  4. Alias alias.0.O-DTU-Power.power has no target 8
50 Beiträge 3 Kommentatoren 5.6k Aufrufe 1 Beobachtet
  • L Laser
    @Homoran Habe auf "debug" gestellt. Da kommen noch einige Meldungen mehr. Da muß ich aber erst mal sehen, was das Alles bedeutet!
    Ein kleiner Auszug:
    web.0
    2024-05-03 18:57:35.590	debug	2024-05-03T16:57:35.589Z Request authenticate [system.user.admin]
    web.0
    2024-05-03 18:57:35.586	debug	2024-05-03T16:57:35.586Z Request authenticate [system.user.admin]
    web.0
    2024-05-03 18:57:35.553	debug	2024-05-03T16:57:35.553Z Request authenticate [system.user.admin]
    web.0
    2024-05-03 18:57:34.799	debug	Subscribes: vis-2.0.info.uploaded, vis-2.0.control.instance, vis-2.0.control.data, vis-2.0.control.command, hm-rpc.1.PEQ1630804.4.ACTUAL_TEMPERATURE, hm-rpc.1.PEQ1630804.4.VALVE_STATE, shelly.1.SHSW-25#3C6105E462D5#1.Shutter.Energy, echarts.0.ArbeitszimmerChart, owfs.0.wires.Aussentemperatur, hm-rpc.1.REQ0839212.4.VALVE_STATE, hm-rpc.1.PEQ1630804.4.CONTROL_MODE, hm-rpc.1.REQ0839212.4.CONTROL_MODE, hm-rpc.1.PEQ1630804.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.ACTUAL_TEMPERATURE, opendtu.0.112183225956.ac.phase_1.power, opendtu.0.112183227304.ac.phase_1.power, opendtu.0.total.yieldtotal, opendtu.0.112183225956.dc.input_1.yieldday, opendtu.0.112183227304.dc.input_1.yieldday, opendtu.0.112183225956.dc.input_1.yieldtotal, opendtu.0.112183818346.dc.input_1.yieldday, opendtu.0.112183818346.dc.input_1.yieldtotal, opendtu.0.112183818346.ac.phase_1.power, 0_userdata.0.variables.DP-kWh-ges-solar, alias.0.ShellyEM3Power.Power1EM3, alias.0.ShellyEM3Power.Power0EM3, alias.0.ShellyEM3Power.Power2EM3, vedirect.0.V, vedirect.0.I, vedirect.0.PPV, 0_userdata.0.variables.DP-kW-ges-Zaehler, opendtu.0.total.power, sourceanalytix.0.alias__0__VE-Total__H19.cumulativeReading, alias.0.ZaehlerET.zaehler-Watt, rpi2.0.gpio.12.state, rpi2.0.gpio.16.state, javascript.0.scriptEnabled.Heizung.BoilerHeizen
    web.0
    2024-05-03 18:57:34.798	debug	Subscribes: vis-2.0.info.uploaded, vis-2.0.control.instance, vis-2.0.control.data, vis-2.0.control.command, hm-rpc.1.PEQ1630804.4.ACTUAL_TEMPERATURE, hm-rpc.1.PEQ1630804.4.VALVE_STATE, shelly.1.SHSW-25#3C6105E462D5#1.Shutter.Energy, echarts.0.ArbeitszimmerChart, owfs.0.wires.Aussentemperatur, hm-rpc.1.REQ0839212.4.VALVE_STATE, hm-rpc.1.PEQ1630804.4.CONTROL_MODE, hm-rpc.1.REQ0839212.4.CONTROL_MODE, hm-rpc.1.PEQ1630804.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.ACTUAL_TEMPERATURE, opendtu.0.112183225956.ac.phase_1.power, opendtu.0.112183227304.ac.phase_1.power, opendtu.0.total.yieldtotal, opendtu.0.112183225956.dc.input_1.yieldday, opendtu.0.112183227304.dc.input_1.yieldday, opendtu.0.112183225956.dc.input_1.yieldtotal, opendtu.0.112183818346.dc.input_1.yieldday, opendtu.0.112183818346.dc.input_1.yieldtotal, opendtu.0.112183818346.ac.phase_1.power, 0_userdata.0.variables.DP-kWh-ges-solar, alias.0.ShellyEM3Power.Power1EM3, alias.0.ShellyEM3Power.Power0EM3, alias.0.ShellyEM3Power.Power2EM3, vedirect.0.V, vedirect.0.I, vedirect.0.PPV, 0_userdata.0.variables.DP-kW-ges-Zaehler, opendtu.0.total.power, sourceanalytix.0.alias__0__VE-Total__H19.cumulativeReading, alias.0.ZaehlerET.zaehler-Watt, rpi2.0.gpio.12.state, rpi2.0.gpio.16.state
    @laser sagte in Alias alias.0.O-DTU-Power.power has no target 8:
    wir auch!
    • L Laser
      Ein kleiner Auszug:
      web.0
      web.0
      web.0
      web.0
      web.0
      @laser
      Danke fürs EDIT!
      da ist aber noch kein alias Error. nur ganz normale Meldungen.
      Das einzig interessante ist dass du mit vis2 arbeitest
      L 1 Antwort Letzte Antwort
        @laser
        Danke fürs EDIT!
        Laser
        @homoran Das waren ja auch nur Warnmeldungen, die mich zumüllen!
        • L Laser
          Warnungen, dass es einen Fehler mit deinem Alias gibt
            Laser
            @homoran Den Alias hatte ich je gelöscht und neu angelegt. Den Alias mit:
             web.0 2024-05-03 19:04:32.073	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
            habe ich komplett gelöscht. Den frage ich auch nicht ab.
            • L Laser
              aber irgendwas greift darauf zu
              wie sieht der alias aus?
              Objektdaten!
                Objektdaten!
                Laser
                schrieb am zuletzt editiert von Laser
                @homoran Muß ja. Aber was?
                EDIT: diese beiden Aliasse gibt es ja nicht mehr!
                • L Laser
                  sag du es uns!
                  immer noch keine Meldung im web?
                  statt im Sekundentakt
                    sag du es uns!
                    Laser
                    @homoran Den Level habe ich wieder auf "warn" gestellt. (iob Restart.) Waren ja die Warnmeldungen, die mich gestört haben. Zur Zeit kommt keine Warnmeldung. Ich rufe jetzt jede View einzeln auf, um zu sehen, ob eine Meldung kommt. Bisher nichts von diesen beiden Meldungen. Dafür wieder etwas Anders (Eine Quelle, die ich gelöscht habe). Diesen Fehler beseitige ich gleich. Wenn ich eine bestimmte View aufrufe, kommt eine Meldung von: Alias alias.0.O-DTU-Power.power has no target 8
                    Das ist schon mal ein Ansatz!
                    • L Laser
                      Wenn ich eine bestimmte View aufrufe, kommt eine Meldung. Das ist schon mal ein Ansatz!
                      ja
                        ja
                        Laser
                        @homoran Ich möchte Dich heute nicht weiter nerven und suche erst mal in dieser Richtung weiter! (Es ist etwas in einem E-Chart. Ich glaube, ich habe noch einige Leichen im Keller!). Danke, daß Ihr mir auf die Sprünge geholfen habt!
                        • L Laser
                          Laser
                          @Homoran @mickym Es war tatsächlich der E-Chart, welchen ich als kleines Bild in einem View eingebettet hatte. Dort drin war ein Verweis auf einen gelöschten Alias. Durch die Winzigkeit hatte ich nicht gesehen, daß kein Wert vorhanden war. Außerdem war die Kurve von diesem Alias für mich uninteressant.
                          Jetzt geht es an die nächsten Warnmeldungen...
