httpPostAsync = (url, data, options) => {
                  httpPost(url, data, options, (err, res) => {
                          resolve(res)
          // url und data können aus den Options extrahiert werden
          • F fastfoot
                            resolve(res)
                            resolve(res)
            MartinPM Online
            MartinPM Online
            MartinP
            #171
            @fastfoot Die Fritzbox schickt ja schon etwas zurück - das ist aber nicht die JSON-Tabelle, die ich erwarten würde ...
            Ich vermute ja noch immer, dass da irgendetwas in dem, was ich dem httpPost() übergebe nicht korrekt ist... Werde das aber trotzdem mal probieren
            • MartinPM MartinP
              F Online
              F Online
              fastfoot
              #172
              @martinp das ist mit der FB getestet :-)
              • F fastfoot
                MartinPM Online
                MartinPM Online
                MartinP
                #173
                @fastfoot den Status 200 habe ich ja auch schon hinbekommen, nur war der Rest des Ergebnisses zwar VIEL, aber völlig unbrauchbar .....Hilfstexte von AVM usw ...
                	script.js.Fritzbox.DOCSISV01: data: <!DOCTYPE html> <html lang="de"> <head> <meta http-equiv=content-type content="text/html; charset=utf-8" /> <meta http-equiv="Cache-Control" content="private, no-transform" /> <meta http-equiv="X-UA-Compatible" content="IE=edge" /> <meta name="format-detection" content="telephone=no" /> <meta http-equiv="x-rim-auto-match" content="none" /> <meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=yes, minimal-ui" /> <meta name="mobile-web-app-capable" content="yes" /> <meta name="apple-mobile-web-app-capable" content="yes" /> <meta name="apple-mobile-web-app-status-bar-style" content="black-translucent" /> <meta http-equiv="cleartype" content="on"> <link rel="icon" href="/favicon.ico" size="16x16"/> <link rel="icon" href="/icon.svg" type="image/svg+xml"/> <link rel="icon" href="/icon.png" type="image/png"/> <link rel="apple-touch-icon" href="/apple-touch-icon.png" /> <link rel="apple-touch-startup-image" href="/apple-touch-icon.png" /> <style> /*@font-face { font-family: 'Source Sans Pro'; font-style: italic; font-stretch: normal; font-weight: 400; src: url('/assets/fonts/SourceSansPro-Italic.woff2') format('woff2'); }*/ @font-face { font-family: 'Source Sans Pro'; font-style: normal; font-stretch: normal; font-weight: 400; src: url('/assets/fonts/source-sans-pro-v11-latin-ext_latin-regular.woff2') format('woff2'); } @font-face { font-family: 'Source Sans Pro'; font-style: normal; font-stretch: normal; font-weight: 600; src: url('/assets/fonts/source-sans-pro-v11-latin-ext_latin-600.woff2') format('woff2'); } @font-face { font-family: 'Source Sans Pro'; font-style: normal; font-stretch: normal; font-weight: 900; src: url('/assets/fonts/SourceSansPro-Black.woff2') format('woff2'); } html, input, textarea, keygen, select, button { font-family: 'Source Sans Pro', Arial, sans-serif; font-size: 100%; } </style> <link rel="stylesheet" type="text/css" href="/css/box.css"> <link rel='stylesheet' type='text/css' href="/css/rd/login.css"/> <title> FRITZ!Box </title> </head> <body> <script> var gNbc = false; </script> <script src="/js/browser.js"></script> <script src="/js/vendor.js"></script> <script src="/js/box-login.js"></script> <script type="module"> import { setConfig } from "/js/config.js"; import login from "/js/login.js"; setConfig({"ZIGBEE":false,"GUI_IS_POWERLINE":false,"isDebug":false,"gu_type":"release","WLAN":{"is_double_wlan":false},"GUI_IS_REPEATER":false,"GUI_IS_GATEWAY":false,"language":"de","GUI_HIDE_TEASER":false}); const data = {"firstTenMin":fa
                • MartinPM MartinP
                  F Online
                  F Online
                  fastfoot
                  schrieb am zuletzt editiert von fastfoot
                  #174
                  @martinp options und Aufruf?
                  Edit: Wenn wie weiter oben dann mal mit meinem Aufruf vergleichen!
                  • F fastfoot
                    MartinPM Online
                    MartinPM Online
                    MartinP
                    #175
                    @fastfoot
                    Das hatte ich als Gedächtnisstütze für die vorherige Version auskommentiert behalten
                    //    var options = {
                    //        url: docsisURL,
                    //        method: 'POST',
                    //        headers: {
                    //            'Content-Type': 'application/x-www-form-urlencoded'
                    //        body: 'xhr=1&sid=' + sid + '&lang=de&page=docInfo&xhrId=all&no_sidrenew='
                    //    };toString
                    //    request(options, function(error, response, body)
                    Da der Beginn der Auswerteroutine - mit viel Logging aktuell -
                          httpPost(docsisURL,
                    //            title : 'channels',
                                body: 'xhr=1&sid=' + sid + '&lang=de&page=docinfo&xhrId=all&no_sidrenew=',
                    //            user_id : '1'
                                timeout: 2000,
                                // responseType: 'arraybuffer',
                    //            bearerAuth: sid,
                                headers: {
                            (error, response) => {
                            if (!error && response.statusCode == 200) {
                                log ('status ' + response.statusCode);
                                log ('headers ' + response.headers);
                                log ('data: ' + response.data);
                                const body = response.data;
                                // tableData = JSON.parse(body);
                                tableData = response.data;
                                if(tableData){
                    F 2 Antworten Letzte Antwort
                    • MartinPM MartinP
                      @fastfoot
                      //    var options = {
                      //        url: docsisURL,
                      //        method: 'POST',
                      //        headers: {
                      //    };toString
                            httpPost(docsisURL,
                      //            user_id : '1'
                                  timeout: 2000,
                      //            bearerAuth: sid,
                                  headers: {
                                  if(tableData){
                      F Online
                      F Online
                      fastfoot
                      #176
                      @martinp
                      httpPost(url,options.body, options,callback)
                      der zweite Parameter muss ein String sein und options wie im Original.
                      • MartinPM MartinP
                        @fastfoot
                        //    var options = {
                        //        url: docsisURL,
                        //        method: 'POST',
                        //        headers: {
                        //    };toString
                              httpPost(docsisURL,
                        //            user_id : '1'
                                    timeout: 2000,
                        //            bearerAuth: sid,
                                    headers: {
                                    if(tableData){
                        F Online
                        F Online
                        fastfoot
                        #177
                        @martinp oder ganz konkret:
                        let data = `xhr=1&sid=${SID}&lang=de&page=${page}&xhrId=all`
                        let url = docsisURL;
                        let options = {
                            headers: {
                                "Content-Type": "application/x-www-form-urlencoded",
                                let fbData = JSON.parse(res.data); // nur wenn ein JSON erwartet wird,
                        • F fastfoot
                          let options = {
                              headers: {
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          #178
                          @fastfoot Wollte doch gerade zum Abendbrot gehen, aber jetzt juckt es in den Fingern ;-)
                          • MartinPM MartinP
                            F Online
                            F Online
                            fastfoot
                            #179
                            @martinp ein simpler Test wäre dann console.log(fbData.timeTillLogout)). Sollte 1200 zeigen. Die eigentlichen Kanal-Daten finden sich in fbbData.data
                            • MartinPM Online
                              MartinPM Online
                              MartinP
                              #180
                              @martinp Funktioniert immer noch nicht ...
                              Das ist der Aufruf
                                    httpPost(docsisURL,
                                          headers: {
                              script.js.Fritzbox.DOCSISV01: httpPost(config={"method":"post","url":"http://192.168.2.1/data.lua","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Content-Type":"application/x-www-form-urlencoded"},"data":"xhr=1&sid=6xxxxxxxxxxxxxxxx3c&lang=de&page=docinfo&xhrId=all&no_sidrenew="}, data=xhr=1&sid=6.................c&lang=de&page=docinfo&xhrId=all&no_sidrenew=)
                              • MartinPM MartinP
                                Das ist der Aufruf
                                      httpPost(docsisURL,
                                            headers: {
                                MartinPM Online
                                MartinPM Online
                                MartinP
                                #181
                                @martinp
                                GAAHH "page=docInfo" und nicht "page=docinfo" ...
                                Jetzt funktioniert es .... Ein paar Werte sind auch schon über Influx in Grafana gelandet ...
                                Schnell eine Sicherung machen, und später noch alles etwas von Logging "säubern" ...
                                • MartinPM MartinP
                                  @martinp
                                  F Online
                                  F Online
                                  fastfoot
                                  #182
                                  @martinp na dann viel Spass beim weiterbasteln :-)
                                  • F fastfoot
                                    MartinPM Online
                                    MartinPM Online
                                    MartinP
                                    #183
                                    @fastfoot Habe seit neuestem eine Gitea-Instanz in einem LXC-Container auf dem Proxmox auf dem auch der iob in einem LXC läuft aufgesetzt, auf der ich meine Scripte auch noch einmal sichere ... ansonsten ist das immer so ein Gehampel, die "Secrets" secret zu halten ...
                                    Man will ja nicht nach Github sein Fritzbox-Password hochladen ...
                                    I F 2 Antworten Letzte Antwort
                                    • MartinPM MartinP
                                      I Offline
                                      I Offline
                                      ichderarnd
                                      #184
                                      Cool, ich würde gerne mitmachen, muss arbeiten. Quartalsabrechnung :-(
                                      MartinPM F 2 Antworten Letzte Antwort
                                      • I ichderarnd
                                        MartinPM Online
                                        MartinPM Online
                                        MartinP
                                        #185
                                        @ichderarnd
                                        Hier ein Full-Quote des ganzen Scripts. Das ist aber womöglich ansonsten ein älterer Stand ggüb. Deinen Code, ich habe wohl recht früh geforkt ...
                                        // Version 0.1 -Build 1 03-JUL-2024
                                        // removed double Lines first try with httpGet, httpPush MP
                                        // Version 0.1-2 ß4-JUL-2024
                                        var logging = false;
                                        const iconv = require('iconv-lite');
                                        const crypto = require('crypto');
                                        var DOCSIS30DSChannels = 30;
                                        var DOCSIS31DSChannels = 2;
                                        var DOCSIS30USChannels = 4;
                                        var DOCSIS31USChannels = 1;
                                        var NullValue = null;
                                        var sid;
                                        var fritzBenutzer = '..........';
                                        var fritzPasswort = '.............';
                                        var loginURL = 'http://192.168.2.1/login_sid.lua?username=';
                                        var docsisURL = 'http://192.168.2.1/data.lua';
                                        var fritzboxJsonVersion = 2; // Version 1: Fritz OS 7.29, Version 2: Fritz OS 7.56
                                        // Downstream DOCSIS 3.0
                                        for (var i = 1; i <= 30; i++) {
                                            var Channel = 'C' + (i < 10 ? '0' + i.toString() : i.toString());
                                            createState('Internet.Docsis.DS.' + Channel + '.Frequency', 0, false, {
                                                unit: 'MHz',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.Modulation', 0, false, {
                                                unit: 'QAM',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.PowerLevel', 0, false, {
                                                unit: 'dBmV',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.MSE', 0, false, {
                                                unit: 'dB',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.Latency', 0, false, {
                                                unit: 'ms',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.CorrectableErrors', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.CorrectableErrorsPerMinute', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.UncorrectableErrors', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.DS.' + Channel + '.UncorrectableErrorsPerMinute', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                        // Upstream DOCSIS 3.0
                                        for (var i = 0; i < 4; i++) {
                                            var Channel = 'C0' + i.toString();
                                            createState('Internet.Docsis.US.' + Channel + '.Frequency', 0, false, {
                                                unit: 'MHz',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.US.' + Channel + '.Modulation', 0, false, {
                                                unit: 'QAM',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.US.' + Channel + '.MultiplexMethod', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.US.' + Channel + '.PowerLevel', 0, false, {
                                                unit: 'dBmV',
                                                type: 'mixed',
                                                role: 'state'
                                            createState('Internet.Docsis.US.' + Channel + '.ChannelID', 0, false, {
                                                type: 'mixed',
                                                role: 'state'
                                        // Downstream DOCSIS 3.1
                                        createState('Internet.Docsis31.DS.C01.Frequency', 0, false, {
                                            unit: 'MHz',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C01.Modulation', 0, false, {
                                            unit: 'QAM',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C01.PowerLevel', 0, false, {
                                            unit: 'dBmV',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C01.MSE', 0, false, {
                                            unit: 'dB',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C01.UncorrectableErrors', 0, false, {
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C01.UncorrectableErrorsPerMinute', 0, false, {
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.Frequency', 0, false, {
                                            unit: 'MHz',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.Modulation', 0, false, {
                                            unit: 'QAM',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.PowerLevel', 0, false, {
                                            unit: 'dBmV',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.MSE', 0, false, {
                                            unit: 'dB',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.UncorrectableErrors', 0, false, {
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.DS.C02.UncorrectableErrorsPerMinute', 0, false, {
                                            type: 'mixed',
                                            role: 'state'
                                        // Upstream DOCSIS 3.1
                                        createState('Internet.Docsis31.US.C00.Frequency', 0, false, {
                                            unit: 'MHz',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.US.C00.Modulation', 0, false, {
                                            unit: 'QAM',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.US.C00.MultiplexMethod', 0, false, {
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.US.C00.FFT', 0, false, {
                                            unit: 'K',
                                            type: 'mixed',
                                            role: 'state'
                                        createState('Internet.Docsis31.US.C00.PowerLevel', 0, false, {
                                            unit: 'dBmV',
                                            type: 'mixed',
                                            role: 'state'
                                         * Simple XML parser
                                         * @param {String} xml
                                         * @return {Object}
                                        function parseXML(xml) {
                                            var beg = -1;
                                            var end = 0;
                                            var tmp = 0;
                                            var current = [];
                                            var obj = {};
                                            var from = -1;
                                            while (true) {
                                                beg = xml.indexOf('<', beg + 1);
                                                if (beg === -1)
                                                    break;
                                                end = xml.indexOf('>', beg + 1);
                                                if (end === -1)
                                                    break;
                                                var el = xml.substring(beg, end + 1);
                                                var c = el[1];
                                                if (c === '?' || c === '/') {
                                                    var o = current.pop();
                                                    if (from === -1 || o !== el.substring(2, el.length - 1))
                                                        continue;
                                                    var path = current.join('.') + '.' + o;
                                                    var value = xml.substring(from, beg);
                                                    if (typeof(obj[path]) === 'undefined')
                                                        obj[path] = value;
                                                    else if (obj[path]instanceof Array)
                                                        obj[path].push(value);
                                                    else
                                                        obj[path] = [obj[path], value];
                                                    from = -1;
                                                    continue;
                                                tmp = el.indexOf(' ');
                                                var hasAttributes = true;
                                                if (tmp === -1) {
                                                    tmp = el.length - 1;
                                                    hasAttributes = false;
                                                from = beg + el.length;
                                                var isSingle = el[el.length - 2] === '/';
                                                var name = el.substring(1, tmp);
                                                if (!isSingle)
                                                    current.push(name);
                                                if (!hasAttributes)
                                                    continue;
                                                var match = el.match(/\w+\=\".*?\"/g);
                                                if (match === null)
                                                    continue;
                                                var attr = {};
                                                var length = match.length;
                                                for (var i = 0; i < length; i++) {
                                                    var index = match[i].indexOf('"');
                                                    attr[match[i].substring(0, index - 1)] = match[i].substring(index + 1, match[i].length - 1);
                                                obj[current.join('.') + (isSingle ? '.' + name : '') + '[]'] = attr;
                                            return obj;
                                        function loginAndGetSID() {
                                            sid = null;
                                            // Challenge holen
                                            // var options = {
                                            //    url: loginURL + fritzBenutzer,
                                            //    method: 'GET'
                                            httpGet(loginURL + fritzBenutzer, (error, response) => {
                                                    // log(' response:      ' + ', body: ' + body, 'info');
                                                    var result = parseXML(body);
                                                    var challenge = result['SessionInfo.Challenge'];
                                                    if (logging)
                                                        log('Challenge: ' + challenge);
                                                    // Einloggen und SID holen
                                                    var utf16le_encoded = iconv.encode(challenge + '-' + fritzPasswort, 'UTF-16LE', {
                                                        addBOM: false
                                                    var challengeResponse = crypto.createHash('md5').update(utf16le_encoded).digest('hex');
                                                    // options = {
                                                    //     url: loginURL + fritzBenutzer + '&response=' + challenge + '-' + challengeResponse,
                                                    //     method: 'GET'
                                                    // (8 )};
                                                    httpGet(loginURL + fritzBenutzer + '&response=' + challenge + '-' + challengeResponse, (error, response) => {
                                                            sid = result['SessionInfo.SID'];
                                                            if (logging)
        log('Logged in. SID = ' + sid, 'info');
                                                        } else {
                                                            log('error: ' + error + ', response: ' + response.statusCode.toString(), 'info');
                                                } else {
                                        // Wenn keine Daten abgerufen werden konnten, werden die States auf NULL gesetzt
                                        function setStates2NullValues() {
                                            // DOCSIS 3.0 Downstream Channels
                                            for (i = 0; i < DOCSIS30DSChannels; i++) {
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.Frequency', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.Modulation', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.PowerLevel', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.MSE', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.Latency', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.CorrectableErrors', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.CorrectableErrorsPerMinute', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.UncorrectableErrors', NullValue, true);
                                                setState('Internet.Docsis.DS.C' + (i < 10 ? '0' : '') + i.toString() + '.UncorrectableErrorsPerMinute', NullValue, true);
                                            // DOCSIS 3.1 Downstream Channel
                                            setState('Internet.Docsis31.DS.C01.PowerLevel', NullValue, true);
                                            setState('Internet.Docsis31.DS.C01.MSE', NullValue, true);
                                            setState('Internet.Docsis31.DS.C01.Modulation', NullValue, true);
                                            setState('Internet.Docsis31.DS.C01.Frequency', NullValue, true);
                                            setState('Internet.Docsis31.DS.C01.UncorrectableErrors', NullValue, true);
                                            setState('Internet.Docsis31.DS.C01.UncorrectableErrorsPerMinute', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.PowerLevel', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.MSE', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.Modulation', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.Frequency', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.UncorrectableErrors', NullValue, true);
                                            setState('Internet.Docsis31.DS.C02.UncorrectableErrorsPerMinute', NullValue, true);
                                            // DOCSIS 3.0 Upstream Channels
                                            for (i = 0; i < DOCSIS30USChannels; i++) {
                                                setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.Frequency', NullValue, true);
                                                setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.Modulation', NullValue, true);
                                                setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.MultiplexMethod', NullValue, true);
                                                setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.PowerLevel', NullValue, true);
                                                setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.ChannelID', NullValue, true);
                                            // DOCSIS 3.1 Upstream Channel
                                            setState('Internet.Docsis31.US.C00.PowerLevel', NullValue, true);
                                            setState('Internet.Docsis31.US.C00.Modulation', NullValue, true);
                                            if (fritzboxJsonVersion == 1) {
                                                setState('Internet.Docsis31.US.C00.MultiplexMethod', NullValue, true);
                                            } else {
                                                setState('Internet.Docsis31.US.C00.FFT', NullValue, true);
                                            setState('Internet.Docsis31.US.C00.Frequency', NullValue, true);
                                        // Holt die Informationen von der Fritzbox Benutzeroberfläche. Ab fritz.OS Version 7.2x werden die Informationen als JSON-String übermittelt (getCableModemChannelInfos Version 2)
                                        function getCableModemChannelInfosV2() {
                                            // const list = getSchedules(true);
                                            // list.forEach(schedule => log(JSON.stringify(schedule)));
                                            if (logging)
                                                log('Schedule V6 Started');
                                            var tableData;
                                            //    var options = {
                                            //        url: docsisURL,
                                            //        method: 'POST',
                                            //        headers: {
                                            //    };toString
                                            // xhr	"1"
                                            // && sid	"e88a7fea301a9529"
                                            // lang	"de"
                                            // page	"docOv"
                                            // xhrId	"all"
                                            httpPost(docsisURL,
                                                'xhr=1&sid=' + sid + '&lang=de&page=docInfo&xhrId=all&no_sidrenew=', {
                                                headers: {
                                                    if (tableData) {
                                                        // console.log(tableData.timeTillLogout);
                                                        DOCSIS30DSChannels = Object.entries(tableData.data.channelDs.docsis30).length;
                                                        if (logging)
                                                            log('DOCSIS30DSChannels: ' + DOCSIS30DSChannels.toString(), 'info');
                                                            var channelID = parseInt(tableData.data.channelDs.docsis30[i].channelID);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.Frequency', parseInt(tableData.data.channelDs.docsis30[i].frequency), true);
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.Modulation', parseInt(tableData.data.channelDs.docsis30[i].type.replace('QAM', '')), true);
                                                            } else {
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.Modulation', parseInt(tableData.data.channelDs.docsis30[i].modulation.replace('QAM', '')), true);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.PowerLevel', parseFloat(tableData.data.channelDs.docsis30[i].powerLevel), true);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.MSE', parseFloat(tableData.data.channelDs.docsis30[i].mse), true);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.Latency', parseFloat(tableData.data.channelDs.docsis30[i].latency), true);
                                                            var correctableErrors = getState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.CorrectableErrors');
                                                            var lastValue = correctableErrors.val;
                                                            var lastTimeStamp = correctableErrors.ts;
                                                            var newValue = parseInt(tableData.data.channelDs.docsis30[i].corrErrors);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.CorrectableErrors', newValue, true);
                                                            // Sicherstellen, dass der letzte und der neue Wert nicht NULL sind und dann die Differenz zum letzten Wert berechnen
                                                            if (lastValue != null && newValue != null && lastTimeStamp != null) {
        var ts_diff = new Date().getTime() - lastTimeStamp;
        // Die Differenz zum letzten Wert nur dann speichern, wenn dieser ca. 1 Min. alt ist
        if (ts_diff > 40000 && ts_diff < 80000 && newValue >= lastValue) {
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.CorrectableErrorsPerMinute', newValue - lastValue, true);
        } else {
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.CorrectableErrorsPerMinute', NullValue, true);
                                                            var uncorrectableErrors = getState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.UncorrectableErrors');
                                                            lastValue = uncorrectableErrors.val;
                                                            lastTimeStamp = uncorrectableErrors.ts;
                                                            newValue = parseInt(tableData.data.channelDs.docsis30[i].nonCorrErrors);
                                                            setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.UncorrectableErrors', newValue, true);
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.UncorrectableErrorsPerMinute', newValue - lastValue, true);
        } else {
        setState('Internet.Docsis.DS.C' + (channelID < 10 ? '0' : '') + tableData.data.channelDs.docsis30[i].channelID + '.UncorrectableErrorsPerMinute', NullValue, true);
                                                        if (tableData.data.channelDs.docsis31 != null) {
                                                            DOCSIS31DSChannels = Object.entries(tableData.data.channelDs.docsis31).length;
                                                            if (logging)
        log('DOCSIS31DSChannels: ' + DOCSIS31DSChannels.toString(), 'info');
                                                            if (DOCSIS31DSChannels > 0) {
        setState('Internet.Docsis31.DS.C01.PowerLevel', parseFloat(tableData.data.channelDs.docsis31[0].powerLevel), true);
        setState('Internet.Docsis31.DS.C01.Modulation', parseInt(tableData.data.channelDs.docsis31[0].type.replace('K', '')), true);
        } else {
        setState('Internet.Docsis31.DS.C01.Modulation', parseInt(tableData.data.channelDs.docsis31[0].modulation.replace('QAM', '')), true);
        setState('Internet.Docsis31.DS.C01.MSE', parseInt(tableData.data.channelDs.docsis31[0].mer), true);
        //           "docsis31": [{
        //                    "powerLevel": "0.5",
        //                    "nonCorrErrors": 3717,
        //                    "modulation": "4096QAM",
        //                    "plc": "823",
        //                    "mer": "36",
        //                    "fft": "4K",
        //                    "channelID": 193,
        //                    "frequency": "750.975 - 860.975"
        var uncorrectableErrors = getState('Internet.Docsis31.DS.C01.UncorrectableErrors');
        newValue = parseInt(tableData.data.channelDs.docsis31[0].nonCorrErrors);
        setState('Internet.Docsis31.DS.C01.UncorrectableErrors', newValue, true);
        setState('Internet.Docsis31.DS.C01.UncorrectableErrorsPerMinute', newValue - lastValue, true);
        setState('Internet.Docsis31.DS.C01.Frequency', tableData.data.channelDs.docsis31[0].frequency, true);
                                                            if (DOCSIS31DSChannels > 1) {
        setState('Internet.Docsis31.DS.C02.PowerLevel', parseFloat(tableData.data.channelDs.docsis31[1].powerLevel), true);
        setState('Internet.Docsis31.DS.C02.Modulation', parseInt(tableData.data.channelDs.docsis31[1].type.replace('K', '')), true);
        } else {
        setState('Internet.Docsis31.DS.C02.Modulation', parseInt(tableData.data.channelDs.docsis31[1].modulation.replace('QAM', '')), true);
        setState('Internet.Docsis31.DS.C02.MSE', parseInt(tableData.data.channelDs.docsis31[1].mer), true);
        var uncorrectableErrors = getState('Internet.Docsis31.DS.C02.UncorrectableErrors');
        newValue = parseInt(tableData.data.channelDs.docsis31[1].nonCorrErrors);
        setState('Internet.Docsis31.DS.C02.UncorrectableErrors', newValue, true);
        setState('Internet.Docsis31.DS.C02.UncorrectableErrorsPerMinute', newValue - lastValue, true);
        setState('Internet.Docsis31.DS.C02.Frequency', tableData.data.channelDs.docsis31[1].frequency, true);
                                                        if (tableData.data.channelUs.docsis30 != null) {
                                                            DOCSIS30USChannels = Object.entries(tableData.data.channelUs.docsis30).length;
                                                            if (DOCSIS30USChannels > 0) {
        if (logging)
        log('DOCSIS30USChannels: ' + DOCSIS30USChannels.toString(), 'info');
        // var channelID = parseInt(tableData.data.channelUs.docsis30[i].channelID);
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.Frequency', parseFloat(tableData.data.channelUs.docsis30[i].frequency), true);
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.Modulation', parseInt(tableData.data.channelUs.docsis30[i].type.replace('QAM', '')), true);
        } else {
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.Modulation', parseInt(tableData.data.channelUs.docsis30[i].modulation.replace('QAM', '')), true);
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.MultiplexMethod', tableData.data.channelUs.docsis30[i].multiplex, true);
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.PowerLevel', parseFloat(tableData.data.channelUs.docsis30[i].powerLevel), true);
        setState('Internet.Docsis.US.C' + (i < 10 ? '0' : '') + i.toString() + '.ChannelID', tableData.data.channelUs.docsis30[i].channelID, true);
                                                            } else {
        for (i = 1; i <= 4; i++) {
        setState('Internet.Docsis.US.C0' + i.toString() + '.Frequency', 0, true);
        setState('Internet.Docsis.US.C0' + i.toString() + '.Modulation', 0, true);
        setState('Internet.Docsis.US.C0' + i.toString() + '.MultiplexMethod', '', true);
        setState('Internet.Docsis.US.C0' + i.toString() + '.PowerLevel', 0, true);
        setState('Internet.Docsis.US.C0' + i.toString() + '.ChannelID', 0, true);
                                                        if (tableData.data.channelUs.docsis31 != null) {
                                                            DOCSIS31USChannels = Object.entries(tableData.data.channelUs.docsis31).length; ;
                                                            if (DOCSIS31USChannels > 0) {
        if (logging)
        log('DOCSIS31USChannels: ' + DOCSIS31USChannels.toString(), 'info');
        setState('Internet.Docsis31.US.C00.PowerLevel', parseFloat(tableData.data.channelUs.docsis31[0].powerLevel), true);
        setState('Internet.Docsis31.US.C00.Modulation', parseInt(tableData.data.channelUs.docsis31[0].type.replace('K', '')), true);
        } else {
        setState('Internet.Docsis31.US.C00.Modulation', parseInt(tableData.data.channelUs.docsis31[0].modulation.replace('QAM', '')), true);
        setState('Internet.Docsis31.US.C00.MultiplexMethod', tableData.data.channelUs.docsis31[0].multiplex, true);
        } else {
        setState('Internet.Docsis31.US.C00.FFT', parseInt(tableData.data.channelUs.docsis31[0].fft.replace('K', '')), true);
        setState('Internet.Docsis31.US.C00.Frequency', parseInt(tableData.data.channelUs.docsis31[0].frequency), true);
                                                            } else {
        // Es ist kein DOCSIS 3.1 Kanal aktiv
        if (logging)
        setState('Internet.Docsis31.US.C00.PowerLevel', 0, true);
        setState('Internet.Docsis31.US.C00.Modulation', 0, true);
        } else {
        setState('Internet.Docsis31.US.C00.Frequency', 0, true);
                                                    } else {
                                                        log('Empty response', 'error');
                                                        setStates2NullValues();
                                                        loginAndGetSID();
                                                } else {
                                                    log('error: ' + error + ', response: ' + response.statusCode.toString(), 'error');
                                                    loginAndGetSID();
                                        if (logging)
                                            log('DocsisInfo starting', 'info');
                                        // SID holen und merken (User Token)
                                        loginAndGetSID();
                                        var getSIDinterval = setInterval(loginAndGetSID, 900000); // Alle 15 Minuten neue SID holen
                                            // FFT gibt es in Version 1 noch nicht. Feld leeren.
                                            if (getState('Internet.Docsis31.US.C00.FFT').val != NullValue) {
                                        } else {
                                            // MultiplexMethod gibt es ab Version 2 nicht mehr. Feld leeren.
                                            if (getState('Internet.Docsis31.US.C00.MultiplexMethod').val != NullValue) {
                                        schedule("* * * * *", function () { // Zu jeder vollen Minute die Fritzbox DOCSIS-Daten abfragen
                                            getCableModemChannelInfosV2();
                                        D S 2 Antworten Letzte Antwort
                                        • MartinPM MartinP
                                          F Online
                                          F Online
                                          fastfoot
                                          #186
                                          @martinp sagte in Pegelwerte Fritzbox 6490 Cable auslesen?:
                                          Gitea
                                          ich habe alles herkömmlich, wobei ich in VS Code arbeite und so iobroker spezifische Sachen wie setState auskommentiere und später einfach in den iobroker paste. ich mache z.Zt. nicht so viel mit iobroker, bin mit anderen Projekten ziemlich ausgelastet.
