  4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
27 Beiträge 4 Kommentatoren 4.2k Aufrufe 4 Beobachtet
    @wauzzi
    bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
    echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
    iobroker.inst@3.0.0 /opt/iobroker
    └── iobroker.ble@0.14.0
    wauzziW Offline
    wauzziW Offline
    wauzzi
    @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
    sieht bei mir ähnlich aus:
    admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
    wird dies denn zwingend für den ble Adapter benötigt ?
    • wauzziW wauzzi
      @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
      sudo -H -u iobroker npm install bluetooth-hci-socket
      admin@iobroker:~ $ cd /opt/iobroker
      admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
      npm ERR! command failed
      npm ERR! command sh -c node-gyp rebuild
      npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
      npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
      npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@10.0.1
      npm ERR! gyp info using node@18.19.0 | linux | arm64
      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args 'binding.gyp',
      npm ERR! gyp info spawn args '-f',
      npm ERR! gyp info spawn args 'make',
      npm ERR! gyp info spawn args '-I',
      npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
      npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
      npm ERR! gyp info spawn args '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args '-Dvisibility=default',
      npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
      npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
      npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
      npm ERR! gyp info spawn args '-Dnode_engine=v8',
      npm ERR! gyp info spawn args '--depth=.',
      npm ERR! gyp info spawn args '--no-parallel',
      npm ERR! gyp info spawn args '--generator-output',
      npm ERR! gyp info spawn args 'build',
      npm ERR! gyp info spawn args '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! gyp info spawn make
      npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
      npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
      npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
      npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
      npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
      npm ERR!       |                                              ^~~~~~~~~~~
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
      npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
      npm ERR! ../../nan/nan.h:1053:46: note: declared here
      npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      npm ERR!       |                                              ^~~~~~~~~~~~
      npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
      npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
      npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
      npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
      npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      npm ERR!       |                                           ^~~
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
      npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      npm ERR!       |                                           ^~~
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
      npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
      npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
      npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
      npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
      npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
      npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
      npm ERR!   395 |       devId = arg0->IntegerValue();
      npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
      npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
      npm ERR!   417 |       devId = arg0->IntegerValue();
      npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
      npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
      npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
      npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
      npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
      npm ERR! gyp ERR! build error
      npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
      npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
      npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
      npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
      npm ERR! gyp ERR! node -v v18.19.0
      npm ERR! gyp ERR! node-gyp -v v10.0.1
      npm ERR! gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
      GlasfaserG Offline
      GlasfaserG Offline
      @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
      keine Ahnung was das mit python3 zu tun hat
      • wauzziW wauzzi
        npm ERR! code 1
        npm ERR!       |                                           ^~~
        npm ERR!       |                                           ^~~
        @wauzzi
        Grundvoraussetzungen sind da?
        sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
        sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
        wauzziW 1 Antwort Letzte Antwort
          @wauzzi
          wauzziW Offline
          wauzziW Offline
          wauzzi
          sudo setcap cap_net_raw+eip $(eval readlink -f which node)
          offensichtlich, ja. Wenn ich dies beurteilen würde
          admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
          Reading package lists... Done
          bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
          bluez is already the newest version (5.66-1+rpt1+deb12u1).
          libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
          libudev-dev is already the newest version (252.22-1~deb12u1).
          libcap2-bin is already the newest version (1:2.66-4).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
          • wauzziW wauzzi
            @wauzzi
            Dann schau dir einen Kaltstart des Adapters per
            iob logs --watch | uniq
            an.
            GlasfaserG wauzziW 2 Antworten Letzte Antwort
              @wauzzi
              an.
              GlasfaserG Offline
              GlasfaserG Offline
              Kommt wohl öfters der Fehler vor :
              https://github.com/AlCalzone/ioBroker.ble/issues/837
                @wauzzi
                an.
                wauzziW Offline
                wauzziW Offline
                wauzzi
                2024-02-10 23:45:58.679  - info: ble.0 (1699) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
                2024-02-10 23:45:58.740  - info: ble.0 (1699) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                2024-02-10 23:45:58.741  - info: ble.0 (1699) enabled plugins: _default
                2024-02-10 23:45:58.741  - info: ble.0 (1699) monitoring all services
                2024-02-10 23:45:58.790  - info: ble.0 (1699) starting scanner process...
                2024-02-10 23:45:58.901  - error: ble.0 (1699) Cannot find module '@abandonware/bluetooth-hci-socket'
                Require stack:
                - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
                - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
                - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
                - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
                - /opt/iobroker/node_modules/@abandonware/noble/index.js
                - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                Require stack:
                • wauzziW wauzzi
                  Require stack:
                  Require stack:
                  @wauzzi
                  Dann versuch
                  cd /opt/iobroker/node_modules
                  sudo -H -u iobroker npm i @abandonware/bluetooth-hci-socket --omit=dev
                    @wauzzi
                    Dann versuch
                    wauzziW Offline
                    wauzziW Offline
                    wauzzi
                    schrieb am zuletzt editiert von wauzzi
                    @wauzzi
                    Dann versuch
                    Ja Geil !!!! Hat geklappt !!! Alles grün und die BT Geräte werden gefunden. MEGA !!!!👯
                    Vielen lieben Dank Thomas
                    Auch vielen lieben an alle anderen die mir versucht haben zu helfen 💞
                    Jetzt kann Charlie wieder selbst nach Hause kommen ;-)
                    https://youtu.be/6ebXPKz4bSc?si=bCU5lA-OjBXOasHM
                    • W Offline
                      W Offline
                      wrod
                      @wauzzi
                      wegen solcher Probleme mit BLE habe ich schon länger ein Skript "fixble.sh" folgenden Inhalts:
                      iobroker stop
                      sudo apt update
                      sudo apt upgrade
                      cd /opt/iobroker/node_modules/iobroker.ble
                      npm install --omit=dev
                      iobroker fix
                      sudo reboot
                      Dieses startet u.a. npm install.
                      Datin wird eine Abfrage gestellt, ob man etwas erneuern will.
                      Ich würde das Skript gerne auch unattended (per cron) laufen lassen. (Wie) kann man dabei erreichen, dass diese Abfrage immer als mit "Y" beantwortet gilt, ohne dass ein Eingriff nötig ist?
                      Dank im Voraus
