  4. Lösung für Türklingel
    5.1k
homematictürklingel
44 Beiträge 7 Kommentatoren 4.7k Aufrufe 2 Beobachtet
  • surfer09S surfer09
    Ich habe gerade nochmal alles neu gestartet. Es taucht immer dann ".. no matching device" auf
    2024-04-01 10:17:36.654 - info: host.IOBroker-Server iobroker.js-controller version 5.0.19 js-controller starting
    2024-04-01 10:17:36.657 - info: host.IOBroker-Server Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-04-01 10:17:36.658 - info: host.IOBroker-Server hostname: IOBroker-Server, node: v18.20.0
    2024-04-01 10:17:36.658 - info: host.IOBroker-Server ip addresses: 192.168.1.25
    2024-04-01 10:17:36.666 - warn: host.IOBroker-Server-Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    2024-04-01 10:17:38.430 - warn: host.IOBroker-Server-Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    2024-04-01 10:17:38.625 - info: host.IOBroker-Server connected to Objects and States
    2024-04-01 10:17:38.651 - info: host.IOBroker-Server added notifications configuration of host
    2024-04-01 10:17:39.041 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.nodeCurrent"
    2024-04-01 10:17:39.043 - info: host.IOBroker-Server 40 instances found
    2024-04-01 10:17:39.077 - info: host.IOBroker-Server starting 29 instances
    2024-04-01 10:17:39.180 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.nodeNewest"
    2024-04-01 10:17:39.182 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.nodeNewestNext"
    2024-04-01 10:17:39.194 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.npmCurrent"
    2024-04-01 10:17:39.207 - info: host.IOBroker-Server instance system.adapter.admin.0 started with pid 7328
    2024-04-01 10:17:39.211 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.npmNewest"
    2024-04-01 10:17:39.215 - info: host.IOBroker-Server Delete state "system.host.IOBroker-Server.versions.npmNewestNext"
    2024-04-01 10:17:39.218 - info: host.IOBroker-Server Some obsolete host states deleted.
    2024-04-01 10:17:41.458 - error: admin.0 (7328) admin.0 already running
    2024-04-01 10:17:41.459 - warn: admin.0 (7328) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:17:42.024 - error: host.IOBroker-Server instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:17:42.024 - info: host.IOBroker-Server Restart adapter system.adapter.admin.0 because enabled
    2024-04-01 10:17:43.709 - info: host.IOBroker-Server instance system.adapter.javascript.0 started with pid 7444
    2024-04-01 10:17:45.116 - error: javascript.0 (7444) javascript.0 already running
    2024-04-01 10:17:45.117 - warn: javascript.0 (7444) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:17:45.685 - error: host.IOBroker-Server instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:17:45.685 - info: host.IOBroker-Server Restart adapter system.adapter.javascript.0 because enabled
    2024-04-01 10:17:47.127 - info: host.IOBroker-Server instance system.adapter.node-red.0 started with pid 7492
    2024-04-01 10:17:47.717 - error: node-red.0 (7492) node-red.0 already running
    2024-04-01 10:17:47.718 - warn: node-red.0 (7492) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:17:48.266 - error: host.IOBroker-Server instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:17:48.266 - info: host.IOBroker-Server Restart adapter system.adapter.node-red.0 because enabled
    2024-04-01 10:17:51.138 - info: host.IOBroker-Server instance system.adapter.sql.0 started with pid 8340
    2024-04-01 10:17:51.786 - error: sql.0 (8340) sql.0 already running
    2024-04-01 10:17:51.787 - warn: sql.0 (8340) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:17:52.345 - error: host.IOBroker-Server instance system.adapter.sql.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:17:52.345 - info: host.IOBroker-Server Restart adapter system.adapter.sql.0 because enabled
    2024-04-01 10:17:55.139 - info: host.IOBroker-Server instance system.adapter.telegram.2 started with pid 9264
    2024-04-01 10:17:56.368 - error: telegram.2 (9264) telegram.2 already running
    2024-04-01 10:17:56.369 - warn: telegram.2 (9264) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:17:56.939 - error: host.IOBroker-Server instance system.adapter.telegram.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:17:56.939 - info: host.IOBroker-Server Restart adapter system.adapter.telegram.2 because enabled
    2024-04-01 10:17:59.136 - info: host.IOBroker-Server instance system.adapter.hm-rega.0 started with pid 9512
    2024-04-01 10:17:59.950 - error: hm-rega.0 (9512) hm-rega.0 already running
    2024-04-01 10:17:59.951 - warn: hm-rega.0 (9512) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:00.514 - error: host.IOBroker-Server instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:00.514 - info: host.IOBroker-Server Restart adapter system.adapter.hm-rega.0 because enabled
    2024-04-01 10:18:03.178 - info: host.IOBroker-Server instance system.adapter.hm-rpc.0 started with pid 9744
    2024-04-01 10:18:03.919 - debug: hm-rpc.0 (9744) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2024-04-01 10:18:03.936 - debug: hm-rpc.0 (9744) Objects client ready ... initialize now
    2024-04-01 10:18:03.937 - debug: hm-rpc.0 (9744) Objects create System PubSub Client
    2024-04-01 10:18:03.937 - debug: hm-rpc.0 (9744) Objects create User PubSub Client
    2024-04-01 10:18:03.958 - debug: hm-rpc.0 (9744) Objects client initialize lua scripts
    2024-04-01 10:18:03.961 - debug: hm-rpc.0 (9744) Objects connected to redis: 0.0.0.0:9001
    2024-04-01 10:18:03.984 - debug: hm-rpc.0 (9744) Redis States: Use Redis connection: 0.0.0.0:9000
    2024-04-01 10:18:03.992 - debug: hm-rpc.0 (9744) States create System PubSub Client
    2024-04-01 10:18:03.992 - debug: hm-rpc.0 (9744) States create User PubSub Client
    2024-04-01 10:18:04.007 - debug: hm-rpc.0 (9744) States connected to redis: 0.0.0.0:9000
    2024-04-01 10:18:04.011 - error: hm-rpc.0 (9744) hm-rpc.0 already running
    2024-04-01 10:18:04.012 - debug: hm-rpc.0 (9744) Plugin sentry destroyed
    2024-04-01 10:18:04.012 - warn: hm-rpc.0 (9744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:04.565 - error: host.IOBroker-Server instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:04.565 - info: host.IOBroker-Server Restart adapter system.adapter.hm-rpc.0 because enabled
    2024-04-01 10:18:07.124 - info: host.IOBroker-Server instance system.adapter.hm-rpc.1 started with pid 10088
    2024-04-01 10:18:07.764 - error: hm-rpc.1 (10088) hm-rpc.1 already running
    2024-04-01 10:18:07.765 - warn: hm-rpc.1 (10088) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:08.329 - error: host.IOBroker-Server instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:08.330 - info: host.IOBroker-Server Restart adapter system.adapter.hm-rpc.1 because enabled
    2024-04-01 10:18:11.150 - info: host.IOBroker-Server instance scheduled system.adapter.ical.0 */25 * * * *
    2024-04-01 10:18:11.153 - info: host.IOBroker-Server instance system.adapter.ical.0 started with pid 9604
    2024-04-01 10:18:12.054 - info: host.IOBroker-Server instance system.adapter.admin.0 started with pid 9044
    2024-04-01 10:18:12.981 - info: admin.0 (9044) starting. Version 6.13.16 in I:/ioBroker/node_modules/iobroker.admin, node: v18.20.0, js-controller: 5.0.19
    2024-04-01 10:18:12.990 - info: admin.0 (9044) requesting all objects
    2024-04-01 10:18:13.613 - info: admin.0 (9044) received all objects
    2024-04-01 10:18:13.779 - info: admin.0 (9044) Request actual repository...
    2024-04-01 10:18:13.787 - info: admin.0 (9044) socket.io server listening on port 8081
    2024-04-01 10:18:13.789 - info: admin.0 (9044) http server listening on port 8081
    2024-04-01 10:18:13.789 - info: admin.0 (9044) Use link "http://127.0.0.1:8081" to configure.
    2024-04-01 10:18:13.863 - error: host.IOBroker-Server cannot call visUtils: Not exists
    2024-04-01 10:18:14.048 - info: host.IOBroker-Server Updating repository "Stable" under "http://iobroker.live/repo/sources-dist.json"
    2024-04-01 10:18:14.731 - info: admin.0 (9044) Repository received successfully.
    2024-04-01 10:18:15.066 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:15.069 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:15.103 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:15.115 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:15.137 - info: host.IOBroker-Server instance system.adapter.mielecloudservice.0 started with pid 10216
    2024-04-01 10:18:15.476 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:16.098 - info: host.IOBroker-Server instance system.adapter.javascript.0 started with pid 10140
    2024-04-01 10:18:16.108 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:16.110 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:16.111 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:16.206 - warn: host.IOBroker-Server "system.host.IOBROKER-SLAVE-WINDOWS" is offline
    2024-04-01 10:18:16.210 - error: mielecloudservice.0 (10216) mielecloudservice.0 already running
    2024-04-01 10:18:16.211 - warn: mielecloudservice.0 (10216) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:16.803 - error: host.IOBroker-Server instance system.adapter.mielecloudservice.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:16.804 - info: host.IOBroker-Server Restart adapter system.adapter.mielecloudservice.0 because enabled
    2024-04-01 10:18:17.059 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:17.062 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:17.839 - info: host.IOBroker-Server instance system.adapter.mielecloudservice.0 started with pid 1508
    2024-04-01 10:18:18.312 - info: host.IOBroker-Server instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-04-01 10:18:18.333 - info: host.IOBroker-Server instance system.adapter.node-red.0 started with pid 2988
    2024-04-01 10:18:19.124 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:19.205 - info: host.IOBroker-Server instance system.adapter.synology.0 started with pid 6324
    2024-04-01 10:18:20.066 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:20.068 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:20.097 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:20.098 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:20.339 - error: synology.0 (6324) synology.0 already running
    2024-04-01 10:18:20.341 - warn: synology.0 (6324) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:20.896 - error: host.IOBroker-Server instance system.adapter.synology.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:20.896 - info: host.IOBroker-Server Restart adapter system.adapter.synology.0 because enabled
    2024-04-01 10:18:21.063 - info: admin.0 (9044) ==> Connected system.user.admin from ::ffff:192.168.1.4
    2024-04-01 10:18:21.066 - info: admin.0 (9044) <== Disconnect system.user.admin from ::ffff:192.168.1.4 admin
    2024-04-01 10:18:21.276 - error: javascript.0 (10140) npm
    2024-04-01 10:18:21.277 - error: javascript.0 (10140) WARN deprecated har-validator@5.1.5: this library is no longer supported
    2024-04-01 10:18:21.352 - error: host.IOBroker-Server cannot call visUtils: Not exists
    2024-04-01 10:18:21.432 - error: javascript.0 (10140) npm
    2024-04-01 10:18:21.433 - error: javascript.0 (10140) WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    2024-04-01 10:18:21.601 - error: javascript.0 (10140) npm
    2024-04-01 10:18:21.602 - error: javascript.0 (10140) WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    2024-04-01 10:18:21.612 - error: javascript.0 (10140) npm
    2024-04-01 10:18:21.613 - error: javascript.0 (10140)
    2024-04-01 10:18:21.613 - error: javascript.0 (10140) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    2024-04-01 10:18:22.440 - info: host.IOBroker-Server instance system.adapter.sql.0 started with pid 7900
    2024-04-01 10:18:23.143 - info: host.IOBroker-Server instance system.adapter.alexa2.0 started with pid 608
    2024-04-01 10:18:24.405 - error: alexa2.0 (608) alexa2.0 already running
    2024-04-01 10:18:24.407 - warn: alexa2.0 (608) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:24.978 - error: host.IOBroker-Server instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:24.979 - info: host.IOBroker-Server Restart adapter system.adapter.alexa2.0 because enabled
    2024-04-01 10:18:25.114 - warn: node-red.0 (2988) Node-RED: 1 Apr 10:18:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2024-04-01 10:18:25.124 - warn: node-red.0 (2988) Node-RED: 1 Apr 10:18:25 - [warn] Encrypted credentials not found
    2024-04-01 10:18:26.993 - info: host.IOBroker-Server instance system.adapter.telegram.2 started with pid 9196
    2024-04-01 10:18:27.135 - info: host.IOBroker-Server instance system.adapter.sonos.0 started with pid 9292
    2024-04-01 10:18:28.148 - error: sonos.0 (9292) sonos.0 already running
    2024-04-01 10:18:28.150 - warn: sonos.0 (9292) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:28.705 - error: host.IOBroker-Server instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:28.705 - info: host.IOBroker-Server Restart adapter system.adapter.sonos.0 because enabled
    2024-04-01 10:18:30.558 - info: host.IOBroker-Server instance system.adapter.hm-rega.0 started with pid 8108
    2024-04-01 10:18:31.121 - info: host.IOBroker-Server instance system.adapter.sun2000.0 started with pid 9608
    2024-04-01 10:18:31.512 - info: hm-rega.0 (8108) starting. Version 4.0.0 in I:/ioBroker/node_modules/iobroker.hm-rega, node: v18.20.0, js-controller: 5.0.19
    2024-04-01 10:18:31.574 - info: hm-rega.0 (8108) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
    2024-04-01 10:18:31.622 - info: hm-rega.0 (8108) ReGaHSS 192.168.1.100 up
    2024-04-01 10:18:31.651 - info: hm-rega.0 (8108) time difference local-ccu 1s
    2024-04-01 10:18:31.785 - info: hm-rega.0 (8108) request state values
    2024-04-01 10:18:32.158 - error: sun2000.0 (9608) sun2000.0 already running
    2024-04-01 10:18:32.159 - warn: sun2000.0 (9608) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:32.626 - info: hm-rega.0 (8108) Updated all datapoints
    2024-04-01 10:18:32.720 - error: host.IOBroker-Server instance system.adapter.sun2000.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:32.720 - info: host.IOBroker-Server Restart adapter system.adapter.sun2000.0 because enabled
    2024-04-01 10:18:32.767 - info: hm-rega.0 (8108) added/updated 1 objects
    2024-04-01 10:18:32.779 - info: hm-rega.0 (8108) update rooms to enum.rooms
    2024-04-01 10:18:34.609 - info: host.IOBroker-Server instance system.adapter.hm-rpc.0 started with pid 10168
    2024-04-01 10:18:35.139 - info: host.IOBroker-Server instance system.adapter.zigbee.0 started with pid 8968
    2024-04-01 10:18:35.319 - debug: hm-rpc.0 (10168) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2024-04-01 10:18:35.338 - debug: hm-rpc.0 (10168) Objects client ready ... initialize now
    2024-04-01 10:18:35.339 - debug: hm-rpc.0 (10168) Objects create System PubSub Client
    2024-04-01 10:18:35.339 - debug: hm-rpc.0 (10168) Objects create User PubSub Client
    2024-04-01 10:18:35.361 - debug: hm-rpc.0 (10168) Objects client initialize lua scripts
    2024-04-01 10:18:35.365 - debug: hm-rpc.0 (10168) Objects connected to redis: 0.0.0.0:9001
    2024-04-01 10:18:35.382 - debug: hm-rpc.0 (10168) Redis States: Use Redis connection: 0.0.0.0:9000
    2024-04-01 10:18:35.389 - debug: hm-rpc.0 (10168) States create System PubSub Client
    2024-04-01 10:18:35.390 - debug: hm-rpc.0 (10168) States create User PubSub Client
    2024-04-01 10:18:35.406 - debug: hm-rpc.0 (10168) States connected to redis: 0.0.0.0:9000
    2024-04-01 10:18:35.425 - debug: hm-rpc.0 (10168) Plugin sentry Initialize Plugin (enabled=true)
    2024-04-01 10:18:35.559 - info: hm-rpc.0 (10168) starting. Version 1.16.0 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v18.20.0, js-controller: 5.0.19
    2024-04-01 10:18:35.613 - info: hm-rpc.0 (10168) xmlrpc server is trying to listen on 192.168.1.25:2001
    2024-04-01 10:18:35.613 - info: hm-rpc.0 (10168) xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:18:35.614 - debug: hm-rpc.0 (10168) Connect...
    2024-04-01 10:18:35.614 - debug: hm-rpc.0 (10168) xmlrpc -> 192.168.1.100:2001/ init ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:18:35.619 - debug: hm-rpc.0 (10168) start connecting interval
    2024-04-01 10:18:35.631 - info: hm-rpc.0 (10168) xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:18:35.636 - info: hm-rpc.0 (10168) xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:18:35.637 - debug: hm-rpc.0 (10168) No suitable Lua script, fallback to keys!: function(doc) {
    if (doc._id.match(/^hm-rpc\.[0-9]+\.\*?[A-Za-z0-9_-]+(\.[0-9]+)?$/)) {
    emit(doc._id, {ADDRESS:(doc.native?doc.native.ADDRESS:''),VERSION:(doc.native?doc.native.VERSION:'')});
    2024-04-01 10:18:35.654 - info: hm-rpc.0 (10168) xmlrpc -> 94 devices
    2024-04-01 10:18:35.681 - info: hm-rpc.0 (10168) Connected
    2024-04-01 10:18:35.682 - debug: hm-rpc.0 (10168) clear connecting interval
    2024-04-01 10:18:35.682 - debug: hm-rpc.0 (10168) start ping interval
    2024-04-01 10:18:35.682 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,LEQ0568108:0,STICKY_UNREACH,true
    2024-04-01 10:18:35.682 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","LEQ0568108:0","STICKY_UNREACH",true]
    2024-04-01 10:18:35.682 - debug: hm-rpc.0 (10168) hm-rpc.0.LEQ0568108.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,LEQ0796944:0,CONFIG_PENDING,true
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","LEQ0796944:0","CONFIG_PENDING",true]
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) hm-rpc.0.LEQ0796944.0.CONFIG_PENDING ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,LEQ1003243:0,STICKY_UNREACH,true
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","LEQ1003243:0","STICKY_UNREACH",true]
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) hm-rpc.0.LEQ1003243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:35.683 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,MEQ0641207:0,CONFIG_PENDING,true
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","MEQ0641207:0","CONFIG_PENDING",true]
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) hm-rpc.0.MEQ0641207.0.CONFIG_PENDING ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,OEQ0015243:0,STICKY_UNREACH,true
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","OEQ0015243:0","STICKY_UNREACH",true]
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) hm-rpc.0.OEQ0015243.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103,QEQ2009724:0,STICKY_UNREACH,true
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103","QEQ2009724:0","STICKY_UNREACH",true]
    2024-04-01 10:18:35.684 - debug: hm-rpc.0 (10168) hm-rpc.0.QEQ2009724.0.STICKY_UNREACH ==> UNIT: "" (min: undefined, max: undefined) From "true" => "true"
    2024-04-01 10:18:37.053 - error: zigbee.0 (8968) zigbee.0 already running
    2024-04-01 10:18:37.055 - warn: zigbee.0 (8968) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:37.619 - error: host.IOBroker-Server instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:37.619 - info: host.IOBroker-Server Restart adapter system.adapter.zigbee.0 because enabled
    2024-04-01 10:18:37.663 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,BOOT,true
    2024-04-01 10:18:37.663 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","BOOT",true]
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.BOOT:true discarded, no matching device
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,ENERGY_COUNTER,91511.6
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","ENERGY_COUNTER",91511.6]
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.ENERGY_COUNTER:91511.6 discarded, no matching device
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,POWER,68.1
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","POWER",68.1]
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.POWER:68.1 discarded, no matching device
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,CURRENT,535
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","CURRENT",535]
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.CURRENT:535 discarded, no matching device
    2024-04-01 10:18:37.664 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,VOLTAGE,226.1
    2024-04-01 10:18:37.665 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","VOLTAGE",226.1]
    2024-04-01 10:18:37.665 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.VOLTAGE:226.1 discarded, no matching device
    2024-04-01 10:18:37.665 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0533995:2,FREQUENCY,49.97
    2024-04-01 10:18:37.665 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0533995:2","FREQUENCY",49.97]
    2024-04-01 10:18:37.665 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0533995.2.FREQUENCY:49.97 discarded, no matching device
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0568108:1,TEMPERATURE,9.7
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0568108:1","TEMPERATURE",9.7]
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0568108.1.TEMPERATURE:9.7 discarded, no matching device
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,LEQ0568108:1,HUMIDITY,89
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","LEQ0568108:1","HUMIDITY",89]
    2024-04-01 10:18:37.669 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.LEQ0568108.1.HUMIDITY:89 discarded, no matching device
    2024-04-01 10:18:38.385 - info: host.IOBroker-Server instance system.adapter.hm-rpc.1 started with pid 9832
    2024-04-01 10:18:39.110 - info: host.IOBroker-Server instance system.adapter.discovery.0 started with pid 9932
    2024-04-01 10:18:39.921 - error: discovery.0 (9932) discovery.0 already running
    2024-04-01 10:18:39.922 - warn: discovery.0 (9932) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:40.479 - error: host.IOBroker-Server instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:40.479 - info: host.IOBroker-Server Restart adapter system.adapter.discovery.0 because enabled
    2024-04-01 10:18:43.769 - info: host.IOBroker-Server instance system.adapter.info.0 started with pid 5448
    2024-04-01 10:18:45.203 - error: info.0 (5448) info.0 already running
    2024-04-01 10:18:45.204 - warn: info.0 (5448) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:45.763 - error: host.IOBroker-Server instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:45.763 - info: host.IOBroker-Server Restart adapter system.adapter.info.0 because enabled
    2024-04-01 10:18:47.134 - info: host.IOBroker-Server instance system.adapter.simple-api.0 started with pid 1712
    2024-04-01 10:18:48.103 - error: simple-api.0 (1712) simple-api.0 already running
    2024-04-01 10:18:48.105 - warn: simple-api.0 (1712) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:48.664 - error: host.IOBroker-Server instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:48.664 - info: host.IOBroker-Server Restart adapter system.adapter.simple-api.0 because enabled
    2024-04-01 10:18:49.723 - info: host.IOBroker-Server instance system.adapter.simple-api.0 started with pid 3944
    2024-04-01 10:18:50.658 - warn: simple-api.0 (3944) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2024-04-01 10:18:50.692 - debug: hm-rpc.0 (10168) [KEEPALIVE] Check if connection is alive
    2024-04-01 10:18:50.693 - debug: hm-rpc.0 (10168) Send PING...
    2024-04-01 10:18:50.700 - debug: hm-rpc.0 (10168) PING ok
    2024-04-01 10:18:50.702 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,CENTRAL,PONG,IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103
    2024-04-01 10:18:50.702 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","CENTRAL","PONG","IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:18:50.702 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.CENTRAL.PONG:IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103 discarded, no matching device
    2024-04-01 10:18:50.935 - info: host.IOBroker-Server instance system.adapter.synology.0 started with pid 7464
    2024-04-01 10:18:51.122 - info: host.IOBroker-Server instance system.adapter.web.0 started with pid 3472
    2024-04-01 10:18:52.126 - error: web.0 (3472) web.0 already running
    2024-04-01 10:18:52.127 - warn: web.0 (3472) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:52.675 - error: host.IOBroker-Server instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:52.675 - info: host.IOBroker-Server Restart adapter system.adapter.web.0 because enabled
    2024-04-01 10:18:55.017 - info: host.IOBroker-Server instance system.adapter.alexa2.0 started with pid 1060
    2024-04-01 10:18:55.094 - info: host.IOBroker-Server instance system.adapter.yahka.2 started with pid 7880
    2024-04-01 10:18:56.492 - error: yahka.2 (7880) yahka.2 already running
    2024-04-01 10:18:56.494 - warn: yahka.2 (7880) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:18:57.065 - error: host.IOBroker-Server instance system.adapter.yahka.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:18:57.065 - info: host.IOBroker-Server Restart adapter system.adapter.yahka.2 because enabled
    2024-04-01 10:18:58.745 - info: host.IOBroker-Server instance system.adapter.sonos.0 started with pid 8608
    2024-04-01 10:18:59.140 - info: host.IOBroker-Server instance system.adapter.jarvis.0 started with pid 6704
    2024-04-01 10:19:00.611 - error: jarvis.0 (6704) jarvis.0 already running
    2024-04-01 10:19:00.611 - warn: jarvis.0 (6704) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:19:01.161 - error: host.IOBroker-Server instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:19:01.161 - info: host.IOBroker-Server Restart adapter system.adapter.jarvis.0 because enabled
    2024-04-01 10:19:02.763 - info: host.IOBroker-Server instance system.adapter.sun2000.0 started with pid 9364
    2024-04-01 10:19:03.111 - info: host.IOBroker-Server instance system.adapter.socketio.0 started with pid 8308
    2024-04-01 10:19:04.146 - error: socketio.0 (8308) socketio.0 already running
    2024-04-01 10:19:04.148 - warn: socketio.0 (8308) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:19:04.682 - error: host.IOBroker-Server instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:19:04.682 - info: host.IOBroker-Server Restart adapter system.adapter.socketio.0 because enabled
    2024-04-01 10:19:05.692 - debug: hm-rpc.0 (10168) [KEEPALIVE] Check if connection is alive
    2024-04-01 10:19:05.692 - debug: hm-rpc.0 (10168) Send PING...
    2024-04-01 10:19:05.700 - debug: hm-rpc.0 (10168) PING ok
    2024-04-01 10:19:05.702 - debug: hm-rpc.0 (10168) xml multicall : IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67,CENTRAL,PONG,IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103
    2024-04-01 10:19:05.702 - debug: hm-rpc.0 (10168) xmlrpc <- event ["IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67","CENTRAL","PONG","IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103"]
    2024-04-01 10:19:05.702 - debug: hm-rpc.0 (10168) xmlrpc <- event: IOBroker-Server:hm-rpc.0:7cec1d0f2b415e054a707b064790aa67.CENTRAL.PONG:IOBroker-Server:hm-rpc.0:27432cc944a84b163a8c42e6a2ea8103 discarded, no matching device
    2024-04-01 10:19:07.126 - info: host.IOBroker-Server instance system.adapter.ws.0 started with pid 9612
    2024-04-01 10:19:07.675 - info: host.IOBroker-Server instance system.adapter.zigbee.0 started with pid 3680
    2024-04-01 10:19:08.106 - error: ws.0 (9612) ws.0 already running
    2024-04-01 10:19:08.108 - warn: ws.0 (9612) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:19:08.756 - error: host.IOBroker-Server instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:19:08.756 - info: host.IOBroker-Server Restart adapter system.adapter.ws.0 because enabled
    2024-04-01 10:19:10.524 - info: host.IOBroker-Server instance system.adapter.discovery.0 started with pid 3152
    2024-04-01 10:19:11.080 - info: host.IOBroker-Server instance system.adapter.echarts.0 started with pid 9748
    2024-04-01 10:19:11.993 - error: echarts.0 (9748) echarts.0 already running
    2024-04-01 10:19:11.994 - warn: echarts.0 (9748) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:19:12.556 - error: host.IOBroker-Server instance system.adapter.echarts.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:19:12.557 - info: host.IOBroker-Server Restart adapter system.adapter.echarts.0 because enabled
    2024-04-01 10:19:13.069 - warn: zigbee.0 (3680) DeviceConfigure: 0x680ae2fffe121dcf TRADFRI on/off switch Failed to configure. When device works is all fine when not wake up the device and check again
    2024-04-01 10:19:15.126 - info: host.IOBroker-Server instance system.adapter.windows-control.0 started with pid 2144
    2024-04-01 10:19:15.823 - info: host.IOBroker-Server instance system.adapter.info.0 started with pid 2644
    2024-04-01 10:19:15.836 - error: windows-control.0 (2144) windows-control.0 already running
    2024-04-01 10:19:15.837 - warn: windows-control.0 (2144) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-01 10:19:16.446 - error: host.IOBroker-Server instance system.adapter.windows-control.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-01 10:19:16.446 - info: host.IOBroker-Server Restart adapter system.adapter.windows-control.0 because enabled
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    @surfer09
    wie gesagt; diesen Fehler hatte ich noch nie.
    Er wird aber offensichtlich nur bei debug ausgewiesen.
    Was kommt denn, wenn du auf Info gehst.
    Danke.
    surfer09S 1 Antwort Letzte Antwort
    • bahnuhrB bahnuhr
      @surfer09
      surfer09S Offline
      surfer09S Offline
      surfer09
      @bahnuhr Mit Info sieht das so aus nach Neustart
      024-04-01 10:35:21.039 - info: hm-rega.0 (9240) starting. Version 4.0.0 in I:/ioBroker/node_modules/iobroker.hm-rega, node: v18.20.0, js-controller: 5.0.19
      2024-04-01 10:35:21.096 - info: hm-rega.0 (9240) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      2024-04-01 10:35:21.147 - info: hm-rega.0 (9240) ReGaHSS 192.168.1.100 up
      2024-04-01 10:35:21.178 - info: hm-rega.0 (9240) time difference local-ccu 0s
      2024-04-01 10:35:21.315 - info: hm-rega.0 (9240) request state values
      2024-04-01 10:35:21.384 - error: host.IOBroker-Server cannot call visUtils: Not exists
      2024-04-01 10:35:21.894 - error: sun2000.0 (6404) sun2000.0 already running
      2024-04-01 10:35:21.895 - warn: sun2000.0 (6404) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-04-01 10:35:22.152 - info: hm-rega.0 (9240) Updated all datapoints
      2024-04-01 10:35:22.264 - info: hm-rega.0 (9240) added/updated 1 objects
      2024-04-01 10:35:22.275 - info: hm-rega.0 (9240) update rooms to enum.rooms
      2024-04-01 10:35:22.440 - error: host.IOBroker-Server instance system.adapter.sun2000.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-04-01 10:35:22.441 - info: host.IOBroker-Server Restart adapter system.adapter.sun2000.0 because enabled
      2024-04-01 10:35:24.195 - info: host.IOBroker-Server instance system.adapter.hm-rpc.0 started with pid 9280
      2024-04-01 10:35:24.764 - info: host.IOBroker-Server instance system.adapter.zigbee.0 started with pid 3708
      2024-04-01 10:35:25.055 - info: hm-rpc.0 (9280) starting. Version 1.16.0 in I:/ioBroker/node_modules/iobroker.hm-rpc, node: v18.20.0, js-controller: 5.0.19
      2024-04-01 10:35:25.118 - info: hm-rpc.0 (9280) xmlrpc server is trying to listen on 192.168.1.25:2001
      2024-04-01 10:35:25.119 - info: hm-rpc.0 (9280) xmlrpc client is trying to connect to 192.168.1.100:2001/ with ["http://192.168.1.25:2001","IOBroker-Server:hm-rpc.0:7b460713fdc3b2fbb893549b6d0365ac"]
      2024-04-01 10:35:25.135 - info: hm-rpc.0 (9280) xmlrpc <- system.listMethods ["IOBroker-Server:hm-rpc.0:7b460713fdc3b2fbb893549b6d0365ac"]
      2024-04-01 10:35:25.140 - info: hm-rpc.0 (9280) xmlrpc <- listDevices ["IOBroker-Server:hm-rpc.0:7b460713fdc3b2fbb893549b6d0365ac"]
      2024-04-01 10:35:25.159 - info: hm-rpc.0 (9280) xmlrpc -> 94 devices
      2024-04-01 10:35:25.187 - info: hm-rpc.0 (9280) Connected
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @surfer09
        zumindest ist das "no matching" weg.
        Kann dir nicht sagen, was das ist.
        Hatte meine HM Adapter noch nie (glaub ich) auf debug.
        mfg
        Danke.
        • bahnuhrB bahnuhr
          @surfer09
          mfg
          surfer09S Offline
          surfer09S Offline
          surfer09
          @bahnuhr OKay ich denke, ich tausche dann im ersten Schott mal die Funkschnittstelle aus gegen die Tasterschnittstelle. Mal sehen, ob das damit besser wird.
          bahnuhrB haselchenH 2 Antworten Letzte Antwort
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @surfer09
            Ja, mach das.
            Bei mir keine Probleme damit.
            Danke.
              haselchenH Offline
              haselchenH Offline
              haselchen
              @surfer09 sagte in Lösung für Türklingel:
              Zusätzlich, einfach nur um mal alles beleuchtet zu haben,
              hast Du im HM-Rega Polling aktiviert?
              Wenn ja, wieviel Sekunden?
              Dann im HM-RPC :
              Habe ich die Standardintervalle gelassen.
              Kann ja evtl. sein, dass deine gewählte Zeit zu Problemen führt.
              Das sind so die Unterschiede, die ich zu meinen Einstellungen feststellen konnte.
              • haselchenH haselchen
                Dann im HM-RPC :
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                @surfer09
                Da es sich um eine Art von Timing Problem zu handeln scheint, wenn die Fehler nach einem Adapter-Neustart nicht mehr auftreten, hätte ich noch die Idee, an der Startreihenfolge des Adapters zu schrauben. Standardmäßig wird der hm-rpc Adapter als "Data Provider" eingestuft. Wenn du das auf 3 (Other) änderst, startet der Adapter später in der Reihenfolge. Vielleicht bringt das was?
                EDIT: falsch referenziert
                haselchenH surfer09S 3 Antworten Letzte Antwort
                • Marc BergM Marc Berg
                  @surfer09
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @marc-berg
                  Ich bin nicht derjenige mit dem Problem ;)
                    @surfer09
                    surfer09S Offline
                    surfer09S Offline
                    surfer09
                    @marc-berg Ich teste das mal aus! Danke für den Tipp!
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @surfer09
                      Ja ,ne, ich hab einfach aus Langeweile geschrieben 😂
                      Vielleicht probierst Du es auch mal aus oder antwortest zumindest 😉
                        @surfer09
                        surfer09S Offline
                        surfer09S Offline
                        surfer09
                        @haselchen Dickes Sorry, hatte deine Antwort überlesen. Aber jetzt!
                        Wo kann ich das Polling im HM-Rega aktivieren/prüfen?
                        Die Anpassung vom Interval unter RM-RPC ändert nichts an dem Verhalten. Das habe ich gerade getestet.
                          @surfer09
                          surfer09S Offline
                          surfer09S Offline
                          surfer09
                          schrieb am zuletzt editiert von surfer09
                          @marc-berg Habe ich auch gerade getestet. Das bringt leider auch keinen Erfolg. Nach Neustart immer noch das gleiche Problem.
                          E 1 Antwort Letzte Antwort
                            emil70
                            @surfer09
                            in der Instanzeinstellungen: hm-rega.0 ganz unten
                            gruss emil70
                            iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                            • E emil70
                              @surfer09
                              surfer09S Offline
                              surfer09S Offline
                              surfer09
                              Ich habe mir jetzt eine Tasterschnittstelle besorgt, ich bin mir jetzt aber nicht sicher, wie das Ganze zu verkabeln ist. Die Bilder der Türklingel hatte ich ja schon gepostet. Kann mir da vielleicht nochmal jemand helfen?
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @surfer09
                                Ei, du hast doch als Klingel einen normalen Taster
                                Also:
                                Taster Klingel Abgang A -> HM Com
                                Taster Klingel Abgang B -> HM E1
                                Und dann mit Multimeter prüfen ob dies klappt.
                                Alternativ in der ccu schauen ob dies funktioniert.
                                Danke.
                                • bahnuhrB bahnuhr
                                  @surfer09
                                  Also:
                                  surfer09S Offline
                                  surfer09S Offline
                                  surfer09
                                  @bahnuhr: Ja, das sind Taster.
                                  Also würde ich jetzt grün/weiß auf COM und braun/weiß auf E1 setzen und orange/weiß auch auf COM und blau/weiß auf E2? Sorry, ich muss das für Doofe erklärt haben, bin kein Elektriker 🙄
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    bin kein Elektriker
                                    ich auch nicht. Also keine Gewähr.
                                    Erklär doch mal warum an jedem Anschluss 2 Kabel sind.
                                    Wurde ja schon einmal gefragt (glaub ich).
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      bin kein Elektriker
                                      surfer09S Offline
                                      surfer09S Offline
                                      surfer09
                                      @bahnuhr Ich denke mal, weil das so dünne Adern sind und die Leistungslänge über 3m ist. Ich meine, dass es damals mit nur einem Kabel erst nicht geklappt hatte.
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @surfer09
                                        Nein, das glaub ich nicht.
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          @surfer09
                                          surfer09S Offline
                                          surfer09S Offline
                                          surfer09
                                          @bahnuhr Doch, ist tatsächlich so. Die beiden Adern laufen zusammen. Für den ersten Taster funktioniert es auch schon.
