  4. Update von Telegram und Alexa2 führt zu Fehler
19 Beiträge 7 Kommentatoren 2.0k Aufrufe 5 Beobachtet
  • J Jup_HX
    Hier die Langfassung:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    model name	: Intel(R) Core(TM) i5-4250U CPU @ 1.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     17:13:56 up 112 days, 17:30,  3 users,  load average: 0.84, 0.57, 0.64
    CPU threads: 4
    *** Time and Time Zones ***
    Failed to query server: Connection timed out
    *** User and Groups ***
    thorsten
    /home/thorsten
    thorsten sudo iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal:
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            6.4G        2.1G        3.4G         45K        1.0G        4.4G
    Swap:           4.3G         13M        4.3G
    Total:           10G        2.1G        7.6G
             6144 M total memory
             1959 M used memory
              493 M active memory
             2205 M inactive memory
             3203 M free memory
                0 M buffer memory
              980 M swap cache
             4096 M total swap
               13 M used swap
             4082 M free swap
    *** FAILED SERVICES ***
      UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount      loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount   loaded failed failed Kernel Configuration File System
    * logrotate.service         loaded failed failed Rotate log files
    * man-db.service            loaded failed failed Daily man-db regeneration
    * systemd-hostnamed.service loaded failed failed Hostname Service
    * systemd-logind.service    loaded failed failed User Login Management
    * systemd-timedated.service loaded failed failed Time & Date Service
    7 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       30G  9.4G   19G  34% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G   88K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.9G	/var/
    1.1G	/var/log
    975M	/var/log/journal/1942570c893249e8b5e5f9a3f5b1745b
    576M	/var/cache
    Archived and active journals take up 106.7M in the file system.
    /opt/iobroker/backups:
    2.0G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    474M	/opt/iobroker/iobroker-data/
    306M	/opt/iobroker/iobroker-data/files
    109M	/opt/iobroker/iobroker-data/backup-objects
    57M	/opt/iobroker/iobroker-data/files/javascript.admin
    45M	/opt/iobroker/iobroker-data/files/devices.admin/static
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M	/opt/iobroker/iobroker-data/objects.jsonl
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.12.2
    /usr/bin/node 		v20.12.2
    /usr/bin/npm 		10.5.0
    /usr/bin/npx 		10.5.0
    /usr/bin/corepack 	0.25.2
    nodejs:
      Installed: 20.12.2-1nodesource1
      Candidate: 20.12.2-1nodesource1
      Version table:
     *** 20.12.2-1nodesource1 500
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.12.1-1nodesource1 500
         20.12.0-1nodesource1 500
         20.11.1-1nodesource1 500
         20.11.0-1nodesource1 500
         20.10.0-1nodesource1 500
         20.9.0-1nodesource1 500
         20.8.1-1nodesource1 500
         20.8.0-1nodesource1 500
         20.7.0-1nodesource1 500
         20.6.1-1nodesource1 500
         20.6.0-1nodesource1 500
         20.5.1-1nodesource1 500
         20.5.0-1nodesource1 500
         20.4.0-1nodesource1 500
         20.3.1-1nodesource1 500
         20.3.0-1nodesource1 500
         20.2.0-1nodesource1 500
         20.1.0-1nodesource1 500
         20.0.0-1nodesource1 500
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	7.8.0
    Adapters from github: 	2
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.psa.0                    : psa                   : iobroker                                 - disabled
      system.adapter.psa.1                    : psa                   : iobroker                                 - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
      system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "psa"          : 0.0.11   , installed 0.0.11
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects: 	16930
    States: 	14891
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        471677702  132/influxd
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       1064786022 611149/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1064786021 611149/io.mqtt.0
    tcp        0      0 127.0.0.1:37931         0.0.0.0:*               LISTEN      1000       1064790494 611717/io.yahka.0
    tcp        0      0 10.10.10.10:2010        0.0.0.0:*               LISTEN      1000       1064788392 611401/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1064782154 610907/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1064783272 610907/iobroker.js-
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       1064790872 611818/io.jarvis.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          766916284  286454/master
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          471678077  159/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          471674796  1/systemd
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        471679201  132/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1064794285 612151/io.simple-ap
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1064784166 610928/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1064792179 611753/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          766916285  286454/master
    tcp6       0      0 :::45203                :::*                    LISTEN      1000       1064789621 611717/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          471678079  159/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          471674798  1/systemd
    udp        0      0 0.0.0.0:52232           0.0.0.0:*                           1000       1064792748 611971/io.broadlink
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          471674797  1/systemd
    udp        0      0 10.10.10.10:123         0.0.0.0:*                           0          766917331  286563/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          766917329  286563/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          766916506  286563/ntpd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1064789622 611717/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1064785222 611178/io.shelly.0
    udp        0      0 0.0.0.0:43150           0.0.0.0:*                           1000       1064793401 611971/io.broadlink
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       1064792591 611971/io.broadlink
    udp6       0      0 :::111                  :::*                                0          471674799  1/systemd
    udp6       0      0 2003:f3:4703:b800:1:123 :::*                                113        1014880858 286563/ntpd
    udp6       0      0 fe80::10ec:11ff:fe7:123 :::*                                0          766917337  286563/ntpd
    udp6       0      0 ::1:123                 :::*                                0          766917333  286563/ntpd
    udp6       0      0 :::123                  :::*                                0          766917325  286563/ntpd
    2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
    2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
    2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18) {
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]: }
    2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]: Node.js v20.12.2
    2024-04-19 17:14:52.483  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-19 17:14:52.483  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
    @jup_hx sagte in Update von Telegram und Alexa2 führt zu Fehler:
    Wassen da mit deinem Container los?
    mcm1957M J 2 Antworten Letzte Antwort
      mcm1957M Online
      mcm1957M Online
      mcm1957
      Es gab heute kurze Zeit (ca 30 Minuten) ein fehlerhaftes Downloadpaket. Durch eine Neuinstallation bzw ein Update eines Adapters sollte der Fehler automatisch behoben werden.
      Bitte diesbezügliche Diskussion primär in diesem Topic führen um Parallelitäten zu minimieren.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        Jup_HX
        @mcm57
        Vielen Dank für die Info. Da war ich wohl "zum falschen Zeitpunkt am falschen Ort". Nach Neuinstallation läuft wieder alles wie gewohnt!
        H 1 Antwort Letzte Antwort
          Jup_HX
          @thomas-braun Ich habe keine Ahnung. Muss ich mir mal anschauen. Hast Du einen Tipp für mich, wo ich da ansetzen könnte?
          • J Jup_HX
            Von Containern hab ich keine Ahnung. Schaut aber komisch aus.
            • J Jup_HX
              @mcm57
              Henny112
              @mcm57
              Habe auch alles neu gemacht läuft wieder. Bis auf ein Backup vom Conbee war etwas alt das hat ein wenig Arbeit gemacht.
              • H Henny112
                @mcm57
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Für das zugrundeliegende Problem gibts nun einen eigenen Topic mit Erläuterung. Falls noch wer Hilfe braucht bitte dort melden:
                https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
                • W Offline
                  W Offline
                  Wolhem
                  Bei mir läuft nach updates auch Alexa, telegram und zigbee nicht mehr.```
                  Bildschirmfoto vom 2024-04-21 12-29-35.png code_text
                  • W Wolhem
                    @wolhem
                    Bitte das LogFile als TEXT in CodeTags eingebettet posten. Und in richtiger zeitlicher Abfolge.
                    Und zuvor das versuchen:
                    https://forum.iobroker.net/topic/74238/lösung-für-fehler-typeerror-err_invalid_arg_value
                    W 1 Antwort Letzte Antwort
                    • W Wolhem
                      @wolhem ein Bild in code-tags setzen macht daraus keinen Text 😁
                      BTW
                        @wolhem
                        W Offline
                        W Offline
                        Wolhem
                        Bei allen dreien finde ich den 3.1.2
                        • W Wolhem
                          @wolhem sagte in Update von Telegram und Alexa2 führt zu Fehler:
                          Das ist schön. Dann hast du den Fehler ja gefunden. Fix wie oben.
                            W Offline
                            W Offline
                            Wolhem
                            @thomas-braun Supi, läuft wieder👍 👍 👍
                            • W Offline
                              W Offline
                              Wolhem
                              Weißt du vielleicht wodurch Funk-Rolladenmotoren gestört werden können?
                              • W Wolhem
                                durch Funkstörungen 😁
                                Was genau willst du wissen?
