  4. iobroker exit 25 bei Adapter-Update
    1.0k
    6.1k
113 Beiträge 8 Kommentatoren 19.1k Aufrufe 7 Beobachtet
  • Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    @meister-mopper geht irgendwie nicht. Forum sagt Forbidden.
    Siggi0904S 1 Antwort Letzte Antwort
    • Siggi0904S Siggi0904
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-18-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:29:33 up 33 days,  8:01,  2 users,  load average: 1.35, 0.88, 0.56
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Fri 2024-03-29 19:29:33 CET
                 Universal time: Fri 2024-03-29 18:29:33 UTC
                       RTC time: Fri 2024-03-29 18:29:33
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      mario
      /home/mario
      mario adm sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        2.2G        1.4G        282K        824M        2.0G
      Swap:           4.3G        745M        3.5G
      Total:          8.4G        2.9G        4.9G
               3915 M total memory
               2053 M used memory
                853 M active memory
               1458 M inactive memory
               1326 M free memory
                103 M buffer memory
                682 M swap cache
               4092 M total swap
                710 M used swap
               3382 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  552K  392M   1% /run
      /dev/sda1      ext4       45G   15G   29G  34% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1001
      [Sun Feb 25 11:27:43 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Feb 25 11:27:44 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      3.9G    /var/
      3.6G    /var/log
      3.5G    /var/log/journal/06882d2afcc64e848dd2d19ddcda7ca8
      192M    /var/lib
      Archived and active journals take up 3.4G in the file system.
      /opt/iobroker/backups:
      1.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      427M    /opt/iobroker/iobroker-data/
      253M    /opt/iobroker/iobroker-data/files
      121M    /opt/iobroker/iobroker-data/backup-objects
      58M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      11M     /opt/iobroker/iobroker-data/states.jsonl
      9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2139836-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.0
      /usr/bin/node           v18.20.0
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.0-1nodesource1
        Candidate: 18.20.0-1nodesource1
        Version table:
       *** 18.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
              500 https://deb.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      npm ERR! A complete log of this run can be found in: /home/mario/.npm/_logs/2024-03-29T18_29_38_095Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.0  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.11   , installed 2.5.10 [Updatable]
      Objects and States
      Objects:        11175
      States:         9290
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
      Hit:4 https://deb.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1000       48777242   2251117/io.hm-rpc.1
      tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1000       48777186   2251102/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       48777763   2251200/io.sonoff.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       48786319   2251919/deCONZ
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13253      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15905      485/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16266      771/exim4
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       48786373   2251919/deCONZ
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       48776583   2250967/iobroker.js
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       48776590   2250967/iobroker.js
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       48776762   2250988/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       48779211   2251377/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16267      771/exim4
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13259      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15917      485/sshd: /usr/sbin
      udp        0      0 0.0.0.0:56176           0.0.0.0:*                           1000       48789541   2252085/io.javascri
      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1000       48790724   2252163/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15776      441/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       48778696   2251284/io.shelly.0
      udp        0      0 0.0.0.0:50739           0.0.0.0:*                           107        15778      441/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       48786404   2251919/deCONZ
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       48779720   2251427/io.deconz.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14550      362/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13256      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       48778821   2251301/io.mihome-v
      udp6       0      0 :::5353                 :::*                                107        15777      441/avahi-daemon: r
      udp6       0      0 :::48905                :::*                                107        15779      441/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1000       48779722   2251427/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       48779721   2251427/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          13262      1/init
      2024-03-29 19:20:04.276  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-29 19:25:00.017  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2270759
      2024-03-29 19:25:02.457  - info: dwd.0 (2270759) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.0, js-controller: 5.0.19
      2024-03-29 19:25:03.330  - info: dwd.0 (2270759) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-03-29 19:25:03.858  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-29 19:30:00.044  - info: javascript.0 (2252085) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
      2024-03-29 19:30:00.134  - info: javascript.0 (2252085) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
      2024-03-29 19:30:00.219  - info: javascript.0 (2252085) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2024-03-29 19:30:00.254  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2272490
      2024-03-29 19:30:00.333  - info: javascript.0 (2252085) script.js.Skripte.Außen.AstroDaten: Astro: Gültige Zeiten: [aktueller Tag: 3] | [nächster Tag: 10] | [Aktualisiert: 1] | Aktuelle Tageszeit: Abenddämmerung | Kommende Tageszeit: später Abend
      2024-03-29 19:30:04.293  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 2272518
      2024-03-29 19:30:05.861  - info: dwd.0 (2272490) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.0, js-controller: 5.0.19
      2024-03-29 19:30:07.482  - info: dwd.0 (2272490) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-03-29 19:30:08.080  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-29 19:30:08.306  - info: host.iobroker instance system.adapter.ical.0 started with pid 2272531
      2024-03-29 19:30:13.576  - info: daswetter.0 (2272518) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.0, js-controller: 5.0.19
      2024-03-29 19:30:15.818  - info: ical.0 (2272531) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.0, js-controller: 5.0.19
      2024-03-29 19:30:20.880  - info: ical.0 (2272531) processing URL: Müllkalender https://www.web-alltag.de/Dateien/Kalender/Muell.ics
      2024-03-29 19:30:21.118  - info: ical.0 (2272531) processing URL: Urlaub https://calendar.google.com/calendar/ical/hnvmluhmkfu2svcop0cskk6mdo%40group.calendar.google.com/private-e6ba95b8b530eabcc3b46d2269fb571a/basic.ics
      2024-03-29 19:30:21.199  - info: ical.0 (2272531) processing URL: Schichtplan-Roland https://calendar.google.com/calendar/ical/0b4fto81f6n5eq31g7lec9opvo%40group.calendar.google.com/private-ad3e250feb20686095dc9c96ebd91e02/basic.ics
      2024-03-29 19:30:26.993  - info: ical.0 (2272531) Terminated (NO_ERROR): Without reason
      2024-03-29 19:30:27.561  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-03-29 19:30:32.709  - info: daswetter.0 (2272518) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-03-29 19:30:33.245  - info: daswetter.0 (2272518) cleaned everything up...
      2024-03-29 19:30:33.321  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        mario
        /home/mario
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 3915 M total memory
                 2053 M used memory
                  853 M active memory
                 1326 M free memory
                  103 M buffer memory
                  682 M swap cache
                 4092 M total swap
                  710 M used swap
                 3382 M free swap
        *** FILESYSTEM ***
        /var:
        3.9G    /var/
        3.6G    /var/log
        192M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11175
        States:         9290
        Pending Updates: 0
        Meister MopperM Online
        Meister Mopper
        @siggi0904
        Das sieht für mein Verständnis eigentlich gut aus, vielleicht sieht da @Thomas-Braun eine Ursache.
        Proxmox und HA ...
          @siggi0904
          Siggi0904S Offline
          Siggi0904S Offline
          Siggi0904
          @meister-mopper ich würd sagen bei npm sieht es krumm aus.
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @siggi0904
            iob fix hast du schon versucht?
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
              Siggi0904S Offline
              Siggi0904
              ja, inkl. stop und wieder start.
              Da wurden keine Fehler gefunden.
              Fehler bleibt da.
              irgendwas mit node-waf: not found aber wo kommt das her?
              Ich habe heute die node-js Version per apt aktualisiert und das awtrix 3 addon von @haus-automatisierung aktualisiert.
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                @siggi0904
                Jag mal das iob node update script drüber:
                https://forum.iobroker.net/topic/69067/neuer-befehl-iob-nodejs-update
                Schlechter kanns ja kaum werden. BACKUP HAST DU?
                  Fehler bleibt da.
                  @siggi0904
                  Da klemmt es.
                    @siggi0904
                    Da klemmt es.
                    Siggi0904S Offline
                    Siggi0904S Offline
                    Siggi0904
                    @thomas-braun ja, hab ich auch gerade gesehen. Aber wie fixe ich das?
                    Ich habe gerade den iob nodejs-update 18 laufen lassen.
                    Da gab es aber auch keine Fehlermeldungen. Anschließend VM neu gestartet.
                    Dann Versuch eines Updates eines Addons, aber Fehler bleibt.
                    Log vom nodejs-update:
                    ioBroker nodejs updater 2023-10-13
                    You requested to intall latest version from nodejs v18 tree.
                    Your current setup is:
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    We found these nodejs versions available for installation:
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Nothing to do - Your installation is using the correct paths.
                    You are running nodejs v18.20.0. Do you want to install latest version from nodejs v.18 tree?
                    Press <y> to continue or any other key to quit
                    Trying to update your installation now. Please be patient.
                    Virtualization: kvm
                    Waiting for ioBroker to shut down - Give me a minute...
                    *** These repos are active on your system:
                    Reading package lists... Done
                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                    Package: nodejs
                    Pin: origin deb.nodesource.com
                    Pin-Priority: 1001
                    *** These repos are active after the adjustments:
                    Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                    Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [7731 B]
                    Fetched 19.9 kB in 1s (20.4 kB/s)
                    Installing the recommended nodejs version now!
                    Installing the recommended nodejs version!
                    *** You need to manually restart your container/virtual machine now! ***
                    We tried our best to update or fix your nodejs. Please run 'iob diag' again to verify.
                    mario@iobroker:/opt/iobroker$
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      Virtualization: kvm
                      Package: nodejs
                      Pin-Priority: 1001
                      @siggi0904
                      cd /opt/iobroker
                      npm ls -a | grep xmlbuilder
                        Siggi0904S Offline
                        Siggi0904
                        login as: mario
                        mario@192.168.178.64's password:
                        Linux iobroker 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
                        permitted by applicable law.
                        Last login: Fri Mar 29 20:42:04 2024 from 192.168.178.41
                        mario@iobroker:~$ cd /opt/iobroker
                        mario@iobroker:/opt/iobroker$ npm ls -a | grep xmlbuilder
                        [sudo] Passwort für mario:
                        │   └── xmlbuilder@11.0.1
                        │   └── xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                        │ └── xmlbuilder@15.1.1
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_04_01_416Z-debug-0.log
                          login as: mario
                          @siggi0904
                          cd /opt/iobroker
                          npm ls xmlbuilder
                            @siggi0904
                            cd /opt/iobroker
                            npm ls xmlbuilder
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            mario@iobroker:/opt/iobroker$ npm ls xmlbuilder
                            iobroker.inst@2.0.3 /opt/iobroker
                            ├─┬ iobroker.hm-rega@4.0.0
                            │ └─┬ xml2js@0.6.2
                            ├─┬ iobroker.hm-rpc@1.16.0
                            │ └─┬ homematic-xmlrpc@1.0.2
                            ├─┬ iobroker.shelly@6.8.0
                            └─┬ iobroker.tr-064@4.2.18
                              └─┬ xml2js@0.4.23
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_12_39_266Z-debug-0.log
                              │ └─┬ xml2js@0.6.2
                                └─┬ xml2js@0.4.23
                              @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
                              iobroker.hm-rpc
                              Installier den nochmal. Ich vermute die Abhängigkeit ist da falsch.
                                iobroker.hm-rpc
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                @thomas-braun Hallo, wie? ggf. mit Debug, dass man sieht was da passiert.
                                Wundert mich aber, weil der schon ewig läuft.
                                  @siggi0904
                                  Du hast da irgendein steinaltes Modul im Setup, das mit node-waf gebaut werden soll. Nur ist das seit mehreren Jahren obsolet und durch node-gyp ersetzt worden. Man müsste mal irgendwie schauen was das sein könnte. Vermutlich der xmlbuilder@0.4.2, der ist ja auch komplett veraltet und nicht mehr verlinkt.
                                    @siggi0904
                                    iob update
                                    iob upgrade hm-rpc@1.16.0
                                    iob upgrade all
                                      Siggi0904S Offline
                                      Siggi0904
                                      @thomas-braun oh, wie kommt das da hin?
                                      Wie kann ich iobroker.hm-rpc nochmal installieren?
                                        @siggi0904
                                        iob update
                                        iob upgrade all
                                        Siggi0904S Offline
                                        Siggi0904S Offline
                                        Siggi0904
                                        @thomas-braun sagte in iobroker exit 25 bei Adapter-Update:
                                        hm, misst. Bleibt auch so erhalten, der Fehler.
                                        mario@iobroker:/opt/iobroker$ iob update
                                        mario@iobroker:/opt/iobroker$ iob upgrade hm-rpc@1.16.0
                                        Would you like to reinstall version 1.16.0 of hm-rpc now? [(y)es, (n)o]: y
                                        Update hm-rpc from @1.16.0 to @1.16.0
                                        NPM version: 10.5.0
                                        Installing iobroker.hm-rpc@1.16.0... (System call)
                                        npm ERR! code 127
                                        npm ERR! path /opt/iobroker/node_modules/zlib
                                        npm ERR! command failed
                                        npm ERR! command sh -c node-waf clean || true; node-waf configure build
                                        npm ERR! sh: 1: node-waf: not found
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-29T20_31_44_159Z-debug-0.log
                                        host.iobroker Cannot install iobroker.hm-rpc@1.16.0: 127
                                          NPM version: 10.5.0
                                          npm ERR! code 127
                                          zlib
                                          npm ls zlib
