  4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
27 Beiträge 4 Kommentatoren 4.2k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
    Ich schätze irgendwo ist der Wurm drin
    du stehst falsch
    cd
    /opt/iobroker
    wauzziW Offline
    wauzziW Offline
    wauzzi
    @glasfaser irgendwie kann er das Verzeichnis nicht erstellen, oder liege ich falsch mit meiner Vermutung ?
    • wauzziW wauzzi
      @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
      du stehst falsch
      cd
      /opt/iobroker
      selbes spiel
      admin@iobroker:~ $ cd /opt/iobroker
      admin@iobroker:/opt/iobroker $ sudo npm install bluetooth-hci-socket
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
      npm ERR! command failed
      npm ERR! command sh -c node-gyp rebuild
      npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
      npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
      npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@10.0.1
      npm ERR! gyp info using node@18.19.0 | linux | arm64
      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args 'binding.gyp',
      npm ERR! gyp info spawn args '-f',
      npm ERR! gyp info spawn args 'make',
      npm ERR! gyp info spawn args '-I',
      npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
      npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.19.0/include/node/common.gypi',
      npm ERR! gyp info spawn args '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args '-Dvisibility=default',
      npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.19.0',
      npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
      npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
      npm ERR! gyp info spawn args '-Dnode_engine=v8',
      npm ERR! gyp info spawn args '--depth=.',
      npm ERR! gyp info spawn args '--no-parallel',
      npm ERR! gyp info spawn args '--generator-output',
      npm ERR! gyp info spawn args 'build',
      npm ERR! gyp info spawn args '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! gyp info spawn make
      npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
      npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
      npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
      npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
      npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:33,
      npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node.h:73,
      npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
      npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
      npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
      npm ERR!       |                                              ^~~~~~~~~~~
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
      npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
      npm ERR! ../../nan/nan.h:1053:46: note: declared here
      npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      npm ERR!       |                                              ^~~~~~~~~~~~
      npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
      npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
      npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
      npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
      npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:24:
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
      npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      npm ERR!       |                                           ^~~
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
      npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      npm ERR!       |                                           ^~~
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
      npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
      npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
      npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
      npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
      npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
      npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
      npm ERR!   395 |       devId = arg0->IntegerValue();
      npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
      npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
      npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
      npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
      npm ERR!   417 |       devId = arg0->IntegerValue();
      npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
      npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
      npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
      npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
      npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
      npm ERR! gyp ERR! build error
      npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
      npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
      npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
      npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
      npm ERR! gyp ERR! node -v v18.19.0
      npm ERR! gyp ERR! node-gyp -v v10.0.1
      npm ERR! gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-02-10T22_11_48_917Z-debug-0.log
      GlasfaserG Offline
      GlasfaserG Offline
      selbes spiel
      sorry habe den Thread nicht ganz dazu gelesen .
      nur das machen ..
      https://forum.iobroker.net/post/151081
      nicht die Befehle darunter !
      wauzziW 1 Antwort Letzte Antwort
        selbes spiel
        nur das machen ..
        wauzziW Offline
        wauzziW Offline
        wauzzi
        @glasfaser Das hatte ich vorhin auch schon versucht. Hab es eben nochmals versucht.
        Scheint aber alles sauber zu sein:
        admin@iobroker:/opt/iobroker $ sudo npm install --production
        npm WARN config production Use `--omit=dev` instead.
        up to date in 3s
        145 packages are looking for funding
          run `npm fund` for details
        admin@iobroker:/opt/iobroker $ npm fund
        iobroker.inst@3.0.0
        ├── https://github.com/sponsors/epoberezkin
        │   └── ajv@6.12.6
        ├── https://github.com/sponsors/jaredhanson
        │   └── passport@0.6.0, oauth2orize@1.11.1
        ├── https://github.com/sponsors/isaacs
        │   └── glob@7.2.3, minimatch@7.4.6, rimraf@3.0.2
        ├── https://github.com/sponsors/feross
        │   └── safe-buffer@5.2.1, base64-js@1.5.1, buffer@6.0.3, simple-concat@1.0.1
        ├── https://github.com/sponsors/RubenVerborgh
        │   └── follow-redirects@1.15.5
        ├── https://github.com/sponsors/ljharb
        │   └── qs@6.10.4, minimist@1.2.8, define-properties@1.2.1, es-abstract@1.22.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.slice@1.0.3, available-typed-arrays@1.0.6, es-to-primitive@1.2.1, is-date-object@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1.2.3, get-symbol-description@1.0.2, globalthis@1.0.3, is-array-buffer@3.0.4, is-callable@1.2.7, is-negative-zero@2.0.2, is-regex@1.1.4, is-shared-array-buffer@1.0.2, is-string@1.0.7, is-typed-array@1.1.13, is-weakref@1.0.2, object.assign@4.1.5, regexp.prototype.flags@1.5.1, safe-array-concat@1.1.0, safe-regex-test@1.0.3, string.prototype.trim@1.2.8, string.prototype.trimend@1.0.7, string.prototype.trimstart@1.0.7, typed-array-byte-length@1.0.0, typed-array-byte-offset@1.0.0, typed-array-length@1.0.4, unbox-primitive@1.0.2, has-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object@1.1.2, is-number-object@1.0.7, which-typed-array@1.1.14, has-tostringtag@1.0.2, traverse@0.6.8
        ├── https://github.com/sponsors/broofa
        │   └── uuid@9.0.1
        ├── https://github.com/sponsors/sindresorhus
        │   └── is-plain-obj@3.0.0, is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, onetime@5.1.2, make-dir@3.1.0, mimic-response@2.1.0, component-emitter@1.3.1, debounce@2.0.0
        ├── https://github.com/sponsors/jonschlinkert
        │   └── picomatch@2.3.1
        ├─┬ https://github.com/sindresorhus/got?sponsor=1
        │ │ └── got@11.8.6
        │ └── https://github.com/sindresorhus/is?sponsor=1
        │     └── @sindresorhus/is@4.6.0
        ├── https://github.com/sponsors/NaturalIntelligence
        │   └── fast-xml-parser@4.3.4
        ├─┬ https://opencollective.com/node-fetch
        │ │ └── node-fetch@3.3.2
        │ └── https://github.com/sponsors/jimmywarting
        │     └── fetch-blob@3.2.0, node-domexception@1.0.0
        ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
        │ │ └── wrap-ansi@7.0.0
        │ └── https://github.com/chalk/ansi-styles?sponsor=1
        │     └── ansi-styles@4.3.0
        ├── https://opencollective.com/serialport/donate
        │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
        ├─┬ https://github.com/chalk/chalk-template?sponsor=1
        │ │ └── chalk-template@0.4.0
        │ └── https://github.com/chalk/chalk?sponsor=1
        │     └── chalk@4.1.2
        ├── https://opencollective.com/date-fns
        │   └── date-fns@2.30.0
        ├── https://opencollective.com/ioredis
        │   └── ioredis@4.28.5
        ├── https://github.com/sindresorhus/execa?sponsor=1
        │   └── execa@5.1.1
        ├── https://paulmillr.com/funding/
        │   └── chokidar@3.6.0
        ├── https://github.com/sponsors/sibiraj-s
        │   └── ci-info@3.9.0
        ├── https://opencollective.com/js-sdsl
        │   └── js-sdsl@4.3.0
        ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
        │ │ └── cheerio@1.0.0-rc.10
        │ ├─┬ https://github.com/sponsors/fb55
        │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.1.0, domelementtype@2.3.0
        │ │ └── https://github.com/fb55/domutils?sponsor=1
        │ │     └── domutils@2.8.0, domutils@3.1.0
        │ ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
        │ │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0
        │ │ └── https://github.com/fb55/entities?sponsor=1
        │ │     └── entities@2.2.0, entities@4.5.0
        │ ├── https://github.com/fb55/domhandler?sponsor=1
        │ │   └── domhandler@4.3.1, domhandler@5.0.3
        │ └── https://github.com/fb55/htmlparser2?sponsor=1
        │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
        ├── https://locize.com
        │   └── i18next@21.10.0
        ├── https://ko-fi.com/killymxi
        │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
        ├── https://github.com/sponsors/3846masa
        │   └── http-cookie-agent@5.0.4
        └── https://github.com/inikulin/parse5?sponsor=1
          └── parse5@7.1.2
        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
        • wauzziW wauzzi
          up to date in 3s
          iobroker.inst@3.0.0
          │   └── ajv@6.12.6
          │   └── uuid@9.0.1
          │ │ └── got@11.8.6
          │     └── chalk@4.1.2
          │   └── execa@5.1.1
          │   └── ci-info@3.9.0
          │   └── js-sdsl@4.3.0
            └── parse5@7.1.2
          GlasfaserG Offline
          GlasfaserG Offline
          @wauzzi
          ins Verzeichniss
          cd /opt/iobroker/node_modules/bluetooth-hci-socket
          dann dort
          Bitte alles in Ruhe lesen , es steht auch dort !!
            @wauzzi
            ins Verzeichniss
            dann dort
            wauzziW Offline
            wauzziW Offline
            wauzzi
            @glasfaser
            Danke für Deine Geduld mit mir 😌
            Das Verzeichnis "opt/iobroker/node_modules/bluetooth-hci-socket" existiert bei mir nicht.
            Ich hab eben nochmals mit dem Winscp geschaut. nicht vorhanden
            • wauzziW wauzzi
              up to date in 3s
              iobroker.inst@3.0.0
              │   └── ajv@6.12.6
              │   └── uuid@9.0.1
              │ │ └── got@11.8.6
              │     └── chalk@4.1.2
              │   └── execa@5.1.1
              │   └── ci-info@3.9.0
              │   └── js-sdsl@4.3.0
                └── parse5@7.1.2
              sudo npm
              Arrrgh. Nie npm in Verbindung mit sudo verwenden.
              • GlasfaserG Offline
                GlasfaserG Offline
                Beim Versuch "npm install bluetooth-hci-socket" durchzuführen
                cd /opt/iobroker
                sudo -H -u iobroker npm install bluetooth-hci-socket
                • wauzziW wauzzi
                  @glasfaser
                  @wauzzi
                  bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
                  echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                  iobroker.inst@3.0.0 /opt/iobroker
                  └── iobroker.ble@0.14.0
                    cd /opt/iobroker
                    wauzziW Offline
                    wauzziW Offline
                    wauzzi
                    admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
                    npm ERR! code 1
                    npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
                    npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
                    npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                    npm ERR!       |                                           ^~~
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                    npm ERR!       |                                           ^~~
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
                      @wauzzi
                      wauzziW Offline
                      wauzziW Offline
                      wauzzi
                      @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
                      sieht bei mir ähnlich aus:
                      admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                      wird dies denn zwingend für den ble Adapter benötigt ?
                      • wauzziW wauzzi
                        npm ERR! code 1
                        npm ERR!       |                                           ^~~
                        npm ERR!       |                                           ^~~
                        GlasfaserG Offline
                        GlasfaserG Offline
                        keine Ahnung was das mit python3 zu tun hat
                        • wauzziW wauzzi
                          npm ERR! code 1
                          npm ERR!       |                                           ^~~
                          npm ERR!       |                                           ^~~
                          @wauzzi
                          Grundvoraussetzungen sind da?
                          sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                            @wauzzi
                            wauzziW Offline
                            wauzziW Offline
                            wauzzi
                            sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                            offensichtlich, ja. Wenn ich dies beurteilen würde
                            admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                            Reading package lists... Done
                            bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
                            bluez is already the newest version (5.66-1+rpt1+deb12u1).
                            libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
                            libudev-dev is already the newest version (252.22-1~deb12u1).
                            libcap2-bin is already the newest version (1:2.66-4).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                            • wauzziW wauzzi
                              @wauzzi
                              Dann schau dir einen Kaltstart des Adapters per
                              iob logs --watch | uniq
                              an.
                              GlasfaserG wauzziW 2 Antworten Letzte Antwort
                                @wauzzi
                                an.
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Kommt wohl öfters der Fehler vor :
                                https://github.com/AlCalzone/ioBroker.ble/issues/837
                                  @wauzzi
                                  an.
                                  wauzziW Offline
                                  wauzziW Offline
                                  wauzzi
                                  2024-02-10 23:45:58.679  - info: ble.0 (1699) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
                                  2024-02-10 23:45:58.740  - info: ble.0 (1699) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                  2024-02-10 23:45:58.741  - info: ble.0 (1699) enabled plugins: _default
                                  2024-02-10 23:45:58.741  - info: ble.0 (1699) monitoring all services
                                  2024-02-10 23:45:58.790  - info: ble.0 (1699) starting scanner process...
                                  2024-02-10 23:45:58.901  - error: ble.0 (1699) Cannot find module '@abandonware/bluetooth-hci-socket'
                                  Require stack:
                                  - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
                                  - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
                                  - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
                                  - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
                                  - /opt/iobroker/node_modules/@abandonware/noble/index.js
                                  - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                                  Require stack:
                                  • wauzziW wauzzi
                                    Require stack:
                                    Require stack:
                                    @wauzzi
                                    Dann versuch
                                    sudo -H -u iobroker npm i @abandonware/bluetooth-hci-socket --omit=dev
                                      @wauzzi
                                      Dann versuch
                                      wauzziW Offline
                                      wauzziW Offline
                                      wauzzi
                                      schrieb am zuletzt editiert von wauzzi
                                      @wauzzi
                                      Dann versuch
                                      Ja Geil !!!! Hat geklappt !!! Alles grün und die BT Geräte werden gefunden. MEGA !!!!👯
                                      Vielen lieben Dank Thomas
                                      Auch vielen lieben an alle anderen die mir versucht haben zu helfen 💞
                                      Jetzt kann Charlie wieder selbst nach Hause kommen ;-)
                                      https://youtu.be/6ebXPKz4bSc?si=bCU5lA-OjBXOasHM
                                      • W Offline
                                        W Offline
                                        wrod
                                        @wauzzi
                                        wegen solcher Probleme mit BLE habe ich schon länger ein Skript "fixble.sh" folgenden Inhalts:
                                        iobroker stop
                                        sudo apt update
                                        sudo apt upgrade
                                        cd /opt/iobroker/node_modules/iobroker.ble
                                        npm install --omit=dev
                                        iobroker fix
                                        sudo reboot
                                        Dieses startet u.a. npm install.
                                        Datin wird eine Abfrage gestellt, ob man etwas erneuern will.
                                        Ich würde das Skript gerne auch unattended (per cron) laufen lassen. (Wie) kann man dabei erreichen, dass diese Abfrage immer als mit "Y" beantwortet gilt, ohne dass ein Eingriff nötig ist?
                                        Dank im Voraus
