  4. [Aufruf] IKEA-Trådfri Adapter testen
471 Beiträge 49 Kommentatoren 175.9k Aufrufe 5 Beobachtet
  • P Offline
    pxstd
    #252
    @AlCalzone:
    Danke für den Log. Der relevante Part scheint dieser zu sein:
    2017-12-18T13:13:31.611Z node-coap-client workOffSendQueue > queue empty
    2017-12-18T13:13:40.618Z node-coap-client getConnection(coaps://10.1.15.102:5684) => found existing connection
    2017-12-18T13:13:40.618Z node-coap-client remembering request: msgID=0x122, token=, url=coaps://10.1.15.102:5684
    2017-12-18T13:13:40.618Z node-coap-client added message to send queue, new length = 1
    2017-12-18T13:13:40.618Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
    2017-12-18T13:13:40.618Z node-coap-client concurrency low enough, sending message 0x122
    2017-12-18T13:13:40.618Z node-coap-client request 0x122: concurrency changed => 1
    2017-12-18T13:13:40.626Z node-coap-client received message: ID=0x122
    2017-12-18T13:13:40.626Z node-coap-client request 0x122: concurrency changed => 0
    2017-12-18T13:13:40.627Z node-coap-client workOffSendQueue > queue empty
    2017-12-18T13:13:40.627Z node-coap-client received response to ping with ID 0x122
    2017-12-18T13:13:40.627Z node-coap-client forgetting request: token=; msgID=0x122
    ping successful...
    2017-12-18T13:13:41.620Z node-coap-client workOffSendQueue > queue empty
    2017-12-18T13:13:50.625Z node-coap-client getConnection(coaps://10.1.15.102:5684) => found existing connection
    2017-12-18T13:13:50.625Z node-coap-client remembering request: msgID=0x123, token=, url=coaps://10.1.15.102:5684
    2017-12-18T13:13:50.625Z node-coap-client added message to send queue, new length = 1
    2017-12-18T13:13:50.625Z node-coap-client workOffSendQueue > concurrency = 0 (MAX 1)
    2017-12-18T13:13:50.625Z node-coap-client concurrency low enough, sending message 0x123
    2017-12-18T13:13:50.625Z node-coap-client request 0x123: concurrency changed => 1
    2017-12-18T13:13:51.627Z node-coap-client workOffSendQueue > queue empty
    2017-12-18T13:13:55.627Z node-coap-client forgetting request: token=; msgID=0x123
    2017-12-18T13:13:55.627Z node-coap-client request 0x123: concurrency changed => 0
    2017-12-18T13:13:55.627Z node-coap-client workOffSendQueue > queue empty
    ping unsuccessful...
    In Summe nichts auffälliges, außer dass das Gateway auf den letzten Ping nicht antwortet und danach auch nicht mehr.
    Auf vorherige Anfragen werden aber weiterhin Updates geschickt… Seltsam. Ich muss nochmal mit dem automatischen Restart spielen, schätze da führt kein Weg dran vorbei. `
    Gibt's eine Art Workaround den ich erstmal basteln könnte?
    Ich hatte schon überlegt via PING Adapter und bei "unreachable" state den Tradfri Adapter neu zu starten. Leider pongt das GW aber.
    Desweiteren hatte ich schon einen 5-Minuten Cronjob mit Tradfri Adapter restart angedacht, aber das funktioniert leider auch nicht.
    Ideen?
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #253
      Probier bitte mal Version 1.0.2 (auf Github und npm) und berichte wie es sich jetzt verhält.
      • P Offline
        pxstd
        #254
        Bekomme ich die via
        iobroker update
          AlCalzoneA Offline
          AlCalzone
          #255
          @pxstd:
          Bekomme ich die via
          iobroker update
          Wenn du latest repo ausgewählt hast, ja. Sonst in der Adapter Liste aufs github Symbol klicken und TRÅDFRI aus der Liste auswählen. Nach Update von github musst du die Instanz neu starten.
          • P Offline
            pxstd
            #256
            Was genau sagt mir
            > Adapter "tradfri" : 1.0.0 , installed 1.0.2
            1.0.2 ist installiert, aber 1.0.0 läuft in der Instanz?
            Habe Adapter + iobroker neugestartet.
              #257
              Nein, es heißt dass es in dem von dir gewählten repository in der Version 1.0.0 vorliegt, du aber bereits (auf anderen Wegen) die 1.0.2 installiert hast und somit deiner Zeit voraus bist ;-)
              • P Offline
                pxstd
                #258
                @AlCalzone:
                Probier bitte mal Version 1.0.2 (auf Github und npm) und berichte wie es sich jetzt verhält. `
                Es ist hübsch! Sehr hübsch! :)
                ! tradfri.0 2017-12-29 10:17:47.013 info received all groups and scenes
                ! tradfri.0 2017-12-29 10:17:47.013 info received all devices
                ! tradfri.0 2017-12-29 10:17:47.013 info Connection to gateway reestablished
                ! tradfri.0 2017-12-29 10:17:42.007 warn Lost connection to gateway
                ! tradfri.0 2017-12-29 10:07:08.158 info received all groups and scenes
                ! tradfri.0 2017-12-29 10:07:08.157 info updating possible scenes for group 131081: ["196632","196633","196634"]
                ! tradfri.0 2017-12-29 10:07:08.088 info updating possible scenes for group 131081: ["196632","196633"]
                ! tradfri.0 2017-12-29 10:07:08.011 info updating possible scenes for group 131081: ["196632"]
                ! tradfri.0 2017-12-29 10:07:07.941 info updating possible scenes for group 131080: ["196629","196630","196631"]
                ! tradfri.0 2017-12-29 10:07:07.897 info updating possible scenes for group 131080: ["196629","196630"]
                ! tradfri.0 2017-12-29 10:07:07.854 info updating possible scenes for group 131080: ["196629"]
                ! tradfri.0 2017-12-29 10:07:07.809 info updating possible scenes for group 131077: ["196620","196621","196622"]
                ! tradfri.0 2017-12-29 10:07:07.701 info updating possible scenes for group 131077: ["196620","196621"]
                ! tradfri.0 2017-12-29 10:07:07.578 info updating possible scenes for group 131077: ["196620"]
                ! tradfri.0 2017-12-29 10:07:07.474 info updating possible scenes for group 131073: ["196608","196609","196610"]
                ! tradfri.0 2017-12-29 10:07:07.393 info updating possible scenes for group 131073: ["196608","196609"]
                ! tradfri.0 2017-12-29 10:07:07.309 info updating possible scenes for group 131073: ["196608"]
                ! tradfri.0 2017-12-29 10:07:07.225 info got all scenes in group 131081: [196632,196633,196634]
                ! tradfri.0 2017-12-29 10:07:07.207 info got all scenes in group 131080: [196629,196630,196631]
                ! tradfri.0 2017-12-29 10:07:07.191 info got all scenes in group 131077: [196620,196621,196622]
                ! tradfri.0 2017-12-29 10:07:07.170 info got all scenes in group 131073: [196608,196609,196610]
                ! tradfri.0 2017-12-29 10:07:07.069 info got all groups: [131081,131080,131077,131073]
                ! tradfri.0 2017-12-29 10:07:07.059 info received all devices
                ! tradfri.0 2017-12-29 10:07:06.828 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                ! tradfri.0 2017-12-29 10:07:06.769 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                ! tradfri.0 2017-12-29 10:07:06.735 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                ! tradfri.0 2017-12-29 10:07:03.848 info terminating
                ! tradfri.0 2017-12-29 10:07:03.846 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:07:03.846 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:07:03.846 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:07:01.502 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:07:01.502 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:07:01.502 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:59.726 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:59.726 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:59.726 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:58.755 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:58.755 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:58.755 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:58.093 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:58.093 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:58.093 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:57.090 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:57.090 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:57.090 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:55.719 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:55.719 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:55.719 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:54.297 error Please restart the adapter!
                ! tradfri.0 2017-12-29 10:06:54.297 error Cannot send changes.
                ! tradfri.0 2017-12-29 10:06:54.296 error The connection to the gateway is dead.
                ! tradfri.0 2017-12-29 10:06:53.826 error Restarting the adapter in 10 seconds!
                ! tradfri.0 2017-12-29 10:06:53.826 error Three consecutive reset attempts failed!
                ! tradfri.0 2017-12-29 10:06:25.814 error unhandled promise rejection: CoapClient was reset
                ! tradfri.0 2017-12-29 10:06:25.812 warn 3 consecutive pings failed, resetting connection (attempt #3)…
                ! tradfri.0 2017-12-29 10:06:14.059 error at Timer.listOnTimeout (timers.js:214:5)
                ! tradfri.0 2017-12-29 10:06:14.059 error at tryOnTimeout (timers.js:250:5)
                ! tradfri.0 2017-12-29 10:06:14.059 error at ontimeout (timers.js:386:11)
                ! tradfri.0 2017-12-29 10:06:14.059 error at Timeout.action [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/build/CoapClient.js:281:38)
                ! tradfri.0 2017-12-29 10:06:14.059 error at Function.retransmit (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/node_modules/node-coap-client/build/CoapClient.js:364:40)
                ! tradfri.0 2017-12-29 10:06:14.059 error > stack: Error: Retransmit counter exceeded
                ! tradfri.0 2017-12-29 10:06:14.058 error unhandled promise rejection: Retransmit counter exceeded
                ! tradfri.0 2017-12-29 10:06:05.815 warn Lost connection to gateway
                ! tradfri.0 2017-12-29 10:05:38.843 info updating possible scenes for group 131077: ["196620","196621","196622"]
                ! tradfri.0 2017-12-29 10:05:38.727 info updating possible scenes for group 131077: ["196620","196621","196622"]
                ! tradfri.0 2017-12-29 10:05:38.629 info updating possible scenes for group 131077: ["196620","196621","196622"]
                ! tradfri.0 2017-12-29 09:58:00.629 info received all groups and scenes
                ! tradfri.0 2017-12-29 09:58:00.629 info received all devices
                ! tradfri.0 2017-12-29 09:58:00.628 info Connection to gateway reestablished
                ! tradfri.0 2017-12-29 09:57:55.628 warn Lost connection to gateway
                ! tradfri.0 2017-12-29 09:56:30.595 info received all groups and scenes
                ! tradfri.0 2017-12-29 09:56:30.595 info received all devices
                ! tradfri.0 2017-12-29 09:56:30.595 info Connection to gateway reestablished
                ! tradfri.0 2017-12-29 09:56:25.591 warn Lost connection to gateway
                ! tradfri.0 2017-12-29 09:51:50.490 info received all groups and scenes
                ! tradfri.0 2017-12-29 09:51:50.490 info received all devices
                ! tradfri.0 2017-12-29 09:51:50.489 info Connection to gateway reestablished
                ! tradfri.0 2017-12-29 09:51:35.473 warn Lost connection to gateway
                • P Offline
                  pxstd
                  #259
                  Nachtrag: Sobald allerdings ein Restart passiert, funktioniert das aktuell angezeigte VIS nicht mehr korrekt.
                  Ich habe ein Tablet im EG über das ich steuere - wird der Adapter neu gestartet, sind alle Veränderungen im VIS ohne Funktion. (iPad Air, iPad 1)
                    AlCalzoneA Offline
                    AlCalzone
                    #260
                    @pxstd:
                    wird der Adapter neu gestartet, sind alle Veränderungen im VIS ohne Funktion. (iPad Air, iPad 1) `
                    Bin kein VIS-Mensch, daher weiß ich nicht obs da was zu beachten gibt.
                    Lassen sich die Änderungen, die du per VIS vornehmen willst, nach einem Neustart manuell in der Objektliste vornehmen?
                    • R Offline
                      ramses
                      #261
                      … ach wäre das göttlich wenn bei Tastendruck auf die Tadfri Fernbedienung oder Dimmer auch was beim Adapter ankommen würde :-(
                      Momentan sind die Dinger für mich nur als Türstopper zu verwenden :-(
                      Kommt da noch was an support oder ist das nicht möglich?
                      • P Offline
                        pxstd
                        #262
                        @AlCalzone:
                        @pxstd:
                        Lassen sich die Änderungen, die du per VIS vornehmen willst, nach einem Neustart manuell in der Objektliste vornehmen? `
                        Nein, egal was ich an States verändere, die Änderungen werden nicht übertragen.
                        Der Adapter läuft zwar, aber ich kann nichts mehr steuern.
                          AlCalzoneA Offline
                          AlCalzone
                          #263
                          ` > Nein, egal was ich an States verändere, die Änderungen werden nicht übertragen.
                          Der Adapter läuft zwar, aber ich kann nichts mehr steuern. `
                          Was steht dann im log?
                          • R Offline
                            ramses
                            #264
                            Bei mir klappt alles soweit.
                            Hab die Tradfri lampen an das Hue gateway angebunden.
                            Komischerweise wechselt meine Ikea RGB E27 birne mitten im Betrieb einfach mal auf weiss oder geht auch hin und wieder mal so an.
                            Sieht aus als würde se kurz den "strom" verlieren…
                            Denke mal das ist einfach nen defekt der Birne und werde se umtauschen.
                            Durch iobroker wurde auf jeden Fall nichts getriggert.
                            • P Offline
                              pxstd
                              #265
                              @AlCalzone:
                              Gesendet von iPhone mit Tapatalk `
                              Checke ich nochmal.
                                AlCalzoneA Offline
                                AlCalzone
                                #266
                                Bei mir läuft die Automatisierung übrigens seit dem Update ohne manuelles Eingreifen - vorher musste ich etwa täglich den Adapter neu starten.
                                • P Offline
                                  pxstd
                                  #267
                                  @AlCalzone:
                                  Bei mir läuft die Automatisierung übrigens seit dem Update ohne manuelles Eingreifen - vorher musste ich etwa täglich den Adapter neu starten. `
                                  Ich bin verwirrt. Bei mir jetzt für den Moment auch. Ich berichte sobald sich etwas ändert.
                                  Danke schonmal, AlCazone! Good Job!
                                  • P Offline
                                    pxstd
                                    #268
                                    ! tradfri.0 2018-01-03 23:33:02.297 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:33:02.297 info received all devices
                                    ! tradfri.0 2018-01-03 23:33:02.297 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:32:57.296 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:30:52.272 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:30:52.272 info received all devices
                                    ! tradfri.0 2018-01-03 23:30:52.272 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:30:47.248 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:26:12.168 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:26:12.168 info received all devices
                                    ! tradfri.0 2018-01-03 23:26:12.168 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:26:07.165 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:23:32.119 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:23:32.118 info received all devices
                                    ! tradfri.0 2018-01-03 23:23:32.118 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:23:17.102 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:15:43.087 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 23:15:43.018 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 23:15:42.959 error at process._tickCallback (internal/process/next_tick.js:109:7)
                                    ! tradfri.0 2018-01-03 23:15:42.959 error at Promise.all.then.catch.reason (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/build/tradfri-client.js:303:62)
                                    ! tradfri.0 2018-01-03 23:15:42.959 error > stack: TypeError: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 23:15:42.959 error unhandled promise rejection: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 23:15:42.958 error unhandled promise rejection: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 23:15:42.958 error at process._tickCallback (internal/process/next_tick.js:109:7)
                                    ! tradfri.0 2018-01-03 23:15:42.958 error at Promise.all.then.catch.reason (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/build/tradfri-client.js:303:62)
                                    ! tradfri.0 2018-01-03 23:15:42.958 error > stack: TypeError: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 23:15:42.957 error unhandled promise rejection: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 23:15:42.957 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:15:42.956 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 23:15:42.887 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 23:15:42.845 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 23:15:42.800 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 23:15:42.761 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 23:15:42.677 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 23:15:42.577 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 23:15:42.489 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 23:15:42.422 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 23:15:42.349 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 23:15:42.274 info got all scenes in group 131081: [196632,196633,196634]
                                    ! tradfri.0 2018-01-03 23:15:42.254 info got all scenes in group 131080: [196629,196630,196631]
                                    ! tradfri.0 2018-01-03 23:15:42.237 info got all scenes in group 131077: [196620,196621,196622]
                                    ! tradfri.0 2018-01-03 23:15:42.224 info got all scenes in group 131073: [196608,196609,196610]
                                    ! tradfri.0 2018-01-03 23:15:42.125 info got all groups: [131081,131080,131077,131073]
                                    ! tradfri.0 2018-01-03 23:15:41.989 info received all devices
                                    ! tradfri.0 2018-01-03 23:15:41.976 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                                    ! tradfri.0 2018-01-03 23:15:41.968 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:15:16.927 warn 3 consecutive pings failed, resetting connection (attempt #1)…
                                    ! tradfri.0 2018-01-03 23:14:56.928 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:10:33.149 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:10:33.148 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 23:10:33.079 info updating possible scenes for group 131081: ["196632","196633"]
                                    ! tradfri.0 2018-01-03 23:10:33.011 info updating possible scenes for group 131081: ["196632"]
                                    ! tradfri.0 2018-01-03 23:10:32.949 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 23:10:32.909 info updating possible scenes for group 131080: ["196629","196630"]
                                    ! tradfri.0 2018-01-03 23:10:32.869 info updating possible scenes for group 131080: ["196629"]
                                    ! tradfri.0 2018-01-03 23:10:32.820 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 23:10:32.725 info updating possible scenes for group 131077: ["196620","196621"]
                                    ! tradfri.0 2018-01-03 23:10:32.640 info updating possible scenes for group 131077: ["196620"]
                                    ! tradfri.0 2018-01-03 23:10:32.544 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 23:10:32.474 info updating possible scenes for group 131073: ["196608","196609"]
                                    ! tradfri.0 2018-01-03 23:10:32.402 info updating possible scenes for group 131073: ["196608"]
                                    ! tradfri.0 2018-01-03 23:10:32.327 info got all scenes in group 131081: [196632,196633,196634]
                                    ! tradfri.0 2018-01-03 23:10:32.307 info got all scenes in group 131080: [196629,196630,196631]
                                    ! tradfri.0 2018-01-03 23:10:32.289 info got all scenes in group 131077: [196620,196621,196622]
                                    ! tradfri.0 2018-01-03 23:10:32.276 info got all scenes in group 131073: [196608,196609,196610]
                                    ! tradfri.0 2018-01-03 23:10:32.151 info got all groups: [131081,131080,131077,131073]
                                    ! tradfri.0 2018-01-03 23:10:32.138 info received all devices
                                    ! tradfri.0 2018-01-03 23:10:31.830 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                                    ! tradfri.0 2018-01-03 23:10:31.759 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                    ! tradfri.0 2018-01-03 23:10:31.721 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                    ! tradfri.0 2018-01-03 23:10:28.842 info terminating
                                    ! tradfri.0 2018-01-03 23:05:42.565 error If the settings are correct, consider re-authentication in the adapter config.
                                    ! tradfri.0 2018-01-03 23:05:42.564 error Please check your network and adapter settings and restart the adapter!
                                    ! tradfri.0 2018-01-03 23:05:42.564 error Could not connect to the gateway 10.1.15.102!
                                    ! tradfri.0 2018-01-03 23:05:39.549 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                    ! tradfri.0 2018-01-03 23:05:39.511 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                    ! tradfri.0 2018-01-03 23:05:36.630 error The connection to the gateway is dead.
                                    ! tradfri.0 2018-01-03 23:05:26.604 error Restarting the adapter in 10 seconds!
                                    ! tradfri.0 2018-01-03 23:05:26.604 error Three consecutive reset attempts failed!
                                    ! tradfri.0 2018-01-03 23:05:06.600 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 23:04:01.573 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 23:04:01.573 info received all devices
                                    ! tradfri.0 2018-01-03 23:04:01.573 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 23:03:56.573 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 22:59:31.478 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 22:59:31.478 info received all devices
                                    ! tradfri.0 2018-01-03 22:59:31.478 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 22:59:26.474 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 22:56:12.533 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 22:56:12.473 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 22:56:12.413 error at process._tickCallback (internal/process/next_tick.js:109:7)
                                    ! tradfri.0 2018-01-03 22:56:12.413 error at Promise.all.then.catch.reason (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/build/tradfri-client.js:303:62)
                                    ! tradfri.0 2018-01-03 22:56:12.413 error > stack: TypeError: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 22:56:12.413 error unhandled promise rejection: Cannot read property 'reject' of null
                                    ! tradfri.0 2018-01-03 22:56:12.413 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 22:56:12.412 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                    ! tradfri.0 2018-01-03 22:56:12.350 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 22:56:12.311 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 22:56:12.269 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                    ! tradfri.0 2018-01-03 22:56:12.224 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 22:56:12.132 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 22:56:12.035 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                    ! tradfri.0 2018-01-03 22:56:11.951 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 22:56:11.882 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 22:56:11.812 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                    ! tradfri.0 2018-01-03 22:56:11.740 info got all scenes in group 131081: [196632,196633,196634]
                                    ! tradfri.0 2018-01-03 22:56:11.720 info got all scenes in group 131080: [196629,196630,196631]
                                    ! tradfri.0 2018-01-03 22:56:11.701 info got all scenes in group 131077: [196620,196621,196622]
                                    ! tradfri.0 2018-01-03 22:56:11.683 info got all scenes in group 131073: [196608,196609,196610]
                                    ! tradfri.0 2018-01-03 22:56:11.589 info got all groups: [131081,131080,131077,131073]
                                    ! tradfri.0 2018-01-03 22:56:11.452 info received all devices
                                    ! tradfri.0 2018-01-03 22:56:11.440 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                                    ! tradfri.0 2018-01-03 22:56:11.433 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 22:55:44.403 warn 3 consecutive pings failed, resetting connection (attempt #3)…
                                    ! tradfri.0 2018-01-03 22:55:16.392 warn 3 consecutive pings failed, resetting connection (attempt #2)...
                                    ! tradfri.0 2018-01-03 22:54:56.388 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 22:48:51.282 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 22:48:51.282 info received all devices
                                    ! tradfri.0 2018-01-03 22:48:51.282 info Connection to gateway reestablished
                                    ! tradfri.0 2018-01-03 22:48:46.266 warn Lost connection to gateway
                                    ! tradfri.0 2018-01-03 22:46:51.236 info received all groups and scenes
                                    ! tradfri.0 2018-01-03 22:46:51.235 info received all devices
                                    • P Offline
                                      pxstd
                                      #269
                                      Und nun regelmäßig:
                                      ! tradfri.0 2018-01-04 06:01:24.372 error If the settings are correct, consider re-authentication in the adapter config.
                                      ! tradfri.0 2018-01-04 06:01:24.372 error Please check your network and adapter settings and restart the adapter!
                                      ! tradfri.0 2018-01-04 06:01:24.372 error Could not connect to the gateway 10.1.15.102!
                                      ! tradfri.0 2018-01-04 06:01:21.357 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                      ! tradfri.0 2018-01-04 06:01:21.324 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                      ! tradfri.0 2018-01-04 06:01:18.439 error The connection to the gateway is dead.
                                      ! tradfri.0 2018-01-04 06:01:08.420 error Restarting the adapter in 10 seconds!
                                      ! tradfri.0 2018-01-04 06:01:08.420 error Three consecutive reset attempts failed!
                                      ! tradfri.0 2018-01-04 06:00:38.417 warn 3 consecutive pings failed, resetting connection (attempt #3)…
                                      ! tradfri.0 2018-01-04 06:00:08.410 warn 3 consecutive pings failed, resetting connection (attempt #2)...
                                      ! tradfri.0 2018-01-04 05:59:40.394 warn 3 consecutive pings failed, resetting connection (attempt #1)...
                                      ! tradfri.0 2018-01-04 05:59:20.390 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:57:25.354 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:57:25.354 info received all devices
                                      ! tradfri.0 2018-01-04 05:57:25.354 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:57:10.349 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:54:55.306 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:54:55.305 info received all devices
                                      ! tradfri.0 2018-01-04 05:54:55.305 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:54:40.301 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:47:55.166 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:47:55.166 info received all devices
                                      ! tradfri.0 2018-01-04 05:47:55.166 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:47:50.153 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:41:15.021 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:41:15.021 info received all devices
                                      ! tradfri.0 2018-01-04 05:41:15.021 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:41:10.016 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:36:54.940 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:36:54.940 info received all devices
                                      ! tradfri.0 2018-01-04 05:36:54.940 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:36:39.928 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:34:14.878 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:34:14.878 info received all devices
                                      ! tradfri.0 2018-01-04 05:34:14.878 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:34:09.873 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:32:24.847 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:32:24.847 info received all devices
                                      ! tradfri.0 2018-01-04 05:32:24.846 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:32:19.837 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:24:14.653 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:24:14.653 info received all devices
                                      ! tradfri.0 2018-01-04 05:24:14.653 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:24:09.650 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:23:04.657 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:23:04.657 info received all devices
                                      ! tradfri.0 2018-01-04 05:23:04.657 info Connection to gateway reestablished
                                      ! tradfri.0 2018-01-04 05:22:59.624 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:18:45.772 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:18:45.772 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2018-01-04 05:18:45.700 info updating possible scenes for group 131081: ["196632","196633"]
                                      ! tradfri.0 2018-01-04 05:18:45.631 info updating possible scenes for group 131081: ["196632"]
                                      ! tradfri.0 2018-01-04 05:18:45.568 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2018-01-04 05:18:45.522 info updating possible scenes for group 131080: ["196629","196630"]
                                      ! tradfri.0 2018-01-04 05:18:45.482 info updating possible scenes for group 131080: ["196629"]
                                      ! tradfri.0 2018-01-04 05:18:45.443 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2018-01-04 05:18:45.359 info updating possible scenes for group 131077: ["196620","196621"]
                                      ! tradfri.0 2018-01-04 05:18:45.269 info updating possible scenes for group 131077: ["196620"]
                                      ! tradfri.0 2018-01-04 05:18:45.173 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                      ! tradfri.0 2018-01-04 05:18:45.101 info updating possible scenes for group 131073: ["196608","196609"]
                                      ! tradfri.0 2018-01-04 05:18:45.030 info updating possible scenes for group 131073: ["196608"]
                                      ! tradfri.0 2018-01-04 05:18:44.959 info got all scenes in group 131081: [196632,196633,196634]
                                      ! tradfri.0 2018-01-04 05:18:44.942 info got all scenes in group 131080: [196629,196630,196631]
                                      ! tradfri.0 2018-01-04 05:18:44.927 info got all scenes in group 131077: [196620,196621,196622]
                                      ! tradfri.0 2018-01-04 05:18:44.906 info got all scenes in group 131073: [196608,196609,196610]
                                      ! tradfri.0 2018-01-04 05:18:44.796 info got all groups: [131081,131080,131077,131073]
                                      ! tradfri.0 2018-01-04 05:18:44.783 info received all devices
                                      ! tradfri.0 2018-01-04 05:18:44.539 info got all devices: [65536,65544,65546,65538,65545,65541,65551,65537,65543,65553,65552,65548,65550,65549]
                                      ! tradfri.0 2018-01-04 05:18:44.481 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                      ! tradfri.0 2018-01-04 05:18:44.414 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                      ! tradfri.0 2018-01-04 05:18:41.528 error The connection to the gateway is dead.
                                      ! tradfri.0 2018-01-04 05:18:31.514 error Restarting the adapter in 10 seconds!
                                      ! tradfri.0 2018-01-04 05:18:31.514 error Three consecutive reset attempts failed!
                                      ! tradfri.0 2018-01-04 05:18:11.507 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 05:16:27.599 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2018-01-04 05:16:27.538 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2018-01-04 05:16:27.472 error at process._tickCallback (internal/process/next_tick.js:109:7)
                                      ! tradfri.0 2018-01-04 05:16:27.472 error at Promise.all.then.catch.reason (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/build/tradfri-client.js:303:62)
                                      ! tradfri.0 2018-01-04 05:16:27.472 error > stack: TypeError: Cannot read property 'reject' of null
                                      ! tradfri.0 2018-01-04 05:16:27.472 error unhandled promise rejection: Cannot read property 'reject' of null
                                      ! tradfri.0 2018-01-04 05:16:27.471 error at process._tickCallback (internal/process/next_tick.js:109:7)
                                      ! tradfri.0 2018-01-04 05:16:27.471 error at Promise.all.then.catch.reason (/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-tradfri-client/build/tradfri-client.js:303:62)
                                      ! tradfri.0 2018-01-04 05:16:27.471 error > stack: TypeError: Cannot read property 'reject' of null
                                      ! tradfri.0 2018-01-04 05:16:27.471 error unhandled promise rejection: Cannot read property 'reject' of null
                                      ! tradfri.0 2018-01-04 05:16:27.471 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 05:16:27.471 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2018-01-04 05:16:27.408 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2018-01-04 05:16:27.367 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2018-01-04 05:16:27.322 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2018-01-04 05:16:27.283 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2018-01-04 05:16:27.200 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2018-01-04 05:16:27.113 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2018-01-04 05:16:27.028 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                      ! tradfri.0 2018-01-04 05:16:26.959 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                      ! tradfri.0 2018-01-04 05:16:26.890 info updating possible scenes for group 131073: ["196608","196609","196610"]
                                      ! tradfri.0 2018-01-04 05:16:26.817 info got all scenes in group 131081: [196632,196633,196634]
                                      ! tradfri.0 2018-01-04 05:16:26.798 info got all scenes in group 131080: [196629,196630,196631]
                                      ! tradfri.0 2018-01-04 05:16:26.781 info got all scenes in group 131077: [196620,196621,196622]
                                      EDIT:
                                      ! tradfri.0 2018-01-04 13:42:23.192 error If the settings are correct, consider re-authentication in the adapter config.
                                      ! tradfri.0 2018-01-04 13:42:23.192 error Please check your network and adapter settings and restart the adapter!
                                      ! tradfri.0 2018-01-04 13:42:23.192 error Could not connect to the gateway 10.1.15.102!
                                      ! tradfri.0 2018-01-04 13:42:20.176 info startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
                                      ! tradfri.0 2018-01-04 13:42:20.141 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.12.0
                                      ! tradfri.0 2018-01-04 13:42:17.255 error The connection to the gateway is dead.
                                      ! tradfri.0 2018-01-04 13:42:07.234 error Restarting the adapter in 10 seconds!
                                      ! tradfri.0 2018-01-04 13:42:07.234 error Three consecutive reset attempts failed!
                                      ! tradfri.0 2018-01-04 13:41:37.224 warn 3 consecutive pings failed, resetting connection (attempt #3)…
                                      ! tradfri.0 2018-01-04 13:41:07.212 warn 3 consecutive pings failed, resetting connection (attempt #2)...
                                      ! tradfri.0 2018-01-04 13:40:39.197 warn 3 consecutive pings failed, resetting connection (attempt #1)...
                                      ! tradfri.0 2018-01-04 13:40:19.201 warn Lost connection to gateway
                                      ! tradfri.0 2018-01-04 12:31:24.095 info received all groups and scenes
                                      ! tradfri.0 2018-01-04 12:31:24.095 info updating possible scenes for group 131081: ["196632","196633","196634"]
                                      ! tradfri.0 2018-01-04 12:31:24.031 info updating possible scenes for group 131081: ["196632","196633"]
                                      ! tradfri.0 2018-01-04 12:31:23.965 info updating possible scenes for group 131081: ["196632"]
                                      ! tradfri.0 2018-01-04 12:31:23.901 info updating possible scenes for group 131080: ["196629","196630","196631"]
                                      ! tradfri.0 2018-01-04 12:31:23.861 info updating possible scenes for group 131080: ["196629","196630"]
                                      ! tradfri.0 2018-01-04 12:31:23.812 info updating possible scenes for group 131080: ["196629"]
                                      ! tradfri.0 2018-01-04 12:31:23.765 info updating possible scenes for group 131077: ["196620","196621","196622"]
                                      ! tradfri.0 2018-01-04 12:31:23.663 info updating possible scenes for group 131077: ["196620","196621"]
                                      ! tradfri.0 2018-01-04 12:31:23.562 info updating possible scenes for group 131077: ["196620"]
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #270
                                        Einen Fehler hast du schon mal gefunden, aber warum deine Verbindung solche Probleme macht, ist mir unklar. Ich fürchte ich muss da ein paar mehr Logs einbauen.
                                        Edit: Hast du auf deinem ioBroker-Host die Möglichkeit, mal den Traffic von Adapterstart bis Abbruch zu loggen (Wireshark/tcpdump/etc…)?
                                        Edit 2: In Version 1.0.3 auf Github sollte zumindest die unhandled rejection weg sein. Ich fürchte aber dass das nur ein Symptom ist.
                                        • ldittmarL Offline
                                          ldittmarL Offline
                                          ldittmar
                                          #271
                                          Hi Community,
                                          kann es sein, dass die Bezeichnung der States immer wieder mit der originale Bezeichnung überschrieben werden? Ich hatte mal alle on/off schön umbenannt, aber jetzt schaue ich nach und alle heißen wieder wie vorher. 😢
                                          Grüße,
                                          ldittmar
