  4. JavaScript
  5. maximum of 1000 setState during boot
    6.8k
53 Beiträge 13 Kommentatoren 7.9k Aufrufe 10 Beobachtet
  • P Offline
    peterfido
    @hschief
    ich habe das Testskript auf meinem zweiten iobroker getestet. Keine mehrfachen Aufrufe beim Start zu entdecken.
    2024-04-17 19:40:51.936 - info: javascript.0 (706) starting. Version 7.8.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.20.2, js-controller: 5.0.19
    2024-04-17 19:40:52.184 - info: javascript.0 (706) requesting all states
    2024-04-17 19:40:52.185 - info: javascript.0 (706) requesting all objects
    2024-04-17 19:40:52.446 - info: javascript.0 (706) received all objects
    2024-04-17 19:40:52.493 - info: javascript.0 (706) received all states
    2024-04-17 19:40:52.574 - info: javascript.0 (706) Start javascript script.js.Scripte.CronJobs
    2024-04-17 19:40:52.590 - error: javascript.0 (706) script.js.Scripte.CronJobs: Script Test1 aufgerufen
    2024-04-17 19:40:52.606 - info: javascript.0 (706) script.js.Scripte.CronJobs: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    2024-04-17 19:40:55.160 - info: host.iob instance system.adapter.simple-api.0 started with pid 721
    2024-04-17 19:40:55.593 - info: simple-api.0 (721) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.2, js-controller: 5.0.19
    2024-04-17 19:40:55.599 - warn: simple-api.0 (721) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2024-04-17 19:40:55.600 - info: simple-api.0 (721) simpleAPI server listening on port 8087
    2024-04-17 19:40:55.601 - info: simple-api.0 (721) Allow states only when user is owner: false
    2024-04-17 19:40:55.603 - info: simple-api.0 (721) http server listening on port 8087
    2024-04-17 19:40:59.155 - info: host.iob instance system.adapter.socketio.0 started with pid 736
    2024-04-17 19:40:59.643 - info: socketio.0 (736) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.20.2, js-controller: 5.0.19
    2024-04-17 19:40:59.652 - warn: socketio.0 (736) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2024-04-17 19:40:59.664 - info: socketio.0 (736) socket.io server listening on port 8088
    2024-04-17 19:41:00.005 - error: javascript.0 (706) script.js.Scripte.CronJobs: In Function
    2024-04-17 19:41:10.002 - error: javascript.0 (706) script.js.Scripte.CronJobs: In Function
    2024-04-17 19:41:20.001 - error: javascript.0 (706) script.js.Scripte.CronJobs: In Function
    Peterfido
    • P peterfido
      @hschief
      @peterfido
      gilt das bei dir auch:
      @hschief sagte in maximum of 1000 setState during boot:
      Javascript Version 7.8.0
      node 18.17.1
      jscontroller 5.0.19
      P 1 Antwort Letzte Antwort
        @peterfido
        node 18.17.1
        jscontroller 5.0.19
        peterfido
        schrieb am zuletzt editiert von peterfido
        @homoran Steht in der ersten Zeile meines Logs. Mein System ist mit node 18.20.2 aktueller.
        Peterfido
        • H hschief
          @thomas-braun said in maximum of 1000 setState during boot:
          iob nodejs-update
          Update durchgeführt, aktuelle Version ist jetzt: v.18.20.2, Fehler ist aber auch nach dem Update da.
          Noch eine zusätzliche Info, wenn ich nach dem start des IOBrokers ein
          iobroker restart javascript.0 läuft alles sauber.
          Evtl. braucht der JavaScript Adapter andere Dienste die zu diesem Zeitpunkt noch nicht verfügbar sind ... nur eine Idee.
          @peterfido
          mit der gerade gefundenen Antwort
          iob nodejs-update
          seid ihr also was diese Versionen angeht, identisch!
          Sehr gut.
          P H 2 Antworten Letzte Antwort
            @peterfido
            iob nodejs-update
            Sehr gut.
            peterfido
            @homoran Evtl. nützlich: Meine iobroker sind VMs unter proxmox. Die Uhren stehen auf Host.
            Peterfido
              @peterfido
              iob nodejs-update
              Sehr gut.
              hschief
              @homoran ich hatte die Version ja auf anraten hochgezogen, mir ist aber gestern bei der Erstellung des Issues im Debug Log folgendes aufgefallen, was auch durch dein Log hier nochmals bestätigt wird:
              Mein Log fängt direkt mit den Meldungen der Function an und nicht mit der Initialisierung des Javascript Adapters. Jetzt kann es natürlich sein, dass Meldungen auf meinem System nur einfach zeitlich vorher in den Log kommen. Ich vermute aber eher, dass der Adapter aus irgendeinem Grund noch nicht vollständig gestartet ist,
              Shutdown at 13:55:35 -> Boot at 13:59:24
              2024-04-17 13:55:35.534 - ^[[32minfo^[[39m: javascript.0 (2626) terminating
              2024-04-17 13:59:24.355 - ^[[31merror^[[39m: javascript.0 (953) script.js.Technik.Heizung.BootTestScript: In Function
              2024-04-17 13:59:24.410 - ^[[31merror^[[39m: javascript.0 (953) script.js.Technik.Heizung.BootTestScript: In Function
              2024-04-17 13:59:24.441 - ^[[31merror^[[39m: javascript.0 (953) script.js.Technik.Heizung.BootTestScript: In Function
              2024-04-17 13:59:24.475 - ^[[31merror^[[39m: javascript.0 (953) script.js.Technik.Heizung.BootTestScript: In Function
              2024-04-17 13:59:24.492 - ^[[31merror^[[39m: javascript.0 (953) script.js.Technik.Heizung.BootTestScript: In Function
              Vielen Dank fürs testen, somit scheint es kein allgemeiner Fehler sondern eher eine ganz spezielles Zusammenspiel beim booten zu sein. Kann man irgendwo die Reihenfolge der Adapter beim Starten vorgeben?
              W paul53P 2 Antworten Letzte Antwort
              • H hschief
                W Online
                W Online
                Wildbill
                @hschief Ich habe mir angewöhnt, bei einem Neustart des iobroker (also vor dem Reboot nach Kernel-Updates beispielsweise, oder wenn der js-controller ein Update bekommt) einfach vor dem Beenden selbstständig bestimmte Adapter anzuhalten. Bei mir sind das javascript, Sourceanalytix und devicewatcher. Die starte ich dann erst manuell, wenn die restlichen Adapter wieder laufen. Javascript, da anonsten diverse Scripte mit falschen Werten laufen würden, da manche Adapter hier vor dem Start manchmal „falsche“ Werte anzeigen, Sourceanalytix aus demselben Grund, weil beispielsweise Homematic-Stecker mit Strimmessung hier kurz auf 0 springen und der device-watcher, weil sonst Meldungen über viele Offline-Geräte kommen, weil die jeweiligen Adapter eben noch nicht gestartet sind und deren Geräte teilweise bei alive auf false stehen würden.
                Hat sich bewährt bei mir. Ob sich das irgendwie automatisieren lässt, so dass man eine Reihenfolge für Adapterstarts (selbst) einstellen kann, weiss ich nicht. Ich meine, mal gelesen zu haben, dass der Adapter-Ersteller hier zumindest selbst Abhängigkeiten hingterlegen kann, so dass voneinander abhängige Adapter/Instanzen in korrekter Reihenfolge starten.
                Ungeplante Neustarts von iobroker kommen bei mir höchstens mal vor, wenn ein Stromausfall länger dauert, die USVs leer laufen und die Hosts runterfahren ohne dass ich vorher selbst aktiv geworden wäre. Also höchst selten.
                Gruss, Jürgen
                • H hschief
                  @hschief sagte: spezielles Zusammenspiel beim booten zu sein.
                  Es ist mir unerklärlich wie Node.js zwischen Start nach Boot und normalem Neustart von ioBroker unterscheiden kann.
                  Vielleicht passiert etwas Eigenartiges beim Shutdown? Hast du mal ioBroker vor dem Shutdown gestoppt?
                  • H hschief
                    @mcm57 ich folge mal deinem Rat und mache dies unter dem Adapter als Issue auf.
                    Ich habe eben noch folgenden Test gemacht:
                    function Test1() {
                        log('In Function','error');
                        setState('0_userdata.0.Allgemein.TestBoot', 'test', false);
                    log('Script Test1 gestartet:','error');
                    setTimeout(function(){schedule("*/10 * * * * *", Test1 )},50000);
                    Hier müsste beim Boot im Log ja als erstes der Log mit dem Text: "Script Test1 gestartet" erscheinen und dann deutlich später die Meldung: "In Function" alle 10s.
                    Das Ergebnis beim Boot sieht aber wie Folgt aus: 12:51:32 ... letzte Meldung vor dem Shutdown und dann um 12:55:26.076 direkt die Meldung "In Function" ... sieht so aus als würde die schedule Anweisung komplett ignoriert.
                    2024-04-17 12:51:32.643 - ^[[32minfo^[[39m: nina.0 (903) terminating
                    2024-04-17 12:55:26.076 - ^[[31merror^[[39m: javascript.0 (954) script.js.Technik.Heizung.BootTestScript: In Function
                    2024-04-17 12:55:26.140 - ^[[31merror^[[39m: javascript.0 (954) script.js.Technik.Heizung.BootTestScript: In Function
                    2024-04-17 12:55:26.184 - ^[[31merror^[[39m: javascript.0 (954) script.js.Technik.Heizung.BootTestScript: In Function
                    Vielen, Vielen Dank für die Tipps und Ideen!
                    peterfido
                    function Test1() { log('In Function','error'); setState('0_userdata.0.Allgemein.TestBoot', 'test', false); }; log('Script Test1 gestartet:','error'); setTimeout(function(){schedule("*/10 * * * * *", Test1 )},50000);
                    Ich habe das eben mit der Verzögerung getestet.:
                    2024-04-18 11:42:27.863 - info: host.iob instance system.adapter.javascript.0 started with pid 705
                    2024-04-18 11:42:28.702 - info: javascript.0 (705) starting. Version 7.8.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.20.2, js-controller: 5.0.19
                    2024-04-18 11:42:28.931 - info: javascript.0 (705) requesting all states
                    2024-04-18 11:42:28.932 - info: javascript.0 (705) requesting all objects
                    2024-04-18 11:42:29.223 - info: javascript.0 (705) received all objects
                    2024-04-18 11:42:29.269 - info: javascript.0 (705) received all states
                    2024-04-18 11:42:29.383 - info: javascript.0 (705) Start javascript script.js.Scripte.CronJobs
                    2024-04-18 11:42:29.405 - error: javascript.0 (705) script.js.Scripte.CronJobs: Script Test1 gestartet:
                    2024-04-18 11:42:29.406 - info: javascript.0 (705) script.js.Scripte.CronJobs: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-04-18 11:42:31.861 - info: host.iob instance system.adapter.simple-api.0 started with pid 720
                    2024-04-18 11:42:32.347 - info: simple-api.0 (720) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.2, js-controller: 5.0.19
                    2024-04-18 11:42:32.355 - warn: simple-api.0 (720) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                    2024-04-18 11:42:32.358 - info: simple-api.0 (720) simpleAPI server listening on port 8087
                    2024-04-18 11:42:32.358 - info: simple-api.0 (720) Allow states only when user is owner: false
                    2024-04-18 11:42:32.362 - info: simple-api.0 (720) http server listening on port 8087
                    2024-04-18 11:42:35.867 - info: host.iob instance system.adapter.socketio.0 started with pid 735
                    2024-04-18 11:42:36.419 - info: socketio.0 (735) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.20.2, js-controller: 5.0.19
                    2024-04-18 11:42:36.433 - warn: socketio.0 (735) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                    2024-04-18 11:42:36.452 - info: socketio.0 (735) socket.io server listening on port 8088
                    2024-04-18 11:43:20.004 - error: javascript.0 (705) script.js.Scripte.CronJobs: In Function
                    2024-04-18 11:43:30.001 - error: javascript.0 (705) script.js.Scripte.CronJobs: In Function
                    Somit bei mir wie es soll.
                    Peterfido
                    • W Wildbill
                      Gruss, Jürgen
                      haus-automatisierungH Offline
                      @wildbill sagte in maximum of 1000 setState during boot:
                      Genau, es gibt verschiedene Tier-Level, welche die Startreihenfolge festlegen. Damit zB Logikadapter laufen, bevor die ersten Werte kommen
                      📚 Meine Dokumentation
                      H W 2 Antworten Letzte Antwort
                        hschief
                        @haus-automatisierung Vielen Dank für die tollen Antworten und auch die Information, dass der Fehler bei euch nicht reproduziert werden kann, Ich werde das Issue in GitHub erstmal schliessen und weiter forschen um das Problem einzugrenzen. Ich berichte was sich weiter ergibt.
                          W Online
                          W Online
                          Wildbill
                          @haus-automatisierung sagte in maximum of 1000 setState during boot:
                          Also eigentlich genau andersrum, wie ich es manuell mache? Ich starte die Logiken eben erst, wenn alle Werte da sind, damit ich keine falschen Werte verarbeite, die bei manchen Adaptern beim Start auftreten.
                          Die Tier-Level kann man als User aber vermutlich nicht selbst festlegen, oder? Die werden vom Adapter-Ersteller fest eincodiert?
                          Gruss, Jürgen
                          • W Wildbill
                            Gruss, Jürgen
                            oder!
                            vermute ich.
                            Hab im Expertenmodus mal was gesehen, was genau dafür sein könnte
                            DJMarc75D W 2 Antworten Letzte Antwort
                              oder!
                              vermute ich.
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @homoran rischtisch
                              Lehrling seit 1975 !!!
                              W 1 Antwort Letzte Antwort
                                oder!
                                vermute ich.
                                W Online
                                W Online
                                Wildbill
                                @homoran Gerade mal geschaut, Du meinst das hier:
                                Das sieht in der Tat danach aus. Da schraub ich jetzt aber nix rum, meine manuelle Methode funktioniert mindestens genausogut. 😊
                                Gruss, Jürgen
                                • DJMarc75D DJMarc75
                                  @homoran rischtisch
                                  W Online
                                  W Online
                                  Wildbill
                                  @djmarc75 Gibt es einen Grund, warum logikverarbeitende Adapter da als Erstes gestartet werden? Es gibt ja doch einige Adapter, bei denen zum Start eben nicht alle Werte der „Wahrheit“ entsprechen. Die Logik da als Letztes zu starten erscheint mir da eher „logisch“. Oder gibt es gute Gründe, die ich gar nicht sehe?
                                  Gruss, Jürgen
                                  DJMarc75D mcm1957M 2 Antworten Letzte Antwort
                                  • W Wildbill
                                    Gruss, Jürgen
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    kann ich Dir leider nicht beantworten, habe mich damit noch nicht beschäftigt.
                                    • W Wildbill
                                      Gruss, Jürgen
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @wildbill
                                      Einer der Gründe ist (wahrscheinlich) dass man sicherstellen will, dass eine Logik anspricht wenn der Adapter einen (neuen) Wert schreibt. Wird der javascript erst noch dem Adapterstart gestartet dann kann er ev auf das Setzen eines Zustands (via subscription) nicht mehr reagieren weil er das Setzen gar nicht mitbekommt.
                                      Bezüglich device-watcher rege ich an da einen Feature Request beim Adapter zu erstellen. Es erscheint mir sinnvoll wenn der Devicewatcher selbst eine gewisse Zeit nach seinem Start wartet bevor er prüft / alamiert.
                                      Und ja man kann die Startsequenz im grob einstellen. Es gibt 3 Tiers die in der Reihenfolge 1 - 2 - 3 gestartet werden. Aller Adapter innerhalb einers Tiers werden in nicht festgelegter Reihenfolge gestartet. Diese Einstellung kann vom User vorgenommen werden wobei es wahrscheinlich weniger Sinn macht eine vis in Tier 1 zu legen :-).
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • W Online
                                        W Online
                                        Wildbill
                                        @mcm57 Danke für die Erläuterungen. Issue bzw. feature request habe ich bei device watcher mal erstellt.
                                        Bezüglich JavascriptAdapter. Genau deshalb beende ich ihn ja vorab manuell. Gewisse Adapter bzw. Geräte haben die Angewohnheit, beim Start kurz mal auf 0 zu springen und dann erst wieder auf den korrekten Wert. Ich meine, bei Homematic-Zwischensteckern mit Strommessung war das bei mir so bei aktueller Leistung und kumuliertem Wert. Das hat eben Scripte dann falsch ausgelöst und beim Sourceanalytix jedesmal die Meldung gebracht, der Wert hätte sich resettet. Da war/ist es mir lieber, bei Systemstart erstmal quasi die erste Änderung nicht mitzubekommen und dann eben erst, wenn sich alle "beruhigt" hat und die Werte "stabil" sind.
                                        Vielleicht mache ich bei Gelegenheit nochmal einen Test und beende keinen Adapter manuell und schaue, wie es sich mittlerweile verhält. Denn ich mache das bestimmt schon seit 1-2 Jahren so (problemlos).
                                        Gruss, Jürgen
                                        • W Wildbill
                                          Gruss, Jürgen
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @wildbill
                                          Ich glaub es wird schwierig da eine für alle System passende Lösung zu finden. Wenn es aber Adapter gibt die beim Start den Wert mal so auf 0 setzen, dann kann man da ruhig auch ein Issue erstellen damit der Maintainer schaut ob es dafür einen technischen Grund gibt oder ob nur irgendwo eine an sich unnötige Initialisierung erfolgt.
                                          @peterfido
                                          Ev. check mal ob ev. beim Start von ioBroker im Zuge eine Bootvorgangs die Systemzeit (noch) nicht stimmt (RTC ev defekt / verstellt?) und diese dann erst zeitnahe aktualisisert wird z.B. durch NTP Daemon. Ist aber nur so mal ein Idee ohne dass ich sowas schon mal erlebt hätte.
