  4. Iobroker startet nicht mehr nach Restore
59 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • B Bill S. Preston
    @crunchip
    MotionEye deinstalieren funktionier nicht
    herke@raspberrypi:~ $ pip uninstall motioneye
    Found existing installation: motioneye 0.43.1b1
    Uninstalling motioneye-0.43.1b1:
      Would remove:
        /usr/local/bin/meyectl
        /usr/local/bin/motioneye_init
        /usr/local/lib/python3.11/dist-packages/motioneye-0.43.1b1.dist-info/*
        /usr/local/lib/python3.11/dist-packages/motioneye/*
    Proceed (Y/n)? y
    ERROR: Exception:
    Traceback (most recent call last):
      File "/usr/lib/python3.11/shutil.py", line 825, in move
        os.rename(src, real_dst)
    PermissionError: [Errno 13] Permission denied: '/usr/local/bin/meyectl' -> '/tmp/pip-uninstall-eit5jf_4/meyectl'
    During handling of the above exception, another exception occurred:
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
        status = run_func(*args)
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/commands/uninstall.py", line 105, in run
        uninstall_pathset = req.uninstall(
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_install.py", line 727, in uninstall
        uninstalled_pathset.remove(auto_confirm, verbose)
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 380, in remove
        moved.stash(path)
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 271, in stash
        renames(path, new_path)
      File "/usr/local/lib/python3.11/dist-packages/pip/_internal/utils/misc.py", line 358, in renames
        shutil.move(old, new)
      File "/usr/lib/python3.11/shutil.py", line 846, in move
        os.unlink(src)
    und
    Shinobi wird nach der Installation auch nicht erreicht über 192.168.178.68:8080
    herke@raspberrypi:~ $ bash <(curl -s https://gitlab.com/Shinobi-Systems/Shinobi-        Installer/raw/master/shinobi-install.sh)
    Opening Install Location : "/home"
    *Shinobi requires being run as root.
    *Do you want to continue without being root?
    (Y)es or (n)o? Default : Yes
    y
    Install the Development branch?
    (y)es or (N)o? Default : No
    n
    Getting the Master Branch
    Cloning into 'Shinobi'...
    remote: Enumerating objects: 23189, done.
    remote: Counting objects: 100% (148/148), done.
    remote: Compressing objects: 100% (113/113), done.
    remote: Total 23189 (delta 61), reused 78 (delta 35), pack-reused 23041 (from 1)
    Receiving objects: 100% (23189/23189), 16.76 MiB | 11.07 MiB/s, done.
    Resolving deltas: 100% (15552/15552), done.
    fatal: detected dubious ownership in repository at '/home/Shinobi'
    To add an exception for this directory, call:
            git config --global --add safe.directory /home/Shinobi
    ---------- Shinobi Systems ----------
    Repository : https://gitlab.com/Shinobi-Systems/Shinobi
    Product : Shinobi Professional (Pro)
    Branch : master
    Version :
    Date : Tue  7 May 10:20:37 CEST 2024
    Shinobi Installer
    Select your OS
    If your OS is not on the list please refer to the docs.
    1. Ubuntu - Fast and Touchless
    2. Ubuntu - Advanced
    3. Alma Linux 9.2 / Rocky 9 / CentOS 8 - Fast and Touchless (Red Hat)
    4. CentOS
    5. MacOS
    6. FreeBSD
    7. OpenSUSE
    ==!! Shinobi : The Open Source CCTV and NVR Solution !!==
    To answer yes type the letter (y) in lowercase and press ENTER.
    Default is no (N). Skip any components you already have or don't need.
     Detecting Ubuntu Version
     Ubuntu Version: 12
    Shinobi - Do you want to temporarily disable IPv6?
    Sometimes IPv6 causes Ubuntu package updates to fail. Only do this if your machi        ne doesn't rely on IPv6.
    (y)es or (N)o
    y
    net.ipv6.conf.all.disable_ipv6 = 1
    net.ipv6.conf.default.disable_ipv6 = 1
    net.ipv6.conf.lo.disable_ipv6 = 1
    Reading package lists... Done
    gcc is already the newest version (4:12.2.0-3).
    g++ is already the newest version (4:12.2.0-3).
    g++ set to manually installed.
    cmake is already the newest version (3.25.1-1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    update-alternatives: error: alternative path /usr/bin/gcc-8 doesn't exist
    Default Superuser : admin@shinobi.video
    Default Password : admin
    * You can edit these settings in "super.json" located in the Shinobi directory.
    Shinobi - Installing Node.js
    Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
    Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
    Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
    Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
    Get:6 https://apt.grafana.com stable InRelease [7,660 B]
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [153 kB]
    Get:9 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [150 kB]
    Get:10 http://deb.debian.org/debian-security bookworm-security/main Translation-        en [95.1 kB]
    Get:11 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [387 k        B]
    Get:12 https://apt.grafana.com stable/main arm64 Packages [194 kB]
    Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [397 k        B]
    Get:14 https://apt.grafana.com stable/main armhf Packages [171 kB]
    Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [10.7 kB]
    Fetched 1,699 kB in 2s (1,023 kB/s)
    ca-certificates is already the newest version (20230311).
    curl is already the newest version (7.88.1-10+deb12u5).
    gnupg is already the newest version (2.2.40-1.1).
    File '/etc/apt/keyrings/nodesource.gpg' exists. Overwrite? (y/N) n
    Enter new filename: shinobigeil
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    nodejs is already the newest version (18.20.2-1nodesource1).
    make is already the newest version (4.3-4.1).
    make set to manually installed.
    zip is already the newest version (3.0-13).
    FFmpeg Found...
    Version : ffmpeg version 5.1.4-0+rpt3+deb12u1 Copyright (c) 2000-2023 the FFmpeg        developers
    built with gcc 12 (Debian 12.2.0-14)
    configuration: --prefix=/usr --extra-version=0+rpt3+deb12u1 --toolchain=hardened        --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --disa        ble-mmal --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enabl        e-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec        2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetyp        e --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enab        le-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-        libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-libr        ist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr        --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-l        ibtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-lib        vpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable        -libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-ope        nal --enable-opencl --enable-opengl --enable-sand --enable-sdl2 --disable-sndio        --enable-libjxl --enable-neon --enable-v4l2-request --enable-libudev --enable-ep        oxy --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --ena        ble-librsvg --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec        61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo        --enable-librav1e --enable-shared
    libavutil      57. 28.100 / 57. 28.100
    libavcodec     59. 37.100 / 59. 37.100
    libavformat    59. 27.100 / 59. 27.100
    libavdevice    59.  7.100 / 59.  7.100
    libavfilter     8. 44.100 /  8. 44.100
    libswscale      6.  7.100 /  6.  7.100
    libswresample   4.  7.100 /  4.  7.100
    libpostproc    56.  6.100 / 56.  6.100
    Shinobi - Installing MariaDB
    MariaDB will be installed with no password.
    The following additional packages will be installed:
      galera-4 gawk libcgi-fast-perl libcgi-pm-perl libclone-perl
      libconfig-inifiles-perl libdaxctl1 libdbd-mariadb-perl libdbi-perl
      libencode-locale-perl libfcgi-bin libfcgi-perl libfcgi0ldbl libgpm2
      libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl
      libhttp-date-perl libhttp-message-perl libio-html-perl
      liblwp-mediatypes-perl libncurses6 libndctl6 libpmem1 libregexp-ipv6-perl
      libsigsegv2 libterm-readkey-perl libtimedate-perl liburi-perl liburing2 lsof
      mariadb-client mariadb-client-core mariadb-plugin-provider-bzip2
      mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma
      mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy
      mariadb-server-core pv socat
    Suggested packages:
      gawk-doc libmldbm-perl libnet-daemon-perl libsql-statement-perl gpm
      libdata-dump-perl libipc-sharedcache-perl libbusiness-isbn-perl libwww-perl
      mailx mariadb-test netcat-openbsd doc-base
    The following NEW packages will be installed:
      mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server
    0 upgraded, 42 newly installed, 0 to remove and 0 not upgraded.
    Need to get 18.1 MB of archives.
    After this operation, 196 MB of additional disk space will be used.
    Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1        [37.0 kB]
    Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640        kB]
    Get:3 http://deb.debian.org/debian bookworm/main arm64 galera-4 arm64 26.4.13-1        [702 kB]
    Get:4 http://deb.debian.org/debian bookworm/main arm64 libdbi-perl arm64 1.643-4        [767 kB]
    Get:5 http://deb.debian.org/debian bookworm/main arm64 lsof arm64 4.95.0-1 [313        kB]
    Get:6 http://deb.debian.org/debian bookworm/main arm64 libconfig-inifiles-perl a        ll 3.000003-2 [45.9 kB]
    Get:7 http://deb.debian.org/debian bookworm/main arm64 libncurses6 arm64 6.4-4 [        93.9 kB]
    Get:8 http://deb.debian.org/debian bookworm/main arm64 mariadb-client-core arm64        1:10.11.6-0+deb12u1 [846 kB]
    Get:9 http://deb.debian.org/debian bookworm/main arm64 mariadb-client arm64 1:10        .11.6-0+deb12u1 [2,865 kB]
    Get:10 http://deb.debian.org/debian bookworm/main arm64 libdaxctl1 arm64 76.1-1        [19.8 kB]
    Get:11 http://deb.debian.org/debian bookworm/main arm64 libndctl6 arm64 76.1-1 [        57.4 kB]
    Get:12 http://deb.debian.org/debian bookworm/main arm64 libpmem1 arm64 1.12.1-2        [45.7 kB]
    Get:13 http://deb.debian.org/debian bookworm/main arm64 liburing2 arm64 2.3-3 [1        2.6 kB]
    Get:14 http://deb.debian.org/debian bookworm/main arm64 mariadb-server-core arm6        4 1:10.11.6-0+deb12u1 [6,734 kB]
    Get:15 http://deb.debian.org/debian bookworm/main arm64 socat arm64 1.7.4.4-2 [3        66 kB]
    Get:16 http://deb.debian.org/debian bookworm/main arm64 mariadb-server arm64 1:1        0.11.6-0+deb12u1 [3,447 kB]
    Get:17 http://deb.debian.org/debian bookworm/main arm64 libhtml-tagset-perl all        3.20-6 [11.7 kB]
    Get:18 http://deb.debian.org/debian bookworm/main arm64 libregexp-ipv6-perl all        0.03-3 [5,212 B]
    Get:19 http://deb.debian.org/debian bookworm/main arm64 liburi-perl all 5.17-1 [        90.4 kB]
    Get:20 http://deb.debian.org/debian bookworm/main arm64 libhtml-parser-perl arm6        4 3.81-1 [98.6 kB]
    Get:21 http://deb.debian.org/debian bookworm/main arm64 libcgi-pm-perl all 4.55-        1 [220 kB]
    Get:22 http://deb.debian.org/debian bookworm/main arm64 libfcgi0ldbl arm64 2.4.2        -2 [25.3 kB]
    Get:23 http://deb.debian.org/debian bookworm/main arm64 libfcgi-perl arm64 0.82+        ds-2 [24.4 kB]
    Get:24 http://deb.debian.org/debian bookworm/main arm64 libcgi-fast-perl all 1:2        .15-1 [12.1 kB]
    Get:25 http://deb.debian.org/debian bookworm/main arm64 libclone-perl arm64 0.46        -1 [13.5 kB]
    Get:26 http://deb.debian.org/debian bookworm/main arm64 libdbd-mariadb-perl arm6        4 1.22-1+b1 [89.1 kB]
    Get:27 http://deb.debian.org/debian bookworm/main arm64 libencode-locale-perl al        l 1.05-3 [12.9 kB]
    Get:28 http://deb.debian.org/debian bookworm/main arm64 libfcgi-bin arm64 2.4.2-        2 [12.5 kB]
    Get:29 http://deb.debian.org/debian bookworm/main arm64 libgpm2 arm64 1.20.7-10+        b1 [14.4 kB]
    Get:30 http://deb.debian.org/debian bookworm/main arm64 libhtml-template-perl al        l 2.97-2 [66.5 kB]
    Get:31 http://deb.debian.org/debian bookworm/main arm64 libtimedate-perl all 2.3        300-2 [39.3 kB]
    Get:32 http://deb.debian.org/debian bookworm/main arm64 libhttp-date-perl all 6.        05-2 [10.5 kB]
    Get:33 http://deb.debian.org/debian bookworm/main arm64 libio-html-perl all 1.00        4-3 [16.2 kB]
    Get:34 http://deb.debian.org/debian bookworm/main arm64 liblwp-mediatypes-perl a        ll 6.04-2 [20.2 kB]
    Get:35 http://deb.debian.org/debian bookworm/main arm64 libhttp-message-perl all        6.44-1 [81.7 kB]
    Get:36 http://deb.debian.org/debian bookworm/main arm64 libterm-readkey-perl arm        64 2.38-2+b1 [24.1 kB]
    Get:37 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        bzip2 arm64 1:10.11.6-0+deb12u1 [24.9 kB]
    Get:38 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lz4 arm64 1:10.11.6-0+deb12u1 [24.8 kB]
    Get:39 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzma arm64 1:10.11.6-0+deb12u1 [24.9 kB]
    Get:40 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzo arm64 1:10.11.6-0+deb12u1 [24.8 kB]
    Get:41 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        snappy arm64 1:10.11.6-0+deb12u1 [24.9 kB]
    Get:42 http://deb.debian.org/debian bookworm/main arm64 pv arm64 1.6.20-1 [58.6        kB]
    Fetched 18.1 MB in 2s (10.3 MB/s)
    Extracting templates from packages: 100%
    Preconfiguring packages ...
    Selecting previously unselected package libsigsegv2:arm64.
    (Reading database ... 103045 files and directories currently installed.)
    Preparing to unpack .../libsigsegv2_2.14-1_arm64.deb ...
    Unpacking libsigsegv2:arm64 (2.14-1) ...
    Setting up libsigsegv2:arm64 (2.14-1) ...
    Selecting previously unselected package gawk.
    (Reading database ... 103054 files and directories currently installed.)
    Preparing to unpack .../00-gawk_1%3a5.2.1-2_arm64.deb ...
    Unpacking gawk (1:5.2.1-2) ...
    Selecting previously unselected package galera-4.
    Preparing to unpack .../01-galera-4_26.4.13-1_arm64.deb ...
    Unpacking galera-4 (26.4.13-1) ...
    Selecting previously unselected package libdbi-perl:arm64.
    Preparing to unpack .../02-libdbi-perl_1.643-4_arm64.deb ...
    Unpacking libdbi-perl:arm64 (1.643-4) ...
    Selecting previously unselected package lsof.
    Preparing to unpack .../03-lsof_4.95.0-1_arm64.deb ...
    Unpacking lsof (4.95.0-1) ...
    Selecting previously unselected package libconfig-inifiles-perl.
    Preparing to unpack .../04-libconfig-inifiles-perl_3.000003-2_all.deb ...
    Unpacking libconfig-inifiles-perl (3.000003-2) ...
    Selecting previously unselected package libncurses6:arm64.
    Preparing to unpack .../05-libncurses6_6.4-4_arm64.deb ...
    Unpacking libncurses6:arm64 (6.4-4) ...
    Selecting previously unselected package mariadb-client-core.
    Preparing to unpack .../06-mariadb-client-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
    Unpacking mariadb-client-core (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package mariadb-client.
    Preparing to unpack .../07-mariadb-client_1%3a10.11.6-0+deb12u1_arm64.deb ...
    Unpacking mariadb-client (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package libdaxctl1:arm64.
    Preparing to unpack .../08-libdaxctl1_76.1-1_arm64.deb ...
    Unpacking libdaxctl1:arm64 (76.1-1) ...
    Selecting previously unselected package libndctl6:arm64.
    Preparing to unpack .../09-libndctl6_76.1-1_arm64.deb ...
    Unpacking libndctl6:arm64 (76.1-1) ...
    Selecting previously unselected package libpmem1:arm64.
    Preparing to unpack .../10-libpmem1_1.12.1-2_arm64.deb ...
    Unpacking libpmem1:arm64 (1.12.1-2) ...
    Selecting previously unselected package liburing2:arm64.
    Preparing to unpack .../11-liburing2_2.3-3_arm64.deb ...
    Unpacking liburing2:arm64 (2.3-3) ...
    Selecting previously unselected package mariadb-server-core.
    Preparing to unpack .../12-mariadb-server-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
    Unpacking mariadb-server-core (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package socat.
    Preparing to unpack .../13-socat_1.7.4.4-2_arm64.deb ...
    Unpacking socat (1.7.4.4-2) ...
    Selecting previously unselected package mariadb-server.
    Preparing to unpack .../14-mariadb-server_1%3a10.11.6-0+deb12u1_arm64.deb ...
    Unpacking mariadb-server (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package libhtml-tagset-perl.
    Preparing to unpack .../15-libhtml-tagset-perl_3.20-6_all.deb ...
    Unpacking libhtml-tagset-perl (3.20-6) ...
    Selecting previously unselected package libregexp-ipv6-perl.
    Preparing to unpack .../16-libregexp-ipv6-perl_0.03-3_all.deb ...
    Unpacking libregexp-ipv6-perl (0.03-3) ...
    Selecting previously unselected package liburi-perl.
    Preparing to unpack .../17-liburi-perl_5.17-1_all.deb ...
    Unpacking liburi-perl (5.17-1) ...
    Selecting previously unselected package libhtml-parser-perl:arm64.
    Preparing to unpack .../18-libhtml-parser-perl_3.81-1_arm64.deb ...
    Unpacking libhtml-parser-perl:arm64 (3.81-1) ...
    Selecting previously unselected package libcgi-pm-perl.
    Preparing to unpack .../19-libcgi-pm-perl_4.55-1_all.deb ...
    Unpacking libcgi-pm-perl (4.55-1) ...
    Selecting previously unselected package libfcgi0ldbl:arm64.
    Preparing to unpack .../20-libfcgi0ldbl_2.4.2-2_arm64.deb ...
    Unpacking libfcgi0ldbl:arm64 (2.4.2-2) ...
    Selecting previously unselected package libfcgi-perl.
    Preparing to unpack .../21-libfcgi-perl_0.82+ds-2_arm64.deb ...
    Unpacking libfcgi-perl (0.82+ds-2) ...
    Selecting previously unselected package libcgi-fast-perl.
    Preparing to unpack .../22-libcgi-fast-perl_1%3a2.15-1_all.deb ...
    Unpacking libcgi-fast-perl (1:2.15-1) ...
    Selecting previously unselected package libclone-perl:arm64.
    Preparing to unpack .../23-libclone-perl_0.46-1_arm64.deb ...
    Unpacking libclone-perl:arm64 (0.46-1) ...
    Selecting previously unselected package libdbd-mariadb-perl.
    Preparing to unpack .../24-libdbd-mariadb-perl_1.22-1+b1_arm64.deb ...
    Unpacking libdbd-mariadb-perl (1.22-1+b1) ...
    Selecting previously unselected package libencode-locale-perl.
    Preparing to unpack .../25-libencode-locale-perl_1.05-3_all.deb ...
    Unpacking libencode-locale-perl (1.05-3) ...
    Selecting previously unselected package libfcgi-bin.
    Preparing to unpack .../26-libfcgi-bin_2.4.2-2_arm64.deb ...
    Unpacking libfcgi-bin (2.4.2-2) ...
    Selecting previously unselected package libgpm2:arm64.
    Preparing to unpack .../27-libgpm2_1.20.7-10+b1_arm64.deb ...
    Unpacking libgpm2:arm64 (1.20.7-10+b1) ...
    Selecting previously unselected package libhtml-template-perl.
    Preparing to unpack .../28-libhtml-template-perl_2.97-2_all.deb ...
    Unpacking libhtml-template-perl (2.97-2) ...
    Selecting previously unselected package libtimedate-perl.
    Preparing to unpack .../29-libtimedate-perl_2.3300-2_all.deb ...
    Unpacking libtimedate-perl (2.3300-2) ...
    Selecting previously unselected package libhttp-date-perl.
    Preparing to unpack .../30-libhttp-date-perl_6.05-2_all.deb ...
    Unpacking libhttp-date-perl (6.05-2) ...
    Selecting previously unselected package libio-html-perl.
    Preparing to unpack .../31-libio-html-perl_1.004-3_all.deb ...
    Unpacking libio-html-perl (1.004-3) ...
    Selecting previously unselected package liblwp-mediatypes-perl.
    Preparing to unpack .../32-liblwp-mediatypes-perl_6.04-2_all.deb ...
    Unpacking liblwp-mediatypes-perl (6.04-2) ...
    Selecting previously unselected package libhttp-message-perl.
    Preparing to unpack .../33-libhttp-message-perl_6.44-1_all.deb ...
    Unpacking libhttp-message-perl (6.44-1) ...
    Selecting previously unselected package libterm-readkey-perl.
    Preparing to unpack .../34-libterm-readkey-perl_2.38-2+b1_arm64.deb ...
    Unpacking libterm-readkey-perl (2.38-2+b1) ...
    Selecting previously unselected package mariadb-plugin-provider-bzip2.
    Preparing to unpack .../35-mariadb-plugin-provider-bzip2_1%3a10.11.6-0+deb12u1_a        rm64.deb ...
    Unpacking mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package mariadb-plugin-provider-lz4.
    Preparing to unpack .../36-mariadb-plugin-provider-lz4_1%3a10.11.6-0+deb12u1_arm        64.deb ...
    Unpacking mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package mariadb-plugin-provider-lzma.
    Preparing to unpack .../37-mariadb-plugin-provider-lzma_1%3a10.11.6-0+deb12u1_ar        m64.deb ...
    Unpacking mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package mariadb-plugin-provider-lzo.
    Preparing to unpack .../38-mariadb-plugin-provider-lzo_1%3a10.11.6-0+deb12u1_arm        64.deb ...
    Unpacking mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package mariadb-plugin-provider-snappy.
    Preparing to unpack .../39-mariadb-plugin-provider-snappy_1%3a10.11.6-0+deb12u1_        arm64.deb ...
    Unpacking mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
    Selecting previously unselected package pv.
    Preparing to unpack .../40-pv_1.6.20-1_arm64.deb ...
    Unpacking pv (1.6.20-1) ...
    Setting up libconfig-inifiles-perl (3.000003-2) ...
    Setting up galera-4 (26.4.13-1) ...
    Setting up libgpm2:arm64 (1.20.7-10+b1) ...
    Setting up libfcgi0ldbl:arm64 (2.4.2-2) ...
    Setting up gawk (1:5.2.1-2) ...
    Setting up libclone-perl:arm64 (0.46-1) ...
    Setting up libhtml-tagset-perl (3.20-6) ...
    Setting up liblwp-mediatypes-perl (6.04-2) ...
    Setting up libfcgi-bin (2.4.2-2) ...
    Setting up libencode-locale-perl (1.05-3) ...
    Setting up socat (1.7.4.4-2) ...
    Setting up libncurses6:arm64 (6.4-4) ...
    Setting up libio-html-perl (1.004-3) ...
    Setting up libdaxctl1:arm64 (76.1-1) ...
    Setting up lsof (4.95.0-1) ...
    Setting up libtimedate-perl (2.3300-2) ...
    Setting up libregexp-ipv6-perl (0.03-3) ...
    Setting up pv (1.6.20-1) ...
    Setting up libndctl6:arm64 (76.1-1) ...
    Setting up libfcgi-perl (0.82+ds-2) ...
    Setting up libterm-readkey-perl (2.38-2+b1) ...
    Setting up liburing2:arm64 (2.3-3) ...
    Setting up libpmem1:arm64 (1.12.1-2) ...
    Setting up liburi-perl (5.17-1) ...
    Setting up libdbi-perl:arm64 (1.643-4) ...
    Setting up libhttp-date-perl (6.05-2) ...
    Setting up mariadb-client-core (1:10.11.6-0+deb12u1) ...
    Setting up libdbd-mariadb-perl (1.22-1+b1) ...
    Setting up libhtml-parser-perl:arm64 (3.81-1) ...
    Setting up mariadb-server-core (1:10.11.6-0+deb12u1) ...
    Setting up libhttp-message-perl (6.44-1) ...
    Setting up mariadb-client (1:10.11.6-0+deb12u1) ...
    Setting up libcgi-pm-perl (4.55-1) ...
    Setting up libhtml-template-perl (2.97-2) ...
    Setting up mariadb-server (1:10.11.6-0+deb12u1) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /l        ib/systemd/system/mariadb.service.
    Setting up mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
    Setting up mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
    Setting up mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
    Setting up mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
    Setting up libcgi-fast-perl (1:2.15-1) ...
    Setting up mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
    Processing triggers for man-db (2.11.2-2) ...
    Processing triggers for libc-bin (2.36-9+rpt2+deb12u6) ...
    Processing triggers for mariadb-server (1:10.11.6-0+deb12u1) ...
    Shinobi - Installing Database...
    Shinobi - Install NPM Libraries
    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#dep        recated
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprec        ated
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
    npm WARN deprecated @discordjs/form-data@3.0.1: Package no longer supported. Con        tact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated @discordjs/collection@0.1.6: no longer supported
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
    npm WARN deprecated discord.js@12.2.0: no longer supported
    added 762 packages, and audited 763 packages in 1m
    45 packages are looking for funding
      run `npm fund` for details
    18 vulnerabilities (16 moderate, 2 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    npm notice
    npm notice New minor version of npm available! 10.5.0 -> 10.7.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.7.0
    npm notice Run npm install -g npm@10.7.0 to update!
    npm notice
    Shinobi - Install PM2
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    added 162 packages in 18s
    14 packages are looking for funding
    Shinobi - Finished
    dos2unix: converting file INSTALL/shinobi to Unix format...
    Shinobi - Randomizing cron key
    addToConfig: [object Object]
    Changes Complete. Here is what it is now.
      "port": 8080,
      "debugLog": false,
      "enableFaceManager": false,
      "videosDir": "__DIR__/videos",
      "passwordType": "sha256",
      "detectorMergePamRegionTriggers": true,
      "wallClockTimestampAsDefault": true,
      "useBetterP2P": true,
      "smtpServerOptions": {
        "allowInsecureAuth": true
      "addStorage": [
          "name": "second",
          "path": "__DIR__/videos2"
      "db": {
        "host": "127.0.0.1",
        "user": "majesticflame",
        "password": "",
        "database": "ccio",
        "port": 3306
      "mail": {
        "service": "gmail",
        "auth": {
          "user": "your_email@gmail.com",
          "pass": "your_password_or_app_specific_password"
      "cron": {
        "key": "09e6aa3f65ca6ef81d120889f44dec94e8efc9d92c90615f26a06177af5a"
      "pluginKeys": {}
    Shinobi - Starting Shinobi and setting to start on boot
    __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
     _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
      _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
       _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
        _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
         _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
          _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
           _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
            _\///______________\///______________\///__\///////////////__
                              Runtime Edition
            PM2 is a Production Process Manager for Node.js applications
                         with a built-in Load Balancer.
                    Start and Daemonize any application:
                    $ pm2 start app.js
                    Load Balance 4 instances of api.js:
                    $ pm2 start api.js -i 4
                    Monitor in production:
                    $ pm2 monitor
                    Make pm2 auto-boot at server restart:
                    $ pm2 startup
                    To go further checkout:
                    http://pm2.io/
    [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
    [PM2] PM2 Successfully daemonized
    [PM2] Starting /home/Shinobi/camera.js in fork_mode (1 instance)
    [PM2] Done.
    │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
    │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 0s     │ 0    │ online    │ 0%       │ 38.8mb   │ root     │ disabled │
    [PM2] Init System found: systemd
    Platform systemd
    Template
    [Unit]
    Description=PM2 process manager
    Documentation=https://pm2.keymetrics.io/
    After=network.target
    [Service]
    Type=forking
    User=root
    LimitNOFILE=infinity
    LimitNPROC=infinity
    LimitCORE=infinity
    Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
    Environment=PM2_HOME=/root/.pm2
    PIDFile=/root/.pm2/pm2.pid
    Restart=on-failure
    ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
    ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
    ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
    [Install]
    WantedBy=multi-user.target
    Target path
    /etc/systemd/system/pm2-root.service
    Command list
    [ 'systemctl enable pm2-root' ]
    [PM2] Writing init configuration in /etc/systemd/system/pm2-root.service
    [PM2] Making script booting at startup...
    [PM2] [-] Executing: systemctl enable pm2-root...
    Created symlink /etc/systemd/system/multi-user.target.wants/pm2-root.service → /etc/systemd/system/pm2-root.service.
    [PM2] [v] Command successfully executed.
    [PM2] Freeze a process list on reboot via:
    $ pm2 save
    [PM2] Remove init script via:
    $ pm2 unstartup systemd
    [PM2] Saving current process list...
    [PM2] Successfully saved in /root/.pm2/dump.pm2
    │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 4s     │ 0    │ online    │ 0%       │ 111.5mb  │ root     │ disabled │
    ||=====   Install Completed   =====||
    || Login with the Superuser and create a new user!!
    || Open http://192.168.178.68:8080/super in your web browser.
    System nochmal neu aufsetzen? Da ist doch was faul
    crunchipC Offline
    crunchipC Offline
    @bill-s-preston dann mach mal ein
    sudo pip....
      sudo pip....
      Bill S. Preston
      @crunchip said in Iobroker startet nicht mehr nach Restore:
      sudo pip....
      herke@raspberrypi:~ $ sudo pip
      Usage:
        pip <command> [options]
      Commands:
        install                     Install packages.
        download                    Download packages.
        uninstall                   Uninstall packages.
        freeze                      Output installed packages in requirements format.
        inspect                     Inspect the python environment.
        list                        List installed packages.
        show                        Show information about installed packages.
        check                       Verify installed packages have compatible dependen        cies.
        config                      Manage local and global configuration.
        search                      Search PyPI for packages.
        cache                       Inspect and manage pip's wheel cache.
        index                       Inspect information available from package indexes        .
        wheel                       Build wheels from your requirements.
        hash                        Compute hashes of package archives.
        completion                  A helper command used for command completion.
        debug                       Show information useful for debugging.
        help                        Show help for commands.
      General Options:
        -h, --help                  Show help.
        --debug                     Let unhandled exceptions propagate outside the
                                    main subroutine, instead of logging them to
                                    stderr.
        --isolated                  Run pip in an isolated mode, ignoring
                                    environment variables and user configuration.
        --require-virtualenv        Allow pip to only run in a virtual environment;
                                    exit with an error otherwise.
        --python <python>           Run pip with the specified Python interpreter.
        -v, --verbose               Give more output. Option is additive, and can be
                                    used up to 3 times.
        -V, --version               Show version and exit.
        -q, --quiet                 Give less output. Option is additive, and can be
                                    used up to 3 times (corresponding to WARNING,
                                    ERROR, and CRITICAL logging levels).
        --log <path>                Path to a verbose appending log.
        --no-input                  Disable prompting for input.
        --keyring-provider <keyring_provider>
                                    Enable the credential lookup via the keyring
                                    library if user input is allowed. Specify which
                                    mechanism to use [disabled, import, subprocess].
                                    (default: disabled)
        --proxy <proxy>             Specify a proxy in the form
                                    scheme://[user:passwd@]proxy.server:port.
        --retries <retries>         Maximum number of retries each connection should
                                    attempt (default 5 times).
        --timeout <sec>             Set the socket timeout (default 15 seconds).
        --exists-action <action>    Default action when a path already exists:
                                    (s)witch, (i)gnore, (w)ipe, (b)ackup, (a)bort.
        --trusted-host <hostname>   Mark this host or host:port pair as trusted,
                                    even though it does not have valid or any HTTPS.
        --cert <path>               Path to PEM-encoded CA certificate bundle. If
                                    provided, overrides the default. See 'SSL
                                    Certificate Verification' in pip documentation
                                    for more information.
        --client-cert <path>        Path to SSL client certificate, a single file
                                    containing the private key and the certificate
                                    in PEM format.
        --cache-dir <dir>           Store the cache data in <dir>.
        --no-cache-dir              Disable the cache.
        --disable-pip-version-check
                                    Don't periodically check PyPI to determine
                                    whether a new version of pip is available for
                                    download. Implied with --no-index.
        --no-color                  Suppress colored output.
        --no-python-version-warning
                                    Silence deprecation warnings for upcoming
                                    unsupported Pythons.
        --use-feature <feature>     Enable new functionality, that may be backward
                                    incompatible.
        --use-deprecated <feature>  Enable deprecated functionality, that will be
                                    removed in the future.
        @bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
        motioneye.service loaded failed failed
        So viel ich weiß, müssen ggf Ports angepasst werden um Motioneye und iobroker zusammen auf einen Rechner laufen zu lassen
        Unabhängig davon, reichen 4GB RAM da eh nicht aus
        crunchipC Offline
        crunchipC Offline
        @crunchip sagte in Iobroker startet nicht mehr nach Restore:
        @Bill-S-Preston
        Wollt ich noch mal anmerken
        Da auch noch Influx und Grafana laufen
        • B Bill S. Preston
          sudo pip....
          Usage:
          Commands:
          General Options:
                                        stderr.
                                        used up to 3 times.
                                        (default: disabled)
                                        in PEM format.
                                        incompatible.
          crunchipC Offline
          crunchipC Offline
          @bill-s-preston natürlich das ganze Kommando, hatte nur abgekürzt, da ich am Handy tippe
            @Bill-S-Preston
            Bill S. Preston
            @crunchip
            Ein neuer Pi4 mit 8GB und M2 SSD wird heute geliefert.
            Da werde ich dann nochmal komplett neu anfangen
              Bill S. Preston
              Du meinst
              sudo pip uninstall
              • B Bill S. Preston
                Du meinst
                sudo pip uninstall
                crunchipC Offline
                crunchipC Offline
                @bill-s-preston ja, dein motioneye
                  Bill S. Preston
                  @crunchip
                  herke@raspberrypi:~ $ sudo pip uninstall motioneye
                    Would remove:
                  Proceed (Y/n)? y
                    Successfully uninstalled motioneye-0.43.1b1
                  WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
                  Hat geklappt
                    Bill S. Preston
                    Wie deinstalliere ich Shinobi?
                    herke@raspberrypi:~ $ sudo pip uninstall shinobi
                    WARNING: Skipping shinobi as it is not installed.
                    So ging es nicht
                    • B Bill S. Preston
                      So ging es nicht
                      Dazu gibt es eine umfangreiche Anleitung auf deren Seite.
                      • B Bill S. Preston
                        So ging es nicht
                        crunchipC Offline
                        crunchipC Offline
                        @bill-s-preston liest du dich nicht vorher ein?
                        https://docs.shinobi.video/system/uninstall
                          Bill S. Preston
                          remove nodejs ???
                          sudo npm uninstall pm2 -g
                          sudo apt remove nodejs -y && sudo apt autoremove -y
                          Nicht gut oder?
                          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                          • B Bill S. Preston
                            remove nodejs ???
                            Nicht gut oder?
                            crunchipC Offline
                            crunchipC Offline
                            @bill-s-preston du darfst nicht stur nach der Anleitung gehen
                            Nodejs brauchst du ja
                            • B Bill S. Preston
                              remove nodejs ???
                              Nicht gut oder?
                              Nicht gut oder?
                              Nein, nicht gut, wenn nodejs noch für andere Dinge (wie den ioBroker) notwendig ist.
                              Solche Anleitungen sind immer noch an die Gegebenheiten auf dem eigenen System anzupassen.
