  2. English
  3. Development
  4. Adapter for Gree and C&H conditioners
Geplant Angeheftet Gesperrt Verschoben Development
14 Beiträge 5 Kommentatoren 7.0k Aufrufe 3 Beobachtet
  • Serhiy KrasovskyyS Offline
    Serhiy Krasovskyy
    schrieb am zuletzt editiert von Serhiy Krasovskyy
    Supported devices
    All devices which can be controlled via EWPE Smart app should be supported, including:
    Gree Smart series
    Cooper&Hunter: Supreme, Vip Inverter, ICY II, Arctic, Alpha, Alpha NG, Veritas, Veritas NG series
    EcoAir X series
    ProKlima
    You can install adapter from beta repository(should be available in 24hrs) "gree-hvac" or directly from github: https://github.com/XHunter74/ioBroker.gree-hvac
    I will be glad to any feedback.
    W 1 Antwort Letzte Antwort
    • Serhiy KrasovskyyS Serhiy Krasovskyy
      Supported devices
      Gree Smart series
      EcoAir X series
      ProKlima
      W Offline
      W Offline
      Wildbill
      @serhiy-krasovskyy Installed via NPM, put in ip of a Proklima aircon and it worked OOTB. Seeing all the stuff I also see in FHEM, which I use for some things, iobroker can't handle (like this aircon until right now).
      Good job and thanks.
      • W Wildbill
        mcm1957M Offline
        mcm1957M Offline
        mcm1957
        @wildbill said in Adapter for Gree and C&H conditioners:
        Just to ensure that info reaches users: adapter is available at latest repository
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          W Offline
          W Offline
          Wildbill
          @mcm1957 Today noon, at the time I installed it, I changed repo from stable to beta(Latest) searched for "gree" but didn't find anything. Even not after manually refreshing. So I decided to click on the "cat", selected NPM and looked for gree and BINGO.
          Perhaps I was a little impatient and too early. 😊
          HomoranH mcm1957M 2 Antworten Letzte Antwort
          • W Wildbill
            HomoranH Offline
            HomoranH Offline
            @wildbill sagte in Adapter for Gree and C&H conditioners:
            @mcm1957
            to be honest, I think the 23 days in latest, according to your screeshot, is not possible
              @mcm1957
              mcm1957M Offline
              mcm1957M Offline
              mcm1957
              @homoran said in Adapter for Gree and C&H conditioners:
              @mcm1957
              Yes, but thats something to report to Bluefox / Statisticscalculation :-)
              I think the time is taken from npm package creation date as I do not know that the date a revison is inserted into repository json is stored anywhere.
              Main goal was to show that the adapter IS available at latest and an direct installtion is not required (althogh tester normally know what they are doing and thus its ok to directly install from npm or github for them
              • W Wildbill
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                Well, most likely you did not press "Search for updates" Button after changing repos. That's a know issue (in my oppinion) that changing repositories does not include a refresh of the data.
                ~~https://github.com/ioBroker/ioBroker.admin/issues/2420~~
                But it's ok for testers to do direct installations - I did not want to critize you in any way.
                EDIT:
                Just read that you did a refresh.
                Interesting - no idea what happend.
                NOW it is available - at least at my system :-)
                Well, don't think its worth further examination.
                • mcm1957M mcm1957
                  EDIT:
                  W Offline
                  W Offline
                  Wildbill
                  schrieb am zuletzt editiert von Wildbill
                  @mcm1957 sagte in Adapter for Gree and C&H conditioners:
                  Well, as I wrote, I changed to beta, did a manual refreshing (hitting the button you mentioned) but there was no gree adapter visible. So I decided to go the "npm way".
                  I normally am no tester and use stable for all adapters, where it is possible. But I also have no problem to use some versions out of the beta repo or npm, even this is my productive system. Thanks to Proxmox and the snapshot and backup functions I have no problem to go back, if something gets broken. Also, I'm relatively confirm with Linux and know what to do, if something won't work as expected.
                  But yes, normally I also would suggest not to use Github or NPM versions in a productive system (beside you know what you are doing). So no risk, no fun. 😊
                  • I did not want to critize you in any way.
                  I didn't take it that way either. Everything is fine.
                  EDIT: To get fully ONTOPIC:
                  @Serhiy-Krasovskyy I did some tests and all worked as expected. Even changed some values via FHEM and after the polling time the values changed in iobroker as well and vice versa.
                  I got exactly one error in the log since I installed an that was not during some of my tests. I don't know what happend. In FHEM log I got no messages but I even don't know if there get all those things logged.
                  Since then, no more messages, just a working adapter.
                  gree-hvac.0
                  2024-05-24 12:42:43.401	info	Device 502xxxxxx2e9 is responding again
                  gree-hvac.0
                  2024-05-24 12:42:33.366	error	Error in getDeviceStatus for device 502xxxxxx2e9: Error: Request to 192.168.100.101:7000 timed out
                  Serhiy KrasovskyyS 1 Antwort Letzte Antwort
                  • W Wildbill
                    gree-hvac.0
                    gree-hvac.0
                    Serhiy Krasovskyy
                    @wildbill device can't respond by many reasons, for example, my devices stops responding if they don't have internet access.
                    • W Offline
                      W Offline
                      Wildbill
                      @serhiy-krasovskyy Since this one no more errors in log until now. I‘ll keep an eye on it, maybe I can find a reason. Nevertheless, adapter is working as expected. Thanks.
                      • W Offline
                        W Offline
                        Wildbill
                        @Serhiy-Krasovskyy Just a few more errors today, but beside of that, all working fine.
                        I set the interval to 20000, maybe this „filters“ some of the moments, the device isn‘t reachable.
                        gree-hvac.0
                        2024-05-25 10:09:07.227	error	Error in getDeviceStatus for device 502xxxxx52e9: Error: Request to 192.168.100.101:7000 timed out
                        gree-hvac.0
                        2024-05-25 03:29:52.324	error	Error in getDeviceStatus for device 502xxxxx52e9: Error: Request to 192.168.100.101:7000 timed out
                        gree-hvac.0
                        2024-05-25 01:48:15.175	error	Error in getDeviceStatus for device 502xxxxx52e9: Error: Request to 192.168.100.101:7000 timed out
                        gree-hvac.0
                        2024-05-25 00:40:12.990	error	Error in getDeviceStatus for device 502xxxxx52e9: Error: Request to 192.168.100.101:7000 timed out
                        • W Wildbill
                          Serhiy Krasovskyy
                          @wildbill Actually this error is not critical if occurred occasionally. Just informs that didn't receive data in current iteration. For my devices I set request timeout to 5000.
                          P 1 Antwort Letzte Antwort
                            Pixelsolution
                            @serhiy-krasovskyy I ve installed a "U-Match gud50t1" when i am writing to the adapter i always receive time out messages "Error in onStateChange for state gree-hvac.0.c039375c96a6.power: Error: Request to 192.168.x.xxx timed out" any ideas?
                            • P Pixelsolution
                              Pixelsolution
                              @pixelsolution Oh - noticed U-Match isn't supported?
