  4. Smartgarden Error 429
1 Beiträge 1 Kommentatoren 84 Aufrufe 1 Beobachtet
    michihorn
    Hallo, ich verfolge das Thema Smartgarden Adapter und die API Nutzung.
    Ich habe heute mal wieder eine neue API erhalten und schon wieder habe nach nach einigen Stunden Error 429
    Anbei mein LOG, vielleicht sieht jemand was ich ändern kann.
    v7.0.7
    Log-Größe: 30.2 KB
    smartgarden.0
    Zeit
    silly
    Nachricht
    smartgarden.0
    2024-07-01 19:33:26.259 silly States system redis pmessage system.adapter.smartgarden.0.sigKill/system.adapter.smartgarden.0.sigKill:{"val":-1,"ack":false,"ts":1719855206256,"q":0,"from":"system.host.rp5","lc":1719855206256}
    smartgarden.0
    2024-07-01 19:33:26.259 info Got terminate signal TERMINATE_YOURSELF
    smartgarden.0
    2024-07-01 19:33:26.259 info 3/ cleaned everything up...
    smartgarden.0
    2024-07-01 19:33:26.259 info 3/ stopAllTimer
    smartgarden.0
    2024-07-01 19:33:26.742 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1719855206737,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1719841482826}
    smartgarden.0
    2024-07-01 19:33:26.761 info terminating
    smartgarden.0
    2024-07-01 19:33:26.762 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    smartgarden.0
    2024-07-01 19:33:26.765 info terminating
    smartgarden.0
    2024-07-01 19:33:32.174 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
    smartgarden.0
    2024-07-01 19:33:32.435 debug Objects client ready ... initialize now
    smartgarden.0
    2024-07-01 19:33:32.521 debug Objects create System PubSub Client
    smartgarden.0
    2024-07-01 19:33:32.523 debug Objects create User PubSub Client
    smartgarden.0
    2024-07-01 19:33:32.993 debug Objects client initialize lua scripts
    smartgarden.0
    2024-07-01 19:33:33.007 debug Objects connected to redis: 127.0.0.1:9001
    smartgarden.0
    2024-07-01 19:33:33.012 silly redis psubscribe cfg.o.system.user.*
    smartgarden.0
    2024-07-01 19:33:33.231 silly redis psubscribe cfg.o.enum.*
    smartgarden.0
    2024-07-01 19:33:33.238 silly objectDB connected
    smartgarden.0
    2024-07-01 19:33:33.240 debug Redis States: Use Redis connection: 127.0.0.1:9000
    smartgarden.0
    2024-07-01 19:33:33.521 debug States create System PubSub Client
    smartgarden.0
    2024-07-01 19:33:33.526 debug States create User PubSub Client
    smartgarden.0
    2024-07-01 19:33:33.910 debug States connected to redis: 127.0.0.1:9000
    smartgarden.0
    2024-07-01 19:33:33.911 silly statesDB connected
    smartgarden.0
    2024-07-01 19:33:34.891 info starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v20.15.0, js-controller: 5.0.19
    smartgarden.0
    2024-07-01 19:33:34.923 silly States system redis pmessage system.adapter.smartgarden.0.logLevel/system.adapter.smartgarden.0.logLevel:{"val":"silly","ack":true,"ts":1719855214915,"q":0,"from":"system.adapter.smartgarden.0","lc":1718653204578}
    smartgarden.0
    2024-07-01 19:33:34.941 info 3/ getConnection...
    smartgarden.0
    2024-07-01 19:33:34.942 info 3/ connectToGardena...
    smartgarden.0
    2024-07-01 19:33:34.944 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2024-07-01 19:33:34.945 info 3/ connecting to Gardena Smart System Service ...
    smartgarden.0
    2024-07-01 19:33:34.945 info 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    2024-07-01 19:33:34.946 info 3/ connect ... empty username
    smartgarden.0
    2024-07-01 19:33:34.946 info 3/ connect ... empty password
    smartgarden.0
    2024-07-01 19:33:34.947 info 3/ connect ... using client credentials grant
    smartgarden.0
    2024-07-01 19:33:35.077 info 3/ sgSetState: info.revision value=Main: 3209 / API: 3207 ack=true
    smartgarden.0
    2024-07-01 19:33:35.105 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1719855215093,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1719841482826}
    smartgarden.0
    2024-07-01 19:33:35.125 info 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
    smartgarden.0
    2024-07-01 19:33:35.165 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1719855215147,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1719841482826}
    smartgarden.0
    2024-07-01 19:33:35.166 info 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
    smartgarden.0
    2024-07-01 19:33:35.292 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.revision:{"val":"Main: 3209 / API: 3207","ack":true,"ts":1719855215282,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1716746142430}
    smartgarden.0
    2024-07-01 19:33:35.292 info 3/ ---> State change by device: state smartgarden.0.info.revision changed: Main: 3209 / API: 3207 (ack = true)
    smartgarden.0
    2024-07-01 19:33:35.356 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.adapterversion:{"val":"2.0.1","ack":true,"ts":1719855215353,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1716746142433}
    smartgarden.0
    2024-07-01 19:33:35.357 info 3/ ---> State change by device: state smartgarden.0.info.adapterversion changed: 2.0.1 (ack = true)
    smartgarden.0
    2024-07-01 19:33:35.466 info 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    smartgarden.0
    2024-07-01 19:33:35.474 info 3/ Connection: expires_in/timeout/factor:86399 / 86313 / 0.999
    smartgarden.0
    2024-07-01 19:33:35.475 info 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XX-XXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    smartgarden.0
    2024-07-01 19:33:35.475 info 3/ get_locations ...
    smartgarden.0
    2024-07-01 19:33:35.694 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2024-07-01 19:33:35.699 info 3/ get_locations failure: response.statusCode/Message=429/
    smartgarden.0
    2024-07-01 19:33:35.700 info 3/ get_locations failure:..return with error
    smartgarden.0
    2024-07-01 19:33:35.700 error Error: request returned 429
    smartgarden.0
    2024-07-01 19:33:35.700 info 3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2024-07-01 19:33:35.701 info 3/ getConnection: returned connection error: request returned 429
    smartgarden.0
    2024-07-01 19:33:35.701 info 3/ getConnection: trying to connect again in 600 seconds
    smartgarden.0
    2024-07-01 19:33:35.728 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1719855215722,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1719841482826}
    smartgarden.0
    2024-07-01 19:33:35.729 info 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
    smartgarden.0
    2024-07-01 19:33:35.790 silly States user redis pmessage smartgarden.0.*/smartgarden.0.info.connection:{"val":false,"ack":true,"ts":1719855215788,"q":0,"from":"system.adapter.smartgarden.0","user":"system.user.admin","lc":1719841482826}
    smartgarden.0
    2024-07-01 19:33:35.791 info 3/ ---> State change by device: state smartgarden.0.info.connection changed: false (ack = true)
    smartgarden.0
    2024-07-01 19:33:42.712 silly States system redis pmessage system.adapter.smartgarden.0.plugins.*/system.adapter.smartgarden.0.plugins.sentry.enabled:{"val":true,"ack":true,"ts":1719855222707,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1716836978932}
    Es sei gesagt ich den Mover per Script steuere und keine Nutzungsprognosen Aboniere.
    Anbei ein paar Bilder meiner Einstellungen.
    Michael
